path: root/include
2008-07-20[MIPS] don't leak setup_early_printk() in userspace headerAdrian Bunk
Our userspace headers shouldn't contain prototypes of in-kernel functions. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-20[MIPS] Remove include/asm-mips/mips-boards/sead{,int}.hAdrian Bunk
include/asm-mips/mips-boards/sead{,int}.h are now obsolete. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-20[MIPS] Remove asm-mips/mips-boards/atlas{,int}.hAdrian Bunk
asm-mips/mips-boards/atlas{,int}.h are now obsolete. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-20[MIPS] Routerboard 532: Support for base systemRalf Baechle
Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-20[MIPS] Tinker with constraints in <asm/atomic.h> to fix build error.Ralf Baechle
[...] CC init/main.o include/asm/bitops.h: In function `start_kernel': include/asm/bitops.h:76: warning: asm operand 2 probably doesn't match constraints include/asm/bitops.h:76: warning: asm operand 2 probably doesn't match constraints include/asm/bitops.h:76: warning: asm operand 2 probably doesn't match constraints include/asm/bitops.h:76: error: impossible constraint in `asm' include/asm/bitops.h:76: error: impossible constraint in `asm' include/asm/bitops.h:76: error: impossible constraint in `asm' make[1]: *** [init/main.o] Error 1 [...] The build error is caused by the ages old gcc bug where gcc at the time of analyzing the constraints is unable to figure out that an "i" constraint actually can be satisfied and thus will abort unless an "r" is added to the constraint. For the actual code generation gcc will only ever use the "i" constraint. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-20[MIPS] Add missing prototypes to asm/page.hDmitri Vorobiev
This patch fixes the following sparse warnings: >>>>>>>>>>>>>>>>>> arch/mips/mm/page.c:284:16: warning: symbol 'build_clear_page' was not declared. Should it be static? arch/mips/mm/page.c:426:16: warning: symbol 'build_copy_page' was not declared. Should it be static? >>>>>>>>>>>>>>>>>> The fix is to add appropriate prototypes to the header include/asm-mips/page.h. Build-tested against Malta defconfig. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-20[MIPS] Fix missing prototypes in asm/fpu.hDmitri Vorobiev
While building the Malta defconfig, sparse spat the following warnings: >>>>>>>>>>>>>>>>>> arch/mips/math-emu/kernel_linkage.c:31:6: warning: symbol 'fpu_emulator_init_fpu' was not declared. Should it be static? arch/mips/math-emu/kernel_linkage.c:54:5: warning: symbol 'fpu_emulator_save_context' was not declared. Should it be static? arch/mips/math-emu/kernel_linkage.c:68:5: warning: symbol 'fpu_emulator_restore_context' was not declared. Should it be static? >>>>>>>>>>>>>>>>>> This patch fixes these errors by adding the proper prototypes to the include/asm-mips/fpu.h header, and actually using this header in the sparse-spotted source file. Build-tested with Malta defconfig. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-20[MIPS] PCI: Make the pcibios_max_latency variable staticDmitri Vorobiev
The pcibios_max_latency variable is needlessly defined global, and this patch makes it static. Build-tested using malta_defconfig. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-17Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: [PATCH] ocfs2: fix oops in mmap_truncate testing configfs: call drop_link() to cleanup after create_link() failure configfs: Allow ->make_item() and ->make_group() to return detailed errors. configfs: Fix failing mkdir() making racing rmdir() fail configfs: Fix deadlock with racing rmdir() and rename() configfs: Make configfs_new_dirent() return error code instead of NULL configfs: Protect configfs_dirent s_links list mutations configfs: Introduce configfs_dirent_lock ocfs2: Don't snprintf() without a format. ocfs2: Fix CONFIG_OCFS2_DEBUG_FS #ifdefs ocfs2/net: Silence build warnings on sparc64 ocfs2: Handle error during journal load ocfs2: Silence an error message in ocfs2_file_aio_read() ocfs2: use simple_read_from_buffer() ocfs2: fix printk format warnings with OCFS2_FS_STATS=n [PATCH 2/2] ocfs2: Instrument fs cluster locks [PATCH 1/2] ocfs2: Add CONFIG_OCFS2_FS_STATS config option
2008-07-17Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: fix asm/e820.h for userspace inclusion x86: fix numaq_tsc_disable x86: fix kernel_physical_mapping_init() for large x86 systems
2008-07-17x86: fix asm/e820.h for userspace inclusionRusty Russell
asm-x86/e820.h is included from userspace. 'x86: make e820.c to have common functions' (b79cd8f1268bab57ff85b19d131f7f23deab2dee) broke it: make -C Documentation/lguest cc -Wall -Wmissing-declarations -Wmissing-prototypes -O3 -I../../include lguest.c -lz -o lguest In file included from ../../include/asm-x86/bootparam.h:8, from lguest.c:45: ../../include/asm/e820.h:66: error: expected ‘)’ before ‘start’ ../../include/asm/e820.h:67: error: expected ‘)’ before ‘start’ ../../include/asm/e820.h:68: error: expected ‘)’ before ‘start’ ../../include/asm/e820.h:72: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘e820_update_range’ ... Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-17Merge branch 'ptrace-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-utrace * 'ptrace-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-utrace: fix dangling zombie when new parent ignores children do_wait: return security_task_wait() error code in place of -ECHILD ptrace children revamp do_wait reorganization
2008-07-17[S390] qdio: new qdio driver.Jan Glauber
List of major changes: - split qdio driver into several files - seperation of thin interrupt code - improved handling for multiple thin interrupt devices - inbound and outbound processing now always runs in tasklet context - significant less tasklet schedules per interrupt needed - merged qebsm with non-qebsm handling - cleanup qdio interface and added kerneldoc - coding style Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Reviewed-by: Utz Bacher <utz.bacher@de.ibm.com> Reviewed-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-17[S390] chsc headers userspace cleanupAdrian Bunk
Kernel headers shouldn't expose functions to userspace. Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-16ptrace children revampRoland McGrath
ptrace no longer fiddles with the children/sibling links, and the old ptrace_children list is gone. Now ptrace, whether of one's own children or another's via PTRACE_ATTACH, just uses the new ptraced list instead. There should be no user-visible difference that matters. The only change is the order in which do_wait() sees multiple stopped children and stopped ptrace attachees. Since wait_task_stopped() was changed earlier so it no longer reorders the children list, we already know this won't cause any new problems. Signed-off-by: Roland McGrath <roland@redhat.com>
2008-07-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (72 commits) Revert "x86/PCI: ACPI based PCI gap calculation" PCI: remove unnecessary volatile in PCIe hotplug struct controller x86/PCI: ACPI based PCI gap calculation PCI: include linux/pm_wakeup.h for device_set_wakeup_capable PCI PM: Fix pci_prepare_to_sleep x86/PCI: Fix PCI config space for domains > 0 Fix acpi_pm_device_sleep_wake() by providing a stub for CONFIG_PM_SLEEP=n PCI: Simplify PCI device PM code PCI PM: Introduce pci_prepare_to_sleep and pci_back_from_sleep PCI ACPI: Rework PCI handling of wake-up ACPI: Introduce new device wakeup flag 'prepared' ACPI: Introduce acpi_device_sleep_wake function PCI: rework pci_set_power_state function to call platform first PCI: Introduce platform_pci_power_manageable function ACPI: Introduce acpi_bus_power_manageable function PCI: make pci_name use dev_name PCI: handle pci_name() being const PCI: add stub for pci_set_consistent_dma_mask() PCI: remove unused arch pcibios_update_resource() functions PCI: fix pci_setup_device()'s sprinting into a const buffer ... Fixed up conflicts in various files (arch/x86/kernel/setup_64.c, arch/x86/pci/irq.c, arch/x86/pci/pci.h, drivers/acpi/sleep/main.c, drivers/pci/pci.c, drivers/pci/pci.h, include/acpi/acpi_bus.h) from x86 and ACPI updates manually.
2008-07-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (68 commits) sdio_uart: Fix SDIO break control to now return success or an error mmc: host driver for Ricoh Bay1Controllers sdio: sdio_io.c Fix sparse warnings sdio: fix the use of hard coded timeout value. mmc: OLPC: update vdd/powerup quirk comment mmc: fix spares errors of sdhci.c mmc: remove multiwrite capability wbsd: fix bad dma_addr_t conversion atmel-mci: Driver for Atmel on-chip MMC controllers mmc: fix sdio_io sparse errors mmc: wbsd.c fix shadowing of 'dma' variable MMC: S3C24XX: Refuse incorrectly aligned transfers MMC: S3C24XX: Add maintainer entry MMC: S3C24XX: Update error debugging. MMC: S3C24XX: Add media presence test to request handling. MMC: S3C24XX: Fix use of msecs where jiffies are needed MMC: S3C24XX: Add MODULE_ALIAS() entries for the platform devices MMC: S3C24XX: Fix s3c2410_dma_request() return code check. MMC: S3C24XX: Allow card-detect on non-IRQ capable pin MMC: S3C24XX: Ensure host->mrq->data is valid ... Manually fixed up bogus executable bits on drivers/mmc/core/sdio_io.c and include/linux/mmc/sdio_func.h when merging.
2008-07-16Merge branch 'for_linus' of git://git.infradead.org/~dedekind/ubifs-2.6Linus Torvalds
* 'for_linus' of git://git.infradead.org/~dedekind/ubifs-2.6: UBIFS: include to compilation UBIFS: add new flash file system UBIFS: add brief documentation MAINTAINERS: add UBIFS section do_mounts: allow UBI root device name VFS: export sync_sb_inodes VFS: move inode_lock into sync_sb_inodes
2008-07-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (76 commits) IDE: Report errors during drive reset back to user space Update documentation of HDIO_DRIVE_RESET ioctl IDE: Remove unused code IDE: Fix HDIO_DRIVE_RESET handling hd.c: remove the #include <linux/mc146818rtc.h> update the BLK_DEV_HD help text move ide/legacy/hd.c to drivers/block/ ide/legacy/hd.c: use late_initcall() remove BLK_DEV_HD_ONLY ide: endian annotations in ide-floppy.c ide-floppy: zero out the whole struct ide_atapi_pc on init ide-floppy: fold idefloppy_create_test_unit_ready_cmd into idefloppy_open ide-cd: move request prep chunk from cdrom_do_newpc_cont to rq issue path ide-cd: move request prep from cdrom_start_rw_cont to rq issue path ide-cd: move request prep from cdrom_start_seek_continuation to rq issue path ide-cd: fold cdrom_start_seek into ide_cd_do_request ide-cd: simplify request issuing path ide-cd: mv ide_do_rw_cdrom ide_cd_do_request ide-cd: cdrom_start_seek: remove unused argument block ide-cd: ide_do_rw_cdrom: add the catch-all bad request case to the if-else block ...
2008-07-16Merge branch 'release-2.6.27' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-merge-2.6 * 'release-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-merge-2.6: (87 commits) Fix FADT parsing Add the ability to reset the machine using the RESET_REG in ACPI's FADT table. ACPI: use dev_printk when possible PNPACPI: add support for HP vendor-specific CCSR descriptors PNP: avoid legacy IDE IRQs PNP: convert resource options to single linked list ISAPNP: handle independent options following dependent ones PNP: remove extra 0x100 bit from option priority PNP: support optional IRQ resources PNP: rename pnp_register_*_resource() local variables PNPACPI: ignore _PRS interrupt numbers larger than PNP_IRQ_NR PNP: centralize resource option allocations PNP: remove redundant pnp_can_configure() check PNP: make resource assignment functions return 0 (success) or -EBUSY (failure) PNP: in debug resource dump, make empty list obvious PNP: improve resource assignment debug PNP: increase I/O port & memory option address sizes PNP: introduce pnp_irq_mask_t typedef PNP: make resource option structures private to PNP subsystem PNP: define PNP-specific IORESOURCE_IO_* flags alongside IRQ, DMA, MEM ...
2008-07-16block: Trivial fix for blk_integrity_rq()Martin K. Petersen
Fail integrity check gracefully when request does not have a bio attached (BLOCK_PC). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16Merge git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (82 commits) NFSv4: Remove BKL from the nfsv4 state recovery SUNRPC: Remove the BKL from the callback functions NFS: Remove BKL from the readdir code NFS: Remove BKL from the symlink code NFS: Remove BKL from the sillydelete operations NFS: Remove the BKL from the rename, rmdir and unlink operations NFS: Remove BKL from NFS lookup code NFS: Remove the BKL from nfs_link() NFS: Remove the BKL from the inode creation operations NFS: Remove BKL usage from open() NFS: Remove BKL usage from the write path NFS: Remove the BKL from the permission checking code NFS: Remove attribute update related BKL references NFS: Remove BKL requirement from attribute updates NFS: Protect inode->i_nlink updates using inode->i_lock nfs: set correct fl_len in nlmclnt_test() SUNRPC: Support registering IPv6 interfaces with local rpcbind daemon SUNRPC: Refactor rpcb_register to make rpcbindv4 support easier SUNRPC: None of rpcb_create's callers wants a privileged source port SUNRPC: Introduce a specific rpcb_create for contacting localhost ...
2008-07-16Add the ability to reset the machine using the RESET_REG in ACPI's FADT table.Aaron Durbin
Signed-off-by: Aaron Durbin <adurbin@google.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-07-16PNP: convert resource options to single linked listBjorn Helgaas
ISAPNP, PNPBIOS, and ACPI describe the "possible resource settings" of a device, i.e., the possibilities an OS bus driver has when it assigns I/O port, MMIO, and other resources to the device. PNP used to maintain this "possible resource setting" information in one independent option structure and a list of dependent option structures for each device. Each of these option structures had lists of I/O, memory, IRQ, and DMA resources, for example: dev independent options ind-io0 -> ind-io1 ... ind-mem0 -> ind-mem1 ... ... dependent option set 0 dep0-io0 -> dep0-io1 ... dep0-mem0 -> dep0-mem1 ... ... dependent option set 1 dep1-io0 -> dep1-io1 ... dep1-mem0 -> dep1-mem1 ... ... ... This data structure was designed for ISAPNP, where the OS configures device resource settings by writing directly to configuration registers. The OS can write the registers in arbitrary order much like it writes PCI BARs. However, for PNPBIOS and ACPI devices, the OS uses firmware interfaces that perform device configuration, and it is important to pass the desired settings to those interfaces in the correct order. The OS learns the correct order by using firmware interfaces that return the "current resource settings" and "possible resource settings," but the option structures above doesn't store the ordering information. This patch replaces the independent and dependent lists with a single list of options. For example, a device might have possible resource settings like this: dev options ind-io0 -> dep0-io0 -> dep1->io0 -> ind-io1 ... All the possible settings are in the same list, in the order they come from the firmware "possible resource settings" list. Each entry is tagged with an independent/dependent flag. Dependent entries also have a "set number" and an optional priority value. All dependent entries must be assigned from the same set. For example, the OS can use all the entries from dependent set 0, or all the entries from dependent set 1, but it cannot mix entries from set 0 with entries from set 1. Prior to this patch PNP didn't keep track of the order of this list, and it assigned all independent options first, then all dependent ones. Using the example above, that resulted in a "desired configuration" list like this: ind->io0 -> ind->io1 -> depN-io0 ... instead of the list the firmware expects, which looks like this: ind->io0 -> depN-io0 -> ind-io1 ... Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: support optional IRQ resourcesBjorn Helgaas
This patch adds an IORESOURCE_IRQ_OPTIONAL flag for use when assigning resources to a device. If the flag is set and we are unable to assign an IRQ to the device, we can leave the IRQ disabled but allow the overall resource allocation to succeed. Some devices request an IRQ, but can run without an IRQ (possibly with degraded performance). This flag lets us run the device without the IRQ instead of just leaving the device disabled. This is a reimplementation of this previous change by Rene Herman <rene.herman@gmail.com>: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=3b73a223661ed137c5d3d2635f954382e94f5a43 I reimplemented this for two reasons: - to prepare for converting all resource options into a single linked list, as opposed to the per-resource-type lists we have now, and - to preserve the order and number of resource options. In PNPBIOS and ACPI, we configure a device by giving firmware a list of resource assignments. It is important that this list has exactly the same number of resources, in the same order, as the "template" list we got from the firmware in the first place. The problem of a sound card MPU401 being left disabled for want of an IRQ was reported by Uwe Bugla <uwe.bugla@gmx.de>. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: make resource option structures private to PNP subsystemBjorn Helgaas
Nothing outside the PNP subsystem should need access to a device's resource options, so this patch moves the option structure declarations to a private header file. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: define PNP-specific IORESOURCE_IO_* flags alongside IRQ, DMA, MEMBjorn Helgaas
PNP previously defined PNP_PORT_FLAG_16BITADDR and PNP_PORT_FLAG_FIXED in a private header file, but put those flags in struct resource.flags fields. Better to make them IORESOURCE_IO_* flags like the existing IRQ, DMA, and MEM flags. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: add pnp_possible_config() -- can a device could be configured this way?Bjorn Helgaas
As part of a heuristic to identify modem devices, 8250_pnp.c checks to see whether a device can be configured at any of the legacy COM port addresses. This patch moves the code that traverses the PNP "possible resource options" from 8250_pnp.c to the PNP subsystem. This encapsulation is important because a future patch will change the implementation of those resource options. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: replace pnp_resource_table with dynamically allocated resourcesBjorn Helgaas
PNP used to have a fixed-size pnp_resource_table for tracking the resources used by a device. This table often overflowed, so we've had to increase the table size, which wastes memory because most devices have very few resources. This patch replaces the table with a linked list of resources where the entries are allocated on demand. This removes messages like these: pnpacpi: exceeded the max number of IO resources 00:01: too many I/O port resources References: http://bugzilla.kernel.org/show_bug.cgi?id=9535 http://bugzilla.kernel.org/show_bug.cgi?id=9740 http://lkml.org/lkml/2007/11/30/110 This patch also changes the way PNP uses the IORESOURCE_UNSET, IORESOURCE_AUTO, and IORESOURCE_DISABLED flags. Prior to this patch, the pnp_resource_table entries used the flags like this: IORESOURCE_UNSET This table entry is unused and available for use. When this flag is set, we shouldn't look at anything else in the resource structure. This flag is set when a resource table entry is initialized. IORESOURCE_AUTO This resource was assigned automatically by pnp_assign_{io,mem,etc}(). This flag is set when a resource table entry is initialized and cleared whenever we discover a resource setting by reading an ISAPNP config register, parsing a PNPBIOS resource data stream, parsing an ACPI _CRS list, or interpreting a sysfs "set" command. Resources marked IORESOURCE_AUTO are reinitialized and marked as IORESOURCE_UNSET by pnp_clean_resource_table() in these cases: - before we attempt to assign resources automatically, - if we fail to assign resources automatically, - after disabling a device IORESOURCE_DISABLED Set by pnp_assign_{io,mem,etc}() when automatic assignment fails. Also set by PNPBIOS and PNPACPI for: - invalid IRQs or GSI registration failures - invalid DMA channels - I/O ports above 0x10000 - mem ranges with negative length After this patch, there is no pnp_resource_table, and the resource list entries use the flags like this: IORESOURCE_UNSET This flag is no longer used in PNP. Instead of keeping IORESOURCE_UNSET entries in the resource list, we remove entries from the list and free them. IORESOURCE_AUTO No change in meaning: it still means the resource was assigned automatically by pnp_assign_{port,mem,etc}(), but these functions now set the bit explicitly. We still "clean" a device's resource list in the same places, but rather than reinitializing IORESOURCE_AUTO entries, we just remove them from the list. Note that IORESOURCE_AUTO entries are always at the end of the list, so removing them doesn't reorder other list entries. This is because non-IORESOURCE_AUTO entries are added by the ISAPNP, PNPBIOS, or PNPACPI "get resources" methods and by the sysfs "set" command. In each of these cases, we completely free the resource list first. IORESOURCE_DISABLED In addition to the cases where we used to set this flag, ISAPNP now adds an IORESOURCE_DISABLED resource when it reads a configuration register with a "disabled" value. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: make pnp_{port,mem,etc}_start(), et al work for invalid resourcesBjorn Helgaas
Some callers use pnp_port_start() and similar functions without making sure the resource is valid. This patch makes us fall back to returning the initial values if the resource is not valid or not even present. This mostly preserves the previous behavior, where we would just return the initial values set by pnp_init_resource_table(). The original 2.6.25 code didn't range-check the "bar", so it would return garbage if the bar exceeded the table size. This code returns sensible values instead. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPI : Create "idle=nomwait" bootparamZhao Yakui
"idle=nomwait" disables the use of the MWAIT instruction from both C1 (C1_FFH) and deeper (C2C3_FFH) C-states. When MWAIT is unavailable, the BIOS and OS generally negotiate to use the HALT instruction for C1, and use IO accesses for deeper C-states. This option is useful for power and performance comparisons, and also to work around BIOS bugs where broken MWAIT support is advertised. http://bugzilla.kernel.org/show_bug.cgi?id=10807 http://bugzilla.kernel.org/show_bug.cgi?id=10914 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Li Shaohua <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPI: Create "idle=halt" bootparamZhao Yakui
"idle=halt" limits the idle loop to using the halt instruction. No MWAIT, no IO accesses, no C-states deeper than C1. If something is broken in the idle code, "idle=halt" is a less severe workaround than "idle=poll" which disables all power savings. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPI: Enhance /sys/firmware/interrupts to allow enable/disable/clear from ↵Zhang Rui
user-space Allow users to enable/disable/clear a specific & valid GPE/Fixed Event in user space. This is useful for debugging, especially for some interrupt storm issues. All wakeup GPEs are disabled and they can not be enabled at runtime, and we mark them as invalid. All GPEs that don't have a _Lxx/_Exx method are marked as invalid. All Fixed Events that don't have an event handler are marked as invalid and they can't be enabled until an event handler is registered. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Ling Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Update version to 20080609Bob Moore
Update version to 20080609. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Cleanup debug operand dump mechanismBob Moore
Eliminated unnecessary operands; eliminated use of negative index in loop. Operands now displayed in correct order, not backwards. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Update disassembler for DMAR table changesBob Moore
Now supports the 2007 intel Virtualization Technology for Directed I/O specification. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Update DMAR and SRAT table definitionsBob Moore
Synchronized tables with current specifications. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Update version to 20080514Bob Moore
Update version to 20080514 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Add const qualifier for appropriate string constantsBob Moore
Mostly MODULE_NAME and printf format strings. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Eliminate acpi_native_uint type v2Bob Moore
No longer needed; replaced mostly with u32, but also acpi_size where a type that changes 32/64 bit on 32/64-bit platforms is required. v2: Fix a cast of a 32-bit int to a pointer in ACPI to avoid a compiler warning. from David Howells Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Fix possible negative array index in acpi_ut_validate_exceptionBob Moore
Added NULL fields to the exception string arrays to eliminate the -1 subtraction on the SubStatus field. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Update tracking macros to reduce code/data sizeJan Beulich
Changed ACPI_MODULE_NAME and ACPI_FUNCTION_NAME to use arrays of strings instead of pointers to static strings. Jan Beulich and Bob Moore. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Fix for hang on GPE method invocationBob Moore
Fixes problem where the new method argument count validation mechanism will enter an infinite loop when a GPE method is dispatched. Problem fixed be removing the obsolete code that passes GPE block information to the notify handler via the control method parameter pointer. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Add argument count checking to control method invocation via ↵Bob Moore
acpi_evaluate_object Error if too few arguments, warning if too many. This applies only to external programmatic control method execution, not method-to-method calls within the AML. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16Freezer: Introduce PF_FREEZER_NOSIGRafael J. Wysocki
The freezer currently attempts to distinguish kernel threads from user space tasks by checking if their mm pointer is unset and it does not send fake signals to kernel threads. However, there are kernel threads, mostly related to networking, that behave like user space tasks and may want to be sent a fake signal to be frozen. Introduce the new process flag PF_FREEZER_NOSIG that will be set by default for all kernel threads and make the freezer only send fake signals to the tasks having PF_FREEZER_NOSIG unset. Provide the set_freezable_with_signal() function to be called by the kernel threads that want to be sent a fake signal for freezing. This patch should not change the freezer's observable behavior. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16ACPI PM: acpi_pm_device_sleep_state() cleanupDavid Brownell
Get rid of a superfluous acpi_pm_device_sleep_state() parameter. The only legitimate value of that parameter must be derived from the first parameter, which is what all the callers already do. (However, this does not address the fact that ACPI still doesn't set up those flags.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16ACPICA: fix mutex names in debug code.Vegard Nossum
Reorder the mutex names to match the preceding #defines Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16Make GPE disable more robustBob Moore
Implemented another change for the GPE disable. We now perform a read-change-write of the enable register instead of simply writing out the cached enable mask. This will prevent inadvertent enabling of GPEs if a rogue GPE is received during initialization (before GPE handlers are installed.) http://bugzilla.kernel.org/show_bug.cgi?id=6217 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPI: change processors from array to per_cpu variableMike Travis
Change processors from an array sized by NR_CPUS to a per_cpu variable. Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16IDE: Remove unused codeElias Oltmanns
Remove some code which has been made obsolete and hasn't worked properly before anyway. Part of the infrastructure may be reintroduced in a follow up patch to implement a working command aborting facility. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Cc: "Alan Cox" <alan@lxorguk.ukuu.org.uk> Cc: "Randy Dunlap" <randy.dunlap@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
