path: root/include
2008-10-13mfd: Add WM8350 interrupt supportMark Brown
The WM8350 has an interrupt line to the CPU which is shared by the devices on the CPU. This patch adds support for the interrupt controller within the WM8350 which identifies which identifies the interrupt cause. In common with other similar chips this is done outside the standard interrupt framework due to the need to access the interrupt controller over an interrupt-driven bus. This code was all originally written by Liam Girdwood with updates for submission by me. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-10-13mfd: Add initialisation callback for WM8350Mark Brown
Some functions of the WM8350 require board-specific initialisation on startup. Provide a callback to the WM8350 driver in platform data for platforms to use to configure the chip. Use of a callback allows platforms to control the ordering of initialisation which can be important. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-10-13mfd: Add GPIO pin configuration support for WM8350Mark Brown
The WM8350 provides a number of user-configurable pins providing access to various signals generated by the functions on the chip. These are referred to as GPIO pins in the device documentation but in Linux terms they are more general than that, providing configuration of alternate functions. This patch implements support for selecting the alternate functions for these pins. They can also be used as GPIOs in the normal Linux sense - a subsequent patch will add support for doing so. This code was all written by Liam Girdwood and has had minor updates and rearrangements by Mark Brown. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-10-13mfd: Core support for the WM8350 AudioPlus PMICMark Brown
The WM8350 is an integrated audio and power management subsystem intended for use as the primary PMIC in mobile multimedia applications. The WM8350 can be controlled via either I2C or SPI - the control interface is provided by a separate module in order to allow greatest flexibility in configuring the kernel. This driver was originally written by Liam Girdwood and has since been updated to current kernel APIs and split up for submission by me. All the heavy lifting here was done by Liam. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-10-13mfd: Add WM8350 watchdog register definitionsMark Brown
2008-10-13mfd: Add WM8350 RTC register definitionsMark Brown
2008-10-13mfd: Add WM8350 comparator register definitionsMark Brown
2008-10-13mfd: Add WM8350 PMU register definitionsMark Brown
2008-10-13mfd: Add WM8350 PMIC register definitionsMark Brown
2008-10-13mfd: Add WM8350 GPIO register definitionsMark Brown
2008-10-13mfd: Add WM8350 audio register definitionsMark Brown
2008-10-13regulator: Add WM8400 regulator supportMark Brown
The WM8400 provides two programmable DCDC step-down (buck) convertors and four low-dropout (LDO) regulators. This driver provides support for runtime managment of these in the standard regulator API. Support for configuration of the suspend and hibernate mode behaviour of the regulators is not yet included. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-10-13mfd: Core support for the WM8400 AudioPlus HiFi CODEC and PMUMark Brown
The WM8400 is a highly integrated audio CODEC and power management unit optimised for use in mobile multimedia applications. This patch adds core support for the WM8400 to the MFD subsystem. Both I2C and SPI access are supported by the hardware but currently only I2C access is implemented. The code is structured to allow SPI support to be slotted in later. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-10-13regulator: Fix typoMark Brown
2008-10-13regulator: core - Rework machine API to remove string based functions.Liam Girdwood
This improves the machine level API in order to configure regulator constraints and consumers as platform data and removes the old string based API that required several calls to set up each regulator. The intention is to create a struct regulator_init_data, populate it's fields with constraints, consumers devices, etc and then register the regulator device from board.c in the standard Linux way. e.g. regulator LDO2 (supplying codec and sim) platform data. /* regulator LDO2 consumer devices */ static struct regulator_consumer_supply ldo2_consumers[] = { { .dev = &platform_audio_device.dev, .supply = "codec_avdd", }, { .dev = &platform_sim_device.dev, .supply = "sim_vcc", } }; /* regulator LDO2 constraints */ static struct regulator_init_data ldo2_data = { .constraints = { .min_uV = 3300000, .max_uV = 3300000, .valid_modes_mask = REGULATOR_MODE_NORMAL, .apply_uV = 1, }, .num_consumer_supplies = ARRAY_SIZE(ldo2_consumers), .consumer_supplies = ldo2_consumers, }; /* machine regulator devices with thier consumers and constraints */ static struct platform_device wm8350_regulator_devices[] = { { .name = "wm8350-regulator", .id = WM8350_LDO_2, .dev = { .platform_data = &ldo2_data, }, }, }; Changes in detail:- o Removed all const char* regulator config functions in machine API. o Created new struct regulator_init_data to contain regulator machine configuration constraints and consmuers. o Changed set_supply(), set_machine_constraints(), set_consumer_device_supply() to remove their string identifier parameters. Also made them static and moved functions nearer top of core.c. o Removed no longer used inline func to_rdev() o Added regulator_get_init_drvdata() to retrieve init data. o Added struct device* as parameter to regulator_register(). o Changed my email address. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (33 commits) ALSA: ASoC codec: remove unused #include <version.h> ALSA: ASoC: update email address for Liam Girdwood ALSA: hda: corrected invalid mixer values ALSA: hda: add mixers for analog mixer on 92hd75xx codecs ALSA: ASoC: Add destination and source port for DMA on OMAP1 ALSA: ASoC: Drop device registration from GTA01 lm4857 driver ALSA: ASoC: Fix build of GTA01 audio driver ALSA: ASoC: Add widgets before setting endpoints on GTA01 ALSA: ASoC: Fix inverted input PGA mute bits in WM8903 ALSA: ASoC: OMAP: Set DMA stream name at runtime in McBSP DAI driver ALSA: ASoC: OMAP: Add support for OMAP2430 and OMAP34xx in McBSP DAI driver ALSA: ASoC: OMAP: Add multilink support to McBSP DAI driver ALSA: ASoC: Make TLV320AIC26 user-visible ALSA: ASoC - clean up Kconfig for TLV320AIC2 ALSA: ASoC: Make WM8510 microphone input a DAPM mixer ALSA: ASoC: Implement WM8510 bias level control ALSA: ASoC: Remove unused AUDIO_NAME define from codec drivers ALSA: ASoC: tlv320aic3x: Use uniform tlv320aic naming ALSA: ASoC: Add WM8510 SPI support ALSA: ASoC: Add WM8753 SPI support ...
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (24 commits) integrity: special fs magic As pointed out by Jonathan Corbet, the timer must be deleted before ERROR: code indent should use tabs where possible The tpm_dev_release function is only called for platform devices, not pnp Protect tpm_chip_list when transversing it. Renames num_open to is_open, as only one process can open the file at a time. Remove the BKL calls from the TPM driver, which were added in the overall netlabel: Add configuration support for local labeling cipso: Add support for native local labeling and fixup mapping names netlabel: Changes to the NetLabel security attributes to allow LSMs to pass full contexts selinux: Cache NetLabel secattrs in the socket's security struct selinux: Set socket NetLabel based on connection endpoint netlabel: Add functionality to set the security attributes of a packet netlabel: Add network address selectors to the NetLabel/LSM domain mapping netlabel: Add a generic way to create ordered linked lists of network addrs netlabel: Replace protocol/NetLabel linking with refrerence counts smack: Fix missing calls to netlbl_skbuff_err() selinux: Fix missing calls to netlbl_skbuff_err() selinux: Fix a problem in security_netlbl_sid_to_secattr() selinux: Better local/forward check in selinux_ip_postroute() ...
2008-10-13Merge git://git.infradead.org/users/dwmw2/random-2.6Linus Torvalds
* git://git.infradead.org/users/dwmw2/random-2.6: Fix autoloading of MacBook Pro backlight driver. Automatic MODULE_ALIAS() for DMI match tables. Remove asm/a.out.h files for all architectures without a.out support. Introduce HAVE_AOUT symbol to remove hard-coded arch list for BINFMT_AOUT Remove redundant CONFIG_ARCH_SUPPORTS_AOUT S390: Update comments about why we don't use <asm-generic/statfs.h> SPARC: Use <asm-generic/statfs.h> PowerPC: Use <asm-generic/statfs.h> PARISC: Use <asm-generic/statfs.h> x86_64: Use <asm-generic/statfs.h> IA64: Use <asm-generic/statfs.h> ARM: Use <asm-generic/statfs.h> Make <asm-generic/statfs.h> suitable for 64-bit platforms. Define and use PCI_DEVICE_ID_MARVELL_88ALP01_CCIC for CAFÉ camera driver [MTD] [NAND] Define and use PCI_DEVICE_ID_MARVELL_88ALP01_NAND for CAFÉ Use PCI_DEVICE_ID_88ALP01 for CAFÉ chip, rather than PCI_DEVICE_ID_CAFE. EFS: Don't set f_fsid in statfs().
2008-10-13Merge phase #5 (misc) of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip Merges oprofile, timers/hpet, x86/traps, x86/time, and x86/core misc items. * 'x86-core-v4-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (132 commits) x86: change early_ioremap to use slots instead of nesting x86: adjust dependencies for CONFIG_X86_CMOV dumpstack: x86: various small unification steps, fix x86: remove additional_cpus x86: remove additional_cpus configurability x86: improve UP kernel when CPU-hotplug and SMP is enabled dumpstack: x86: various small unification steps dumpstack: i386: make kstack= an early boot-param and add oops=panic dumpstack: x86: use log_lvl and unify trace formatting dumptrace: x86: consistently include loglevel, print stack switch dumpstack: x86: add "end" parameter to valid_stack_ptr and print_context_stack dumpstack: x86: make printk_address equal dumpstack: x86: move die_nmi to dumpstack_32.c traps: x86: finalize unification of traps.c traps: x86: make traps_32.c and traps_64.c equal traps: x86: various noop-changes preparing for unification of traps_xx.c traps: x86_64: use task_pid_nr(tsk) instead of tsk->pid in do_general_protection traps: i386: expand clear_mem_error and remove from mach_traps.h traps: x86_64: make io_check_error equal to the one on i386 traps: i386: use preempt_conditional_sti/cli in do_int3 ...
2008-10-13tty: some ICANON magic is in the wrong placesAlan Cox
Move the set up on ldisc change into the ldisc Move the INQ/OUTQ cases into the driver not in shared ioctl code where it gives bogus answers for other ldisc values Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Add an instance parameter devpts interfacesSukadev Bhattiprolu
Pass-in 'inode' or 'tty' parameter to devpts interfaces. With multiple devpts instances, these parameters will be used in subsequent patches to identify the instance of devpts mounted. The parameters also help simplify devpts implementation. Changelog[v3]: - minor changes due to merge with ttydev updates - rename parameters to emphasize they are ptmx or pts inodes - pass-in tty_struct * to devpts_pty_kill() (this will help cleanup the get_node() call in a subsequent patch) Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: extract the pty init time special casesAlan Cox
The majority of the remaining init_dev code is pty special cases. We refactor this code into the driver->install method. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Finish fixing up the init_dev interface to use ERR_PTRAlan Cox
Original suggestion and proposal from Sukadev Bhattiprolu. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: More driver operationsAlan Cox
We have the lookup operation abstracted which is nice for pty cleanup but we really want to abstract the add/remove entries as well so that we can pull the pty code out of the tty core and create a clear defined interface for the tty driver table. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: kref the tty driver objectAlan Cox
2008-10-13tty: Clean up the tty_init_dev changes furtherAlan Cox
Fix up the naming, style and extract some bits of code into the driver specific code Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Remove more special casing and out of place codeAlan Cox
Carry on pushing code out of tty_io when it belongs to other drivers. I'm not 100% happy with some of this and it will be worth revisiting some of the exports later when the restructuring work is done. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: shutdown methodAlan Cox
Right now there are various drivers that try to use tty->count to know when they get the final close. Aristeau Rozanski showed while debugging the vt sysfs race that this isn't entirely safe. Instead of driver side tricks to work around this introduce a shutdown which is called when the tty is being destructed. This also means that the shutdown method is tied into the refcounting. Use this to rework the console close/sysfs logic. Remove lots of special case code from the tty core code. The pty code can now have a shutdown() method that replaces the special case hackery in the tree free up paths. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: the vhangup syscall is racyAlan Cox
We now have the infrastructure to sort this out but rather than teaching the syscall tty lock rules we move the hard work into a tty helper Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: usb-serial krefsAlan Cox
Use kref in the USB serial drivers so that we don't free tty structures from under the URB receive handlers as has historically been the case if you were unlucky. This also gives us a framework for general tty drivers to use tty_port objects and refcount. Contains two err->dev_err changes merged together to fix clashes in the -next tree. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Add termioxAlan Cox
We need a way to describe the various additional modes and flow control features that random weird hardware shows up and software such as wine wants to emulate as Windows supports them. TCGETX/TCSETX and the termiox ioctl are a SYS5 extension that we might as well adopt. This patches adds the structures and the basic ioctl interfaces when the TCGETX etc defines are added for an architecture. Drivers wishing to use this stuff need to add new methods. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Cris has a nice RS485 ioctl so we should steal itAlan Cox
JP Tosoni observed: "About a RS485 ioctl: could you consider the attached files which are already in the Linux kernel (in include/asm-cris). They define a TIOCSERSETRS485 (ioctl.h), and the data structure (rs485.h) with allows to specify timings. Sounds just like what we want ?" and he's right: sort of. Rework the structure to use flag bits and make the time delay a fixed sized field so we don't get 32/64bit problems. Add the ioctls to x86 so that people know what to add to their platform of choice. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Add a kref countAlan Cox
Introduce a kref to the tty structure and use it to protect the tty->signal tty references. For now we don't introduce it for anything else. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13pps: Reserve a line discipline number for PPSAlan Cox
Add a new line discipline for "pulse per second" devices connected to a serial port. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: split the buffering from tty_ioAlan Cox
The two are basically independent chunks of code so lets split them up for readability and sanity. It also makes the API boundaries much clearer. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13serial: Make uart_port's ioport "unsigned long".David Miller
Otherwise the top 32-bits of the resource value get chopped off on 64-bit systems, and the resulting I/O accesses go to random places. Thanks to testing and debugging by Josip Rodin, which helped track this down. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: include/asm-x86/statfs.h
2008-10-13Automatic MODULE_ALIAS() for DMI match tables.David Woodhouse
This makes modpost handle MODULE_DEVICE_TABLE(dmi, xxxx). I had to change the string pointers in the match table to char arrays, and picked a size of 79 bytes almost at random -- do we need to make it bigger than that? I was a bit concerned about the 'bloat' this introduces into the match tables, but they should all be __initdata so it shouldn't matter too much. (Actually, modpost does go through the relocations and look at most of them; it wouldn't be impossible to make it handle string pointers -- but doesn't seem to be worth the effort, since they're __initdata). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-13Merge branches 'oprofile-v2' and 'timers/hpet' into x86/core-v4Ingo Molnar
2008-10-13Merge branch 'linus' into oprofile-v2Ingo Molnar
Conflicts: arch/x86/kernel/apic_32.c arch/x86/oprofile/nmi_int.c include/linux/pci_ids.h
2008-10-13x86: change early_ioremap to use slots instead of nestingYinghai Lu
so we could remove the requirement that one needs to call early_iounmap() in exactly reverse order of early_ioremap(). Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13traps: x86: various noop-changes preparing for unification of traps_xx.cAlexander van Heukelum
- reordering include files - whitespace changes - comment changes - removed unused bad_intr() - make default_do_nmi static Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13traps: i386: expand clear_mem_error and remove from mach_traps.hAlexander van Heukelum
This is the last user of clear_mem_error, which is defined only on i386. Expand the inline function and remove it from include/asm-x86/mach-default/mach_traps.h Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13traps: x86: converge trap_init functionsAlexander van Heukelum
- set_system_gate on i386 is really set_system_trap_gate - set_system_gate on x86_64 is really set_system_intr_gate - ist=0 means no special stack switch is done: - introduce STACKFAULT_STACK, DOUBLEFAULT_STACK, NMI_STACK, DEBUG_STACK and MCE_STACK as on x86_64. - use the _ist variants with XXX_STACK set to zero - remove set_system_gate Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu> traps: x86: correct copy/paste bug: a trap is a GATE_TRAP Fix copy/paste/forgot-to-edit bug in desc.h. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86, traps: converge do_debug handlersAlexander van Heukelum
Make the x86_64-version and the i386-version of do_debug more similar. - introduce preempt_conditional_sti/cli to i386. The preempt-count is now elevated during the trap handler, like on x86_64. It does not run on a separate stack, however. - replace an open-coded "send_sigtrap" - copy some comments Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86, traps: introduce dotraplinkageAlexander van Heukelum
Mark the exception handlers with "dotraplinkage" to hide the calling convention differences between i386 and x86_64. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86, traps: split out math_error and simd_math_errorAlexander van Heukelum
Split out math_error from do_coprocessor_error and simd_math_error from do_simd_coprocessor_error, like on i386. While at it, add the "error_code" parameter to do_coprocessor_error, do_simd_coprocessor_error and do_spurious_interrupt_bug. This does not change the generated code, but brings the declarations in line with all the other trap handlers. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86: fix virt_addr_valid() with CONFIG_DEBUG_VIRTUAL=y, v2Vegard Nossum
virt_addr_valid() calls __pa(), which calls __phys_addr(). With CONFIG_DEBUG_VIRTUAL=y, __phys_addr() will kill the kernel if the address *isn't* valid. That's clearly wrong for virt_addr_valid(). We also incorporate the debugging checks into virt_addr_valid(). Signed-off-by: Vegard Nossum <vegardno@ben.ifi.uio.no> Acked-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86: __show_registers() and __show_regs() API unificationPekka Enberg
Currently the low-level function to dump user-passed registers on i386 is called __show_registers() whereas on x86-64 it's called __show_regs(). Unify the API to simplify porting of kmemcheck to x86-64. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
