path: root/include/net/ipv6.h
2007-10-10[IPV6]: Add ICMPMsgStats MIB (RFC 4293) [rev 2]David L Stevens
Background: RFC 4293 deprecates existing individual, named ICMP type counters to be replaced with the ICMPMsgStatsTable. This table includes entries for both IPv4 and IPv6, and requires counting of all ICMP types, whether or not the machine implements the type. These patches "remove" (but not really) the existing counters, and replace them with the ICMPMsgStats tables for v4 and v6. It includes the named counters in the /proc places they were, but gets the values for them from the new tables. It also counts packets generated from raw socket output (e.g., OutEchoes, MLD queries, RA's from radvd, etc). Changes: 1) create icmpmsg_statistics mib 2) create icmpv6msg_statistics mib 3) modify existing counters to use these 4) modify /proc/net/snmp to add "IcmpMsg" with all ICMP types listed by number for easy SNMP parsing 5) modify /proc/net/snmp printing for "Icmp" to get the named data from new counters. [new to 2nd revision] 6) support per-interface ICMP stats 7) use common macro for per-device stat macros Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPV6]: Add v4mapped address inlineBrian Haley
Add v4mapped address inline to avoid calls to ipv6_addr_type(). Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[IPV6]: Remove circular dependency on if_inet6.hHerbert Xu
net/if_inet6.h includes linux/ipv6.h which also tries to include net/if_inet6.h. Since the latter only needs it for forward declarations, we can fix this by adding the declarations. A number of files are implicitly including net/if_inet6.h through linux/ipv6.h. They also use net/ipv6.h so this patch includes net/if_inet6.h there. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV6]: Do not send RH0 anymore.YOSHIFUJI Hideaki
Based on <draft-ietf-ipv6-deprecate-rh0-00.txt>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[XFRM]: Allow packet drops during larval state resolution.David S. Miller
The current IPSEC rule resolution behavior we have does not work for a lot of people, even though technically it's an improvement from the -EAGAIN buisness we had before. Right now we'll block until the key manager resolves the route. That works for simple cases, but many folks would rather packets get silently dropped until the key manager resolves the IPSEC rules. We can't tell these folks to "set the socket non-blocking" because they don't have control over the non-block setting of things like the sockets used to resolve DNS deep inside of the resolver libraries in libc. With that in mind I coded up the patch below with some help from Herbert Xu which provides packet-drop behavior during larval state resolution, controllable via sysctl and off by default. This lays the framework to either: 1) Make this default at some point or... 2) Move this logic into xfrm{4,6}_policy.c and implement the ARP-like resolution queue we've all been dreaming of. The idea would be to queue packets to the policy, then once the larval state is resolved by the key manager we re-resolve the route and push the packets out. The packets would timeout if the rule didn't get resolved in a certain amount of time. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[IPV6]: Some cleanups in include/net/ipv6.hEric Dumazet
1) struct ip6_flowlabel : moves 'users' field to avoid two 32bits holes for 64bit arches. Shrinks by 8 bytes sizeof(struct ip6_flowlabel) 2) ipv6_addr_cmp() and ipv6_addr_copy() dont need (void *) casts : Compiler might take into account natural alignement of in6_addr structs to emit better code for memcpy()/memcmp() Casts to (void *) force byte accesses. 3) ipv6_addr_prefix() optimization : Better to clear whole struct, as compiler can emit better code for memset(addr, 0, 16) (2 stores on x86_64), and avoid some conditional branches. # size vmlinux.after vmlinux.before text data bss dec hex filename 5262262 647612 557432 6467306 62aeea vmlinux.after 5262550 647612 557432 6467594 62b00a vmlinux.before thats 288 bytes saved. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[IPV6]: Get rid of __HAVE_ARCH_ADDR_SET.Eric Dumazet
__HAVE_ARCH_ADDR_SET seems unused these days, just get rid of it. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6]: Consolidate common SNMP codeHerbert Xu
This patch moves the non-proc SNMP code into addrconf.c and reuses IPv4 SNMP code where applicable. As a result we can skip proc.o if /proc is disabled. Note that I've made a number of functions static since they're only used by addrconf.c for now. If they ever get used elsewhere we can always remove the static. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6] SNMP: Use put_unaligned() instead of memcpy().YOSHIFUJI Hideaki
Hint from David Miller <davem@davemloft.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6] SNMP: Avoid unaligned accesses.YOSHIFUJI Hideaki
Because stats pointer may not be aligned for u64, use memcpy to fill u64 values. Issue reported by David Miller <davem@davemloft.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-04-25[IPV6] SNMP: Netlink interface.YOSHIFUJI Hideaki
2006-12-02[IPV6]: __ipv6_addr_diff() annotations and cleanup.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Misc endianness annotations.Al Viro
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Per-interface statistics support.YOSHIFUJI Hideaki
For IP MIB (RFC4293). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-12-02[IPV6]: flowlabels are net-endianAl Viro
2006-12-02[IPV6]: annotate struct frag_hdrAl Viro
2006-09-28[IPV6]: struct in6_addr annotationsAl Viro
in6_addr elements are net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] MIP6: Add Mobility header definition.Masahide NAKAMURA
Add Mobility header definition for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Antti Tuominen <anttit@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Allow to replace skbuff by TLV parser.Masahide NAKAMURA
In receiving Mobile IPv6 home address option which is a TLV carried by destination options header, kernel will try to mangle source adderss of packet. Think of cloned skbuff it is required to replace it by the parser just like routing header case. This is a framework to achieve that to allow TLV parser to replace inbound skbuff pointer. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Find option offset by type.Masahide NAKAMURA
This is a helper to search option offset from extension header which can carry TLV option like destination options header. Mobile IPv6 home address option will use it. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[IPV6]: Audit all ip6_dst_lookup/ip6_dst_store callsHerbert Xu
The current users of ip6_dst_lookup can be divided into two classes: 1) The caller holds no locks and is in user-context (UDP). 2) The caller does not want to lookup the dst cache at all. The second class covers everyone except UDP because most people do the cache lookup directly before calling ip6_dst_lookup. This patch adds ip6_sk_dst_lookup for the first class. Similarly ip6_dst_store users can be divded into those that need to take the socket dst lock and those that don't. This patch adds __ip6_dst_store for those (everyone except UDP/datagram) that don't need an extra lock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-18[IPV6]: Clean up hop-by-hop options handler.YOSHIFUJI Hideaki
- Removed unused argument (nhoff) for ipv6_parse_hopopts(). - Make ipv6_parse_hopopts() to align with other extension header handlers. - Removed pointless assignment (hdr), which is not used afterwards. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: {get|set}sockopt compatibility layerDmitry Mishin
This patch extends {get|set}sockopt compatibility layer in order to move protocol specific parts to their place and avoid huge universal net/compat.c file in the future. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NETFILTER]: Move ip6_masked_addrcmp to include/net/ipv6.hPatrick McHardy
Replace netfilter's ip6_masked_addrcmp by a more efficient version in include/net/ipv6.h to make it usable without module dependencies. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV4/6]: Netfilter IPsec input hooksPatrick McHardy
When the innermost transform uses transport mode the decapsulated packet is not visible to netfilter. Pass the packet through the PRE_ROUTING and LOCAL_IN hooks again before handing it to upper layer protocols to make netfilter-visibility symetrical to the output path. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET6]: Generalise tcp_v6_hash_connectArnaldo Carvalho de Melo
Renaming it to inet6_hash_connect, making it possible to ditch dccp_v6_hash_connect and share the same code with TCP instead. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Export ipv6_opt_acceptedArnaldo Carvalho de Melo
It was already non-TCP specific, will be used by DCCPv6. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-20Merge git://git.skbuff.net/gitroot/yoshfuji/linux-2.6.14+advapi-fix/David S. Miller
2005-11-20[IPV6]: Fix sending extension headers before and including routing header.YOSHIFUJI Hideaki
Based on suggestion from Masahide Nakamura <nakam@linux-ipv6.org>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2005-11-08[IPV6]: Make ipv6_addr_type() more generic so that we can use it for source ↵YOSHIFUJI Hideaki
address selection. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[IPV6]: Put addr_diff() into common header for future use.YOSHIFUJI Hideaki
2005-09-08[IPV6]: Support IPV6_{RECV,}TCLASS socket options / ancillary data.YOSHIFUJI Hideaki
Based on patch from David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2005-09-08[IPV6]: Support several new sockopt / ancillary data in Advanced API (RFC3542).YOSHIFUJI Hideaki
Support several new socket options / ancillary data: IPV6_RECVPKTINFO, IPV6_PKTINFO, IPV6_RECVHOPOPTS, IPV6_HOPOPTS, IPV6_RECVDSTOPTS, IPV6_DSTOPTS, IPV6_RTHDRDSTOPTS, IPV6_RECVRTHDR, IPV6_RTHDR, IPV6_RECVHOPOPTS, IPV6_HOPOPTS Old semantics are preserved as IPV6_2292xxxx so that we can maintain backward compatibility. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Cleanup INET_REFCNT_DEBUG codeArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[IPV6]: remove more unused IPV6_AUTHHDR things.YOSHIFUJI Hideaki
Remove two more unused IPV6_AUTHHDR option things, which I failed to remove them last time, plus, mark IPV6_AUTHHDR obsolete. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[SELINUX]: Fix ipv6_skip_exthdr() invocation causing OOPS.Herbert Xu
The SELinux hooks invoke ipv6_skip_exthdr() with an incorrect length final argument. However, the length argument turns out to be superfluous. I was just reading ipv6_skip_exthdr and it occured to me that we can get rid of len altogether. The only place where len is used is to check whether the skb has two bytes for ipv6_opt_hdr. This check is done by skb_header_pointer/skb_copy_bits anyway. Now it might appear that we've made the code slower by deferring the check to skb_copy_bits. However, this check should not trigger in the common case so this is OK. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
