path: root/include/trace/irq.h
2009-04-14tracing/events: move trace point headers into include/trace/eventsSteven Rostedt
Impact: clean up Create a sub directory in include/trace called events to keep the trace point headers in their own separate directory. Only headers that declare trace points should be defined in this directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing: create automated trace definesSteven Rostedt
This patch lowers the number of places a developer must modify to add new tracepoints. The current method to add a new tracepoint into an existing system is to write the trace point macro in the trace header with one of the macros TRACE_EVENT, TRACE_FORMAT or DECLARE_TRACE, then they must add the same named item into the C file with the macro DEFINE_TRACE(name) and then add the trace point. This change cuts out the needing to add the DEFINE_TRACE(name). Every file that uses the tracepoint must still include the trace/<type>.h file, but the one C file must also add a define before the including of that file. #define CREATE_TRACE_POINTS #include <trace/mytrace.h> This will cause the trace/mytrace.h file to also produce the C code necessary to implement the trace point. Note, if more than one trace/<type>.h is used to create the C code it is best to list them all together. #define CREATE_TRACE_POINTS #include <trace/foo.h> #include <trace/bar.h> #include <trace/fido.h> Thanks to Mathieu Desnoyers and Christoph Hellwig for coming up with the cleaner solution of the define above the includes over my first design to have the C code include a "special" header. This patch converts sched, irq and lockdep and skb to use this new method. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing: consolidate trace and trace_event headersSteven Rostedt
Impact: clean up Neil Horman (et. al.) criticized the way the trace events were broken up into two files. The reason for that was that ftrace needed to separate out the declarations from where the #include <linux/tracepoint.h> was used. It then dawned on me that the tracepoint.h header only needs to define the TRACE_EVENT macro if it is not already defined. The solution is simply to test if TRACE_EVENT is defined, and if it is not then the linux/tracepoint.h header can define it. This change consolidates all the <traces>.h and <traces>_event_types.h into the <traces>.h file. Reported-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Theodore Tso <tytso@mit.edu> Reported-by: Jiaying Zhang <jiayingz@google.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jason Baron <jbaron@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-02-26tracing, genirq: add irq enter and exit trace eventsJason Baron
Impact: add new tracepoints Add them to the generic IRQ code, that way every architecture gets these new tracepoints, not just x86. Using Steve's new 'TRACE_FORMAT', I can get function graph trace as follows using the original two IRQ tracepoints: 3) | handle_IRQ_event() { 3) | /* (irq_handler_entry) irq=28 handler=eth0 */ 3) | e1000_intr_msi() { 3) 2.460 us | __napi_schedule(); 3) 9.416 us | } 3) | /* (irq_handler_exit) irq=28 handler=eth0 return=handled */ 3) + 22.935 us | } Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mathieu Desnoyers <compudj@krystal.dyndns.org> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
