Add support for RFC3873 remote address table OID.
+--(5) sctpAssocRemAddrTable
| |--(-) sctpAssocId (shared index)
| +--(1) sctpAssocRemAddrType (index)
. +--(2) sctpAssocRemAddr (index)
+--(3) sctpAssocRemAddrActive
+--(4) sctpAssocRemAddrHBActive
+--(5) sctpAssocRemAddrRTO
+--(6) sctpAssocRemAddrMaxPathRtx
+--(7) sctpAssocRemAddrRtx
+--(8) sctpAssocRemAddrStartTime
This patch places all the requsite data in /proc/net/sctp/remaddr.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
net/ipv6/ndisc.c
Introduced by 270637abff0cdf848b910b9f96ad342e1da61c66
("[SCTP]: Fix a race between module load and protosw access")
Reported by Gabriel C:
In file included from net/sctp/sm_statetable.c:50:
include/net/sctp/sctp.h: In function 'sctp_v6_pf_init':
include/net/sctp/sctp.h:392: warning: 'return' with a value, in function returning void
In file included from net/sctp/sm_statefuns.c:62:
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
There is a race is SCTP between the loading of the module
and the access by the socket layer to the protocol functions.
In particular, a list of addresss that SCTP maintains is
not initialized prior to the registration with the protosw.
Thus it is possible for a user application to gain access
to SCTP functions before everything has been initialized.
The problem shows up as odd crashes during connection
initializtion when we try to access the SCTP address list.
The solution is to refactor how we do registration and
initialize the lists prior to registering with the protosw.
Care must be taken since the address list initialization
depends on some other pieces of SCTP initialization. Also
the clean-up in case of failure now also needs to be refactored.
Acked-by: Sridhar Samudrala <sri@us.ibm.com>
After the patch:
$ git-grep sctp_sysctl_jiffies_ms | wc -l
0
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
I was notified by Randy Stewart that lksctp claims to be
"the reference implementation". First of all, "the
refrence implementation" was the original implementation
of SCTP in usersapce written ty Randy and a few others.
Second, after looking at the definiton of 'reference implementation',
we don't really meet the requirements.
This patch introduces new memory accounting functions for each network
protocol. Most of them are renamed from memory accounting functions
for stream protocols. At the same time, some stream memory accounting
functions are removed since other functions do same thing.
Renaming:
sk_stream_free_skb() -> sk_wmem_free_skb()
__sk_stream_mem_reclaim() -> __sk_mem_reclaim()
sk_stream_mem_reclaim() -> sk_mem_reclaim()
sk_stream_mem_schedule -> __sk_mem_schedule()
sk_stream_pages() -> sk_mem_pages()
sk_stream_rmem_schedule() -> sk_rmem_schedule()
sk_stream_wmem_schedule() -> sk_wmem_schedule()
sk_charge_skb() -> sk_mem_charge()
Removeing
sk_stream_rfree(): consolidates into sock_rfree()
sk_stream_set_owner_r(): consolidates into skb_set_owner_r()
sk_stream_mem_schedule()
The following functions are added.
sk_has_account(): check if the protocol supports accounting
sk_mem_uncharge(): do the opposite of sk_mem_charge()
In addition, to achieve consolidation, updating sk_wmem_queued is
removed from sk_mem_charge().
Next, to consolidate memory accounting functions, this patch adds
memory accounting calls to network core functions. Moreover, present
memory accounting call is renamed to new accounting call.
Finally we replace present memory accounting calls with new interface
in TCP and SCTP.
Signed-off-by: Takahiro Yasui <tyasui@redhat.com>
Signed-off-by: Hideo Aoki <haoki@redhat.com>
The crc32c library used an identical table and algorithm
as SCTP. Switch to using the library instead of carrying
our own table. Using crypto layer proved to have too
much overhead compared to using the library directly.
Convert the custom hash list traversals to use hlist functions.
Commit d0ce92910bc04e107b2f3f2048f07e94f570035d broke several retransmit
cases including fast retransmit. The reason is that we should
only delay by rto while doing retranmists as a result of a timeout.
Retransmit as a result of path mtu discover, fast retransmit, or
other evernts that should trigger immidiate retransmissions got broken.
Also, since rto is doubled prior to marking of packets elegable for
retransmission, we never marked correct chunks anyway.
The fix is provide a reason for a given retransmission so that we
can mark chunks appropriately and to save the old rto value to do
comparisons against.
All regressions tests passed with this code.
Spotted by Wei Yongjun <yjwei@cn.fujitsu.com>
sctp_update_copy_cksum() is no longer used.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch implements the internals operations of the AUTH, such as
key computation and storage. It also adds necessary variables to
the SCTP data structures.
This patch introduces autotuning to the sctp buffer management code
similar to the TCP. The buffer space can be grown if the advertised
receive window still has room. This might happen if small message
sizes are used, which is common in telecom environmens.
New tunables are introduced that provide limits to buffer growth
and memory pressure is entered if to much buffer spaces is used.
sctp_localaddr_list is modified dynamically via NETDEV_UP
and NETDEV_DOWN events, but there is not synchronization
between writer (even handler) and readers. As a result,
the readers can access an entry that has been freed and
crash the sytem.
Acked-by: Sridhar Samdurala <sri@us.ibm.com>
sctp_chunk_cachep & sctp_bucket_cachep is used module global, so move it
to a header file.
Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc>
Currently, if the socket is owned by the user, we drop the ICMP
message. As a result SCTP forgets that path MTU changed and
never adjusting it's estimate. This causes all subsequent
packets to be fragmented. With this patch, we'll flag the association
that it needs to udpate it's estimate based on the already updated
routing information.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
This patch makes the following needlessly global functions static:
- ipv6.c: sctp_inet6addr_event()
- protocol.c: sctp_inetaddr_event()
Cc: Andi Kleen <ak@suse.de>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
When doing receiver buffer accounting, we always used skb->truesize.
This is problematic when processing bundled DATA chunks because for
every DATA chunk that could be small part of one large skb, we would
charge the size of the entire skb. The new approach is to store the
size of the DATA chunk we are accounting for in the sctp_ulpevent
structure and use that stored value for accounting.
This patch contains the following cleanups:
- make the following needlessly global function static:
- socket.c: sctp_apply_peer_addr_params()
- add proper prototypes for the several global functions in
Note that this fixes wrong prototypes for the following functions:
- sctp_snmp_proc_exit()
- sctp_eps_proc_exit()
- sctp_assocs_proc_exit()
The latter was spotted by the GNU C compiler and reported
by David Woodhouse.
This patch adds more statistics info under /proc/net/sctp/snmp
that should be useful for debugging. The additional events that
are counted now include timer expirations, retransmits, packet
and data chunk discards.
The Data chunk discards include all the cases where a data chunk
is discarded including high tsn, bad stream, dup tsn and the most
useful one(out of receive buffer/rwnd).
Also moved the SCTP MIB data structures from the generic include
directories to include/sctp/sctp.h.
This patch converts SCTP to use the new HMAC template and hash interface.
sctp_make_abort_user() now takes the msg_len along with the msg
so that we don't have to recalculate the bytes in iovec.
It also uses memcpy_fromiovec() so that we don't go beyond the
length allocated.
It is good to have this fix even if verify_iovec() is fixed to
return error on overflow.
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[ATM]: fix broken uses of NIPQUAD in net/atm
[SCTP]: sctp_unpack_cookie() fix
[SCTP]: Fix unintentional change to SCTP_ASSERT when !SCTP_DEBUG
[NET]: Prevent multiple qdisc runs
[CONNECTOR]: Initialize subsystem earlier.
[NETFILTER]: xt_sctp: fix endless loop caused by 0 chunk length
* git://git.infradead.org/hdrcleanup-2.6: (63 commits)
[S390] __FD_foo definitions.
Switch to __s32 types in joystick.h instead of C99 types for consistency.
Add <sys/types.h> to headers included for userspace in <linux/input.h>
Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h
Remove struct fddi_statistics from user view in <linux/if_fddi.h>
Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390
Revert include/media changes: Mauro says those ioctls are only used in-kernel(!)
Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h>
Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too
Remove private struct dx_hash_info from public view in <linux/ext3_fs.h>
Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h>
Use __uXX types in <linux/divert.h> for struct divert_blk et al.
Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible.
Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely
Use __uXX types in user-visible structures in <linux/nbd.h>
Don't use 'u32' in user-visible struct ip_conntrack_old_tuple.
Use __uXX types for S390 DASD volume label definitions which are user-visible
S390 BIODASDREADCMB ioctl should use __u64 not u64 type.
Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h>
Fix private integer types used in V4L2 ioctls.
Manually resolve conflict in include/linux/mtd/physmap.h
A local debugging change slipped into a previous changeset.
When SCTP_DEBUG is off SCTP_ASSERT should do nothing.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
include/asm-powerpc/unistd.h
include/asm-sparc/unistd.h
include/asm-sparc64/unistd.h
When performing bound checks during the parameter processing, we
want to use the real chunk and paramter lengths for bounds instead
of the rounded ones. This prevents us from potentially walking of
the end if the chunk length was miscalculated. We still use rounded
lengths when advancing the pointer. This was found during a
conformance test that changed the chunk length without modifying
parameters.
Validate and update the sk in sctp_rcv() to avoid the race where an
assoc/ep could move to a different socket after we get the sk, but before
the skb is added to the backlog.
Also migrate the skb's in backlog queue to new sk when doing a peeloff.
There are errors and inconsistency in the display of NIP6 strings.
ie: net/ipv6/ip6_flowlabel.c
There are errors and inconsistency in the display of NIPQUAD strings too.
ie: net/netfilter/nf_conntrack_ftp.c
This patch:
adds NIP6_FMT to kernel.h
changes all code to use NIP6_FMT
fixes net/ipv6/ip6_flowlabel.c
adds NIPQUAD_FMT to kernel.h
fixes net/netfilter/nf_conntrack_ftp.c
changes a few uses of "%u.%u.%u.%u" to NIPQUAD_FMT for symmetry to NIP6_FMT
- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
Implements sctp_connectx() as defined in the SCTP sockets API draft by
tunneling the request through a setsockopt().
Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com>
infrastructure for it.
Let it rip!
