path: root/include/net/sock.h
2006-07-03[PATCH] lockdep: annotate sk_locksIngo Molnar
Teach sk_lock semantics to the lock validator. In the softirq path the slock has mutex_trylock()+mutex_unlock() semantics, in the process context sock_lock() case it has mutex_lock()/mutex_unlock() semantics. Thus we treat sock_owned_by_user() flagged areas as an exclusion area too, not just those areas covered by a held sk_lock.slock. Effect on non-lockdep kernels: minimal, sk_lock_sock_init() has been turned into an inline function. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate bh_lock_sock()Ingo Molnar
Teach special (recursive) locking code to the lock validator. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate sock_lock_init()Ingo Molnar
Teach special (multi-initialized, per-address-family) locking code to the lock validator. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[NET]: Generalise TSO-specific bits from skb_setup_capsHerbert Xu
This patch generalises the TSO-specific bits from sk_setup_caps by adding the sk_gso_type member to struct sock. This makes sk_setup_caps generic so that it can be used by TCPv6 or UFO. The only catch is that whoever uses this must provide a GSO implementation for their protocol which I think is a fair deal :) For now UFO continues to live without a GSO implementation which is OK since it doesn't use the sock caps field at the moment. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[NET]: Add ECN support for TSOMichael Chan
In the current TSO implementation, NETIF_F_TSO and ECN cannot be turned on together in a TCP connection. The problem is that most hardware that supports TSO does not handle CWR correctly if it is set in the TSO packet. Correct handling requires CWR to be set in the first packet only if it is set in the TSO header. This patch adds the ability to turn on NETIF_F_TSO and ECN using GSO if necessary to handle TSO packets with CWR set. Hardware that handles CWR correctly can turn on NETIF_F_TSO_ECN in the dev-> features flag. All TSO packets with CWR set will have the SKB_GSO_TCPV4_ECN set. If the output device does not have the NETIF_F_TSO_ECN feature set, GSO will split the packet up correctly with CWR only set in the first segment. With help from Herbert Xu <herbert@gondor.apana.org.au>. Since ECN can always be enabled with TSO, the SOCK_NO_LARGESEND sock flag is completely removed. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[NET]: fix net-core kernel-docRandy Dunlap
Warning(/var/linsrc/linux-2617-g4//include/linux/skbuff.h:304): No description found for parameter 'dma_cookie' Warning(/var/linsrc/linux-2617-g4//include/net/sock.h:1274): No description found for parameter 'copied_early' Warning(/var/linsrc/linux-2617-g4//net/core/dev.c:3309): No description found for parameter 'chan' Warning(/var/linsrc/linux-2617-g4//net/core/dev.c:3309): No description found for parameter 'event' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[NET]: Added GSO toggleHerbert Xu
This patch adds a generic segmentation offload toggle that can be turned on/off for each net device. For now it only supports in TCPv4. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-20Merge git://git.infradead.org/hdrcleanup-2.6Linus Torvalds
* git://git.infradead.org/hdrcleanup-2.6: (63 commits) [S390] __FD_foo definitions. Switch to __s32 types in joystick.h instead of C99 types for consistency. Add <sys/types.h> to headers included for userspace in <linux/input.h> Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h Remove struct fddi_statistics from user view in <linux/if_fddi.h> Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390 Revert include/media changes: Mauro says those ioctls are only used in-kernel(!) Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h> Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too Remove private struct dx_hash_info from public view in <linux/ext3_fs.h> Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h> Use __uXX types in <linux/divert.h> for struct divert_blk et al. Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible. Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely Use __uXX types in user-visible structures in <linux/nbd.h> Don't use 'u32' in user-visible struct ip_conntrack_old_tuple. Use __uXX types for S390 DASD volume label definitions which are user-visible S390 BIODASDREADCMB ioctl should use __u64 not u64 type. Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h> Fix private integer types used in V4L2 ioctls. ... Manually resolve conflict in include/linux/mtd/physmap.h
2006-06-17[NET]: skb_trim auditHerbert Xu
I found a few more spots where pskb_trim_rcsum could be used but were not. This patch changes them to use it. Also, sk_filter can get paged skb data. Therefore we must use pskb_trim instead of skb_trim. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: Make sk_eat_skb I/OAT aware.Chris Leech
Add an extra argument to sk_eat_skb, and make it move early copied packets to the async_wait_queue instead of freeing them. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: Structure changes for TCP recv offload to I/OATChris Leech
Adds an async_wait_queue and some additional fields to tcp_sock, and a dma_cookie_t to sk_buff. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6David Woodhouse
2006-04-29[NET]: use hlist_unhashed()Akinobu Mita
Use hlist_unhashed() rather than accessing inside data structure. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-20[NET]: Add skb->truesize assertion checking.David S. Miller
Add some sanity checking. truesize should be at least sizeof(struct sk_buff) plus the current packet length. If not, then truesize is seriously mangled and deserves a kernel log message. Currently we'll do the check for release of stream socket buffers. But we can add checks to more spots over time. Incorporating ideas from Herbert Xu. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[NET]: deinline 200+ byte inlines in sock.hDenis Vlasenko
Sizes in bytes (allyesconfig, i386) and files where those inlines are used: 238 sock_queue_rcv_skb 2.6.16/net/x25/x25_in.o 238 sock_queue_rcv_skb 2.6.16/net/rose/rose_in.o 238 sock_queue_rcv_skb 2.6.16/net/packet/af_packet.o 238 sock_queue_rcv_skb 2.6.16/net/netrom/nr_in.o 238 sock_queue_rcv_skb 2.6.16/net/llc/llc_sap.o 238 sock_queue_rcv_skb 2.6.16/net/llc/llc_conn.o 238 sock_queue_rcv_skb 2.6.16/net/irda/af_irda.o 238 sock_queue_rcv_skb 2.6.16/net/ipx/af_ipx.o 238 sock_queue_rcv_skb 2.6.16/net/ipv6/udp.o 238 sock_queue_rcv_skb 2.6.16/net/ipv6/raw.o 238 sock_queue_rcv_skb 2.6.16/net/ipv4/udp.o 238 sock_queue_rcv_skb 2.6.16/net/ipv4/raw.o 238 sock_queue_rcv_skb 2.6.16/net/ipv4/ipmr.o 238 sock_queue_rcv_skb 2.6.16/net/econet/econet.o 238 sock_queue_rcv_skb 2.6.16/net/econet/af_econet.o 238 sock_queue_rcv_skb 2.6.16/net/bluetooth/sco.o 238 sock_queue_rcv_skb 2.6.16/net/bluetooth/l2cap.o 238 sock_queue_rcv_skb 2.6.16/net/bluetooth/hci_sock.o 238 sock_queue_rcv_skb 2.6.16/net/ax25/ax25_in.o 238 sock_queue_rcv_skb 2.6.16/net/ax25/af_ax25.o 238 sock_queue_rcv_skb 2.6.16/net/appletalk/ddp.o 238 sock_queue_rcv_skb 2.6.16/drivers/net/pppoe.o 276 sk_receive_skb 2.6.16/net/decnet/dn_nsp_in.o 276 sk_receive_skb 2.6.16/net/dccp/ipv6.o 276 sk_receive_skb 2.6.16/net/dccp/ipv4.o 276 sk_receive_skb 2.6.16/net/dccp/dccp_ipv6.o 276 sk_receive_skb 2.6.16/drivers/net/pppoe.o 209 sk_dst_check 2.6.16/net/ipv6/ip6_output.o 209 sk_dst_check 2.6.16/net/ipv4/udp.o 209 sk_dst_check 2.6.16/net/decnet/dn_nsp_out.o Large inlines with multiple callers: Size Uses Wasted Name and definition ===== ==== ====== ================================================ 238 21 4360 sock_queue_rcv_skb include/net/sock.h 109 10 801 sock_recv_timestamp include/net/sock.h 276 4 768 sk_receive_skb include/net/sock.h 94 8 518 __sk_dst_check include/net/sock.h 209 3 378 sk_dst_check include/net/sock.h 131 4 333 sk_setup_caps include/net/sock.h 152 2 132 sk_stream_alloc_pskb include/net/sock.h 125 2 105 sk_stream_writequeue_purge include/net/sock.h Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-24[NET]: Fill in a 32-bit hole in struct sock on 64-bit platforms.David S. Miller
This makes struct sock 8 bytes smaller on 64-bit. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: {get|set}sockopt compatibility layerDmitry Mishin
This patch extends {get|set}sockopt compatibility layer in order to move protocol specific parts to their place and avoid huge universal net/compat.c file in the future. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-17[NET]: Fix race condition in sk_wait_event().Alexey Kuznetsov
It is broken, the condition is checked out of socket lock. It is wonderful the bug survived for so long time. [ This fixes bugzilla #6233: race condition in tcp_sendmsg when connection became established ] Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-02[NET]: Add CONFIG_NETDEBUG to suppress bad packet messages.Stephen Hemminger
If you are on a hostile network, or are running protocol tests, you can easily get the logged swamped by messages about bad UDP and ICMP packets. This turns those messages off unless a config option is enabled. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-06[NET]: Change sk_run_filter()'s return type in net/core/filter.cKris Katterjohn
It should return an unsigned value, and fix sk_filter() as well. Signed-off-by: Kris Katterjohn <kjak@ispwest.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SOCK]: Introduce sk_receive_skbArnaldo Carvalho de Melo
Its common enough to to justify that, TCP still can't use it as it has the prequeueing stuff, still to be made generic in the not so distant future :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TWSK]: Introduce struct timewait_sock_opsArnaldo Carvalho de Melo
So that we can share several timewait sockets related functions and make the timewait mini sockets infrastructure closer to the request mini sockets one. Next changesets will take advantage of this, moving more code out of TCP and DCCP v4 and v6 to common infrastructure. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Avoid atomic xchg() for non-error caseBenjamin LaHaise
It also looks like there were 2 places where the test on sk_err was missing from the event wait logic (in sk_stream_wait_connect and sk_stream_wait_memory), while the rest of the sock_error() users look to be doing the right thing. This version of the patch fixes those, and cleans up a few places that were testing ->sk_err directly. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: speed up SACK processingStephen Hemminger
Use "hints" to speed up the SACK processing. Various forms of this have been used by TCP developers (Web100, STCP, BIC) to avoid the 2x linear search of outstanding segments. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[NET]: sk_add_backlog convert from macro to inlineStephen Hemminger
There is no reason for sk_add_backlog to be a macro. It can just be an inline function and get type checking. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-28[PATCH] gfp_t: net/*Al Viro
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-03[INET]: speedup inet (tcp/dccp) lookupsEric Dumazet
Arnaldo and I agreed it could be applied now, because I have other pending patches depending on this one (Thank you Arnaldo) (The other important patch moves skc_refcnt in a separate cache line, so that the SMP/NUMA performance doesnt suffer from cache line ping pongs) 1) First some performance data : -------------------------------- tcp_v4_rcv() wastes a *lot* of time in __inet_lookup_established() The most time critical code is : sk_for_each(sk, node, &head->chain) { if (INET_MATCH(sk, acookie, saddr, daddr, ports, dif)) goto hit; /* You sunk my battleship! */ } The sk_for_each() does use prefetch() hints but only the begining of "struct sock" is prefetched. As INET_MATCH first comparison uses inet_sk(__sk)->daddr, wich is far away from the begining of "struct sock", it has to bring into CPU cache cold cache line. Each iteration has to use at least 2 cache lines. This can be problematic if some chains are very long. 2) The goal ----------- The idea I had is to change things so that INET_MATCH() may return FALSE in 99% of cases only using the data already in the CPU cache, using one cache line per iteration. 3) Description of the patch --------------------------- Adds a new 'unsigned int skc_hash' field in 'struct sock_common', filling a 32 bits hole on 64 bits platform. struct sock_common { unsigned short skc_family; volatile unsigned char skc_state; unsigned char skc_reuse; int skc_bound_dev_if; struct hlist_node skc_node; struct hlist_node skc_bind_node; atomic_t skc_refcnt; + unsigned int skc_hash; struct proto *skc_prot; }; Store in this 32 bits field the full hash, not masked by (ehash_size - 1) Using this full hash as the first comparison done in INET_MATCH permits us immediatly skip the element without touching a second cache line in case of a miss. Suppress the sk_hashent/tw_hashent fields since skc_hash (aliased to sk_hash and tw_hash) already contains the slot number if we mask with (ehash_size - 1) File include/net/inet_hashtables.h 64 bits platforms : #define INET_MATCH(__sk, __hash, __cookie, __saddr, __daddr, __ports, __dif)\ (((__sk)->sk_hash == (__hash)) ((*((__u64 *)&(inet_sk(__sk)->daddr)))== (__cookie)) && \ ((*((__u32 *)&(inet_sk(__sk)->dport))) == (__ports)) && \ (!((__sk)->sk_bound_dev_if) || ((__sk)->sk_bound_dev_if == (__dif)))) 32bits platforms: #define TCP_IPV4_MATCH(__sk, __hash, __cookie, __saddr, __daddr, __ports, __dif)\ (((__sk)->sk_hash == (__hash)) && \ (inet_sk(__sk)->daddr == (__saddr)) && \ (inet_sk(__sk)->rcv_saddr == (__daddr)) && \ (!((__sk)->sk_bound_dev_if) || ((__sk)->sk_bound_dev_if == (__dif)))) - Adds a prefetch(head->chain.first) in __inet_lookup_established()/__tcp_v4_check_established() and __inet6_lookup_established()/__tcp_v6_check_established() and __dccp_v4_check_established() to bring into cache the first element of the list, before the {read|write}_lock(&head->lock); Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-05[NET]: Do not protect sysctl_optmem_max with CONFIG_SYSCTLDavid S. Miller
The ipv4 and ipv6 protocols need to access it unconditionally. SYSCTL=n build failure reported by Russell King. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01[TCP]: Fix sk_forward_alloc underflow in tcp_sendmsgHerbert Xu
I've finally found a potential cause of the sk_forward_alloc underflows that people have been reporting sporadically. When tcp_sendmsg tacks on extra bits to an existing TCP_PAGE we don't check sk_forward_alloc even though a large amount of time may have elapsed since we allocated the page. In the mean time someone could've come along and liberated packets and reclaimed sk_forward_alloc memory. This patch makes tcp_sendmsg check sk_forward_alloc every time as we do in do_tcp_sendpages. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01[NET]: Add sk_stream_wmem_scheduleHerbert Xu
This patch introduces sk_stream_wmem_schedule as a short-hand for the sk_forward_alloc checking on egress. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: fix PROC_FS=n compileAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Implement SKB fast cloning.David S. Miller
Protocols that make extensive use of SKB cloning, for example TCP, eat at least 2 allocations per packet sent as a result. To cut the kmalloc() count in half, we implement a pre-allocation scheme wherein we allocate 2 sk_buff objects in advance, then use a simple reference count to free up the memory at the correct time. Based upon an initial patch by Thomas Graf and suggestions from Herbert Xu. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Store skb->timestamp as offset to a base timestampPatrick McHardy
Reduces skb size by 8 bytes on 64-bit. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Make NETDEBUG pure printk wrappersPatrick McHardy
2005-08-29[ICSK]: Generalise tcp_listen_{start,stop}Arnaldo Carvalho de Melo
This also moved inet_iif from tcp to inet_hashtables.h, as it is needed by the inet_lookup callers, perhaps this needs a bit of polishing, but for now seems fine. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Introduce inet_connection_sockArnaldo Carvalho de Melo
This creates struct inet_connection_sock, moving members out of struct tcp_sock that are shareable with other INET connection oriented protocols, such as DCCP, that in my private tree already uses most of these members. The functions that operate on these members were renamed, using a inet_csk_ prefix while not being moved yet to a new file, so as to ease the review of these changes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SOCK]: Introduce sk_cloneArnaldo Carvalho de Melo
Out of tcp_create_openreq_child, will be used in dccp_create_openreq_child, and is a nice sock function anyway. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Generalise the TCP sock ID lookup routinesArnaldo Carvalho de Melo
And also some TIME_WAIT functions. [acme@toy net-2.6.14]$ grep built-in /tmp/before.size /tmp/after.size /tmp/before.size: 282955 13122 9312 305389 4a8ed net/ipv4/built-in.o /tmp/after.size: 281566 13122 9312 304000 4a380 net/ipv4/built-in.o [acme@toy net-2.6.14]$ I kept them still inlined, will uninline at some point to see what would be the performance difference. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Generalise tcp_tw_bucket, aka TIME_WAIT socketsArnaldo Carvalho de Melo
This paves the way to generalise the rest of the sock ID lookup routines and saves some bytes in TCPv4 TIME_WAIT sockets on distro kernels (where IPv6 is always built as a module): [root@qemu ~]# grep tw_sock /proc/slabinfo tw_sock_TCPv6 0 0 128 31 1 tw_sock_TCP 0 0 96 41 1 [root@qemu ~]# Now if a protocol wants to use the TIME_WAIT generic infrastructure it only has to set the sk_prot->twsk_obj_size field with the size of its inet_timewait_sock derived sock and proto_register will create sk_prot->twsk_slab, for now its only for INET sockets, but we can introduce timewait_sock later if some non INET transport protocolo wants to use this stuff. Next changesets will take advantage of this new infrastructure to generalise even more TCP code. [acme@toy net-2.6.14]$ grep built-in /tmp/before.size /tmp/after.size /tmp/before.size: 188646 11764 5068 205478 322a6 net/ipv4/built-in.o /tmp/after.size: 188144 11764 5068 204976 320b0 net/ipv4/built-in.o [acme@toy net-2.6.14]$ Tested with both IPv4 & IPv6 (::1 (localhost) & ::ffff:172.20.0.1 (qemu host)). Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Move tcp_port_rover to inet_hashinfoArnaldo Carvalho de Melo
Also expose all of the tcp_hashinfo members, i.e. killing those tcp_ehash, etc macros, this will more clearly expose already generic functions and some that need just a bit of work to become generic, as we'll see in the upcoming changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SOCK]: Introduce sk_setup_capsArnaldo Carvalho de Melo
From tcp_v4_setup_caps, that always is preceded by a call to __sk_dst_set, so coalesce this sequence into sk_setup_caps, removing one call to a TCP function in the IP layer. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SOCK]: Rename __tcp_v4_rehash to __sk_prot_rehashArnaldo Carvalho de Melo
This operation was already generic and DCCP will use it. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Cleanup INET_REFCNT_DEBUG codeArnaldo Carvalho de Melo
2005-08-23[NET]: Fix socket bitop damageRalf Baechle
The socket flag cleanups that went into 2.6.12-rc1 are basically oring the flags of an old socket into the socket just being created. Unfortunately that one was just initialized by sock_init_data(), so already has SOCK_ZAPPED set. As the result zapped sockets are created and all incoming connection will fail due to this bug which again was carefully replicated to at least AX.25, NET/ROM or ROSE. In order to keep the abstraction alive I've introduced sock_copy_flags() to copy the socket flags from one sockets to another and used that instead of the bitwise copy thing. Anyway, the idea here has probably been to copy all flags, so sock_copy_flags() should be the right thing. With this the ham radio protocols are usable again, so I hope this will make it into 2.6.13. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-08[NET]: Fix sparse warningsVictor Fusco
From: Victor Fusco <victor@cetuc.puc-rio.br> Fix the sparse warning "implicit cast to nocast type" Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[TCP]: Simplify SKB data portion allocation with NETIF_F_SG.David S. Miller
The ideal and most optimal layout for an SKB when doing scatter-gather is to put all the headers at skb->data, and all the user data in the page array. This makes SKB splitting and combining extremely simple, especially before a packet goes onto the wire the first time. So, when sk_stream_alloc_pskb() is given a zero size, make sure there is no skb_tailroom(). This is achieved by applying SKB_DATA_ALIGN() to the header length used here. Next, make select_size() in TCP output segmentation use a length of zero when NETIF_F_SG is true on the outgoing interface. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Rename open_request to request_sockArnaldo Carvalho de Melo
Ok, this one just renames some stuff to have a better namespace and to dissassociate it from TCP: struct open_request -> struct request_sock tcp_openreq_alloc -> reqsk_alloc tcp_openreq_free -> reqsk_free tcp_openreq_fastfree -> __reqsk_free With this most of the infrastructure closely resembles a struct sock methods subset. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
