There are two small cleanups in this patch:
- p9_errstr2errno was declared twice - remove one declaration.
- A uint8_t type was mixed in, change it to u8 to match
with the rest of the type names and remove dependency.
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
Typo fixes and minor cleanups for v9fs
Signed-off-by: Rob Landley <rob@landley.net>
Reviewed-by: Venkateswararao Jujjuri (JV) <jvrao@linux.vnet.ibm.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits)
bnx2x: allow device properly initialize after hotplug
bnx2x: fix DMAE timeout according to hw specifications
bnx2x: properly handle CFC DEL in cnic flow
bnx2x: call dev_kfree_skb_any instead of dev_kfree_skb
net: filter: move forward declarations to avoid compile warnings
pktgen: refactor pg_init() code
pktgen: use vzalloc_node() instead of vmalloc_node() + memset()
net: skb_trim explicitely check the linearity instead of data_len
ipv4: Give backtrace in ip_rt_bug().
net: avoid synchronize_rcu() in dev_deactivate_many
net: remove synchronize_net() from netdev_set_master()
rtnetlink: ignore NETDEV_RELEASE and NETDEV_JOIN event
net: rename NETDEV_BONDING_DESLAVE to NETDEV_RELEASE
bridge: call NETDEV_JOIN notifiers when add a slave
netpoll: disable netpoll when enslave a device
macvlan: Forward unicast frames in bridge mode to lowerdev
net: Remove linux/prefetch.h include from linux/skbuff.h
ipv4: Include linux/prefetch.h in fib_trie.c
netlabel: Remove prefetches from list handlers.
drivers/net: add prefetch header for prefetch users
Fixed up prefetch parts: removed a few duplicate prefetch.h includes,
fixed the location of the igb prefetch.h, took my version of the
skbuff.h code without the extra parentheses etc.
Fix new kernel-doc Error and Warning in <net/mac80211.h>:
Error(linux-2.6.39-git5/include/net/mac80211.h:550): cannot understand prototype: 'struct ieee80211_sched_scan_ies '
Warning(linux-2.6.39-git5/include/net/mac80211.h:2289): No description found for parameter 'sta'
Trivial patch updating documentation in header files only.
Error handling of CAIF transmit errors was changed by commit:
caif: Don't resend if dev_queue_xmit fails.
This patch updates the documentation accordingly.
Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits)
Revert "rcu: Decrease memory-barrier usage based on semi-formal proof"
net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree
batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu
batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree()
batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu
net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu()
net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu()
net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu()
perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu()
perf,rcu: convert call_rcu(free_ctx) to kfree_rcu()
net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(net_generic_release) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu()
security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu()
net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu()
net,rcu: convert call_rcu(xps_map_release) to kfree_rcu()
net,rcu: convert call_rcu(rps_map_release) to kfree_rcu()
ipv6 has per device ICMP SNMP counters, taking too much space because
they use percpu storage.
needed size per device is :
(512+4)*sizeof(long)*number_of_possible_cpus*2
On a 32bit kernel, 16 possible cpus, this wastes more than 64kbytes of
memory per ipv6 enabled network device, taken in vmalloc pool.
Since ICMP messages are rare, just use shared counters (atomic_long_t)
Per network space ICMP counters are still using percpu memory, we might
also convert them to shared counters in a future patch.
CC: Denys Fedoryshchenko <denys@visp.net.lb>
This will next trickle down to rt_bind_peer().
This way the caller can get at the fully resolved fl4->{daddr,saddr}
etc.
It's way past it's usefulness. And this gets rid of a bunch
of stray ->rt_{dst,src} references.
Even the comment documenting the macro was inaccurate (stated
default was 1 when it's 0).
If reintroduced, it should be done properly, with dynamic debug
facilities.
drivers/net/vmxnet3/vmxnet3_ethtool.c
net/core/dev.c
If CONFIG_PROC_SYSCTL=n the building process fails:
ping.c:(.text+0x52af3): undefined reference to `inet_get_ping_group_range_net'
Moved inet_get_ping_group_range_net() to ping.c.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/iwlwifi/iwl-agn-tx.c
net/mac80211/sta_info.h
Currently the devices that have already stripped IEEE 802.11
header from the AMSDU SKB can not use ieee80211_amsdu_to_8023s
routine. This patch enhances ieee80211_amsdu_to_8023s() API by
changing mandatory removing of IEEE 802.11 header from AMSDU
to optional.
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
These definitions need to be exposed now that we can set the peer link
states via NL80211_ATTR_STA_PLINK_STATE. They were already being
(opaquely) reported by NL80211_STA_INFO_PLINK_STATE.
Signed-off-by: Javier Cardona <javier@cozybit.com>
Add the ability to advertise interface combinations in nl80211.
This allows the driver to indicate what the combinations are
that it supports. "Combinations" of just a single interface are
implicit, as previously. Note that cfg80211 will enforce that
the restrictions are met, but not for all drivers yet (once all
drivers are updated, we can remove the flag and enforce for all).
When no combinations are actually supported, an empty list will
be exported so that userspace can know if the kernel exported
this info or not (although it isn't clear to me what tools using
the info should do if the kernel didn't export it).
Since some interface types are purely virtual/software and don't
fit the restrictions, those are exposed in a new list of pure SW
types, not subject to restrictions. This mainly exists to handle
AP-VLAN and monitor interfaces in mac80211.
Do proper handling of dev_queue_xmit errors in order to
avoid double free of skb and leaks in error conditions.
In cfctrl pending requests are removed when CAIF Link layer goes down.
Use struct net to reference CAIF configuration object instead of static variables.
Refactor functions caif_connect_client, caif_disconnect_client and squach
files cfcnfg.c and caif_config_utils.
CAIF Socket Layer and ip-interface registers reference counters
in CAIF service layer. The functions sock_hold, sock_put and
dev_hold, dev_put are used by CAIF Stack to protect from freeing
memory while packets are in-flight.
Instead of having reference counts in caif service layers,
we hook into existing refcount handling in socket layer and netdevice.
Introduce Per-cpu reference for lower part of CAIF Stack.
Before freeing payload is disabled, synchronize_rcu() is called,
and then ref-count verified to be zero.
RCU read_lock and refcount is used to protect in-flight packets.
Use RCU and counters to manage freeing lower part of the CAIF stack if
CAIF-link layer is removed. Old solution based on delaying removal of
device is removed.
When CAIF link layer goes down the use of CAIF link layer is disabled
(by calling caif_set_phy_state()), but removal and freeing of the
lower part of the CAIF stack is done when Link layer is unregistered.
Replace spin_lock with rcu_read_lock when accessing lists to layers
and cache. While packets are in flight rcu_read_lock should not be held,
instead ref-counters are used in combination with RCU.
bridge: fix forwarding of IPv6
bonding,llc: Fix structure sizeof incompatibility for some PDUs
ipv6: restore correct ECN handling on TCP xmit
ne-h8300: Fix regression caused during net_device_ops conversion
hydra: Fix regression caused during net_device_ops conversion
zorro8390: Fix regression caused during net_device_ops conversion
sfc: Always map MCDI shared memory as uncacheable
ehea: Fix memory hotplug oops
libertas: fix cmdpendingq locking
iwlegacy: fix IBSS mode crashes
ath9k: Fix a warning due to a queued work during S3 state
mac80211: don't start the dynamic ps timer if not associated
Pass in the sk_buff so that we can fetch the necessary keys from
the packet header when working with input routes.
This patch adds IPPROTO_ICMP socket kind. It makes it possible to send
ICMP_ECHO messages and receive the corresponding ICMP_ECHOREPLY messages
without any special privileges. In other words, the patch makes it
possible to implement setuid-less and CAP_NET_RAW-less /bin/ping. In
order not to increase the kernel's attack surface, the new functionality
is disabled by default, but is enabled at bootup by supporting Linux
distributions, optionally with restriction to a group or a group range
(see below).
Similar functionality is implemented in Mac OS X:
http://www.manpagez.com/man/4/icmp/
A new ping socket is created with
socket(PF_INET, SOCK_DGRAM, PROT_ICMP)
Message identifiers (octets 4-5 of ICMP header) are interpreted as local
ports. Addresses are stored in struct sockaddr_in. No port numbers are
reserved for privileged processes, port 0 is reserved for API ("let the
kernel pick a free number"). There is no notion of remote ports, remote
port numbers provided by the user (e.g. in connect()) are ignored.
Data sent and received include ICMP headers. This is deliberate to:
1) Avoid the need to transport headers values like sequence numbers by
other means.
2) Make it easier to port existing programs using raw sockets.
ICMP headers given to send() are checked and sanitized. The type must be
ICMP_ECHO and the code must be zero (future extensions might relax this,
see below). The id is set to the number (local port) of the socket, the
checksum is always recomputed.
ICMP reply packets received from the network are demultiplexed according
to their id's, and are returned by recv() without any modifications.
IP header information and ICMP errors of those packets may be obtained
via ancillary data (IP_RECVTTL, IP_RETOPTS, and IP_RECVERR). ICMP source
quenches and redirects are reported as fake errors via the error queue
(IP_RECVERR); the next hop address for redirects is saved to ee_info (in
network order).
socket(2) is restricted to the group range specified in
"/proc/sys/net/ipv4/ping_group_range". It is "1 0" by default, meaning
that nobody (not even root) may create ping sockets. Setting it to "100
100" would grant permissions to the single group (to either make
/sbin/ping g+s and owned by this group or to grant permissions to the
"netadmins" group), "0 4294967295" would enable it for the world, "100
4294967295" would enable it for the users, but not daemons.
The existing code might be (in the unlikely case anyone needs it)
extended rather easily to handle other similar pairs of ICMP messages
(Timestamp/Reply, Information Request/Reply, Address Mask Request/Reply
etc.).
Userspace ping util & patch for it:
http://openwall.info/wiki/people/segoon/ping
For Openwall GNU/*/Linux it was the last step on the road to the
setuid-less distro. A revision of this patch (for RHEL5/OpenVZ kernels)
is in use in Owl-current, such as in the 2011/03/12 LiveCD ISOs:
http://mirrors.kernel.org/openwall/Owl/current/iso/
Initially this functionality was written by Pavel Kankovsky for
Linux 2.4.32, but unfortunately it was never made public.
All ping options (-b, -p, -Q, -R, -s, -t, -T, -M, -I), are tested with
the patch.
PATCH v3:
- switched to flowi4.
- minor changes to be consistent with raw sockets code.
PATCH v2:
- changed ping_debug() to pr_debug().
- removed CONFIG_IP_PING.
- removed ping_seq_fops.owner field (unused for procfs).
- switched to proc_net_fops_create().
- switched to %pK in seq_printf().
PATCH v1:
- fixed checksumming bug.
- CAP_NET_RAW may not create icmp sockets anymore.
RFC v2:
- minor cleanups.
- introduced sysctl'able group range to restrict socket(2).
With some combinations of arch/compiler (e.g. arm-linux-gcc) the sizeof
operator on structure returns value greater than expected. In cases when the
structure is used for mapping PDU fields it may lead to unexpected results
(such as holes and alignment problems in skb data). __packed prevents this
undesired behavior.
Signed-off-by: Vitalii Demianets <vitas@nppfactor.kiev.ua>
Since commit e9df2e8fd8fbc9 (Use appropriate sock tclass setting for
routing lookup) we lost ability to properly add ECN codemarks to ipv6
TCP frames.
It seems like TCP_ECN_send() calls INET_ECN_xmit(), which only sets the
ECN bit in the IPv4 ToS field (inet_sk(sk)->tos), but after the patch,
what's checked is inet6_sk(sk)->tclass, which is a completely different
field.
Close bug https://bugzilla.kernel.org/show_bug.cgi?id=34322
[Eric Dumazet] : added the INET_ECN_dontxmit() fix and replace macros
by inline functions for clarity.
Signed-off-by: Steinar H. Gunderson <sgunderson@bigfoot.com>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Remove all remaining references to rt->rt_{src,dst}
by using dest->dst_saddr to cache saddr (used for TUN mode).
For ICMP in FORWARD hook just restrict the rt_mode for NAT
to disable LOCALNODE. All other modes do not allow
IP_VS_RT_MODE_RDR, so we should be safe with the ICMP
forwarding. Using cp->daddr as replacement for rt_dst
is safe for all modes except BYPASS, even when cp->dest is
NULL because it is cp->daddr that is used to assign cp->dest
for sync-ed connections.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
When removing last vlan from a device, garp_uninit_applicant() calls
synchronize_rcu() to make sure no user can still manipulate struct
garp_applicant before we free it.
Use call_rcu() instead, as a step to further net_device dismantle
optimizations.
Add the temporary garp_cleanup_module() function to make sure no pending
call_rcu() are left at module unload time [ this will be removed when
kfree_rcu() is available ]
When sched_scan_stopped was called by the driver, mac80211 calls
cfg80211, which in turn was calling mac80211 back with a flag
"driver_initiated". This flag was used so that mac80211 would do the
necessary cleanup but would not call the driver. This was enough to
prevent the bounce back between the driver and mac80211, but not
between mac80211 and cfg80211.
To fix this, we now do the cleanup in mac80211 before calling
cfg80211. To help with locking issues, the workqueue was moved from
cfg80211 to mac80211.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Luciano Coelho <coelho@ti.com>
Multiple virtual AP interfaces can currently try
to use different beacon intervals, but that just
leads to problems since it won't actually be done
that way by drivers. Return an error in this case
to make sure it won't be done wrong.
Also, ignore attempts to change the DTIM period
or beacon interval during the lifetime of the BSS.
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-next-2.6
Introduce NL80211_ATTR_SCHED_SCAN_INTERVAL as a required attribute for
NL80211_CMD_START_SCHED_SCAN. This value informs the driver at which
intervals the scheduled scan cycles should be executed.
Implement support for HW scheduled scan. The mac80211 code doesn't perform
scheduled scans itself, but calls the driver to start and stop scheduled
scans.
This patch also creates a trace event class to be used by drv_hw_scan
and the new drv_sched_scan_start and drv_sched_stop functions, in
order to avoid duplicate code.
Implement new functionality for scheduled scan offload. With this feature we
can scan automatically at certain intervals.
The idea is that the hardware can perform scan automatically and filter on
desired results without waking up the host unnecessarily.
Add NL80211_CMD_START_SCHED_SCAN and NL80211_CMD_STOP_SCHED_SCAN
commands to the nl80211 interface. When results are available they are
reported by NL80211_CMD_SCHED_SCAN_RESULTS events. The userspace is
informed when the scheduled scan has stopped with a
NL80211_CMD_SCHED_SCAN_STOPPED event, which can be triggered either by
the driver or by a call to NL80211_CMD_STOP_SCHED_SCAN.
Introduce a new configuration option to support AMPE from userspace.
Prior to this series we only supported authentication in userspace: an
authentication daemon would authenticate peer candidates in userspace
and hand them over to the kernel. From that point the mesh stack would
take over and establish a peer link (Mesh Peering Management).
These patches introduce support for Authenticated Mesh Peering Exchange
in userspace. The userspace daemon implements the AMPE protocol and on
successfull completion create mesh peers and install encryption keys.
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6
drivers/net/benet/be_main.c
In case of pre v2.1 devices authentication request will return
success immediately if the link key already exists without any
authentication process.
That means, it's not possible to re-authenticate the link if you
already have combination key and for instance want to re-authenticate
to get the high security (use 16 digit pin).
Therefore, it's necessary to check security requirements on auth
complete event to prevent not enough secure connection.
Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
slcan: fix ldisc->open retval
net/usb: mark LG VL600 LTE modem ethernet interface as WWAN
xfrm: Don't allow esn with disabled anti replay detection
xfrm: Assign the inner mode output function to the dst entry
net: dev_close() should check IFF_UP
vlan: fix GVRP at dismantle time
netfilter: revert a2361c8735e07322023aedc36e4938b35af31eb0
netfilter: IPv6: fix DSCP mangle code
netfilter: IPv6: initialize TOS field in REJECT target module
IPVS: init and cleanup restructuring
IPVS: Change of socket usage to enable name space exit.
netfilter: ebtables: only call xt_compat_add_offset once per rule
netfilter: fix ebtables compat support
netfilter: ctnetlink: fix timestamp support for new conntracks
pch_gbe: support ML7223 IOH
PCH_GbE : Fixed the issue of checksum judgment
PCH_GbE : Fixed the issue of collision detection
NET: slip, fix ldisc->open retval
be2net: Fixed bugs related to PVID.
ehea: fix wrongly reported speed and port
As it is, we assign the outer modes output function to the dst entry
when we create the xfrm bundle. This leads to two problems on interfamily
scenarios. We might insert ipv4 packets into ip6_fragment when called
from xfrm6_output. The system crashes if we try to fragment an ipv4
packet with ip6_fragment. This issue was introduced with git commit
ad0081e4 (ipv6: Fragment locally generated tunnel-mode IPSec6 packets
as needed). The second issue is, that we might insert ipv4 packets in
netfilter6 and vice versa on interfamily scenarios.
With this patch we assign the inner mode output function to the dst entry
when we create the xfrm bundle. So xfrm4_output/xfrm6_output from the inner
mode is used and the right fragmentation and netfilter functions are called.
We switch then to outer mode with the output_finish functions.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
This eliminates an access to rt->rt_src.
- kenrel -> kernel
- whetehr -> whether
- ttt -> tt
- sss -> ss
DESCRIPTION
This patch tries to restore the initial init and cleanup
sequences that was before namspace patch.
Netns also requires action when net devices unregister
which has never been implemented. I.e this patch also
covers when a device moves into a network namespace,
and has to be released.
IMPLEMENTATION
The number of calls to register_pernet_device have been
reduced to one for the ip_vs.ko
Schedulers still have their own calls.
This patch adds a function __ip_vs_service_cleanup()
and an enable flag for the netfilter hooks.
The nf hooks will be enabled when the first service is loaded
and never disabled again, except when a namespace exit starts.
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
[horms@verge.net.au: minor edit to changelog]
Signed-off-by: Simon Horman <horms@verge.net.au>
