path: root/include/net/ieee802154_netdev.h
2014-05-16ieee802154, mac802154: implement devkey record optionPhoebe Buckheister
The 802.15.4-2011 standard states that for each key, a list of devices that use this key shall be kept. Previous patches have only considered two options: * a device "uses" (or may use) all keys, rendering the list useless * a device is restricted to a certain set of keys Another option would be that a device *may* use all keys, but need not do so, and we are interested in the actual set of keys the device uses. Recording keys used by any given device may have a noticable performance impact and might not be needed as often. The common case, in which a device will not switch keys too often, should still perform well. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16mac802154: add llsec configuration functionsPhoebe Buckheister
2014-05-16mac802154: integrate llsec with wpan devicesPhoebe Buckheister
2014-05-16ieee802154: add types for link-layer securityPhoebe Buckheister
The added structures match 802.15.4-2011 link-layer security PIBs as closely as is reasonable. Some lists required by the standard were modeled as bitmaps (frame_types and command_frame_ids in *llsec_key, 802.15.4-2011 7.5/Table 61), since using lists for those seems a bit excessive and not particularly useful. The DeviceDescriptorHandleList was inverted and is here a per-device list, since operations on this list are likely to have both a key and a device at hand, and per-device lists of keys are shorter than per-key lists of devices. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15ieee802154: change _cb handling slightlyPhoebe Buckheister
The current mac_cb handling of ieee802154 is rather awkward and limited. Decompose the single flags field into multiple fields with the meanings of each subfield of the flags field to make future extensions (for example, link-layer security) easier. Also don't set the frame sequence number in upper layers, since that's a thing the MAC is supposed to set on frame transmit - we set it on header creation, but assuming that upper layers do not blindly duplicate our headers, this is fine. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15ieee802154: add definitions for link-layer security and header functionsPhoebe Buckheister
When dealing with 802.15.4, one often has to know the maximum payload size for a given packet. This depends on many factors, one of which is whether or not a security header is present in the frame. These definitions and functions provide an easy way for any upper layer to calculate the maximum payload size for a packet. The first obvious user for this is 6lowpan, which duplicates this calculation and gets it partially wrong because it ignores security headers. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-01mac802154: make csma/cca parameters per-wpanPhoebe Buckheister
Commit 9b2777d6089bcd (ieee802154: add TX power control to wpan_phy) and following erroneously added CSMA and CCA parameters for 802.15.4 devices as PHY parameters, while they are actually MAC parameters and can differ for any two WPAN instances. Since it is now sensible to have multiple WPAN devices with differing CSMA/CCA parameters, make these parameters MAC parameters instead. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-146lowpan: move lowpan frag_info out of 802.15.4 headersPhoebe Buckheister
Fragmentation and reassembly information for 6lowpan is independent from the 802.15.4 stack and used only by the 6lowpan reassembly process. Move the ieee802154_frag_info struct to a private are, it needn't be in the 802.15.4 skb control block. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: use ieee802154_addr instead of *_sa variantsPhoebe Buckheister
Change all internal uses of ieee802154_addr_sa to ieee802154_addr, except for those instances that communicate directly with userspace. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14mac802154: use header operations to create/parse headersPhoebe Buckheister
Use the operations on 802.15.4 header structs introduced in a previous patch to create and parse all headers in the mac802154 stack. This patch reduces code duplication between different parts of the mac802154 stack that needed information from headers, and also fixes a few bugs that seem to have gone unnoticed until now: * 802.15.4 dgram sockets would return a slightly incorrect value for the SIOCINQ ioctl * mac802154 would not drop frames with the "security enabled" bit set, even though it does not support security, in violation of the standard Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: add header structs with endiannes and operationsPhoebe Buckheister
This patch provides a set of structures to represent 802.15.4 MAC headers, and a set of operations to push/pull/peek these structs from skbs. We cannot simply pointer-cast the skb MAC header pointer to these structs, because 802.15.4 headers are wildly variable - depending on the first three bytes, virtually all other fields of the header may be present or not, and be present with different lengths. The new header creation/parsing routines also support 802.15.4 security headers, which are currently not supported by the mac802154 implementation of the protocol. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: enforce consistent endianness in the 802.15.4 stackPhoebe Buckheister
Enable sparse warnings about endianness, replace the remaining fields regarding network operations without explicit endianness annotations with such that are annotated, and propagate this through the entire stack. Uses of ieee802154_addr_sa are not changed yet, this patch is only concerned with all other fields (such as address filters, operation parameters and the likes). Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: add address struct with proper endiannes and some operationsPhoebe Buckheister
Add a replacement ieee802154_addr struct with proper endianness on fields. Short address fields are stored as __le16 as on the network, extended (EUI64) addresses are __le64 as opposed to the u8[8] format used previously. This disconnect with the netdev address, which is stored as big-endian u8[8], is intentional. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: rename struct ieee802154_addr to *_saPhoebe Buckheister
The struct as currently defined uses host byte order for some fields, and most big endian/EUI display byte order for other fields. Inside the stack, endianness should ideally match network byte order where possible to minimize the number of byteswaps done in critical paths, but this patch does not address this; it is only preparatory. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-286lowpan: add frag information structAlexander Aring
This patch adds a 6lowpan fragmentation struct into cb of skb which is necessary to hold fragmentation information. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-08ieee802154/nl-mac.c: make some MLME operations optionalWerner Almesberger
Check for NULL before calling the following operations from "struct ieee802154_mlme_ops": assoc_req, assoc_resp, disassoc_req, start_req, and scan_req. This fixes a current oops where those functions are called but not implemented. It also updates the documentation to clarify that they are now optional by design. If a call to an unimplemented function is attempted, the kernel returns EOPNOTSUPP via netlink. The following operations are still required: get_phy, get_pan_id, get_short_addr, and get_dsn. Note that the places where this patch changes the initialization of "ret" should not affect the rest of the code since "ret" was always set (again) before returning its value. Signed-off-by: Werner Almesberger <werner@almesberger.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-08IEEE 802.15.4: remove get_bsn from "struct ieee802154_mlme_ops"Werner Almesberger
It served no purpose: we never call it from anywhere in the stack and the only driver that did implement it (fakehard) merely provided a dummy value. There is also considerable doubt whether it would make sense to even attempt beacon processing at this level in the Linux kernel. Signed-off-by: Werner Almesberger <werner@almesberger.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: declare reduced mlme operationsalex.bluesman.smirnov@gmail.com
According IEEE 802.15.4 standard each node can be either full functionality device (FFD) or reduce functionality device (RFD). So 2 sets of operations are needed. This patch declare RFD operations structure. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: RX data pathalex.bluesman.smirnov@gmail.com
Main RX data path implementation between physical and mac layers. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06ieee802154: add an mlme_ops call to retrieve PHY objectDmitry Eremin-Solenikov
ops->get_phy should increment reference to wpan-phy. As we return the external structure, we should do refcounting correctly. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-11-06ieee802154: constify struct net_device in some operationsDmitry Eremin-Solenikov
Some of ieee802154 operations really shouldn't change passed net_device. Constify passed argument. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-08-19ieee802154: add support for channel pages from IEEE 802.15.4-2006Dmitry Eremin-Solenikov
IEEE 802.15.4-2006 adds new concept: channel pages, which can contain several channels. Add support for channel pages in the API and in the fakehard driver. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-07-23ieee802154: move headers out of extra directoryDmitry Eremin-Solenikov
include/net/ieee802154/af_ieee802154.h (and others) naming seems to be too long and redundant. Drop one level of subdirectories. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
