path: root/include/net/flow.h
2012-02-04ipv4: reset flowi parameters on route connectJulian Anastasov
Eric Dumazet found that commit 813b3b5db83 (ipv4: Use caller's on-stack flowi as-is in output route lookups.) that comes in 3.0 added a regression. The problem appears to be that resulting flowi4_oif is used incorrectly as input parameter to some routing lookups. The result is that when connecting to local port without listener if the IP address that is used is not on a loopback interface we incorrectly assign RTN_UNICAST to the output route because no route is matched by oif=lo. The RST packet can not be sent immediately by tcp_v4_send_reset because it expects RTN_LOCAL. So, change ip_route_connect and ip_route_newports to update the flowi4 fields that are input parameters because we do not want unnecessary binding to oif. To make it clear what are the input parameters that can be modified during lookup and to show which fields of floiw4 are reused add a new function to update the flowi4 structure: flowi4_update_output. Thanks to Yurij M. Plotnikov for providing a bug report including a program to reproduce the problem. Thanks to Eric Dumazet for tracking the problem down to tcp_v4_send_reset and providing initial fix. Reported-by: Yurij M. Plotnikov <Yurij.Plotnikov@oktetlabs.ru> Signed-off-by: Julian Anastasov <ja@ssi.bg> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-17net: fix some sparse errorsEric Dumazet
make C=2 CF="-D__CHECK_ENDIAN__" M=net And fix flowi4_init_output() prototype for sport Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/bluetooth/l2cap_core.c Just two overlapping changes, one added an initialization of a local variable, and another change added a new local variable. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-21net: Add a flow_cache_flush_deferred functionSteffen Klassert
flow_cach_flush() might sleep but can be called from atomic context via the xfrm garbage collector. So add a flow_cache_flush_deferred() function and use this if the xfrm garbage colector is invoked from within the packet path. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-01ipv4: use a 64bit load/store in output pathEric Dumazet
gcc compiler is smart enough to use a single load/store if we memcpy(dptr, sptr, 8) on x86_64, regardless of CONFIG_CC_OPTIMIZE_FOR_SIZE In IP header, daddr immediately follows saddr, this wont change in the future. We only need to make sure our flowi4 (saddr,daddr) fields wont break the rule. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-16net: Handle different key sizes between address families in flow cachedpward
With the conversion of struct flowi to a union of AF-specific structs, some operations on the flow cache need to account for the exact size of the key. Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-16net: Align AF-specific flowi structs to longDavid Ward
AF-specific flowi structs are now passed to flow_key_compare, which must also be aligned to a long. Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-31net: Order ports in same order as addresses in flow objects.David S. Miller
For consistency. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-31net: Add helper flowi4_init_output().David S. Miller
On-stack initialization via assignment of flow structures are expensive because GCC emits a memset() to clear the entire structure out no matter what. Add a helper for ipv4 output flow key setup which we can use to avoid the memset. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12decnet: Convert to use flowidn where applicable.David S. Miller
2011-03-12net: Put fl6_* macros to struct flowi6 and use them again.David S. Miller
2011-03-12net: Put fl4_* macros to struct flowi4 and use them again.David S. Miller
2011-03-12net: Add flowi6_* member helper macros.David S. Miller
2011-03-12ipv4: Pass ipv4 flow objects into fib_lookup() paths.David S. Miller
To start doing these conversions, we need to add some temporary flow4_* macros which will eventually go away when all the protocol code paths are changed to work on AF specific flowi objects. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Add flowiX_to_flowi() shorthands.David S. Miller
This is just a shorthand which will help in passing around AF specific flow structures as generic ones. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Break struct flowi out into AF specific instances.David S. Miller
Now we have struct flowi4, flowi6, and flowidn for each address family. And struct flowi is just a union of them all. It might have been troublesome to convert flow_cache_uli_match() but as it turns out this function is completely unused and therefore can be simply removed. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Make flowi ports AF dependent.David S. Miller
Create two sets of port member accessors, one set prefixed by fl4_* and the other prefixed by fl6_* This will let us to create AF optimal flow instances. It will work because every context in which we access the ports, we have to be fully aware of which AF the flowi is anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Create union flowi_uliDavid S. Miller
This will be used when we have seperate flowi types. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Create struct flowi_commonDavid S. Miller
Pull out the AF independent members of struct flowi into a new struct flowi_common Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Remove unnecessary padding in struct flowiDavid S. Miller
Move tos, scope, proto, and flags to the beginning of the structure. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01net: Add FLOWI_FLAG_CAN_SLEEP.David S. Miller
And set is in contexts where the route resolution can sleep. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22net: Make flow cache paths use a const struct flowi.David S. Miller
2011-02-22net: Mark flowi arg to flow_cache_uli_match() const.David S. Miller
2011-01-27net: Pre-COW metrics for TCP.David S. Miller
TCP is going to record metrics for the connection, so pre-COW the route metrics at route cache entry creation time. This avoids several atomic operations that have to occur if we COW the metrics after the entry reaches global visibility. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-23Revert "ipv4: Allow configuring subnets as local addresses"David S. Miller
This reverts commit 4465b469008bc03b98a1b8df4e9ae501b6c69d4b. Conflicts: net/ipv4/fib_frontend.c As reported by Ben Greear, this causes regressions: > Change 4465b469008bc03b98a1b8df4e9ae501b6c69d4b caused rules > to stop matching the input device properly because the > FLOWI_FLAG_MATCH_ANY_IIF is always defined in ip_dev_find(). > > This breaks rules such as: > > ip rule add pref 512 lookup local > ip rule del pref 0 lookup local > ip link set eth2 up > ip -4 addr add 172.16.0.102/24 broadcast 172.16.0.255 dev eth2 > ip rule add to 172.16.0.102 iif eth2 lookup local pref 10 > ip rule add iif eth2 lookup 10001 pref 20 > ip route add 172.16.0.0/24 dev eth2 table 10001 > ip route add unreachable 0/0 table 10001 > > If you had a second interface 'eth0' that was on a different > subnet, pinging a system on that interface would fail: > > [root@ct503-60 ~]# ping 192.168.100.1 > connect: Invalid argument Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15xfrm: use gre key as flow upper protocol infoTimo Teräs
The GRE Key field is intended to be used for identifying an individual traffic flow within a tunnel. It is useful to be able to have XFRM policy selector matches to have different policies for different GRE tunnels. Signed-off-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-28ipv4: Allow configuring subnets as local addressesTom Herbert
This patch allows a host to be configured to respond to any address in a specified range as if it were local, without actually needing to configure the address on an interface. This is done through routing table configuration. For instance, to configure a host to respond to any address in 10.1/16 received on eth0 as a local address we can do: ip rule add from all iif eth0 lookup 200 ip route add local 10.1/16 dev lo proto kernel scope host src 127.0.0.1 table 200 This host is now reachable by any 10.1/16 address (route lookup on input for packets received on eth0 can find the route). On output, the rule will not be matched so that this host can still send packets to 10.1/16 (not sent on loopback). Presumably, external routing can be configured to make sense out of this. To make this work, we needed to modify the logic in finding the interface which is assigned a given source address for output (dev_ip_find). We perform a normal fib_lookup instead of just a lookup on the local table, and in the lookup we ignore the input interface for matching. This patch is useful to implement IP-anycast for subnets of virtual addresses. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-07flow: virtualize flow cache entry methodsTimo Teräs
This allows to validate the cached object before returning it. It also allows to destruct object properly, if the last reference was held in flow cache. This is also a prepartion for caching bundles in the flow cache. In return for virtualizing the methods, we save on: - not having to regenerate the whole flow cache on policy removal: each flow matching a killed policy gets refreshed as the getter function notices it smartly. - we do not have to call flow_cache_flush from policy gc, since the flow cache now properly deletes the object if it had any references Signed-off-by: Timo Teras <timo.teras@iki.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: lookup in netnsAlexey Dobriyan
Pass netns to xfrm_lookup()/__xfrm_lookup(). For that pass netns to flow_cache_lookup() and resolver callback. Take it from socket or netdevice. Stub DECnet to init_net. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Loosen source address check on IPv4 outputJulian Anastasov
ip_route_output() contains a check to make sure that no flows with non-local source IP addresses are routed. This obviously makes using such addresses impossible. This patch introduces a flowi flag which makes omitting this check possible. The new flag provides a way of handling transparent and non-transparent connections differently. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-05ipv4: remove unused field in struct flowi (include/net/flow.h).Rami Rosen
This patch removes an unused field (flags) from struct flowi; it seems that this "flags" field was used once in the past for multipath routing with FLOWI_FLAG_MULTIPATHOLDROUTE flag (which does no longer exist); however, the "flags" field of struct flowi is not used anymore. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Remove unused multipath cached routing defintion in net/flow.hRami Rosen
2007-07-10[IPV6] MIP6: Kill unnecessary ifdefs.Masahide NAKAMURA
Kill unnecessary CONFIG_IPV6_MIP6. o It is redundant for RAW socket to keep MH out with the config then it can handle any protocol. o Clean-up at AH. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[XFRM]: Restrict upper layer information by bundle.Masahide NAKAMURA
On MIPv6 usage, XFRM sub policy is enabled. When main (IPsec) and sub (MIPv6) policy selectors have the same address set but different upper layer information (i.e. protocol number and its ports or type/code), multiple bundle should be created. However, currently we have issue to use the same bundle created for the first time with all flows covered by the case. It is useful for the bundle to have the upper layer information to be restructured correctly if it does not match with the flow. 1. Bundle was created by two policies Selector from another policy is added to xfrm_dst. If the flow does not match the selector, it goes to slow path to restructure new bundle by single policy. 2. Bundle was created by one policy Flow cache is added to xfrm_dst as originated one. If the flow does not match the cache, it goes to slow path to try searching another policy. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Rethink mark field in struct flowiThomas Graf
Now that all protocols have been made aware of the mark field it can be moved out of the union thus simplyfing its usage. The config options in the IPv4/IPv6/DECnet subsystems to enable respectively disable mark based routing only obfuscate the code with ifdefs, the cost for the additional comparison in the flow key is insignificant, and most distributions have all these options enabled by default anyway. Therefore it makes sense to remove the config options and enable mark based routing by default. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: flowlabels are net-endianAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-21[NET]: Reduce sizeof(struct flowi) by 20 bytes.Eric Dumazet
As suggested by David, just kill off some unused fields in dnports to reduce sizef(struct flowi). If they come back, they should be moved to nl_u.dn_u in order not to enlarge again struct flowi [ Modified to really delete this stuff instead of using #if 0. -DaveM ] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11IPsec: propagate security module errors up from flow_cache_lookupJames Morris
When a security module is loaded (in this case, SELinux), the security_xfrm_policy_lookup() hook can return an access denied permission (or other error). We were not handling that correctly, and in fact inverting the return logic and propagating a false "ok" back up to xfrm_lookup(), which then allowed packets to pass as if they were not associated with an xfrm policy. The way I was seeing the problem was when connecting via IPsec to a confined service on an SELinux box (vsftpd), which did not have the appropriate SELinux policy permissions to send packets via IPsec. The first SYNACK would be blocked, because of an uncached lookup via flow_cache_lookup(), which would fail to resolve an xfrm policy because the SELinux policy is checked at that point via the resolver. However, retransmitted SYNACKs would then find a cached flow entry when calling into flow_cache_lookup() with a null xfrm policy, which is interpreted by xfrm_lookup() as the packet not having any associated policy and similarly to the first case, allowing it to pass without transformation. The solution presented here is to first ensure that errno values are correctly propagated all the way back up through the various call chains from security_xfrm_policy_lookup(), and handled correctly. Then, flow_cache_lookup() is modified, so that if the policy resolver fails (typically a permission denied via the security module), the flow cache entry is killed rather than having a null policy assigned (which indicates that the packet can pass freely). This also forces any future lookups for the same flow to consult the security module (e.g. SELinux) for current security policy (rather than, say, caching the error on the flow cache entry). Signed-off-by: James Morris <jmorris@namei.org>
2006-09-28[XFRM]: fl_ipsec_spi is net-endianAl Viro
2006-09-28[NET]: ip ports in struct flowi are net-endianAl Viro
2006-09-28[IPV4]: annotate ipv4 addresses in struct rtable and struct flowiAl Viro
2006-09-22[IPV6] ROUTE: Routing by FWMARK.YOSHIFUJI Hideaki
Based on patch by Jean Lorchat <lorchat@sfc.wide.ad.jp>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[IPV6] MIP6: Add Mobility header definition.Masahide NAKAMURA
Add Mobility header definition for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Antti Tuominen <anttit@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Flow based matching of xfrm policy and stateVenkat Yekkirala
This implements a seemless mechanism for xfrm policy selection and state matching based on the flow sid. This also includes the necessary SELinux enforcement pieces. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Add security sid to flowiVenkat Yekkirala
This adds security to flow key for labeling of flows as also to allow for making flow cache lookups based on the security label seemless. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DECnet]: Endian annotation and fixes for DECnet.Steven Whitehouse
The typedef for dn_address has been removed in favour of using __le16 or __u16 directly as appropriate. All the DECnet header files are updated accordingly. The byte ordering of dn_eth2dn() and dn_dn2eth() are both changed since just about all their callers wanted network order rather than host order, so the conversion is now done in the functions themselves. Several missed endianess conversions have been picked up during the conversion process. The nh_gw field in struct dn_fib_info has been changed from a 32 bit field to 16 bits as it ought to be. One or two cases of using htons rather than dn_htons in the routing code have been found and fixed. There are still a few warnings to fix, but this patch deals with the important cases. Signed-off-by: Steven Whitehouse <steve@chygwyn.com> Signed-off-by: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[LSM-IPSec]: Security association restriction.Trent Jaeger
This patch series implements per packet access control via the extension of the Linux Security Modules (LSM) interface by hooks in the XFRM and pfkey subsystems that leverage IPSec security associations to label packets. Extensions to the SELinux LSM are included that leverage the patch for this purpose. This patch implements the changes necessary to the XFRM subsystem, pfkey interface, ipv4/ipv6, and xfrm_user interface to restrict a socket to use only authorized security associations (or no security association) to send/receive network packets. Patch purpose: The patch is designed to enable access control per packets based on the strongly authenticated IPSec security association. Such access controls augment the existing ones based on network interface and IP address. The former are very coarse-grained, and the latter can be spoofed. By using IPSec, the system can control access to remote hosts based on cryptographic keys generated using the IPSec mechanism. This enables access control on a per-machine basis or per-application if the remote machine is running the same mechanism and trusted to enforce the access control policy. Patch design approach: The overall approach is that policy (xfrm_policy) entries set by user-level programs (e.g., setkey for ipsec-tools) are extended with a security context that is used at policy selection time in the XFRM subsystem to restrict the sockets that can send/receive packets via security associations (xfrm_states) that are built from those policies. A presentation available at www.selinux-symposium.org/2005/presentations/session2/2-3-jaeger.pdf from the SELinux symposium describes the overall approach. Patch implementation details: On output, the policy retrieved (via xfrm_policy_lookup or xfrm_sk_policy_lookup) must be authorized for the security context of the socket and the same security context is required for resultant security association (retrieved or negotiated via racoon in ipsec-tools). This is enforced in xfrm_state_find. On input, the policy retrieved must also be authorized for the socket (at __xfrm_policy_check), and the security context of the policy must also match the security association being used. The patch has virtually no impact on packets that do not use IPSec. The existing Netfilter (outgoing) and LSM rcv_skb hooks are used as before. Also, if IPSec is used without security contexts, the impact is minimal. The LSM must allow such policies to be selected for the combination of socket and remote machine, but subsequent IPSec processing proceeds as in the original case. Testing: The pfkey interface is tested using the ipsec-tools. ipsec-tools have been modified (a separate ipsec-tools patch is available for version 0.5) that supports assignment of xfrm_policy entries and security associations with security contexts via setkey and the negotiation using the security contexts via racoon. The xfrm_user interface is tested via ad hoc programs that set security contexts. These programs are also available from me, and contain programs for setting, getting, and deleting policy for testing this interface. Testing of sa functions was done by tracing kernel behavior. Signed-off-by: Trent Jaeger <tjaeger@cse.psu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
