path: root/include/net/tcp.h
2010-09-15tcp: Prevent overzealous packetization by SWS logic.Alexey Kuznetsov
If peer uses tiny MSS (say, 75 bytes) and similarly tiny advertised window, the SWS logic will packetize to half the MSS unnecessarily. This causes problems with some embedded devices. However for large MSS devices we do want to half-MSS packetize otherwise we never get enough packets into the pipe for things like fast retransmit and recovery to work. Be careful also to handle the case where MSS > window, otherwise we'll never send until the probe timer. Reported-by: ツ Leandro Melo de Sales <leandroal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25tcp: Combat per-cpu skew in orphan tests.David S. Miller
As reported by Anton Blanchard when we use percpu_counter_read_positive() to make our orphan socket limit checks, the check can be off by up to num_cpus_online() * batch (which is 32 by default) which on a 128 cpu machine can be as large as the default orphan limit itself. Fix this by doing the full expensive sum check if the optimized check triggers. Reported-by: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2010-07-15tcp: sizeof struct tcp_skb_cb is 44Eric Dumazet
Correct comment stating sizeof(struct tcp_skb_cb) is 36 or 40, since its 44 bytes, since commit 951dbc8ac714b04 ([IPV6]: Move nextheader offset to the IP6CB). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12inet, inet6: make tcp_sendmsg() and tcp_sendpage() through inet_sendmsg() ↵Changli Gao
and inet_sendpage() a new boolean flag no_autobind is added to structure proto to avoid the autobind calls when the protocol is TCP. Then sock_rps_record_flow() is called int the TCP's sendmsg() and sendpage() pathes. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- include/net/inet_common.h | 4 ++++ include/net/sock.h | 1 + include/net/tcp.h | 8 ++++---- net/ipv4/af_inet.c | 15 +++++++++------ net/ipv4/tcp.c | 11 +++++------ net/ipv4/tcp_ipv4.c | 3 +++ net/ipv6/af_inet6.c | 8 ++++---- net/ipv6/tcp_ipv6.c | 3 +++ 8 files changed, 33 insertions(+), 20 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net: cleanupsChangli Gao
remove useless blanks. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- include/net/inet_common.h | 55 ++++------- include/net/tcp.h | 222 +++++++++++++++++----------------------------- include/net/udp.h | 38 +++---- 3 files changed, 123 insertions(+), 192 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-26syncookies: add support for ECNFlorian Westphal
Allows use of ECN when syncookies are in effect by encoding ecn_ok into the syn-ack tcp timestamp. While at it, remove a uneeded #ifdef CONFIG_SYN_COOKIES. With CONFIG_SYN_COOKIES=nm want_cookie is ifdef'd to 0 and gcc removes the "if (0)". Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16syncookies: check decoded options against sysctl settingsFlorian Westphal
Discard the ACK if we find options that do not match current sysctl settings. Previously it was possible to create a connection with sack, wscale, etc. enabled even if the feature was disabled via sysctl. Also remove an unneeded call to tcp_sack_reset() in cookie_check_timestamp: Both call sites (cookie_v4_check, cookie_v6_check) zero "struct tcp_options_received", hand it to tcp_parse_options() (which does not change tcp_opt->num_sacks/dsack) and then call cookie_check_timestamp(). Even if num_sacks/dsacks were changed, the structure is allocated on the stack and after cookie_check_timestamp returns only a few selected members are copied to the inet_request_sock. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15tcp: unify tcp flag macrosChangli Gao
unify tcp flag macros: TCPHDR_FIN, TCPHDR_SYN, TCPHDR_RST, TCPHDR_PSH, TCPHDR_ACK, TCPHDR_URG, TCPHDR_ECE and TCPHDR_CWR. TCBCB_FLAG_* are replaced with the corresponding TCPHDR_*. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- include/net/tcp.h | 24 ++++++------- net/ipv4/tcp.c | 8 ++-- net/ipv4/tcp_input.c | 2 - net/ipv4/tcp_output.c | 59 ++++++++++++++++----------------- net/netfilter/nf_conntrack_proto_tcp.c | 32 ++++++----------- net/netfilter/xt_TCPMSS.c | 4 -- 6 files changed, 58 insertions(+), 71 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-07tcp: Fix slowness in read /proc/net/tcpTom Herbert
This patch address a serious performance issue in reading the TCP sockets table (/proc/net/tcp). Reading the full table is done by a number of sequential read operations. At each read operation, a seek is done to find the last socket that was previously read. This seek operation requires that the sockets in the table need to be counted up to the current file position, and to count each of these requires taking a lock for each non-empty bucket. The whole algorithm is O(n^2). The fix is to cache the last bucket value, offset within the bucket, and the file position returned by the last read operation. On the next sequential read, the bucket and offset are used to find the last read socket immediately without needing ot scan the previous buckets the table. This algorithm t read the whole table is O(n). The improvement offered by this patch is easily show by performing cat'ing /proc/net/tcp on a machine with a lot of connections. With about 182K connections in the table, I see the following: - Without patch time cat /proc/net/tcp > /dev/null real 1m56.729s user 0m0.214s sys 1m56.344s - With patch time cat /proc/net/tcp > /dev/null real 0m0.894s user 0m0.290s sys 0m0.594s Signed-off-by: Tom Herbert <therbert@google.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: include/linux/if_link.h
2010-05-16tcp: fix MD5 (RFC2385) supportEric Dumazet
TCP MD5 support uses percpu data for temporary storage. It currently disables preemption so that same storage cannot be reclaimed by another thread on same cpu. We also have to make sure a softirq handler wont try to use also same context. Various bug reports demonstrated corruptions. Fix is to disable preemption and BH. Reported-by: Bhaskar Dutta <bhaskie@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27TCP: avoid to send keepalive probes if receiving dataFlavio Leitner
RFC 1122 says the following: ... Keep-alive packets MUST only be sent when no data or acknowledgement packets have been received for the connection within an interval. ... The acknowledgement packet is reseting the keepalive timer but the data packet isn't. This patch fixes it by checking the timestamp of the last received data packet too when the keepalive timer expires. Signed-off-by: Flavio Leitner <fleitner@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22tcp: fix outsegs stat for TSO segmentsTom Herbert
Account for TSO segments of an skb in TCP_MIB_OUTSEGS counter. Without doing this, the counter can be off by orders of magnitude from the actual number of segments sent. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11inet: Remove unused send_check length argumentHerbert Xu
inet: Remove unused send_check length argument This patch removes the unused length argument from the send_check function in struct inet_connection_sock_af_ops. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Yinghai <yinghai.lu@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-04net: add scheduler sync hint to tcp_prequeue().Mike Galbraith
Decreases the odds wakee will suffer from frequent cache misses. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18net: TCP thin dupackAndreas Petlund
This patch enables fast retransmissions after one dupACK for TCP if the stream is identified as thin. This will reduce latencies for thin streams that are not able to trigger fast retransmissions due to high packet interarrival time. This mechanism is only active if enabled by iocontrol or syscontrol and the stream is identified as thin. Signed-off-by: Andreas Petlund <apetlund@simula.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18net: TCP thin linear timeoutsAndreas Petlund
This patch will make TCP use only linear timeouts if the stream is thin. This will help to avoid the very high latencies that thin stream suffer because of exponential backoff. This mechanism is only active if enabled by iocontrol or syscontrol and the stream is identified as thin. A maximum of 6 linear timeouts is tried before exponential backoff is resumed. Signed-off-by: Andreas Petlund <apetlund@simula.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18net: TCP thin-stream detectionAndreas Petlund
Inline function to dynamically detect thin streams based on the number of packets in flight. Used to dynamically trigger thin-stream mechanisms if enabled by ioctl or sysctl. Signed-off-by: Andreas Petlund <apetlund@simula.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16percpu: add __percpu sparse annotations to netTejun Heo
Add __percpu sparse annotations to net. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. The macro and type tricks around snmp stats make things a bit interesting. DEFINE/DECLARE_SNMP_STAT() macros mark the target field as __percpu and SNMP_UPD_PO_STATS() macro is updated accordingly. All snmp_mib_*() users which used to cast the argument to (void **) are updated to cast it to (void __percpu **). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17tcp: account SYN-ACK timeouts & retransmissionsOctavian Purdila
Currently we don't increment SYN-ACK timeouts & retransmissions although we do increment the same stats for SYN. We seem to have lost the SYN-ACK accounting with the introduction of tcp_syn_recv_timer (commit 2248761e in the netdev-vger-cvs tree). This patch fixes this issue. In the process we also rename the v4/v6 syn/ack retransmit functions for clarity. We also add a new request_socket operations (syn_ack_timeout) so we can keep code in inet_connection_sock.c protocol agnostic. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23net: Add rtnetlink init_rcvwnd to set the TCP initial receive windowlaurent chavey
Add rtnetlink init_rcvwnd to set the TCP initial receive window size advertised by passive and active TCP connections. The current Linux TCP implementation limits the advertised TCP initial receive window to the one prescribed by slow start. For short lived TCP connections used for transaction type of traffic (i.e. http requests), bounding the advertised TCP initial receive window results in increased latency to complete the transaction. Support for setting initial congestion window is already supported using rtnetlink init_cwnd, but the feature is useless without the ability to set a larger TCP initial receive window. The rtnetlink init_rcvwnd allows increasing the TCP initial receive window, allowing TCP connection to advertise larger TCP receive window than the ones bounded by slow start. Signed-off-by: Laurent Chavey <chavey@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23tcp: Remove check in __tcp_push_pending_framesKrishna Kumar
tcp_push checks tcp_send_head and calls __tcp_push_pending_frames, which again checks tcp_send_head, and this unnecessary check is done for every other caller of __tcp_push_pending_frames. Remove tcp_send_head check in __tcp_push_pending_frames and add the check to tcp_push_pending_frames. Other functions call __tcp_push_pending_frames only when tcp_send_head would evaluate to true. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15tcp: Revert per-route SACK/DSACK/TIMESTAMP changes.David S. Miller
It creates a regression, triggering badness for SYN_RECV sockets, for example: [19148.022102] Badness at net/ipv4/inet_connection_sock.c:293 [19148.022570] NIP: c02a0914 LR: c02a0904 CTR: 00000000 [19148.023035] REGS: eeecbd30 TRAP: 0700 Not tainted (2.6.32) [19148.023496] MSR: 00029032 <EE,ME,CE,IR,DR> CR: 24002442 XER: 00000000 [19148.024012] TASK = eee9a820[1756] 'privoxy' THREAD: eeeca000 This is likely caused by the change in the 'estab' parameter passed to tcp_parse_options() when invoked by the functions in net/ipv4/tcp_minisocks.c But even if that is fixed, the ->conn_request() changes made in this patch series is fundamentally wrong. They try to use the listening socket's 'dst' to probe the route settings. The listening socket doesn't even have a route, and you can't get the right route (the child request one) until much later after we setup all of the state, and it must be done by hand. This stuff really isn't ready, so the best thing to do is a full revert. This reverts the following commits: f55017a93f1a74d50244b1254b9a2bd7ac9bbf7d 022c3f7d82f0f1c68018696f2f027b87b9bb45c2 1aba721eba1d84a2defce45b950272cee1e6c72a cda42ebd67ee5fdf09d7057b5a4584d36fe8a335 345cda2fd695534be5a4494f1b59da9daed33663 dc343475ed062e13fc260acccaab91d7d80fd5b2 05eaade2782fb0c90d3034fd7a7d5a16266182bb 6a2a2d6bf8581216e08be15fcb563cfd6c430e1e Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: include/net/tcp.h
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-08tcp: Stalling connections: Move timeout calculation routineDamian Lukowski
This patch moves retransmits_timed_out() from include/net/tcp.h to tcp_timer.c, where it is used. Reported-by: Frederic Leroy <fredo@starox.org> Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08tcp: Stalling connections: Fix timeout calculation routineDamian Lukowski
This patch fixes a problem in the TCP connection timeout calculation. Currently, timeout decisions are made on the basis of the current tcp_time_stamp and retrans_stamp, which is usually set at the first retransmission. However, if the retransmission fails in tcp_retransmit_skb(), retrans_stamp is not updated and remains zero. This leads to wrong decisions in retransmits_timed_out() if tcp_time_stamp is larger than the specified timeout, which is very likely. In this case, the TCP connection dies after the first attempted (and unsuccessful) retransmission. With this patch, tcp_skb_cb->when is used instead, when retrans_stamp is not available. This bug has been introduced together with retransmits_timed_out() in 2.6.32, as the number of retransmissions has been used for timeout decisions before. The corresponding commit was 6fa12c85031485dff38ce550c24f10da23b0adaa (Revert Backoff [v3]: Calculate TCP's connection close threshold as a time value.). Thanks to Ilpo Järvinen for code suggestions and Frederic Leroy for testing. Reported-by: Frederic Leroy <fredo@starox.org> Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-02tcp: clear hints to avoid a stale one (nfs only affected?)Ilpo Järvinen
Eric Dumazet mentioned in a context of another problem: "Well, it seems NFS reuses its socket, so maybe we miss some cleaning as spotted in this old patch" I've not check under which conditions that actually happens but if true, we need to make sure we don't accidently leave stale hints behind when the write queue had to be purged (whether reusing with NFS can actually happen if purging took place is something I'm not sure of). ...At least it compiles. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1g: Responder Cookie => InitiatorWilliam Allen Simpson
Parse incoming TCP_COOKIE option(s). Calculate <SYN,ACK> TCP_COOKIE option. Send optional <SYN,ACK> data. This is a significantly revised implementation of an earlier (year-old) patch that no longer applies cleanly, with permission of the original author (Adam Langley): http://thread.gmane.org/gmane.linux.network/102586 Requires: TCPCT part 1a: add request_values parameter for sending SYNACK TCPCT part 1b: generate Responder Cookie secret TCPCT part 1c: sysctl_tcp_cookie_size, socket option TCP_COOKIE_TRANSACTIONS TCPCT part 1d: define TCP cookie option, extend existing struct's TCPCT part 1e: implement socket option TCP_COOKIE_TRANSACTIONS TCPCT part 1f: Initiator Cookie => Responder Signed-off-by: William.Allen.Simpson@gmail.com Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1d: define TCP cookie option, extend existing struct'sWilliam Allen Simpson
Data structures are carefully composed to require minimal additions. For example, the struct tcp_options_received cookie_plus variable fits between existing 16-bit and 8-bit variables, requiring no additional space (taking alignment into consideration). There are no additions to tcp_request_sock, and only 1 pointer in tcp_sock. This is a significantly revised implementation of an earlier (year-old) patch that no longer applies cleanly, with permission of the original author (Adam Langley): http://thread.gmane.org/gmane.linux.network/102586 The principle difference is using a TCP option to carry the cookie nonce, instead of a user configured offset in the data. This is more flexible and less subject to user configuration error. Such a cookie option has been suggested for many years, and is also useful without SYN data, allowing several related concepts to use the same extension option. "Re: SYN floods (was: does history repeat itself?)", September 9, 1996. http://www.merit.net/mail.archives/nanog/1996-09/msg00235.html "Re: what a new TCP header might look like", May 12, 1998. ftp://ftp.isi.edu/end2end/end2end-interest-1998.mail These functions will also be used in subsequent patches that implement additional features. Requires: TCPCT part 1a: add request_values parameter for sending SYNACK TCPCT part 1b: generate Responder Cookie secret TCPCT part 1c: sysctl_tcp_cookie_size, socket option TCP_COOKIE_TRANSACTIONS Signed-off-by: William.Allen.Simpson@gmail.com Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1c: sysctl_tcp_cookie_size, socket option TCP_COOKIE_TRANSACTIONSWilliam Allen Simpson
Define sysctl (tcp_cookie_size) to turn on and off the cookie option default globally, instead of a compiled configuration option. Define per socket option (TCP_COOKIE_TRANSACTIONS) for setting constant data values, retrieving variable cookie values, and other facilities. Move inline tcp_clear_options() unchanged from net/tcp.h to linux/tcp.h, near its corresponding struct tcp_options_received (prior to changes). This is a straightforward re-implementation of an earlier (year-old) patch that no longer applies cleanly, with permission of the original author (Adam Langley): http://thread.gmane.org/gmane.linux.network/102586 These functions will also be used in subsequent patches that implement additional features. Requires: net: TCP_MSS_DEFAULT, TCP_MSS_DESIRED Signed-off-by: William.Allen.Simpson@gmail.com Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1b: generate Responder Cookie secretWilliam Allen Simpson
Define (missing) hash message size for SHA1. Define hashing size constants specific to TCP cookies. Add new function: tcp_cookie_generator(). Maintain global secret values for tcp_cookie_generator(). This is a significantly revised implementation of earlier (15-year-old) Photuris [RFC-2522] code for the KA9Q cooperative multitasking platform. Linux RCU technique appears to be well-suited to this application, though neither of the circular queue items are freed. These functions will also be used in subsequent patches that implement additional features. Signed-off-by: William.Allen.Simpson@gmail.com Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1a: add request_values parameter for sending SYNACKWilliam Allen Simpson
Add optional function parameters associated with sending SYNACK. These parameters are not needed after sending SYNACK, and are not used for retransmission. Avoids extending struct tcp_request_sock, and avoids allocating kernel memory. Also affects DCCP as it uses common struct request_sock_ops, but this parameter is currently reserved for future use. Signed-off-by: William.Allen.Simpson@gmail.com Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13net: TCP_MSS_DEFAULT, TCP_MSS_DESIREDWilliam Allen Simpson
Define two symbols needed in both kernel and user space. Remove old (somewhat incorrect) kernel variant that wasn't used in most cases. Default should apply to both RMSS and SMSS (RFC2581). Replace numeric constants with defined symbols. Stand-alone patch, originally developed for TCPCT. Signed-off-by: William.Allen.Simpson@gmail.com Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/netEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow tcp_parse_options to consult dst entryGilad Ben-Yossef
We need tcp_parse_options to be aware of dst_entry to take into account per dst_entry TCP options settings Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15tcp: fix ssthresh u16 leftoverIlpo Järvinen
It was once upon time so that snd_sthresh was a 16-bit quantity. ...That has not been true for long period of time. I run across some ancient compares which still seem to trust such legacy. Put all that magic into a single place, I hopefully found all of them. Compile tested, though linking of allyesconfig is ridiculous nowadays it seems. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tcp: replace hard coded GFP_KERNEL with sk_allocationWu Fengguang
This fixed a lockdep warning which appeared when doing stress memory tests over NFS: inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage. page reclaim => nfs_writepage => tcp_sendmsg => lock sk_lock mount_root => nfs_root_data => tcp_close => lock sk_lock => tcp_send_fin => alloc_skb_fclone => page reclaim David raised a concern that if the allocation fails in tcp_send_fin(), and it's GFP_ATOMIC, we are going to yield() (which sleeps) and loop endlessly waiting for the allocation to succeed. But fact is, the original GFP_KERNEL also sleeps. GFP_ATOMIC+yield() looks weird, but it is no worse the implicit sleep inside GFP_KERNEL. Both could loop endlessly under memory pressure. CC: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> CC: David S. Miller <davem@davemloft.net> CC: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01RTO connection timeout: coding style fixes and commentsDamian Lukowski
This patch affects the retransmits_timed_out() function. Changes: 1) Variables have more meaningful names 2) retransmits_timed_out() has an introductionary comment. 3) Small coding style changes. Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01Revert Backoff [v3]: Calculate TCP's connection close threshold as a time value.Damian Lukowski
RFC 1122 specifies two threshold values R1 and R2 for connection timeouts, which may represent a number of allowed retransmissions or a timeout value. Currently linux uses sysctl_tcp_retries{1,2} to specify the thresholds in number of allowed retransmissions. For any desired threshold R2 (by means of time) one can specify tcp_retries2 (by means of number of retransmissions) such that TCP will not time out earlier than R2. This is the case, because the RTO schedule follows a fixed pattern, namely exponential backoff. However, the RTO behaviour is not predictable any more if RTO backoffs can be reverted, as it is the case in the draft "Make TCP more Robust to Long Connectivity Disruptions" (http://tools.ietf.org/html/draft-zimmermann-tcp-lcd). In the worst case TCP would time out a connection after 3.2 seconds, if the initial RTO equaled MIN_RTO and each backoff has been reverted. This patch introduces a function retransmits_timed_out(N), which calculates the timeout of a TCP connection, assuming an initial RTO of MIN_RTO and N unsuccessful, exponentially backed-off retransmissions. Whenever timeout decisions are made by comparing the retransmission counter to some value N, this function can be used, instead. The meaning of tcp_retries2 will be changed, as many more RTO retransmissions can occur than the value indicates. However, it yields a timeout which is similar to the one of an unpatched, exponentially backing off TCP in the same scenario. As no application could rely on an RTO greater than MIN_RTO, there should be no risk of a regression. Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01Revert Backoff [v3]: Revert RTO on ICMP destination unreachableDamian Lukowski
Here, an ICMP host/network unreachable message, whose payload fits to TCP's SND.UNA, is taken as an indication that the RTO retransmission has not been lost due to congestion, but because of a route failure somewhere along the path. With true congestion, a router won't trigger such a message and the patched TCP will operate as standard TCP. This patch reverts one RTO backoff, if an ICMP host/network unreachable message, whose payload fits to TCP's SND.UNA, arrives. Based on the new RTO, the retransmission timer is reset to reflect the remaining time, or - if the revert clocked out the timer - a retransmission is sent out immediately. Backoffs are only reverted, if TCP is in RTO loss recovery, i.e. if there have been retransmissions and reversible backoffs, already. Changes from v2: 1) Renaming of skb in tcp_v4_err() moved to another patch. 2) Reintroduced tcp_bound_rto() and __tcp_set_rto(). 3) Fixed code comments. Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-28tcp: keepalive cleanupsEric Dumazet
Introduce keepalive_probes(tp) helper, and use it, like keepalive_time_when(tp) and keepalive_intvl_when(tp) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-20tcp: Fix MD5 signature checking on IPv4 mapped socketsJohn Dykstra
Fix MD5 signature checking so that an IPv4 active open to an IPv6 socket can succeed. In particular, use the correct address family's signature generation function for the SYN/ACK. Reported-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John Dykstra <john.dykstra1@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: include/net/tcp.h
2009-05-07tcp: tcp_prequeue() can use keyed wakeupsEric Dumazet
We can avoid waking up tasks not interested in receive notifications, using wake_up_interruptible_poll() instead of wake_up_interruptible() Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-07tcp: tcp_prequeue() cleanupEric Dumazet
Small cleanup patch to reduce line lengths, before a change in tcp_prequeue(). Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-04tcp: Fix tcp_prequeue() to get correct rto_min valueSatoru SATOH
tcp_prequeue() refers to the constant value (TCP_RTO_MIN) regardless of the actual value might be tuned. The following patches fix this and make tcp_prequeue get the actual value returns from tcp_rto_min(). Signed-off-by: Satoru SATOH <satoru.satoh@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
