path: root/include/net/inet_common.h
2015-11-02net: avoid NULL deref in inet_ctl_sock_destroy()Eric Dumazet
Under low memory conditions, tcp_sk_init() and icmp_sk_init() can both iterate on all possible cpus and call inet_ctl_sock_destroy(), with eventual NULL pointer. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-11net: Modify sk_alloc to not reference count the netns of kernel sockets.Eric W. Biederman
Now that sk_alloc knows when a kernel socket is being allocated modify it to not reference count the network namespace of kernel sockets. Keep track of if a socket needs reference counting by adding a flag to struct sock called sk_net_refcnt. Update all of the callers of sock_create_kern to stop using sk_change_net and sk_release_kernel as those hacks are no longer needed, to avoid reference counting a kernel socket. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: Remove iocb argument from sendmsg and recvmsgYing Xue
After TIPC doesn't depend on iocb argument in its internal implementations of sendmsg() and recvmsg() hooks defined in proto structure, no any user is using iocb argument in them at all now. Then we can drop the redundant iocb argument completely from kinds of implementations of both sendmsg() and recvmsg() in the entire networking stack. Cc: Christoph Hellwig <hch@lst.de> Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26net-timestamp: make tcp_recvmsg call ipv6_recv_error for AF_INET6 socksWillem de Bruijn
TCP timestamping introduced MSG_ERRQUEUE handling for TCP sockets. If the socket is of family AF_INET6, call ipv6_recv_error instead of ip_recv_error. This change is more complex than a single branch due to the loadable ipv6 module. It reuses a pre-existing indirect function call from ping. The ping code is safe to call, because it is part of the core ipv6 module and always present when AF_INET6 sockets are active. Fixes: 4ed2d765 (net-timestamp: TCP timestamping) Signed-off-by: Willem de Bruijn <willemb@google.com> ---- It may also be worthwhile to add WARN_ON_ONCE(sk->family == AF_INET6) to ip_recv_error. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-21inet*.h: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-19net-tcp: Fast Open client - sendmsg(MSG_FASTOPEN)Yuchung Cheng
sendmsg() (or sendto()) with MSG_FASTOPEN is a combo of connect(2) and write(2). The application should replace connect() with it to send data in the opening SYN packet. For blocking socket, sendmsg() blocks until all the data are buffered locally and the handshake is completed like connect() call. It returns similar errno like connect() if the TCP handshake fails. For non-blocking socket, it returns the number of bytes queued (and transmitted in the SYN-data packet) if cookie is available. If cookie is not available, it transmits a data-less SYN packet with Fast Open cookie request option and returns -EINPROGRESS like connect(). Using MSG_FASTOPEN on connecting or connected socket will result in simlar errno like repeating connect() calls. Therefore the application should only use this flag on new sockets. The buffer size of sendmsg() is independent of the MSS of the connection. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12inet, inet6: make tcp_sendmsg() and tcp_sendpage() through inet_sendmsg() ↵Changli Gao
and inet_sendpage() a new boolean flag no_autobind is added to structure proto to avoid the autobind calls when the protocol is TCP. Then sock_rps_record_flow() is called int the TCP's sendmsg() and sendpage() pathes. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- include/net/inet_common.h | 4 ++++ include/net/sock.h | 1 + include/net/tcp.h | 8 ++++---- net/ipv4/af_inet.c | 15 +++++++++------ net/ipv4/tcp.c | 11 +++++------ net/ipv4/tcp_ipv4.c | 3 +++ net/ipv6/af_inet6.c | 8 ++++---- net/ipv6/tcp_ipv6.c | 3 +++ 8 files changed, 33 insertions(+), 20 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net: cleanupsChangli Gao
remove useless blanks. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- include/net/inet_common.h | 55 ++++------- include/net/tcp.h | 222 +++++++++++++++++----------------------------- include/net/udp.h | 38 +++---- 3 files changed, 123 insertions(+), 192 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[NETNS]: Inet control socket should not hold a namespace.Denis V. Lunev
This is a generic requirement, so make inet_ctl_sock_create namespace aware and create a inet_ctl_sock_destroy wrapper around sk_release_kernel. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[INET]: Let inet_ctl_sock_create return sock rather than socket.Denis V. Lunev
All upper protocol layers are already use sock internally. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[INET]: Rename inet_csk_ctl_sock_create to inet_ctl_sock_create.Denis V. Lunev
This call is nothing common with INET connection sockets code. It simply creates an unhashes kernel sockets for protocol messages. Move the new call into af_inet.c after the rename. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[INET]: Remove leftover prototypes from include/net/inet_common.hArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Move the TCP hashtable functions/structs to inet_hashtables.[ch]Arnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Cleanup INET_REFCNT_DEBUG codeArnaldo Carvalho de Melo
