The SCTP mailing list address to send patches or questions
to is linux-sctp@vger.kernel.org and not
lksctp-developers@lists.sourceforge.net anymore. Therefore,
update all occurences.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
In the event that an association exceeds its max_retrans attempts, we should
send an ABORT chunk indicating that we are closing the assocation as a result.
Because of the nature of the error, its unlikely to be received, but its a nice
clean way to close the association if it does make it through, and it will give
anyone watching via tcpdump a clue as to what happened.
Change notes:
v2)
* Removed erroneous changes from sctp_make_violation_parmlen
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: linux-sctp@vger.kernel.org
There are a handle of state machine functions primarily those dealing
with processing INIT packets where there is neither a valid endpoint nor
a valid assoication from which to derive a struct net. Therefore add
struct net * to the parameter list of sctp_state_fn_t and update all of
the state machine functions.
This trickles up through sctp_sm_lookup_event up to sctp_do_sm
and up further into sctp_primitiv_NAME before the code reaches
places where struct net can be reliably found.
This patch implement event notification SCTP_SENDER_DRY_EVENT.
SCTP Socket API Extensions:
6.1.9. SCTP_SENDER_DRY_EVENT
When the SCTP stack has no more user data to send or retransmit, this
notification is given to the user. Also, at the time when a user app
subscribes to this event, if there is no data to be sent or
retransmit, the stack will immediately send up this notification.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Make heartbeat information in sctp_make_heartbeat() instead
of make it in sctp_sf_heartbeat() directly for common using.
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ar9170/usb.c
drivers/scsi/iscsi_tcp.c
net/ipv4/ipmr.c
ICMP protocol unreachable handling completely disregarded
the fact that the user may have locked the socket. It proceeded
to destroy the association, even though the user may have
held the lock and had a ref on the association. This resulted
in the following:
Attempt to release alive inet socket f6afcc00
[ BUG: held lock freed! ]
somenu/2672 is freeing memory f6afcc00-f6afcfff, with a lock still held
there!
(sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c
1 lock held by somenu/2672:
#0: (sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c
stack backtrace:
Pid: 2672, comm: somenu Not tainted 2.6.32-telco #55
Call Trace:
[<c1232266>] ? printk+0xf/0x11
[<c1038553>] debug_check_no_locks_freed+0xce/0xff
[<c10620b4>] kmem_cache_free+0x21/0x66
[<c1185f25>] __sk_free+0x9d/0xab
[<c1185f9c>] sk_free+0x1c/0x1e
[<c1216e38>] sctp_association_put+0x32/0x89
[<c1220865>] __sctp_connect+0x36d/0x3f4
[<c122098a>] ? sctp_connect+0x13/0x4c
[<c102d073>] ? autoremove_wake_function+0x0/0x33
[<c12209a8>] sctp_connect+0x31/0x4c
[<c11d1e80>] inet_dgram_connect+0x4b/0x55
[<c11834fa>] sys_connect+0x54/0x71
[<c103a3a2>] ? lock_release_non_nested+0x88/0x239
[<c1054026>] ? might_fault+0x42/0x7c
[<c11847ab>] sys_socketcall+0x6d/0x178
[<c10da994>] ? trace_hardirqs_on_thunk+0xc/0x10
[<c1002959>] syscall_call+0x7/0xb
This was because the sctp_wait_for_connect() would aqcure the socket
lock and then proceed to release the last reference count on the
association, thus cause the fully destruction path to finish freeing
the socket.
The simplest solution is to start a very short timer in case the socket
is owned by user. When the timer expires, we can do some verification
and be able to do the release properly.
In current implementation if ABORT chunk is received with T flag is set
and zero verification tag in COOKIE-WAIT state, the ABORT chunk will be
always accepted. This is because in COOKIE-WAIT state, the endpoint does
not know the peer's verification tag, and it's zero in the endpoint.
The "Invalid Stream Identifier" error has a 16 bit reserved
field at the end, thus making the parameter length be 8 bytes.
We've never supplied that reserved field making wireshark
tag the packet as malformed.
Reported-by: Chris Dischino <cdischino@sonusnet.com>
Once an endpoint has reached the SHUTDOWN-RECEIVED state,
it MUST NOT send a SHUTDOWN in response to a ULP request.
The Cumulative TSN Ack of the received SHUTDOWN chunk
MUST be processed.
This patch fix to process Cumulative TSN Ack of the received
SHUTDOWN chunk in SHUTDOWN_RECEIVED state.
Since call to function sctp_sf_abort_violation() need paramter 'arg' with
'struct sctp_chunk' type, it will read the chunk type and chunk length from
the chunk_hdr member of chunk. But call to sctp_sf_violation_paramlen()
always with 'struct sctp_paramhdr' type's parameter, it will be passed to
sctp_sf_abort_violation(). This may cause kernel panic.
|-- sctp_sf_abort_violation()
|-- sctp_make_abort_violation()
This patch fixed this problem. This patch also fix two place which called
sctp_sf_violation_paramlen() with wrong paramter type.
With a was number of callsites sctp_add_cmd_sf wrapper bloats
kernel by some amount. Due to unlikely tracking allyesconfig,
with the initial result were around ~7kB (thus caught my
attention) while a non-debug config produced only ~2.3kB effect.
I (ij) proposed first a patch to uninline it but Vlad responded
with a patch that removed the only sctp_add_cmd call which is
wrapped by sctp_add_cmd_sf (I wasn't sure if I could do that).
I did minor cleanup to Vlad's patch.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
I was notified by Randy Stewart that lksctp claims to be
"the reference implementation". First of all, "the
refrence implementation" was the original implementation
of SCTP in usersapce written ty Randy and a few others.
Second, after looking at the definiton of 'reference implementation',
we don't really meet the requirements.
This patch implements the receive path needed to process authenticated
chunks. Add ability to process the AUTH chunk and handle edge cases
for authenticated COOKIE-ECHO as well.
SCTP-AUTH, Section 6.2:
Endpoints MUST send all requested chunks authenticated where this has
been requested by the peer. The other chunks MAY be sent
authenticated or not. If endpoint pair shared keys are used, one of
them MUST be selected for authentication.
To send chunks in an authenticated way, the sender MUST include these
chunks after an AUTH chunk. This means that a sender MUST bundle
chunks in order to authenticate them.
If the endpoint has no endpoint pair shared key for the peer, it MUST
use Shared Key Identifier 0 with an empty endpoint pair shared key.
If there are multiple endpoint shared keys the sender selects one and
uses the corresponding Shared Key Identifier
If ADDIP is enabled, when an ASCONF chunk is received with ASCONF
paramter length set to zero, this will cause infinite loop.
By the way, if an malformed ASCONF chunk is received, will cause
processing to access memory without verifying.
This is because of not check the validity of parameters in ASCONF chunk.
This patch fixed this.
While processing OOTB chunks as well as chunks with an invalid
length of 0, it was possible to SCTP to get wedged inside an
infinite loop because we didn't catch the condition correctly,
or didn't mark the packet for discard correctly.
This work is based on original findings and work by
PROTOCOL VIOLATION error cause in ABORT is bad encode when make abort
chunk. When SCTP encode ABORT chunk with PROTOCOL VIOLATION error cause,
it just add the error messages to PROTOCOL VIOLATION error cause, the
rest four bytes(struct sctp_paramhdr) is just add to the chunk, not
change the length of error cause. This cause the ABORT chunk to be a bad
format. The chunk is like this:
ABORT chunk
Chunk type: ABORT (6)
Chunk flags: 0x00
Chunk length: 72 (*1)
Protocol violation cause
Cause code: Protocol violation (0x000d)
Cause length: 62 (*2)
Cause information: 5468652063756D756C61746976652074736E2061636B2062...
Cause padding: 0000
[Needless] 00030010
Chunk Length(*1) = 72 but Cause length(*2) only 62, not include the
extend 4 bytes.
((72 - sizeof(chunk_hdr)) = 68) != (62 +3) / 4 * 4
Consider the chunk as Out-of-the-Blue if we don't have
an endpoint. Otherwise discard it as before.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
sctp_make_abort_user() now takes the msg_len along with the msg
so that we don't have to recalculate the bytes in iovec.
It also uses memcpy_fromiovec() so that we don't go beyond the
length allocated.
It is good to have this fix even if verify_iovec() is fixed to
return error on overflow.
- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
Another rollup of patches which give various symbols static scope
Implements sctp_connectx() as defined in the SCTP sockets API draft by
tunneling the request through a setsockopt().
Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com>
- Fixed sctp_vtag_verify_either() to comply with impguide 2.41 B) and C).
- Make sure vtag is reflected when T-bit is set in SHUTDOWN-COMPLETE sent
due to an OOTB SHUTDOWN-ACK and in ABORT sent due to an OOTB packet.
- Do not set T-Bit in ABORT chunk in response to INIT.
- Fixed some comments to reflect the new meaning of the T-Bit.
Signed-off-by: Jerome Forissier <jerome.forissier@hp.com>
infrastructure for it.
Let it rip!
