path: root/include/net/sctp/sctp.h
2013-08-09net: sctp: trivial: update bug report in header commentDaniel Borkmann
With the restructuring of the lksctp.org site, we only allow bug reports through the SCTP mailing list linux-sctp@vger.kernel.org, not via SF, as SF is only used for web hosting and nothing more. While at it, also remove the obvious statement that bugs will be fixed and incooperated into the kernel. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-02sctp: Don't lookup dst if transport dst is still validfan.du
When sctp sits on IPv6, sctp_transport_dst_check pass cookie as ZERO, as a result ip6_dst_check always fail out. This behaviour makes transport->dst useless, because every sctp_packet_transmit must look for valid dst. Add a dst_cookie into sctp_transport, and set the cookie whenever we get new dst for sctp_transport. So dst validness could be checked against it. Since I have split genid for IPv4 and IPv6, also delete/add IPv6 address will also bump IPv6 genid. So issues we discussed in: http://marc.info/?l=linux-netdev&m=137404469219410&w=4 have all been sloved for this patch. Signed-off-by: Fan Du <fan.du@windriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-24net: sctp: trivial: update mailing list addressDaniel Borkmann
The SCTP mailing list address to send patches or questions to is linux-sctp@vger.kernel.org and not lksctp-developers@lists.sourceforge.net anymore. Therefore, update all occurences. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-01net: sctp: rework debugging framework to use pr_debug and friendsDaniel Borkmann
We should get rid of all own SCTP debug printk macros and use the ones that the kernel offers anyway instead. This makes the code more readable and conform to the kernel code, and offers all the features of dynamic debbuging that pr_debug() et al has, such as only turning on/off portions of debug messages at runtime through debugfs. The runtime cost of having CONFIG_DYNAMIC_DEBUG enabled, but none of the debug statements printing, is negligible [1]. If kernel debugging is completly turned off, then these statements will also compile into "empty" functions. While we're at it, we also need to change the Kconfig option as it /now/ only refers to the ifdef'ed code portions in outqueue.c that enable further debugging/tracing of SCTP transaction fields. Also, since SCTP_ASSERT code was enabled with this Kconfig option and has now been removed, we transform those code parts into WARNs resp. where appropriate BUG_ONs so that those bugs can be more easily detected as probably not many people have SCTP debugging permanently turned on. To turn on all SCTP debugging, the following steps are needed: # mount -t debugfs none /sys/kernel/debug # echo -n 'module sctp +p' > /sys/kernel/debug/dynamic_debug/control This can be done more fine-grained on a per file, per line basis and others as described in [2]. [1] https://www.kernel.org/doc/ols/2009/ols2009-pages-39-46.pdf [2] Documentation/dynamic-debug-howto.txt Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-25net: sctp: migrate cookie life from timeval to ktimeDaniel Borkmann
Currently, SCTP code defines its own timeval functions (since timeval is rarely used inside the kernel by others), namely tv_lt() and TIMEVAL_ADD() macros, that operate on SCTP cookie expiration. We might as well remove all those, and operate directly on ktime structures for a couple of reasons: ktime is available on all archs; complexity of ktime calculations depending on the arch is less than (reduces to a simple arithmetic operations on archs with BITS_PER_LONG == 64 or CONFIG_KTIME_SCALAR) or equal to timeval functions (other archs); code becomes more readable; macros can be thrown out. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-25net: sctp: remove TEST_FRAME ifdefDaniel Borkmann
We do neither ship a test_frame.h, nor will this be compatible with the 2.5 out-of-tree lksctp kernel test suite anyway. So remove this artefact. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17net: sctp: remove SCTP_STATIC macroDaniel Borkmann
SCTP_STATIC is just another define for the static keyword. It's use is inconsistent in the SCTP code anyway and it was introduced in the initial implementation of SCTP in 2.5. We have a regression suite in lksctp-tools, but this is for user space only, so noone makes use of this macro anymore. The kernel test suite for 2.5 is incompatible with the current SCTP code anyway. So simply Remove it, to be more consistent with the rest of the kernel code. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17net: sctp: get rid of t_new macro for kzallocDaniel Borkmann
t_new rather obfuscates things where everyone else is using actual function names instead of that macro, so replace it with kzalloc, which is the function t_new wraps. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-18net: sctp: remove cast for kmalloc/kzalloc return valueZhang Yanfei
remove cast for kmalloc/kzalloc return value. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: Vlad Yasevich <vyasevich@gmail.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-sctp@vger.kernel.org Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-03sctp: Add support to per-association statistics via a new ↵Michele Baldessari
SCTP_GET_ASSOC_STATS call The current SCTP stack is lacking a mechanism to have per association statistics. This is an implementation modeled after OpenSolaris' SCTP_GET_ASSOC_STATS. Userspace part will follow on lksctp if/when there is a general ACK on this. V4: - Move ipackets++ before q->immediate.func() for consistency reasons - Move sctp_max_rto() at the end of sctp_transport_update_rto() to avoid returning bogus RTO values - return asoc->rto_min when max_obs_rto value has not changed V3: - Increase ictrlchunks in sctp_assoc_bh_rcv() as well - Move ipackets++ to sctp_inq_push() - return 0 when no rto updates took place since the last call V2: - Implement partial retrieval of stat struct to cope for future expansion - Kill the rtxpackets counter as it cannot be precise anyway - Rename outseqtsns to outofseqtsns to make it clearer that these are out of sequence unexpected TSNs - Move asoc->ipackets++ under a lock to avoid potential miscounts - Fold asoc->opackets++ into the already existing asoc check - Kill unneeded (q->asoc) test when increasing rtxchunks - Do not count octrlchunks if sending failed (SCTP_XMIT_OK != 0) - Don't count SHUTDOWNs as SACKs - Move SCTP_GET_ASSOC_STATS to the private space API - Adjust the len check in sctp_getsockopt_assoc_stats() to allow for future struct growth - Move association statistics in their own struct - Update idupchunks when we send a SACK with dup TSNs - return min_rto in max_rto when RTO has not changed. Also return the transport when max_rto last changed. Signed-off: Michele Baldessari <michele@acksyn.org> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-15sctp: fix a compile error in sctp.hCong Wang
I got the following compile error: In file included from include/net/sctp/checksum.h:46:0, from net/ipv4/netfilter/nf_nat_proto_sctp.c:14: include/net/sctp/sctp.h: In function ‘sctp_dbg_objcnt_init’: include/net/sctp/sctp.h:370:88: error: parameter name omitted include/net/sctp/sctp.h: In function ‘sctp_dbg_objcnt_exit’: include/net/sctp/sctp.h:371:88: error: parameter name omitted which is caused by commit 13d782f6b4fbbaf9d0380a9947deb45a9de46ae7 Author: Eric W. Biederman <ebiederm@xmission.com> Date: Mon Aug 6 08:45:15 2012 +0000 sctp: Make the proc files per network namespace. This patch could fix it. Cc: David S. Miller <davem@davemloft.net> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Push struct net down to sctp_chunk_event_lookupEric W. Biederman
This trickles up through sctp_sm_lookup_event up to sctp_do_sm and up further into sctp_primitiv_NAME before the code reaches places where struct net can be reliably found. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Add infrastructure for per net sysctlsEric W. Biederman
Start with an empty sctp_net_table that will be populated as the various tunable sysctls are made per net. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the mib per network namespaceEric W. Biederman
2012-08-14sctp: Make the proc files per network namespace.Eric W. Biederman
- Convert all of the files under /proc/net/sctp to be per network namespace. - Don't print anything for /proc/net/sctp/snmp except in the initial network namespaces as the snmp counters still have to be converted to be per network namespace. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the ctl_sock per network namespaceEric W. Biederman
- Kill sctp_get_ctl_sock, it is useless now. - Pass struct net where needed so net->sctp.ctl_sock is accessible. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the address lists per network namespaceEric W. Biederman
- Move the address lists into struct net - Add per network namespace initialization and cleanup - Pass around struct net so it is everywhere I need it. - Rename all of the global variable references into references to the variables moved into struct net Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the association hashtable handle multiple network namespacesEric W. Biederman
- Use struct net in the hash calculation - Use sock_net(association.base.sk) in the association lookups. - On receive calculate the network namespace from skb->dev. - Pass struct net from receive down to the functions that actually do the association lookup. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the endpoint hashtable handle multiple network namespacesEric W. Biederman
- Use struct net in the hash calculation - Use sock_net(endpoint.base.sk) in the endpoint lookups. - On receive calculate the network namespace from skb->dev. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the port hash table use struct net in it's key.Eric W. Biederman
- Add struct net into the port hash table hash calculation - Add struct net inot the struct sctp_bind_bucket so there is a memory of which network namespace a port is allocated in. No need for a ref count because sctp_bind_bucket only exists when there are sockets in the hash table and sockets can not change their network namspace, and sockets already ref count their network namespace. - Add struct net into the key comparison when we are testing to see if we have found the port hash table entry we are looking for. With these changes lookups in the port hash table becomes safe to use in multiple network namespaces. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-16sctp: Adjust PMTU updates to accomodate route invalidation.David S. Miller
This adjusts the call to dst_ops->update_pmtu() so that we can transparently handle the fact that, in the future, the dst itself can be invalidated by the PMTU update (when we have non-host routes cached in sockets). Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12ipv6: Add redirect support to all protocol icmp error handlers.David S. Miller
2012-05-10sctp: check cached dst before using itNicolas Dichtel
dst_check() will take care of SA (and obsolete field), hence IPsec rekeying scenario is taken into account. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Vlad Yaseivch <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-08sctp: Export sctp_do_peeloffBenjamin Poirier
lookup sctp_association within sctp_do_peeloff() to enable its use outside of the sctp code with minimal knowledge of the former. Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-11net: use IS_ENABLED(CONFIG_IPV6)Eric Dumazet
Instead of testing defined(CONFIG_IPV6) || defined(CONFIG_IPV6_MODULE) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-05include/net: Remove unnecessary semicolonsJoe Perches
Semicolons are not necessary after switch/while/for/if braces so remove them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add Auto-ASCONF support (core).Michio Honda
SCTP reconfigure the IP addresses in the association by using ASCONF chunks as mentioned in RFC5061. For example, we can start to use the newly configured IP address in the existing association. This patch implements automatic ASCONF operation in the SCTP stack with address events in the host computer, which is called auto_asconf. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Allow regular C expression in 4th argument for ↵YOSHIFUJI Hideaki
SCTP_DEBUG_PRINTK_IPADDR macro. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-07net,rcu: convert call_rcu(sctp_local_addr_free) to kfree_rcu()Lai Jiangshan
The rcu callback sctp_local_addr_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sctp_local_addr_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-04-20sctp: remove redundant check when walking through a list of TLV parametersShan Wei
When pos.v <= (void *)chunk + end - ntohs(pos.p->length) and ntohs(pos.p->length) >= sizeof(sctp_paramhdr_t) these two expressions are all true, pos.v <= (void *)chunk + end - sizeof(sctp_paramhdr_t) *must* be true. This patch removes this kind of redundant check. It's same to _sctp_walk_errors macro. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26net/sctp: Use pr_fmt and pr_<level>Joe Perches
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to use do { print } while (0) guards. Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when lines were continued. Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Add a missing newline in "Failed bind hash alloc" Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-03Merge branch 'net-next' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/vxy/lksctp-dev Add missing linux/vmalloc.h include to net/sctp/probe.c Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-02Merge branch 'master' of ↵David S. Miller
2010-04-30sctp: update transport initializationsVlad Yasevich
Right now, sctp transports are not fully initialized and when adding any new fields, they have to be explicitely initialized. This is prone to mistakes. So we switch to calling kzalloc() which makes things much simpler. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-28sctp: avoid irq lock inversion while call sk->sk_data_ready()Wei Yongjun
sk->sk_data_ready() of sctp socket can be called from both BH and non-BH contexts, but the default sk->sk_data_ready(), sock_def_readable(), can not be used in this case. Therefore, we have to make a new function sctp_data_ready() to grab sk->sk_data_ready() with BH disabling. ========================================================= [ INFO: possible irq lock inversion dependency detected ] 2.6.33-rc6 #129 --------------------------------------------------------- sctp_darn/1517 just changed the state of lock: (clock-AF_INET){++.?..}, at: [<c06aab60>] sock_def_readable+0x20/0x80 but this lock took another, SOFTIRQ-unsafe lock in the past: (slock-AF_INET){+.-...} and interrupts could create inverse lock ordering between them. other info that might help us debug this: 1 lock held by sctp_darn/1517: #0: (sk_lock-AF_INET){+.+.+.}, at: [<cdfe363d>] sctp_sendmsg+0x23d/0xc00 [sctp] Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-21net: snmp mib cleanupEric Dumazet
There is no point to align or pad mibs to cache lines, they are per cpu allocated with a 8 bytes alignment anyway. This wastes space for no gain. This patch removes __SNMP_MIB_ALIGN__ Since SNMP mibs contain "unsigned long" fields only, we can relax the allocation alignment from "unsigned long long" to "unsigned long" Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/netEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-04sctp: Fix SCTP_MAXSEG socket option to comply to spec.Vlad Yasevich
We had a bug that we never stored the user-defined value for MAXSEG when setting the value on an association. Thus future PMTU events ended up re-writing the frag point and increasing it past user limit. Additionally, when setting the option on the socket/endpoint, we effect all current associations, which is against spec. Now, we store the user 'maxseg' value along with the computed 'frag_point'. We inherit 'maxseg' from the socket at association creation and use it as an upper limit for 'frag_point' when its set. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-06-23net: Move rx skb_orphan call to where neededHerbert Xu
In order to get the tun driver to account packets, we need to be able to receive packets with destructors set. To be on the safe side, I added an skb_orphan call for all protocols by default since some of them (IP in particular) cannot handle receiving packets destructors properly. Now it seems that at least one protocol (CAN) expects to be able to pass skb->sk through the rx path without getting clobbered. So this patch attempts to fix this properly by moving the skb_orphan call to where it's actually needed. In particular, I've added it to skb_set_owner_[rw] which is what most users of skb->destructor call. This is actually an improvement for tun too since it means that we only give back the amount charged to the socket when the skb is passed to another socket that will also be charged accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Oliver Hartkopp <olver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21sctp: Clean up TEST_FRAME hacks.Vlad Yasevich
Remove 2 TEST_FRAME hacks that are no longer needed. These allowed sctp regression tests to compile before, but are no longer needed. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-16sctp: Inherit all socket options from parent correctly.Vlad Yasevich
During peeloff/accept() sctp needs to save the parent socket state into the new socket so that any options set on the parent are inherited by the child socket. This was found when the parent/listener socket issues SO_BINDTODEVICE, but the data was misrouted after a route cache flush. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25net: Use a percpu_counter for sockets_allocatedEric Dumazet
Instead of using one atomic_t per protocol, use a percpu_counter for "sockets_allocated", to reduce cache line contention on heavy duty network servers. Note : We revert commit (248969ae31e1b3276fc4399d67ce29a5d81e6fd9 net: af_unix can make unix_nr_socks visbile in /proc), since it is not anymore used after sock_prot_inuse_add() addition Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31misc: replace NIPQUAD()Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
2008-10-28net: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-10-16include: replace __FUNCTION__ with __func__Harvey Harrison
2008-09-22sctp: Use skb_queue_walk_safe() and skb_queue_split_tail_init().David S. Miller
