Introduce Kconfig option allowing architectures where sysdev
operations used during system suspend, resume and shutdown have been
completely replaced with struct sycore_ops operations to avoid
building sysdev code that will never be used.
Make callbacks in struct sys_device and struct sysdev_driver depend
on ARCH_NO_SYSDEV_OPS to allows us to verify if all of the references
have been actually removed from the code the given architecture
depends on.
Make x86 select ARCH_NO_SYSDEV_OPS.
Commit 34db18a054c6 ("smp: move smp setup functions to kernel/smp.c")
causes this build error on s390 because of a missing init.h include:
CC arch/s390/kernel/asm-offsets.s
In file included from /home2/heicarst/linux-2.6/arch/s390/include/asm/spinlock.h:14:0,
from include/linux/spinlock.h:87,
from include/linux/seqlock.h:29,
from include/linux/time.h:8,
from include/linux/timex.h:56,
from include/linux/sched.h:57,
from arch/s390/kernel/asm-offsets.c:10:
include/linux/smp.h:117:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'setup_nr_cpu_ids'
include/linux/smp.h:118:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'smp_init'
Fix it by adding the include statement.
Acked-by: WANG Cong <amwang@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (66 commits)
avr32: at32ap700x: fix typo in DMA master configuration
dmaengine/dmatest: Pass timeout via module params
dma: let IMX_DMA depend on IMX_HAVE_DMA_V1 instead of an explicit list of SoCs
fsldma: make halt behave nicely on all supported controllers
fsldma: reduce locking during descriptor cleanup
fsldma: support async_tx dependencies and automatic unmapping
fsldma: fix controller lockups
fsldma: minor codingstyle and consistency fixes
fsldma: improve link descriptor debugging
fsldma: use channel name in printk output
fsldma: move related helper functions near each other
dmatest: fix automatic buffer unmap type
drivers, pch_dma: Fix warning when CONFIG_PM=n.
dmaengine/dw_dmac fix: use readl & writel instead of __raw_readl & __raw_writel
avr32: at32ap700x: Specify DMA Flow Controller, Src and Dst msize
dw_dmac: Setting Default Burst length for transfers as 16.
dw_dmac: Allow src/dst msize & flow controller to be configured at runtime
dw_dmac: Changing type of src_master and dest_master to u8.
dw_dmac: Pass Channel Priority from platform_data
dw_dmac: Pass Channel Allocation Order from platform_data
Instead of always creating a huge (268K) deflate_workspace with the
maximum compression parameters (windowBits=15, memLevel=8), allow the
caller to obtain a smaller workspace by specifying smaller parameter
values.
For example, when capturing oops and panic reports to a medium with
limited capacity, such as NVRAM, compression may be the only way to
capture the whole report. In this case, a small workspace (24K works
fine) is a win, whether you allocate the workspace when you need it (i.e.,
during an oops or panic) or at boot time.
I've verified that this patch works with all accepted values of windowBits
(positive and negative), memLevel, and compression level.
Signed-off-by: Jim Keniston <jkenisto@us.ibm.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Chris Mason <chris.mason@oracle.com>
Add brackets around typecasted argument in crc32() macro.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Analog Devices' SigmaStudio can produce firmware blobs for devices with
these DSPs embedded (like some audio codecs). Allow these device drivers
to easily parse and load them.
1. simple_strto*() do not contain overflow checks and crufty,
libc way to indicate failure.
2. strict_strto*() also do not have overflow checks but the name and
comments pretend they do.
3. Both families have only "long long" and "long" variants,
but users want strtou8()
4. Both "simple" and "strict" prefixes are wrong:
Simple doesn't exactly say what's so simple, strict should not exist
because conversion should be strict by default.
The solution is to use "k" prefix and add convertors for more types.
Enter
kstrtoull()
kstrtoll()
kstrtoul()
kstrtol()
kstrtouint()
kstrtoint()
kstrtou64()
kstrtos64()
kstrtou32()
kstrtos32()
kstrtou16()
kstrtos16()
kstrtou8()
kstrtos8()
Include runtime testsuite (somewhat incomplete) as well.
strict_strto*() become deprecated, stubbed to kstrto*() and
eventually will be removed altogether.
Use kstrto*() in code today!
Note: on some archs _kstrtoul() and _kstrtol() are left in tree, even if
they'll be unused at runtime. This is temporarily solution,
because I don't want to hardcode list of archs where these
functions aren't needed. Current solution with sizeof() and
__alignof__ at least always works.
Move setup_nr_cpu_ids(), smp_init() and some other SMP boot parameter
setup functions from init/main.c to kenrel/smp.c, saves some #ifdef
CONFIG_SMP.
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Rakib Mullick <rakib.mullick@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Akinobu Mita <akinobu.mita@gmail.com>
PTR_RET() can be used if you have an error-pointer and are only interested
in the eventual error value, but not the pointer. Yields the usual 0 for
no error, -ESOMETHING otherwise.
Re-ordering struct block_inode to remove 8 bytes of padding on 64 bit
builds, which also shrinks bdev_inode by 8 bytes (776 -> 768) allowing it
to fit into one fewer cache lines.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
Unify identical gcc3.x and gcc4.x macros.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
All architectures can use the common dma_addr_t typedef now. We can
remove the arch specific dma_addr_t.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Add a new __GFP_OTHER_NODE flag to tell the low level numa statistics in
zone_statistics() that an allocation is on behalf of another thread. This
way the local and remote counters can be still correct, even when
background daemons like khugepaged are changing memory mappings.
This only affects the accounting, but I think it's worth doing that right
to avoid confusing users.
I first tried to just pass down the right node, but this required a lot of
changes to pass down this parameter and at least one addition of a 10th
argument to a 9 argument function. Using the flag is a lot less
intrusive.
Open: should be also used for migration?
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
balancing small zones
When reclaiming for order-0 pages, kswapd requires that all zones be
balanced. Each cycle through balance_pgdat() does background ageing on
all zones if necessary and applies equal pressure on the inactive zone
unless a lot of pages are free already.
A "lot of free pages" is defined as a "balance gap" above the high
watermark which is currently 7*high_watermark. Historically this was
reasonable as min_free_kbytes was small. However, on systems using huge
pages, it is recommended that min_free_kbytes is higher and it is tuned
with hugeadm --set-recommended-min_free_kbytes. With the introduction of
transparent huge page support, this recommended value is also applied. On
X86-64 with 4G of memory, min_free_kbytes becomes 67584 so one would
expect around 68M of memory to be free. The Normal zone is approximately
35000 pages so under even normal memory pressure such as copying a large
file, it gets exhausted quickly. As it is getting exhausted, kswapd
applies pressure equally to all zones, including the DMA32 zone. DMA32 is
approximately 700,000 pages with a high watermark of around 23,000 pages.
In this situation, kswapd will reclaim around (23000*8 where 8 is the high
watermark + balance gap of 7 * high watermark) pages or 718M of pages
before the zone is ignored. What the user sees is that free memory far
higher than it should be.
To avoid an excessive number of pages being reclaimed from the larger
zones, explicitely defines the "balance gap" to be either 1% of the zone
or the low watermark for the zone, whichever is smaller. While kswapd
will check all zones to apply pressure, it'll ignore zones that meets the
(high_wmark + balance_gap) watermark.
To test this, 80G were copied from a partition and the amount of memory
being used was recorded. A comparison of a patch and unpatched kernel can
be seen at
http://www.csn.ul.ie/~mel/postings/minfree-20110222/memory-usage-hydra.ps
and shows that kswapd is not reclaiming as much memory with the patch
applied.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: "Chen, Tim C" <tim.c.chen@intel.com>
Right now, if a mm_walk has either ->pte_entry or ->pmd_entry set, it will
unconditionally split any transparent huge pages it runs in to. In
practice, that means that anyone doing a
cat /proc/$pid/smaps
will unconditionally break down every huge page in the process and depend
on khugepaged to re-collapse it later. This is fairly suboptimal.
This patch changes that behavior. It teaches each ->pmd_entry handler
(there are five) that they must break down the THPs themselves. Also, the
_generic_ code will never break down a THP unless a ->pte_entry handler is
actually set.
This means that the ->pmd_entry handlers can now choose to deal with THPs
without breaking them down.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Acked-by: David Rientjes <rientjes@google.com>
Reviewed-by: Eric B Munson <emunson@mgebm.net>
Tested-by: Eric B Munson <emunson@mgebm.net>
Cc: Michael J Wolf <mjwolf@us.ibm.com>
Cc: Matt Mackall <mpm@selenic.com>
The rotate_reclaimable_page function moves just written out pages, which
the VM wanted to reclaim, to the end of the inactive list. That way the
VM will find those pages first next time it needs to free memory.
This patch applies the rule in memcg. It can help to prevent unnecessary
working page eviction of memcg.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Recently, there are reported problem about thrashing.
(http://marc.info/?l=rsync&m=128885034930933&w=2) It happens by backup
workloads(ex, nightly rsync). That's because the workload makes just
use-once pages and touches pages twice. It promotes the page into active
list so that it results in working set page eviction.
Some app developer want to support POSIX_FADV_NOREUSE. But other OSes
don't support it, either.
(http://marc.info/?l=linux-mm&m=128928979512086&w=2)
By other approach, app developers use POSIX_FADV_DONTNEED. But it has a
problem. If kernel meets page is writing during invalidate_mapping_pages,
it can't work. It makes for application programmer to use it since they
always have to sync data before calling fadivse(..POSIX_FADV_DONTNEED) to
make sure the pages could be discardable. At last, they can't use
deferred write of kernel so that they could see performance loss.
(http://insights.oetiker.ch/linux/fadvise.html)
In fact, invalidation is very big hint to reclaimer. It means we don't
use the page any more. So let's move the writing page into inactive
list's head if we can't truncate it right now.
Why I move page to head of lru on this patch, Dirty/Writeback page would
be flushed sooner or later. It can prevent writeout of pageout which is
less effective than flusher's writeout.
Originally, I reused lru_demote of Peter with some change so added his
Signed-off-by.
Reported-by: Ben Gamari <bgamari.foss@gmail.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Reorder mm_struct to remove 16 bytes of alignment padding on 64 bit
builds. On my config this shrinks mm_struct by enough to fit in one
fewer cache lines and allows more objects per slab in mm_struct
kmem_cache under SLUB.
slabinfo before patch :-
Sizes (bytes) Slabs
Object : 848 Total : 9
SlabObj: 896 Full : 2
SlabSiz: 16384 Partial: 5
Loss : 48 CpuSlab: 2
Align : 64 Objects: 18
slabinfo after :-
Sizes (bytes) Slabs
Object : 832 Total : 7
SlabObj: 832 Full : 2
SlabSiz: 16384 Partial: 3
Loss : 0 CpuSlab: 2
Align : 64 Objects: 19
TestSetPageLocked() isn't being used anywhere. Also, using it would
likely be an error, since the proper interface trylock_page() provides
stronger ordering guarantees.
Signed-off-by: Michel Lespinasse <walken@google.com>
This patch changes the anon_vma refcount to be 0 when the object is free.
It does this by adding 1 ref to being in use in the anon_vma structure
(iow. the anon_vma->head list is not empty).
This allows a simpler release scheme without having to check both the
refcount and the list as well as avoids taking a ref for each entry on the
list.
We need the anon_vma refcount unconditionally to simplify the anon_vma
lifetime rules.
The normal code pattern used in the kernel is: get/put.
Now we renamed remove_from_page_cache with delete_from_page_cache. As
consistency of __remove_from_swap_cache and remove_from_swap_cache, we
change internal page cache handling function name, too.
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Now delete_from_page_cache() replaces remove_from_page_cache(). So we
remove remove_from_page_cache so fs or something out of mainline will
notice it when compile time and can fix it.
Presently we increase the page refcount in add_to_page_cache() but don't
decrease it in remove_from_page_cache(). Such asymmetry adds confusion,
requiring that callers notice it and a comment explaining why they release
a page reference. It's not a good API.
A long time ago, Hugh tried it (http://lkml.org/lkml/2004/10/24/140) but
gave up because reiser4's drop_page() had to unlock the page between
removing it from page cache and doing the page_cache_release(). But now
the situation is changed. I think at least things in current mainline
don't have any obstacles. The problem is for out-of-mainline filesystems
- if they have done such things as reiser4, this patch could be a problem
but they will discover this at compile time since we remove
This patch:
This function works as just wrapper remove_from_page_cache(). The
difference is that it decreases page references in itself. So caller have
to make sure it has a page reference before calling.
This patch is ready for removing remove_from_page_cache().
Cc: Edward Shishkin <edward.shishkin@gmail.com>
This function basically does:
remove_from_page_cache(old);
page_cache_release(old);
add_to_page_cache_locked(new);
Except it does this atomically, so there's no possibility for the "add" to
fail because of a race.
If memory cgroups are enabled, then the memory cgroup charge is also moved
from the old page to the new.
This function is currently used by fuse to move pages into the page cache
on read, instead of copying the page contents.
[minchan.kim@gmail.com: add freepage() hook to replace_page_cache_page()]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
GUP user may want to try to acquire a reference to a page if it is already
in memory, but not if IO, to bring it in, is needed. For example KVM may
tell vcpu to schedule another guest process if current one is trying to
access swapped out page. Meanwhile, the page will be swapped in and the
guest process, that depends on it, will be able to run again.
This patch adds FAULT_FLAG_RETRY_NOWAIT (suggested by Linus) and
FOLL_NOWAIT follow_page flags. FAULT_FLAG_RETRY_NOWAIT, when used in
conjunction with VM_FAULT_ALLOW_RETRY, indicates to handle_mm_fault that
it shouldn't drop mmap_sem and wait on a page, but return VM_FAULT_RETRY
instead.
[akpm@linux-foundation.org: improve FOLL_NOWAIT comment]
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
The oom killer is extremely verbose for machines with a large number of
cpus and/or nodes. This verbosity can often be harmful if it causes other
important messages to be scrolled from the kernel log and incurs a
signicant time delay, specifically for kernels with CONFIG_NODES_SHIFT >
8.
This patch causes only memory information to be displayed for nodes that
are allowed by current's cpuset when dumping the VM state. Information
for all other nodes is irrelevant to the oom condition; we don't care if
there's an abundance of memory elsewhere if we can't access it.
This only affects the behavior of dumping memory information when an oom
is triggered. Other dumps, such as for sysrq+m, still display the
unfiltered form when using the existing show_mem() interface.
Additionally, the per-cpu pageset statistics are extremely verbose in oom
killer output, so it is now suppressed. This removes
nodes_weight(current->mems_allowed) * (1 + nr_cpus)
lines from the oom killer output.
Callers may use __show_mem(SHOW_MEM_FILTER_NODES) to filter disallowed
nodes.
Signed-off-by: David Rientjes <rientjes@google.com>
All kthreads being created from a single helper task, they all use memory
from a single node for their kernel stack and task struct.
This patch suite creates kthread_create_on_node(), adding a 'cpu' parameter
to parameters already used by kthread_create().
This parameter serves in allocating memory for the new kthread on its
memory node if possible.
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: <linux-arch@vger.kernel.org>
This patch reverts 5a03b051 ("thp: use compaction in kswapd for GFP_ATOMIC
order > 0") due to reports stating that kswapd CPU usage was higher and
IRQs were being disabled more frequently. This was reported at
http://www.spinics.net/linux/fedora/alsa-user/msg09885.html.
Without this patch applied, CPU usage by kswapd hovers around the 20% mark
according to the tester (Arthur Marsh:
http://www.spinics.net/linux/fedora/alsa-user/msg09899.html). With this
patch applied, it's around 2%.
The problem is not related to THP which specifies __GFP_NO_KSWAPD but is
triggered by high-order allocations hitting the low watermark for their
order and waking kswapd on kernels with CONFIG_COMPACTION set. The most
common trigger for this is network cards configured for jumbo frames but
it's also possible it'll be triggered by fork-heavy workloads (order-1)
and some wireless cards which depend on order-1 allocations.
The symptoms for the user will be high CPU usage by kswapd in low-memory
situations which could be confused with another writeback problem. While
a patch like 5a03b051 may be reintroduced in the future, this patch plays
it safe for now and reverts it.
[mel@csn.ul.ie: Beefed up the changelog]
Reported-by: Arthur Marsh <arthur.marsh@internode.on.net>
Tested-by: Arthur Marsh <arthur.marsh@internode.on.net>
Cc: <stable@kernel.org> [2.6.38.1]
In systems with multiple framebuffer devices, one of the devices might be
blanked while another is unblanked. In order for the backlight blanking
logic to know whether to turn off the backlight for a particular
framebuffer's blanking notification, it needs to be able to check if a
given framebuffer device corresponds to the backlight.
This plumbs the check_fb hook from core backlight through the
pwm_backlight helper to allow platform code to plug in a check_fb hook.
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Arun Murthy <arun.murthy@stericsson.com>
Cc: Linus Walleij <linus.walleij@stericsson.com>
There may be multiple ways of controlling the backlight on a given
machine. Allow drivers to expose the type of interface they are
providing, making it possible for userspace to make appropriate policy
decisions.
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: David Airlie <airlied@linux.ie>
Cc: Alex Deucher <alexdeucher@gmail.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
And fix a typo.
Cc: Lars-Peter Clausen <lars@metafoo.de>
Simple backlight driver for National Semiconductor LM3530. Presently only
manual mode is supported, PWM and ALS support to be added.
Signed-off-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com>
syncfs() is duplicating name_to_handle_at() due to a merging mistake.
Cc: Sage Weil <sage@newdream.net>
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'slab/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
slub: Add statistics for this_cmpxchg_double failures
slub: Add missing irq restore for the OOM path
* git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
rbd: use watch/notify for changes in rbd header
libceph: add lingering request and watch/notify event framework
rbd: update email address in Documentation
ceph: rename dentry_release -> d_release, fix comment
ceph: add request to the tail of unsafe write list
ceph: remove request from unsafe list if it is canceled/timed out
ceph: move readahead default to fs/ceph from libceph
ceph: add ino32 mount option
ceph: update common header files
ceph: remove debugfs debug cruft
libceph: fix osd request queuing on osdmap updates
ceph: preserve I_COMPLETE across rename
libceph: Fix base64-decoding when input ends in newline.
Using delayed-work for tty flip buffers ends up causing us to wait for
the next tick to complete some actions. That's usually not all that
noticeable, but for certain latency-critical workloads it ends up being
totally unacceptable.
As an extreme case of this, passing a token back-and-forth over a pty
will take two ticks per iteration, so even just a thousand iterations
will take 8 seconds assuming a common 250Hz configuration.
Avoiding the whole delayed work issue brings that ping-pong test-case
down to 0.009s on my machine.
In more practical terms, this latency has been a performance problem for
things like dive computer simulators (simulating the serial interface
using the ptys) and for other environments (Alan mentions a CP/M emulator).
Reported-by: Jef Driesen <jefdriesen@telenet.be>
Acked-by: Greg KH <gregkh@suse.de>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Add some statistics for debugging.
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Lingering requests are requests that are sent to the OSD normally but
tracked also after we get a successful request. This keeps the OSD
connection open and resends the original request if the object moves to
another OSD. The OSD can then send notification messages back to us
if another client initiates a notify.
This framework will be used by RBD so that the client gets notification
when a snapshot is created by another node or tool.
Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
Signed-off-by: Sage Weil <sage@newdream.net>
* 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linux:
i2c-pxa2xx: Don't clear isr bits too early
i2c-pxa2xx: Fix register offsets
i2c-pxa2xx: pass of_node from platform driver to adapter and publish
i2c-pxa2xx: check timeout correctly
i2c-pxa2xx: add support for shared IRQ handler
i2c-pxa2xx: Add PCI support for PXA I2C controller
ARM: pxa2xx: reorganize I2C files
i2c-pxa2xx: use dynamic register layout
i2c-mxs: set controller to pio queue mode after reset
i2c-eg20t: support new device OKI SEMICONDUCTOR ML7213 IOH
i2c/busses: Add support for Diolan U2C-12 USB-I2C adapter
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
slub: Dont define useless label in the !CONFIG_CMPXCHG_LOCAL case
slab,rcu: don't assume the size of struct rcu_head
slub,rcu: don't assume the size of struct rcu_head
slub: automatically reserve bytes at the end of slab
Lockless (and preemptless) fastpaths for slub
slub: Get rid of slab_free_hook_irq()
slub: min_partial needs to be in first cacheline
slub: fix ksize() build error
slub: fix kmemcheck calls to match ksize() hints
Revert "slab: Fix missing DEBUG_SLAB last user"
mm: Remove support for kmem_cache_name()
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits)
IPVS: Use global mutex in ip_vs_app.c
ipvs: fix a typo in __ip_vs_control_init()
veth: Fix the byte counters
net ipv6: Fix duplicate /proc/sys/net/ipv6/neigh directory entries.
macvlan: Fix use after free of struct macvlan_port.
net: fix incorrect spelling in drop monitor protocol
can: c_can: Do basic c_can configuration _before_ enabling the interrupts
net/appletalk: fix atalk_release use after free
ipx: fix ipx_release()
snmp: SNMP_UPD_PO_STATS_BH() always called from softirq
l2tp: fix possible oops on l2tp_eth module unload
xfrm: Fix initialize repl field of struct xfrm_state
netfilter: ipt_CLUSTERIP: fix buffer overflow
netfilter: xtables: fix reentrancy
netfilter: ipset: fix checking the type revision at create command
netfilter: ipset: fix address ranges at hash:*port* types
niu: Rename NIU parent platform device name to fix conflict.
r8169: fix a bug in rtl8169_init_phy()
bonding: fix a typo in a comment
ftmac100: use resource_size()
As part of the work to make IPVS network namespace aware
__ip_vs_app_mutex was replaced by a per-namespace lock,
ipvs->app_mutex. ipvs->app_key is also supplied for debugging purposes.
Unfortunately this implementation results in ipvs->app_key residing
in non-static storage which at the very least causes a lockdep warning.
This patch takes the rather heavy-handed approach of reinstating
__ip_vs_app_mutex which will cover access to the ipvs->list_head
of all network namespaces.
[ 12.610000] IPVS: Creating netns size=2456 id=0
[ 12.630000] IPVS: Registered protocols (TCP, UDP, SCTP, AH, ESP)
[ 12.640000] BUG: key ffff880003bbf1a0 not in .data!
[ 12.640000] ------------[ cut here ]------------
[ 12.640000] WARNING: at kernel/lockdep.c:2701 lockdep_init_map+0x37b/0x570()
[ 12.640000] Hardware name: Bochs
[ 12.640000] Pid: 1, comm: swapper Tainted: G W 2.6.38-kexec-06330-g69b7efe-dirty #122
[ 12.650000] Call Trace:
[ 12.650000] [<ffffffff8102e685>] warn_slowpath_common+0x75/0xb0
[ 12.650000] [<ffffffff8102e6d5>] warn_slowpath_null+0x15/0x20
[ 12.650000] [<ffffffff8105967b>] lockdep_init_map+0x37b/0x570
[ 12.650000] [<ffffffff8105829d>] ? trace_hardirqs_on+0xd/0x10
[ 12.650000] [<ffffffff81055ad8>] debug_mutex_init+0x38/0x50
[ 12.650000] [<ffffffff8104bc4c>] __mutex_init+0x5c/0x70
[ 12.650000] [<ffffffff81685ee7>] __ip_vs_app_init+0x64/0x86
[ 12.660000] [<ffffffff81685a3b>] ? ip_vs_init+0x0/0xff
[ 12.660000] [<ffffffff811b1c33>] T.620+0x43/0x170
[ 12.660000] [<ffffffff811b1e9a>] ? register_pernet_subsys+0x1a/0x40
[ 12.660000] [<ffffffff811b1db7>] register_pernet_operations+0x57/0xb0
[ 12.670000] [<ffffffff811b1ea9>] register_pernet_subsys+0x29/0x40
[ 12.670000] [<ffffffff81685f19>] ip_vs_app_init+0x10/0x12
[ 12.670000] [<ffffffff81685a87>] ip_vs_init+0x4c/0xff
[ 12.670000] [<ffffffff8166562c>] do_one_initcall+0x7a/0x12e
[ 12.670000] [<ffffffff8166583e>] kernel_init+0x13e/0x1c2
[ 12.670000] [<ffffffff8128c134>] kernel_thread_helper+0x4/0x10
[ 12.670000] [<ffffffff8128ad40>] ? restore_args+0x0/0x30
[ 12.680000] [<ffffffff81665700>] ? kernel_init+0x0/0x1c2
[ 12.680000] [<ffffffff8128c130>] ? kernel_thread_helper+0x0/0x1global0
Signed-off-by: Simon Horman <horms@verge.net.au>
Cc: Julian Anastasov <ja@ssi.bg>
Cc: Hans Schillstrom <hans@schillstrom.com>
We dont need to test if we run from softirq context, we definitely are.
This saves few instructions in ip_rcv() & ip_rcv_finish()
Commit 'xfrm: Move IPsec replay detection functions to a separate file'
(9fdc4883d92d20842c5acea77a4a21bb1574b495)
introduce repl field to struct xfrm_state, and only initialize it
under SA's netlink create path, the other path, such as pf_key,
ipcomp/ipcomp6 etc, the repl field remaining uninitialize. So if
the SA is created by pf_key, any input packet with SA's encryption
algorithm will cause panic.
int xfrm_input()
x->repl->advance(x, seq);
This patch fixed it by introduce new function __xfrm_init_state().
Pid: 0, comm: swapper Not tainted 2.6.38-next+ #14 Bochs Bochs
EIP: 0060:[<c078e5d5>] EFLAGS: 00010206 CPU: 0
EIP is at xfrm_input+0x31c/0x4cc
EAX: dd839c00 EBX: 00000084 ECX: 00000000 EDX: 01000000
ESI: dd839c00 EDI: de3a0780 EBP: dec1de88 ESP: dec1de64
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process swapper (pid: 0, ti=dec1c000 task=c09c0f20 task.ti=c0992000)
Stack:
00000000 00000000 00000002 c0ba27c0 00100000 01000000 de3a0798 c0ba27c0
00000033 dec1de98 c0786848 00000000 de3a0780 dec1dea4 c0786868 00000000
dec1debc c074ee56 e1da6b8c de3a0780 c074ed44 de3a07a8 dec1decc c074ef32
Call Trace:
[<c0786848>] xfrm4_rcv_encap+0x22/0x27
[<c0786868>] xfrm4_rcv+0x1b/0x1d
[<c074ee56>] ip_local_deliver_finish+0x112/0x1b1
[<c074ed44>] ? ip_local_deliver_finish+0x0/0x1b1
[<c074ef32>] NF_HOOK.clone.1+0x3d/0x44
[<c074ef77>] ip_local_deliver+0x3e/0x44
[<c074ec03>] ip_rcv_finish+0x30a/0x332
[<c074e8f9>] ? ip_rcv_finish+0x0/0x332
[<c074f188>] ip_rcv+0x20b/0x247
[<c072797d>] __netif_receive_skb+0x373/0x399
[<c0727bc1>] netif_receive_skb+0x4b/0x51
[<e0817e2a>] cp_rx_poll+0x210/0x2c4 [8139cp]
[<c072818f>] net_rx_action+0x9a/0x17d
[<c0445b5c>] __do_softirq+0xa1/0x149
[<c0445abb>] ? __do_softirq+0x0/0x149
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: (ads1015) Make gain and datarate configurable
hwmon: (ads1015) Drop dynamic attribute group
hwmon: Add support for Texas Instruments ADS1015
hwmon: New driver for SMSC SCH5627
hwmon: (abituguru*) Update my email address
hwmon: (lm75) Speed up detection
hwmon: (lm75) Add detection of the National Semiconductor LM75A
hp_accel: Fix driver name
Move lis3lv02d drivers to drivers/misc
Move hp_accel to drivers/platform/x86
Let Kconfig handle lis3lv02d dependencies
hwmon: (sht15) Fix integer overflow in humidity calculation
hwmon: (sht15) Spelling fix
hwmon: (w83795) Document pin mapping
This updates the common header files used by the different ceph
related modules. Specifically it adds definitions required by
the rbd watch/notify feature.
If we send a request to osd A, and the request's pg remaps to osd B and
then back to A in quick succession, we need to resend the request to A. The
old code was only calling kick_requests after processing all incremental
maps in a message, so it was very possible to not resend a request that
needed to be resent. This would make the osd eventually time out (at least
with the current default of osd timeouts enabled).
The correct approach is to scan requests on every map incremental. This
patch refactors the kick code in a few ways:
- all requests are either on req_lru (in flight), req_unsent (ready to
send), or req_notarget (currently map to no up osd)
- mapping always done by map_request (previous map_osds)
- if the mapping changes, we requeue. requests are resent only after all
map incrementals are processed.
- some osd reset code is moved out of kick_requests into a separate
function
- the "kick this osd" functionality is moved to kick_osd_requests, as it
is unrelated to scanning for request->pg->osd mapping changes
