path: root/include/net/icmp.h
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
