path: root/include/net/ip6_route.h
2009-11-04net: cleanup include/netEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-14netns: Add network namespace argument to rt6_fill_node() and ↵Brian Haley
ipv6_dev_get_saddr() ipv6_dev_get_saddr() blindly de-references dst_dev to get the network namespace, but some callers might pass NULL. Change callers to pass a namespace pointer instead. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13ipv6: Kill unused ip6_prohibit_entry and ip6_blk_hole_entry declarations.Rami Rosen
This patch removes ip6_prohibit_entry and ip6_blk_hole_entry declarations from include/net/ip6_route.h as they are unused. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13ipv6: ip6_route.h cleanup.Rami Rosen
This patch removes rt6_lock declaration from include/net/ip6_route.h as it is unused. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22ipv6: icmp6_dst_gc return changeStephen Hemminger
Change icmp6_dst_gc to return the one value the caller cares about rather than using call by reference. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[IPV6]: Make address arguments const.YOSHIFUJI Hideaki
- net/ipv6/addrconf.c: ipv6_get_ifaddr(), ipv6_dev_get_saddr() - net/ipv6/mcast.c: ipv6_sock_mc_join(), ipv6_sock_mc_drop(), inet6_mc_check(), ipv6_dev_mc_inc(), __ipv6_dev_mc_dec(), ipv6_dev_mc_dec(), ipv6_chk_mcast_addr() - net/ipv6/route.c: rt6_lookup(), icmp6_dst_alloc() - net/ipv6/ip6_output.c: ip6_nd_hdr() - net/ipv6/ndisc.c: ndisc_send_ns(), ndisc_send_rs(), ndisc_send_redirect(), ndisc_get_neigh(), __ndisc_send() Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-10[IPV6]: Remove unused declarations in include/net/ip6_route.h.Rami Rosen
1) Standlaone ip6_null_entry is no longer needed as it is replaced by the ip6_null_entry member of ipv6 (instance of struct netns_ipv6) in struct net (as a result of Network Namespaces patches). 2) These 3 methods from this same header are not defined anywhere: ip6_rt_addr_add(), ip6_rt_addr_del(), rt6_sndmsg() Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[IPV6]: Support Source Address Selection API (RFC5014).YOSHIFUJI Hideaki
2008-03-25[IPV6]: Optimize hop-limit determination.YOSHIFUJI Hideaki
Last part of hop-limit determination is always: hoplimit = dst_metric(dst, RTAX_HOPLIMIT); if (hoplimit < 0) hoplimit = ipv6_get_hoplimit(dst->dev). Let's consolidate it as ip6_dst_hoplimit(dst). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-05[NETNS][IPV6] route6 - add netns parameter to ip6_route_outputDaniel Lezcano
Add an netns parameter to ip6_route_output. That will allow to access to the right routing table for outgoing traffic. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[NETNS][IPV6] rt6_info - make rt6_info accessed as a pointerDaniel Lezcano
This patch make mindless changes and prepares the code to use dynamic allocation for rt6_info structure. The code accesses the rt6_info structure as a pointer instead of a global static variable. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[NETNS][IPV6] route6 - make route6 per namespaceDaniel Lezcano
This patch makes the routing engine use the network namespaces to access routing informations: Add a network namespace parameter to ipv6_route_ioctl and propagate the network namespace value to all the routing code that have not yet been changed. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[NETNS][IPV6] route6 - Pass the network namespace parameter to ↵Daniel Lezcano
rt6_purge_dflt_routers Add a network namespace parameter to rt6_purge_dflt_routers. This is needed to call fib6_get_table with the appropriate network namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[NETNS][IPV6] route6 - Pass the network namespace parameter to rt6_lookupDaniel Lezcano
Add a network namespace parameter to rt6_lookup(). Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-03[NETNS][IPV6] ip6_fib - gc timer per namespaceDaniel Lezcano
Move the timer initialization at the network namespace creation and store the network namespace in the timer argument. That enables multiple timers (one per network namespace) to do garbage collecting. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-03[NETNS][IPV6] ip6_fib - fib6_clean_all handle several network namespacesDaniel Lezcano
The function fib6_clean_all takes the network namespace as parameter. That allows to flush the routes related to a specific network namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[IPV6]: Make ndisc_dst_alloc() common for later use.YOSHIFUJI Hideaki
For later use, this patch is renaming ndisc_dst_alloc() (and related function/structures) to icmp6_dst_alloc() (and so on). This patch also removing unused function- pointer argument for it. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-07[IPV6] Minor clenup: remove two unused definitions in net/ip6_route.hRami Rosen
Remove IP6_RT_PRIO_FW and IP6_RT_FLOW_MASK definitions in include/net/ip6_route.h, as they are not used in the kernel. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][IPV6]: Make sysctls route per namespace.Daniel Lezcano
All the sysctl concerning the routes are moved to the network namespace structure. A helper function is called to initialize the variables. Because the ipv6 protocol is not yet per namespace, the variables are accessed relatively from the network namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: Make ip6_route_init to return an error code.Daniel Lezcano
The route initialization function does not return any value to notify if the initialization is successful or not. This patch checks all calls made for the initilization in order to return a value for the caller. Unfortunately, proc_net_fops_create will return a NULL pointer if CONFIG_PROC_FS is off, so we can not check the return code without an ifdef CONFIG_PROC_FS block in the ip6_route_init function. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Acked-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPv6]: Use rtnl registration interfaceThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Misc endianness annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[IPV6]: Remove struct pol_chain.Ville Nuorvala
Struct pol_chain has existed since at least the 2.2 kernel, but isn't used anymore. As the IPv6 policy routing is implemented in a totally different way in the current kernel, just get rid of it. Signed-off-by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: ip6table_mangle: reroute when nfmark changes in NF_IP6_LOCAL_OUTPatrick McHardy
Now that IPv6 supports policy routing we need to reroute in NF_IP6_LOCAL_OUT when the mark value changes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] ROUTE: Unify RT6_F_xxx and RT6_SELECT_F_xxx flagsYOSHIFUJI Hideaki
Unify RT6_F_xxx and RT6_SELECT_F_xxx flags into RT6_LOOKUP_F_xxx flags, and put them into ip6_route.h Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Ville Nuorvala <vnuorval@tcs.hut.fi Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Cache source address as well in ipv6_pinfo{}.YOSHIFUJI Hideaki
Based on MIPL2 kernel patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] NDISC: Take source address into account for redirects.YOSHIFUJI Hideaki
2006-09-22[IPv6] route: FIB6 configuration using struct fib6_configThomas Graf
Replaces the struct in6_rtmsg based interface orignating from the ioctl interface with a struct fib6_config based on. Allows changing the interface without breaking the ioctl interface and avoids passing on tons of parameters. The recently introduced struct nl_info is used to pass on netlink authorship information for notifications. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPv6] route: Simplify ip6_ins_rt()Thomas Graf
Provide a simple ip6_ins_rt() for the majority of users and an alternative for the exception via netlink. Avoids code obfuscation. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPv6] route: Simplify ip6_del_rt()Thomas Graf
Provide a simple ip6_del_rt() for the majority of users and an alternative for the exception via netlink. Avoids code obfuscation. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Increase number of possible routing tables to 2^32Patrick McHardy
Increase number of possible routing tables to 2^32 by replacing iterations over all possible table IDs by hash table walking. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Policy Routing RulesThomas Graf
Adds support for policy routing rules including a new local table for routes with a local destination. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Multiple Routing TablesThomas Graf
Adds the framework to support multiple IPv6 routing tables. Currently all automatically generated routes are put into the same table. This could be changed at a later point after considering the produced locking overhead. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[IPV6]: Audit all ip6_dst_lookup/ip6_dst_store callsHerbert Xu
The current users of ip6_dst_lookup can be divided into two classes: 1) The caller holds no locks and is in user-context (UDP). 2) The caller does not want to lookup the dst cache at all. The second class covers everyone except UDP because most people do the cache lookup directly before calling ip6_dst_lookup. This patch adds ip6_sk_dst_lookup for the first class. Similarly ip6_dst_store users can be divded into those that need to take the socket dst lock and those that don't. This patch adds __ip6_dst_store for those (everyone except UDP/datagram) that don't need an extra lock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-30[IPV6]: Added GSO support for TCPv6Herbert Xu
This patch adds GSO support for IPv6 and TCPv6. This is based on a patch by Ananda Raju <Ananda.Raju@neterion.com>. His original description is: This patch enables TSO over IPv6. Currently Linux network stacks restricts TSO over IPv6 by clearing of the NETIF_F_TSO bit from "dev->features". This patch will remove this restriction. This patch will introduce a new flag NETIF_F_TSO6 which will be used to check whether device supports TSO over IPv6. If device support TSO over IPv6 then we don't clear of NETIF_F_TSO and which will make the TCP layer to create TSO packets. Any device supporting TSO over IPv6 will set NETIF_F_TSO6 flag in "dev->features" along with NETIF_F_TSO. In case when user disables TSO using ethtool, NETIF_F_TSO will get cleared from "dev->features". So even if we have NETIF_F_TSO6 we don't get TSO packets created by TCP layer. SKB_GSO_TCPV4 renamed to SKB_GSO_TCP to make it generic GSO packet. SKB_GSO_UDPV4 renamed to SKB_GSO_UDP as UFO is not a IPv4 feature. UFO is supported over IPv6 also The following table shows there is significant improvement in throughput with normal frames and CPU usage for both normal and jumbo. -------------------------------------------------- | | 1500 | 9600 | | ------------------|-------------------| | | thru CPU | thru CPU | -------------------------------------------------- | TSO OFF | 2.00 5.5% id | 5.66 20.0% id | -------------------------------------------------- | TSO ON | 2.63 78.0 id | 5.67 39.0% id | -------------------------------------------------- Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV6]: ROUTE: Add experimental support for Route Information Option in RA ↵YOSHIFUJI Hideaki
(RFC4191). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV6]: ROUTE: Add support for Router Preference (RFC4191).YOSHIFUJI Hideaki
2006-03-20[IPV6]: ROUTE: Eliminate lock for default route pointer.YOSHIFUJI Hideaki
And prepare for more advanced router selection. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[IPV6]: V6 route events reported with wrong netlink PID and seq numberJamal Hadi Salim
Essentially netlink at the moment always reports a pid and sequence of 0 always for v6 route activities. To understand the repurcassions of this look at: http://lists.quagga.net/pipermail/quagga-dev/2005-June/003507.html While fixing this, i took the liberty to resolve the outstanding issue of IPV6 routes inserted via ioctls to have the correct pids as well. This patch tries to behave as close as possible to the v4 routes i.e maintains whatever PID the socket issuing the command owns as opposed to the process. That made the patch a little bulky. I have tested against both netlink derived utility to add/del routes as well as ioctl derived one. The Quagga folks have tested against quagga. This fixes the problem and so far hasnt been detected to introduce any new issues. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
