path: root/include/net/ndisc.h
2007-10-10[IPv6]: Export userland ND options through netlink (RDNSS support)Pierre Ynard
As discussed before, this patch provides userland with a way to access relevant options in Router Advertisements, after they are processed and validated by the kernel. Extra options are processed in a generic way; this patch only exports RDNSS options described in RFC5006, but support to control which options are exported could be easily added. A new rtnetlink message type is defined, to transport Neighbor Discovery options, along with optional context information. At the moment only the address of the router sending an RDNSS option is included, but additional attributes may be later defined, if needed by new use cases. Signed-off-by: Pierre Ynard <linkfanel@yahoo.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Misc endianness annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-20[IPV6]: ROUTE: Add experimental support for Route Information Option in RA ↵YOSHIFUJI Hideaki
(RFC4191). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
