path: root/include/net
2011-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) tg3: Fix tg3_skb_error_unmap() net: tracepoint of net_dev_xmit sees freed skb and causes panic drivers/net/can/flexcan.c: add missing clk_put net: dm9000: Get the chip in a known good state before enabling interrupts drivers/net/davinci_emac.c: add missing clk_put af-packet: Add flag to distinguish VID 0 from no-vlan. caif: Fix race when conditionally taking rtnl lock usbnet/cdc_ncm: add missing .reset_resume hook vlan: fix typo in vlan_dev_hard_start_xmit() net/ipv4: Check for mistakenly passed in non-IPv4 address iwl4965: correctly validate temperature value bluetooth l2cap: fix locking in l2cap_global_chan_by_psm ath9k: fix two more bugs in tx power cfg80211: don't drop p2p probe responses Revert "net: fix section mismatches" drivers/net/usb/catc.c: Fix potential deadlock in catc_ctrl_run() sctp: stop pending timers and purge queues when peer restart asoc drivers/net: ks8842 Fix crash on received packet when in PIO mode. ip_options_compile: properly handle unaligned pointer iwlagn: fix incorrect PCI subsystem id for 6150 devices ...
2011-05-31sctp: stop pending timers and purge queues when peer restart asocWei Yongjun
If the peer restart the asoc, we should not only fail any unsent/unacked data, but also stop the T3-rtx, SACK, T4-rto timers, and teardown ASCONF queues. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Kill ratelimit.h dependency in linux/net.h net: Add linux/sysctl.h includes where needed. net: Kill ether_table[] declaration. inetpeer: fix race in unused_list manipulations atm: expose ATM device index in sysfs IPVS: bug in ip_vs_ftp, same list heaad used in all netns. bug.h: Move ratelimit warn interfaces to ratelimit.h bonding: cleanup module option descriptions net:8021q:vlan.c Fix pr_info to just give the vlan fullname and version. net: davinci_emac: fix dev_err use at probe can: convert to %pK for kptr_restrict support net: fix ETHTOOL_SFEATURES compatibility with old ethtool_ops.set_flags netfilter: Fix several warnings in compat_mtw_from_user(). netfilter: ipset: fix ip_set_flush return code netfilter: ipset: remove unused variable from type_pf_tdel() netfilter: ipset: Use proper timeout value to jiffies conversion
2011-05-27net: Kill ratelimit.h dependency in linux/net.hDavid S. Miller
Ingo Molnar noticed that we have this unnecessary ratelimit.h dependency in linux/net.h, which hid compilation problems from people doing builds only with CONFIG_NET enabled. Move this stuff out to a seperate net/net_ratelimit.h file and include that in the only two places where this thing is needed. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu>
2011-05-27net: Add linux/sysctl.h includes where needed.David S. Miller
Several networking headers were depending upon the implicit linux/sysctl.h include they get when including linux/net.h Add explicit includes. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-27Merge branch 'pablo/nf-2.6-updates' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-05-27IPVS: bug in ip_vs_ftp, same list heaad used in all netns.Hans Schillstrom
When ip_vs was adapted to netns the ftp application was not adapted in a correct way. However this is a fix to avoid kernel errors. In the long term another solution might be chosen. I.e the ports that the ftp appl, uses should be per netns. Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfdLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfd: net: fix get_net_ns_by_fd for !CONFIG_NET_NS ns proc: Return -ENOENT for a nonexistent /proc/self/ns/ entry. ns: Declare sys_setns in syscalls.h net: Allow setting the network namespace by fd ns proc: Add support for the ipc namespace ns proc: Add support for the uts namespace ns proc: Add support for the network namespace. ns: Introduce the setns syscall ns: proc files for namespace naming policy.
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits) bonding: documentation and code cleanup for resend_igmp bonding: prevent deadlock on slave store with alb mode (v3) net: hold rtnl again in dump callbacks Add Fujitsu 1000base-SX PCI ID to tg3 bnx2x: protect sequence increment with mutex sch_sfq: fix peek() implementation isdn: netjet - blacklist Digium TDM400P via-velocity: don't annotate MAC registers as packed xen: netfront: hold RTNL when updating features. sctp: fix memory leak of the ASCONF queue when free asoc net: make dev_disable_lro use physical device if passed a vlan dev (v2) net: move is_vlan_dev into public header file (v2) bug.h: Fix build with CONFIG_PRINTK disabled. wireless: fix fatal kernel-doc error + warning in mac80211.h wireless: fix cfg80211.h new kernel-doc warnings iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled dst: catch uninitialized metrics be2net: hash key for rss-config cmd not set bridge: initialize fake_rtable metrics net: fix __dst_destroy_metrics_generic() ... Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
2011-05-25Merge branch 'for-davem' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2011-05-259p: Small cleanup in <net/9p/9p.h>Sasha Levin
There are two small cleanups in this patch: - p9_errstr2errno was declared twice - remove one declaration. - A uint8_t type was mixed in, change it to u8 to match with the rest of the type names and remove dependency. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-259p: typo fixes and minor cleanupsRob Landley
Typo fixes and minor cleanups for v9fs Signed-off-by: Rob Landley <rob@landley.net> Reviewed-by: Venkateswararao Jujjuri (JV) <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-24Merge ↵John W. Linville
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-05-24wireless: fix fatal kernel-doc error + warning in mac80211.hRandy Dunlap
Fix new kernel-doc Error and Warning in <net/mac80211.h>: Error(linux-2.6.39-git5/include/net/mac80211.h:550): cannot understand prototype: 'struct ieee80211_sched_scan_ies ' Warning(linux-2.6.39-git5/include/net/mac80211.h:2289): No description found for parameter 'sta' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-24wireless: fix cfg80211.h new kernel-doc warningsRandy Dunlap
Fix new kernel-doc warnings in <net/cfg80211.h>: Warning(linux-2.6.39-git5/include/net/cfg80211.h:560): No description found for parameter 'bss_param' Warning(linux-2.6.39-git5/include/net/cfg80211.h:1555): Enum value 'WIPHY_FLAG_SUPPORTS_SCHED_SCAN' not described in enum 'wiphy_flags' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-24dst: catch uninitialized metricsStephen Hemminger
Catch cases where dst_metric_set() and other functions are called but _metrics is NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) bnx2x: allow device properly initialize after hotplug bnx2x: fix DMAE timeout according to hw specifications bnx2x: properly handle CFC DEL in cnic flow bnx2x: call dev_kfree_skb_any instead of dev_kfree_skb net: filter: move forward declarations to avoid compile warnings pktgen: refactor pg_init() code pktgen: use vzalloc_node() instead of vmalloc_node() + memset() net: skb_trim explicitely check the linearity instead of data_len ipv4: Give backtrace in ip_rt_bug(). net: avoid synchronize_rcu() in dev_deactivate_many net: remove synchronize_net() from netdev_set_master() rtnetlink: ignore NETDEV_RELEASE and NETDEV_JOIN event net: rename NETDEV_BONDING_DESLAVE to NETDEV_RELEASE bridge: call NETDEV_JOIN notifiers when add a slave netpoll: disable netpoll when enslave a device macvlan: Forward unicast frames in bridge mode to lowerdev net: Remove linux/prefetch.h include from linux/skbuff.h ipv4: Include linux/prefetch.h in fib_trie.c netlabel: Remove prefetches from list handlers. drivers/net: add prefetch header for prefetch users ... Fixed up prefetch parts: removed a few duplicate prefetch.h includes, fixed the location of the igb prefetch.h, took my version of the skbuff.h code without the extra parentheses etc.
2011-05-22wireless: fix fatal kernel-doc error + warning in mac80211.hRandy Dunlap
Fix new kernel-doc Error and Warning in <net/mac80211.h>: Error(linux-2.6.39-git5/include/net/mac80211.h:550): cannot understand prototype: 'struct ieee80211_sched_scan_ies ' Warning(linux-2.6.39-git5/include/net/mac80211.h:2289): No description found for parameter 'sta' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-22caif: Update documentation of CAIF transmit and receive functions.sjur.brandeland@stericsson.com
Trivial patch updating documentation in header files only. Error handling of CAIF transmit errors was changed by commit: caif: Don't resend if dev_queue_xmit fails. This patch updates the documentation accordingly. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-19Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits) Revert "rcu: Decrease memory-barrier usage based on semi-formal proof" net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree() batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu() net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu() net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu() perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu() perf,rcu: convert call_rcu(free_ctx) to kfree_rcu() net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(net_generic_release) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu() security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu() net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu() net,rcu: convert call_rcu(xps_map_release) to kfree_rcu() net,rcu: convert call_rcu(rps_map_release) to kfree_rcu() ...
2011-05-19ipv6: reduce per device ICMP mib sizesEric Dumazet
ipv6 has per device ICMP SNMP counters, taking too much space because they use percpu storage. needed size per device is : (512+4)*sizeof(long)*number_of_possible_cpus*2 On a 32bit kernel, 16 possible cpus, this wastes more than 64kbytes of memory per ipv6 enabled network device, taken in vmalloc pool. Since ICMP messages are rare, just use shared counters (atomic_long_t) Per network space ICMP counters are still using percpu memory, we might also convert them to shared counters in a future patch. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19cfg80211: Use consistent BSS matching between scan and smeJouni Malinen
cfg80211 scan code adds separate BSS entries if the same BSS shows up on multiple channels. However, sme implementation does not use the frequency when fetching the BSS entry. Fix this by adding channel information to cfg80211_roamed() and include it in cfg80211_get_bss() calls. Please note that drivers using cfg80211_roamed() need to be modified to fully implement this fix. This commit includes only minimal changes to avoid compilation issues; it maintains the old (broken) behavior for most drivers. ath6kl was the only one that I could test, so I updated it to provide the operating frequency in the roamed event. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-18ipv4: Pass explicit destination address to rt_bind_peer().David S. Miller
2011-05-18ipv4: Pass explicit destination address to rt_get_peer().David S. Miller
This will next trickle down to rt_bind_peer(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-18ipv4: Make caller provide flowi4 key to inet_csk_route_req().David S. Miller
This way the caller can get at the fully resolved fl4->{daddr,saddr} etc. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-18ipv4: Kill RT_CACHE_DEBUGDavid S. Miller
It's way past it's usefulness. And this gets rid of a bunch of stray ->rt_{dst,src} references. Even the comment documenting the macro was inaccurate (stated default was 1 when it's 0). If reintroduced, it should be done properly, with dynamic debug facilities. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/vmxnet3/vmxnet3_ethtool.c net/core/dev.c
2011-05-17net: ping: fix build failureVasiliy Kulikov
If CONFIG_PROC_SYSCTL=n the building process fails: ping.c:(.text+0x52af3): undefined reference to `inet_get_ping_group_range_net' Moved inet_get_ping_group_range_net() to ping.c. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-tx.c net/mac80211/sta_info.h
2011-05-16cfg80211: make stripping of 802.11 header optional from AMSDUYogesh Ashok Powar
Currently the devices that have already stripped IEEE 802.11 header from the AMSDU SKB can not use ieee80211_amsdu_to_8023s routine. This patch enhances ieee80211_amsdu_to_8023s() API by changing mandatory removing of IEEE 802.11 header from AMSDU to optional. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16nl80211: Move peer link state definition to nl80211Javier Cardona
These definitions need to be exposed now that we can set the peer link states via NL80211_ATTR_STA_PLINK_STATE. They were already being (opaquely) reported by NL80211_STA_INFO_PLINK_STATE. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16cfg80211: advertise possible interface combinationsJohannes Berg
Add the ability to advertise interface combinations in nl80211. This allows the driver to indicate what the combinations are that it supports. "Combinations" of just a single interface are implicit, as previously. Note that cfg80211 will enforce that the restrictions are met, but not for all drivers yet (once all drivers are updated, we can remove the flag and enforce for all). When no combinations are actually supported, an empty list will be exported so that userspace can know if the kernel exported this info or not (although it isn't clear to me what tools using the info should do if the kernel didn't export it). Since some interface types are purely virtual/software and don't fit the restrictions, those are exposed in a new list of pure SW types, not subject to restrictions. This mainly exists to handle AP-VLAN and monitor interfaces in mac80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-15caif: remove unesesarry exportssjur.brandeland@stericsson.com
2011-05-15caif: Handle dev_queue_xmit errors.sjur.brandeland@stericsson.com
Do proper handling of dev_queue_xmit errors in order to avoid double free of skb and leaks in error conditions. In cfctrl pending requests are removed when CAIF Link layer goes down. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15caif: prepare support for namespacessjur.brandeland@stericsson.com
Use struct net to reference CAIF configuration object instead of static variables. Refactor functions caif_connect_client, caif_disconnect_client and squach files cfcnfg.c and caif_config_utils. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15caif: Protected in-flight packets using dev or sock refcont.sjur.brandeland@stericsson.com
CAIF Socket Layer and ip-interface registers reference counters in CAIF service layer. The functions sock_hold, sock_put and dev_hold, dev_put are used by CAIF Stack to protect from freeing memory while packets are in-flight. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15caif: Move refcount from service layer to sock and dev.sjur.brandeland@stericsson.com
Instead of having reference counts in caif service layers, we hook into existing refcount handling in socket layer and netdevice. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15caif: Add ref-count to framing layersjur.brandeland@stericsson.com
Introduce Per-cpu reference for lower part of CAIF Stack. Before freeing payload is disabled, synchronize_rcu() is called, and then ref-count verified to be zero. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15caif: Use RCU instead of spin-lock in caif_dev.csjur.brandeland@stericsson.com
RCU read_lock and refcount is used to protect in-flight packets. Use RCU and counters to manage freeing lower part of the CAIF stack if CAIF-link layer is removed. Old solution based on delaying removal of device is removed. When CAIF link layer goes down the use of CAIF link layer is disabled (by calling caif_set_phy_state()), but removal and freeing of the lower part of the CAIF stack is done when Link layer is unregistered. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15caif: Use rcu_read_lock in CAIF mux layer.sjur.brandeland@stericsson.com
Replace spin_lock with rcu_read_lock when accessing lists to layers and cache. While packets are in flight rcu_read_lock should not be held, instead ref-counters are used in combination with RCU. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: bridge: fix forwarding of IPv6 bonding,llc: Fix structure sizeof incompatibility for some PDUs ipv6: restore correct ECN handling on TCP xmit ne-h8300: Fix regression caused during net_device_ops conversion hydra: Fix regression caused during net_device_ops conversion zorro8390: Fix regression caused during net_device_ops conversion sfc: Always map MCDI shared memory as uncacheable ehea: Fix memory hotplug oops libertas: fix cmdpendingq locking iwlegacy: fix IBSS mode crashes ath9k: Fix a warning due to a queued work during S3 state mac80211: don't start the dynamic ps timer if not associated
2011-05-13ipv4: Remove route key identity dependencies in ip_rt_get_source().David S. Miller
Pass in the sk_buff so that we can fetch the necessary keys from the packet header when working with input routes. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13net: ipv4: add IPPROTO_ICMP socket kindVasiliy Kulikov
This patch adds IPPROTO_ICMP socket kind. It makes it possible to send ICMP_ECHO messages and receive the corresponding ICMP_ECHOREPLY messages without any special privileges. In other words, the patch makes it possible to implement setuid-less and CAP_NET_RAW-less /bin/ping. In order not to increase the kernel's attack surface, the new functionality is disabled by default, but is enabled at bootup by supporting Linux distributions, optionally with restriction to a group or a group range (see below). Similar functionality is implemented in Mac OS X: http://www.manpagez.com/man/4/icmp/ A new ping socket is created with socket(PF_INET, SOCK_DGRAM, PROT_ICMP) Message identifiers (octets 4-5 of ICMP header) are interpreted as local ports. Addresses are stored in struct sockaddr_in. No port numbers are reserved for privileged processes, port 0 is reserved for API ("let the kernel pick a free number"). There is no notion of remote ports, remote port numbers provided by the user (e.g. in connect()) are ignored. Data sent and received include ICMP headers. This is deliberate to: 1) Avoid the need to transport headers values like sequence numbers by other means. 2) Make it easier to port existing programs using raw sockets. ICMP headers given to send() are checked and sanitized. The type must be ICMP_ECHO and the code must be zero (future extensions might relax this, see below). The id is set to the number (local port) of the socket, the checksum is always recomputed. ICMP reply packets received from the network are demultiplexed according to their id's, and are returned by recv() without any modifications. IP header information and ICMP errors of those packets may be obtained via ancillary data (IP_RECVTTL, IP_RETOPTS, and IP_RECVERR). ICMP source quenches and redirects are reported as fake errors via the error queue (IP_RECVERR); the next hop address for redirects is saved to ee_info (in network order). socket(2) is restricted to the group range specified in "/proc/sys/net/ipv4/ping_group_range". It is "1 0" by default, meaning that nobody (not even root) may create ping sockets. Setting it to "100 100" would grant permissions to the single group (to either make /sbin/ping g+s and owned by this group or to grant permissions to the "netadmins" group), "0 4294967295" would enable it for the world, "100 4294967295" would enable it for the users, but not daemons. The existing code might be (in the unlikely case anyone needs it) extended rather easily to handle other similar pairs of ICMP messages (Timestamp/Reply, Information Request/Reply, Address Mask Request/Reply etc.). Userspace ping util & patch for it: http://openwall.info/wiki/people/segoon/ping For Openwall GNU/*/Linux it was the last step on the road to the setuid-less distro. A revision of this patch (for RHEL5/OpenVZ kernels) is in use in Owl-current, such as in the 2011/03/12 LiveCD ISOs: http://mirrors.kernel.org/openwall/Owl/current/iso/ Initially this functionality was written by Pavel Kankovsky for Linux 2.4.32, but unfortunately it was never made public. All ping options (-b, -p, -Q, -R, -s, -t, -T, -M, -I), are tested with the patch. PATCH v3: - switched to flowi4. - minor changes to be consistent with raw sockets code. PATCH v2: - changed ping_debug() to pr_debug(). - removed CONFIG_IP_PING. - removed ping_seq_fops.owner field (unused for procfs). - switched to proc_net_fops_create(). - switched to %pK in seq_printf(). PATCH v1: - fixed checksumming bug. - CAP_NET_RAW may not create icmp sockets anymore. RFC v2: - minor cleanups. - introduced sysctl'able group range to restrict socket(2). Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13bonding,llc: Fix structure sizeof incompatibility for some PDUsVitalii Demianets
With some combinations of arch/compiler (e.g. arm-linux-gcc) the sizeof operator on structure returns value greater than expected. In cases when the structure is used for mapping PDU fields it may lead to unexpected results (such as holes and alignment problems in skb data). __packed prevents this undesired behavior. Signed-off-by: Vitalii Demianets <vitas@nppfactor.kiev.ua> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12ipv6: restore correct ECN handling on TCP xmitSteinar H. Gunderson
Since commit e9df2e8fd8fbc9 (Use appropriate sock tclass setting for routing lookup) we lost ability to properly add ECN codemarks to ipv6 TCP frames. It seems like TCP_ECN_send() calls INET_ECN_xmit(), which only sets the ECN bit in the IPv4 ToS field (inet_sk(sk)->tos), but after the patch, what's checked is inet6_sk(sk)->tclass, which is a completely different field. Close bug https://bugzilla.kernel.org/show_bug.cgi?id=34322 [Eric Dumazet] : added the INET_ECN_dontxmit() fix and replace macros by inline functions for clarity. Signed-off-by: Steinar H. Gunderson <sgunderson@bigfoot.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12ipvs: Remove all remaining references to rt->rt_{src,dst}Julian Anastasov
Remove all remaining references to rt->rt_{src,dst} by using dest->dst_saddr to cache saddr (used for TUN mode). For ICMP in FORWARD hook just restrict the rt_mode for NAT to disable LOCALNODE. All other modes do not allow IP_VS_RT_MODE_RDR, so we should be safe with the ICMP forwarding. Using cp->daddr as replacement for rt_dst is safe for all modes except BYPASS, even when cp->dest is NULL because it is cp->daddr that is used to assign cp->dest for sync-ed connections. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12garp: remove last synchronize_rcu() callEric Dumazet
When removing last vlan from a device, garp_uninit_applicant() calls synchronize_rcu() to make sure no user can still manipulate struct garp_applicant before we free it. Use call_rcu() instead, as a step to further net_device dismantle optimizations. Add the temporary garp_cleanup_module() function to make sure no pending call_rcu() are left at module unload time [ this will be removed when kfree_rcu() is available ] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12cfg80211/mac80211: avoid bounce back mac->cfg->mac on sched_scan_stoppedLuciano Coelho
When sched_scan_stopped was called by the driver, mac80211 calls cfg80211, which in turn was calling mac80211 back with a flag "driver_initiated". This flag was used so that mac80211 would do the necessary cleanup but would not call the driver. This was enough to prevent the bounce back between the driver and mac80211, but not between mac80211 and cfg80211. To fix this, we now do the cleanup in mac80211 before calling cfg80211. To help with locking issues, the workqueue was moved from cfg80211 to mac80211. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
