Some consumers of the netdev events API would like to know who is the
active slave when a NETDEV_CHANGEUPPER or NETDEV_BONDING_FAILOVER
events occur. For example, when managing RoCE GIDs, GIDs based on the
bond's ips should only be set on the port which corresponds to active
slave netdevice.
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
For loopback purposes, RoCE devices should have a default GID in the
port GID table, even when the interface is down. In order to do so,
we use the IPv6 link local address which would have been genenrated
for the related Ethernet netdevice when it goes up as a default GID.
addrconf_ifid_eui48 is used to gernerate this address, export it.
Since commit 55334a5db5cd ("net_sched: act: refuse to remove bound action
outside"), we end up with a wrong reference count for a tc action.
Test case 1:
FOO="1,6 0 0 4294967295,"
BAR="1,6 0 0 4294967294,"
tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 \
action bpf bytecode "$FOO"
tc actions show action bpf
action order 0: bpf bytecode '1,6 0 0 4294967295' default-action pipe
index 1 ref 1 bind 1
tc actions replace action bpf bytecode "$BAR" index 1
action order 0: bpf bytecode '1,6 0 0 4294967294' default-action pipe
index 1 ref 2 bind 1
tc actions replace action bpf bytecode "$FOO" index 1
index 1 ref 3 bind 1
Test case 2:
tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 action ok
tc actions show action gact
action order 0: gact action pass
random type none pass val 0
tc actions add action drop index 1
RTNETLINK answers: File exists [...]
What happens is that in tcf_hash_check(), we check tcf_common for a given
index and increase tcfc_refcnt and conditionally tcfc_bindcnt when we've
found an existing action. Now there are the following cases:
1) We do a late binding of an action. In that case, we leave the
tcfc_refcnt/tcfc_bindcnt increased and are done with the ->init()
handler. This is correctly handeled.
2) We replace the given action, or we try to add one without replacing
and find out that the action at a specific index already exists
(thus, we go out with error in that case).
In case of 2), we have to undo the reference count increase from
tcf_hash_check() in the tcf_hash_check() function. Currently, we fail to
do so because of the 'tcfc_bindcnt > 0' check which bails out early with
an -EPERM error.
Now, while commit 55334a5db5cd prevents 'tc actions del action ...' on an
already classifier-bound action to drop the reference count (which could
then become negative, wrap around etc), this restriction only accounts for
invocations outside a specific action's ->init() handler.
One possible solution would be to add a flag thus we possibly trigger
the -EPERM ony in situations where it is indeed relevant.
After the patch, above test cases have correct reference count again.
Fixes: 55334a5db5cd ("net_sched: act: refuse to remove bound action outside")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Reviewed-by: Cong Wang <cwang@twopensource.com>
Currently, tcp_recvmsg enters a busy loop in sk_wait_data if called
with flags = MSG_WAITALL | MSG_PEEK.
sk_wait_data waits for sk_receive_queue not empty, but in this case,
the receive queue is not empty, but does not contain any skb that we
can use.
Add a "last skb seen on receive queue" argument to sk_wait_data, so
that it sleeps until the receive queue has new skbs.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=99461
Link: https://sourceware.org/bugzilla/show_bug.cgi?id=18493
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1205258
Reported-by: Enrico Scholz <rh-bugzilla@ensc.de>
Reported-by: Dan Searle <dan@censornet.com>
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
We can simply remove the INET_FRAG_EVICTED flag to avoid all the flags
race conditions with the evictor and use a participation test for the
evictor list, when we're at that point (after inet_frag_kill) in the
timer there're 2 possible cases:
1. The evictor added the entry to its evictor list while the timer was
waiting for the chainlock
or
2. The timer unchained the entry and the evictor won't see it
In both cases we should be able to see list_evictor correctly due
to the sync on the chainlock.
Joint work with Florian Westphal.
Tested-by: Frank Schreuder <fschreuder@transip.nl>
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Followup patch will call it after inet_frag_queue was freed, so q->net
doesn't work anymore (but netf = q->net; free(q); mem_limit(netf) would).
commit 65ba1f1ec0eff ("inet: frags: fix a race between inet_evict_bucket
and inet_frag_kill") describes the bug, but the fix doesn't work reliably.
Problem is that ->flags member can be set on other cpu without chainlock
being held by that task, i.e. the RMW-Cycle can clear INET_FRAG_EVICTED
bit after we put the element on the evictor private list.
We can crash when walking the 'private' evictor list since an element can
be deleted from list underneath the evictor.
Join work with Nikolay Alexandrov.
Fixes: b13d3cbfb8e8 ("inet: frag: move eviction of queues to work queue")
Reported-by: Johan Schuijt <johan@transip.nl>
Signed-off-by: Nikolay Alexandrov <nikolay@cumulusnetworks.com>
Pablo Neira Ayuso says:
Netfilter/IPVS fixes for net
The following patchset contains ten Netfilter/IPVS fixes, they are:
1) Address refcount leak when creating an expectation from the ctnetlink
interface.
2) Fix bug splat in the IDLETIMER target related to sysfs, from Dmitry
Torokhov.
3) Resolve panic for unreachable route in IPVS with locally generated
traffic in the output path, from Alex Gartrell.
4) Fix wrong source address in rare cases for tunneled traffic in IPVS,
from Julian Anastasov.
5) Fix crash if scheduler is changed via ipvsadm -E, again from Julian.
6) Make sure skb->sk is unset for forwarded traffic through IPVS, again from
Alex Gartrell.
7) Fix crash with IPVS sync protocol v0 and FTP, from Julian.
8) Reset sender cpu for forwarded traffic in IPVS, also from Julian.
9) Allocate template conntracks through kmalloc() to resolve netns dependency
problems with the conntrack kmem_cache.
10) Fix zones with expectations that clash using the same tuple, from Joe
Stringer.
fib_select_default considers alternative routes only when
res->fi is for the first alias in res->fa_head. In the
common case this can happen only when the initial lookup
matches the first alias with highest TOS value. This
prevents the alternative routes to require specific TOS.
This patch solves the problem as follows:
- routes that require specific TOS should be returned by
fib_select_default only when TOS matches, as already done
in fib_table_lookup. This rule implies that depending on the
TOS we can have many different lists of alternative gateways
and we have to keep the last used gateway (fa_default) in first
alias for the TOS instead of using single tb_default value.
- as the aliases are ordered by many keys (TOS desc,
fib_priority asc), we restrict the possible results to
routes with matching TOS and lowest metric (fib_priority)
and routes that match any TOS, again with lowest metric.
For example, packet with TOS 8 can not use gw3 (not lowest
metric), gw4 (different TOS) and gw6 (not lowest metric),
all other gateways can be used:
tos 8 via gw1 metric 2 <--- res->fa_head and res->fi
tos 8 via gw2 metric 2
tos 8 via gw3 metric 3
tos 4 via gw4
tos 0 via gw5
tos 0 via gw6 metric 1
Reported-by: Hagen Paul Pfeifer <hagen@jauu.net>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Johannes Berg says:
Some fixes for the current cycle:
1. Arik introduced an rtnl-locked regulatory API to be able
to differentiate between place do/don't have the RTNL;
this fixes missing locking in some of the code paths
2. Two small mesh bugfixes from Bob, one to avoid treating
a certain malformed over-the-air frame and one to avoid
sending a garbage field over the air.
3. A fix for powersave during WoWLAN suspend from Krishna Chaitanya.
4. A fix for a powersave vs. aggregation teardown race, from Michal.
5. Thomas reduced the loglevel of CRDA messages to avoid spamming
the kernel log with mostly irrelevant information.
6. Tom fixed a dangling debugfs directory pointer that could cause
crashes if subsequent addition of the same interface to debugfs
failed for some reason.
7. A fix from myself for a list corruption issue in mac80211 during
combined interface shutdown/removal - shut down interfaces first
and only then remove them to avoid that.
Quoting Daniel Borkmann:
"When adding connection tracking template rules to a netns, f.e. to
configure netfilter zones, the kernel will endlessly busy-loop as soon
as we try to delete the given netns in case there's at least one
template present, which is problematic i.e. if there is such bravery that
the priviledged user inside the netns is assumed untrusted.
Minimal example:
ip netns add foo
ip netns exec foo iptables -t raw -A PREROUTING -d 1.2.3.4 -j CT --zone 1
ip netns del foo
What happens is that when nf_ct_iterate_cleanup() is being called from
nf_conntrack_cleanup_net_list() for a provided netns, we always end up
with a net->ct.count > 0 and thus jump back to i_see_dead_people. We
don't get a soft-lockup as we still have a schedule() point, but the
serving CPU spins on 100% from that point onwards.
Since templates are normally allocated with nf_conntrack_alloc(), we
also bump net->ct.count. The issue why they are not yet nf_ct_put() is
because the per netns .exit() handler from x_tables (which would eventually
invoke xt_CT's xt_ct_tg_destroy() that drops reference on info->ct) is
called in the dependency chain at a *later* point in time than the per
netns .exit() handler for the connection tracker.
This is clearly a chicken'n'egg problem: after the connection tracker
.exit() handler, we've teared down all the connection tracking
infrastructure already, so rightfully, xt_ct_tg_destroy() cannot be
invoked at a later point in time during the netns cleanup, as that would
lead to a use-after-free. At the same time, we cannot make x_tables depend
on the connection tracker module, so that the xt_ct_tg_destroy() would
be invoked earlier in the cleanup chain."
Daniel confirms this has to do with the order in which modules are loaded or
having compiled nf_conntrack as modules while x_tables built-in. So we have no
guarantees regarding the order in which netns callbacks are executed.
Fix this by allocating the templates through kmalloc() from the respective
SYNPROXY and CT targets, so they don't depend on the conntrack kmem cache.
Then, release then via nf_ct_tmpl_free() from destroy_conntrack(). This branch
is marked as unlikely since conntrack templates are rarely allocated and only
from the configuration plane path.
Note that templates are not kept in any list to avoid further dependencies with
nf_conntrack anymore, thus, the tmpl larval list is removed.
Reported-by: Daniel Borkmann <daniel@iogearbox.net>
Tested-by: Daniel Borkmann <daniel@iogearbox.net>
The RTNL is required to check for IR-relaxation conditions that allow
more channels to beacon. Export an RTNL locked version of reg_can_beacon
and use it where possible in AP/STA interface type flows, where
IR-relaxation may be applicable.
Fixes: 06f207fc5418 ("cfg80211: change GO_CONCURRENT to IR_CONCURRENT for STA")
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
ip6_datagram_connect() is doing a lot of socket changes without
socket being locked.
This looks wrong, at least for udp_lib_rehash() which could corrupt
lists because of concurrent udp_sk(sk)->udp_portaddr_hash accesses.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
No more users, so it can now be removed.
Just make a ax25_sock structure that provides the ax25_cb pointer.
Pull networking updates from David Miller:
1) Add TX fast path in mac80211, from Johannes Berg.
2) Add TSO/GRO support to ibmveth, from Thomas Falcon
3) Move away from cached routes in ipv6, just like ipv4, from Martin
KaFai Lau.
4) Lots of new rhashtable tests, from Thomas Graf.
5) Run ingress qdisc lockless, from Alexei Starovoitov.
6) Allow servers to fetch TCP packet headers for SYN packets of new
connections, for fingerprinting. From Eric Dumazet.
7) Add mode parameter to pktgen, for testing receive. From Alexei
Starovoitov.
8) Cache access optimizations via simplifications of build_skb(), from
Alexander Duyck.
9) Move page frag allocator under mm/, also from Alexander.
10) Add xmit_more support to hv_netvsc, from KY Srinivasan.
11) Add a counter guard in case we try to perform endless reclassify
loops in the packet scheduler.
12) Extern flow dissector to be programmable and use it in new "Flower"
classifier. From Jiri Pirko.
13) AF_PACKET fanout rollover fixes, performance improvements, and new
statistics. From Willem de Bruijn.
14) Add netdev driver for GENEVE tunnels, from John W Linville.
15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso.
16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet.
17) Add an ECN retry fallback for the initial TCP handshake, from Daniel
Borkmann.
18) Add tail call support to BPF, from Alexei Starovoitov.
19) Add several pktgen helper scripts, from Jesper Dangaard Brouer.
20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa.
21) Favor even port numbers for allocation to connect() requests, and
odd port numbers for bind(0), in an effort to help avoid
ip_local_port_range exhaustion. From Eric Dumazet.
22) Add Cavium ThunderX driver, from Sunil Goutham.
23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata,
24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai.
25) Double TCP Small Queues default to 256K to accomodate situations
like the XEN driver and wireless aggregation. From Wei Liu.
26) Add more entropy inputs to flow dissector, from Tom Herbert.
27) Add CDG congestion control algorithm to TCP, from Kenneth Klette
Jonassen.
28) Convert ipset over to RCU locking, from Jozsef Kadlecsik.
29) Track and act upon link status of ipv4 route nexthops, from Andy
Gospodarek.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits)
bridge: vlan: flush the dynamically learned entries on port vlan delete
bridge: multicast: add a comment to br_port_state_selection about blocking state
net: inet_diag: export IPV6_V6ONLY sockopt
stmmac: troubleshoot unexpected bits in des0 & des1
net: ipv4 sysctl option to ignore routes when nexthop link is down
net: track link-status of ipv4 nexthops
net: switchdev: ignore unsupported bridge flags
net: Cavium: Fix MAC address setting in shutdown state
drivers: net: xgene: fix for ACPI support without ACPI
ip: report the original address of ICMP messages
net/mlx5e: Prefetch skb data on RX
net/mlx5e: Pop cq outside mlx5e_get_cqe
net/mlx5e: Remove mlx5e_cq.sqrq back-pointer
net/mlx5e: Remove extra spaces
net/mlx5e: Avoid TX CQE generation if more xmit packets expected
net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion
net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq()
net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them
net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues
net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device
drivers/net/ethernet/mellanox/mlx4/main.c
net/packet/af_packet.c
Both conflicts were cases of simple overlapping changes.
This feature is only enabled with the new per-interface or ipv4 global
sysctls called 'ignore_routes_with_linkdown'.
net.ipv4.conf.all.ignore_routes_with_linkdown = 0
net.ipv4.conf.default.ignore_routes_with_linkdown = 0
net.ipv4.conf.lo.ignore_routes_with_linkdown = 0
When the above sysctls are set, will report to userspace that a route is
dead and will no longer resolve to this nexthop when performing a fib
lookup. This will signal to userspace that the route will not be
selected. The signalling of a RTNH_F_DEAD is only passed to userspace
if the sysctl is enabled and link is down. This was done as without it
the netlink listeners would have no idea whether or not a nexthop would
be selected. The kernel only sets RTNH_F_DEAD internally if the
interface has IFF_UP cleared.
With the new sysctl set, the following behavior can be observed
(interface p8p1 is link-down):
default via 10.0.5.2 dev p9p1
10.0.5.0/24 dev p9p1 proto kernel scope link src 10.0.5.15
70.0.0.0/24 dev p7p1 proto kernel scope link src 70.0.0.1
80.0.0.0/24 dev p8p1 proto kernel scope link src 80.0.0.1 dead linkdown
90.0.0.0/24 via 80.0.0.2 dev p8p1 metric 1 dead linkdown
90.0.0.0/24 via 70.0.0.2 dev p7p1 metric 2
90.0.0.1 via 70.0.0.2 dev p7p1 src 70.0.0.1
cache
local 80.0.0.1 dev lo src 80.0.0.1
cache <local>
80.0.0.2 via 10.0.5.2 dev p9p1 src 10.0.5.15
cache
While the route does remain in the table (so it can be modified if
needed rather than being wiped away as it would be if IFF_UP was
cleared), the proper next-hop is chosen automatically when the link is
down. Now interface p8p1 is linked-up:
192.168.56.0/24 dev p2p1 proto kernel scope link src 192.168.56.2
90.0.0.1 via 80.0.0.2 dev p8p1 src 80.0.0.1
cache
cache <local>
cache
and the output changes to what one would expect.
If the sysctl is not set, the following output would be expected when
p8p1 is down:
80.0.0.0/24 dev p8p1 proto kernel scope link src 80.0.0.1 linkdown
90.0.0.0/24 via 80.0.0.2 dev p8p1 metric 1 linkdown
Since the dead flag does not appear, there should be no expectation that
the kernel would skip using this route due to link being down.
v2: Split kernel changes into 2 patches, this actually makes a
behavioral change if the sysctl is set. Also took suggestion from Alex
to simplify code by only checking sysctl during fib lookup and
suggestion from Scott to add a per-interface sysctl.
v3: Code clean-ups to make it more readable and efficient as well as a
reverse path check fix.
v4: Drop binary sysctl
v5: Whitespace fixups from Dave
v6: Style changes from Dave and checkpatch suggestions
v7: One more checkpatch fixup
Signed-off-by: Andy Gospodarek <gospo@cumulusnetworks.com>
Signed-off-by: Dinesh Dutt <ddutt@cumulusnetworks.com>
Acked-by: Scott Feldman <sfeldma@gmail.com>
Add a fib flag called RTNH_F_LINKDOWN to any ipv4 nexthops that are
reachable via an interface where carrier is off. No action is taken,
but additional flags are passed to userspace to indicate carrier status.
This also includes a cleanup to fib_disable_ip to more clearly indicate
what event made the function call to replace the more cryptic force
option previously used.
v2: Split out kernel functionality into 2 patches, this patch simply
sets and clears new nexthop flag RTNH_F_LINKDOWN.
v3: Cleanups suggested by Alex as well as a bug noticed in
fib_sync_down_dev and fib_sync_up when multipath was not enabled.
v5: Whitespace and variable declaration fixups suggested by Dave.
v6: Style fixups noticed by Dave; ran checkpatch to be sure I got them
all.
Use vid_begin/end to be consistent with BRIDGE_VLAN_INFO_RANGE_BEGIN/END.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
Add code to nf_unregister_hook to flush the nf_queue when a hook is
unregistered. This guarantees that the pointer that the nf_queue code
retains into the nf_hook list will remain valid while a packet is
queued.
I tested what would happen if we do not flush queued packets and was
trivially able to obtain the oops below. All that was required was
to stop the nf_queue listening process, to delete all of the nf_tables,
and to awaken the nf_queue listening process.
> BUG: unable to handle kernel paging request at 0000000100000001
> IP: [<0000000100000001>] 0x100000001
> PGD b9c35067 PUD 0
> Oops: 0010 [#1] SMP
> Modules linked in:
> CPU: 0 PID: 519 Comm: lt-nfqnl_test Not tainted
> task: ffff8800b9c8c050 ti: ffff8800ba9d8000 task.ti: ffff8800ba9d8000
> RIP: 0010:[<0000000100000001>] [<0000000100000001>] 0x100000001
> RSP: 0018:ffff8800ba9dba40 EFLAGS: 00010a16
> RAX: ffff8800bab48a00 RBX: ffff8800ba9dba90 RCX: ffff8800ba9dba90
> RDX: ffff8800b9c10128 RSI: ffff8800ba940900 RDI: ffff8800bab48a00
> RBP: ffff8800b9c10128 R08: ffffffff82976660 R09: ffff8800ba9dbb28
> R10: dead000000100100 R11: dead000000200200 R12: ffff8800ba940900
> R13: ffffffff8313fd50 R14: ffff8800b9c95200 R15: 0000000000000000
> FS: 00007fb91fc34700(0000) GS:ffff8800bfa00000(0000) knlGS:0000000000000000
> CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
> CR2: 0000000100000001 CR3: 00000000babfb000 CR4: 00000000000007f0
> Stack:
> ffffffff8206ab0f ffffffff82982240 ffff8800bab48a00 ffff8800b9c100a8
> ffff8800b9c10100 0000000000000001 ffff8800ba940900 ffff8800b9c10128
> ffffffff8206bd65 ffff8800bfb0d5e0 ffff8800bab48a00 0000000000014dc0
> Call Trace:
> [<ffffffff8206ab0f>] ? nf_iterate+0x4f/0xa0
> [<ffffffff8206bd65>] ? nf_reinject+0x125/0x190
> [<ffffffff8206dee5>] ? nfqnl_recv_verdict+0x255/0x360
> [<ffffffff81386290>] ? nla_parse+0x80/0xf0
> [<ffffffff8206c42c>] ? nfnetlink_rcv_msg+0x13c/0x240
> [<ffffffff811b2fec>] ? __memcg_kmem_get_cache+0x4c/0x150
> [<ffffffff8206c2f0>] ? nfnl_lock+0x20/0x20
> [<ffffffff82068159>] ? netlink_rcv_skb+0xa9/0xc0
> [<ffffffff820677bf>] ? netlink_unicast+0x12f/0x1c0
> [<ffffffff82067ade>] ? netlink_sendmsg+0x28e/0x650
> [<ffffffff81fdd814>] ? sock_sendmsg+0x44/0x50
> [<ffffffff81fde07b>] ? ___sys_sendmsg+0x2ab/0x2c0
> [<ffffffff810e8f73>] ? __wake_up+0x43/0x70
> [<ffffffff8141a134>] ? tty_write+0x1c4/0x2a0
> [<ffffffff81fde9f4>] ? __sys_sendmsg+0x44/0x80
> [<ffffffff823ff8d7>] ? system_call_fastpath+0x12/0x6a
> Code: Bad RIP value.
> RIP [<0000000100000001>] 0x100000001
> RSP <ffff8800ba9dba40>
> ---[ end trace 08eb65d42362793f ]---
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
Johan Hedberg says:
pull request: bluetooth-next 2015-06-18
Here's the final bluetooth-next pull request for 4.2.
- Cleanups & fixes to 802.15.4 code and related drivers
- Fix btusb driver memory leak
- New USB IDs for Atheros controllers
- Support for BCM4324B3 UART based Broadcom controller
- Fix for Bluetooth encryption key size handling
- Broadcom controller initialization fixes
- Support for Intel controller DDC parameters
- Support for multiple Bluetooth LE advertising instances
- Fix for HCI user channel cleanup path
Please let me know if there are any issues pulling. Thanks.
Pull crypto update from Herbert Xu:
"Here is the crypto update for 4.2:
API:
- Convert RNG interface to new style.
- New AEAD interface with one SG list for AD and plain/cipher text.
All external AEAD users have been converted.
- New asymmetric key interface (akcipher).
Algorithms:
- Chacha20, Poly1305 and RFC7539 support.
- New RSA implementation.
- Jitter RNG.
- DRBG is now seeded with both /dev/random and Jitter RNG. If kernel
pool isn't ready then DRBG will be reseeded when it is.
- DRBG is now the default crypto API RNG, replacing krng.
- 842 compression (previously part of powerpc nx driver).
Drivers:
- Accelerated SHA-512 for arm64.
- New Marvell CESA driver that supports DMA and more algorithms.
- Updated powerpc nx 842 support.
- Added support for SEC1 hardware to talitos"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (292 commits)
crypto: marvell/cesa - remove COMPILE_TEST dependency
crypto: algif_aead - Temporarily disable all AEAD algorithms
crypto: af_alg - Forbid the use internal algorithms
crypto: echainiv - Only hold RNG during initialisation
crypto: seqiv - Add compatibility support without RNG
crypto: eseqiv - Offer normal cipher functionality without RNG
crypto: chainiv - Offer normal cipher functionality without RNG
crypto: user - Add CRYPTO_MSG_DELRNG
crypto: user - Move cryptouser.h to uapi
crypto: rng - Do not free default RNG when it becomes unused
crypto: skcipher - Allow givencrypt to be NULL
crypto: sahara - propagate the error on clk_disable_unprepare() failure
crypto: rsa - fix invalid select for AKCIPHER
crypto: picoxcell - Update to the current clk API
crypto: nx - Check for bogus firmware properties
crypto: marvell/cesa - add DT bindings documentation
crypto: marvell/cesa - add support for Kirkwood and Dove SoCs
crypto: marvell/cesa - add support for Orion SoCs
crypto: marvell/cesa - add allhwsupport module parameter
crypto: marvell/cesa - add support for all armada SoCs
Struct inet_proto no longer exists, so update the
comment which is out of date.
Signed-off-by: Zhaowei Yuan <zhaowei.yuan@samsung.com>
Merge the mvebu/drivers branch of the arm-soc tree which contains
just a single patch bfa1ce5f38938cc9e6c7f2d1011f88eba2b9e2b2 ("bus:
mvebu-mbus: add mv_mbus_dram_info_nooverlap()") that happens to be
a prerequisite of the new marvell/cesa crypto driver.
This pulls the full hook netfilter definitions from all those that include
net_namespace.h.
Instead let's just include the bare minimum required in the new
linux/netfilter_defs.h file, and use it from the netfilter netns header files.
I also needed to include in.h and in6.h from linux/netfilter.h otherwise we hit
this compilation error:
In file included from include/linux/netfilter_defs.h:4:0,
from include/net/netns/netfilter.h:4,
from include/net/net_namespace.h:22,
from include/linux/netdevice.h:43,
from net/netfilter/nfnetlink_queue_core.c:23:
include/uapi/linux/netfilter.h:76:17: error: field ‘in’ has incomplete type struct in_addr in;
And also explicit include linux/netfilter.h in several spots.
We don't need to pull the full definitions in that file, a simple forward
declaration is enough.
Moreover, include linux/procfs.h from nf_synproxy_core, otherwise this hits a
compilation error due to missing declarations, ie.
net/netfilter/nf_synproxy_core.c: In function ‘synproxy_proc_init’:
net/netfilter/nf_synproxy_core.c:326:2: error: implicit declaration of function ‘proc_create’ [-Werror=implicit-function-declaration]
if (!proc_create("synproxy", S_IRUGO, net->proc_net_stat,
Include linux/idr.h and linux/skbuff.h since they are required by objects that
are declared in the net structure.
struct net {
struct idr netns_ids;
struct sk_buff_head wext_nlevents;
Resolve compilation breakage when CONFIG_IPV6 is not set by moving the IPv6
code into a separated br_netfilter_ipv6.c file.
Fixes: efb6de9b4ba0 ("netfilter: bridge: forward IPv6 fragmented packets")
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Now that all preconditions are present for actual multi-advertising, the
number of allowed advertising instances can be larger than one. This
patch increases the number of allowed advertising instances to 5.
Signed-off-by: Florian Grandel <fgrandel@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Now that the obsolete adv_instance is no longer being referenced
anywhere in the code it can be removed without breaking the build.
The add_advertising() and add_advertising_complete() functions reference
the now obsolete hdev->adv_instance struct. Both methods are being
refactored to access the dynamic advertising instance list instead.
This patch also introduces all logic necessary to actually deal with
multiple instance advertising. Notably the mgmt_adv_inst_expired() and
schedule_adv_inst() method are being referenced to schedule instances in
a round robin fashion.
This patch also introduces a "pending" flag into the adv_info struct.
This is necessary to identify and remove recently added advertising
instances when the HCI commands return with an error status code.
Otherwise new advertising instances could be leaked without properly
informing userspace about their existence.
Currently the delayed work managing advertising duration and timeout is
part of the advertising instance structure. This is not correct as only
a single instance can be advertised at any given time. To implement
round robin advertising a single delayed work structure is needed.
To fix this the delayed work structure is being moved to the hci_dev
structure. The instance specific variable is renamed to "remaining_time"
to make it clear that this is the remaining lifetime of the instance and
not the current advertising timeout.
The current hci dev structure only supports a single advertising
instance. To support multi-instance advertising it is necessary to
introduce a linked list of advertising instances so that multiple
advertising instances can be dynamically added and/or removed.
In a first step, the existing adv_instance member of the hci_dev
struct is supplemented by a linked list of advertising instances.
This patch introduces the list and supporting list management
infrastructure. The list is not being used yet.
These groups will contain socket-destruction events for
AF_INET/AF_INET6, IPPROTO_TCP/IPPROTO_UDP.
Near the end of socket destruction, a check for listeners is
performed. In the presence of a listener, rather than completely
cleanup the socket, a unit of work will be added to a private
work queue which will first broadcast information about the socket
and then finish the cleanup operation.
Signed-off-by: Craig Gallek <kraig@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/nfc-next
Samuel Ortiz says:
NFC 4.2 pull request
This is the NFC pull request for 4.2.
- NCI drivers can now define their own handlers for processing
proprietary NCI responses and notifications.
- NFC vendors can use a dedicated netlink API to send their own
proprietary commands, like e.g. all commands needed to implement
vendor specific manufacturing tools.
- A new generic NCI over UART driver against which any NCI chipset
running on top of a serial interface can register.
- The st21nfcb driver is renamed to st-nci as it can and will support
most of ST Microelectronics NCI chipsets.
- The st21nfcb driver can put its CLF in hibernate mode and save
significant amount of power.
- A few st21nfcb minor fixes.
- The NXP NCI driver now supports ACPI enumeration.
- The Marvell NCI driver now supports both USB and serial
physical interfaces.
- The Marvell NCI drivers also supports NCI frames being muxed
over HCI. This is a setting that can be defined by a DT property.
In case the net_device is gone, we have to unregister the hooks and put back
the reference on the net_device object. Once it comes back, register them
again. This also covers the device rename case.
This patch also adds a new flag to indicate that the basechain is disabled, so
their hooks are not registered. This flag is used by the netdev family to
handle the case where the net_device object is gone. Currently this flag is not
exposed to userspace.
The device is part of the hook configuration, so instead of a global
configuration per table, set it to each of the basechain that we create.
This patch reworks ebddf1a8d78a ("netfilter: nf_tables: allow to bind table to
net_device").
Note that this adds a dev_name field in the nft_base_chain structure which is
required the netdev notification subscription that follows up in a patch to
handle gone net_devices.
Suggested-by: Patrick McHardy <kaber@trash.net>
->auto_asconf_splist is per namespace and mangled by functions like
sctp_setsockopt_auto_asconf() which doesn't guarantee any serialization.
Also, the call to inet_sk_copy_descendant() was backuping
->auto_asconf_list through the copy but was not honoring
->do_auto_asconf, which could lead to list corruption if it was
different between both sockets.
This commit thus fixes the list handling by using ->addr_wq_lock
spinlock to protect the list. A special handling is done upon socket
creation and destruction for that. Error handlig on sctp_init_sock()
will never return an error after having initialized asconf, so
sctp_destroy_sock() can be called without addrq_wq_lock. The lock now
will be take on sctp_close_sock(), before locking the socket, so we
don't do it in inverse order compared to sctp_addr_wq_timeout_handler().
Instead of taking the lock on sctp_sock_migrate() for copying and
restoring the list values, it's preferred to avoid rewritting it by
implementing sctp_copy_descendant().
Issue was found with a test application that kept flipping sysctl
default_auto_asconf on and off, but one could trigger it by issuing
simultaneous setsockopt() calls on multiple sockets or by
creating/destroying sockets fast enough. This is only triggerable
locally.
Fixes: 9f7d653b67ae ("sctp: Add Auto-ASCONF support (core).")
Reported-by: Ji Jianwen <jiji@redhat.com>
Suggested-by: Neil Horman <nhorman@tuxdriver.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
This patch fixes commits ("mac802154: cleanup ieee802154 hardware flags")
bcbfd2078d9b11277d9c9ce0c30ba73c750503c9 and ("mac802154: cleanup address
filtering flags") 6b70a43c7e0202cf285c864bc9f20f607c42e432 by starting
the flags definitions at BIT(0) which is same like the previous behaviour.
Signed-off-by: Alexander Aring <alex.aring@gmail.com>
This patch changes the setting of llsec param flag with the BIT macro.
Signed-off-by: Varka Bhadram <varkab@cdac.in>
Acked-by: Alexander Aring <alex.aring@gmail.com>
Since Bluetooth 3.0 there's a HCI command available for reading the
encryption key size of an BR/EDR connection. This information is
essential e.g. for generating an LTK using SMP over BR/EDR, so store
it as part of struct hci_conn.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
In commit cd7d8498c9a5 ("tcp: change tcp_skb_pcount() location") we stored
gso_segs in a temporary cache hot location.
This patch does the same for gso_size.
This allows to save 2 cache line misses in tcp xmit path for
the last packet that is considered but not sent because of
various conditions (cwnd, tso defer, receiver window, TSQ...)
Some NFC controller supports UART as host interface.
As with SPI, a lot of code can be shared between vendor
drivers. This patch add the generic support of UART and
provides some extension API for vendor specific needs.
This code is strongly inspired by the Bluetooth HCI ldisc
implementation. NCI UART vendor drivers will have to register
themselves to this layer via nci_uart_register.
Underlying tty will have to be configured from user land
thanks to an ioctl.
Signed-off-by: Vincent Cuissard <cuissard@marvell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Johannes Berg says:
For this round we mostly have fixes:
* mesh fixes from Alexis Green and Chun-Yeow Yeoh,
* a documentation fix from Jakub Kicinski,
* a missing channel release (from Michal Kazior),
* a fix for a signal strength reporting bug (from Sara Sharon),
* handle deauth while associating (myself),
* don't report mangled TX SKB back to userspace for status (myself),
* handle aggregation session timeouts properly in fast-xmit (myself)
However, there are also a few cleanups and one big change that
affects all drivers (and that required me to pull in your tree)
to change the mac80211 HW flags to use an unsigned long bitmap
so that we can extend them more easily - we're running out of
flags even with a cleanup to remove the two unused ones.
SCM_SECURITY was originally only implemented for datagram sockets,
not for stream sockets. However, SCM_CREDENTIALS is supported on
Unix stream sockets. For consistency, implement Unix stream support
for SCM_SECURITY as well. Also clean up the existing code and get
rid of the superfluous UNIXSID macro.
Motivated by https://bugzilla.redhat.com/show_bug.cgi?id=1224211,
where systemd was using SCM_CREDENTIALS and assumed wrongly that
SCM_SECURITY was also supported on Unix stream sockets.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Paul Moore <paul@paul-moore.com>
As we're running out of hardware capability flags pretty quickly,
convert them to use the regular test_bit() style unsigned long
bitmaps.
This introduces a number of helper functions/macros to set and to
test the bits, along with new debugfs code.
The occurrences of an explicit __clear_bit() are intentional, the
drivers were never supposed to change their supported bits on the
fly. We should investigate changing this to be a per-frame flag.
Merge back net-next to get wireless driver changes (from Kalle)
to be able to create the API change across all trees properly.
Signed-off-by: Christoffer Holmstedt <christoffer@christofferholmstedt.se>
FIF_PROMISC_IN_BSS was removed in commit df1404650ccb
("mac80211: remove support for IFF_PROMISC").
Signed-off-by: Jakub Kicinski <kubakici@wp.pl>
