path: root/include/net/sctp/structs.h
2011-12-19sctp: fix incorrect overflow check on autocloseXi Wang
Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for limiting the autoclose value. If userspace passes in -1 on 32-bit platform, the overflow check didn't work and autoclose would be set to 0xffffffff. This patch defines a max_autoclose (in seconds) for limiting the value and exposes it through sysctl, with the following intentions. 1) Avoid overflowing autoclose * HZ. 2) Keep the default autoclose bound consistent across 32- and 64-bit platforms (INT_MAX / HZ in this patch). 3) Keep the autoclose value consistent between setsockopt() and getsockopt() calls. Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-24sctp: Bundle HEAERTBEAT into ASCONF_ACKMichio Honda
With this patch a HEARTBEAT chunk is bundled into the ASCONF-ACK for ADD IP ADDRESS, confirming the new destination as quickly as possible. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-02sctp: Add ASCONF operation on the single-homed hostMichio Honda
In this case, the SCTP association transmits an ASCONF packet including addition of the new IP address and deletion of the old address. This patch implements this functionality. In this case, the ASCONF chunk is added to the beginning of the queue, because the other chunks cannot be transmitted in this state. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add Auto-ASCONF support (core).Michio Honda
SCTP reconfigure the IP addresses in the association by using ASCONF chunks as mentioned in RFC5061. For example, we can start to use the newly configured IP address in the existing association. This patch implements automatic ASCONF operation in the SCTP stack with address events in the host computer, which is called auto_asconf. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-31sctp: stop pending timers and purge queues when peer restart asocWei Yongjun
If the peer restart the asoc, we should not only fail any unsent/unacked data, but also stop the T3-rtx, SACK, T4-rto timers, and teardown ASCONF queues. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08sctp: Store a flowi in transports to provide persistent keying.David S. Miller
Several future simplifications are possible now because of this. For example, the sctp_addr unions can simply refer directly to the flowi information. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: clean up route lookup callsVlad Yasevich
Change the call to take the transport parameter and set the cached 'dst' appropriately inside the get_dst() function calls. This will allow us in the future to clean up source address storage as well. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: remove useless arguments from get_saddr() callVlad Yasevich
There is no point in passing a destination address to a get_saddr() call. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: cache the ipv6 source after route lookupVlad Yasevich
The ipv6 routing lookup does give us a source address, but instead of filling it into the dst, it's stored in the flowi. We can use that instead of going through the entire source address selection again. Also the useless ->dst_saddr member of sctp_pf is removed. And sctp_v6_dst_saddr() is removed, instead by introduce sctp_v6_to_addr(), which can be reused to cleanup some dup code. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20sctp: fix to check the source address of COOKIE-ECHO chunkWei Yongjun
SCTP does not check whether the source address of COOKIE-ECHO chunk is the original address of INIT chunk or part of the any address parameters saved in COOKIE in CLOSED state. So even if the COOKIE-ECHO chunk is from any address but with correct COOKIE, the COOKIE-ECHO chunk still be accepted. If the COOKIE is not from a valid address, the assoc should not be established. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-01sctp: fix auth_hmacs field's length of struct sctp_cookieWei Yongjun
auth_hmacs field of struct sctp_cookie is used for store Requested HMAC Algorithm Parameter, and each HMAC Identifier is 2 bytes, so the length should be: SCTP_AUTH_NUM_HMACS * sizeof(__u16) + 2 Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29sctp: kill unused macros in head fileShan Wei
1. SCTP_CMD_NUM_VERBS,SCTP_CMD_MAX These two macros have never been used for several years since v2.6.12-rc2. 2.sctp_port_rover,sctp_port_alloc_lock The commit 063930 abandoned global variables of port_rover and port_alloc_lock, but still keep two macros to refer to them. So, remove them now. commit 06393009000779b00a558fd2f280882cc7dc2008 Author: Stephen Hemminger <shemminger@linux-foundation.org> Date: Wed Oct 10 17:30:18 2007 -0700 [SCTP]: port randomization Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in net/ and include/ (except netfilter) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-26sctp: dubious bitfields in sctp_transportDan Carpenter
Sparse complains because these one-bit bitfields are signed. include/net/sctp/structs.h:879:24: error: dubious one-bit signed bitfield include/net/sctp/structs.h:889:31: error: dubious one-bit signed bitfield include/net/sctp/structs.h:895:26: error: dubious one-bit signed bitfield include/net/sctp/structs.h:898:31: error: dubious one-bit signed bitfield include/net/sctp/structs.h:901:27: error: dubious one-bit signed bitfield It doesn't cause a problem in the current code, but it would be better to clean it up. This was introduced by c0058a35aacc7: "sctp: Save some room in the sctp_transport by using bitfields". Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ar9170/usb.c drivers/scsi/iscsi_tcp.c net/ipv4/ipmr.c
2010-05-06sctp: Fix a race between ICMP protocol unreachable and connect()Vlad Yasevich
ICMP protocol unreachable handling completely disregarded the fact that the user may have locked the socket. It proceeded to destroy the association, even though the user may have held the lock and had a ref on the association. This resulted in the following: Attempt to release alive inet socket f6afcc00 ========================= [ BUG: held lock freed! ] ------------------------- somenu/2672 is freeing memory f6afcc00-f6afcfff, with a lock still held there! (sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c 1 lock held by somenu/2672: #0: (sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c stack backtrace: Pid: 2672, comm: somenu Not tainted 2.6.32-telco #55 Call Trace: [<c1232266>] ? printk+0xf/0x11 [<c1038553>] debug_check_no_locks_freed+0xce/0xff [<c10620b4>] kmem_cache_free+0x21/0x66 [<c1185f25>] __sk_free+0x9d/0xab [<c1185f9c>] sk_free+0x1c/0x1e [<c1216e38>] sctp_association_put+0x32/0x89 [<c1220865>] __sctp_connect+0x36d/0x3f4 [<c122098a>] ? sctp_connect+0x13/0x4c [<c102d073>] ? autoremove_wake_function+0x0/0x33 [<c12209a8>] sctp_connect+0x31/0x4c [<c11d1e80>] inet_dgram_connect+0x4b/0x55 [<c11834fa>] sys_connect+0x54/0x71 [<c103a3a2>] ? lock_release_non_nested+0x88/0x239 [<c1054026>] ? might_fault+0x42/0x7c [<c1054026>] ? might_fault+0x42/0x7c [<c11847ab>] sys_socketcall+0x6d/0x178 [<c10da994>] ? trace_hardirqs_on_thunk+0xc/0x10 [<c1002959>] syscall_call+0x7/0xb This was because the sctp_wait_for_connect() would aqcure the socket lock and then proceed to release the last reference count on the association, thus cause the fully destruction path to finish freeing the socket. The simplest solution is to start a very short timer in case the socket is owned by user. When the timer expires, we can do some verification and be able to do the release properly. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-03Merge branch 'net-next' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/vxy/lksctp-dev Add missing linux/vmalloc.h include to net/sctp/probe.c Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-30sctp: Tag messages that can be Nagle delayed at creation.Vlad Yasevich
When we create the sctp_datamsg and fragment the user data, we know exactly if we are sending full segments or not and how they might be bundled. During this time, we can mark messages a Nagle capable or not. This makes the check at transmit time much simpler. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-30sctp: fast recovery algorithm is per association.Vlad Yasevich
SCTP fast recovery algorithm really applies per association and impacts all transports. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-30sctp: Save some room in the sctp_transport by using bitfieldsVlad Yasevich
Saves some room in the sctp_transport structure. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-30sctp: remove 'resent' bit from the chunkVlad Yasevich
The 'resent' bit is used to make sure that we don't update rto estimate based on retransmitted chunks. However, we already have the 'rto_pending' bit that we test when need to update rto, so 'resent' bit is just extra. Additionally, we currently have a bug in that we always set a 'resent' bit and thus rto estimate is only updated by Heartbeats. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-28sctp: Fix skb_over_panic resulting from multiple invalid parameter errors ↵Neil Horman
(CVE-2010-1173) (v4) Ok, version 4 Change Notes: 1) Minor cleanups, from Vlads notes Summary: Hey- Recently, it was reported to me that the kernel could oops in the following way: <5> kernel BUG at net/core/skbuff.c:91! <5> invalid operand: 0000 [#1] <5> Modules linked in: sctp netconsole nls_utf8 autofs4 sunrpc iptable_filter ip_tables cpufreq_powersave parport_pc lp parport vmblock(U) vsock(U) vmci(U) vmxnet(U) vmmemctl(U) vmhgfs(U) acpiphp dm_mirror dm_mod button battery ac md5 ipv6 uhci_hcd ehci_hcd snd_ens1371 snd_rawmidi snd_seq_device snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_ac97_codec snd soundcore pcnet32 mii floppy ext3 jbd ata_piix libata mptscsih mptsas mptspi mptscsi mptbase sd_mod scsi_mod <5> CPU: 0 <5> EIP: 0060:[<c02bff27>] Not tainted VLI <5> EFLAGS: 00010216 (2.6.9-89.0.25.EL) <5> EIP is at skb_over_panic+0x1f/0x2d <5> eax: 0000002c ebx: c033f461 ecx: c0357d96 edx: c040fd44 <5> esi: c033f461 edi: df653280 ebp: 00000000 esp: c040fd40 <5> ds: 007b es: 007b ss: 0068 <5> Process swapper (pid: 0, threadinfo=c040f000 task=c0370be0) <5> Stack: c0357d96 e0c29478 00000084 00000004 c033f461 df653280 d7883180 e0c2947d <5> 00000000 00000080 df653490 00000004 de4f1ac0 de4f1ac0 00000004 df653490 <5> 00000001 e0c2877a 08000800 de4f1ac0 df653490 00000000 e0c29d2e 00000004 <5> Call Trace: <5> [<e0c29478>] sctp_addto_chunk+0xb0/0x128 [sctp] <5> [<e0c2947d>] sctp_addto_chunk+0xb5/0x128 [sctp] <5> [<e0c2877a>] sctp_init_cause+0x3f/0x47 [sctp] <5> [<e0c29d2e>] sctp_process_unk_param+0xac/0xb8 [sctp] <5> [<e0c29e90>] sctp_verify_init+0xcc/0x134 [sctp] <5> [<e0c20322>] sctp_sf_do_5_1B_init+0x83/0x28e [sctp] <5> [<e0c25333>] sctp_do_sm+0x41/0x77 [sctp] <5> [<c01555a4>] cache_grow+0x140/0x233 <5> [<e0c26ba1>] sctp_endpoint_bh_rcv+0xc5/0x108 [sctp] <5> [<e0c2b863>] sctp_inq_push+0xe/0x10 [sctp] <5> [<e0c34600>] sctp_rcv+0x454/0x509 [sctp] <5> [<e084e017>] ipt_hook+0x17/0x1c [iptable_filter] <5> [<c02d005e>] nf_iterate+0x40/0x81 <5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151 <5> [<c02e0c7f>] ip_local_deliver_finish+0xc6/0x151 <5> [<c02d0362>] nf_hook_slow+0x83/0xb5 <5> [<c02e0bb2>] ip_local_deliver+0x1a2/0x1a9 <5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151 <5> [<c02e103e>] ip_rcv+0x334/0x3b4 <5> [<c02c66fd>] netif_receive_skb+0x320/0x35b <5> [<e0a0928b>] init_stall_timer+0x67/0x6a [uhci_hcd] <5> [<c02c67a4>] process_backlog+0x6c/0xd9 <5> [<c02c690f>] net_rx_action+0xfe/0x1f8 <5> [<c012a7b1>] __do_softirq+0x35/0x79 <5> [<c0107efb>] handle_IRQ_event+0x0/0x4f <5> [<c01094de>] do_softirq+0x46/0x4d Its an skb_over_panic BUG halt that results from processing an init chunk in which too many of its variable length parameters are in some way malformed. The problem is in sctp_process_unk_param: if (NULL == *errp) *errp = sctp_make_op_error_space(asoc, chunk, ntohs(chunk->chunk_hdr->length)); if (*errp) { sctp_init_cause(*errp, SCTP_ERROR_UNKNOWN_PARAM, WORD_ROUND(ntohs(param.p->length))); sctp_addto_chunk(*errp, WORD_ROUND(ntohs(param.p->length)), param.v); When we allocate an error chunk, we assume that the worst case scenario requires that we have chunk_hdr->length data allocated, which would be correct nominally, given that we call sctp_addto_chunk for the violating parameter. Unfortunately, we also, in sctp_init_cause insert a sctp_errhdr_t structure into the error chunk, so the worst case situation in which all parameters are in violation requires chunk_hdr->length+(sizeof(sctp_errhdr_t)*param_count) bytes of data. The result of this error is that a deliberately malformed packet sent to a listening host can cause a remote DOS, described in CVE-2010-1173: http://cve.mitre.org/cgi-bin/cvename.cgi?name=2010-1173 I've tested the below fix and confirmed that it fixes the issue. We move to a strategy whereby we allocate a fixed size error chunk and ignore errors we don't have space to report. Tested by me successfully Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-29Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/ieee802154/fakehard.c drivers/net/e1000e/ich8lan.c drivers/net/e1000e/phy.c drivers/net/netxen/netxen_nic_init.c drivers/net/wireless/ath/ath9k/main.c
2009-11-29sctp: on T3_RTX retransmit all the in-flight chunksAndrei Pelinescu-Onciul
When retransmitting due to T3 timeout, retransmit all the in-flight chunks for the corresponding transport/path, including chunks sent less then 1 rto ago. This is the correct behaviour according to rfc4960 section 6.3.3 E3 and "Note: Any DATA chunks that were sent to the address for which the T3-rtx timer expired but did not fit in one MTU (rule E3 above) should be marked for retransmission and sent as soon as cwnd allows (normally, when a SACK arrives). ". This fixes problems when more then one path is present and the T3 retransmission of the first chunk that timeouts stops the T3 timer for the initial active path, leaving all the other in-flight chunks waiting forever or until a new chunk is transmitted on the same path and timeouts (and this will happen only if the cwnd allows sending new chunks, but since cwnd was dropped to MTU by the timeout => it will wait until the first heartbeat). Example: 10 packets in flight, sent at 0.1 s intervals on the primary path. The primary path is down and the first packet timeouts. The first packet is retransmitted on another path, the T3 timer for the primary path is stopped and cwnd is set to MTU. All the other 9 in-flight packets will not be retransmitted (unless more new packets are sent on the primary path which depend on cwnd allowing it, and even in this case the 9 packets will be retransmitted only after a new packet timeouts which even in the best case would be more then RTO). This commit reverts d0ce92910bc04e107b2f3f2048f07e94f570035d and also removes the now unused transport->last_rto, introduced in b6157d8e03e1e780660a328f7183bcbfa4a93a19. p.s The problem is not only when multiple paths are there. It can happen in a single homed environment. If the application stops sending data, it possible to have a hung association. Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23sctp: Update max.burst implementationVlad Yasevich
Current implementation of max.burst ends up limiting new data during cwnd decay period. The decay is happening becuase the connection is idle and we are allowed to fill the congestion window. The point of max.burst is to limit micro-bursts in response to large acks. This still happens, as max.burst is still applied to each transmit opportunity. It will also apply if a very large send is made (greater then allowed by burst). Tested-by: Florian Niederbacher <florian.niederbacher@student.uibk.ac.at> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: Remove useless last_time_used variableVlad Yasevich
The transport last_time_used variable is rather useless. It was only used when determining if CWND needs to be updated due to idle transport. However, idle transport detection was based on a Heartbeat timer and last_time_used was not incremented when sending Heartbeats. As a result the check for cwnd reduction was always true. We can get rid of the variable and just base our cwnd manipulation on the HB timer (like the code comment sais). We also have to call into the cwnd manipulation function regardless of whether HBs are enabled or not. That way we will detect idle transports if the user has disabled Heartbeats. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: Update SWS avaoidance receiver side algorithmVlad Yasevich
We currently send window update SACKs every time we free up 1 PMTU worth of data. That a lot more SACKs then necessary. Instead, we'll now send back the actuall window every time we send a sack, and do window-update SACKs when a fraction of the receive buffer has been opened. The fraction is controlled with a sysctl. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-13sctp: Set source addresses on the association before adding transportsVlad Yasevich
Recent commit 8da645e101a8c20c6073efda3c7cc74eec01b87f sctp: Get rid of an extra routing lookup when adding a transport introduced a regression in the connection setup. The behavior was different between IPv4 and IPv6. IPv4 case ended up working because the route lookup routing returned a NULL route, which triggered another route lookup later in the output patch that succeeded. In the IPv6 case, a valid route was returned for first call, but we could not find a valid source address at the time since the source addresses were not set on the association yet. Thus resulted in a hung connection. The solution is to set the source addresses on the association prior to adding peers. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-04sctp: turn flags in 'struct sctp_association' into bit fieldsWei Yongjun
This shrinks the size of struct sctp_association a little. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-09-04sctp: Sysctl configuration for IPv4 Address ScopingBhaskar Dutta
This patch introduces a new sysctl option to make IPv4 Address Scoping configurable <draft-stewart-tsvwg-sctp-ipv4-00.txt>. In networking environments where DNAT rules in iptables prerouting chains convert destination IP's to link-local/private IP addresses, SCTP connections fail to establish as the INIT chunk is dropped by the kernel due to address scope match failure. For example to support overlapping IP addresses (same IP address with different vlan id) a Layer-5 application listens on link local IP's, and there is a DNAT rule that maps the destination IP to a link local IP. Such applications never get the SCTP INIT if the address-scoping draft is strictly followed. This sysctl configuration allows SCTP to function in such unconventional networking environments. Sysctl options: 0 - Disable IPv4 address scoping draft altogether 1 - Enable IPv4 address scoping (default, current behavior) 2 - Enable address scoping but allow IPv4 private addresses in init/init-ack 3 - Enable address scoping but allow IPv4 link local address in init/init-ack Signed-off-by: Bhaskar Dutta <bhaskar.dutta@globallogic.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-09-04sctp: Turn flags in 'sctp_packet' into bit fieldsVlad Yasevich
This shrinks the size of sctp_packet a little. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-09-04sctp: Fix SCTP_MAXSEG socket option to comply to spec.Vlad Yasevich
We had a bug that we never stored the user-defined value for MAXSEG when setting the value on an association. Thus future PMTU events ended up re-writing the frag point and increasing it past user limit. Additionally, when setting the option on the socket/endpoint, we effect all current associations, which is against spec. Now, we store the user 'maxseg' value along with the computed 'frag_point'. We inherit 'maxseg' from the socket at association creation and use it as an upper limit for 'frag_point' when its set. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-09-04sctp: Don't do NAGLE delay on large writes that were fragmented smallVlad Yasevich
SCTP will delay the last part of a large write due to NAGLE, if that part is smaller then MTU. Since we are doing large writes, we might as well send the last portion now instead of waiting untill the next large write happens. The small portion will be sent as is regardless, so it's better to not delay it. This is a result of much discussions with Wei Yongjun <yjwei@cn.fujitsu.com> and Doug Graham <dgraham@nortel.com>. Many thanks go out to them. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-09-04sctp: drop a_rwnd to 0 when receive buffer overflows.Vlad Yasevich
SCTP has a problem that when small chunks are used, it is possible to exhaust the receiver buffer without fully closing receive window. This happens due to all overhead that we have account for with small messages. To fix this, when receive buffer is exceeded, we'll drop the window to 0 and save the 'drop' portion. When application starts reading data and freeing up recevie buffer space, we'll wait until we've reached the 'drop' window and then add back this 'drop' one mtu at a time. This worked well in testing and under stress produced rather even recovery. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-09-04sctp: Send user messages to the lower layer as oneVlad Yasevich
Currenlty, sctp breaks up user messages into fragments and sends each fragment to the lower layer by itself. This means that for each fragment we go all the way down the stack and back up. This also discourages bundling of multiple fragments when they can fit into a sigle packet (ex: due to user setting a low fragmentation threashold). We introduce a new command SCTP_CMD_SND_MSG and hand the whole message down state machine. The state machine and the side-effect parser will cork the queue, add all chunks from the message to the queue, and then un-cork the queue thus causing the chunks to get transmitted. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-06-03sctp: fix to choose alternate destination when retransmit ASCONF chunkWei Yongjun
RFC 5061 Section 5.1 ASCONF Chunk Procedures said: B4) Re-transmit the ASCONF Chunk last sent and if possible choose an alternate destination address (please refer to [RFC4960], Section 6.4.1). An endpoint MUST NOT add new parameters to this chunk; it MUST be the same (including its Sequence Number) as the last ASCONF sent. An endpoint MAY, however, bundle an additional ASCONF with new ASCONF parameters with the next Sequence Number. For details, see Section 5.5. This patch fix to choose an alternate destination address when re-transmit the ASCONF chunk, with some dup codes cleanup. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-02-16sctp: Fix the RTO-doubling on idle-link heartbeatsVlad Yasevich
SCTP incorrectly doubles rto ever time a Hearbeat chunk is generated. However RFC 4960 states: On an idle destination address that is allowed to heartbeat, it is recommended that a HEARTBEAT chunk is sent once per RTO of that destination address plus the protocol parameter 'HB.interval', with jittering of +/- 50% of the RTO value, and exponential backoff of the RTO if the previous HEARTBEAT is unanswered. Essentially, of if the heartbean is unacknowledged, do we double the RTO. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-16sctp: Allow to disable SCTP checksums via module parameterLucas Nussbaum
This is a new version of my patch, now using a module parameter instead of a sysctl, so that the option is harder to find. Please note that, once the module is loaded, it is still possible to change the value of the parameter in /sys/module/sctp/parameters/, which is useful if you want to do performance comparisons without rebooting. Computation of SCTP checksums significantly affects the performance of SCTP. For example, using two dual-Opteron 246 connected using a Gbe network, it was not possible to achieve more than ~730 Mbps, compared to 941 Mbps after disabling SCTP checksums. Unfortunately, SCTP checksum offloading in NICs is not commonly available (yet). By default, checksums are still enabled, of course. Signed-off-by: Lucas Nussbaum <lucas.nussbaum@ens-lyon.fr> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08sctp: Rework the tsn map to use generic bitmap.Vlad Yasevich
The tsn map currently use is 4K large and is stuck inside the sctp_association structure making memory references REALLY expensive. What we really need is at most 4K worth of bits so the biggest map we would have is 512 bytes. Also, the map is only really usefull when we have gaps to store and report. As such, starting with minimal map of say 32 TSNs (bits) should be enough for normal low-loss operations. We can grow the map by some multiple of 32 along with some extra room any time we receive the TSN which would put us outside of the map boundry. As we close gaps, we can shift the map to rebase it on the latest TSN we've seen. This saves 4088 bytes per association just in the map alone along savings from the now unnecessary structure members. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01sctp: try harder to figure out address family when checking wildcardsVlad Yasevich
sctp_is_any() function that is used to check for wildcard addresses only looks at the address itself to determine the address family. This function is used in the API to check the address passed in from the user. If the user simply zerroes out the sockaddr_storage and pass that in, we'll end up failing. So, let's try harder to determine the address family by also checking the socket if it's possible. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-10-01sctp: reduce memory footprint of sctp_chunk structureNeil Horman
sctp_chunks should be put on a diet. This is some of the low hanging fruit that we can strip out. Changes all the __s8/__u8 flags to bitfields. Saves 12 bytes per chunk. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-08-03sctp: Drop ipfargok in sctp_xmit functionHerbert Xu
The ipfragok flag controls whether the packet may be fragmented either on the local host on beyond. The latter is only valid on IPv4. In fact, we never want to do the latter even on IPv4 when PMTU is enabled. This is because even though we can't fragment packets within SCTP due to the prtocol's inherent faults, we can still fragment it at IP layer. By setting the DF bit we will improve the PMTU process. RFC 2960 only says that we SHOULD clear the DF bit in this case, so we're compliant even if we set the DF bit. In fact RFC 4960 no longer has this statement. Once we make this change, we only need to control the local fragmentation. There is already a bit in the skb which controls that, local_df. So this patch sets that instead of using the ipfragok argument. The only complication is that there isn't a struct sock object per transport, so for IPv4 we have to resort to changing the pmtudisc field for every packet. This should be safe though as the protocol is single-threaded. Note that after this patch we can remove ipfragok from the rest of the stack too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22sctp: make sctp_outq_flush() staticAdrian Bunk
sctp_outq_flush() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18sctp: Support ipv6only AF_INET6 sockets.Vlad Yasevich
