path: root/include/net/sch_generic.h
2007-10-26[NET_CLS_ACT]: Introduce skb_act_cloneJamal Hadi Salim
Reworked skb_clone looks uglier with the single ifdef CONFIG_NET_CLS_ACT This patch introduces skb_act_clone which will replace skb_clone in tc actions Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET_SCHED]: Making rate table lookups more flexible.Jesper Dangaard Brouer
This is done in order to, add support to changing the rate table to use the upper-boundry L2T (length to time) value. Currently we use the lower-boundry, which result in under-estimating the actual bandwidth usage. Extend the tc_ratespec struct, with two parameters: 1) "cell_align" that allow adjusting the alignment of the rate table. 2) "overhead" that allow adding a packet overhead before the lookup. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET_SCHED]: Cleanup L2T macros and handle oversized packetsJesper Dangaard Brouer
Change L2T (length to time) macros, in all rate based schedulers, to call a common function qdisc_l2t() that does the rate table lookup. This function handles if the packet size lookup is larger than the rate table, which often occurs with TSO enabled. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15[NET_SCHED]: Kill CONFIG_NET_CLS_POLICEPatrick McHardy
The NET_CLS_ACT option is now a full replacement for NET_CLS_POLICE, remove the old code. The config option will be kept around to select the equivalent NET_CLS_ACT options for a short time to allow easier upgrades. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15[NET_SCHED]: act_api: qdisc internal reclassify supportPatrick McHardy
The behaviour of NET_CLS_POLICE for TC_POLICE_RECLASSIFY was to return it to the qdisc, which could handle it internally or ignore it. With NET_CLS_ACT however, tc_classify starts over at the first classifier and never returns it to the qdisc. This makes it impossible to support qdisc-internal reclassification, which in turn makes it impossible to remove the old NET_CLS_POLICE code without breaking compatibility since we have two qdiscs (CBQ and ATM) that support this. This patch adds a tc_classify_compat function that handles reclassification the old way and changes CBQ and ATM to use it. This again is of course not fully backwards compatible with the previous NET_CLS_ACT behaviour. Unfortunately there is no way to fully maintain compatibility *and* support qdisc internal reclassification with NET_CLS_ACT, but this seems like the better choice over keeping the two incompatible options around forever. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Unline tcf_destroyPatrick McHardy
Uninline tcf_destroy and add a helper function to destroy an entire filter chain. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PKT_SCHED] qdisc: Use rtnl registration interfaceThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Fix endless loops caused by inaccurate qlen counters (part 1)Patrick McHardy
There are multiple problems related to qlen adjustment that can lead to an upper qdisc getting out of sync with the real number of packets queued, leading to endless dequeueing attempts by the upper layer code. All qdiscs must maintain an accurate q.qlen counter. There are basically two groups of operations affecting the qlen: operations that propagate down the tree (enqueue, dequeue, requeue, drop, reset) beginning at the root qdisc and operations only affecting a subtree or single qdisc (change, graft, delete class). Since qlen changes during operations from the second group don't propagate to ancestor qdiscs, their qlen values become desynchronized. This patch adds a function to propagate qlen changes up the qdisc tree, optionally calling a callback function to perform qdisc-internal maintenance when the child qdisc becomes empty. The follow-up patches will convert all qdiscs to use this function where necessary. Noticed by Timo Steinbach <tsteinbach@astaro.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Set parent classid in default qdiscsPatrick McHardy
Set parent classids in default qdiscs to allow walking up the tree from outside the qdiscs. This is needed by the next patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: net/sched annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-07-05[PKT_SCHED]: Cleanup qdisc creation and alignment macrosThomas Graf
Adds qdisc_alloc() to share code between qdisc_create() and qdisc_create_dflt(). Hides the qdisc alignment behind macros and makes use of them. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[PKT_SCHED]: Move sch_generic.c prototypes to correct header fileThomas Graf
2005-06-18[PKT_SCHED]: Generic queue management interface for qdiscs using internal ↵Thomas Graf
skb queues Implements an interface to be used by leaf qdiscs maintaining an internal skb queue. The interface maintains a backlog in bytes additionaly to the skb_queue_len() maintained by the queue itself. Relevant statistics get incremented automatically. Every function comes in two variants, one assuming Qdisc->q is used as queue and the second taking a sk_buff_head as argument. Be aware that, if you use multiple queues, you still have to maintain the Qdisc->q.qlen counter yourself. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
