This helps in more control over debugging.
root@qemu-img-64:~# ls /pass/123
ls: cannot access /pass/123: No such file or directory
root@qemu-img-64:~# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# TASK-PID CPU# TIMESTAMP FUNCTION
ls-1536 [001] 70.928584: 9p_protocol_dump: clnt 18446612132784021504 P9_TWALK(tag = 1)
000: 16 00 00 00 6e 01 00 01 00 00 00 02 00 00 00 01
010: 00 03 00 31 32 33 00 00 00 ff ff ff ff 00 00 00
ls-1536 [001] 70.928587: <stack trace>
=> trace_9p_protocol_dump
=> p9pdu_finalize
=> p9_client_rpc
=> p9_client_walk
=> v9fs_vfs_lookup
=> d_alloc_and_lookup
=> walk_component
=> path_lookupat
ls-1536 [000] 70.929696: 9p_protocol_dump: clnt 18446612132784021504 P9_RLERROR(tag = 1)
000: 0b 00 00 00 07 01 00 02 00 00 00 4e 03 00 02 00
010: 00 00 00 00 03 00 02 00 00 00 00 00 ff 43 00 00
ls-1536 [000] 70.929697: <stack trace>
=> p9_client_rpc
=> p9_client_walk
=> v9fs_vfs_lookup
=> walk_component
=> path_lookupat
=> do_path_lookup
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
Without this msize=4294967295 will result in a crash
* remove lot of update to different data structure
* add a seperate callback for zero copy request.
* above makes non zero copy code path simpler
* remove conditionalizing TREAD/TREADDIR/TWRITE in the zero copy path
* Fix the dotu p9_check_errors with zero copy. Add sufficient doc around
* Add support for both in and output buffers in zero copy callback
* pin and unpin pages in the same context
* use helpers instead of defining page offset and rest of page ourself
* Fix mem leak in p9_check_errors
* Remove 'E' and 'F' in p9pdu_vwritef
Commit 903ab86d195cca295379699299c5fc10beba31c7 of 1 March this year ("udp: Add
lockless transmit path") introduced a new fast TX path that broke the checksum
coverage computation of UDP-lite, which so far depended on up->len (only set
if the socket is locked and 0 in the fast path).
Fixed by providing both fast- and slow-path computation of checksum coverage.
The latter can be removed when UDP(-lite)v6 also uses a lockless transmit path.
Reported-by: Thomas Volkert <thomas@homer-conferencing.com>
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
ip_vs_mutext is used by both netns shutdown code and startup
and both implicit uses sk_lock-AF_INET mutex.
cleanup CPU-1 startup CPU-2
ip_vs_dst_event() ip_vs_genl_set_cmd()
sk_lock-AF_INET __ip_vs_mutex
sk_lock-AF_INET
__ip_vs_mutex
* DEAD LOCK *
A new mutex placed in ip_vs netns struct called sync_mutex is added.
Comments from Julian and Simon added.
This patch has been running for more than 3 month now and it seems to work.
Ver. 3
IP_VS_SO_GET_DAEMON in do_ip_vs_get_ctl protected by sync_mutex
instead of __ip_vs_mutex as sugested by Julian.
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
* 'for-linus' of http://people.redhat.com/agk/git/linux-dm:
dm crypt: always disable discard_zeroes_data
dm: raid fix write_mostly arg validation
dm table: avoid crash if integrity profile changes
dm: flakey fix corrupt_bio_byte error path
* git://github.com/davem330/net:
pch_gbe: Fixed the issue on which a network freezes
pch_gbe: Fixed the issue on which PC was frozen when link was downed.
make PACKET_STATISTICS getsockopt report consistently between ring and non-ring
net: xen-netback: correctly restart Tx after a VM restore/migrate
bonding: properly stop queuing work when requested
can bcm: fix incomplete tx_setup fix
RDSRDMA: Fix cleanup of rds_iw_mr_pool
net: Documentation: Fix type of variables
ibmveth: Fix oops on request_irq failure
ipv6: nullify ipv6_ac_list and ipv6_fl_list when creating new socket
cxgb4: Fix EEH on IBM P7IOC
can bcm: fix tx_setup off-by-one errors
MAINTAINERS: tehuti: Alexander Indenbaum's address bounces
dp83640: reduce driver noise
ptp: fix L2 event message recognition
Add the ability to disable PCI-E MPS turning and using the BIOS
configured MPS defaults. Due to the number of issues recently
discovered on some x86 chipsets, make this the default behavior.
Also, add the option for peer to peer DMA MPS configuration. Peer to
peer DMA is outside the scope of this patch, but MPS configuration could
prevent it from working by having the MPS on one root port different
than the MPS on another. To work around this, simply make the system
wide MPS the smallest possible value (128B).
Signed-off-by: Jon Mason <mason@myri.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
'sched-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip
* 'irq-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
irq: Fix check for already initialized irq_domain in irq_domain_add
irq: Add declaration of irq_domain_simple_ops to irqdomain.h
* 'x86-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
x86/rtc: Don't recursively acquire rtc_lock
* 'sched-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
posix-cpu-timers: Cure SMP wobbles
sched: Fix up wchan borkage
sched/rt: Migrate equal priority tasks to available CPUs
David reported:
Attached below is a watered-down version of rt/tst-cpuclock2.c from
GLIBC. Just build it with "gcc -o test test.c -lpthread -lrt" or
similar.
Run it several times, and you will see cases where the main thread
will measure a process clock difference before and after the nanosleep
which is smaller than the cpu-burner thread's individual thread clock
difference. This doesn't make any sense since the cpu-burner thread
is part of the top-level process's thread group.
I've reproduced this on both x86-64 and sparc64 (using both 32-bit and
64-bit binaries).
For example:
[davem@boricha build-x86_64-linux]$ ./test
process: before(0.001221967) after(0.498624371) diff(497402404)
thread: before(0.000081692) after(0.498316431) diff(498234739)
self: before(0.001223521) after(0.001240219) diff(16698)
The diff of 'process' should always be >= the diff of 'thread'.
I make sure to wrap the 'thread' clock measurements the most tightly
around the nanosleep() call, and that the 'process' clock measurements
are the outer-most ones.
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <fcntl.h>
#include <string.h>
#include <errno.h>
#include <pthread.h>
static pthread_barrier_t barrier;
static void *chew_cpu(void *arg)
pthread_barrier_wait(&barrier);
while (1)
__asm__ __volatile__("" : : : "memory");
return NULL;
int main(void)
clockid_t process_clock, my_thread_clock, th_clock;
struct timespec process_before, process_after;
struct timespec me_before, me_after;
struct timespec th_before, th_after;
struct timespec sleeptime;
unsigned long diff;
pthread_t th;
int err;
err = clock_getcpuclockid(0, &process_clock);
if (err)
return 1;
err = pthread_getcpuclockid(pthread_self(), &my_thread_clock);
if (err)
return 1;
pthread_barrier_init(&barrier, NULL, 2);
err = pthread_create(&th, NULL, chew_cpu, NULL);
if (err)
return 1;
err = pthread_getcpuclockid(th, &th_clock);
if (err)
return 1;
err = clock_gettime(process_clock, &process_before);
if (err)
return 1;
err = clock_gettime(my_thread_clock, &me_before);
if (err)
return 1;
err = clock_gettime(th_clock, &th_before);
if (err)
return 1;
sleeptime.tv_sec = 0;
sleeptime.tv_nsec = 500000000;
nanosleep(&sleeptime, NULL);
err = clock_gettime(th_clock, &th_after);
if (err)
return 1;
err = clock_gettime(my_thread_clock, &me_after);
if (err)
return 1;
err = clock_gettime(process_clock, &process_after);
if (err)
return 1;
diff = process_after.tv_nsec - process_before.tv_nsec;
printf("process: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n",
process_before.tv_sec, process_before.tv_nsec,
process_after.tv_sec, process_after.tv_nsec, diff);
diff = th_after.tv_nsec - th_before.tv_nsec;
printf("thread: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n",
th_before.tv_sec, th_before.tv_nsec,
th_after.tv_sec, th_after.tv_nsec, diff);
diff = me_after.tv_nsec - me_before.tv_nsec;
printf("self: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n",
me_before.tv_sec, me_before.tv_nsec,
me_after.tv_sec, me_after.tv_nsec, diff);
return 0;
This is due to us using p->se.sum_exec_runtime in
thread_group_cputime() where we iterate the thread group and sum all
data. This does not take time since the last schedule operation (tick
or otherwise) into account. We can cure this by using
task_sched_runtime() at the cost of having to take locks.
This also means we can (and must) do away with
thread_group_sched_runtime() since the modified thread_group_cputime()
is now more accurate and would deadlock when called from
thread_group_sched_runtime().
Aside of that it makes the function safe on 32 bit systems. The old
code added t->se.sum_exec_runtime unprotected. sum_exec_runtime is a
64bit value and could be changed on another cpu at the same time.
Reported-by: David Miller <davem@davemloft.net>
Cc: stable@kernel.org
Link: http://lkml.kernel.org/r/1314874459.7945.22.camel@twins
Tested-by: David Miller <davem@davemloft.net>
The IEEE 1588 standard defines two kinds of messages, event and general
messages. Event messages require time stamping, and general do not. When
using UDP transport, two separate ports are used for the two message
types.
The BPF designed to recognize event messages incorrectly classifies L2
general messages as event messages. This commit fixes the issue by
extending the filter to check the message type field for L2 PTP packets.
Event messages are be distinguished from general messages by testing
the "general" bit.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Cc: <stable@kernel.org>
* 'writeback-for-linus' of git://github.com/fengguang/linux:
writeback: show raw dirtied_when in trace writeback_single_inode
That flag no longer makes sense, since we don't look up automount points
as eagerly any more. Additionally, it turns out that the NO_AUTOMOUNT
handling was buggy to begin with: it would avoid automounting even for
cases where we really *needed* to do the automount handling, and could
return ENOENT for autofs entries that hadn't been instantiated yet.
With our new non-eager automount semantics, one discussion has been
about adding a AT_AUTOMOUNT flag to vfs_fstatat (and thus the
newfstatat() and fstatat64() system calls), but it's probably not worth
it: you can always force at least directory automounting by simply
adding the final '/' to the filename, which works for *all* of the stat
family system calls, old and new.
So AT_NO_AUTOMOUNT (and thus LOOKUP_NO_AUTOMOUNT) really were just a
result of our bad default behavior.
Acked-by: Ian Kent <raven@themaw.net>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Since we've now turned around and made LOOKUP_FOLLOW *not* force an
automount, we want to add the ability to force an automount event on
lookup even if we don't happen to have one of the other flags that force
it implicitly (LOOKUP_OPEN, LOOKUP_DIRECTORY, LOOKUP_PARENT..)
Most cases will never want to use this, since you'd normally want to
delay automounting as long as possible, which usually implies
LOOKUP_OPEN (when we open a file or directory, we really cannot avoid
the automount any more).
But Trond argued sufficiently forcefully that at a minimum bind mounting
a file and quotactl will want to force the automount lookup. Some other
cases (like nfs_follow_remote_path()) could use it too, although
LOOKUP_DIRECTORY would work there as well.
This commit just adds the flag and logic, no users yet, though. It also
doesn't actually touch the LOOKUP_NO_AUTOMOUNT flag that is related, and
was made irrelevant by the same change that made us not follow on
LOOKUP_FOLLOW.
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Jeff Layton <jlayton@redhat.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Greg KH <gregkh@suse.de>
If optional discard support in dm-crypt is enabled, discards requests
bypass the crypt queue and blocks of the underlying device are discarded.
For the read path, discarded blocks are handled the same as normal
ciphertext blocks, thus decrypted.
So if the underlying device announces discarded regions return zeroes,
dm-crypt must disable this flag because after decryption there is just
random noise instead of zeroes.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6:
[S390] kvm: extension capability for new address space layout
[S390] kvm: fix address mode switching
* 'for-linus' of git://git.kernel.dk/linux-block:
floppy: use del_timer_sync() in init cleanup
blk-cgroup: be able to remove the record of unplugged device
block: Don't check QUEUE_FLAG_SAME_COMP in __blk_complete_request
mm: Add comment explaining task state setting in bdi_forker_thread()
mm: Cleanup clearing of BDI_pending bit in bdi_forker_thread()
block: simplify force plug flush code a little bit
block: change force plug flush call order
block: Fix queue_flag update when rq_affinity goes from 2 to 1
block: separate priority boosting from REQ_META
block: remove READ_META and WRITE_META
xen-blkback: fixed indentation and comments
xen-blkback: Don't disconnect backend until state switched to XenbusStateClosed.
598841ca9919d008b520114d8a4378c4ce4e40a1 ([S390] use gmap address
spaces for kvm guest images) changed kvm on s390 to use a separate
address space for kvm guests. We can now put KVM guests anywhere
in the user address mode with a size up to 8PB - as long as the
memory is 1MB-aligned. This change was done without KVM extension
capability bit.
The change was added after 3.0, but we still have a chance to add
a feature bit before 3.1 (keeping the releases in a sane state).
We use number 71 to avoid collisions with other pending kvm patches
as requested by Alexander Graf.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Avi Kivity <avi@redhat.com>
Cc: Alexander Graf <agraf@suse.de>
irq_domain_simple_ops is exported, but is not declared in irqdomain.h,
so add it.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: marc.zyngier@arm.com
Cc: thomas.abraham@linaro.org
Cc: jamie@jamieiles.com
Cc: b-cousson@ti.com
Cc: shawn.guo@linaro.org
Cc: devicetree-discuss@lists.ozlabs.org
Link: http://lkml.kernel.org/r/1316017900-19918-2-git-send-email-robherring2@gmail.com
tcp: fix validation of D-SACK
tcp: fix build error if !CONFIG_SYN_COOKIES
commit 946cedccbd7387 (tcp: Change possible SYN flooding messages)
added a build error if CONFIG_SYN_COOKIES=n
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
* 'for-linus' of git://git.infradead.org/users/sameo/mfd-2.6:
mfd: Fix omap-usb-host build failure
mfd: Make omap-usb-host TLL mode work again
mfd: Set MAX8997 irq pointer
mfd: Fix initialisation of tps65910 interrupts
mfd: Check for twl4030-madc NULL pointer
mfd: Copy the device pointer to the twl4030-madc structure
mfd: Rename wm8350 static gpio_set_debounce()
mfd: Fix value of WM8994_CONFIGURE_GPIO
* git://github.com/davem330/net: (62 commits)
ipv6: don't use inetpeer to store metrics for routes.
can: ti_hecc: include linux/io.h
IRDA: Fix global type conflicts in net/irda/irsysctl.c v2
net: Handle different key sizes between address families in flow cache
net: Align AF-specific flowi structs to long
ipv4: Fix fib_info->fib_metrics leak
caif: fix a potential NULL dereference
sctp: deal with multiple COOKIE_ECHO chunks
ibmveth: Fix checksum offload failure handling
ibmveth: Checksum offload is always disabled
ibmveth: Fix issue with DMA mapping failure
ibmveth: Fix DMA unmap error
pch_gbe: support ML7831 IOH
pch_gbe: added the process of FIFO over run error
pch_gbe: fixed the issue which receives an unnecessary packet.
sfc: Use 64-bit writes for TX push where possible
Revert "sfc: Use write-combining to reduce TX latency" and follow-ups
bnx2x: Fix ethtool advertisement
bnx2x: Fix 578xx link LED
bnx2x: Fix XMAC loopback test
With the conversion of struct flowi to a union of AF-specific structs, some
operations on the flow cache need to account for the exact size of the key.
Signed-off-by: David Ward <david.ward@ll.mit.edu>
AF-specific flowi structs are now passed to flow_key_compare, which must
also be aligned to a long.
Attempt to reduce the number of IP packets emitted in response to single
SCTP packet (2e3216cd) introduced a complication - if a packet contains
two COOKIE_ECHO chunks and nothing else then SCTP state machine corks the
socket while processing first COOKIE_ECHO and then loses the association
and forgets to uncork the socket. To deal with the issue add new SCTP
command which can be used to set association explictly. Use this new
command when processing second COOKIE_ECHO chunk to restore the context
for SCTP state machine.
Signed-off-by: Max Matveev <makc@redhat.com>
dev_forward_skb loops an skb back into host networking
stack which might hang on the memory indefinitely.
In particular, this can happen in macvtap in bridged mode.
Copy the userspace fragments to avoid blocking the
sender in that case.
As this patch makes skb_copy_ubufs extern now,
I also added some documentation and made it clear
the SKBTX_DEV_ZEROCOPY flag automatically instead
of doing it in all callers. This can be made into a separate
patch if people feel it's worth it.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
"Possible SYN flooding on port xxxx " messages can fill logs on servers.
Change logic to log the message only once per listener, and add two new
SNMP counters to track :
TCPReqQFullDoCookies : number of times a SYNCOOKIE was replied to client
TCPReqQFullDrop : number of times a SYN request was dropped because
syncookies were not enabled.
Based on a prior patch from Tom Herbert, and suggestions from David.
CC: Tom Herbert <therbert@google.com>
Building a kernel with hotplug disabled results in a link failure:
`bgpio_remove' referenced in section `___ksymtab_gpl+bgpio_remove' of drivers/built-in.o: defined in discarded section `.devexit.text' of drivers/built-in.o
This is because of bgpio_remove() is exported. It is illegal to export
symbols which are discarded either at link time or as part of an
init/exit section.
Fix this by dropping the __devexit attributation from bgpio_remove().
Also drop the __devinit attributation from bgpio_init().
Revert the post-3.0 commit 82f9d486e59f5 ("memcg: add
memory.vmscan_stat").
The implementation of per-memcg reclaim statistics violates how memcg
hierarchies usually behave: hierarchically.
The reclaim statistics are accounted to child memcgs and the parent
hitting the limit, but not to hierarchy levels in between. Usually,
hierarchical statistics are perfectly recursive, with each level
representing the sum of itself and all its children.
Since this exports statistics to userspace, this may lead to confusion
and problems with changing things after the release, so revert it now,
we can try again later.
Signed-off-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Ying Han <yinghan@google.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Fix kernel-doc warning about internal/private data by marking it
as "private:" so that kernel-doc will ignore it.
Warning(include/linux/regulator/consumer.h:128): No description found for parameter 'ret'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Fix kernel-doc warning in net/cfg80211.h:
Warning(include/net/cfg80211.h:1884): No description found for parameter 'registered'
* 'perf-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
x86, perf: Check that current->mm is alive before getting user callchain
perf_event: Fix broken calc_timer_values()
perf events: Fix slow and broken cgroup context switch code
This needs to be an out of band value for the register and on this device
registers are 16 bit so we must shift left one to the 17th bit.
Signed-off-by: Jim Garlick <garlick@llnl.gov>
Some of the flags are OS/arch dependent we add a 9p
protocol value which maps to asm-generic/fcntl.h values in Linux
Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
Save inode->dirtied_when in the raw trace output for reliable scripting,
and to also show in formatted output the relative age in seconds for
easy human reading.
CC: Jan Kara <jack@suse.cz>
Acked-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Allow transparent sockets to be less restrictive about
the source ip of ipv6 udp packets being sent.
Google-Bug-Id: 5018138
Signed-off-by: Maciej Żenczykowski <maze@google.com>
CC: "Erik Kline" <ek@google.com>
CC: "Lorenzo Colitti" <lorenzo@google.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (42 commits)
netpoll: fix incorrect access to skb data in __netpoll_rx
cassini: init before use in cas_interruptN.
can: ti_hecc: Fix uninitialized spinlock in probe
can: ti_hecc: Fix unintialized variable
net: sh_eth: fix the compile error
net/phy: fix DP83865 phy interrupt handler
sendmmsg/sendmsg: fix unsafe user pointer access
ibmveth: Fix leak when recycling skb and hypervisor returns error
arp: fix rcu lockdep splat in arp_process()
bridge: fix a possible use after free
bridge: Pseudo-header required for the checksum of ICMPv6
mcast: Fix source address selection for multicast listener report
MAINTAINERS: Update GIT trees for network development
ath9k: Fix PS wrappers in ath9k_set_coverage_class
carl9170: Fix mismatch in carl9170_op_set_key mutex lock-unlock
wl12xx: add max_sched_scan_ssids value to the hw description
wl12xx: Fix validation of pm_runtime_get_sync return value
wl12xx: Remove obsolete testmode NVS push command
bcma: add uevent to the bus, to autoload drivers
ath9k_hw: Fix STA (AR9485) bringup issue due to incorrect MAC address
The current cgroup context switch code was incorrect leading
to bogus counts. Furthermore, as soon as there was an active
cgroup event on a CPU, the context switch cost on that CPU
would increase by a significant amount as demonstrated by a
simple ping/pong example:
$ ./pong
Both processes pinned to CPU1, running for 10s
10684.51 ctxsw/s
Now start a cgroup perf stat:
$ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 100
$ ./pong
6674.61 ctxsw/s
That's a 37% penalty.
Note that pong is not even in the monitored cgroup.
The results shown by perf stat are bogus:
Performance counter stats for 'sleep 100':
CPU1 <not counted> cycles test
CPU1 16,984,189,138 cycles # 0.000 GHz
The second 'cycles' event should report a count @ CPU clock
(here 2.4GHz) as it is counting across all cgroups.
The patch below fixes the bogus accounting and bypasses any
cgroup switches in case the outgoing and incoming tasks are
in the same cgroup.
With this patch the same test now yields:
$ ./pong
10775.30 ctxsw/s
Start perf stat with cgroup:
Run pong outside the cgroup:
$ /pong
10687.80 ctxsw/s
The penalty is now less than 2%.
And the results for perf stat are correct:
Performance counter stats for 'sleep 10':
CPU1 <not counted> cycles test # 0.000 GHz
CPU1 23,933,981,448 cycles # 0.000 GHz
Now perf stat reports the correct counts for
for the non cgroup event.
If we run pong inside the cgroup, then we also get the
correct counts:
CPU1 22,297,726,205 cycles test # 0.000 GHz
10.001457237 seconds time elapsed
Signed-off-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20110825135803.GA4697@quad
The nfsservctl system call is now gone, so we should remove all
linkage for it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
omap-serial: Allow IXON and IXOFF to be disabled.
TTY: serial, document ignoring of uart->ops->startup error
TTY: pty, fix pty counting
8250: Fix race condition in serial8250_backup_timeout().
serial/8250_pci: delete duplicate data definition
8250_pci: add support for Rosewill RC-305 4x serial port card
tty: Add "spi:" prefix for spi modalias
atmel_serial: fix atmel_default_console_device
serial: 8250_pnp: add Intermec CV60 touchscreen device
drivers/serial/ucc_uart.c: Fix compiler warning
pch_uart: Set PCIe bus number using probe parameter
serial: samsung: Fix build error
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
drivers:misc: ti-st: fix unexpected UART close
drivers:misc: ti-st: free skb on firmware download
drivers:misc: ti-st: wait for completion at fail
drivers:misc: ti-st: reinit completion before send
drivers:misc: ti-st: fail-safe on wrong pkt type
drivers:misc: ti-st: reinit completion on ver read
drivers:misc:ti-st: platform hooks for chip states
drivers:misc: ti-st: avoid a misleading dbg msg
base/devres.c: quiet sparse noise about context imbalance
pti: add missing CONFIG_PCI dependency
drivers/base/devtmpfs.c: correct annotation of `setup_done'
driver core: fix kernel-doc warning in platform.c
firmware: fix google/gsmi.c build warning
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
We need a callback to do some things after pwm_enable, pwm_disable
and pwm_config.
Signed-off-by: Dilan Lee <dilee@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Arun Murthy <arun.murthy@stericsson.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Replace/remove use of RIO v.1.2 registers/bits that are not
forward-compatible with newer versions of RapidIO specification.
RapidIO specification v.1.3 removed Write Port CSR, Doorbell CSR,
Mailbox CSR and Mailbox and Doorbell bits of the PEF CAR.
Use of removed (since RIO v.1.3) register bits affects users of
currently available 1.3 and 2.x compliant devices who may use not so
recent kernel versions.
Removing checks for unsupported bits makes corresponding routines
compatible with all versions of RapidIO specification. Therefore,
backporting makes stable kernel versions compliant with RIO v.1.3 and
later as well.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Thomas Moll <thomas.moll@sysgo.com>
Cc: Chul Kim <chul.kim@idt.com>
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net>
Purely in-memory filesystems do not use the inode hash as the dcache
tells us if an entry already exists. As a result, they do not call
unlock_new_inode, and thus directory inodes do not get put into a
different lockdep class for i_sem.
We need the different lockdep classes, because the locking order for
i_mutex is different for directory inodes and regular inodes. Directory
inodes can do "readdir()", which takes i_mutex *before* possibly taking
mm->mmap_sem (due to a page fault while copying the directory entry to
user space).
In contrast, regular inodes can be mmap'ed, which takes mm->mmap_sem
before accessing i_mutex.
The two cases can never happen for the same inode, so no real deadlock
can occur, but without the different lockdep classes, lockdep cannot
understand that. As a result, if CONFIG_DEBUG_LOCK_ALLOC is set, this
can lead to false positives from lockdep like below:
find/645 is trying to acquire lock:
(&mm->mmap_sem){++++++}, at: [<ffffffff81109514>] might_fault+0x5c/0xac
but task is already holding lock:
(&sb->s_type->i_mutex_key#15){+.+.+.}, at: [<ffffffff81149f34>]
vfs_readdir+0x5b/0xb4
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&sb->s_type->i_mutex_key#15){+.+.+.}:
[<ffffffff8108ac26>] lock_acquire+0xbf/0x103
[<ffffffff814db822>] __mutex_lock_common+0x4c/0x361
[<ffffffff814dbc46>] mutex_lock_nested+0x40/0x45
[<ffffffff811daa87>] hugetlbfs_file_mmap+0x82/0x110
[<ffffffff81111557>] mmap_region+0x258/0x432
[<ffffffff811119dd>] do_mmap_pgoff+0x2ac/0x306
[<ffffffff81111b4f>] sys_mmap_pgoff+0x118/0x16a
[<ffffffff8100c858>] sys_mmap+0x22/0x24
[<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b
-> #0 (&mm->mmap_sem){++++++}:
[<ffffffff8108a4bc>] __lock_acquire+0xa1a/0xcf7
[<ffffffff81109541>] might_fault+0x89/0xac
[<ffffffff81149cff>] filldir+0x6f/0xc7
[<ffffffff811586ea>] dcache_readdir+0x67/0x205
[<ffffffff81149f54>] vfs_readdir+0x7b/0xb4
[<ffffffff8114a073>] sys_getdents+0x7e/0xd1
This patch moves the directory vs file lockdep annotation into a helper
function that can be called by in-memory filesystems and has hugetlbfs
call it.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
