With commit 63dc68a8cf60cb110b147dab1704d990808b39e2, kernel can not
handle BUG() and BUG_ON() properly since get_user() returns false for
kernel code. Use __get_user() to skip unnecessary access_ok(). This
patch also make BRK_BUG code encoded in the TNE instruction.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
The save_fp_context()/restore_fp_context() might sleep on accessing
user stack and therefore might lose FPU ownership in middle of them.
If these function failed due to "in_atomic" test in do_page_fault,
touch the sigcontext area in non-atomic context and retry these
save/restore operation.
This is a replacement of a (broken) fix which was titled "Allow CpU
exception in kernel partially".
The commit 4d40bff7110e9e1a97ff8c01bdd6350e9867cc10 ("Allow CpU
exception in kernel partially") was broken. The commit was to fix
theoretical problem but broke usual case. Revert it for now.
Recent versions of the BCM112X processors aren't recognized by Linux
(preventing Linux from booting on those processors). This patch adds
support for those that are missing.
Signed-off-by: Mark Mason <mason@broadcom.com>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[BRIDGE]: Unaligned access when comparing ethernet addresses
[SCTP]: Unmap v4mapped addresses during SCTP_BINDX_REM_ADDR operation.
[SCTP]: Fix assertion (!atomic_read(&sk->sk_rmem_alloc)) failed message
[NET]: Set a separate lockdep class for neighbour table's proxy_queue
[NET]: Fix UDP checksum issue in net poll mode.
[KEY]: Fix conversion between IPSEC_MODE_xxx and XFRM_MODE_xxx.
[NET]: Get rid of alloc_skb_from_cache
Provide an dummy implementation of devm_ioport_map() and
devm_ioport_unmap() to allow drivers (eg, pata_platform) to build for
platforms where CONFIG_NO_IOPORT is selected.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jeff Garzik <jeff@garzik.org>
Override compiler .arch directive for generic kernel build.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Signed-off-by: Richard Henderson <rth@twiddle.net>
Files:
arch/alpha/kernel/core_mcpcia.c
arch/alpha/kernel/sys_rawhide.c
include/asm-alpha/core_mcpcia.h
Determine correct hose configuration; RAWHIDE family can have
2 or 4 hoses, so make sure non-existent hoses are ignored.
arch/alpha/kernel/err_titan.c
Supply a needed #include <asm/irq_regs.h>
arch/alpha/kernel/module.c
Add some useful output to the relocation overflow messages.
arch/alpha/kernel/sys_noritake.c
Supply necessary noritake_end_irq() to correct interrupt handling.
This fixes a problem first noted by hangs during boot probing with
a DE500-BA TULIP NIC present.
arch/alpha/kernel/sys_sio.c
Correct saving of original PIRQ register (PCI IRQ routing);
change default PIRQ setting to leave PCI IRQs 9 and 14 free to
be used for sound (Multia) and IDE (any), respectively.
include/asm-alpha/io.h
Supply the "isa_virt_to_bus" routine.
Signed-off-by: Jay Estabrook <jay.estabrook@hp.com>
Cc: Richard Henderson <rth@twiddle.net>
Make kernel-doc comments match macro names.
Correct parameter names in a few places.
Remove '#' from beginning of kernel-doc comment macro names.
Remove extra (erroneous) blank lines in kernel-doc.
Warning(plist.h:100): Cannot understand * #PLIST_HEAD_INIT - static struct plist_head initializer on line 100 - I thought it was a doc line
Warning(plist.h:112): Cannot understand * #PLIST_NODE_INIT - static struct plist_node initializer on line 112 - I thought it was a doc line
Warning(plist.h:103): No description found for parameter '_lock'
Warning(plist.h:129): No description found for parameter 'lock'
Warning(plist.h:158): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'n'
Warning(plist.h:179): No description found for parameter 'mem'
This still leaves one warning & one error that need attention:
Error(plist.h:219): cannot understand prototype: '('
Warning(plist.h): no structured comments found
Acked-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Daniel Walker <dwalker@mvista.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Trivial change to pass vmsplice arguments through the compat layer on
pp64.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
Acked-by: Paul Mackerras <paulus@samba.org>
Otherwise the following calltrace will lead to a wrong
lockdep warning:
neigh_proxy_process()
`- lock(neigh_table->proxy_queue.lock);
arp_redo /* via tbl->proxy_redo */
arp_process
neigh_event_ns
neigh_update
skb_queue_purge
`- lock(neighbor->arp_queue.lock);
This is not a deadlock actually, as neighbor table's proxy_queue
and the neighbor's arp_queue are different queues.
Lockdep thinks there is a deadlock as both queues are initialized
with skb_queue_head_init() and thus have a common class.
Since this was added originally for Xen, and Xen has recently (~2.6.18)
stopped using this function, we can safely get rid of it. Good timing
too since this function has started to bit rot.
If the writebacks are cancelled via nfs_cancel_dirty_list, or due to the
memory allocation failing in nfs_flush_one/nfs_flush_multi, then we must
ensure that the PG_writeback flag is cleared.
Also ensure that we actually own the PG_writeback flag whenever we
schedule a new writeback by making nfs_set_page_writeback() return the
value of test_set_page_writeback().
The PG_writeback page flag ends up replacing the functionality of the
PG_FLUSHING nfs_page flag, so we rip that out too.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6:
ide: add "optical" to sysfs "media" attribute
ide: ugly messages trying to open CD drive with no media present
ide: correctly prevent IDE timer expiry function to run if request was already handled
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] SGI Altix : fix pcibr_dmamap_ate32() bug
[IA64] Fix CPU freq displayed in /proc/cpuinfo
[IA64] Fix wrong assumption about irq and vector in msi_ia64.c
[IA64] BTE error timer fix
already handled
It is possible for the timer expiry function to run even though the
request has already been handled: ide_timer_expiry() only checks that
the handler is not NULL, but it is possible that we have handled a
request (thus clearing the handler) and then started a new request
(thus starting the timer again, and setting a handler).
A simple way to exhibit this is to set the DMA timeout to 1 jiffy and
run dd: The kernel will panic after a few minutes because
ide_timer_expiry() tries to add a timer when it's already active.
To fix this, we simply add a request generation count that gets
incremented at every interrupt, and check in ide_timer_expiry() that
we have not already handled a new interrupt before running the expiry
function.
Signed-off-by: Suleiman Souhlal <suleiman@google.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Since lazy MMU batching mode still allows interrupts to enter, it is
possible for interrupt handlers to try to use kmap_atomic, which fails when
lazy mode is active, since the PTE update to highmem will be delayed. The
best workaround is to issue an explicit flush in kmap_atomic_functions
case; this is the only way nested PTE updates can happen in the interrupt
handler.
Thanks to Jeremy Fitzhardinge for noting the bug and suggestions on a fix.
This patch gets reverted again when we start 2.6.22 and the bug gets fixed
differently.
Signed-off-by: Zachary Amsden <zach@vmware.com>
Cc: Andi Kleen <ak@muc.de>
Soeren Sonnenburg reported that upon resume he is getting
this backtrace:
[<c0119637>] smp_apic_timer_interrupt+0x57/0x90
[<c0142d30>] retrigger_next_event+0x0/0xb0
[<c0104d30>] apic_timer_interrupt+0x28/0x30
[<c0140068>] __kfifo_put+0x8/0x90
[<c0130fe5>] on_each_cpu+0x35/0x60
[<c0143538>] clock_was_set+0x18/0x20
[<c0135cdc>] timekeeping_resume+0x7c/0xa0
[<c02aabe1>] __sysdev_resume+0x11/0x80
[<c02ab0c7>] sysdev_resume+0x47/0x80
[<c02b0b05>] device_power_up+0x5/0x10
it turns out that on resume we mistakenly re-enable interrupts too
early. Do the timer retrigger only on the current CPU.
Acked-by: Soeren Sonnenburg <kernel@nn7.de>
On a SGI Altix TIOCP based PCI bus we need to include the ATE_PIO attribute
bit if we're mapping a 32bit MSI address.
Signed-off-by: Mike Habeck <habeck@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Just a one-byter for an ia64 thinko/typo - already fixed for i386 and x86_64.
Acked-by: Tony Luck <tony.luck@intel.com>
Revert all this. It can cause device-mapper to receive a different major from
earlier kernels and it turns out that the Amanda backup program (via GNU tar,
apparently) checks major numbers on files when performing incremental backups.
Which is a bit broken of Amanda (or tar), but this feature isn't important
enough to justify the churn.
A device can be removed from an md array via e.g.
echo remove > /sys/block/md3/md/dev-sde/state
This will try to remove the 'dev-sde' subtree which will deadlock
since
commit e7b0d26a86943370c04d6833c6edba2a72a6e240
With this patch we run the kobject_del via schedule_work so as to
avoid the deadlock.
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Neil Brown <neilb@suse.de>
patch 4/4:
Limit ATAPI DMA to R/W commands only for TORiSAN DRD-N216 DVD-ROM drives
(http://bugzilla.kernel.org/show_bug.cgi?id=6710)
Signed-off-by: Albert Lee <albertcc@tw.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
patch 3/4:
The TORiSAN drive locks up when max sector == 256.
Limit max sector to 128 for the TORiSAN DRD-N216 drives.
patch 1/4:
Reorder HSM_ST_FIRST, such that the task state transition is easier decoded with human eyes.
Add unsigned to unused bit field in a.out.h to make sparse happy.
[ I took care of the sparc64 side as well -DaveM ]
Signed-off-by: Robert Reif <reif@earthlink.net>
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6:
[PATCH] x86: Don't probe for DDC on VBE1.2
[PATCH] x86-64: Increase NMI watchdog probing timeout
[PATCH] x86-64: Let oprofile reserve MSR on all CPUs
[PATCH] x86-64: Disable local APIC timer use on AMD systems with C1E
Fix the regression resulting from the recent change of suspend code
ordering that causes systems based on Intel x86 CPUs using the microcode
driver to hang during the resume.
The problem occurs since the microcode driver uses request_firmware() in
its CPU hotplug notifier, which is called after tasks has been frozen and
hangs. It can be fixed by telling the microcode driver to use the
microcode stored in memory during the resume instead of trying to load it
from disk.
Adrian Bunk <bunk@stusta.de>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Maxim <maximlevitsky@gmail.com>
built-in drivers had broken sysfs links that caused bootup hangs for
certain driver unregistry sequences.
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Greg KH <greg@kroah.com>
Currently we have a confused udelay implementation.
* __const_udelay does not accept usecs but xloops in i386 and x86_64
* our implementation requires usecs as arg
* it gets a xloops count when called by asm/arch/delay.h
Bugs related to this (extremely long shutdown times) where reported by some
x86_64 users, especially using Device Mapper.
To hit this bug, a compile-time constant time parameter must be passed -
that's why UML seems to work most times. Fix this with a simple udelay
implementation.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Acked-by: Jeff Dike <jdike@addtoit.com>
AMD dual core laptops with C1E do not run the APIC timer correctly
when they go idle. Previously the code assumed this only happened
on C2 or deeper. But not all of these systems report support C2.
Use a AMD supplied snippet to detect C1E being enabled and then disable
local apic timer use.
This supercedes an earlier workaround using DMI detection of specific systems.
Thanks to Mark Langsdorf for the detection snippet.
Signed-off-by: Andi Kleen <ak@suse.de>
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 4298/1: fix memory barriers for DMA coherent and SMP platforms
[ARM] 4295/2: Fix error-handling in pxaficp_ir.c (version 2)
[ARM] Fix __NR_kexec_load
[ARM] Export dma_channel_active()
[ARM] 4296/1: ixp4xx: compile fix
[ARM] 4289/1: AT91: SAM9260 NAND flash timing
This patch:
- Switches mb/rmb/wmb back to being full-blown DMBs on ARM SMP systems,
since mb/rmb/wmb are required to order Normal memory accesses as well.
- Enables the use of DMB and ISB on XSC3 (which is an ARMv5TE ISA core
but conforms to the ARMv6 memory ordering model and supports the
various ARMv6 barriers.)
- Makes DMA coherent platforms (only ixp23xx at the moment) map
mb/rmb/wmb to dmb(), as on DMA coherent platforms, DMA consistent
mappings are done as Normal mappings, which are weakly ordered.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
It's __NR_kexec_load, not __NR_sys_kexec_load
There was a typo in commit 7632fc8f809a97f9d82ce125e8e3e579390ce2e5,
preventing it from working - 32bit binaries crashed hopelessly before
the below fix and work perfectly now.
Fix compilation fail for ixp4xx platforms for the case when CONFIG_IXP4XX_INDIRECT_PCI is set. That is due to the check_signature() is appeared in include/linux/io.h.
Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com>
local_irq_restore -> raw_local_irq_restore -> irq_restore_epilog ->
smtc_ipi_replay -> smtc_ipi_dq -> spin_unlock_irqrestore ->
_spin_unlock_irqrestore -> local_irq_restore
The recursion does abort when there is no more IPI queued for a CPU, so
this isn't usually fatal which is why we got away with this for so long
until this was discovered by code inspection.
[IFB]: Fix crash on input device removal
[BNX2]: Fix link interrupt problem.
The definition of struct ucc_slow puts the guemr register immediately after the
utpt register, when it should be at offset 0x90. This patch adds the missing
0x52-byte padding.
The input_device pointer is not refcounted, which means the device may
disappear while packets are queued, causing a crash when ifb passes packets
with a stale skb->dev pointer to netif_rx().
Fix by storing the interface index instead and do a lookup where neccessary.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
_PAGE_PROTNONE conflicts with the lowest bit of pgoff. This causes all sorts
of weirdness when nonlinear mappings are used.
Took me a good half day to track this down.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
Acked-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Signed-off-by: Yinghai Lu <yinghai.lu@amd.com>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6:
[VIDEO]: Fix section mismatch in cg3.c
[SPARC]: sparc64 gcc-4.2.0 20070317 -Werror failure
[VIDEO] ffb: Fix two DAC handling bugs.
[SPARC32]: Fix SMP build regression
[DRM]: Delete sparc64 FFB driver code that never gets built.
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: Trivial fix for hp6xx build.
sh: Fixup __cmpxchg() compile breakage with gcc4.
sh: Kill bogus GCC4 symbol exports.
The IRQ3 define was removed when asm-sh/irq.h was cleaned up,
this updates the hp6xx header to use the IRQ number directly.
Signed-off-by: Kristoffer Ericson <kristoffer_e1@hotmail.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
As reported by Manuel:
When I build linux with GCC-4.x and enable
CONFIG_CC_OPTIMIZE_FOR_SIZE linking fails with this error:
LD .tmp_vmlinux1
kernel/built-in.o: In function '__cmpxchg_called_with_bad_pointer'
make[1]: *** [.tmp_vmlinux1] Error 1
make: *** [_all] Error 2
This ended up being an inlining problem, fixed by explicitly
including linux/compiler.h and grabbing the definitions from there.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream-fixes
Johannes Berg discovered that kernel space was leaking to
userspace on 64 bit platform. He made a first patch to fix that. This
is an improved version of his patch.
Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb:
V4L/DVB (5472): Isl6421: don't reference freed memory
V4L/DVB (5441): Saa7146: Fix allocation of clipping memory
V4L/DVB (5421): Fix suspend/resume in msp3400 and tuner
V4L/DVB (5415): Msp_attach must return 0 if no msp3400 was found.
V4L/DVB (5408): Fix SECAM handling on saa7115
V4L/DVB (5400): Core: fix several locking related problems
V4L/DVB (5390): Radio: Fix error in Kbuild file
V4L/DVB (5332): Ir_rc5_timer_end decoder lockup fix
