Add the ability to advertise interface combinations in nl80211.
This allows the driver to indicate what the combinations are
that it supports. "Combinations" of just a single interface are
implicit, as previously. Note that cfg80211 will enforce that
the restrictions are met, but not for all drivers yet (once all
drivers are updated, we can remove the flag and enforce for all).
When no combinations are actually supported, an empty list will
be exported so that userspace can know if the kernel exported
this info or not (although it isn't clear to me what tools using
the info should do if the kernel didn't export it).
Since some interface types are purely virtual/software and don't
fit the restrictions, those are exposed in a new list of pure SW
types, not subject to restrictions. This mainly exists to handle
AP-VLAN and monitor interfaces in mac80211.
When sched_scan_stopped was called by the driver, mac80211 calls
cfg80211, which in turn was calling mac80211 back with a flag
"driver_initiated". This flag was used so that mac80211 would do the
necessary cleanup but would not call the driver. This was enough to
prevent the bounce back between the driver and mac80211, but not
between mac80211 and cfg80211.
To fix this, we now do the cleanup in mac80211 before calling
cfg80211. To help with locking issues, the workqueue was moved from
cfg80211 to mac80211.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Luciano Coelho <coelho@ti.com>
Multiple virtual AP interfaces can currently try
to use different beacon intervals, but that just
leads to problems since it won't actually be done
that way by drivers. Return an error in this case
to make sure it won't be done wrong.
Also, ignore attempts to change the DTIM period
or beacon interval during the lifetime of the BSS.
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-next-2.6
Introduce NL80211_ATTR_SCHED_SCAN_INTERVAL as a required attribute for
NL80211_CMD_START_SCHED_SCAN. This value informs the driver at which
intervals the scheduled scan cycles should be executed.
Implement support for HW scheduled scan. The mac80211 code doesn't perform
scheduled scans itself, but calls the driver to start and stop scheduled
scans.
This patch also creates a trace event class to be used by drv_hw_scan
and the new drv_sched_scan_start and drv_sched_stop functions, in
order to avoid duplicate code.
Implement new functionality for scheduled scan offload. With this feature we
can scan automatically at certain intervals.
The idea is that the hardware can perform scan automatically and filter on
desired results without waking up the host unnecessarily.
Add NL80211_CMD_START_SCHED_SCAN and NL80211_CMD_STOP_SCHED_SCAN
commands to the nl80211 interface. When results are available they are
reported by NL80211_CMD_SCHED_SCAN_RESULTS events. The userspace is
informed when the scheduled scan has stopped with a
NL80211_CMD_SCHED_SCAN_STOPPED event, which can be triggered either by
the driver or by a call to NL80211_CMD_STOP_SCHED_SCAN.
Commiting settings is possible on devices without PCI core (but with CC
core). Export it for usage in drivers supporting other cores.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Similar patch was commited to ssb.
They may contain encrypted information elements (as AMPE frames do)
but they are not encrypted.
Signed-off-by: Thomas Pedersen <thomas@cozybit.com>
Signed-off-by: Javier Cardona <javier@cozybit.com>
Mesh beacons no longer use all-zeroes BSSID. Beacon frames for MBSS,
infrastructure BSS, or IBSS are differentiated by the Capability
Information field in the Beacon frame. A mesh STA sets the ESS and IBSS
subfields to 0 in transmitted Beacon or Probe Response management
frames.
Note: This breaks compatibility with previous mesh protocol instances.
Introduce a new configuration option to support AMPE from userspace.
Prior to this series we only supported authentication in userspace: an
authentication daemon would authenticate peer candidates in userspace
and hand them over to the kernel. From that point the mesh stack would
take over and establish a peer link (Mesh Peering Management).
These patches introduce support for Authenticated Mesh Peering Exchange
in userspace. The userspace daemon implements the AMPE protocol and on
successfull completion create mesh peers and install encryption keys.
In case of pre v2.1 devices authentication request will return
success immediately if the link key already exists without any
authentication process.
That means, it's not possible to re-authenticate the link if you
already have combination key and for instance want to re-authenticate
to get the high security (use 16 digit pin).
Therefore, it's necessary to check security requirements on auth
complete event to prevent not enough secure connection.
Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Broadcom has released cards based on a new AMBA-based bus type. From a
programming point of view, this new bus type differs from AMBA and does
not use AMBA common registers. It also differs enough from SSB. We
decided that a new bus driver is needed to keep the code clean.
In its current form, the driver detects devices present on the bus and
registers them in the system. It allows registering BCMA drivers for
specified bus devices and provides them basic operations. The bus driver
itself includes two important bus managing drivers: ChipCommon core
driver and PCI(c) core driver. They are early used to allow correct
initialization.
Currently code is limited to supporting buses on PCI(e) devices, however
the driver is designed to be used also on other hosts. The host
abstraction layer is implemented and already used for PCI(e).
Support for PCI(e) hosts is working and seems to be stable (access to
80211 core was tested successfully on a few devices). We can still
optimize it by using some fixed windows, but this can be done later
without affecting any external code. Windows are just ranges in MMIO
used for accessing cores on the bus.
Cc: Greg KH <greg@kroah.com>
Cc: Michael Büsch <mb@bu3sch.de>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: George Kashperko <george@znau.edu.ua>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: Andy Botting <andy@andybotting.com>
Cc: linuxdriverproject <devel@linuxdriverproject.org>
Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org>
This adds basic support for the new WoWLAN
configuration in mac80211. The behaviour is
completely offloaded to the driver though,
with two new callbacks (suspend/resume).
Options for the driver include a complete
reconfiguration after wakeup, and exposing
all the triggers it wants to support.
This is based on (but now quite far from) the
original work from Luis and Eliad. Add support
for configuring WoWLAN triggers, and getting
the configuration out again. Changes from the
original patchset are too numerous to list,
but one important change needs highlighting:
the suspend() callback is passed NULL for the
trigger configuration if userspace has not
configured WoWLAN at all.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
Signed-off-by: Eliad Peller <eliad@wizery.com>
The only user of WIPHY_FLAG_SUPPORTS_SEPARATE_DEFAULT_KEYS was removed
and consequently, this flag can be removed, too. In addition, a single
capability flag was not enough to indicate this capability clearly since
the device behavior may be different based on which operating mode is
being used.
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
A new list was added to replace the socket based one. This new list
doesn't depent on sock and then fits better inside l2cap_core.c code.
It also rename l2cap_chan_alloc() to l2cap_chan_create() and
l2cap_chan_free() to l2cap_chan_destroy)
When the user doesn't specify a psm we have the choose one for the
channel. Now we do this inside l2cap_add_psm().
The intention is to get rid of the l2cap_sk_list usage inside
l2cap_core.c. l2cap_sk_list will soon be replaced by a list that does not
depend on socket usage.
Even for keys that shouldn't be stored some use cases require the
knowledge of a new key having been created so that the conclusion of a
successful pairing can be made. Therefore, always send the mgmt_new_key
event but add a store_hint parameter to it to indicate to user space
whether the key should be stored or not.
Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com>
User space shouldn't have any need for the old key type so remove it
from the corresponding Management interface event.
Link keys should only be stored if very specific criteria of the
authentication process are fulfilled. This patch essentially copies the
criteria that user space has so far been using to the kernel side so
that the management interface works properly.
When accepting a pairing request which fulfills the SSP auto-accept
criteria we need to push the request all the way to the user for
confirmation. This patch adds a new hint to the user_confirm_request
management event so user space can know when to show a numeric
comparison dialog and when to show a simple yes/no confirmation dialog.
Some test systems require an arbitrary delay to the auto-accept test
cases for Secure Simple Pairing in order for the tests to pass.
Previously when this was handled in user space it was worked around by
code modifications and recompilation, but now that it's on the kernel
side it's more convenient if there's a debugfs interface for it.
This patch adds a new API for setting a TX rate mask in
drivers that have rate control in either the firmware or hardware.
This can be used for various purposes, for example, masking out the
11b rates in P2P operation.
Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com>
Add API that allows low level drivers to notify mac80211 about TX
packet loss. This is useful when there are FW triggers to notify the
low level driver about these events.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
Extend the mgmt_pin_code_request interface to require secure
pin code (16 digit) for authentication.
This is a kernel part of the secure pin code requirement notification
to user space agent.
Code styling fix by Johan Hedberg.
Keep the link key type together with connection and use it to
map security level to link key requirements. Authenticate and/or
encrypt connection if the link is insufficiently secure.
Introduce the link key types defs and use them instead of magic numbers.
This patch adds a new event to the Management interface to track when
local adapters are discovering remote devices. For now this only tracks
BR/EDR discovery procedures.
Signed-off-by: Anderson Briglia <anderson.briglia@openbossa.org>
This patch adds start_discovery and stop_discovery commands to the
management interface. Right now their implementation is fairly
simplistic and the parameters are fixed to what user space has
defaulted to so far.
This is the very initial phase for discovery implementation into
the kernel. Next steps include name resolution, LE scanning and
bdaddr type handling.
l2cap_sk_ops can be static, it's not used outside l2cap_sock.c
A new l2cap_chan_free() is added to free the channels.
There is no need to the socket deal directly with the channel, most of the
time it cares about the channel only.
In this commit, psm, scid and dcid.
In this commit, omtu, imtu, flush_to, mode and sport. It also remove the
pi var from l2cap_sock_sendmsg().
In this commit all ERTM and Streaming Mode specific vars.
In this commit sec_level, force_reliable, role_switch and flushable.
l2cap_chan_connect() is a much better name and reflects what this
functions is doing (or will do once socket dependence is removed from the
core).
First move of elements depending on user data.
If the allocation happens at l2cap_sock_create() will be able to use the
struct l2cap_chan to store channel info that comes from the user via
setsockopt.
My 14e4:4315 is SSB_IDLOW_SSBREV_26:
read32 0xfaafcff8 -> 0x600422d5
My 14e4:4328 is SSB_IDLOW_SSBREV_24:
read32 0xfaafcff8 -> 0x400422c5
My 14e4:432b is SSB_IDLOW_SSBREV_26 again:
For all of them wl driver is using 0x2 reject bit:
write32(0xf98) <- 0x00010002
So it seems SSB 2.3 is the exception using another bit.
We probably got false positive results for checking PLL being down.
Add a bool in ath9k_platform_data to pass AHB clock speed information.
Driver needs this to configure PLL on some SOCs.
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
git://git.kernel.org/pub/scm/linux/kernel/git/luca/wl12xx
