Pull audit updates from Paul Moore:
"Another relatively small pull request for v4.9 with just two patches.
The patch from Richard updates the list of features we support and
report back to userspace; this should have been sent earlier with the
rest of the v4.8 patches but it got lost in my inbox.
The second patch fixes a problem reported by our Android friends where
we weren't very consistent in recording PIDs"
* 'stable-4.9' of git://git.infradead.org/users/pcmoore/audit:
audit: add exclude filter extension to feature bitmap
audit: consistently record PIDs with task_tgid_nr()
Add to the audit feature bitmap to indicate availability of the
extension of the exclude filter to include PID, UID, AUID, GID, SUBJ_*.
RFE: add additional fields for use in audit filter exclude rules
https://github.com/linux-audit/audit-kernel/issues/5
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
CALIPSO is a packet labelling protocol for IPv6 which is very similar
to CIPSO. It is specified in RFC 5570. Much of the code is based on
the current CIPSO code.
This adds support for adding passthrough-type CALIPSO DOIs through the
NLBL_CALIPSO_C_ADD command. It requires attributes:
NLBL_CALIPSO_A_TYPE which must be CALIPSO_MAP_PASS.
NLBL_CALIPSO_A_DOI.
In passthrough mode the CALIPSO engine will map MLS secattr levels
and categories directly to the packet label.
At this stage, the major difference between this and the CIPSO
code is that IPv6 may be compiled as a module. To allow for
this the CALIPSO functions are registered at module init time.
Signed-off-by: Huw Davies <huw@codeweavers.com>
Nothing prevents a new auditd starting up and replacing a valid
audit_pid when an old auditd is still running, effectively starving out
the old auditd since audit_pid no longer points to the old valid
auditd.
If no message to auditd has been attempted since auditd died
unnaturally or got killed, audit_pid will still indicate it is alive.
There isn't an easy way to detect if an old auditd is still running on
the existing audit_pid other than attempting to send a message to see
if it fails. An -ECONNREFUSED almost certainly means it disappeared
and can be replaced. Other errors are not so straightforward and may
indicate transient problems that will resolve themselves and the old
auditd will recover. Yet others will likely need manual intervention
for which a new auditd will not solve the problem.
Send a new message type (AUDIT_REPLACE) to the old auditd containing a
u32 with the PID of the new auditd. If the audit replace message
succeeds (or doesn't fail with certainty), fail to register the new
auditd and return an error (-EEXIST).
This is expected to make the patch preventing an old auditd orphaning a
new auditd redundant.
V3: Switch audit message type from 1000 to 1300 block.
Signed-off-by: Paul Moore <pmoore@redhat.com>
Pull audit update from Paul Moore:
"This is one of the larger audit patchsets in recent history,
consisting of eight patches and almost 400 lines of changes.
The bulk of the patchset is the new "audit by executable"
functionality which allows admins to set an audit watch based on the
executable on disk. Prior to this, admins could only track an
application by PID, which has some obvious limitations.
Beyond the new functionality we also have some refcnt fixes and a few
minor cleanups"
* 'upstream' of git://git.infradead.org/users/pcmoore/audit:
fixup: audit: implement audit by executable
audit: clean simple fsnotify implementation
audit: use macros for unset inode and device values
audit: make audit_del_rule() more robust
audit: fix uninitialized variable in audit_add_rule()
audit: eliminate unnecessary extra layer of watch parent references
audit: eliminate unnecessary extra layer of watch references
This adds the ability audit the actions of a not-yet-running process.
This patch implements the ability to filter on the executable path. Instead of
just hard coding the ino and dev of the executable we care about at the moment
the rule is inserted into the kernel, use the new audit_fsnotify
infrastructure to manage this dynamically. This means that if the filename
does not yet exist but the containing directory does, or if the inode in
question is unlinked and creat'd (aka updated) the rule will just continue to
work. If the containing directory is moved or deleted or the filesystem is
unmounted, the rule is deleted automatically. A future enhancement would be to
have the rule survive across directory disruptions.
This is a heavily modified version of a patch originally submitted by Eric
Paris with some ideas from Peter Moody.
Cc: Peter Moody <peter@hda3.com>
Cc: Eric Paris <eparis@redhat.com>
[PM: minor whitespace clean to satisfy ./scripts/checkpatch]
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux
Pull second batch of powerpc updates from Michael Ellerman:
"The highlight is the series that reworks the idle management on
powernv, which allows us to use deeper idle states on those machines.
There's the fix from Anton for the "BUG at kernel/smpboot.c:134!"
problem.
An i2c driver for powernv. This is acked by Wolfram Sang, and he
asked that we take it through the powerpc tree.
A fix for audit from rgb at Red Hat, acked by Paul Moore who is one of
the audit maintainers.
A patch from Ben to export the symbol map of our OPAL firmware as a
sysfs file, so that tools can use it.
Also some CXL fixes, a couple of powerpc perf fixes, a fix for
smt-enabled, and the patch to add __force to get_user() so we can use
bitwise types"
* tag 'powerpc-3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux:
powerpc/powernv: Ignore smt-enabled on Power8 and later
powerpc/uaccess: Allow get_user() with bitwise types
powerpc/powernv: Expose OPAL firmware symbol map
powernv/powerpc: Add winkle support for offline cpus
powernv/cpuidle: Redesign idle states management
powerpc/powernv: Enable Offline CPUs to enter deep idle states
powerpc/powernv: Switch off MMU before entering nap/sleep/rvwinkle mode
i2c: Driver to expose PowerNV platform i2c busses
powerpc: add little endian flag to syscall_get_arch()
power/perf/hv-24x7: Use kmem_cache_free() instead of kfree
powerpc/perf/hv-24x7: Use per-cpu page buffer
cxl: Unmap MMIO regions when detaching a context
cxl: Add timeout to process element commands
cxl: Change contexts_lock to a mutex to fix sleep while atomic bug
powerpc: Secondary CPUs must set cpu_callin_map after setting active and online
"Two small patches from the audit next branch; only one of which has
any real significant code changes, the other is simply a MAINTAINERS
update for audit.
The single code patch is pretty small and rather straightforward, it
changes the audit "version" number reported to userspace from an
integer to a bitmap which is used to indicate the functionality of the
running kernel. This really doesn't have much impact on the kernel,
but it will make life easier for the audit userspace folks.
Thankfully we were still on a version number which allowed us to do
this without breaking userspace"
audit: convert status version to a feature bitmap
audit: add Paul Moore to the MAINTAINERS entry
Since both ppc and ppc64 have LE variants which are now reported by uname, add
that flag (__AUDIT_ARCH_LE) to syscall_get_arch() and add AUDIT_ARCH_PPC64LE
variant.
Without this, perf trace and auditctl fail.
Mainline kernel reports ppc64le (per a058801) but there is no matching
AUDIT_ARCH_PPC64LE.
Since 32-bit PPC LE is not supported by audit, don't advertise it in
AUDIT_ARCH_PPC* variants.
See:
https://www.redhat.com/archives/linux-audit/2014-August/msg00082.html
https://www.redhat.com/archives/linux-audit/2014-December/msg00004.html
Acked-by: Paul Moore <paul@paul-moore.com>
The version field defined in the audit status structure was found to have
limitations in terms of its expressibility of features supported. This is
distict from the get/set features call to be able to command those features
that are present.
Converting this field from a version number to a feature bitmap will allow
distributions to selectively backport and support certain features and will
allow upstream to be able to deprecate features in the future. It will allow
userspace clients to first query the kernel for which features are actually
present and supported. Currently, EINVAL is returned rather than EOPNOTSUP,
which isn't helpful in determining if there was an error in the command, or if
it simply isn't supported yet. Past features are not represented by this
bitmap, but their use may be converted to EOPNOTSUP if needed in the future.
Since "version" is too generic to convert with a #define, use a union in the
struct status, introducing the member "feature_bitmap" unionized with
"version".
Convert existing AUDIT_VERSION_* macros over to AUDIT_FEATURE_BITMAP*
counterparts, leaving the former for backwards compatibility.
[PM: minor whitespace tweaks]
Pull audit updates from Eric Paris:
"So this change across a whole bunch of arches really solves one basic
problem. We want to audit when seccomp is killing a process. seccomp
hooks in before the audit syscall entry code. audit_syscall_entry
took as an argument the arch of the given syscall. Since the arch is
part of what makes a syscall number meaningful it's an important part
of the record, but it isn't available when seccomp shoots the
syscall...
For most arch's we have a better way to get the arch (syscall_get_arch)
So the solution was two fold: Implement syscall_get_arch() everywhere
there is audit which didn't have it. Use syscall_get_arch() in the
seccomp audit code. Having syscall_get_arch() everywhere meant it was
a useless flag on the stack and we could get rid of it for the typical
syscall entry.
The other changes inside the audit system aren't grand, fixed some
records that had invalid spaces. Better locking around the task comm
field. Removing some dead functions and structs. Make some things
static. Really minor stuff"
* git://git.infradead.org/users/eparis/audit: (31 commits)
audit: rename audit_log_remove_rule to disambiguate for trees
audit: cull redundancy in audit_rule_change
audit: WARN if audit_rule_change called illegally
audit: put rule existence check in canonical order
next: openrisc: Fix build
audit: get comm using lock to avoid race in string printing
audit: remove open_arg() function that is never used
audit: correct AUDIT_GET_FEATURE return message type
audit: set nlmsg_len for multicast messages.
audit: use union for audit_field values since they are mutually exclusive
audit: invalid op= values for rules
audit: use atomic_t to simplify audit_serial()
kernel/audit.c: use ARRAY_SIZE instead of sizeof/sizeof[0]
audit: reduce scope of audit_log_fcaps
audit: reduce scope of audit_net_id
audit: arm64: Remove the audit arch argument to audit_syscall_entry
arm64: audit: Add audit hook in syscall_trace_enter/exit()
audit: x86: drop arch from __audit_syscall_entry() interface
sparc: implement is_32bit_task
sparc: properly conditionalize use of TIF_32BIT
For all arches which support audit implement syscall_get_arch()
They are all pretty easy and straight forward, stolen from how the call
to audit_syscall_entry() determines the arch.
Based-on-patch-by: Richard Briggs <rgb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: linux-ia64@vger.kernel.org
Cc: microblaze-uclinux@itee.uq.edu.au
Cc: linux-mips@linux-mips.org
Cc: linux@lists.openrisc.net
Cc: linux-parisc@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
The kernel only uses struct audit_rule_data. We dropped support for
struct audit_rule a long time ago. Drop the definition in the header
file.
On AArch64, audit is supported through generic lib/audit.c and
compat_audit.c, and so this patch adds arch specific definitions required.
Acked-by Will Deacon <will.deacon@arm.com>
Acked-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
include/net/inetpeer.h
net/ipv6/output_core.c
Changes in net were fixing bugs in code removed in net-next.
drivers/net/bonding/bond_alb.c
drivers/net/ethernet/altera/altera_msgdma.c
drivers/net/ethernet/altera/altera_sgdma.c
net/ipv6/xfrm6_output.c
Several cases of overlapping changes.
The xfrm6_output.c has a bug fix which overlaps the renaming
of skb->local_df to skb->ignore_df.
In the Altera TSE driver cases, the register access cleanups
in net-next overlapped with bug fixes done in net.
Similarly a bug fix to send ALB packets in the bonding driver using
the right source address overlaps with cleanups in net-next.
Missing a "|" in AUDIT_ARCH_MIPSEL64N32 macro definition.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Reviewed-by: Markos Chandras <markos.chandras@imgtec.com>
Cc: John Crispin <john@phrozen.org>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: Aurelien Jarno <aurelien@aurel32.net>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/6978/
A MIPS64 kernel may support ELF files for all 3 MIPS ABIs
(O32, N32, N64). Furthermore, the AUDIT_ARCH_MIPS{,EL}64 token
does not provide enough information about the ABI for the 64-bit
process. As a result of which, userland needs to use complex
seccomp filters to decide whether a syscall belongs to the o32 or n32
or n64 ABI. Therefore, a new arch token for MIPS64/n32 is added so it
can be used by seccomp to explicitely set syscall filters for this ABI.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Acked-by: Eric Paris <eparis@redhat.com>
Acked-by: Paul Moore <pmoore@redhat.com>
Link: http://sourceforge.net/p/libseccomp/mailman/message/32239040/
Patchwork: https://patchwork.linux-mips.org/patch/6818/
Add a netlink multicast socket with one group to kaudit for "best-effort"
delivery to read-only userspace clients such as systemd, in addition to the
existing bidirectional unicast auditd userspace client.
Currently, auditd is intended to use the CAP_AUDIT_CONTROL and CAP_AUDIT_WRITE
capabilities, but actually uses CAP_NET_ADMIN. The CAP_AUDIT_READ capability
is added for use by read-only AUDIT_NLGRP_READLOG netlink multicast group
clients to the kaudit subsystem.
This will safely give access to services such as systemd to consume audit logs
while ensuring write access remains restricted for integrity.
1000-1099 is for configuring things. So auditd ignored such messages.
This is about actually logging what was configured. Move it into the
range for such types of messages.
Reported-by: Steve Grubb <sgrubb@redhat.com>
We were exposing a function based on kernel config options to userspace.
This is wrong. Move it to the audit internal header.
Suggested-by: Chris Metcalf <cmetcalf@tilera.com>
lib/audit.c provides a generic function for auditing system calls.
This patch extends it for compat syscall support on bi-architectures
(32/64-bit) by adding lib/compat_audit.c.
What is required to support this feature are:
* add asm/unistd32.h for compat system call names
* select CONFIG_AUDIT_ARCH_COMPAT_GENERIC
During an audit event, cache and print the value of the process's
proctitle value (proc/<pid>/cmdline). This is useful in situations
where processes are started via fork'd virtual machines where the
comm field is incorrect. Often times, setting the comm field still
is insufficient as the comm width is not very wide and most
virtual machine "package names" do not fit. Also, during execution,
many threads have their comm field set as well. By tying it back to
the global cmdline value for the process, audit records will be more
complete in systems with these properties. An example of where this
is useful and applicable is in the realm of Android. With Android,
their is no fork/exec for VM instances. The bare, preloaded Dalvik
VM listens for a fork and specialize request. When this request comes
in, the VM forks, and the loads the specific application (specializing).
This was done to take advantage of COW and to not require a load of
basic packages by the VM on very app spawn. When this spawn occurs,
the package name is set via setproctitle() and shows up in procfs.
Many of these package names are longer then 16 bytes, the historical
width of task->comm. Having the cmdline in the audit records will
couple the application back to the record directly. Also, on my
Debian development box, some audit records were more useful then
what was printed under comm.
The cached proctitle is tied to the life-cycle of the audit_context
structure and is built on demand.
Proctitle is controllable by userspace, and thus should not be trusted.
It is meant as an aid to assist in debugging. The proctitle event is
emitted during syscall audits, and can be filtered with auditctl.
Example:
type=AVC msg=audit(1391217013.924:386): avc: denied { getattr } for pid=1971 comm="mkdir" name="/" dev="selinuxfs" ino=1 scontext=system_u:system_r:consolekit_t:s0-s0:c0.c255 tcontext=system_u:object_r:security_t:s0 tclass=filesystem
type=SYSCALL msg=audit(1391217013.924:386): arch=c000003e syscall=137 success=yes exit=0 a0=7f019dfc8bd7 a1=7fffa6aed2c0 a2=fffffffffff4bd25 a3=7fffa6aed050 items=0 ppid=1967 pid=1971 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="mkdir" exe="/bin/mkdir" subj=system_u:system_r:consolekit_t:s0-s0:c0.c255 key=(null)
type=UNKNOWN[1327] msg=audit(1391217013.924:386): proctitle=6D6B646972002D70002F7661722F72756E2F636F6E736F6C65
Acked-by: Steve Grubb <sgrubb@redhat.com> (wrt record formating)
Signed-off-by: William Roberts <wroberts@tresys.com>
Linux 3.13
include/net/xfrm.h
Simple merge where v3.13 removed 'extern' from definitions and the audit
tree did s/u32/unsigned int/ to the same definitions.
Give names to the audit versions. Just something for a userspace
programmer to know what the version provides.
reaahead-collector abuses the audit logging facility to discover which files
are accessed at boot time to make a pre-load list
Add a tuning option to audit_backlog_wait_time so that if auditd can't keep up,
or gets blocked, the callers won't be blocked.
Bump audit_status API version to "2".
Re-named confusing local variable names (status_set and status_get didn't agree
with their command type name) and reduced their scope.
Future-proof API changes by not depending on the exact size of the audit_status
struct and by adding an API version field.
"Nothing amazing. Formatting, small bug fixes, couple of fixes where
we didn't get records due to some old VFS changes, and a change to how
we collect execve info..."
Fixed conflict in fs/exec.c as per Eric and linux-next.
* git://git.infradead.org/users/eparis/audit: (28 commits)
audit: fix type of sessionid in audit_set_loginuid()
audit: call audit_bprm() only once to add AUDIT_EXECVE information
audit: move audit_aux_data_execve contents into audit_context union
audit: remove unused envc member of audit_aux_data_execve
audit: Kill the unused struct audit_aux_data_capset
audit: do not reject all AUDIT_INODE filter types
audit: suppress stock memalloc failure warnings since already managed
audit: log the audit_names record type
audit: add child record before the create to handle case where create fails
audit: use given values in tty_audit enable api
audit: use nlmsg_len() to get message payload length
audit: use memset instead of trying to initialize field by field
audit: fix info leak in AUDIT_GET requests
audit: update AUDIT_INODE filter rule to comparator function
audit: audit feature to set loginuid immutable
audit: audit feature to only allow unsetting the loginuid
audit: allow unsetting the loginuid (with priv)
audit: remove CONFIG_AUDIT_LOGINUID_IMMUTABLE
audit: loginuid functions coding style
selinux: apply selinux checks on new audit message types
This adds a new 'audit_feature' bit which allows userspace to set it
such that the loginuid is absolutely immutable, even if you have
CAP_AUDIT_CONTROL.
This is a new audit feature which only grants processes with
CAP_AUDIT_CONTROL the ability to unset their loginuid. They cannot
directly set it from a valid uid to another valid uid. The ability to
unset the loginuid is nice because a priviledged task, like that of
container creation, can unset the loginuid and then priv is not needed
inside the container when a login daemon needs to set the loginuid.
The audit_status structure was not designed with extensibility in mind.
Define a new AUDIT_SET_FEATURE message type which takes a new structure
of bits where things can be enabled/disabled/locked one at a time. This
structure should be able to grow in the future while maintaining forward
and backward compatibility (based loosly on the ideas from capabilities
and prctl)
This does not actually add any features, but is just infrastructure to
allow new on/off types of audit system features.
SFR reported this 2013-05-15:
> After merging the final tree, today's linux-next build (i386 defconfig)
> produced this warning:
> kernel/auditfilter.c: In function 'audit_data_to_entry':
> kernel/auditfilter.c:426:3: warning: this decimal constant is unsigned only
> in ISO C90 [enabled by default]
> Introduced by commit 780a7654cee8 ("audit: Make testing for a valid
> loginuid explicit") from Linus' tree.
Replace this decimal constant in the code with a macro to make it more readable
(add to the unsigned cast to quiet the warning).
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Messages of type AUDIT_USER_TTY were being formatted to 1024 octets,
truncating messages approaching MAX_AUDIT_MESSAGE_LENGTH (8970 octets).
Set the formatting to 8560 characters, given maximum estimates for prefix and
suffix budgets.
See the problem discussion:
https://www.redhat.com/archives/linux-audit/2009-January/msg00030.html
And the new size rationale:
https://www.redhat.com/archives/linux-audit/2013-September/msg00016.html
Test ~8k messages with:
auditctl -m "$(for i in $(seq -w 001 820);do echo -n "${i}0______";done)"
Reported-by: LC Bruzenak <lenny@magitekltd.com>
Reported-by: Justin Stephenson <jstephen@redhat.com>
With the architecture gone, any references to it are no longer needed.
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
audit rule additions containing "-F auid!=4294967295" were failing
with EINVAL because of a regression caused by e1760bd.
Apparently some userland audit rule sets want to know if loginuid uid
has been set and are using a test for auid != 4294967295 to determine
that.
In practice that is a horrible way to ask if a value has been set,
because it relies on subtle implementation details and will break
every time the uid implementation in the kernel changes.
So add a clean way to test if the audit loginuid has been set, and
silently convert the old idiom to the cleaner and more comprehensible
new idiom.
Cc: <stable@vger.kernel.org> # 3.7
Reported-By: Richard Guy Briggs <rgb@redhat.com>
Tested-by: Richard Guy Briggs <rgb@redhat.com>
Most commands are entered one line at a time and processed as complete lines
in non-canonical mode. Commands that interactively require a password, enter
canonical mode to do this while shutting off echo. This pair of features
(icanon and !echo) can be used to avoid logging passwords by audit while still
logging the rest of the command.
Adding a member (log_passwd) to the struct audit_tty_status passed in by
pam_tty_audit allows control of canonical mode without echo per task.
While the kernel internals want pt_regs (and so it includes
linux/ptrace.h), the user version of audit.h does not need it. So move
the include out of the uapi version.
This avoids issues where people want the audit defines and userland
ptrace api. Including both the kernel ptrace and the userland ptrace
headers can easily lead to failure.
The seccomp path was using AUDIT_ANOM_ABEND from when seccomp mode 1
could only kill a process. While we still want to make sure an audit
record is forced on a kill, this should use a separate record type since
seccomp mode 2 introduces other behaviors.
In the case of "handled" behaviors (process wasn't killed), only emit a
record if the process is under inspection. This change also fixes
userspace examination of seccomp audit events, since it was considered
malformed due to missing fields of the AUDIT_ANOM_ABEND event type.
Cc: Jeff Layton <jlayton@redhat.com>
Cc: Julien Tinnes <jln@google.com>
Acked-by: Will Drewry <wad@chromium.org>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
