This patch adds support for subpage (partial-page) writes when using
hardware based ECC schemes.
Advantages:
(1) reduces storage overhead when using file-systems like UBIFS, which
store LEB header at page-size granularity.
(2) allows independent subpage writes, thereby increasing NAND storage
efficiency for non-page aligned data.
+ updated cafe_nand and lpc32xx_mlc NAND drivers for change in
chip->write_page interface.
Signed-off-by: Gupta, Pekon <pekon@ti.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Notice that all the flashes belonging to the "legacy ID" class have 512 bytes
NAND page. This means we may simplify the 'LEGACY_ID_NAND()' macro as well as
the NAND ID table a little.
As time goes on, we begin to meet the situation that we can not get enough
information from some nand chips's id data. Take some Toshiba's nand chips
for example. I have 4 Toshiba's nand chips in my hand:
TC58NVG2S0F, TC58NVG3S0F, TC58NVG5D2, TC58NVG6D2
When we read these chips' datasheets, we will get the geometry of these chips:
TC58NVG2S0F : 4096 + 224
TC58NVG3S0F : 4096 + 232
TC58NVG5D2 : 8192 + 640
TC58NVG6D2 : 8192 + 640
But we can not parse out the correct oob size for these chips from the id data.
This patch adds some new fields to the nand_flash_dev{}:
@id_len: the valid length of the id data. See the comments in
nand_id_has_period()
@oobsize: the oob size.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Reviewed-by: Brian Norris <computersforpeace@gmail.com>
Introduce a helpful macro for the maximum NAND ID sequence length instead of
using the "8" magic number.
Acked-by: Huang Shijie <shijie8@gmail.com>
Use 'unsigned int' instead of 'unsigned long' in the NAND chip description data
structure, because 32-bits is more than enough for our purposes. We do not need
64-bits, which is what we end up on 64-bit architectures. We declare many
instances of this data structure, so this should help saving some amount of
memory.
Be a bit stricter and add few more 'const' qualifiers.
'mtd_device_parse_register()' and 'parse_mtd_partitions()' functions accept a
an array of character pointers. These functions modify neither the pointers nor
the characters they point to. The characters are actually names of the MTD
parsers.
At the moment, the argument type is 'const char **', which means that only the
names of the parsers are constant. Let's turn the argument type into 'const
char * const *', which means that both names and the pointers which point to
them are constant.
In case the driver is not probed - due to config mismatches or errors
in the DTS files - dev_get_drvdata() returns NULL, leading to an Ooops
during boot.
Make elm_config() return an error in such cases to propagate the error
up to the user, so it can fall back to software mode.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
Up until now we identified NAND chips by the 'device ID' part of the full chip
ID array, which is the second full ID array byte. However, the newest flashes
use the same device ID for chips with identical page and eraseblock sizes, but
different OOB sizes. And unfortunately, it is not clear if there is a
"standard" way to fetch the OOB size from chip's full ID array. Here is an
example:
Toshiba TC58NVG2S0F: 0x98, 0xdc, 0x90, 0x26, 0x76, 0x15, 0x01, 0x08
Toshiba TC58NVG3S0F: 0x98, 0xd3, 0x90, 0x26, 0x76, 0x15, 0x02, 0x08
The first one is a 512MiB NAND chip with 4KiB NAND pages, 256KiB eraseblock
size and 224 bytes OOB. The second one is a 1GiB NAND chip with the same page
and eraseblock sizes, but with 232 bytes OOB.
This means that we have to store full ID in our NAND flashes table in order to
distinguish between these 2.
This patch adds the 'id[8]' field to the 'struct nand_flash_dev' structure, and
it makes it to be a part of anonymous union, where the second member is a
structure containing the 'mfr_id' and 'dev_id' bytes. The union makes sure that
'mfr_id' refers the same RAM address as 'id[0]' and 'dev_id' refers the same
RAM address as 'id[1]'. The only motivation for the union is an assumption that
'type->dev_id' is more readable than 'type->id[1]'.
Introduce helper macros for defining NAND chips. These macros do not really add
much value in the current code-base. However, we are going to add full ID
support which adds some more complexity to the table, and helper macros become
useful for readability.
The 'id' is a bit confusing name because NAND IDs are multi-byte. Re-name
it to 'dev_id' to make it clear that this is the "device ID" part (the second
byte).
While on it, clean-up the commentary for 'struct nand_flash_dev'.
Acked-by: Brian Norris <computersforpeace@gmail.com>
We have this unused macro, let's use it and justify its existence.
It is unused.
It is not used anywhere.
We have only one AG-AND driver and it was not touched since 2005. It looks
like AG-AND was not really make it to mass-production and can be considered
a dead technology.
Along with the AG-AND support, this patch removes the BBT_AUTO_REFRESH feature,
because the only user of this feature is AG-AND. And even though it is
implemented as a generic feature, I prefer to remove it because NAND flashes do
not really need it in this form.
Pull MTD fixes from David Woodhouse:
"This fixes a couple of problems. Firstly, some people are actually
still using old small-page flash and we broke it by removing the ready
check.
Secondly. fix the handling of partitions on Broadcom 47xx devices.
Recent changes had made it misdetect the location of the NVRAM and
scribble over the bootloader when it tried to update the variables
there. With predictably sad results."
* tag 'for-linus-20130318' of git://git.infradead.org/linux-mtd:
mtd: nand: reintroduce NAND_NO_READRDY as NAND_NEED_READRDY
mtd: bcm47xxpart: look for NVRAM at the end of device
Revert "mtd: bcm47xxpart: improve probing of nvram partition"
Pull ARM SoC bug fixes from Arnd Bergmann:
"Things are calming down for arm-soc as well. This set of bug fixes is
dominated in size by the at91 platform bug fixes. Some of them were
meant to go through the framebuffer tree during the merge window, but
since the framebuffer maintainer could not be reached, I offered to
take them here. The other notable at91 change is the addition of
pinctrl definitions to fix the NAND controller.
The rest are mostly simple regression fixes:
- Our removal of VIRT_TO_BUS conflicted with Stephen Rothwell's
renaming of the Kconfig symbol. You will get a trivial merge
conflict here, we still want to remove it.
- missing bits for clocks on imx and s5pv210
- missing header inclusions in mmp and shmobile
- typos in s5pv210 camera and vt8500 clock support code
and three trivial fixes for pre-3.8 bugs:
- an old bogus build warning in the joystick driver
- a misleading Kconfig description
- a NULL pointer check on davinci"
* tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: fix CONFIG_VIRT_TO_BUS handling
ARM: i.MX35: enable MAX clock
ARM: Scorpion is a v7 architecture, not v6
ARM: mmp: add platform_device head file in gplugd
input/joystick: use get_cycles on ARM
[media] s5p-fimc: fix s5pv210 build
clk: vt8500: Fix "fix device clock divisor calculations"
ARM: i.MX25: Fix DT compilation
ARM: at91: fix infinite loop in at91_irq_suspend/resume
ARM: at91: add gpio suspend/resume support when using pinctrl
ARM: at91: fix LCD-wiring mode
atmel_lcdfb: fix 16-bpp modes on older SOCs
ARM: at91: dt: at91sam9x5: complete NAND pinctrl
ARM: at91: dt: at91sam9x5: correct NAND pins comments
ARM: davinci: edma: fix dmaengine induced null pointer dereference on da830
ARM: shmobile: marzen: Include mmc/host.h
ARM: EXYNOS: Add #dma-cells for generic dma binding support for PL330
ARM: S5PV210: Fix PL330 DMA controller clkdev entries
Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after
suspend/resume") introduces a link failure since
perf_restore_debug_store() is only defined for CONFIG_CPU_SUP_INTEL:
arch/x86/power/built-in.o: In function `restore_processor_state':
(.text+0x45c): undefined reference to `perf_restore_debug_store'
Fix it by defining the dummy function appropriately.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: stable@vger.kernel.org
Pull OpenRISC bug fixes from Jonas Bonn:
- The GPIO descriptor work has exposed how broken the non-GPIOLIB bits
for OpenRISC were. We now require GPIOLIB as this is the preferred
way forward.
- The system.h split introduced a bug in llist.h for arches using
asm-generic/cmpxchg.h directly, which is currently only OpenRISC.
The patch here moves two defines from asm-generic/atomic.h to
asm-generic/cmpxchg.h to make things work as they should.
- The VIRT_TO_BUS selector was added for OpenRISC, but OpenRISC does
not have the virt_to_bus methods, so there's a patch to remove it
again.
* tag 'for-3.9-rc3' of git://openrisc.net/jonas/linux:
openrisc: remove HAVE_VIRT_TO_BUS
asm-generic: move cmpxchg*_local defs to cmpxchg.h
openrisc: require gpiolib
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes
Pull MFD fixes from Samuel Ortiz:
"This is the first batch of MFD fixes for 3.9.
With this one we have:
- An ab8500 build failure fix.
- An ab8500 device tree parsing fix.
- A fix for twl4030_madc remove routine to work properly (when
built-in).
- A fix for properly registering palmas interrupt handler.
- A fix for omap-usb init routine to actually write into the
hostconfig register.
- A couple of warning fixes for ab8500-gpadc and tps65912"
* tag 'mfd-fixes-3.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes:
mfd: twl4030-madc: Remove __exit_p annotation
mfd: ab8500: Kill "reg" property from binding
mfd: ab8500-gpadc: Complain if we fail to enable vtvout LDO
mfd: wm831x: Don't forward declare enum wm831x_auxadc
mfd: twl4030-audio: Fix argument type for twl4030_audio_disable_resource()
mfd: tps65912: Declare and use tps65912_irq_exit()
mfd: palmas: Provide irq flags through DT/platform data
mfd: Make AB8500_CORE select POWER_SUPPLY to fix build error
mfd: omap-usb-host: Actually update hostconfig
This patch fixes a kernel crash when using precise sampling (PEBS)
after a suspend/resume. Turns out the CPU notifier code is not invoked
on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly
by the kernel and keeps it power-on/resume value of 0 causing any PEBS
measurement to crash when running on CPU0.
The workaround is to add a hook in the actual resume code to restore
the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0,
the DS_AREA will be restored twice but this is harmless.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Stephane Eranian <eranian@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu
Pull fix for hlist_entry_safe() regression from Paul McKenney:
"This contains a single commit that fixes a regression in
hlist_entry_safe(). This macro references its argument twice, which
can cause NULL-pointer errors. This commit applies a gcc statement
expression, creating a temporary variable to avoid the double
reference. This has been posted to LKML at
https://lkml.org/lkml/2013/3/9/75.
Kudos to CAI Qian, whose testing uncovered this, to Eric Dumazet, who
spotted root cause, and to Li Zefan, who tested this commit."
* 'rcu/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu:
list: Fix double fetch of pointer in hlist_entry_safe()
The current version of hlist_entry_safe() fetches the pointer twice,
once to test for NULL and the other to compute the offset back to the
enclosing structure. This is OK for normal lock-based use because in
that case, the pointer cannot change. However, when the pointer is
protected by RCU (as in "rcu_dereference(p)"), then the pointer can
change at any time. This use case can result in the following sequence
of events:
1. CPU 0 invokes hlist_entry_safe(), fetches the RCU-protected
pointer as sees that it is non-NULL.
2. CPU 1 invokes hlist_del_rcu(), deleting the entry that CPU 0
just fetched a pointer to. Because this is the last entry
in the list, the pointer fetched by CPU 0 is now NULL.
3. CPU 0 refetches the pointer, obtains NULL, and then gets a
NULL-pointer crash.
This commit therefore applies gcc's "({ })" statement expression to
create a temporary variable so that the specified pointer is fetched
only once, avoiding the above sequence of events. Please note that
it is the caller's responsibility to use rcu_dereference() as needed.
This allows RCU-protected uses to work correctly without imposing
any additional overhead on the non-RCU case.
Many thanks to Eric Dumazet for spotting root cause!
Reported-by: CAI Qian <caiqian@redhat.com>
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Tested-by: Li Zefan <lizefan@huawei.com>
This partially reverts commit 1696e6bc2ae83734e64e206ac99766ea19e9a14e
("mtd: nand: kill NAND_NO_READRDY").
In that patch I overlooked a few things.
The original documentation for NAND_NO_READRDY included "True for all
large page devices, as they do not support autoincrement." I was
conflating "not support autoincrement" with the NAND_NO_AUTOINCR option,
which was in fact doing nothing. So, when I dropped NAND_NO_AUTOINCR, I
concluded that I then could harmlessly drop NAND_NO_READRDY. But of
course the fact the NAND_NO_AUTOINCR was doing nothing didn't mean
NAND_NO_READRDY was doing nothing...
So, NAND_NO_READRDY is re-introduced as NAND_NEED_READRDY and applied
only to those few remaining small-page NAND which needed it in the first
place.
Cc: stable@kernel.org [3.5+]
Reported-by: Alexander Shiyan <shc_work@mail.ru>
Tested-by: Alexander Shiyan <shc_work@mail.ru>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Merge misc fixes from Andrew Morton:
- A bunch of fixes
- Finish off the idr API conversions before someone starts to use the
old interfaces again.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
idr: idr_alloc() shouldn't trigger lowmem warning when preloaded
UAPI: fix endianness conditionals in M32R's asm/stat.h
UAPI: fix endianness conditionals in linux/raid/md_p.h
UAPI: fix endianness conditionals in linux/acct.h
UAPI: fix endianness conditionals in linux/aio_abi.h
decompressors: fix typo "POWERPC"
mm/fremap.c: fix oops on error path
idr: deprecate idr_pre_get() and idr_get_new[_above]()
tidspbridge: convert to idr_alloc()
zcache: convert to idr_alloc()
mlx4: remove leftover idr_pre_get() call
workqueue: convert to idr_alloc()
nfsd: convert to idr_alloc()
nfsd: remove unused get_new_stid()
kernel/signal.c: use __ARCH_HAS_SA_RESTORER instead of SA_RESTORER
signal: always clear sa_restorer on execve
mm: remove_memory(): fix end_pfn setting
include/linux/res_counter.h needs errno.h
In the UAPI header files, __BIG_ENDIAN and __LITTLE_ENDIAN must be
compared against __BYTE_ORDER in preprocessor conditionals where these are
exposed to userspace (that is they're not inside __KERNEL__ conditionals).
However, in the main kernel the norm is to check for
"defined(__XXX_ENDIAN)" rather than comparing against __BYTE_ORDER and
this has incorrectly leaked into the userspace headers.
The definition of struct mdp_superblock_s in linux/raid/md_p.h is wrong in
this way. Note that userspace will likely interpret the ordering of the
fields incorrectly as the big-endian variant on a little-endian machines -
depending on header inclusion order.
[!!!] NOTE [!!!] This patch may adversely change the userspace API. It might
be better to fix the ordering of events_hi, events_lo, cp_events_hi and
cp_events_lo in struct mdp_superblock_s / typedef mdp_super_t.
Acked-by: NeilBrown <neilb@suse.de>
The definition of ACCT_BYTEORDER in linux/acct.h is wrong in this way.
Note that userspace will likely interpret this incorrectly as the
big-endian variant on little-endian machines - depending on header
inclusion order.
be better to fix the value of ACCT_BYTEORDER.
The definition of PADDED() in linux/aio_abi.h is wrong in this way. Note
that userspace will likely interpret this and thus the order of fields in
struct iocb incorrectly as the little-endian variant on big-endian
machines - depending on header inclusion order.
be better to fix the ordering of aio_key and aio_reserved1 in struct iocb.
Acked-by: Benjamin LaHaise <bcrl@kvack.org>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Now that all in-kernel users are converted to ues the new alloc
interface, mark the old interface deprecated. We should be able to
remove these in a few releases.
alpha allmodconfig:
In file included from mm/memcontrol.c:28:
include/linux/res_counter.h: In function 'res_counter_set_limit':
include/linux/res_counter.h:203: error: 'EBUSY' undeclared (first use in this function)
include/linux/res_counter.h:203: error: (Each undeclared identifier is reported only once
include/linux/res_counter.h:203: error: for each function it appears in.)
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Glauber Costa <glommer@parallels.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Frederic Weisbecker <fweisbec@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg Kroah-Hartman:
"Here are a number of tiny USB fixes and new USB device ids for your
3.9 tree.
The "largest" one here is a revert of a usb-storage patch that turned
out to be incorrect, breaking existing users, which is never a good
thing. Everything else is pretty simple and small"
* tag 'usb-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (43 commits)
USB: quatech2: only write to the tty if the port is open.
qcserial: bind to DM/DIAG port on Gobi 1K devices
USB: cdc-wdm: fix buffer overflow
usb: serial: Add Rigblaster Advantage to device table
qcaux: add Franklin U600
usb: musb: core: fix possible build error with randconfig
usb: cp210x new Vendor/Device IDs
usb: gadget: pxa25x: fix disconnect reporting
usb: dwc3: ep0: fix sparc64 build
usb: c67x00 RetryCnt value in c67x00 TD should be 3
usb: Correction to c67x00 TD data length mask
usb: Makefile: fix drivers/usb/phy/ Makefile entry
USB: added support for Cinterion's products AH6 and PLS8
usb: gadget: fix omap_udc build errors
USB: storage: fix Huawei mode switching regression
USB: storage: in-kernel modeswitching is deprecated
tools: usb: ffs-test: Fix build failure
USB: option: add Huawei E5331
usb: musb: omap2430: fix sparse warning
usb: musb: omap2430: fix omap_musb_mailbox glue check again
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg Kroah-Hartman:
"Here are some tty/serial driver fixes for 3.9
We finally mute the annoying WARN_ON that lots of people are hitting
and it turns out isn't needed anymore. Also add a few new device ids
and a some other minor fixes."
* tag 'tty-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
tty: serial: fix typo "SERIAL_S3C2412"
serial: 8250: Keep 8250.<xxxx> module options functional after driver rename
tty: serial: fix typo "ARCH_S5P6450"
tty/8250_pnp: serial port detection regression since v3.7
serial: bcm63xx_uart: fix compilation after "TTY: switch tty_insert_flip_char"
serial: 8250_pci: add support for another kind of NetMos Technology PCI 9835 Multi-I/O Controller
Fix 4 port and add support for 8 port 'Unknown' PCI serial port cards
tty/serial: Add support for Altera serial port
tty: serial: vt8500: Unneccessary duplicated clock code removed
tty: serial: mpc5xxx: fix PSC clock name bug
TTY: disable debugging warning
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree fixes from Greg Kroah-Hartman:
"Here are some drivers/staging and drivers/iio fixes for 3.9 (the two
are still pretty intertwined, hence them coming both from my tree
still.) Nothing major, just a few things that have been reported by
users, all of these have been in linux-next for a while."
* tag 'staging-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: comedi: dt9812: use CR_CHAN() for channel number
staging/vt6656: Fix too large integer constant warning on 32-bit
staging: comedi: drivers: usbduxsigma.c: fix DMA buffers on stack
staging: imx/drm: request irq only after adding the crtc
staging: comedi: drivers: usbduxfast.c: fix for DMA buffers on stack
staging: comedi: drivers: usbdux.c: fix DMA buffers on stack
staging: vt6656: Fix oops on resume from suspend.
iio:common:st_sensors fixed all warning messages about uninitialized variables
iio: Fix build error seen if IIO_TRIGGER is defined but IIO_BUFFER is not
iio/imu: inv_mpu6050 depends on IIO_BUFFER
iio:ad5064: Initialize register cache correctly
iio:ad5064: Fix off by one in DAC value range check
iio:ad5064: Fix address of the second channel for ad5065/ad5045/ad5025
Fix regression introduced by commit 787f9fd23283 ("atmel_lcdfb: support
16bit BGR:565 mode, remove unsupported 15bit modes") which broke 16-bpp
modes for older SOCs which use IBGR:555 (msb is intensity) rather than
BGR:565.
The above commit removes the RGB:555-wiring hack by
removing the no longer used ATMEL_LCDC_WIRING_RGB555 define.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
than BGR:565.
Use SOC-type to determine the pixel layout.
Tested on at91sam9263 and at91sam9g45.
Cc: <stable@vger.kernel.org>
asm/cmpxchg.h can be included on its own and needs to be self-consistent.
The definitions for the cmpxchg*_local macros, as such, need to be part
of this file.
This fixes a build issue on OpenRISC since the system.h smashing patch
96f951edb1f1bdbbc99b0cd458f9808bb83d58ae that introdued the direct inclusion
asm/cmpxchg.h into linux/llist.h.
CC: David Howells <dhowells@redhat.com>
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Fix new kernel-doc warnings in idr:
Warning(include/linux/idr.h:113): No description found for parameter 'idr'
Warning(include/linux/idr.h:113): Excess function parameter 'idp' description in 'idr_find'
Warning(lib/idr.c:232): Excess function parameter 'id' description in 'sub_alloc'
Acked-by: Tejun Heo <tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull Xen fixes from Konrad Rzeszutek Wilk:
- Compile warnings and errors (one on x86, two on ARM)
- WARNING in xen-pciback
- Use the acpi_processor_get_performance_info instead of the 'register'
version
* tag 'stable/for-linus-3.9-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/acpi: remove redundant acpi/acpi_drivers.h include
xen: arm: mandate EABI and use generic atomic operations.
acpi: Export the acpi_processor_get_performance_info
xen/pciback: Don't disable a PCI device that is already disabled.
Add support for Altera 8250/16550 compatible serial port.
Signed-off-by: Ley Foon Tan <lftan@altera.com>
Cc: stable <stable@vger.kernel.org>
We can't forward declare enums.
Clean up interrupts on exit, silencing a sparse warning caused by
tps65912_irq_exit() being defined but not prototyped as we go.
Currently driver sets the irq type to IRQF_TRIGGER_LOW which is
causing interrupt registration failure in ARM based SoCs as:
[ 0.208479] genirq: Setting trigger mode 8 for irq 118 failed (gic_set_type+0x0/0xf0)
[ 0.208513] dummy 0-0059: Failed to request IRQ 118: -22
Provide the irq flags through platform data if device is registered
through board file or get the irq type from DT node property in place
of hardcoding the irq flag in driver to support multiple platforms.
Also configure the device to generate the interrupt signal according to
flag type.
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace bugfixes from Eric Biederman:
"This is three simple fixes against 3.9-rc1. I have tested each of
these fixes and verified they work correctly.
The userns oops in key_change_session_keyring and the BUG_ON triggered
by proc_ns_follow_link were found by Dave Jones.
I am including the enhancement for mount to only trigger requests of
filesystem modules here instead of delaying this for the 3.10 merge
window because it is both trivial and the kind of change that tends to
bit-rot if left untouched for two months."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
proc: Use nd_jump_link in proc_ns_follow_link
fs: Limit sys_mount to only request filesystem modules (Part 2).
fs: Limit sys_mount to only request filesystem modules.
userns: Stop oopsing in key_change_session_keyring
This same driver can be used by atmel based touchscreens and touchpads
(buttonpads). Platform data may specify a device is a touchpad
using the is_tp flag.
This will cause the driver to perform some touchpad specific
initializations, such as:
* register input device name "Atmel maXTouch Touchpad" instead of
Touchscreen.
* register BTN_LEFT & BTN_TOOL_* event types.
* register axis resolution (as a fixed constant, for now)
* register BUTTONPAD property
* process GPIO buttons using reportid T19
Input event GPIO mapping is done by the platform data key_map array.
key_map[x] should contain the KEY or BTN code to send when processing
GPIOx from T19. To specify a GPIO as not an input source, populate
with KEY_RESERVED, or 0.
Signed-off-by: Daniel Kurtz <djkurtz@chromium.org>
Signed-off-by: Benson Leung <bleung@chromium.org>
Signed-off-by: Nick Dyer <nick.dyer@itdev.co.uk>
Tested-by: Olof Johansson <olof@lixom.net>
Pull drm fixes from Dave Airlie:
"Misc radeon, nouveau, mgag200 and intel fixes.
The intel fixes should contain the fix for the touchpad on the
Chromebook - hey I'm an input maintainer now!"
Hate to pee on your parade, Dave, but I don't think being an input
maintainer is necessarily something to strive for..
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (25 commits)
drm/tegra: drop "select DRM_HDMI"
drm: Documentation typo fixes
drm/mgag200: Bug fix: Renesas board now selects native resolution.
drm/mgag200: Reject modes that are too big for VRAM
drm/mgag200: 'fbdev_list' in 'struct mga_fbdev' is not used
drm/radeon: don't check mipmap alignment if MIP_ADDRESS is FMASK
drm/radeon: skip MC reset as it's probably not hung
drm/radeon: add primary dac adj quirk for R200 board
drm/radeon: don't set hpd, afmt interrupts when interrupts are disabled
drm/i915: Turn off hsync and vsync on ADPA when disabling crt
drm/i915: Fix incorrect definition of ADPA HSYNC and VSYNC bits
drm/i915: also disable south interrupts when handling them
drm/i915: enable irqs earlier when resuming
drm/i915: Increase the RC6p threshold.
DRM/i915: On G45 enable cursor plane briefly after enabling the display plane.
drm/nv50-: prevent some races between modesetting and page flipping
drm/nouveau/i2c: drop parent refcount when creating ports
drm/nv84: fix regression in page flipping
drm/nouveau: Fix typo in init_idx_addr_latched().
drm/nouveau: Disable AGP on PowerPC again.
Pull ACPI and power management fixes from Rafael J Wysocki:
- Two fixes for the new intel_pstate driver from Dirk Brandewie.
- Fix for incorrect usage of the .find_bridge() callback from struct
acpi_bus_type in the USB core and subsequent removal of that callback
from Rafael J Wysocki.
- ACPI processor driver cleanups from Chen Gang and Syam Sidhardhan.
- ACPI initialization and error messages fix from Joe Perches.
- Operating Performance Points documentation improvement from Nishanth
Menon.
- Fixes for memory leaks and potential concurrency issues and sysfs
attributes leaks during device removal in the core device PM QoS code
- Calxeda Highbank cpufreq driver simplification from Emilio López.
- cpufreq comment cleanup from Namhyung Kim.
- Fix for a section mismatch in Calxeda Highbank interprocessor
communication code from Mark Langsdorf (this is not a PM fix strictly
speaking, but the code in question went in through the PM tree).
* tag 'pm+acpi-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpufreq / intel_pstate: Do not load on VM that does not report max P state.
cpufreq / intel_pstate: Fix intel_pstate_init() error path
ACPI / glue: Drop .find_bridge() callback from struct acpi_bus_type
ACPI / glue: Add .match() callback to struct acpi_bus_type
ACPI / porocessor: Beautify code, pr->id is u32 which is never < 0
ACPI / processor: Remove redundant NULL check before kfree
ACPI / Sleep: Avoid interleaved message on errors
PM / QoS: Remove device PM QoS sysfs attributes at the right place
PM / QoS: Fix concurrency issues and memory leaks in device PM QoS
cpufreq: highbank: do not initialize array with a loop
PM / OPP: improve introductory documentation
cpufreq: Fix a typo in comment
mailbox, pl320-ipc: remove __init from probe function
Signed-off-by: Christopher Harvey <charvey@matrox.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator fixes from Mark Brown:
"A few small things here and there, nothing major here really. The
conversion of twl4030ldo_ops to get_voltage_sel is a fix, as covered
in the commit log it fixes inconsistency in handling of the IS_UNSUP()
feature in the driver."
* tag 'regulator-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: fixed regulator_bulk_enable unwinding code
regulator: twl: Convert twl4030ldo_ops to get_voltage_sel
regulator: palmas: fix number of SMPS voltages
regulator: core: fix documentation error in regulator_allow_bypass
regulator: core: update kernel documentation for regulator_desc
regulator: db8500-prcmu - remove incorrect __exit markup
