For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can
later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Now that network timestamps use ktime_t infrastructure, we can add a new
SOL_SOCKET sockopt SO_TIMESTAMPNS.
This command is similar to SO_TIMESTAMP, but permits transmission of
a 'timespec struct' instead of a 'timeval struct' control message.
(nanosecond resolution instead of microsecond)
Control message is labelled SCM_TIMESTAMPNS instead of SCM_TIMESTAMP
A socket cannot mix SO_TIMESTAMP and SO_TIMESTAMPNS : the two modes are
mutually exclusive.
sock_recv_timestamp() became too big to be fully inlined so I added a
__sock_recv_timestamp() helper function.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
CC: linux-arch@vger.kernel.org
Covert network warning messages from a compile time to runtime choice.
Removes kernel config option and replaces it with new /proc/sys/net/core/warnings.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Now network timestamps use ktime_t infrastructure, we can add a new
ioctl() SIOCGSTAMPNS command to get timestamps in 'struct timespec'.
User programs can thus access to nanosecond resolution.
CC: Stephen Hemminger <shemminger@linux-foundation.org>
This allows the write queue implementation to be changed,
for example, to one which allows fast interval searching.
This patch eliminates some duplicate code for the verification of
receive checksums between UDP-Lite and UDP. It does this by
introducing __skb_checksum_complete_head which is identical to
__skb_checksum_complete_head apart from the fact that it takes
a length parameter rather than computing the first skb->len bytes.
As a result UDP-Lite will be able to use hardware checksum offload
for packets which do not use partial coverage checksums. It also
means that UDP-Lite loopback no longer does unnecessary checksum
verification.
If any NICs start support UDP-Lite this would also start working
automatically.
This patch removes the assumption that msg_flags has MSG_TRUNC clear
upon entry in recvmsg.
Nominally an autoconfigured IPv6 address is added to an interface in the
Tentative state (as per RFC 2462). Addresses in this state remain in this
state while the Duplicate Address Detection process operates on them to
determine their uniqueness on the network. During this period, these
tentative addresses may not be used for communication, increasing the time
before a node may be able to communicate on a network. Using Optimistic
Duplicate Address Detection, autoconfigured addresses may be used
immediately for communication on the network, as long as certain rules are
followed to avoid conflicts with other nodes during the Duplicate Address
Detection process.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
We currently use a special structure (struct skb_timeval) and plain
'struct timeval' to store packet timestamps in sk_buffs and struct
sock.
This has some drawbacks :
- Fixed resolution of micro second.
- Waste of space on 64bit platforms where sizeof(struct timeval)=16
I suggest using ktime_t that is a nice abstraction of high resolution
time services, currently capable of nanosecond resolution.
As sizeof(ktime_t) is 8 bytes, using ktime_t in 'struct sock' permits
a 8 byte shrink of this structure on 64bit architectures. Some other
structures also benefit from this size reduction (struct ipq in
ipv4/ip_fragment.c, struct frag_queue in ipv6/reassembly.c, ...)
Once this ktime infrastructure adopted, we can more easily provide
nanosecond resolution on top of it. (ioctl SIOCGSTAMPNS and/or
SO_TIMESTAMPNS/SCM_TIMESTAMPNS)
Note : this patch includes a bug correction in
compat_sock_get_timestamp() where a "err = 0;" was missing (so this
syscall returned -ENOENT instead of 0)
CC: John find <linux.kernel@free.fr>
Here is the current version of the 64 bit divide common code.
Where appropriate, convert references to xtime.tv_sec to the
get_seconds() helper function.
Signed-off-by: James Morris <jmorris@namei.org>
sk_backlog is a critical field of struct sock. (known famous words)
It is (ab)used in hot paths, in particular in release_sock(), tcp_recvmsg(),
tcp_v4_rcv(), sk_receive_skb().
It really makes sense to place it next to sk_lock, because sk_backlog is only
used after sk_lock locked (and thus memory cache line in L1 cache). This
should reduce cache misses and sk_lock acquisition time.
(In theory, we could only move the head pointer near sk_lock, and leaving tail
far away, because 'tail' is normally not so hot, but keep it simple :) )
New sysctl tcp_frto_response is added to select amongst these
responses:
- Rate halving based; reuses CA_CWR state (default)
- Very conservative; used to be the only one available (=1)
- Undo cwr; undoes ssthresh and cwnd reductions (=2)
The response with rate halving requires a new parameter to
tcp_enter_cwr because FRTO has already reduced ssthresh and
doing a second reduction there has to be prevented. In addition,
to keep things nice on 80 cols screen, a local variable was
added.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
I noticed in oprofile study a cache miss in tcp_rcv_established() to read
copied_seq.
ffffffff80400a80 <tcp_rcv_established>: /* tcp_rcv_established total: 4034293
2.0400 */
55493 0.0281 :ffffffff80400bc9: mov 0x4c8(%r12),%eax copied_seq
543103 0.2746 :ffffffff80400bd1: cmp 0x3e0(%r12),%eax rcv_nxt
if (tp->copied_seq == tp->rcv_nxt &&
len - tcp_header_len <= tp->ucopy.len) {
In this function, the cache line 0x4c0 -> 0x500 is used only for this
reading 'copied_seq' field.
rcv_wup and copied_seq should be next to rcv_nxt field, to lower number of
active cache lines in hot paths. (tcp_rcv_established(), tcp_poll(), ...)
As you suggested, I changed tcp_create_openreq_child() so that these fields
are changed together, to avoid adding a new store buffer stall.
Patch is 64bit friendly (no new hole because of alignment constraints)
sysctl_tcp_max_ssthresh.
Signed-off-by: John Heffner <jheffner@psc.edu>
This interpretation comes from RFC4138:
"If the sender implements some loss recovery algorithm other
than Reno or NewReno [FHG04], the F-RTO algorithm SHOULD
NOT be entered when earlier fast recovery is underway."
I think the RFC means to say (especially in the light of
Appendix B) that ...recovery is underway (not just fast recovery)
or was underway when it was interrupted by an earlier (F-)RTO
that hasn't yet been resolved (snd_una has not advanced enough).
Thus, my interpretation is that whenever TCP has ever
retransmitted other than head, basic version cannot be used
because then the order assumptions which are used as FRTO basis
do not hold.
NewReno has only the head segment retransmitted at a time.
Therefore, walk up to the segment that has not been SACKed, if
that segment is not retransmitted nor anything before it, we know
for sure, that nothing after the non-SACKed segment should be
either. This assumption is valid because TCPCB_EVER_RETRANS does
not leave holes but each non-SACKed segment is rexmitted
in-order.
Check for retrans_out > 1 avoids more expensive walk through the
skb list, as we can know the result beforehand: F-RTO will not be
allowed.
SACKed skb can turn into non-SACked only in the extremely rare
case of SACK reneging, in this case we might fail to detect
retransmissions if there were them for any other than head. To
get rid of that feature, whole rexmit queue would have to be
walked (always) or FRTO should be prevented when SACK reneging
happens. Of course RTO should still trigger after reneging which
makes this issue even less likely to show up. And as long as the
response is as conservative as it's now, nothing bad happens even
then.
In addition, removed inline.
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[BNX2]: Fix occasional NETDEV WATCHDOG on 5709.
[IPV6]: Disallow RH0 by default.
[XFRM]: beet: fix pseudo header length value
[TCP]: Congestion control initialization.
A security issue is emerging. Disallow Routing Header Type 0 by default
as we have been doing for IPv4.
Note: We allow RH2 by default because it is harmless.
We broke the the alignment of members of taskstats to the 8 byte boundary
with the CSA patches. In the current kernel, the taskstats structure is
not suitable for use by 32 bit applications in a 64 bit kernel.
On x86_64
Offsets of taskstats' members (64 bit kernel, 64 bit application)
@taskstats'offsetof[@taskstats'indices] = (
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
16, # cpu_count
24, # cpu_delay_total
32, # blkio_count
40, # blkio_delay_total
48, # swapin_count
56, # swapin_delay_total
64, # cpu_run_real_total
72, # cpu_run_virtual_total
80, # ac_comm
112, # ac_sched
113, # ac_pad
116, # ac_uid
120, # ac_gid
124, # ac_pid
128, # ac_ppid
132, # ac_btime
136, # ac_etime
144, # ac_utime
152, # ac_stime
160, # ac_minflt
168, # ac_majflt
176, # coremem
184, # virtmem
192, # hiwater_rss
200, # hiwater_vm
208, # read_char
216, # write_char
224, # read_syscalls
232, # write_syscalls
240, # read_bytes
248, # write_bytes
256, # cancelled_write_bytes
Offsets of taskstats' members (64 bit kernel, 32 bit application)
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
12, # cpu_count
20, # cpu_delay_total
28, # blkio_count
36, # blkio_delay_total
44, # swapin_count
52, # swapin_delay_total
60, # cpu_run_real_total
68, # cpu_run_virtual_total
76, # ac_comm
108, # ac_sched
109, # ac_pad
112, # ac_uid
116, # ac_gid
120, # ac_pid
124, # ac_ppid
128, # ac_btime
132, # ac_etime
140, # ac_utime
148, # ac_stime
156, # ac_minflt
164, # ac_majflt
172, # coremem
180, # virtmem
188, # hiwater_rss
196, # hiwater_vm
204, # read_char
212, # write_char
220, # read_syscalls
228, # write_syscalls
236, # read_bytes
244, # write_bytes
252, # cancelled_write_bytes
This is one way to solve the problem without re-arranging structure members
is to pack the structure. The patch adds an __attribute__((aligned(8))) to
the taskstats structure members so that 32 bit applications using taskstats
can work with a 64 bit kernel.
Using __attribute__((packed)) would break the 64 bit alignment of members.
The fix was tested on x86_64. After the fix, we got
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
16, # cpu_count
32, # blkio_count
48, # swapin_count
80, # ac_comm
112, # ac_sched
113, # ac_pad
120, # ac_uid
124, # ac_gid
128, # ac_pid
132, # ac_ppid
136, # ac_btime
144, # ac_etime
152, # ac_utime
160, # ac_stime
168, # ac_minflt
176, # ac_majflt
184, # coremem
192, # virtmem
200, # hiwater_rss
208, # hiwater_vm
216, # read_char
224, # write_char
232, # read_syscalls
240, # write_syscalls
248, # read_bytes
256, # write_bytes
264, # cancelled_write_bytes
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
16, # cpu_count
32, # blkio_count
48, # swapin_count
80, # ac_comm
112, # ac_sched
113, # ac_pad
120, # ac_uid
124, # ac_gid
128, # ac_pid
132, # ac_ppid
136, # ac_btime
144, # ac_etime
152, # ac_utime
160, # ac_stime
168, # ac_minflt
176, # ac_majflt
184, # coremem
192, # virtmem
200, # hiwater_rss
208, # hiwater_vm
216, # read_char
224, # write_char
248, # read_bytes
256, # write_bytes
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Jay Lan <jlan@engr.sgi.com>
Cc: Shailabh Nagar <nagar@watson.ibm.com>
Cc: <stable@kernel.org>
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Fix wrong checksum for split TCP packets on 64-bit MIPS
[MIPS] Fix BUG(), BUG_ON() handling
[MIPS] Retry {save,restore}_fp_context if failed in atomic context.
[MIPS] Disallow CpU exception in kernel again.
[MIPS] Add missing silicon revisions for BCM112x
Get rid of the inlined #ifdefs.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
I've traced down an off-by-one TCP checksum calculation error under
the following conditions:
1) The TCP code needs to split a full-sized packet due to a reduced
MSS (typically due to the addition of TCP options mid-stream like
SACK).
_AND_
2) The checksum of the 2nd fragment is larger than the checksum of the
original packet. After subtraction this results in a checksum for
the 1st fragment with bits 16..31 set to 1. (this is ok)
_AND_
3) The checksum of the 1st fragment's TCP header plus the previously
32bit checksum of the 1st fragment DOES NOT cause a 32bit overflow
when added together. This results in a checksum of the TCP header
plus TCP data that still has the upper 16 bits as 1's.
_THEN_
4) The TCP+data checksum is added to the checksum of the pseudo IP
header with csum_tcpudp_nofold() incorrectly (the bug).
The problem is the checksum of the TCP+data is passed to
csum_tcpudp_nofold() as an 32bit unsigned value, however the assembly
code acts on it as if it is a 64bit unsigned value.
This causes an incorrect 32->64bit extension if the sum has bit 31
set. The resulting checksum is off by one.
This problems is data and TCP header dependent due to #2 and #3
above so it doesn't occur on every TCP packet split.
Signed-off-by: Dave Johnson <djohnson+linux-mips@sw.starentnetworks.com>
With commit 63dc68a8cf60cb110b147dab1704d990808b39e2, kernel can not
handle BUG() and BUG_ON() properly since get_user() returns false for
kernel code. Use __get_user() to skip unnecessary access_ok(). This
patch also make BRK_BUG code encoded in the TNE instruction.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
The save_fp_context()/restore_fp_context() might sleep on accessing
user stack and therefore might lose FPU ownership in middle of them.
If these function failed due to "in_atomic" test in do_page_fault,
touch the sigcontext area in non-atomic context and retry these
save/restore operation.
This is a replacement of a (broken) fix which was titled "Allow CpU
exception in kernel partially".
The commit 4d40bff7110e9e1a97ff8c01bdd6350e9867cc10 ("Allow CpU
exception in kernel partially") was broken. The commit was to fix
theoretical problem but broke usual case. Revert it for now.
Recent versions of the BCM112X processors aren't recognized by Linux
(preventing Linux from booting on those processors). This patch adds
support for those that are missing.
Signed-off-by: Mark Mason <mason@broadcom.com>
[BRIDGE]: Unaligned access when comparing ethernet addresses
[SCTP]: Unmap v4mapped addresses during SCTP_BINDX_REM_ADDR operation.
[SCTP]: Fix assertion (!atomic_read(&sk->sk_rmem_alloc)) failed message
[NET]: Set a separate lockdep class for neighbour table's proxy_queue
[NET]: Fix UDP checksum issue in net poll mode.
[KEY]: Fix conversion between IPSEC_MODE_xxx and XFRM_MODE_xxx.
[NET]: Get rid of alloc_skb_from_cache
Provide an dummy implementation of devm_ioport_map() and
devm_ioport_unmap() to allow drivers (eg, pata_platform) to build for
platforms where CONFIG_NO_IOPORT is selected.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jeff Garzik <jeff@garzik.org>
Override compiler .arch directive for generic kernel build.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Signed-off-by: Richard Henderson <rth@twiddle.net>
Files:
arch/alpha/kernel/core_mcpcia.c
arch/alpha/kernel/sys_rawhide.c
include/asm-alpha/core_mcpcia.h
Determine correct hose configuration; RAWHIDE family can have
2 or 4 hoses, so make sure non-existent hoses are ignored.
arch/alpha/kernel/err_titan.c
Supply a needed #include <asm/irq_regs.h>
arch/alpha/kernel/module.c
Add some useful output to the relocation overflow messages.
arch/alpha/kernel/sys_noritake.c
Supply necessary noritake_end_irq() to correct interrupt handling.
This fixes a problem first noted by hangs during boot probing with
a DE500-BA TULIP NIC present.
arch/alpha/kernel/sys_sio.c
Correct saving of original PIRQ register (PCI IRQ routing);
change default PIRQ setting to leave PCI IRQs 9 and 14 free to
be used for sound (Multia) and IDE (any), respectively.
include/asm-alpha/io.h
Supply the "isa_virt_to_bus" routine.
Signed-off-by: Jay Estabrook <jay.estabrook@hp.com>
Cc: Richard Henderson <rth@twiddle.net>
Make kernel-doc comments match macro names.
Correct parameter names in a few places.
Remove '#' from beginning of kernel-doc comment macro names.
Remove extra (erroneous) blank lines in kernel-doc.
Warning(plist.h:100): Cannot understand * #PLIST_HEAD_INIT - static struct plist_head initializer on line 100 - I thought it was a doc line
Warning(plist.h:112): Cannot understand * #PLIST_NODE_INIT - static struct plist_node initializer on line 112 - I thought it was a doc line
Warning(plist.h:103): No description found for parameter '_lock'
Warning(plist.h:129): No description found for parameter 'lock'
Warning(plist.h:158): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'n'
Warning(plist.h:179): No description found for parameter 'mem'
This still leaves one warning & one error that need attention:
Error(plist.h:219): cannot understand prototype: '('
Warning(plist.h): no structured comments found
Acked-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Daniel Walker <dwalker@mvista.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Trivial change to pass vmsplice arguments through the compat layer on
pp64.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
Acked-by: Paul Mackerras <paulus@samba.org>
Otherwise the following calltrace will lead to a wrong
lockdep warning:
neigh_proxy_process()
`- lock(neigh_table->proxy_queue.lock);
arp_redo /* via tbl->proxy_redo */
arp_process
neigh_event_ns
neigh_update
skb_queue_purge
`- lock(neighbor->arp_queue.lock);
This is not a deadlock actually, as neighbor table's proxy_queue
and the neighbor's arp_queue are different queues.
Lockdep thinks there is a deadlock as both queues are initialized
with skb_queue_head_init() and thus have a common class.
Since this was added originally for Xen, and Xen has recently (~2.6.18)
stopped using this function, we can safely get rid of it. Good timing
too since this function has started to bit rot.
If the writebacks are cancelled via nfs_cancel_dirty_list, or due to the
memory allocation failing in nfs_flush_one/nfs_flush_multi, then we must
ensure that the PG_writeback flag is cleared.
Also ensure that we actually own the PG_writeback flag whenever we
schedule a new writeback by making nfs_set_page_writeback() return the
value of test_set_page_writeback().
The PG_writeback page flag ends up replacing the functionality of the
PG_FLUSHING nfs_page flag, so we rip that out too.
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6:
ide: add "optical" to sysfs "media" attribute
ide: ugly messages trying to open CD drive with no media present
ide: correctly prevent IDE timer expiry function to run if request was already handled
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] SGI Altix : fix pcibr_dmamap_ate32() bug
[IA64] Fix CPU freq displayed in /proc/cpuinfo
[IA64] Fix wrong assumption about irq and vector in msi_ia64.c
[IA64] BTE error timer fix
already handled
It is possible for the timer expiry function to run even though the
request has already been handled: ide_timer_expiry() only checks that
the handler is not NULL, but it is possible that we have handled a
request (thus clearing the handler) and then started a new request
(thus starting the timer again, and setting a handler).
A simple way to exhibit this is to set the DMA timeout to 1 jiffy and
run dd: The kernel will panic after a few minutes because
ide_timer_expiry() tries to add a timer when it's already active.
To fix this, we simply add a request generation count that gets
incremented at every interrupt, and check in ide_timer_expiry() that
we have not already handled a new interrupt before running the expiry
function.
Signed-off-by: Suleiman Souhlal <suleiman@google.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Since lazy MMU batching mode still allows interrupts to enter, it is
possible for interrupt handlers to try to use kmap_atomic, which fails when
lazy mode is active, since the PTE update to highmem will be delayed. The
best workaround is to issue an explicit flush in kmap_atomic_functions
case; this is the only way nested PTE updates can happen in the interrupt
handler.
Thanks to Jeremy Fitzhardinge for noting the bug and suggestions on a fix.
This patch gets reverted again when we start 2.6.22 and the bug gets fixed
differently.
Signed-off-by: Zachary Amsden <zach@vmware.com>
Cc: Andi Kleen <ak@muc.de>
Soeren Sonnenburg reported that upon resume he is getting
this backtrace:
[<c0119637>] smp_apic_timer_interrupt+0x57/0x90
[<c0142d30>] retrigger_next_event+0x0/0xb0
[<c0104d30>] apic_timer_interrupt+0x28/0x30
[<c0140068>] __kfifo_put+0x8/0x90
[<c0130fe5>] on_each_cpu+0x35/0x60
[<c0143538>] clock_was_set+0x18/0x20
[<c0135cdc>] timekeeping_resume+0x7c/0xa0
[<c02aabe1>] __sysdev_resume+0x11/0x80
[<c02ab0c7>] sysdev_resume+0x47/0x80
[<c02b0b05>] device_power_up+0x5/0x10
it turns out that on resume we mistakenly re-enable interrupts too
early. Do the timer retrigger only on the current CPU.
Acked-by: Soeren Sonnenburg <kernel@nn7.de>
On a SGI Altix TIOCP based PCI bus we need to include the ATE_PIO attribute
bit if we're mapping a 32bit MSI address.
Signed-off-by: Mike Habeck <habeck@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Just a one-byter for an ia64 thinko/typo - already fixed for i386 and x86_64.
Acked-by: Tony Luck <tony.luck@intel.com>
Revert all this. It can cause device-mapper to receive a different major from
earlier kernels and it turns out that the Amanda backup program (via GNU tar,
apparently) checks major numbers on files when performing incremental backups.
Which is a bit broken of Amanda (or tar), but this feature isn't important
enough to justify the churn.
A device can be removed from an md array via e.g.
echo remove > /sys/block/md3/md/dev-sde/state
This will try to remove the 'dev-sde' subtree which will deadlock
since
commit e7b0d26a86943370c04d6833c6edba2a72a6e240
With this patch we run the kobject_del via schedule_work so as to
avoid the deadlock.
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Neil Brown <neilb@suse.de>
patch 4/4:
Limit ATAPI DMA to R/W commands only for TORiSAN DRD-N216 DVD-ROM drives
(http://bugzilla.kernel.org/show_bug.cgi?id=6710)
Signed-off-by: Albert Lee <albertcc@tw.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
patch 3/4:
The TORiSAN drive locks up when max sector == 256.
Limit max sector to 128 for the TORiSAN DRD-N216 drives.
patch 1/4:
Reorder HSM_ST_FIRST, such that the task state transition is easier decoded with human eyes.
Add unsigned to unused bit field in a.out.h to make sparse happy.
[ I took care of the sparc64 side as well -DaveM ]
Signed-off-by: Robert Reif <reif@earthlink.net>
