path: root/include/net
2008-04-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: iwlwifi: Allow building iwl3945 without iwl4965. wireless: Fix compile error with wifi & leds tcp: Fix slab corruption with ipv6 and tcp6fuzz ipv4/ipv6 compat: Fix SSM applications on 64bit kernels. [IPSEC]: Use digest_null directly for auth sunrpc: fix missing kernel-doc can: Fix copy_from_user() results interpretation Revert "ipv6: Fix typo in net/ipv6/Kconfig" tipc: endianness annotations ipv6: result of csum_fold() is already 16bit, no need to cast [XFRM] AUDIT: Fix flowlabel text format ambibuity.
2008-04-27ipv4/ipv6 compat: Fix SSM applications on 64bit kernels.David L Stevens
Add support on 64-bit kernels for seting 32-bit compatible MCAST* socket options. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23IPv6 support for NFS server export cachesAurélien Charbon
This adds IPv6 support to the interfaces that are used to express nfsd exports. All addressed are stored internally as IPv6; backwards compatibility is maintained using mapped addresses. Thanks to Bruce Fields, Brian Haley, Neil Brown and Hideaki Joshifuji for comments Signed-off-by: Aurelien Charbon <aurelien.charbon@bull.net> Cc: Neil Brown <neilb@suse.de> Cc: Brian Haley <brian.haley@hp.com> Cc: YOSHIFUJI Hideaki / 吉藤英明 <yoshfuji@linux-ipv6.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-22[IPSEC]: Fix catch-22 with algorithm IDs above 31Herbert Xu
As it stands it's impossible to use any authentication algorithms with an ID above 31 portably. It just happens to work on x86 but fails miserably on ppc64. The reason is that we're using a bit mask to check the algorithm ID but the mask is only 32 bits wide. After looking at how this is used in the field, I have concluded that in the long term we should phase out state matching by IDs because this is made superfluous by the reqid feature. For current applications, the best solution IMHO is to allow all algorithms when the bit masks are all ~0. The following patch does exactly that. This bug was identified by IBM when testing on the ppc64 platform using the NULL authentication algorithm which has an ID of 251. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-17[INET]: Uninline the __inet_inherit_port call.Pavel Emelyanov
This deblats ~200 bytes when ipv6 and dccp are 'y'. Besides, this will ease compilation issues for patches I'm working on to make inet hash tables more scalable wrt net namespaces. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-17[INET]: Drop the inet_inherit_port() call.Pavel Emelyanov
As I can see from the code, two places (tcp_v6_syn_recv_sock and dccp_v6_request_recv_sock) that call this one already run with BHs disabled, so it's safe to call __inet_inherit_port there. Besides (in case I missed smth with code review) the calltrace tcp_v6_syn_recv_sock `- tcp_v4_syn_recv_sock `- __inet_inherit_port and the similar for DCCP are valid, but assumes BHs to be disabled. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16mac80211: no BSS changes to driver from beacons processed during scanningReinette Chatre
There is no need to send BSS changes to driver from beacons processed during scanning. We are more interested in beacons from an AP with which we are associated - these will still be used to send updates to driver as the beacons are received without scanning. This change·removes the requirement that bss_info_changed needs to be atomic. The beacons received during scanning are processed from a tasklet, but if we do not call bss_info_changed for these beacons there is no need for it to be atomic. This function (bss_info_changed) is called either from workqueue or ioctl in all other instances. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Acked-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16[TCP]: Increase the max_burst threshold from 3 to tp->reordering.John Heffner
This change is necessary to allow cwnd to grow during persistent reordering. Cwnd moderation is applied when in the disorder state and an ack that fills the hole comes in. If the hole was greater than 3 packets, but less than tp->reordering, cwnd will shrink when it should not have. Signed-off-by: John Heffner <jheffner@napa.(none)> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[NETNS]: Add netns refcnt debug to fib rules.Denis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[NETNS]: Add netns refcnt debug for kernel sockets.Denis V. Lunev
Protocol control sockets and netlink kernel sockets should not prevent the namespace stop request. They are initialized and disposed in a special way by sk_change_net/sk_release_kernel. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[NETNS]: Make netns refconting debug like a socket one.Denis V. Lunev
Make release_net/hold_net noop for performance-hungry people. This is a debug staff and should be used in the debug mode only. Add check for net != NULL in hold/release calls. This will be required later on. [ Added minor simplifications suggested by Brian Haley. -DaveM ] Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[RTNL]: Introduce the rtnl_kill_links helper.Pavel Emelyanov
This one is responsible for calling ->dellink on each net device found in net to help with vlan net_exit hook in the nearest future. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[NETNS]: The generic per-net pointers.Pavel Emelyanov
Add the elastic array of void * pointer to the struct net. The access rules are simple: 1. register the ops with register_pernet_gen_device to get the id of your private pointer 2. call net_assign_generic() to put the private data on the struct net (most preferably this should be done in the ->init callback of the ops registered) 3. do not store any private reference on the net_generic array; 4. do not change this pointer while the net is alive; 5. use the net_generic() to get the pointer. When adding a new pointer, I copy the old array, replace it with a new one and schedule the old for kfree after an RCU grace period. Since the net_generic explores the net->gen array inside rcu read section and once set the net->gen->ptr[x] pointer never changes, this grants us a safe access to generic pointers. Quoting Paul: "... RCU is protecting -only- the net_generic structure that net_generic() is traversing, and the [pointer] returned by net_generic() is protected by a reference counter in the upper-level struct net." Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[NETNS]: The net-subsys IDs generator.Pavel Emelyanov
To make some per-net generic pointers, we need some way to address them, i.e. - IDs. This is simple IDA-based IDs generator for pernet subsystems. Addressing questions about potential checkpoint/restart problems: these IDs are "lite-offsets" within the net structure and are by no means supposed to be exported to the userspace. Since it will be used in the nearest future by devices only (tun, vlan, tunnels, bridge, etc), I make it resemble the functionality of register_pernet_device(). The new ids is stored in the *id pointer _before_ calling the init callback to make this id available in this callback. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[IRDA]: Remove irlan_eth_send_gratuitous_arp()Adrian Bunk
Even kernel 2.2.26 (sic) already contains the #undef CONFIG_IRLAN_SEND_GRATUITOUS_ARP with the comment "but for some reason the machine crashes if you use DHCP". Either someone finally looks into this or it's simply time to remove this dead code. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Overhaul of socket locking logicAllan Stephens
This patch modifies TIPC's socket code to follow the same approach used by other protocols. This change eliminates the need for a mutex in the TIPC-specific portion of the socket protocol data structure -- in its place, the standard Linux socket backlog queue and associated locking routines are utilized. These changes fix a long-standing receive queue bug on SMP systems, and also enable individual read and write threads to utilize a socket without unnecessarily interfering with each other. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6.26
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-14[NETFILTER]: nf_conntrack: replace NF_CT_DUMP_TUPLE macro indrection by ↵Jan Engelhardt
function call Directly call IPv4 and IPv6 variants where the address family is easily known. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_nat: use bool type in nf_nat_protoJan Engelhardt
2008-04-14[NETFILTER]: nf_conntrack: use bool type in struct nf_conntrack_tuple.hJan Engelhardt
2008-04-14[NETFILTER]: nf_conntrack: use bool type in struct nf_conntrack_l4protoJan Engelhardt
2008-04-14[NETFILTER]: nf_conntrack: use bool type in struct nf_conntrack_l3protoJan Engelhardt
2008-04-14[NETFILTER]: Remove unused callbacks in nf_conntrack_l3protoJan Engelhardt
These functions are never called. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: add tuplehash l3num/protonum accessorsPatrick McHardy
Add accessors for l3num and protonum and get rid of some overly long expressions. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_nat: kill helper and seq_adjust hooksPatrick McHardy
Connection tracking helpers (specifically FTP) need to be called before NAT sequence numbers adjustments are performed to be able to compare them against previously seen ones. We've introduced two new hooks around 2.6.11 to maintain this ordering when NAT modules were changed to get called from conntrack helpers directly. The cost of netfilter hooks is quite high and sequence number adjustments are only rarely needed however. Add a RCU-protected sequence number adjustment function pointer and call it from IPv4 conntrack after calling the helper. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack_extend: warn on confirmed conntracksPatrick McHardy
New extensions may only be added to unconfirmed conntracks to avoid races when reallocating the storage. Also change NF_CT_ASSERT to use WARN_ON to get backtraces. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_nat: don't add NAT extension for confirmed conntracksPatrick McHardy
Adding extensions to confirmed conntracks is not allowed to avoid races on reallocation. Don't setup NAT for confirmed conntracks in case NAT module is loaded late. The has one side-effect, the connections existing before the NAT module was loaded won't enter the bysource hash. The only case where this actually makes a difference is in case of SNAT to a multirange where the IP before NAT is also part of the range. Since old connections don't enter the bysource hash the first new connection from the IP will have a new address selected. This shouldn't matter at all. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: add DCCP protocol supportPatrick McHardy
Add DCCP conntrack helper. Thanks to Gerrit Renker <gerrit@erg.abdn.ac.uk> for review and testing. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_nat: remove unused name from struct nf_nat_protocolPatrick McHardy
2008-04-14[NETFILTER]: nf_nat: move NAT ctnetlink helpers to nf_nat_proto_commonPatrick McHardy
Move to nf_nat_proto_common and rename to nf_nat_proto_... since they're also used by protocols that don't have port numbers. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_nat: add helpers for common NAT protocol operationsPatrick McHardy
Add generic ->in_range and ->unique_tuple ops to avoid duplicating them again and again for future NAT modules and save a few bytes of text: net/ipv4/netfilter/nf_nat_proto_tcp.c: tcp_in_range | -62 (removed) tcp_unique_tuple | -259 # 271 -> 12, # inlines: 1 -> 0, size inlines: 7 -> 0 2 functions changed, 321 bytes removed net/ipv4/netfilter/nf_nat_proto_udp.c: udp_in_range | -62 (removed) udp_unique_tuple | -259 # 271 -> 12, # inlines: 1 -> 0, size inlines: 7 -> 0 2 functions changed, 321 bytes removed net/ipv4/netfilter/nf_nat_proto_gre.c: gre_in_range | -62 (removed) 1 function changed, 62 bytes removed vmlinux: 5 functions changed, 704 bytes removed Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[SKB]: __skb_append = __skb_queue_after Gerrit Renker
This expresses __skb_append in terms of __skb_queue_after, exploiting that __skb_append(old, new, list) = __skb_queue_after(list, old, new). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[IPV6]: Use appropriate sock tclass setting for routing lookup.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[NETNS][DCCPV6]: Move the dccp_v6_ctl_sk on the struct net.Pavel Emelyanov
And replace all its usage with init_net's socket. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[NETNS][DCCPV4]: Move the dccp_v4_ctl_sk on the struct net.Pavel Emelyanov
2008-04-13[NETNS]: Add an empty netns_dccp structure on struct net.Pavel Emelyanov
According to the overall struct net design, it will be filled with DCCP-related members. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[TCP]: Remove owner from tcp_seq_afinfo.Denis V. Lunev
Move it to tcp_seq_afinfo->seq_fops as should be. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[TCP]: Place file operations directly into tcp_seq_afinfo.Denis V. Lunev
No need to have separate never-used variable. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[TCP]: Move seq_ops from tcp_iter_state to tcp_seq_afinfo.Denis V. Lunev
No need to create seq_operations for each instance of 'netstat'. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[TCP]: Replace struct net on tcp_iter_state with seq_net_private.Denis V. Lunev
2008-04-12Merge branch 'net-2.6.26-misc-20080412b' of ↵David S. Miller
git://git.linux-ipv6.org/gitroot/yoshfuji/linux-2.6-dev
2008-04-12NetLabel: Allow passing the LSM domain as a shared pointerPaul Moore
Smack doesn't have the need to create a private copy of the LSM "domain" when setting NetLabel security attributes like SELinux, however, the current NetLabel code requires a private copy of the LSM "domain". This patches fixes that by letting the LSM determine how it wants to pass the domain value. * NETLBL_SECATTR_DOMAIN_CPY The current behavior, NetLabel assumes that the domain value is a copy and frees it when done * NETLBL_SECATTR_DOMAIN New, Smack-friendly behavior, NetLabel assumes that the domain value is a reference to a string managed by the LSM and does not free it when done Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[SCTP]: Fix compiler warning about const qualifiersVlad Yasevich
Fix 3 warnings about discarding const qualifiers: net/sctp/ulpevent.c:862: warning: passing argument 1 of 'sctp_event2skb' discards qualifiers from pointer target type net/sctp/sm_statefuns.c:4393: warning: passing argument 1 of 'SCTP_ASOC' discards qualifiers from pointer target type net/sctp/socket.c:5874: warning: passing argument 1 of 'cmsg_nxthdr' discards qualifiers from pointer target type Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[SCTP]: Fix protocol violation when receiving an error lenght INIT-ACKGui Jianfeng
When receiving an error length INIT-ACK during COOKIE-WAIT, a 0-vtag ABORT will be responsed. This action violates the protocol apparently. This patch achieves the following things. 1 If the INIT-ACK contains all the fixed parameters, use init-tag recorded from INIT-ACK as vtag. 2 If the INIT-ACK doesn't contain all the fixed parameters, just reflect its vtag. Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[IPV6] MIP6: Use our standard definitions for paddings.YOSHIFUJI Hideaki
MIP6_OPT_PAD_X are actually for paddings in destination option header. Replace them with our standard IPV6_TLV_PADX. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-12[IPV6]: Define constants for link-local multicast addresses.YOSHIFUJI Hideaki
- Define link-local all-node / all-router multicast addresses. - Remove ipv6_addr_all_nodes() and ipv6_addr_all_routers(). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-12[IPV6]: Make address arguments const.YOSHIFUJI Hideaki
- net/ipv6/addrconf.c: ipv6_get_ifaddr(), ipv6_dev_get_saddr() - net/ipv6/mcast.c: ipv6_sock_mc_join(), ipv6_sock_mc_drop(), inet6_mc_check(), ipv6_dev_mc_inc(), __ipv6_dev_mc_dec(), ipv6_dev_mc_dec(), ipv6_chk_mcast_addr() - net/ipv6/route.c: rt6_lookup(), icmp6_dst_alloc() - net/ipv6/ip6_output.c: ip6_nd_hdr() - net/ipv6/ndisc.c: ndisc_send_ns(), ndisc_send_rs(), ndisc_send_redirect(), ndisc_get_neigh(), __ndisc_send() Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-12[IPV6] ADDRCONF: Uninline ipv6_isatap_eui64().YOSHIFUJI Hideaki
2008-04-12[IPV6] ADDRCONF: Uninline ipv6_addr_hash().YOSHIFUJI Hideaki
The function is only used in net/ipv6/addrconf.c. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
