path: root/include/net/netns/xfrm.h
2010-10-17netns: reorder fields in struct netEric Dumazet
In a network bench, I noticed an unfortunate false sharing between 'loopback_dev' and 'count' fields in "struct net". 'count' is written each time a socket is created or destroyed, while loopback_dev might be often read in routing code. Move loopback_dev in a read mostly section of "struct net" Note: struct netns_xfrm is cache line aligned on SMP. (It contains a "struct dst_ops") Move it at the end to avoid holes, and reduce sizeof(struct net) by 128 bytes on ia32. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-24netns xfrm: deal with dst entries in netnsAlexey Dobriyan
GC is non-existent in netns, so after you hit GC threshold, no new dst entries will be created until someone triggers cleanup in init_net. Make xfrm4_dst_ops and xfrm6_dst_ops per-netns. This is not done in a generic way, because it woule waste (AF_MAX - 2) * sizeof(struct dst_ops) bytes per-netns. Reorder GC threshold initialization so it'd be done before registering XFRM policies. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net: Allow xfrm_user_net_exit to batch efficiently.Eric W. Biederman
xfrm.nlsk is provided by the xfrm_user module and is access via rcu from other parts of the xfrm code. Add xfrm.nlsk_stash a copy of xfrm.nlsk that will never be set to NULL. This allows the synchronize_net and netlink_kernel_release to be deferred until a whole batch of xfrm.nlsk sockets have been set to NULL. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns sysctlsAlexey Dobriyan
Make net.core.xfrm_aevent_etime net.core.xfrm_acq_expires net.core.xfrm_aevent_rseqth net.core.xfrm_larval_drop sysctls per-netns. For that make net_core_path[] global, register it to prevent two /proc/net/core antries and change initcall position -- xfrm_init() is called from fs_initcall, so this one should be fs_initcall at least. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns NETLINK_XFRM socketAlexey Dobriyan
Stub senders to init_net's one temporarily. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns policy hash resizing workAlexey Dobriyan
2008-11-25netns xfrm: per-netns policy countsAlexey Dobriyan
2008-11-25netns xfrm: per-netns xfrm_policy_bydst hashAlexey Dobriyan
2008-11-25netns xfrm: per-netns inexact policiesAlexey Dobriyan
2008-11-25netns xfrm: per-netns xfrm_policy_byidx hashmaskAlexey Dobriyan
Per-netns hashes are independently resizeable. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns xfrm_policy_byidx hashAlexey Dobriyan
2008-11-25netns xfrm: per-netns policy listAlexey Dobriyan
2008-11-25netns xfrm: per-netns km_waitqAlexey Dobriyan
Disallow spurious wakeups in __xfrm_lookup(). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns state GC workAlexey Dobriyan
State GC is per-netns, and this is part of it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns state GC listAlexey Dobriyan
km_waitq is going to be made per-netns to disallow spurious wakeups in __xfrm_lookup(). To not wakeup after every garbage-collected xfrm_state (which potentially can be from different netns) make state GC list per-netns. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns xfrm_hash_workAlexey Dobriyan
All of this is implicit passing which netns's hashes should be resized. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns xfrm_state countsAlexey Dobriyan
2008-11-25netns xfrm: per-netns xfrm_state_hmaskAlexey Dobriyan
Since hashtables are per-netns, they can be independently resized. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns xfrm_state_byspi hashAlexey Dobriyan
2008-11-25netns xfrm: per-netns xfrm_state_bysrc hashAlexey Dobriyan
2008-11-25netns xfrm: per-netns xfrm_state_bydst hashAlexey Dobriyan
2008-11-25netns xfrm: per-netns xfrm_state_all listAlexey Dobriyan
This is done to get a) simple "something leaked" check b) cover possible DoSes when other netns puts many, many xfrm_states onto a list. c) not miss "alien xfrm_state" check in some of list iterators in future. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: add netns boilerplateAlexey Dobriyan
