path: root/include/net/inet6_hashtables.h
2006-12-02[IPV6]: annotate inet6_hashtablesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-09[IPV6]: Deinline few large functions in inet6 codeDenis Vlasenko
Deinline a few functions which produce 200+ bytes of code. Size Uses Wasted Name and definition ===== ==== ====== ================================================ 429 3 818 __inet6_lookup include/net/inet6_hashtables.h 404 2 384 __inet6_lookup_established include/net/inet6_hashtables.h 206 3 372 __inet6_hash include/net/inet6_hashtables.h Signed-off-by: Denis Vlasenko <vda@ilport.com.ua> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Introduce inet6_timewait_sockArnaldo Carvalho de Melo
Out of tcp6_timewait_sock, that now is just an aggregation of inet_timewait_sock and inet6_timewait_sock, using tw_ipv6_offset in struct inet_timewait_sock, that is common to the IPv6 transport protocols that use timewait sockets, like DCCP and TCP. tw_ipv6_offset plays the struct inet_sock pinfo6 role, i.e. for the generic code to find the IPv6 area in a timewait sock. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise __tcp_v6_hash, renaming it to __inet6_hashArnaldo Carvalho de Melo
2005-10-03[INET]: speedup inet (tcp/dccp) lookupsEric Dumazet
Arnaldo and I agreed it could be applied now, because I have other pending patches depending on this one (Thank you Arnaldo) (The other important patch moves skc_refcnt in a separate cache line, so that the SMP/NUMA performance doesnt suffer from cache line ping pongs) 1) First some performance data : -------------------------------- tcp_v4_rcv() wastes a *lot* of time in __inet_lookup_established() The most time critical code is : sk_for_each(sk, node, &head->chain) { if (INET_MATCH(sk, acookie, saddr, daddr, ports, dif)) goto hit; /* You sunk my battleship! */ } The sk_for_each() does use prefetch() hints but only the begining of "struct sock" is prefetched. As INET_MATCH first comparison uses inet_sk(__sk)->daddr, wich is far away from the begining of "struct sock", it has to bring into CPU cache cold cache line. Each iteration has to use at least 2 cache lines. This can be problematic if some chains are very long. 2) The goal ----------- The idea I had is to change things so that INET_MATCH() may return FALSE in 99% of cases only using the data already in the CPU cache, using one cache line per iteration. 3) Description of the patch --------------------------- Adds a new 'unsigned int skc_hash' field in 'struct sock_common', filling a 32 bits hole on 64 bits platform. struct sock_common { unsigned short skc_family; volatile unsigned char skc_state; unsigned char skc_reuse; int skc_bound_dev_if; struct hlist_node skc_node; struct hlist_node skc_bind_node; atomic_t skc_refcnt; + unsigned int skc_hash; struct proto *skc_prot; }; Store in this 32 bits field the full hash, not masked by (ehash_size - 1) Using this full hash as the first comparison done in INET_MATCH permits us immediatly skip the element without touching a second cache line in case of a miss. Suppress the sk_hashent/tw_hashent fields since skc_hash (aliased to sk_hash and tw_hash) already contains the slot number if we mask with (ehash_size - 1) File include/net/inet_hashtables.h 64 bits platforms : #define INET_MATCH(__sk, __hash, __cookie, __saddr, __daddr, __ports, __dif)\ (((__sk)->sk_hash == (__hash)) ((*((__u64 *)&(inet_sk(__sk)->daddr)))== (__cookie)) && \ ((*((__u32 *)&(inet_sk(__sk)->dport))) == (__ports)) && \ (!((__sk)->sk_bound_dev_if) || ((__sk)->sk_bound_dev_if == (__dif)))) 32bits platforms: #define TCP_IPV4_MATCH(__sk, __hash, __cookie, __saddr, __daddr, __ports, __dif)\ (((__sk)->sk_hash == (__hash)) && \ (inet_sk(__sk)->daddr == (__saddr)) && \ (inet_sk(__sk)->rcv_saddr == (__daddr)) && \ (!((__sk)->sk_bound_dev_if) || ((__sk)->sk_bound_dev_if == (__dif)))) - Adds a prefetch(head->chain.first) in __inet_lookup_established()/__tcp_v4_check_established() and __inet6_lookup_established()/__tcp_v6_check_established() and __dccp_v4_check_established() to bring into cache the first element of the list, before the {read|write}_lock(&head->lock); Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET6_HASHTABLES]: Move inet6_lookup functions to net/ipv6/inet6_hashtables.cArnaldo Carvalho de Melo
Doing this we allow tcp_diag to support IPV6 even if tcp_diag is compiled statically and IPV6 is compiled as a module, removing the previous restriction while not building any IPV6 code if it is not selected. Now to work on the tcpdiag_register infrastructure and then to rename the whole thing to inetdiag, reflecting its by then completely generic nature. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV6]: Generalise the tcp_v6_lookup routinesArnaldo Carvalho de Melo
In the same way as was done with the v4 counterparts, this will be moved to inet6_hashtables.c. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
