path: root/include/net
2010-11-30inetpeer: Add inet_getpeer_v6()David S. Miller
Now that all of the infrastructure is in place, we can add the ipv6 shorthand for peer creation. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30inetpeer: Make inet_getpeer() take an inet_peer_adress_t pointer.David S. Miller
And make an inet_getpeer_v4() helper, update callers. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30inetpeer: Introduce inet_peer_address_t.David S. Miller
Currently only the v4 aspect is used, but this will change. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-11-29sctp: kill unused macros in head fileShan Wei
1. SCTP_CMD_NUM_VERBS,SCTP_CMD_MAX These two macros have never been used for several years since v2.6.12-rc2. 2.sctp_port_rover,sctp_port_alloc_lock The commit 063930 abandoned global variables of port_rover and port_alloc_lock, but still keep two macros to refer to them. So, remove them now. commit 06393009000779b00a558fd2f280882cc7dc2008 Author: Stephen Hemminger <shemminger@linux-foundation.org> Date: Wed Oct 10 17:30:18 2007 -0700 [SCTP]: port randomization Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28xfrm: fix gre key endianessTimo Teräs
fl->fl_gre_key is network byte order contrary to fl->fl_icmp_*. Make xfrm_flowi_{s|d}port return network byte order values for gre key too. Signed-off-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28X25 remove bkl in subscription ioctlsandrew hendry
Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28sctp: kill unused macro definitionShan Wei
These macros have been existed for several years since v2.6.12-rc2. But they never be used. So remove them now. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-27rtnl: make link af-specific updates atomicThomas Graf
As David pointed out correctly, updates to af-specific attributes are currently not atomic. If multiple changes are requested and one of them fails, previous updates may have been applied already leaving the link behind in a undefined state. This patch splits the function parse_link_af() into two functions validate_link_af() and set_link_at(). validate_link_af() is placed to validate_linkmsg() check for errors as early as possible before any changes to the link have been made. set_link_af() is called to commit the changes later. This method is not fail proof, while it is currently sufficient to make set_link_af() inerrable and thus 100% atomic, the validation function method will not be able to detect all error scenarios in the future, there will likely always be errors depending on states which are f.e. not protected by rtnl_mutex and thus may change between validation and setting. Also, instead of silently ignoring unknown address families and config blocks for address families which did not register a set function the errors EAFNOSUPPORT respectively EOPNOSUPPORT are returned to avoid comitting 4 out of 5 update requests without notifying the user. Signed-off-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2010-11-24cfg80211: allow using CQM event to notify packet lossJohannes Berg
This adds the ability for drivers to use CQM events to notify about packet loss for specific stations (which could be the AP for the managed mode case). Since the threshold might be determined by the driver (it isn't passed in right now) it will be passed out of the driver to userspace in the event. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24cfg80211: Add documentation for antenna opsBruno Randolf
Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24cfg80211/mac80211: improve ad-hoc multicast rate handlingFelix Fietkau
- store the multicast rate as an index instead of the rate value (reduces cpu overhead in a hotpath) - validate the rate values (must match a bitrate in at least one sband) Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24Revert "nl80211/mac80211: Report signal average"John W. Linville
This reverts commit 86107fd170bc379869250eb7e1bd393a3a70e8ae. This patch inadvertantly changed the userland ABI. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24scm: lower SCM_MAX_FDEric Dumazet
Lower SCM_MAX_FD from 255 to 253 so that allocations for scm_fp_list are halved. (commit f8d570a4 added two pointers in this structure) scm_fp_dup() should not copy whole structure (and trigger kmemcheck warnings), but only the used part. While we are at it, only allocate needed size. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24ipv6: mcast: RCU conversionEric Dumazet
ipv6_sk_mc_lock rwlock becomes a spinlock. readers (inet6_mc_check()) now takes rcu_read_lock() instead of read lock. Writers dont need to disable BH anymore. struct ipv6_mc_socklist objects are reclaimed after one RCU grace period. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22cfg80211: Fix regulatory bug with multiple cards and delaysLuis R. Rodriguez
When two cards are connected with the same regulatory domain if CRDA had a delayed response then cfg80211's own set regulatory domain would still be the world regulatory domain. There was a bug on cfg80211's logic such that it assumed that once you pegged a request as the last request it was already the currently set regulatory domain. This would mean we would race setting a stale regulatory domain to secondary cards which had the same regulatory domain since the alpha2 would match. We fix this by processing each regulatory request atomically, and only move on to the next one once we get it fully processed. In the case CRDA is not present we will simply world roam. This issue is only present when you have a slow system and the CRDA processing is delayed. Because of this it is not a known regression. Without this fix when a delay is present with CRDA the second card would end up with an intersected regulatory domain and not allow it to use the channels it really is designed for. When two cards with two different regulatory domains were inserted you'd end up rejecting the second card's regulatory domain request. This fails with mac80211_hswim's regtest=2 (two requests, same alpha2) and regtest=3 (two requests, different alpha2) module parameter options. This was reproduced and tested against mac80211_hwsim using this CRDA delayer: #!/bin/bash echo $COUNTRY >> /tmp/log sleep 2 /sbin/crda.orig And these regulatory tests: modprobe mac80211_hwsim regtest=2 modprobe mac80211_hwsim regtest=3 Reported-by: Mark Mentovai <mark@moxienet.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Tested-by: Mark Mentovai <mark@moxienet.com> Tested-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-21netns: let net_generic take pointer-to-const argsJan Engelhardt
This commit is same in nature as v2.6.37-rc1-755-g3654654; the network namespace itself is not modified when calling net_generic, so the parameter can be const. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c net/core/net-sysfs.c net/ipv6/addrconf.c
2010-11-18Merge branch 'master' of ↵David S. Miller
2010-11-18nl80211/mac80211: Report signal averageBruno Randolf
Extend nl80211 to report an exponential weighted moving average (EWMA) of the signal value. Since the signal value usually fluctuates between different packets, an average can be more useful than the value of the last packet. This uses the recently added generic EWMA library function. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-18net: Fix duplicate volatile warning.Tetsuo Handa
jiffies is defined as "volatile". extern unsigned long volatile __jiffy_data jiffies; ACCESS_ONCE() uses "volatile". As a result, some compilers warn duplicate `volatile' for ACCESS_ONCE(jiffies). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17mac80211: defines for AC numbersJohannes Berg
In many places we've just hardcoded the AC numbers -- which is a relic from the original mac80211 (d80211). Add constants for them so we know what we're talking about. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-17net: use the macros defined for the members of flowiChangli Gao
Use the macros defined for the members of flowi to clean the code up. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17rtnetlink: Link address family APIThomas Graf
Each net_device contains address family specific data such as per device settings and statistics. We already expose this data via procfs/sysfs and partially netlink. The netlink method requires the requester to send one RTM_GETLINK request for each address family it wishes to receive data of and then merge this data itself. This patch implements a new API which combines all address family specific link data in a new netlink attribute IFLA_AF_SPEC. IFLA_AF_SPEC contains a sequence of nested attributes, one for each address family which in turn defines the structure of its own attribute. Example: [IFLA_AF_SPEC] = { [AF_INET] = { [IFLA_INET_CONF] = ..., }, [AF_INET6] = { [IFLA_INET6_FLAGS] = ..., [IFLA_INET6_CONF] = ..., } } The API also allows for address families to implement a function which parses the IFLA_AF_SPEC attribute sent by userspace to implement address family specific link options. Signed-off-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-16mac80211: add support for setting the ad-hoc multicast rateFelix Fietkau
2010-11-16cfg80211: add support for setting the ad-hoc multicast rateFelix Fietkau
2010-11-16mac80211: Add function to get probe request template for current APJuuso Oikarinen
Chipsets with hardware based connection monitoring need to autonomically send directed probe-request frames to the AP (in the event of beacon loss, for example.) For the hardware to be able to do this, it requires a template for the frame to transmit to the AP, filled in with the BSSID and SSID of the AP, but also the supported rate IE's. This patch adds a function to mac80211, which allows the hardware driver to fetch this template after association, so it can be configured to the hardware. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mac80211: Add antenna configurationBruno Randolf
Allow antenna configuration by calling driver's function for it. We disallow antenna configuration if the wiphy is already running, mainly to make life easier for 802.11n drivers which need to recalculate HT capabilites. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16cfg80211: Add nl80211 antenna configurationBruno Randolf
Allow setting of TX and RX antennas configuration via nl80211. The antenna configuration is defined as a bitmap of allowed antennas to use. This API can be used to mask out antennas which are not attached or should not be used for other reasons like regulatory concerns or special setups. Separate bitmaps are used for RX and TX to allow configuring different antennas for receiving and transmitting. Each bitmap is 32 bit long, each bit representing one antenna, starting with antenna 1 at the first bit. If an antenna bit is set, this means the driver is allowed to use this antenna for RX or TX respectively; if the bit is not set the hardware is not allowed to use this antenna. Using bitmaps has the benefit of allowing for a flexible configuration interface which can support many different configurations and which can be used for 802.11n as well as non-802.11n devices. Instead of relying on some hardware specific assumptions, drivers can use this information to know which antennas are actually attached to the system and derive their capabilities based on that. 802.11n devices should enable or disable chains, based on which antennas are present (If all antennas belonging to a particular chain are disabled, the entire chain should be disabled). HT capabilities (like STBC, TX Beamforming, Antenna selection) should be calculated based on the available chains after applying the antenna masks. Should a 802.11n device have diversity antennas attached to one of their chains, diversity can be enabled or disabled based on the antenna information. Non-802.11n drivers can use the antenna masks to select RX and TX antennas and to enable or disable antenna diversity. While covering chainmasks for 802.11n and the standard "legacy" modes "fixed antenna 1", "fixed antenna 2" and "diversity" this API also allows more rare, but useful configurations as follows: 1) Send on antenna 1, receive on antenna 2 (or vice versa). This can be used to have a low gain antenna for TX in order to keep within the regulatory constraints and a high gain antenna for RX in order to receive weaker signals ("speak softly, but listen harder"). This can be useful for building long-shot outdoor links. Another usage of this setup is having a low-noise pre-amplifier on antenna 1 and a power amplifier on the other antenna. This way transmit noise is mostly kept out of the low noise receive channel. (This would be bitmaps: tx 1 rx 2). 2) Another similar setup is: Use RX diversity on both antennas, but always send on antenna 1. Again that would allow us to benefit from a higher gain RX antenna, while staying within the legal limits. (This would be: tx 0 rx 3). 3) And finally there can be special experimental setups in research and development even with pre 802.11n hardware where more than 2 antennas are available. It's good to keep the API simple, yet flexible. Signed-off-by: Bruno Randolf <br1@einfach.org> -- v7: Made bitmasks 32 bit wide and rebased to latest wireless-testing. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mac80211: support hardware TX fragmentation offloadArik Nemtsov
The lower driver is notified when the fragmentation threshold changes and upon a reconfig of the interface. If the driver supports hardware TX fragmentation, don't fragment packets in the stack. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16net: reorder struct sock fieldsEric Dumazet
Right now, fields in struct sock are not optimally ordered, because each path (RX softirq, TX completion, RX user, TX user) has to touch fields that are contained in many different cache lines. The really critical thing is to shrink number of cache lines that are used at RX softirq time : CPU handling softirqs for a device can receive many frames per second for many sockets. If load is too big, we can drop frames at NIC level. RPS or multiqueue cards can help, but better reduce latency if possible. This patch starts with UDP protocol, then additional patches will try to reduce latencies of other ones as well. At RX softirq time, fields of interest for UDP protocol are : (not counting ones in inet struct for the lookup) Read/Written: sk_refcnt (atomic increment/decrement) sk_rmem_alloc & sk_backlog.len (to check if there is room in queues) sk_receive_queue sk_backlog (if socket locked by user program) sk_rxhash sk_forward_alloc sk_drops Read only: sk_rcvbuf (sk_rcvqueues_full()) sk_filter sk_wq sk_policy[0] sk_flags Additional notes : - sk_backlog has one hole on 64bit arches. We can fill it to save 8 bytes. - sk_backlog is used only if RX sofirq handler finds the socket while locked by user. - sk_rxhash is written only once per flow. - sk_drops is written only if queues are full Final layout : [1] One section grouping all read/write fields, but placing rxhash and sk_backlog at the end of this section. [2] One section grouping all read fields in RX handler (sk_filter, sk_rcv_buf, sk_wq) [3] Section used by other paths I'll post a patch on its own to put sk_refcnt at the end of struct sock_common so that it shares same cache line than section [1] New offsets on 64bit arch : sizeof(struct sock)=0x268 offsetof(struct sock, sk_refcnt) =0x10 offsetof(struct sock, sk_lock) =0x48 offsetof(struct sock, sk_receive_queue)=0x68 offsetof(struct sock, sk_backlog)=0x80 offsetof(struct sock, sk_rmem_alloc)=0x80 offsetof(struct sock, sk_forward_alloc)=0x98 offsetof(struct sock, sk_rxhash)=0x9c offsetof(struct sock, sk_rcvbuf)=0xa4 offsetof(struct sock, sk_drops) =0xa0 offsetof(struct sock, sk_filter)=0xa8 offsetof(struct sock, sk_wq)=0xb0 offsetof(struct sock, sk_policy)=0xd0 offsetof(struct sock, sk_flags) =0xe0 Instead of : sizeof(struct sock)=0x270 offsetof(struct sock, sk_refcnt) =0x10 offsetof(struct sock, sk_lock) =0x50 offsetof(struct sock, sk_receive_queue)=0xc0 offsetof(struct sock, sk_backlog)=0x70 offsetof(struct sock, sk_rmem_alloc)=0xac offsetof(struct sock, sk_forward_alloc)=0x10c offsetof(struct sock, sk_rxhash)=0x128 offsetof(struct sock, sk_rcvbuf)=0x4c offsetof(struct sock, sk_drops) =0x16c offsetof(struct sock, sk_filter)=0x198 offsetof(struct sock, sk_wq)=0x88 offsetof(struct sock, sk_policy)=0x98 offsetof(struct sock, sk_flags) =0x130 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-16udp: use atomic_inc_not_zero_hintEric Dumazet
UDP sockets refcount is usually 2, unless an incoming frame is going to be queued in receive or backlog queue. Using atomic_inc_not_zero_hint() permits to reduce latency, because processor issues less memory transactions. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-16netlink: let nlmsg and nla functions take pointer-to-const argsJan Engelhardt
The changed functions do not modify the NL messages and/or attributes at all. They should use const (similar to strchr), so that callers which have a const nlmsg/nlattr around can make use of them without casting. While at it, constify a data array. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-16Merge branch 'master' of ↵David S. Miller
2010-11-15cfg80211: fix WIPHY_FLAG_IBSS_RSN bitJussi Kivilinna
WIPHY_FLAG_IBSS_RSN is BIT(7) as is WIPHY_FLAG_CONTROL_PORT_PROTOCOL. Change to BIT(8). Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15b43legacy: Fix compile on ARM architectureArnd Hannemann
When b43legacy is compiled on the arm platform, the following errors are seen: CC [M] drivers/net/wireless/b43legacy/xmit.o In file included from include/net/dst.h:11, from drivers/net/wireless/b43legacy/xmit.c:31: include/net/dst_ops.h:28: error: expected ':', ',', ';', '}' or '__attribute__' before '____cacheline_aligned_in_smp' include/net/dst_ops.h: In function 'dst_entries_get_fast': include/net/dst_ops.h:33: error: 'struct dst_ops' has no member named 'pcpuc_entries' include/net/dst_ops.h: In function 'dst_entries_get_slow': include/net/dst_ops.h:41: error: 'struct dst_ops' has no member named 'pcpuc_entries' include/net/dst_ops.h: In function 'dst_entries_add': include/net/dst_ops.h:49: error: 'struct dst_ops' has no member named 'pcpuc_entries' include/net/dst_ops.h: In function 'dst_entries_init': include/net/dst_ops.h:55: error: 'struct dst_ops' has no member named 'pcpuc_entries' include/net/dst_ops.h: In function 'dst_entries_destroy': include/net/dst_ops.h:60: error: 'struct dst_ops' has no member named 'pcpuc_entries' make[4]: *** [drivers/net/wireless/b43legacy/xmit.o] Error 1 make[3]: *** [drivers/net/wireless/b43legacy] Error 2 make[2]: *** [drivers/net/wireless] Error 2 make[1]: *** [drivers/net] Error 2 make: *** [drivers] Error 2 The cause is a missing include of <linux/cache.h>, which is present for i386 and x86_64 architectures, but not for arm. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15include/net/caif/cfctrl.h: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15xfrm: use gre key as flow upper protocol infoTimo Teräs
The GRE Key field is intended to be used for identifying an individual traffic flow within a tunnel. It is useful to be able to have XFRM policy selector matches to have different policies for different GRE tunnels. Signed-off-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15cfg80211: fix allowing country IEs for WIPHY_FLAG_STRICT_REGULATORYLuis R. Rodriguez
We should be enabling country IE hints for WIPHY_FLAG_STRICT_REGULATORY even if we haven't yet recieved regulatory domain hint for the driver if it needed one. Without this Country IEs are not passed on to drivers that have set WIPHY_FLAG_STRICT_REGULATORY, today this is just all Atheros chipset drivers: ath5k, ath9k, ar9170, carl9170. This was part of the original design, however it was completely overlooked... Cc: Easwar Krishnan <easwar.krishnan@atheros.com> Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-14Merge branch 'master' of ↵David S. Miller
2010-11-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (66 commits) can-bcm: fix minor heap overflow gianfar: Do not call device_set_wakeup_enable() under a spinlock ipv6: Warn users if maximum number of routes is reached. docs: Add neigh/gc_thresh3 and route/max_size documentation. axnet_cs: fix resume problem for some Ax88790 chip ipv6: addrconf: don't remove address state on ifdown if the address is being kept tcp: Don't change unlocked socket state in tcp_v4_err(). x25: Prevent crashing when parsing bad X.25 facilities cxgb4vf: add call to Firmware to reset VF State. cxgb4vf: Fail open if link_start() fails. cxgb4vf: flesh out PCI Device ID Table ... cxgb4vf: fix some errors in Gather List to skb conversion cxgb4vf: fix bug in Generic Receive Offload cxgb4vf: don't implement trivial (and incorrect) ndo_select_queue() ixgbe: Look inside vlan when determining offload protocol. bnx2x: Look inside vlan when determining checksum proto. vlan: Add function to retrieve EtherType from vlan packets. virtio-net: init link state correctly ucc_geth: Fix deadlock ucc_geth: Do not bring the whole IF down when TX failure. ...
2010-11-12igmp: RCU conversion of in_dev->mc_listEric Dumazet
in_dev->mc_list is protected by one rwlock (in_dev->mc_list_lock). This can easily be converted to a RCU protection. Writers hold RTNL, so mc_list_lock is removed, not replaced by a spinlock. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Cypher Wu <cypher.w@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-11ipv4: Make rt->fl.iif tests lest obscure.David S. Miller
When we test rt->fl.iif against zero, we're seeing if it's an output or an input route. Make that explicit with some helper functions. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-11net: get rid of rtable->idevEric Dumazet
It seems idev field in struct rtable has no special purpose, but adding extra atomic ops. We hold refcounts on the device itself (using percpu data, so pretty cheap in current kernel). infiniband case is solved using dst.dev instead of idev->dev Removal of this field means routing without route cache is now using shared data, percpu data, and only potential contention is a pair of atomic ops on struct neighbour per forwarded packet. About 5% speedup on routing test. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-11neigh: reorder struct neighbourEric Dumazet
It is important to move nud_state outside of the often modified cache line (because of refcnt), to reduce false sharing in neigh_event_send() This is a followup of commit 0ed8ddf4045f (neigh: Protect neigh->ha[] with a seqlock) This gives a 7% speedup on routing test with IP route cache disabled. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-10net: avoid limits overflowEric Dumazet
Robin Holt tried to boot a 16TB machine and found some limits were reached : sysctl_tcp_mem[2], sysctl_udp_mem[2] We can switch infrastructure to use long "instead" of "int", now atomic_long_t primitives are available for free. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-by: Robin Holt <holt@sgi.com> Reviewed-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-08decnet: RCU conversion and get rid of dev_base_lockEric Dumazet
While tracking dev_base_lock users, I found decnet used it in dnet_select_source(), but for a wrong purpose: Writers only hold RTNL, not dev_base_lock, so readers must use RCU if they cannot use RTNL. Adds an rcu_head in struct dn_ifaddr and handle proper RCU management. Adds __rcu annotation in dn_route as well. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-08Merge branch 'master' of ↵David S. Miller
