path: root/include/net/scm.h
2017-03-02sched/headers: Prepare to remove <linux/cred.h> inclusion from <linux/sched.h>Ingo Molnar
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h doing that for them. Note that even if the count where we need to add extra headers seems high, it's still a net win, because <linux/sched.h> is included in over 2,200 files ... Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-08unix: correctly track in-flight fds in sending process user_structHannes Frederic Sowa
The commit referenced in the Fixes tag incorrectly accounted the number of in-flight fds over a unix domain socket to the original opener of the file-descriptor. This allows another process to arbitrary deplete the original file-openers resource limit for the maximum of open files. Instead the sending processes and its struct cred should be credited. To do so, we add a reference counted struct user_struct pointer to the scm_fp_list and use it to account for the number of inflight unix fds. Fixes: 712f4aad406bb1 ("unix: properly account for FDs passed over unix sockets") Reported-by: David Herrmann <dh.herrmann@gmail.com> Cc: David Herrmann <dh.herrmann@gmail.com> Cc: Willy Tarreau <w@1wt.eu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-23scm.h: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-20net: fix incorrect credentials passingLinus Torvalds
Commit 257b5358b32f ("scm: Capture the full credentials of the scm sender") changed the credentials passing code to pass in the effective uid/gid instead of the real uid/gid. Obviously this doesn't matter most of the time (since normally they are the same), but it results in differences for suid binaries when the wrong uid/gid ends up being used. This just undoes that (presumably unintentional) part of the commit. Reported-by: Andy Lutomirski <luto@amacapital.net> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serge@hallyn.com> Cc: David S. Miller <davem@davemloft.net> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07scm: Stop passing struct credEric W. Biederman
Now that uids and gids are completely encapsulated in kuid_t and kgid_t we no longer need to pass struct cred which allowed us to test both the uid and the user namespace for equality. Passing struct cred potentially allows us to pass the entire group list as BSD does but I don't believe the cost of cache line misses justifies retaining code for a future potential application. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-24net: Remove unnecessary NULL check in scm_destroy().David S. Miller
All callers provide a non-NULL scm argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07scm: Don't use struct ucred in NETLINK_CB and struct scm_cookie.Eric W. Biederman
Passing uids and gids on NETLINK_CB from a process in one user namespace to a process in another user namespace can result in the wrong uid or gid being presented to userspace. Avoid that problem by passing kuids and kgids instead. - define struct scm_creds for use in scm_cookie and netlink_skb_parms that holds uid and gid information in kuid_t and kgid_t. - Modify scm_set_cred to fill out scm_creds by heand instead of using cred_to_ucred to fill out struct ucred. This conversion ensures userspace does not get incorrect uid or gid values to look at. - Modify scm_recv to convert from struct scm_creds to struct ucred before copying credential values to userspace. - Modify __scm_send to populate struct scm_creds on in the scm_cookie, instead of just copying struct ucred from userspace. - Modify netlink_sendmsg to copy scm_creds instead of struct ucred into the NETLINK_CB. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-21af_netlink: force credentials passing [CVE-2012-3520]Eric Dumazet
Pablo Neira Ayuso discovered that avahi and potentially NetworkManager accept spoofed Netlink messages because of a kernel bug. The kernel passes all-zero SCM_CREDENTIALS ancillary data to the receiver if the sender did not provide such data, instead of not including any such data at all or including the correct data from the peer (as it is the case with AF_UNIX). This bug was introduced in commit 16e572626961 (af_unix: dont send SCM_CREDENTIALS by default) This patch forces passing credentials for netlink, as before the regression. Another fix would be to not add SCM_CREDENTIALS in netlink messages if not provided by the sender, but it might break some programs. With help from Florian Weimer & Petr Matousek This issue is designated as CVE-2012-3520 Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Petr Matousek <pmatouse@redhat.com> Cc: Florian Weimer <fweimer@redhat.com> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-22get rid of ->scm_work_listAl Viro
recursion in __scm_destroy() will be cut by delaying final fput() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-09-28af_unix: dont send SCM_CREDENTIALS by defaultEric Dumazet
Since commit 7361c36c5224 (af_unix: Allow credentials to work across user and pid namespaces) af_unix performance dropped a lot. This is because we now take a reference on pid and cred in each write(), and release them in read(), usually done from another process, eventually from another cpu. This triggers false sharing. # Events: 154K cycles # # Overhead Command Shared Object Symbol # ........ ....... .................. ......................... # 10.40% hackbench [kernel.kallsyms] [k] put_pid 8.60% hackbench [kernel.kallsyms] [k] unix_stream_recvmsg 7.87% hackbench [kernel.kallsyms] [k] unix_stream_sendmsg 6.11% hackbench [kernel.kallsyms] [k] do_raw_spin_lock 4.95% hackbench [kernel.kallsyms] [k] unix_scm_to_skb 4.87% hackbench [kernel.kallsyms] [k] pid_nr_ns 4.34% hackbench [kernel.kallsyms] [k] cred_to_ucred 2.39% hackbench [kernel.kallsyms] [k] unix_destruct_scm 2.24% hackbench [kernel.kallsyms] [k] sub_preempt_count 1.75% hackbench [kernel.kallsyms] [k] fget_light 1.51% hackbench [kernel.kallsyms] [k] __mutex_lock_interruptible_slowpath 1.42% hackbench [kernel.kallsyms] [k] sock_alloc_send_pskb This patch includes SCM_CREDENTIALS information in a af_unix message/skb only if requested by the sender, [man 7 unix for details how to include ancillary data using sendmsg() system call] Note: This might break buggy applications that expected SCM_CREDENTIAL from an unaware write() system call, and receiver not using SO_PASSCRED socket option. If SOCK_PASSCRED is set on source or destination socket, we still include credentials for mere write() syscalls. Performance boost in hackbench : more than 50% gain on a 16 thread machine (2 quad-core cpus, 2 threads per core) hackbench 20 thread 2000 4.228 sec instead of 9.102 sec Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-16Revert "Scm: Remove unnecessary pid & credential references in Unix socket's ↵David S. Miller
send and receive path" This reverts commit 0856a304091b33a8e8f9f9c98e776f425af2b625. As requested by Eric Dumazet, it has various ref-counting problems and has introduced regressions. Eric will add a more suitable version of this performance fix. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-24Scm: Remove unnecessary pid & credential references in Unix socket's send ↵Tim Chen
and receive path Patch series 109f6e39..7361c36c back in 2.6.36 added functionality to allow credentials to work across pid namespaces for packets sent via UNIX sockets. However, the atomic reference counts on pid and credentials caused plenty of cache bouncing when there are numerous threads of the same pid sharing a UNIX socket. This patch mitigates the problem by eliminating extraneous reference counts on pid and credentials on both send and receive path of UNIX sockets. I found a 2x improvement in hackbench's threaded case. On the receive path in unix_dgram_recvmsg, currently there is an increment of reference count on pid and credentials in scm_set_cred. Then there are two decrement of the reference counts. Once in scm_recv and once when skb_free_datagram call skb->destructor function unix_destruct_scm. One pair of increment and decrement of ref count on pid and credentials can be eliminated from the receive path. Until we destroy the skb, we already set a reference when we created the skb on the send side. On the send path, there are two increments of ref count on pid and credentials, once in scm_send and once in unix_scm_to_skb. Then there is a decrement of the reference counts in scm_destroy's call to scm_destroy_cred at the end of unix_dgram_sendmsg functions. One pair of increment and decrement of the reference counts can be removed so we only need to increment the ref counts once. By incorporating these changes, for hackbench running on a 4 socket NHM-EX machine with 40 cores, the execution of hackbench on 50 groups of 20 threads sped up by factor of 2. Hackbench command used for testing: ./hackbench 50 thread 2000 Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24scm: lower SCM_MAX_FDEric Dumazet
Lower SCM_MAX_FD from 255 to 253 so that allocations for scm_fp_list are halved. (commit f8d570a4 added two pointers in this structure) scm_fp_dup() should not copy whole structure (and trigger kmemcheck warnings), but only the used part. While we are at it, only allocate needed size. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16scm: Capture the full credentials of the scm sender.Eric W. Biederman
Start capturing not only the userspace pid, uid and gid values of the sending process but also the struct pid and struct cred of the sending process as well. This is in preparation for properly supporting SCM_CREDENTIALS for sockets that have different uid and/or pid namespaces at the different ends. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16scm: Reorder scm_cookie.Eric W. Biederman
Reorder the fields in scm_cookie so they pack better on 64bit. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/netEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05cleanup: remove unused member in scm_cookie.Rami Rosen
This patch removes an unused member (seq) scm_cookie; besides initialized to 0 in the header file, it is not used. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-14Merge branch 'master' into nextJames Morris
Conflicts: security/keys/internal.h security/keys/process_keys.c security/keys/request_key.c Fixed conflicts above by using the non 'tsk' versions. Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the networking subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: netdev@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-06net: Fix recursive descent in __scm_destroy().David Miller
__scm_destroy() walks the list of file descriptors in the scm_fp_list pointed to by the scm_cookie argument. Those, in turn, can close sockets and invoke __scm_destroy() again. There is nothing which limits how deeply this can occur. The idea for how to fix this is from Linus. Basically, we do all of the fput()s at the top level by collecting all of the scm_fp_list objects hit by an fput(). Inside of the initial __scm_destroy() we keep running the list until it is empty. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17avoid OPEN_MAX in SCM_MAX_FDRoland McGrath
The OPEN_MAX constant is an arbitrary number with no useful relation to anything. Nothing should be using it. SCM_MAX_FD is just an arbitrary constant and it should be clear that its value is chosen in net/scm.h and not actually derived from anything else meaningful in the system. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-08-02[AF_UNIX]: Kernel memory leak fix for af_unix datagram getpeersec patchCatherine Zhang
From: Catherine Zhang <cxzhang@watson.ibm.com> This patch implements a cleaner fix for the memory leak problem of the original unix datagram getpeersec patch. Instead of creating a security context each time a unix datagram is sent, we only create the security context when the receiver requests it. This new design requires modification of the current unix_getsecpeer_dgram LSM hook and addition of two new hooks, namely, secid_to_secctx and release_secctx. The former retrieves the security context and the latter releases it. A hook is required for releasing the security context because it is up to the security module to decide how that's done. In the case of Selinux, it's a simple kfree operation. Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[AF_UNIX]: Datagram getpeersecCatherine Zhang
This patch implements an API whereby an application can determine the label of its peer's Unix datagram sockets via the auxiliary data mechanism of recvmsg. Patch purpose: This patch enables a security-aware application to retrieve the security context of the peer of a Unix datagram socket. The application can then use this security context to determine the security context for processing on behalf of the peer who sent the packet. Patch design and implementation: The design and implementation is very similar to the UDP case for INET sockets. Basically we build upon the existing Unix domain socket API for retrieving user credentials. Linux offers the API for obtaining user credentials via ancillary messages (i.e., out of band/control messages that are bundled together with a normal message). To retrieve the security context, the application first indicates to the kernel such desire by setting the SO_PASSSEC option via getsockopt. Then the application retrieves the security context using the auxiliary data mechanism. An example server application for Unix datagram socket should look like this: toggle = 1; toggle_len = sizeof(toggle); setsockopt(sockfd, SOL_SOCKET, SO_PASSSEC, &toggle, &toggle_len); recvmsg(sockfd, &msg_hdr, 0); if (msg_hdr.msg_controllen > sizeof(struct cmsghdr)) { cmsg_hdr = CMSG_FIRSTHDR(&msg_hdr); if (cmsg_hdr->cmsg_len <= CMSG_LEN(sizeof(scontext)) && cmsg_hdr->cmsg_level == SOL_SOCKET && cmsg_hdr->cmsg_type == SCM_SECURITY) { memcpy(&scontext, CMSG_DATA(cmsg_hdr), sizeof(scontext)); } } sock_setsockopt is enhanced with a new socket option SOCK_PASSSEC to allow a server socket to receive security context of the peer. Testing: We have tested the patch by setting up Unix datagram client and server applications. We verified that the server can retrieve the security context using the auxiliary data mechanism of recvmsg. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Acked-by: Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[AF_UNIX]: scm: better initializationBenjamin LaHaise
Instead of doing a memset then initialization of the fields of the scm structure, just initialize all the members explicitly. Prevent reloading of current on x86 and x86-64 by storing the value in a local variable for subsequent dereferences. This is worth a ~7KB/s increase in af_unix bandwidth. Note that we avoid the issues surrounding potentially uninitialized members of the ucred structure by constructing a struct ucred instead of assigning the members individually, which forces the compiler to zero any padding. [ I modified the patch not to use the aggregate assignment since gcc-3.4.x and earlier cannot optimize that properly at all even though gcc-4.0.x and later can -DaveM ] Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
