This is my rewrite of the SMBus PEC support. The original
implementation was known to have bugs (credits go to Hideki Iwamoto
for reporting many of them recently), and was incomplete due to a
conceptual limitation.
The rewrite affects only software PEC. Hardware PEC needs very little
code and is mostly untouched.
Technically, both implementations differ in that the original one
was emulating PEC in software by modifying the contents of an
i2c_smbus_data union (changing the transaction to a different type),
while the new one works one level lower, on i2c_msg structures (working
on message contents). Due to the definition of the i2c_smbus_data union,
not all SMBus transactions could be handled (at least not without
changing the definition of this union, which would break user-space
compatibility), and those which could had to be implemented
individually. At the opposite, adding PEC to an i2c_msg structure
can be done on any SMBus transaction with common code.
Advantages of the new implementation:
* It's about twice as small (from ~136 lines before to ~70 now, only
counting i2c-core, including blank and comment lines). The memory
used by i2c-core is down by ~640 bytes (~3.5%).
* Easier to validate, less tricky code. The code being common to all
transactions by design, the risk that a bug can stay uncovered is
lower.
* All SMBus transactions have PEC support in I2C emulation mode
(providing the non-PEC transaction is also implemented). Transactions
which have no emulation code right now will get PEC support for free
when they finally get implemented.
* Allows for code simplifications in header files and bus drivers
(patch follows).
Drawbacks (I guess there had to be at least one):
* PEC emulation for non-PEC capable non-I2C SMBus masters was dropped.
It was based on SMBus tricks and doesn't quite fit in the new design.
I don't think it's really a problem, as the benefit was certainly
not worth the additional complexity, but it's only fair that I at
least mention it.
Lastly, let's note that the new implementation does slightly affect
compatibility (both in kernel and user-space), but doesn't actually
break it. Some defines will be dropped, but the code can always be
changed in a way that will work with both the old and the new
implementations. It shouldn't be a problem as there doesn't seem to be
many users of SMBus PEC to date anyway.
Discard I2C_FUNC_SMBUS_*_PEC defines. i2c clients are not supposed to
check for PEC support of i2c bus drivers on individual SMBus
transactions, and i2c bus drivers are not supposed to advertise them.
Drop unused i2c-over-parallel-port i2c IDs:
* I2C_HW_B_LPC was never actually used as far as I could search.
* I2C_HW_B_ELV and I2C_HW_B_VELLE are no more used since the
introduction of the unified i2c-parport driver in Linux 2.6.2.
Fix several redefinitions of i2c IDs. i2c IDs must not be defined
outside of i2c-id.h.
Signed-off-by: Henk Vergonet <henk@god.dyndns.org>
Acked-by: Mark McClelland <mark@alpha.dyndns.org>
New driver for the Xicor X1205 RTC chip.
Signed-off-by: Alessandro Zummo <alessandro.zummo@towertech.it>
Drop I2C_SMBUS_I2C_BLOCK_MAX, use I2C_SMBUS_BLOCK_MAX instead.
I2C_SMBUS_I2C_BLOCK_MAX has always been defined to the same value as
I2C_SMBUS_BLOCK_MAX, and this will never change: setting it to a lower
value would make no sense, setting it to a higher value would break
i2c_smbus_data compatibility. There is no point in changing
i2c_smbus_data to support larger block transactions in SMBus mode, as
no SMBus hardware supports more than 32 byte blocks. Thus, for larger
transactions, direct I2C transfers are the way to go.
There are no more per-i2c-algorithm adapter max. Last time there were
was in July 1999.
Delete 2 out-of-date, colliding ioctl defines. I2C_UDELAY and
I2C_MDELAY are supposed to be used by i2c-algo-bit, but actually
aren't (and I suspect never were). Moreover, their values are the same
as I2C_FUNCS and I2C_SLAVE_FORCE, respectively, which *are* widely
used.
Fix a misplaced comment in i2c.h. Spotted by Hideki Iwamoto.
CVS revision IDs are totally useless and irrelevant by now.
The i2c_smbus_data union block member has a comment stating that an
extra byte is required for SMBus Block Process Call transactions. This
has been true for three weeks around June 2002, but no more since, so
it is about time that we drop this comment and fix the definition.
include/linux/i2c.h | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
Attached is kernel patch for UDP Fragmentation Offload (UFO) feature.
1. This patch incorporate the review comments by Jeff Garzik.
2. Renamed USO as UFO (UDP Fragmentation Offload)
3. udp sendfile support with UFO
This patches uses scatter-gather feature of skb to generate large UDP
datagram. Below is a "how-to" on changes required in network device
driver to use the UFO interface.
UDP Fragmentation Offload (UFO) Interface:
UFO is a feature wherein the Linux kernel network stack will offload the
IP fragmentation functionality of large UDP datagram to hardware. This
will reduce the overhead of stack in fragmenting the large UDP datagram to
MTU sized packets
1) Drivers indicate their capability of UFO using
dev->features |= NETIF_F_UFO | NETIF_F_HW_CSUM | NETIF_F_SG
NETIF_F_HW_CSUM is required for UFO over ipv6.
2) UFO packet will be submitted for transmission using driver xmit routine.
UFO packet will have a non-zero value for
"skb_shinfo(skb)->ufo_size"
skb_shinfo(skb)->ufo_size will indicate the length of data part in each IP
fragment going out of the adapter after IP fragmentation by hardware.
skb->data will contain MAC/IP/UDP header and skb_shinfo(skb)->frags[]
contains the data payload. The skb->ip_summed will be set to CHECKSUM_HW
indicating that hardware has to do checksum calculation. Hardware should
compute the UDP checksum of complete datagram and also ip header checksum of
each fragmented IP packet.
For IPV6 the UFO provides the fragment identification-id in
skb_shinfo(skb)->ip6_frag_id. The adapter should use this ID for generating
IPv6 fragments.
Signed-off-by: Ananda Raju <ananda.raju@neterion.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (forwarded)
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
This patch makes another bunch of functions static.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
This patch moves rfcomm_crc_table[] into the RFCOMM core, because there
is no need to keep it in a separate file.
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
Input: prepare to sysfs integration
Add struct class_device to input_dev; add input_allocate_dev()
to dynamically allocate input devices; dynamically allocated
devices are automatically registered with sysfs.
This patch allows struct class_device to be nested, so that another
struct class_device can be the parent of a new one, instead of only
having the struct class be the parent. This will allow us to
(hopefully) fix up the input and video class subsystem mess.
But please people, don't go crazy and start making huge trees of class
devices, you should only need 2 levels deep to get everything to work
(remember to use a class_interface to get notification of a new class
device being added to the system.)
Oh, this also allows us to have the possibility of potentially, someday,
moving /sys/block into /sys/class. The main hindrance is that pesky
/dev numberspace issue...
A "coldplug + udevstart" can be simple like this:
for i in /sys/block/*/*/uevent; do echo 1 > $i; done
for i in /sys/class/*/*/uevent; do echo 1 > $i; done
for i in /sys/bus/*/devices/*/uevent; do echo 1 > $i; done
Signed-off-by: Kay Sievers <kay.sievers@suse.de>
Driver core: pass interface to class intreface methods
Pass interface as argument to add() and remove() class interface
methods. This way a subsystem can implement generic add/remove
handlers and then call interface-specific ones.
I2O: cleanup - remove i2o_device_class
I2O devices reside on their own bus so there should be no reason
to also have i2c_device class that mirros i2o bus.
This is a refresh of an earlier patch to add "wakeup" support to the
PM core model. This provides per-device bus-neutral control of the
use of wakeup events.
* "struct device_pm_info" has two bits that are initialized as
part of setting up the enclosing struct device:
- "can_wakeup", reflecting hardware capabilities
- "may_wakeup", the policy setting (when CONFIG_PM)
* There's a writeable sysfs "wakeup" file, with one of two values:
- "enabled", when the policy is to allow wakeup
- "disabled", when the policy is not to allow it
- "" if the device can't currently issue wakeups
By default, wakeup is enabled on all devices that support it. If its
driver doesn't support it ... treat it as a bug. :)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Minor manual fixups for gfp_t clashes.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
Manual fixup for trivial "gfp_t" changes.
git://brick.kernel.dk/data/git/linux-2.6-block
Patch from Bellido Nicolas
The AAEC-2000 has an ARM PrimeCell PL110 Color LCD Controller.
This patch contains the platform glue that will be used by specific boards.
Signed-off-by: Nicolas Bellido <ml@acolin.be>
This adds platform code for MTD devices on AAEC-2000.
linux/config.h is not necessary in hardware.h, while asm/sizes.h and asm/arch//aaec2000.h will be used later.
The AAED-2000 board has GPIO pins on an external port.
This patch adds the defines, and do the necessary mapping.
Add defines for GPIO registers on the AAEC-2000 processor.
Patch from Nicolas Pitre
This is the PXA2xx common IRDA driver, plus platform support
for Lubbock and Mainstone.
Signed-off-by: Nicolas Pitre <nico@cam.org>
Acked-by: Jean Tourrilhes <jt@hpl.hp.com>
Patch from Erik Hovland
I noticed that the same typo (i before c in associated) showed up twice
in the file kernel/include/linux/mmc/mmc.h.
This patch fixes both of the instances I found with this mistake. The
typos are in comments and should have no affect on working code.
E
Signed-off-by: Erik Hovland <erik@hovland.org>
Patch from Matt Reimer
Adds support for HWUART on PXA 255 / 26x. This patch originally came from
http://svn.rungie.com/svn/gumstix-buildroot/trunk/sources/kernel-patches/000-gumstix-hwuart.patch
and has been tweaked by me.
Signed-off-by: Matt Reimer <mreimer@vpop.net>
Patch from Todd Poynor
Add symbols for PXA2xx PWRMODE register M field that selects low-power
mode, replace unadorned constants. Honor power mode parameter of
pxa_cpu_suspend(mode), no longer force to 3 (sleep). Full Deep Sleep
low-power mode support for PXA27x is pending generic PM interfaces to
select more than 2 suspend-to-RAM-style power modes, but this is
expected soon. This can be hardcoded in the meantime by replacing the
pxa_cpu_suspend() parameter value. From David Burrage and Todd Poynor.
Try #2 removes one of the register copies and moves the code to save the
pxa_cpu_suspend parameter to immediately surround the call that requires
the parameter value be preserved.
Signed-off-by: Todd Poynor <tpoynor@mvista.com>
Patch from Jon Ringle
Updated 2898/1 per comments:
- Removed fixup
- Moved code in mach-mp1000/ to mach-clps711x/
- Cleaned up code in mp1000-seprom.c. Eliminated code that displayed the contents of the eeprom
Please comment.
Signed-off-by: Jon Ringle
zone handling, mapping->flags handling
