path: root/include
2014-06-05Merge branches 'alignment', 'fixes', 'l2c' (early part) and 'misc' into for-nextRussell King
2014-05-25ARM: 8043/1: uprobes need icache flush after xol writeVictor Kamensky
After instruction write into xol area, on ARM V7 architecture code need to flush dcache and icache to sync them up for given set of addresses. Having just 'flush_dcache_page(page)' call is not enough - it is possible to have stale instruction sitting in icache for given xol area slot address. Introduce arch_uprobe_ixol_copy weak function that by default calls uprobes copy_to_page function and than flush_dcache_page function and on ARM define new one that handles xol slot copy in ARM specific way flush_uprobe_xol_access function shares/reuses implementation with/of flush_ptrace_access function and takes care of writing instruction to user land address space on given variety of different cache types on ARM CPUs. Because flush_uprobe_xol_access does not have vma around flush_ptrace_access was split into two parts. First that retrieves set of condition from vma and common that receives those conditions as flags. Note ARM cache flush function need kernel address through which instruction write happened, so instead of using uprobes copy_to_page function changed code to explicitly map page and do memcpy. Note arch_uprobe_copy_ixol function, in similar way as copy_to_user_page function, has preempt_disable/preempt_enable. Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org> Acked-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: David A. Long <dave.long@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-25ARM: 8057/1: amba: Add Qualcomm vendor ID.srinik
This patch adds Qualcomm amba vendor Id to the list. This ID is used in mmci driver. The ID selected in same lines like 0x41 is "A" for ARM, 0x51 is "Q" for Qualcomm. As there are no physical register on Qcom SOC for amba vendor id, this is a fake ID assigned based on "Q" prefix from Qualcomm. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-22Merge branch 'renameat2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs Pull renameat2 arch support from Miklos Szeredi: "I've collected architecture patches for the renameat2 syscall that maintainers acked and/or asked me to queue. This adds architecture support for the renameat2 syscall to m68k, parisc, ia64 and through asm-generic to arc, arm64, c6x, hexagon, metag, openrisc, score, tile, unicore32" * 'renameat2' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: scripts/checksyscalls.sh: Make renameat optional asm-generic: Add renameat2 syscall ia64: add renameat2 syscall parisc: add renameat2 syscall m68k: add renameat2 syscall
2014-05-21Merge tag 'driver-core-3.15-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fixes from Greg KH: "Here are two driver core (well, sysfs) fixes for 3.15-rc6 that resolve some reported issues and a regression from 3.13" * tag 'driver-core-3.15-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: sysfs: make sure read buffer is zeroed kernfs, sysfs, cgroup: restrict extra perm check on open to sysfs
2014-05-21Merge branch 'for-3.15-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull more cgroup fixes from Tejun Heo: "Three more patches to fix cgroup_freezer breakage due to the recent cgroup internal locking changes - an operation cgroup_freezer was using now requires sleepable context and cgroup_freezer was invoking that while holding a spin lock. cgroup_freezer was using an overly elaborate hierarchical locking scheme. While it's possible to convert the hierarchical spinlocks directly to mutexes, this patch simplifies the overall locking so that it uses a global mutex. This has the added benefit of avoiding iterating potentially huge number of tasks under a spinlock. While the patch is on the larger side in the devel cycle, the changes made are mostly straight-forward and the locking logic is a lot simpler afterwards" * 'for-3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: fix rcu_read_lock() leak in update_if_frozen() cgroup_freezer: replace freezer->lock with freezer_mutex cgroup: introduce task_css_is_root()
2014-05-21Merge tag 'dt-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree fixes from Grant Likely: "Drivercore bugfixes for v3.15 This branch contains bug fixes important to get into v3.15. There is a fix for modifying properties seen during early boot, a fix for an incorrect prototype when CONFIG_OF=n, and a couple of corrections to device tree memory nodes on a few platforms" * tag 'dt-for-linus' of git://git.secretlab.ca/git/linux: mips: dts: Fix missing device_type="memory" property in memory nodes arm: dts: Fix missing device_type="memory" for ste-ccu8540 of: fix CONFIG_OF=n prototype of of_node_full_name() of: make of_update_property() usable earlier in the boot process
2014-05-20asm-generic: Add renameat2 syscallJames Hogan
Add the renameat2 syscall to the generic syscall list, which is used by the following architectures: arc, arm64, c6x, hexagon, metag, openrisc, score, tile, unicore32. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: linux-arch@vger.kernel.org Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Cc: linux-metag@vger.kernel.org Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
2014-05-20Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "MIPS fixes for various loose ends: - Fix workarounds for R4000 erratum. - Patch up DEC, Siemens-Nixdorf and Loongson hardware support. - Wire up renameat2 syscall. - Delete unused file - it was causing false warnings from maintenance scripts. - Revert a patch because it's functionality is now implemented twice which causes superfluous /proc/cpuinfo output. - Fix a microMIPS regression" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: mm: Fix broken microMIPS kernel regression. MIPS: Add new AUDIT_ARCH token for the N32 ABI on MIPS64 MIPS: Wire up renameat2 syscall. MIPS: inst.h: Rename BITFIELD_FIELD to __BITFIELD_FIELD. MIPS: Remove file missed when removing rm9k support a while ago. MIPS/loongson2_cpufreq: Fix CPU clock rate setting MIPS: Loongson: No need to select GENERIC_HARDIRQS_NO__DO_IRQ MIPS: csum_partial.S CPU_DADDI_WORKAROUNDS bug fix MIPS: __strncpy_from_user_asm CPU_DADDI_WORKAROUNDS bug fix MIPS: __delay CPU_DADDI_WORKAROUNDS bug fix MIPS: DEC/SNI: O32 wrapper stack switching fixes MIPS: DEC: Bus error handler <asm/cpu-type.h> fixes MAINTAINERS: TURBOchannel: Update entry Revert "MIPS: MT: proc: Add support for printing VPE and TC ids"
2014-05-20Merge tag 'metag-for-v3.15-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull Metag architecture and related fixes from James Hogan: "Mostly fixes for metag and parisc relating to upgrowing stacks. - Fix missing compiler barriers in metag memory barriers. - Fix BUG_ON on metag when RLIMIT_STACK hard limit is increased beyond safe value. - Make maximum stack size configurable. This reduces the default user stack size back to 80MB (especially on parisc after their removal of _STK_LIM_MAX override). This only affects metag and parisc. - Remove metag _STK_LIM_MAX override to match other arches and follow parisc, now that it is safe to do so (due to the BUG_ON fix mentioned above). - Finally now that both metag and parisc _STK_LIM_MAX overrides have been removed, it makes sense to remove _STK_LIM_MAX altogether" * tag 'metag-for-v3.15-2' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: asm-generic: remove _STK_LIM_MAX metag: Remove _STK_LIM_MAX override parisc,metag: Do not hardcode maximum userspace stack size metag: Reduce maximum stack size to 256MB metag: fix memory barriers
2014-05-20Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "Two small updates from the irq departement: - Provide missing inline stub for a SMP only function - Add sub-maintainer for the drivers/irqchip/ part of the irq subsystem. YAY!" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: MAINTAINERS: Add co-maintainer for drivers/irqchip genirq: Provide irq_force_affinity fallback for non-SMP
2014-05-15of: fix CONFIG_OF=n prototype of of_node_full_name()Stephen Rothwell
Make the CONFIG_OF=n prototpe of of_node_full_name() mateh the CONFIG_OF=y version. Fixes compile warnings like this: sound/soc/soc-core.c: In function 'soc_check_aux_dev': sound/soc/soc-core.c:1667:3: warning: passing argument 1 of 'of_node_full_name' discards 'const' qualifier from pointer target type [enabled by default] codecname = of_node_full_name(aux_dev->codec_of_node); when CONFIG_OF is not defined. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2014-05-15asm-generic: remove _STK_LIM_MAXJames Hogan
_STK_LIM_MAX could be used to override the RLIMIT_STACK hard limit from an arch's include/uapi/asm-generic/resource.h file, but is no longer used since both parisc and metag removed the override. Therefore remove it entirely, setting the hard RLIMIT_STACK limit to RLIM_INFINITY directly in include/asm-generic/resource.h. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: linux-arch@vger.kernel.org Cc: Helge Deller <deller@gmx.de> Cc: John David Anglin <dave.anglin@bell.net>
2014-05-14MIPS: Add new AUDIT_ARCH token for the N32 ABI on MIPS64Markos Chandras
A MIPS64 kernel may support ELF files for all 3 MIPS ABIs (O32, N32, N64). Furthermore, the AUDIT_ARCH_MIPS{,EL}64 token does not provide enough information about the ABI for the 64-bit process. As a result of which, userland needs to use complex seccomp filters to decide whether a syscall belongs to the o32 or n32 or n64 ABI. Therefore, a new arch token for MIPS64/n32 is added so it can be used by seccomp to explicitely set syscall filters for this ABI. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: Paul Moore <pmoore@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: linux-mips@linux-mips.org Link: http://sourceforge.net/p/libseccomp/mailman/message/32239040/ Patchwork: https://patchwork.linux-mips.org/patch/6818/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-13cgroup: introduce task_css_is_root()Tejun Heo
Determining the css of a task usually requires RCU read lock as that's the only thing which keeps the returned css accessible till its reference is acquired; however, testing whether a task belongs to the root can be performed without dereferencing the returned css by comparing the returned pointer against the root one in init_css_set[] which never changes. Implement task_css_is_root() which can be invoked in any context. This will be used by the scheduled cgroup_freezer change. v2: cgroup no longer supports modular controllers. No need to export init_css_set. Pointed out by Li. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2014-05-13kernfs, sysfs, cgroup: restrict extra perm check on open to sysfsTejun Heo
The kernfs open method - kernfs_fop_open() - inherited extra permission checks from sysfs. While the vfs layer allows ignoring the read/write permissions checks if the issuer has CAP_DAC_OVERRIDE, sysfs explicitly denied open regardless of the cap if the file doesn't have any of the UGO perms of the requested access or doesn't implement the requested operation. It can be debated whether this was a good idea or not but the behavior is too subtle and dangerous to change at this point. After cgroup got converted to kernfs, this extra perm check also got applied to cgroup breaking libcgroup which opens write-only files with O_RDWR as root. This patch gates the extra open permission check with a new flag KERNFS_ROOT_EXTRA_OPEN_PERM_CHECK and enables it for sysfs. For sysfs, nothing changes. For cgroup, root now can perform any operation regardless of the permissions as it was before kernfs conversion. Note that kernfs still fails unimplemented operations with -EINVAL. While at it, add comments explaining KERNFS_ROOT flags. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Andrey Wagin <avagin@gmail.com> Tested-by: Andrey Wagin <avagin@gmail.com> Cc: Li Zefan <lizefan@huawei.com> References: http://lkml.kernel.org/g/CANaxB-xUm3rJ-Cbp72q-rQJO5mZe1qK6qXsQM=vh0U8upJ44+A@mail.gmail.com Fixes: 2bd59d48ebfb ("cgroup: convert to kernfs") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Seems like we've had more fixes than usual this release cycle, but there's nothing in particular that we're doing differently. Perhaps it's just one of those cycles where more people are finding more regressions (and/or that the latency of when people actually test what's been in the tree for a while is catching up so that we get the bug reports now). The bigger changes here are are for TI and Marvell platforms: * Timing changes for GPMC (generic localbus) on OMAP causing some largeish DTS deltas. * Fixes to window allocation on PCI for mvebu touching drivers/ stuff. Patches have acks from subsystem maintainers where needed. * A fix from Thomas for a botched DT conversion in drivers/edma. There's a handful of other fixes for the above platforms as well as sunxi, at91, i.MX. I also included a MAINTAINER update for Broadcom, and a trivial move of a binding doc. I know you said you'd be offline this week, but I might as well post it for when you return. :)" I'm not quite offline yet. Doing a few pulls in the last hour before my internet goes away.. * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (31 commits) MAINTAINERS: update Broadcom ARM tree location and add an SoC family ARM: dts: i.MX53: Fix ipu register space size ARM: dts: kirkwood: fix mislocated pcie-controller nodes ARM: sunxi: Enable GMAC in sunxi_defconfig ARM: common: edma: Fix xbar mapping ARM: sun7i: Fix i2c4 base address ARM: Kirkwood: T5325: Fix double probe of Codec ARM: mvebu: enable the SATA interface on Armada 375 DB ARM: mvebu: specify I2C bus frequency on Armada 370 DB ARM: mvebu: use qsgmii phy-mode for Armada XP GP interfaces ARM: mvebu: fix NOR bus-width in Armada XP OpenBlocks AX3 Device Tree ARM: mvebu: fix NOR bus-width in Armada XP DB Device Tree ARM: mvebu: fix NOR bus-width in Armada XP GP Device Tree ARM: dts: AM3517: Disable absent IPs inherited from OMAP3 ARM: dts: OMAP2: Fix interrupts for OMAP2420 mailbox ARM: dts: OMAP5: Add mailbox dt node to fix boot warning ARM: OMAP5: Switch to THUMB mode if needed on secondary CPU ARM: dts: am437x-gp-evm: Do not reset gpio5 ARM: dts: omap3-igep0020: use SMSC9221 timings PCI: mvebu: split PCIe BARs into multiple MBus windows when needed ...
2014-05-09Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "A somewhat unpleasantly large collection of small fixes. The big ones are the __visible tree sweep and a fix for 'earlyprintk=efi,keep'. It was using __init functions with predictably suboptimal results. Another key fix is a build fix which would produce output that simply would not decompress correctly in some configuration, due to the existing Makefiles picking up an unfortunate local label and mistaking it for the global symbol _end. Additional fixes include the handling of 64-bit numbers when setting the vdso data page (a latent bug which became manifest when i386 started exporting a vdso with time functions), a fix to the new MSR manipulation accessors which would cause features to not get properly unblocked, a build fix for 32-bit userland, and a few new platform quirks" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, vdso, time: Cast tv_nsec to u64 for proper shifting in update_vsyscall() x86: Fix typo in MSR_IA32_MISC_ENABLE_LIMIT_CPUID macro x86: Fix typo preventing msr_set/clear_bit from having an effect x86/intel: Add quirk to disable HPET for the Baytrail platform x86/hpet: Make boot_hpet_disable extern x86-64, build: Fix stack protector Makefile breakage with 32-bit userland x86/reboot: Add reboot quirk for Certec BPC600 asmlinkage: Add explicit __visible to drivers/*, lib/*, kernel/* asmlinkage, x86: Add explicit __visible to arch/x86/* asmlinkage: Revert "lto: Make asmlinkage __visible" x86, build: Don't get confused by local symbols x86/efi: earlyprintk=efi,keep fix
2014-05-08Merge tag 'trace-fixes-v3.15-rc4-v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fixes from Steven Rostedt: "This contains two fixes. The first is a long standing bug that causes bogus data to show up in the refcnt field of the module_refcnt tracepoint. It was introduced by a merge conflict resolution back in 2.6.35-rc days. The result should be 'refcnt = incs - decs', but instead it did 'refcnt = incs + decs'. The second fix is to a bug that was introduced in this merge window that allowed for a tracepoint funcs pointer to be used after it was freed. Moving the location of where the probes are released solved the problem" * tag 'trace-fixes-v3.15-rc4-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracepoint: Fix use of tracepoint funcs after rcu free trace: module: Maintain a valid user count
2014-05-08Merge tag 'mfd-mmc-fixes-3.15-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull mmc/rtsx revert from Lee Jones. * tag 'mfd-mmc-fixes-3.15-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: mmc: rtsx: Revert "mmc: rtsx: add support for pre_req and post_req"
2014-05-08trace: module: Maintain a valid user countRomain Izard
The replacement of the 'count' variable by two variables 'incs' and 'decs' to resolve some race conditions during module unloading was done in parallel with some cleanup in the trace subsystem, and was integrated as a merge. Unfortunately, the formula for this replacement was wrong in the tracing code, and the refcount in the traces was not usable as a result. Use 'count = incs - decs' to compute the user count. Link: http://lkml.kernel.org/p/1393924179-9147-1-git-send-email-romain.izard.pro@gmail.com Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: stable@vger.kernel.org # 2.6.35 Fixes: c1ab9cab7509 "merge conflict resolution" Signed-off-by: Romain Izard <romain.izard.pro@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-05-08mmc: rtsx: Revert "mmc: rtsx: add support for pre_req and post_req"Micky Ching
This reverts commit c42deffd5b53c9e583d83c7964854ede2f12410d. commit <mmc: rtsx: add support for pre_req and post_req> did use mutex_unlock() in tasklet, but mutex_unlock() can't be used in tasklet(atomic context). The driver needs to use mutex to avoid concurrency, so we can't use tasklet here, the patch need to be removed. The spinlock host->lock and pcr->lock may deadlock, one way to solve the deadlock is remove host->lock in sd_isr_done_transfer(), but if using workqueue the we can avoid using the spinlock and also avoid the problem. Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Acked-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-05-07Merge branch 'drm-radeon-mullins' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull radeon mullins support from Dave Airlie: "This is support for the new AMD mullins APU, it pretty much just adds support to the driver in the all the right places, and is pretty low risk wrt other GPUs" Oh well. I guess it ends up fitting under "support new hardware" for merging late. * 'drm-radeon-mullins' of git://people.freedesktop.org/~airlied/linux: drm/radeon: add pci ids for Mullins drm/radeon: add Mullins VCE support drm/radeon: modesetting updates for Mullins. drm/radeon: dpm updates for KV/KB drm/radeon: add Mullins dpm support. drm/radeon: add Mullins UVD support. drm/radeon: update cik init for Mullins. drm/radeon: add Mullins chip family
2014-05-07Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "radeon, i915 and nouveau fixes, all fixes for regressions or black screens, or possible oopses" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon: lower the ref * post PLL maximum drm/radeon: check that we have a clock before PLL setup drm/radeon: drm/radeon: add missing radeon_semaphore_free to error path drm/radeon: Fix num_banks calculation for SI agp: info leak in agpioc_info_wrap() drm/gm107/gr: bump attrib cb size quite a bit drm/nouveau: fix another lock unbalance in nouveau_crtc_page_flip drm/nouveau/bios: fix shadowing from PROM on big-endian systems drm/nouveau/acpi: allow non-optimus setups to load vbios from acpi drm/radeon/dp: check for errors in dpcd reads drm/radeon: avoid high jitter with small frac divs drm/radeon: check buffer relocation offset drm/radeon: use pflip irq on R600+ v2 drm/radeon/uvd: use lower clocks on old UVD to boot v2 drm/i915: don't try DP_LINK_BW_5_4 on HSW ULX drm/i915: Sanitize the enable_ppgtt module option once drm/i915: Break encoder->crtc link separately in intel_sanitize_crtc()
2014-05-07Merge branch 'mullins' of git://people.freedesktop.org/~deathsimple/linux ↵Dave Airlie
into drm-fixes Add Mullins chips support. * 'mullins' of git://people.freedesktop.org/~deathsimple/linux: drm/radeon: add pci ids for Mullins drm/radeon: add Mullins VCE support drm/radeon: modesetting updates for Mullins. drm/radeon: dpm updates for KV/KB drm/radeon: add Mullins dpm support. drm/radeon: add Mullins UVD support. drm/radeon: update cik init for Mullins. drm/radeon: add Mullins chip family
2014-05-07Merge tag 'topc/core-stuff-2014-05-05' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-fixes Some more i915 fixes. There's still some DP issues we are looking into, but wanted to get these moving. * tag 'topc/core-stuff-2014-05-05' of git://anongit.freedesktop.org/drm-intel: drm/i915: don't try DP_LINK_BW_5_4 on HSW ULX drm/i915: Sanitize the enable_ppgtt module option once drm/i915: Break encoder->crtc link separately in intel_sanitize_crtc()
2014-05-07genirq: Provide irq_force_affinity fallback for non-SMPArnd Bergmann
Patch 01f8fa4f01d "genirq: Allow forcing cpu affinity of interrupts" added an irq_force_affinity() function, and 30ccf03b4a6 "clocksource: Exynos_mct: Use irq_force_affinity() in cpu bringup" subsequently uses it. However, the driver can be used with CONFIG_SMP disabled, but the function declaration is only available for CONFIG_SMP, leading to this build error: drivers/clocksource/exynos_mct.c:431:3: error: implicit declaration of function 'irq_force_affinity' [-Werror=implicit-function-declaration] irq_force_affinity(mct_irqs[MCT_L0_IRQ + cpu], cpumask_of(cpu)); This patch introduces a dummy helper function for the non-SMP case that always returns success, to get rid of the build error. Since the patches causing the problem are marked for stable backports, this one should be as well. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/5619084.0zmrrIUZLV@wuerfel Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-05-06Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "13 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: agp: info leak in agpioc_info_wrap() fs/affs/super.c: bugfix / double free fanotify: fix -EOVERFLOW with large files on 64-bit slub: use sysfs'es release mechanism for kmem_cache revert "mm: vmscan: do not swap anon pages just because free+file is low" autofs: fix lockref lookup mm: filemap: update find_get_pages_tag() to deal with shadow entries mm/compaction: make isolate_freepages start at pageblock boundary MAINTAINERS: zswap/zbud: change maintainer email address mm/page-writeback.c: fix divide by zero in pos_ratio_polynom hugetlb: ensure hugepage access is denied if hugepages are not supported slub: fix memcg_propagate_slab_attrs drivers/rtc/rtc-pcf8523.c: fix month definition
2014-05-06slub: use sysfs'es release mechanism for kmem_cacheChristoph Lameter
debugobjects warning during netfilter exit: ------------[ cut here ]------------ WARNING: CPU: 6 PID: 4178 at lib/debugobjects.c:260 debug_print_object+0x8d/0xb0() ODEBUG: free active (active state 0) object type: timer_list hint: delayed_work_timer_fn+0x0/0x20 Modules linked in: CPU: 6 PID: 4178 Comm: kworker/u16:2 Tainted: G W 3.11.0-next-20130906-sasha #3984 Workqueue: netns cleanup_net Call Trace: dump_stack+0x52/0x87 warn_slowpath_common+0x8c/0xc0 warn_slowpath_fmt+0x46/0x50 debug_print_object+0x8d/0xb0 __debug_check_no_obj_freed+0xa5/0x220 debug_check_no_obj_freed+0x15/0x20 kmem_cache_free+0x197/0x340 kmem_cache_destroy+0x86/0xe0 nf_conntrack_cleanup_net_list+0x131/0x170 nf_conntrack_pernet_exit+0x5d/0x70 ops_exit_list+0x5e/0x70 cleanup_net+0xfb/0x1c0 process_one_work+0x338/0x550 worker_thread+0x215/0x350 kthread+0xe7/0xf0 ret_from_fork+0x7c/0xb0 Also during dcookie cleanup: WARNING: CPU: 12 PID: 9725 at lib/debugobjects.c:260 debug_print_object+0x8c/0xb0() ODEBUG: free active (active state 0) object type: timer_list hint: delayed_work_timer_fn+0x0/0x20 Modules linked in: CPU: 12 PID: 9725 Comm: trinity-c141 Not tainted 3.15.0-rc2-next-20140423-sasha-00018-gc4ff6c4 #408 Call Trace: dump_stack (lib/dump_stack.c:52) warn_slowpath_common (kernel/panic.c:430) warn_slowpath_fmt (kernel/panic.c:445) debug_print_object (lib/debugobjects.c:262) __debug_check_no_obj_freed (lib/debugobjects.c:697) debug_check_no_obj_freed (lib/debugobjects.c:726) kmem_cache_free (mm/slub.c:2689 mm/slub.c:2717) kmem_cache_destroy (mm/slab_common.c:363) dcookie_unregister (fs/dcookies.c:302 fs/dcookies.c:343) event_buffer_release (arch/x86/oprofile/../../../drivers/oprofile/event_buffer.c:153) __fput (fs/file_table.c:217) ____fput (fs/file_table.c:253) task_work_run (kernel/task_work.c:125 (discriminator 1)) do_notify_resume (include/linux/tracehook.h:196 arch/x86/kernel/signal.c:751) int_signal (arch/x86/kernel/entry_64.S:807) Sysfs has a release mechanism. Use that to release the kmem_cache structure if CONFIG_SYSFS is enabled. Only slub is changed - slab currently only supports /proc/slabinfo and not /sys/kernel/slab/*. We talked about adding that and someone was working on it. [akpm@linux-foundation.org: fix CONFIG_SYSFS=n build] [akpm@linux-foundation.org: fix CONFIG_SYSFS=n build even more] Signed-off-by: Christoph Lameter <cl@linux.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Greg KH <greg@kroah.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Pekka Enberg <penberg@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Bart Van Assche <bvanassche@acm.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06hugetlb: ensure hugepage access is denied if hugepages are not supportedNishanth Aravamudan
Currently, I am seeing the following when I `mount -t hugetlbfs /none /dev/hugetlbfs`, and then simply do a `ls /dev/hugetlbfs`. I think it's related to the fact that hugetlbfs is properly not correctly setting itself up in this state?: Unable to handle kernel paging request for data at address 0x00000031 Faulting instruction address: 0xc000000000245710 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=2048 NUMA pSeries .... In KVM guests on Power, in a guest not backed by hugepages, we see the following: AnonHugePages: 0 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 64 kB HPAGE_SHIFT == 0 in this configuration, which indicates that hugepages are not supported at boot-time, but this is only checked in hugetlb_init(). Extract the check to a helper function, and use it in a few relevant places. This does make hugetlbfs not supported (not registered at all) in this environment. I believe this is fine, as there are no valid hugepages and that won't change at runtime. [akpm@linux-foundation.org: use pr_info(), per Mel] [akpm@linux-foundation.org: fix build when HPAGE_SHIFT is undefined] Signed-off-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "dcache fixes + kvfree() (uninlined, exported by mm/util.c) + posix_acl bugfix from hch" The dcache fixes are for a subtle LRU list corruption bug reported by Miklos Szeredi, where people inside IBM saw list corruptions with the LTP/host01 test. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nick kvfree() from apparmor posix_acl: handle NULL ACL in posix_acl_equiv_mode dcache: don't need rcu in shrink_dentry_list() more graceful recovery in umount_collect() don't remove from shrink list in select_collect() dentry_kill(): don't try to remove from shrink list expand the call of dentry_lru_del() in dentry_kill() new helper: dentry_free() fold try_prune_one_dentry() fold d_kill() and d_free() fix races between __d_instantiate() and checks of dentry flags
2014-05-06nick kvfree() from apparmorAl Viro
too many places open-code it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse fixes from Miklos Szeredi: "This adds ctime update in the new cached writeback mode and also fixes/simplifies the mtime update handling. Support for rename flags (aka renameat2) is also added to the userspace API" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: add renameat2 support fuse: clear MS_I_VERSION fuse: clear FUSE_I_CTIME_DIRTY flag on setattr fuse: trust kernel i_ctime only fuse: remove .update_time fuse: allow ctime flushing to userspace fuse: fuse: add time_gran to INIT_OUT fuse: add .write_inode fuse: clean up fsync fuse: fuse: fallocate: use file_update_time() fuse: update mtime on open(O_TRUNC) in atomic_o_trunc mode fuse: update mtime on truncate(2) fuse: do not use uninitialized i_mode fuse: fix mtime update error in fsync fuse: check fallocate mode fuse: add __exit to fuse_ctl_cleanup
2014-05-06drm/radeon: add pci ids for MullinsSamuel Li
Signed-off-by: Samuel Li <samuel.li@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Christian König <christian.koenig@amd.com>
2014-05-05asmlinkage: Revert "lto: Make asmlinkage __visible"Andi Kleen
As requested by Linus, revert adding __visible to asmlinkage. Instead we add __visible explicitely to all the symbols that need it. This reverts commit 128ea04a9885af9629059e631ddf0cab4815b589. Link: http://lkml.kernel.org/r/1398984278-29319-2-git-send-email-andi@firstfloor.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-05-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) e1000e computes header length incorrectly wrt vlans, fix from Vlad Yasevich. 2) ns_capable() check in sock_diag netlink code, from Andrew Lutomirski. 3) Fix invalid queue pairs handling in virtio_net, from Amos Kong. 4) Checksum offloading busted in sxgbe driver due to incorrect descriptor layout, fix from Byungho An. 5) Fix build failure with SMC_DEBUG set to 2 or larger, from Zi Shen Lim. 6) Fix uninitialized A and X registers in BPF interpreter, from Alexei Starovoitov. 7) Fix arch dependencies of candence driver. 8) Fix netlink capabilities checking tree-wide, from Eric W Biederman. 9) Don't dump IFLA_VF_PORTS if netlink request didn't ask for it in IFLA_EXT_MASK, from David Gibson. 10) IPV6 FIB dump restart doesn't handle table changes that happen meanwhile, causing the code to loop forever or emit dups, fix from Kumar Sandararajan. 11) Memory leak on VF removal in bnx2x, from Yuval Mintz. 12) Bug fixes for new Altera TSE driver from Vince Bridgers. 13) Fix route lookup key in SCTP, from Xugeng Zhang. 14) Use BH blocking spinlocks in SLIP, as per a similar fix to CAN/SLCAN driver. From Oliver Hartkopp. 15) TCP doesn't bump retransmit counters in some code paths, fix from Eric Dumazet. 16) Clamp delayed_ack in tcp_cubic to prevent theoretical divides by zero. Fix from Liu Yu. 17) Fix locking imbalance in error paths of HHF packet scheduler, from John Fastabend. 18) Properly reference the transport module when vsock_core_init() runs, from Andy King. 19) Fix buffer overflow in cdc_ncm driver, from Bjørn Mork. 20) IP_ECN_decapsulate() doesn't see a correct SKB network header in ip_tunnel_rcv(), fix from Ying Cai. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (132 commits) net: macb: Fix race between HW and driver net: macb: Remove 'unlikely' optimization net: macb: Re-enable RX interrupt only when RX is done net: macb: Clear interrupt flags net: macb: Pass same size to DMA_UNMAP as used for DMA_MAP ip_tunnel: Set network header properly for IP_ECN_decapsulate() e1000e: Restrict MDIO Slow Mode workaround to relevant parts e1000e: Fix issue with link flap on 82579 e1000e: Expand workaround for 10Mb HD throughput bug e1000e: Workaround for dropped packets in Gig/100 speeds on 82579 net/mlx4_core: Don't issue PCIe speed/width checks for VFs net/mlx4_core: Load the Eth driver first net/mlx4_core: Fix slave id computation for single port VF net/mlx4_core: Adjust port number in qp_attach wrapper when detaching net: cdc_ncm: fix buffer overflow Altera TSE: ALTERA_TSE should depend on HAS_DMA vsock: Make transport the proto owner net: sched: lock imbalance in hhf qdisc net: mvmdio: Check for a valid interrupt instead of an error net phy: Check for aneg completion before setting state to PHY_RUNNING ...
2014-05-05Merge tag 'tty-3.15-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg KH: "Here are some tty and serial driver fixes for things reported recently" * tag 'tty-3.15-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: Fix lockless tty buffer race Revert "tty: Fix race condition between __tty_buffer_request_room and flush_to_ldisc" drivers/tty/hvc: don't free hvc_console_setup after init n_tty: Fix n_tty_write crash when echoing in raw mode tty: serial: 8250_core.c Bug fix for Exar chips.
2014-05-05vsock: Make transport the proto ownerAndy King
Right now the core vsock module is the owner of the proto family. This means there's nothing preventing the transport module from unloading if there are open sockets, which results in a panic. Fix that by allowing the transport to be the owner, which will refcount it properly. Includes version bump to 1.0.1.0-k Passes checkpatch this time, I swear... Acked-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Andy King <acking@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-04Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: "These are mostly arm64 fixes with an additional arm(64) platform fix for the initialisation of vexpress clocks (the latter only affecting arm64; the arch/arm64 code is SoC agnostic and does not rely on early SoC-specific calls) - vexpress platform clocks initialisation moved earlier following the arm64 move of of_clk_init() call in a previous commit - Default DMA ops changed to non-coherent to preserve compatibility with 32-bit ARM DT files. The "dma-coherent" property can be used to explicitly mark a device coherent. The Applied Micro DT file has been updated to avoid DMA cache maintenance for the X-Gene SATA controller (the only arm64 related driver with such assumption in -rc mainline) - Fixmap correction for earlyprintk - kern_addr_valid() fix for huge pages" * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: vexpress: Initialise the sysregs before setting up the clocks arm64: Mark the Applied Micro X-Gene SATA controller as DMA coherent arm64: Use bus notifiers to set per-device coherent DMA ops arm64: Make default dma_ops to be noncoherent arm64: fixmap: fix missing sub-page offset for earlyprintk arm64: Fix for the arm64 kern_addr_valid() function
2014-05-03Revert "tty: Fix race condition between __tty_buffer_request_room and ↵Peter Hurley
flush_to_ldisc" This reverts commit 6a20dbd6caa2358716136144bf524331d70b1e03. Although the commit correctly identifies an unsafe race condition between __tty_buffer_request_room() and flush_to_ldisc(), the commit fixes the race with an unnecessary spinlock in a lockless algorithm. The follow-on commit, "tty: Fix lockless tty buffer race" fixes the race locklessly. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-03arm64: fixmap: fix missing sub-page offset for earlyprintkMarc Zyngier
Commit d57c33c5daa4 (add generic fixmap.h) added (among other similar things) set_fixmap_io to deal with early ioremap of devices. More recently, commit bf4b558eba92 (arm64: add early_ioremap support) converted the arm64 earlyprintk to use set_fixmap_io. A side effect of this conversion is that my virtual machines have stopped booting when I pass "earlyprintk=uart8250-8bit,0x3f8" to the guest kernel. Turns out that the new earlyprintk code doesn't care at all about sub-page offsets, and just assumes that the earlyprintk device will be page-aligned. Obviously, that doesn't play well with the above example. Further investigation shows that set_fixmap_io uses __set_fixmap instead of __set_fixmap_offset. A fix is to introduce a set_fixmap_offset_io that uses the latter, and to remove the superflous call to fix_to_virt (which only returns the value that set_fixmap_io has already given us). With this applied, my VMs are back in business. Tested on a Cortex-A57 platform with kvmtool as platform emulation. Cc: Will Deacon <will.deacon@arm.com> Acked-by: Mark Salter <msalter@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-05-03Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "This udpate delivers: - A fix for dynamic interrupt allocation on x86 which is required to exclude the GSI interrupts from the dynamic allocatable range. This was detected with the newfangled tablet SoCs which have GPIOs and therefor allocate a range of interrupts. The MSI allocations already excluded the GSI range, so we never noticed before. - The last missing set_irq_affinity() repair, which was delayed due to testing issues - A few bug fixes for the armada SoC interrupt controller - A memory allocation fix for the TI crossbar interrupt controller - A trivial kernel-doc warning fix" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: irq-crossbar: Not allocating enough memory irqchip: armanda: Sanitize set_irq_affinity() genirq: x86: Ensure that dynamic irq allocation does not conflict linux/interrupt.h: fix new kernel-doc warnings irqchip: armada-370-xp: Fix releasing of MSIs irqchip: armada-370-xp: implement the ->check_device() msi_chip operation irqchip: armada-370-xp: fix invalid cast of signed value into unsigned variable
2014-05-01Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module fixes from Rusty Russell: "Fixed one missing place for the new taint flag, and remove a warning giving only false positives (now we finally figured out why)" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: remove warning about waiting module removal. Fix: tracing: use 'E' instead of 'X' for unsigned module taint flag
2014-05-01word-at-a-time: simplify big-endian zero_bytemask macroH. Peter Anvin
This is simpler and cleaner. Depending on architecture, a smart compiler may or may not generate the same code. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-01dentry_kill(): don't try to remove from shrink listAl Viro
If the victim in on the shrink list, don't remove it from there. If shrink_dentry_list() manages to remove it from the list before we are done - fine, we'll just free it as usual. If not - mark it with new flag (DCACHE_MAY_FREE) and leave it there. Eventually, shrink_dentry_list() will get to it, remove the sucker from shrink list and call dentry_kill(dentry, 0). Which is where we'll deal with freeing. Since now dentry_kill(dentry, 0) may happen after or during dentry_kill(dentry, 1), we need to recognize that (by seeing DCACHE_DENTRY_KILLED already set), unlock everything and either free the sucker (in case DCACHE_MAY_FREE has been set) or leave it for ongoing dentry_kill(dentry, 1) to deal with. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-30drm/i915: don't try DP_LINK_BW_5_4 on HSW ULXPaulo Zanoni
Because the docs say ULX doesn't support it on HSW. Reviewed-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2014-04-28Merge tag 'trace-fixes-v3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ftrace bugfix from Steven Rostedt: "Takao Indoh reported that he was able to cause a ftrace bug while loading a module and enabling function tracing at the same time. He uncovered a race where the module when loaded will convert the calls to mcount into nops, and expects the module's text to be RW. But when function tracing is enabled, it will convert all kernel text (core and module) from RO to RW to convert the nops to calls to ftrace to record the function. After the convertion, it will convert all the text back from RW to RO. The issue is, it will also convert the module's text that is loading. If it converts it to RO before ftrace does its conversion, it will cause ftrace to fail and require a reboot to fix it again. This patch moves the ftrace module update that converts calls to mcount into nops to be done when the module state is still MODULE_STATE_UNFORMED. This will ignore the module when the text is being converted from RW back to RO" * tag 'trace-fixes-v3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ftrace/module: Hardcode ftrace_module_init() call into load_module()
2014-04-28Merge tag 'dt-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull devicetree bug fixes from Grant Likely: "These are some important bug fixes that need to get into v3.15. This branch contains a pair of important bug fixes for the DT code: - Fix some incorrect binding property names before they enter common usage - Fix bug where some platform devices will be unable to get their interrupt number when they depend on an interrupt controller that is not available at device creation time. This is a problem causing mainline to fail on a number of ARM platforms" * tag 'dt-for-linus' of git://git.secretlab.ca/git/linux: of/irq: do irq resolution in platform_get_irq of: selftest: add deferred probe interrupt test dt: Fix binding typos in clock-names and interrupt-names
2014-04-28fuse: add renameat2 supportMiklos Szeredi
Support RENAME_EXCHANGE and RENAME_NOREPLACE flags on the userspace ABI. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-04-28ftrace/module: Hardcode ftrace_module_init() call into load_module()Steven Rostedt (Red Hat)
A race exists between module loading and enabling of function tracer. CPU 1 CPU 2 ----- ----- load_module() module->state = MODULE_STATE_COMING register_ftrace_function() mutex_lock(&ftrace_lock); ftrace_startup() update_ftrace_function(); ftrace_arch_code_modify_prepare() set_all_module_text_rw(); <enables-ftrace> ftrace_arch_code_modify_post_process() set_all_module_text_ro(); [ here all module text is set to RO, including the module that is loading!! ] blocking_notifier_call_chain(MODULE_STATE_COMING); ftrace_init_module() [ tries to modify code, but it's RO, and fails! ftrace_bug() is called] When this race happens, ftrace_bug() will produces a nasty warning and all of the function tracing features will be disabled until reboot. The simple solution is to treate module load the same way the core kernel is treated at boot. To hardcode the ftrace function modification of converting calls to mcount into nops. This is done in init/main.c there's no reason it could not be done in load_module(). This gives a better control of the changes and doesn't tie the state of the module to its notifiers as much. Ftrace is special, it needs to be treated as such. The reason this would work, is that the ftrace_module_init() would be called while the module is in MODULE_STATE_UNFORMED, which is ignored by the set_all_module_text_ro() call. Link: http://lkml.kernel.org/r/1395637826-3312-1-git-send-email-indou.takao@jp.fujitsu.com Reported-by: Takao Indoh <indou.takao@jp.fujitsu.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@vger.kernel.org # 2.6.38+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
