git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"You will get the following new drivers:
- Qualcomm PM8941 power key drver
- ChipOne icn8318 touchscreen controller driver
- Broadcom iProc touchscreen and keypad drivers
- Semtech SX8654 I2C touchscreen controller driver
ALPS driver now supports newer SS4 devices; Elantech got a fix that
should make it work on some ASUS laptops; and a slew of other
enhancements and random fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (51 commits)
Input: alps - non interleaved V2 dualpoint has separate stick button bits
Input: alps - fix touchpad buttons getting stuck when used with trackpoint
Input: atkbd - document "no new force-release quirks" policy
Input: ALPS - make alps_get_pkt_id_ss4_v2() and others static
Input: ALPS - V7 devices can report 5-finger taps
Input: ALPS - add support for SS4 touchpad devices
Input: ALPS - refactor alps_set_abs_params_mt()
Input: elantech - fix absolute mode setting on some ASUS laptops
Input: atmel_mxt_ts - split out touchpad initialisation logic
Input: atmel_mxt_ts - implement support for T100 touch object
Input: cros_ec_keyb - fix clearing keyboard state on wakeup
Input: gscps2 - drop pci_ids dependency
Input: synaptics - allocate 3 slots to keep stability in image sensors
Input: Revert "Revert "synaptics - use dmax in input_mt_assign_slots""
Input: MT - make slot assignment work for overcovered solutions
mfd: tc3589x: enforce device-tree only mode
Input: tc3589x - localize platform data
Input: tsc2007 - Convert msecs to jiffies only once
Input: edt-ft5x06 - remove EV_SYN event report
Input: edt-ft5x06 - allow to setting the maximum axes value through the DT
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Most notable:
- introducing the i2c_quirk infrastructure. Now, flaws of I2C
controllers can be described and the core will check if the flaws
collide with the messages to be sent
- wait_for_completion return type cleanup series
- new drivers for Digicolor, Netlogic XLP, Ingenic JZ4780
- updates to the I2C slave framework which include API changes. Its
only user was updated, too. Documentation was finally added
- changed dynamic bus numbering for the DT case. This could change
bus numbers for users. However, it fixes a collision where dynamic
and static busses request the same id.
- driver bugfixes, cleanups"
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (52 commits)
i2c: xlp9xx: Driver for Netlogic XLP9XX/5XX I2C controller
of: Add vendor prefix 'netlogic'
i2c: davinci: use ICPFUNC to toggle I2C as gpio for bus recovery
i2c: davinci: use bus recovery infrastructure
i2c: change input parameter to i2c_adapter for prepare/unprepare_recovery
i2c: i2c-mux-gpio: remove error messages for probe deferrals
i2c: jz4780: Add i2c bus controller driver for Ingenic JZ4780
i2c: dln2: set the device tree node of the adapter
i2c: davinci: fixup wait_for_completion_timeout handling
i2c: mpc: Fix ISR return value
i2c: slave-eeprom: add more info when to increase the pointer
i2c: slave: add documentation for i2c-slave-eeprom
Documentation: i2c: describe the new slave mode
i2c: slave: rework the slave API
i2c: add support for the Digicolor I2C controller
i2c: busses with dynamic ids should start after fixed ids for DT
of: base: add function to get highest id of an alias stem
i2c: designware: Suppress error message if platform_get_irq() < 0
i2c: mpc: assign the correct prescaler from SVR
i2c: img-scb: fixup of wait_for_completion_timeout return handling
Pull VFIO updates from Alex Williamson:
- VFIO platform bus driver support (Baptiste Reynal, Antonios Motakis,
testing and review by Eric Auger)
- Split VFIO irqfd support to separate module (Alex Williamson)
- vfio-pci VGA arbiter client (Alex Williamson)
- New vfio-pci.ids= module option (Alex Williamson)
- vfio-pci D3 power state support for idle devices (Alex Williamson)
* tag 'vfio-v4.1-rc1' of git://github.com/awilliam/linux-vfio: (30 commits)
vfio-pci: Fix use after free
vfio-pci: Move idle devices to D3hot power state
vfio-pci: Remove warning if try-reset fails
vfio-pci: Allow PCI IDs to be specified as module options
vfio-pci: Add VGA arbiter client
vfio-pci: Add module option to disable VGA region access
vgaarb: Stub vga_set_legacy_decoding()
vfio: Split virqfd into a separate module for vfio bus drivers
vfio: virqfd_lock can be static
vfio: put off the allocation of "minor" in vfio_create_group
vfio/platform: implement IRQ masking/unmasking via an eventfd
vfio: initialize the virqfd workqueue in VFIO generic code
vfio: move eventfd support code for VFIO_PCI to a separate file
vfio: pass an opaque pointer on virqfd initialization
vfio: add local lock for virqfd instead of depending on VFIO PCI
vfio: virqfd: rename vfio_pci_virqfd_init and vfio_pci_virqfd_exit
vfio: add a vfio_ prefix to virqfd_enable and virqfd_disable and export
vfio/platform: support for level sensitive interrupts
vfio/platform: trigger an interrupt via eventfd
vfio/platform: initial interrupts support code
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pincontrol updates from Linus Walleij:
"This is the bulk of pin control changes for the v4.1 development
cycle. Nothing really exciting this time: we basically added a few
new drivers and subdrivers and stabilized them in linux-next. Some
cleanups too. With sunrisepoint Intel has a real fine fully featured
pin control driver for contemporary hardware, and the AMD driver is
also for large deployments. Most of the others are ARM devices.
New drivers:
- Intel Sunrisepoint
- AMD KERNCZ GPIO
- Broadcom Cygnus IOMUX
New subdrivers:
- Marvell MVEBU Armada 39x SoCs
- Samsung Exynos 5433
- nVidia Tegra 210
- Mediatek MT8135
- Mediatek MT8173
- AMLogic Meson8b
- Qualcomm PM8916
On top of this cleanups and development history for the above drivers
as issues were fixed after merging"
* tag 'pinctrl-v4.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (71 commits)
pinctrl: sirf: move sgpio lock into state container
pinctrl: Add support for PM8916 GPIO's and MPP's
pinctrl: bcm2835: Fix support for threaded level triggered IRQs
sh-pfc: r8a7790: add EtherAVB pin groups
pinctrl: Document "function" + "pins" pinmux binding
pinctrl: intel: Add Intel Sunrisepoint pin controller and GPIO support
pinctrl: fsl: imx: Check for 0 config register
pinctrl: Add support for Meson8b
documentation: Extend pinctrl docs for Meson8b
pinctrl: Cleanup Meson8 driver
Fix inconsistent spinlock of AMD GPIO driver which can be recognized by static analysis tool smatch. Declare constant Variables with Sparse's suggestion.
pinctrl: at91: convert __raw to endian agnostic IO
pinctrl: constify of_device_id array
pinctrl: pinconf-generic: add dt node names to error messages
pinctrl: pinconf-generic: scan also referenced phandle node
pinctrl: mvebu: add suspend/resume support to Armada XP pinctrl driver
pinctrl: st: Display pin's function when printing pinctrl debug information
pinctrl: st: Show correct pin direction also in GPIO mode
pinctrl: st: Supply a GPIO get_direction() call-back
pinctrl: st: Move st_get_pio_control() further up the source file
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Changes to existing drivers:
- Rename child driver [axp288_battery => axp288_fuel_gauge]; axp20x
- Rename child driver [max77693-flash => max77693-led]; max77693
- Error handling fixes; intel_soc_pmic
- GPIO tweaking; intel_soc_pmic
- Remove non-DT code; vexpress-sysreg, tc3589x
- Remove unused/legacy code; ti_am335x_tscadc, rts5249, rtsx_gops, rtsx_pcr,
rtc-s5m, sec-core, max77693, menelaus,
wm5102-tables
- Trivial fixups; rtsx_pci, da9150-core, sec-core, max7769, max77693,
mc13xxx-core, dln2, hi6421-pmic-core, rk808, twl4030-power,
lpc_ich, menelaus, twl6040
- Update register/address values; rts5227, rts5249
- DT and/or binding document fixups; arizona, da9150, mt6397, axp20x,
qcom-rpm, qcom-spmi-pmic
- Couple of trivial core Kconfig fixups
- Remove use of seq_printf return value; ab8500-debugfs
- Remove __exit markups; menelaus, tps65010
- Fix platform-device name collisions; mfd-core
New drivers/supported devices:
- Add support for wm8280/wm8281 into arizona
- Add support for COMe-cBL6 into kempld-core
- Add support for rts524a and rts525a into rts5249
- Add support for ipq8064 into qcom_rpm
- Add support for extcon into axp20x
- New MediaTek MT6397 PMIC driver
- New Maxim MAX77843 PMIC dirver
- New Intel Quark X1000 I2C-GPIO driver
- New Skyworks SKY81452 driver"
* tag 'mfd-for-linus-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (76 commits)
mfd: sec: Fix RTC alarm interrupt number on S2MPS11
mfd: wm5102: Remove registers for output 3R from readable list
mfd: tps65010: Remove incorrect __exit markups
mfd: devicetree: bindings: Add Qualcomm RPM regulator subnodes
mfd: axp20x: Add support for extcon cell
mfd: lpc_ich: Sort IDs
mfd: twl6040: Remove wrong and unneeded "platform:twl6040" modalias
mfd: qcom-spmi-pmic: Add specific compatible strings for Qualcomm's SPMI PMIC's
mfd: axp20x: Fix duplicate const for model names
mfd: menelaus: Use macro for magic number
mfd: menelaus: Drop support for SW controller VCORE
mfd: menelaus: Delete omap_has_menelaus
mfd: arizona: Correct type of gpio_defaults
mfd: Fix a typo in Kconfig
mfd: qcom_rpm: Add support for IPQ8064
mfd: devicetree: qcom_rpm: Document IPQ8064 resources
mfd: core: Fix platform-device name collisions
mfd: intel_quark_i2c_gpio: Don't crash if !DMI
dt-bindings: Add vendor-prefix for X-Powers
Merge first patchbomb from Andrew Morton:
- arch/sh updates
- ocfs2 updates
- kernel/watchdog feature
- about half of mm/
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (122 commits)
Documentation: update arch list in the 'memtest' entry
Kconfig: memtest: update number of test patterns up to 17
arm: add support for memtest
arm64: add support for memtest
memtest: use phys_addr_t for physical addresses
mm: move memtest under mm
mm, hugetlb: abort __get_user_pages if current has been oom killed
mm, mempool: do not allow atomic resizing
memcg: print cgroup information when system panics due to panic_on_oom
mm: numa: remove migrate_ratelimited
mm: fold arch_randomize_brk into ARCH_HAS_ELF_RANDOMIZE
mm: split ET_DYN ASLR from mmap ASLR
s390: redefine randomize_et_dyn for ELF_ET_DYN_BASE
mm: expose arch_mmap_rnd when available
s390: standardize mmap_rnd() usage
powerpc: standardize mmap_rnd() usage
mips: extract logic for mmap_rnd()
arm64: standardize mmap_rnd() usage
x86: standardize mmap_rnd() usage
arm: factor out mmap ASLR into mmap_rnd
Since memtest might be used by other architectures pass input parameters
as phys_addr_t instead of long to prevent overflow.
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
Memtest is a simple feature which fills the memory with a given set of
patterns and validates memory contents, if bad memory regions is detected
it reserves them via memblock API. Since memblock API is widely used by
other architectures this feature can be enabled outside of x86 world.
This patch set promotes memtest to live under generic mm umbrella and
enables memtest feature for arm/arm64.
It was reported that this patch set was useful for tracking down an issue
with some errant DMA on an arm64 platform.
This patch (of 6):
There is nothing platform dependent in the core memtest code, so other
platforms might benefit from this feature too.
[linux@roeck-us.net: MEMTEST depends on MEMBLOCK]
Cc: Paul Bolle <pebolle@tiscali.nl>
Allocating a large number of elements in atomic context could quickly
deplete memory reserves, so just disallow atomic resizing entirely.
Nothing currently uses mempool_resize() with anything other than
GFP_KERNEL, so convert existing callers to drop the gfp_mask.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Steffen Maier <maier@linux.vnet.ibm.com> [zfcp]
Cc: Steve French <sfrench@samba.org>
If kernel panics due to oom, caused by a cgroup reaching its limit, when
'compulsory panic_on_oom' is enabled, then we will only see that the OOM
happened because of "compulsory panic_on_oom is enabled" but this doesn't
tell the difference between mempolicy and memcg. And dumping system wide
information is plain wrong and more confusing. This patch provides the
information of the cgroup whose limit triggerred panic
Signed-off-by: Balasubramani Vivekanandan <balasubramani_vivekanandan@mentor.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
This code is dead since commit 9e645ab6d089 ("sched/numa: Continue PTE
scanning even if migrate rate limited") so remove it.
The arch_randomize_brk() function is used on several architectures,
even those that don't support ET_DYN ASLR. To avoid bulky extern/#define
tricks, consolidate the support under CONFIG_ARCH_HAS_ELF_RANDOMIZE for
the architectures that support it, while still handling CONFIG_COMPAT_BRK.
Cc: Hector Marco-Gisbert <hecmargi@upv.es>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: "David A. Long" <dave.long@linaro.org>
Cc: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Arun Chandran <achandran@mvista.com>
Cc: Yann Droneaud <ydroneaud@opteya.com>
Cc: Min-Hua Chen <orca.chen@gmail.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Alex Smith <alex@alex-smith.me.uk>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Cc: Vineeth Vijayan <vvijayan@mvista.com>
Cc: Jeff Bailey <jeffbailey@google.com>
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Behan Webster <behanw@converseincode.com>
Cc: Ismael Ripoll <iripoll@upv.es>
Cc: Jan-Simon Mller <dl9pf@gmx.de>
When an architecture fully supports randomizing the ELF load location,
a per-arch mmap_rnd() function is used to find a randomized mmap base.
In preparation for randomizing the location of ET_DYN binaries
separately from mmap, this renames and exports these functions as
arch_mmap_rnd(). Additionally introduces CONFIG_ARCH_HAS_ELF_RANDOMIZE
for describing this feature on architectures that support it
(which is a superset of ARCH_BINFMT_ELF_RANDOMIZE_PIE, since s390
already supports a separated ET_DYN ASLR from mmap ASLR without the
ARCH_BINFMT_ELF_RANDOMIZE_PIE logic).
Change vunmap_pmd_range() and vunmap_pud_range() to tear down huge KVA
mappings when they are set. pud_clear_huge() and pmd_clear_huge() return
zero when no-operation is performed, i.e. huge page mapping was not used.
These changes are only enabled when CONFIG_HAVE_ARCH_HUGE_VMAP is defined
on the architecture.
[akpm@linux-foundation.org: use consistent code layout]
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Cc: Robert Elliott <Elliott@hp.com>
ioremap_pud_range() and ioremap_pmd_range() are changed to create huge I/O
mappings when their capability is enabled, and a request meets required
conditions -- both virtual & physical addresses are aligned by their huge
page size, and a requested range fufills their huge page size. When
pud_set_huge() or pmd_set_huge() returns zero, i.e. no-operation is
performed, the code simply falls back to the next level.
The changes are only enabled when CONFIG_HAVE_ARCH_HUGE_VMAP is defined on
the architecture.
Add ioremap_pud_enabled() and ioremap_pmd_enabled(), which return 1 when
I/O mappings with pud/pmd are enabled on the kernel.
ioremap_huge_init() calls arch_ioremap_pud_supported() and
arch_ioremap_pmd_supported() to initialize the capabilities at boot-time.
A new kernel option "nohugeiomap" is also added, so that user can disable
the huge I/O map capabilities when necessary.
__GFP_NOFAIL is documented as a deprecated flag since commit
478352e789f5 ("mm: add comment about deprecation of __GFP_NOFAIL").
This has discouraged people from using it but in some cases an opencoded
endless loop around allocator has been used instead. So the allocator
is not aware of the de facto __GFP_NOFAIL allocation because this
information was not communicated properly.
Let's make clear that if the allocation context really cannot afford
failure because there is no good failure policy then using __GFP_NOFAIL
is preferable to opencoding the loop outside of the allocator.
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Vipul Pandya <vipul@chelsio.com>
Cc: Jan Kara <jack@suse.cz>
Constify function parameters and use correct signness where needed.
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Acked-by: Gregory Fong <gregory.0xf0@gmail.com>
Cc: Pintu Kumar <pintu.k@samsung.com>
NOTE: this is not about __GFP_THISNODE, this is only about GFP_THISNODE.
GFP_THISNODE is a secret combination of gfp bits that have different
behavior than expected. It is a combination of __GFP_THISNODE,
__GFP_NORETRY, and __GFP_NOWARN and is special-cased in the page
allocator slowpath to fail without trying reclaim even though it may be
used in combination with __GFP_WAIT.
An example of the problem this creates: commit e97ca8e5b864 ("mm: fix
GFP_THISNODE callers and clarify") fixed up many users of GFP_THISNODE
that really just wanted __GFP_THISNODE. The problem doesn't end there,
however, because even it was a no-op for alloc_misplaced_dst_page(),
which also sets __GFP_NORETRY and __GFP_NOWARN, and
migrate_misplaced_transhuge_page(), where __GFP_NORETRY and __GFP_NOWAIT
is set in GFP_TRANSHUGE. Converting GFP_THISNODE to __GFP_THISNODE is a
no-op in these cases since the page allocator special-cases
__GFP_THISNODE && __GFP_NORETRY && __GFP_NOWARN.
It's time to just remove GFP_THISNODE entirely. We leave __GFP_THISNODE
to restrict an allocation to a local node, but remove GFP_THISNODE and
its obscurity. Instead, we require that a caller clear __GFP_WAIT if it
wants to avoid reclaim.
This allows the aforementioned functions to actually reclaim as they
should. It also enables any future callers that want to do
__GFP_THISNODE but also __GFP_NORETRY && __GFP_NOWARN to reclaim. The
rule is simple: if you don't want to reclaim, then don't set __GFP_WAIT.
Aside: ovs_flow_stats_update() really wants to avoid reclaim as well, so
it is unchanged.
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Jarno Rajahalme <jrajahalme@nicira.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Tejun Heo <tj@kernel.org>
The limit equals 32 and is imposed by the number of entries in the
fs_poolid_map and shared_fs_poolid_map. Nowadays it is insufficient,
because with containers on board a Linux host can have hundreds of
active fs mounts.
These maps were introduced by commit 49a9ab815acb8 ("mm: cleancache:
lazy initialization to allow tmem backends to build/run as modules") in
order to allow compiling cleancache drivers as modules. Real pool ids
are stored in these maps while super_block->cleancache_poolid points to
an entry in the map, so that on cleancache registration we can walk over
all (if there are <= 32 of them, of course) cleancache-enabled super
blocks and assign real pool ids.
Actually, there is absolutely no need in these maps, because we can
iterate over all super blocks immediately using iterate_supers. This is
not racy, because cleancache_init_ops is called from mount_fs with
super_block->s_umount held for writing, while iterate_supers takes this
semaphore for reading, so if we call iterate_supers after setting
cleancache_ops, all super blocks that had been created before
cleancache_register_ops was called will be assigned pool ids by the
action function of iterate_supers while all newer super blocks will
receive it in cleancache_init_fs.
This patch therefore removes the maps and hence the artificial limit on
the number of cleancache enabled filesystems.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Stefan Hengelein <ilendir@googlemail.com>
Cc: Florian Schmaus <fschmaus@gmail.com>
Cc: Andor Daam <andor.daam@googlemail.com>
Cc: Dan Magenheimer <dan.magenheimer@oracle.com>
Cc: Bob Liu <lliubbo@gmail.com>
Currently, cleancache_register_ops returns the previous value of
cleancache_ops to allow chaining. However, chaining, as it is
implemented now, is extremely dangerous due to possible pool id
collisions. Suppose, a new cleancache driver is registered after the
previous one assigned an id to a super block. If the new driver assigns
the same id to another super block, which is perfectly possible, we will
have two different filesystems using the same id. No matter if the new
driver implements chaining or not, we are likely to get data corruption
with such a configuration eventually.
This patch therefore disables the ability to override cleancache_ops
altogether as potentially dangerous. If there is already cleancache
driver registered, all further calls to cleancache_register_ops will
return EBUSY. Since no user of cleancache implements chaining, we only
need to make minor changes to the code outside the cleancache core.
Use super_block->s_uuid instead. Every shared filesystem using cleancache
must now initialize super_block->s_uuid before calling
cleancache_init_shared_fs. The only one on the tree, ocfs2, already meets
this requirement.
CONFIG_PGTABLE_LEVELS is now available on every architecture and we can
use it to check if we need to add nr_pmds into mm_struct.
Tested-by: Guenter Roeck <linux@roeck-us.net>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Richard Weinberger <richard@nod.at>
By this time all architectures which support more than two page table
levels should be covered. This patch add default definiton of
PGTABLE_LEVELS equal 2.
We also add assert to detect inconsistence between CONFIG_PGTABLE_LEVELS
and __PAGETABLE_PMD_FOLDED/__PAGETABLE_PUD_FOLDED.
We would want to use number of page table level to define mm_struct.
Let's expose it as CONFIG_PGTABLE_LEVELS.
It seems nobody needs this.
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
This makes show_mem() much less verbose on huge machines. Instead of huge
and almost useless dump of counters for each per-zone per-cpu lists this
patch prints the sum of these counters for each zone (free_pcp) and size
of per-cpu list for current cpu (local_pcp).
The filter flag SHOW_MEM_PERCPU_LISTS reverts to the old verbose mode.
[akpm@linux-foundation.org: update show_free_areas comment]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
This patch replaces cancel_dirty_page() with a helper function
account_page_cleaned() which only updates counters. It's called from
truncate_complete_page() and from try_to_free_buffers() (hack for ext3).
Page is locked in both cases, page-lock protects against concurrent
dirtiers: see commit 2d6d7f982846 ("mm: protect set_page_dirty() from
ongoing truncation").
Delete_from_page_cache() shouldn't be called for dirty pages, they must
be handled by caller (either written or truncated). This patch treats
final dirty accounting fixup at the end of __delete_from_page_cache() as
a debug check and adds WARN_ON_ONCE() around it. If something removes
dirty pages without proper handling that might be a bug and unwritten
data might be lost.
Hugetlbfs has no dirty pages accounting, ClearPageDirty() is enough
here.
cancel_dirty_page() in nfs_wb_page_cancel() is redundant. This is
helper for nfs_invalidate_page() and it's called only in case complete
invalidation.
The mess was started in v2.6.20 after commits 46d2277c796f ("Clean up
and make try_to_free_buffers() not race with dirty pages") and
3e67c0987d75 ("truncate: clear page dirtiness before running
try_to_free_buffers()") first was reverted right in v2.6.20 in commit
ecdfc9787fe5 ("Resurrect 'try_to_free_buffers()' VM hackery"), second in
v2.6.25 commit a2b345642f53 ("Fix dirty page accounting leak with ext3
data=journal").
Custom fixes were introduced between these points. NFS in v2.6.23, commit
1b3b4a1a2deb ("NFS: Fix a write request leak in nfs_invalidate_page()").
Kludge in __delete_from_page_cache() in v2.6.24, commit 3a6927906f1b ("Do
dirty page accounting when removing a page from the page cache"). Since
v2.6.25 all of them are redundant.
There's a deadlock when concurrently hot-adding memory through the probe
interface and switching a memory block from offline to online.
When hot-adding memory via the probe interface, add_memory() first takes
mem_hotplug_begin() and then device_lock() is later taken when registering
the newly initialized memory block. This creates a lock dependency of (1)
mem_hotplug.lock (2) dev->mutex.
When switching a memory block from offline to online, dev->mutex is first
grabbed in device_online() when the write(2) transitions an existing
memory block from offline to online, and then online_pages() will take
mem_hotplug_begin().
This creates a lock inversion between mem_hotplug.lock and dev->mutex.
Vitaly reports that this deadlock can happen when kworker handling a probe
event races with systemd-udevd switching a memory block's state.
This patch requires the state transition to take mem_hotplug_begin()
before dev->mutex. Hot-adding memory via the probe interface creates a
memory block while holding mem_hotplug_begin(), there is no way to take
dev->mutex first in this case.
online_pages() and offline_pages() are only called when transitioning
memory block state. We now require that mem_hotplug_begin() is taken
before calling them -- this requires exporting the mem_hotplug_begin() and
mem_hotplug_done() to generic code. In all hot-add and hot-remove cases,
mem_hotplug_begin() is done prior to device_online(). This is all that is
needed to avoid the deadlock.
Reported-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Tested-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Cc: Wang Nan <wangnan0@huawei.com>
After commit a1fde08c74e9 ("VM: skip the stack guard page lookup in
get_user_pages only for mlock") FOLL_MLOCK has lost its original
meaning: we don't necessarily mlock the page if the flags is set -- we
also take VM_LOCKED into consideration.
Since we use the same codepath for __mm_populate(), let's rename
FOLL_MLOCK to FOLL_POPULATE.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Michel Lespinasse <walken@google.com>
CONFIG_SLAB_DEBUG doesn't exist, CONFIG_DEBUG_SLAB does.
Cc: Pekka Enberg <penberg@kernel.org>
Have kvm_guest_init() use hardlockup_detector_disable() instead of
watchdog_enable_hardlockup_detector(false).
Remove the watchdog_hardlockup_detector_is_enabled() and the
watchdog_enable_hardlockup_detector() function which are no longer needed.
Signed-off-by: Ulrich Obergfell <uobergfe@redhat.com>
Signed-off-by: Don Zickus <dzickus@redhat.com>
With the current user interface of the watchdog mechanism it is only
possible to disable or enable both lockup detectors at the same time.
This series introduces new kernel parameters and changes the semantics of
some existing kernel parameters, so that the hard lockup detector and the
soft lockup detector can be disabled or enabled individually. With this
series applied, the user interface is as follows.
- parameters in /proc/sys/kernel
. soft_watchdog
This is a new parameter to control and examine the run state of
the soft lockup detector.
. nmi_watchdog
The semantics of this parameter have changed. It can now be used
to control and examine the run state of the hard lockup detector.
. watchdog
This parameter is still available to control the run state of both
lockup detectors at the same time. If this parameter is examined,
it shows the logical OR of soft_watchdog and nmi_watchdog.
. watchdog_thresh
The semantics of this parameter are not affected by the patch.
- kernel command line parameters
. nosoftlockup
to disable the soft lockup detector at boot time.
. nmi_watchdog=0 or nmi_watchdog=1
Disable or enable the hard lockup detector at boot time. The patch
introduces '=1' as a new option.
. nowatchdog
The semantics of this parameter are not affected by the patch. It
is still available to disable both lockup detectors at boot time.
Also, remove the proc_dowatchdog() function which is no longer needed.
[dzickus@redhat.com: wrote changelog]
[dzickus@redhat.com: update documentation for kernel params and sysctl]
Separate handlers for each watchdog parameter in /proc/sys/kernel replace
the proc_dowatchdog() function. Three of those handlers merely call
proc_watchdog_common() with one different argument.
The hardlockup and softockup had always been tied together. Due to the
request of KVM folks, they had a need to have one enabled but not the
other. Internally rework the code to split things apart more cleanly.
There is a bunch of churn here, but the end result should be code that
should be easier to maintain and fix without knowing the internals of what
is going on.
This patch (of 9):
Introduce new definitions and variables to separate the user interface in
/proc/sys/kernel from the internal run state of the lockup detectors. The
internal run state is represented by two bits in a new variable that is
named 'watchdog_enabled'. This helps simplify the code, for example:
- In order to check if any of the two lockup detectors is enabled,
it is sufficient to check if 'watchdog_enabled' is not zero.
- In order to enable/disable one or both lockup detectors,
it is sufficient to set/clear one or both bits in 'watchdog_enabled'.
- Concurrent updates of 'watchdog_enabled' need not be synchronized via
a spinlock or a mutex. Updates can either be atomic or concurrency can
be detected by using 'cmpxchg'.
Pull vfs update from Al Viro:
"Part one:
- struct filename-related cleanups
- saner iov_iter_init() replacements (and switching the syscalls to
use of those)
- ntfs switch to ->write_iter() (Anton)
- aio cleanups and splitting iocb into common and async parts
(Christoph)
- assorted fixes (me, bfields, Andrew Elble)
There's a lot more, including the completion of switchover to
->{read,write}_iter(), d_inode/d_backing_inode annotations, f_flags
race fixes, etc, but that goes after #for-davem merge. David has
pulled it, and once it's in I'll send the next vfs pull request"
* 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (35 commits)
sg_start_req(): use import_iovec()
sg_start_req(): make sure that there's not too many elements in iovec
blk_rq_map_user(): use import_single_range()
sg_io(): use import_iovec()
process_vm_access: switch to {compat_,}import_iovec()
switch keyctl_instantiate_key_common() to iov_iter
switch {compat_,}do_readv_writev() to {compat_,}import_iovec()
aio_setup_vectored_rw(): switch to {compat_,}import_iovec()
vmsplice_to_user(): switch to import_iovec()
kill aio_setup_single_vector()
aio: simplify arguments of aio_setup_..._rw()
aio: lift iov_iter_init() into aio_setup_..._rw()
lift iov_iter into {compat_,}do_readv_writev()
NFS: fix BUG() crash in notify_change() with patch to chown_common()
dcache: return -ESTALE not -EBUSY on distributed fs race
NTFS: Version 2.1.32 - Update file write from aio_write to write_iter.
VFS: Add iov_iter_fault_in_multipages_readable()
drop bogus check in file_open_root()
switch security_inode_getattr() to struct path *
constify tomoyo_realpath_from_path()
Pull perf changes from Ingo Molnar:
"Core kernel changes:
- One of the more interesting features in this cycle is the ability
to attach eBPF programs (user-defined, sandboxed bytecode executed
by the kernel) to kprobes.
This allows user-defined instrumentation on a live kernel image
that can never crash, hang or interfere with the kernel negatively.
(Right now it's limited to root-only, but in the future we might
allow unprivileged use as well.)
(Alexei Starovoitov)
- Another non-trivial feature is per event clockid support: this
allows, amongst other things, the selection of different clock
sources for event timestamps traced via perf.
This feature is sought by people who'd like to merge perf generated
events with external events that were measured with different
clocks:
- cluster wide profiling
- for system wide tracing with user-space events,
- JIT profiling events
etc. Matching perf tooling support is added as well, available via
the -k, --clockid <clockid> parameter to perf record et al.
(Peter Zijlstra)
Hardware enablement kernel changes:
- x86 Intel Processor Trace (PT) support: which is a hardware tracer
on steroids, available on Broadwell CPUs.
The hardware trace stream is directly output into the user-space
ring-buffer, using the 'AUX' data format extension that was added
to the perf core to support hardware constraints such as the
necessity to have the tracing buffer physically contiguous.
This patch-set was developed for two years and this is the result.
A simple way to make use of this is to use BTS tracing, the PT
driver emulates BTS output - available via the 'intel_bts' PMU.
More explicit PT specific tooling support is in the works as well -
will probably be ready by 4.2.
(Alexander Shishkin, Peter Zijlstra)
- x86 Intel Cache QoS Monitoring (CQM) support: this is a hardware
feature of Intel Xeon CPUs that allows the measurement and
allocation/partitioning of caches to individual workloads.
These kernel changes expose the measurement side as a new PMU
driver, which exposes various QoS related PMU events. (The
partitioning change is work in progress and is planned to be merged
as a cgroup extension.)
(Matt Fleming, Peter Zijlstra; CPU feature detection by Peter P
Waskiewicz Jr)
- x86 Intel Haswell LBR call stack support: this is a new Haswell
feature that allows the hardware recording of call chains, plus
tooling support. To activate this feature you have to enable it
via the new 'lbr' call-graph recording option:
perf record --call-graph lbr
perf report
or:
perf top --call-graph lbr
This hardware feature is a lot faster than stack walk or dwarf
based unwinding, but has some limitations:
- It reuses the current LBR facility, so LBR call stack and
branch record can not be enabled at the same time.
- It is only available for user-space callchains.
(Yan, Zheng)
- x86 Intel Broadwell CPU support and various event constraints and
event table fixes for earlier models.
(Andi Kleen)
- x86 Intel HT CPUs event scheduling workarounds. This is a complex
CPU bug affecting the SNB,IVB,HSW families that results in counter
value corruption. The mitigation code is automatically enabled and
is transparent.
(Maria Dimakopoulou, Stephane Eranian)
The perf tooling side had a ton of changes in this cycle as well, so
I'm only able to list the user visible changes here, in addition to
the tooling changes outlined above:
User visible changes affecting all tools:
- Improve support of compressed kernel modules (Jiri Olsa)
- Save DSO loading errno to better report errors (Arnaldo Carvalho de Melo)
- Bash completion for subcommands (Yunlong Song)
- Add 'I' event modifier for perf_event_attr.exclude_idle bit (Jiri Olsa)
- Support missing -f to override perf.data file ownership. (Yunlong Song)
- Show the first event with an invalid filter (David Ahern, Arnaldo Carvalho de Melo)
User visible changes in individual tools:
'perf data':
New tool for converting perf.data to other formats, initially
for the CTF (Common Trace Format) from LTTng (Jiri Olsa,
Sebastian Siewior)
'perf diff':
Add --kallsyms option (David Ahern)
'perf list':
Allow listing events with 'tracepoint' prefix (Yunlong Song)
Sort the output of the command (Yunlong Song)
'perf kmem':
Respect -i option (Jiri Olsa)
Print big numbers using thousands' group (Namhyung Kim)
Allow -v option (Namhyung Kim)
Fix alignment of slab result table (Namhyung Kim)
'perf probe':
Support multiple probes on different binaries on the same command line (Masami Hiramatsu)
Support unnamed union/structure members data collection. (Masami Hiramatsu)
Check kprobes blacklist when adding new events. (Masami Hiramatsu)
'perf record':
Teach 'perf record' about perf_event_attr.clockid (Peter Zijlstra)
Support recording running/enabled time (Andi Kleen)
'perf sched':
Improve the performance of 'perf sched replay' on high CPU core count machines (Yunlong Song)
'perf report' and 'perf top':
Allow annotating entries in callchains in the hists browser (Arnaldo Carvalho de Melo)
Indicate which callchain entries are annotated in the
TUI hists browser (Arnaldo Carvalho de Melo)
Add pid/tid filtering to 'report' and 'script' commands (David Ahern)
Consider PERF_RECORD_ events with cpumode == 0 in 'perf top', removing one
cause of long term memory usage buildup, i.e. not processing PERF_RECORD_EXIT
events (Arnaldo Carvalho de Melo)
'perf stat':
Report unsupported events properly (Suzuki K. Poulose)
Output running time and run/enabled ratio in CSV mode (Andi Kleen)
'perf trace':
Handle legacy syscalls tracepoints (David Ahern, Arnaldo Carvalho de Melo)
Only insert blank duration bracket when tracing syscalls (Arnaldo Carvalho de Melo)
Filter out the trace pid when no threads are specified (Arnaldo Carvalho de Melo)
Dump stack on segfaults (Arnaldo Carvalho de Melo)
No need to explicitely enable evsels for workload started from perf, let it
be enabled via perf_event_attr.enable_on_exec, removing some events that take
place in the 'perf trace' before a workload is really started by it.
Allow mixing with tracepoints and suppressing plain syscalls. (Arnaldo Carvalho de Melo)
There's also been a ton of infrastructure work done, such as the
split-out of perf's build system into tools/build/ and other changes -
see the shortlog and changelog for details"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (358 commits)
perf/x86/intel/pt: Clean up the control flow in pt_pmu_hw_init()
perf evlist: Fix type for references to data_head/tail
perf probe: Check the orphaned -x option
perf probe: Support multiple probes on different binaries
perf buildid-list: Fix segfault when show DSOs with hits
perf tools: Fix cross-endian analysis
perf tools: Fix error path to do closedir() when synthesizing threads
perf tools: Fix synthesizing fork_event.ppid for non-main thread
perf tools: Add 'I' event modifier for exclude_idle bit
perf report: Don't call map__kmap if map is NULL.
perf tests: Fix attr tests
perf probe: Fix ARM 32 building error
perf tools: Merge all perf_event_attr print functions
perf record: Add clockid parameter
perf sched replay: Use replay_repeat to calculate the runavg of cpu usage instead of the default value 10
perf sched replay: Support using -f to override perf.data file ownership
perf sched replay: Fix the EMFILE error caused by the limitation of the maximum open files
perf sched replay: Handle the dead halt of sem_wait when create_tasks() fails for any task
perf sched replay: Fix the segmentation fault problem caused by pr_err in threads
perf sched replay: Realloc the memory of pid_to_task stepwise to adapt to the different pid_max configurations
Pull NOHZ changes from Ingo Molnar:
"This tree adds full dynticks support to KVM guests (support the
disabling of the timer tick on the guest). The main missing piece was
the recognition of guest execution as RCU extended quiescent state and
related changes"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
kvm,rcu,nohz: use RCU extended quiescent state when running KVM guest
context_tracking: Export context_tracking_user_enter/exit
context_tracking: Run vtime_user_enter/exit only when state == CONTEXT_USER
context_tracking: Add stub context_tracking_is_enabled
context_tracking: Generalize context tracking APIs to support user and guest
context_tracking: Rename context symbols to prepare for transition state
ppc: Remove unused cpp symbols in kvm headers
Pull RCU changes from Ingo Molnar:
"The main changes in this cycle were:
- changes permitting use of call_rcu() and friends very early in
boot, for example, before rcu_init() is invoked.
- add in-kernel API to enable and disable expediting of normal RCU
grace periods.
- improve RCU's handling of (hotplug-) outgoing CPUs.
- NO_HZ_FULL_SYSIDLE fixes.
- tiny-RCU updates to make it more tiny.
- documentation updates.
- miscellaneous fixes"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (58 commits)
cpu: Provide smpboot_thread_init() on !CONFIG_SMP kernels as well
cpu: Defer smpboot kthread unparking until CPU known to scheduler
rcu: Associate quiescent-state reports with grace period
rcu: Yet another fix for preemption and CPU hotplug
rcu: Add diagnostics to grace-period cleanup
rcutorture: Default to grace-period-initialization delays
rcu: Handle outgoing CPUs on exit from idle loop
cpu: Make CPU-offline idle-loop transition point more precise
rcu: Eliminate ->onoff_mutex from rcu_node structure
rcu: Process offlining and onlining only at grace-period start
rcu: Move rcu_report_unblock_qs_rnp() to common code
rcu: Rework preemptible expedited bitmask handling
rcu: Remove event tracing from rcu_cpu_notify(), used by offline CPUs
rcutorture: Enable slow grace-period initializations
rcu: Provide diagnostic option to slow down grace-period initialization
rcu: Detect stalls caused by failure to propagate up rcu_node tree
rcu: Eliminate empty HOTPLUG_CPU ifdef
rcu: Simplify sync_rcu_preempt_exp_init()
rcu: Put all orphan-callback-related code under same comment
rcu: Consolidate offline-CPU callback initialization
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"Some clean ups and small fixes, but the biggest change is the addition
of the TRACE_DEFINE_ENUM() macro that can be used by tracepoints.
Tracepoints have helper functions for the TP_printk() called
__print_symbolic() and __print_flags() that lets a numeric number be
displayed as a a human comprehensible text. What is placed in the
TP_printk() is also shown in the tracepoint format file such that user
space tools like perf and trace-cmd can parse the binary data and
express the values too. Unfortunately, the way the TRACE_EVENT()
macro works, anything placed in the TP_printk() will be shown pretty
much exactly as is. The problem arises when enums are used. That's
because unlike macros, enums will not be changed into their values by
the C pre-processor. Thus, the enum string is exported to the format
file, and this makes it useless for user space tools.
The TRACE_DEFINE_ENUM() solves this by converting the enum strings in
the TP_printk() format into their number, and that is what is shown to
user space. For example, the tracepoint tlb_flush currently has this
in its format file:
__print_symbolic(REC->reason,
{ TLB_FLUSH_ON_TASK_SWITCH, "flush on task switch" },
{ TLB_REMOTE_SHOOTDOWN, "remote shootdown" },
{ TLB_LOCAL_SHOOTDOWN, "local shootdown" },
{ TLB_LOCAL_MM_SHOOTDOWN, "local mm shootdown" })
After adding:
TRACE_DEFINE_ENUM(TLB_FLUSH_ON_TASK_SWITCH);
TRACE_DEFINE_ENUM(TLB_REMOTE_SHOOTDOWN);
TRACE_DEFINE_ENUM(TLB_LOCAL_SHOOTDOWN);
TRACE_DEFINE_ENUM(TLB_LOCAL_MM_SHOOTDOWN);
Its format file will contain this:
{ 0, "flush on task switch" },
{ 1, "remote shootdown" },
{ 2, "local shootdown" },
{ 3, "local mm shootdown" })"
* tag 'trace-v4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (27 commits)
tracing: Add enum_map file to show enums that have been mapped
writeback: Export enums used by tracepoint to user space
v4l: Export enums used by tracepoints to user space
SUNRPC: Export enums in tracepoints to user space
mm: tracing: Export enums in tracepoints to user space
irq/tracing: Export enums in tracepoints to user space
f2fs: Export the enums in the tracepoints to userspace
net/9p/tracing: Export enums in tracepoints to userspace
x86/tlb/trace: Export enums in used by tlb_flush tracepoint
tracing/samples: Update the trace-event-sample.h with TRACE_DEFINE_ENUM()
tracing: Allow for modules to convert their enums to values
tracing: Add TRACE_DEFINE_ENUM() macro to map enums to their values
tracing: Update trace-event-sample with TRACE_SYSTEM_VAR documentation
tracing: Give system name a pointer
brcmsmac: Move each system tracepoints to their own header
iwlwifi: Move each system tracepoints to their own header
mac80211: Move message tracepoints to their own header
tracing: Add TRACE_SYSTEM_VAR to xhci-hcd
tracing: Add TRACE_SYSTEM_VAR to kvm-s390
tracing: Add TRACE_SYSTEM_VAR to intel-sst
Pull tracefs from Steven Rostedt:
"This adds the new tracefs file system.
This has been in linux-next for more than one release, as I had it
ready for the 4.0 merge window, but a last minute thing that needed to
go into Linux first had to be done. That was that perf hard coded the
file system number when reading /sys/kernel/debugfs/tracing directory
making sure that the path had the debugfs mount # before it would
parse the tracing file. This broke other use cases of perf, and the
check is removed.
Now when mounting /sys/kernel/debug, tracefs is automatically mounted
in /sys/kernel/debug/tracing such that old tools will still see that
path as expected. But now system admins can mount tracefs directly
and not need to mount debugfs, which can expose security issues. A
new directory is created when tracefs is configured such that system
admins can now mount it separately (/sys/kernel/tracing)"
* tag 'trace-4.1-tracefs' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Have mkdir and rmdir be part of tracefs
tracefs: Add directory /sys/kernel/tracing
tracing: Automatically mount tracefs on debugfs/tracing
tracing: Convert the tracing facility over to use tracefs
tracefs: Add new tracefs file system
tracing: Create cmdline tracer options on tracing fs init
tracing: Only create tracer options files if directory exists
debugfs: Provide a file creation function that also takes an initial size
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching
Pull livepatching updates from Jiri Kosina:
"These are mostly smaller things that got accumulated during the
development cycle. The unified solution is still being worked on and
is not mature enough for 4.1 yet.
- s390 livepatching support, from Jiri Slaby (has Ack from s390
maintainers)
- error handling simplification, from Josh Poimboeuf
- two minor code cleanups from Josh Poimboeuf and Miroslav Benes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching:
livepatch: add support on s390
livepatch: remove unnecessary call to klp_find_object_module()
livepatch: simplify disable error path
livepatch: remove extern specifier from header files
Pull trivial tree from Jiri Kosina:
"Usual trivial tree updates. Nothing outstanding -- mostly printk()
and comment fixes and unused identifier removals"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
goldfish: goldfish_tty_probe() is not using 'i' any more
powerpc: Fix comment in smu.h
qla2xxx: Fix printks in ql_log message
lib: correct link to the original source for div64_u64
si2168, tda10071, m88ds3103: Fix firmware wording
usb: storage: Fix printk in isd200_log_config()
qla2xxx: Fix printk in qla25xx_setup_mode
init/main: fix reset_device comment
ipwireless: missing assignment
goldfish: remove unreachable line of code
coredump: Fix do_coredump() comment
stacktrace.h: remove duplicate declaration task_struct
smpboot.h: Remove unused function prototype
treewide: Fix typo in printk messages
mod_devicetable: fix comment for match_flags
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
- quite a few firmware fixes for RMI driver by Andrew Duggan
- huion and uclogic drivers have been substantially overlaping in
functionality laterly. This redundancy is fixed by hid-huion driver
being merged into hid-uclogic; work done by Benjamin Tissoires and
Nikolai Kondrashov
- i2c-hid now supports ACPI GPIO interrupts; patch from Mika Westerberg
- Some of the quirks, that got separated into individual drivers, have
historically had EXPERT dependency. As HID subsystem matured (as
well as the individual drivers), this made less and less sense. This
dependency is now being removed by patch from Jean Delvare
- Logitech lg4ff driver received a couple of improvements for mode
switching, by Michal Malý
- multitouch driver now supports clickpads, patches by Benjamin
Tissoires and Seth Forshee
- hid-sensor framework received a substantial update; namely support
for Custom and Generic pages is being added; work done by Srinivas
Pandruvada
- wacom driver received substantial update; it now supports
i2c-conntected devices (Mika Westerberg), Bamboo PADs are now
properly supported (Benjamin Tissoires), much improved battery
reporting (Jason Gerecke) and pen proximity cleanups (Ping Cheng)
- small assorted fixes and device ID additions
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (68 commits)
HID: sensor: Update document for custom sensor
HID: sensor: Custom and Generic sensor support
HID: debug: fix error handling in hid_debug_events_read()
Input - mt: Fix input_mt_get_slot_by_key
HID: logitech-hidpp: fix error return code
HID: wacom: Add support for Cintiq 13HD Touch
HID: logitech-hidpp: add a module parameter to keep firmware gestures
HID: usbhid: yet another mouse with ALWAYS_POLL
HID: usbhid: more mice with ALWAYS_POLL
HID: wacom: set stylus_in_proximity before checking touch_down
HID: wacom: use wacom_wac_finger_count_touches to set touch_down
HID: wacom: remove hardcoded WACOM_QUIRK_MULTI_INPUT
HID: pidff: effect can't be NULL
HID: add quirk for PIXART OEM mouse used by HP
HID: add HP OEM mouse to quirk ALWAYS_POLL
HID: wacom: ask for a in-prox report when it was missed
HID: hid-sensor-hub: Fix sparse warning
HID: hid-sensor-hub: fix attribute read for logical usage id
HID: plantronics: fix Kconfig default
HID: pidff: support more than one concurrent effect
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big staging driver patchset for 4.1-rc1.
There's a lot of patches here, the Outreachy application period
happened during this development cycle, so that means that there was a
lot of cleanup patches accepted. Other than the normal coding style
and sparse fixes here, there are some driver updates and work toward
making some of the drivers into "mergable" shape (like the Unisys
drivers.)
All of these have been in linux-next for a while"
* tag 'staging-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1214 commits)
staging: lustre: orthography & coding style
staging: lustre: lnet: lnet: fix error return code
staging: lustre: fix sparse warning
Revert "Staging: sm750fb: Fix C99 Comments"
Staging: rtl8192u: use correct array for debug output
staging: rtl8192e: Remove dead code
staging: rtl8192e: Comment cleanup (style/format)
staging: rtl8192e: Fix indentation in rtllib_rx_auth_resp()
staging: rtl8192e: Decrease nesting of rtllib_rx_auth_resp()
staging: rtl8192e: Divide rtllib_rx_auth()
staging: rtl8192e: Fix PRINTK_WITHOUT_KERN_LEVEL warnings
staging: rtl8192e: Fix DO_WHILE_MACRO_WITH_TRAILING_SEMICOLON warning
staging: rtl8192e: Fix BRACES warning
staging: rtl8192e: Fix LINE_CONTINUATIONS warning
staging: rtl8192e: Fix UNNECESSARY_PARENTHESES warnings
staging: rtl8192e: remove unused EXPORT_SYMBOL_RSL macro
staging: rtl8192e: Fix RETURN_VOID warnings
staging: rtl8192e: Fix UNNECESSARY_ELSE warning
staging: rtl8723au: Remove unneeded comments
staging: rtl8723au: Use __func__ in trace logs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here's the driver-core / kobject / lz4 tree update for 4.1-rc1.
Everything here has been in linux-next for a while with no reported
issues. It's mostly just coding style cleanups, with other minor
changes in here as well, nothing big"
* tag 'driver-core-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (32 commits)
debugfs: allow bad parent pointers to be passed in
stable_kernel_rules: Add clause about specification of kernel versions to patch.
kobject: WARN as tip when call kobject_get() to a kobject not initialized
lib/lz4: Pull out constant tables
drivers: platform: parse IRQ flags from resources
driver core: Make probe deferral more quiet
drivers/core/of: Add symlink to device-tree from devices with an OF node
device: Add dev_of_node() accessor
drivers: base: fw: fix ret value when loading fw
firmware: Avoid manual device_create_file() calls
drivers/base: cacheinfo: validate device node for all the caches
drivers/base: use tabs where possible in code indentation
driver core: add missing blank line after declaration
drivers: base: node: Delete space after pointer declaration
drivers: base: memory: Use tabs instead of spaces
firmware_class: Fix whitespace and indentation
drivers: base: dma-mapping: Erase blank space after pointer
drivers: base: class: Add a blank line after declarations
attribute_container: fix missing blank lines after declarations
drivers: base: memory: Fix switch indent
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB driver updates from Greg KH:
"Here's the big USB (and PHY) driver patchset for 4.1-rc1.
Everything here has been in linux-next, and the full details are below
in the shortlog. Nothing major, just the normal round of new
drivers,api updates, and other changes, mostly in the USB gadget area,
as usual"
* tag 'usb-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (252 commits)
drivers/usb/core: devio.c: Removed an uneeded space before tab
usb: dwc2: host: sleep USB_RESUME_TIMEOUT during resume
usb: chipidea: debug: add low power mode check before print registers
usb: chipidea: udc: bypass pullup DP when gadget connect in OTG fsm mode
usb: core: hub: use new USB_RESUME_TIMEOUT
usb: isp1760: hcd: use new USB_RESUME_TIMEOUT
usb: dwc2: hcd: use new USB_RESUME_TIMEOUT
usb: host: sl811: use new USB_RESUME_TIMEOUT
usb: host: r8a66597: use new USB_RESUME_TIMEOUT
usb: host: oxu210hp: use new USB_RESUME_TIMEOUT
usb: host: fusbh200: use new USB_RESUME_TIMEOUT
usb: host: fotg210: use new USB_RESUME_TIMEOUT
usb: host: isp116x: use new USB_RESUME_TIMEOUT
usb: musb: use new USB_RESUME_TIMEOUT
usb: host: uhci: use new USB_RESUME_TIMEOUT
usb: host: ehci: use new USB_RESUME_TIMEOUT
usb: host: xhci: use new USB_RESUME_TIMEOUT
usb: define a generic USB_RESUME_TIMEOUT macro
usb: musb: dsps: fix build on i386 when COMPILE_TEST is set
ehci-hub: use USB_DT_HUB
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"Nothing too interesting. Rik made cpuset cooperate better with
isolcpus and there are several other cleanup patches"
* 'for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cpuset, isolcpus: document relationship between cpusets & isolcpus
cpusets, isolcpus: exclude isolcpus from load balancing in cpusets
sched, isolcpu: make cpu_isolated_map visible outside scheduler
cpuset: initialize cpuset a bit early
cgroup: Use kvfree in pidlist_free()
cgroup: call cgroup_subsys->bind on cgroup subsys initialization
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
- Hannes's patchset implements support for better error reporting
introduced by the new ATA command spec.
- the deperecated pci_ dma API usages have been replaced by dma_ ones.
- a bunch of hardware specific updates and some cleanups.
* 'for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ata: remove deprecated use of pci api
ahci: st: st_configure_oob must be called after IP is clocked.
ahci: st: Update the ahci_st DT documentation
ahci: st: Update the DT example for how to obtain the PHY.
sata_dwc_460ex: indent an if statement
libata: Add tracepoints
libata-eh: Set 'information' field for autosense
libata: Implement support for sense data reporting
libata: Implement NCQ autosense
libata: use status bit definitions in ata_dump_status()
ide,ata: Rename ATA_IDX to ATA_SENSE
libata: whitespace fixes in ata_to_sense_error()
libata: whitespace cleanup in ata_get_cmd_descript()
libata: use READ_LOG_DMA_EXT
libata: remove ATA_FLAG_LOWTAG
sata_dwc_460ex: re-use hsdev->dev instead of dwc_dev
sata_dwc_460ex: move to generic DMA driver
sata_dwc_460ex: join messages back
sata: xgene: add ACPI support for APM X-Gene SATA ports
ata: sata_mv: add proper definitions for LP_PHY_CTL register values
Pull workqueue updates from Tejun Heo:
"Workqueue now prints debug information at the end of sysrq-t which
should be helpful when tracking down suspected workqueue stalls. It
only prints out the ones with something currently going on so it
shouldn't add much output in most cases"
* 'for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: Reorder sysfs code
percpu: Fix trivial typos in comments
workqueue: dump workqueues on sysrq-t
workqueue: keep track of the flushing task and pool manager
workqueue: make the workqueues list RCU walkable
