path: root/include/net/dst.h
2006-09-22[XFRM] STATE: Support non-fragment outbound transformation headers.Masahide NAKAMURA
For originated outbound IPv6 packets which will fragment, ip6_append_data() should know length of extension headers before sending them and the length is carried by dst_entry. IPv6 IPsec headers fragment then transformation was designed to place all headers after fragment header. OTOH Mobile IPv6 extension headers do not fragment then it is a good idea to make dst_entry have non-fragment length to tell it to ip6_append_data(). Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-07[XFRM]: Netfilter IPsec output hooksPatrick McHardy
Call netfilter hooks before IPsec transforms. Packets visit the FORWARD/LOCAL_OUT and POST_ROUTING hook before the first encapsulation and the LOCAL_OUT and POST_ROUTING hook before each following tunnel mode transform. Patch from Herbert Xu <herbert@gondor.apana.org.au>: Move the loop from dst_output into xfrm4_output/xfrm6_output since they're the only ones who need to it. xfrm{4,6}_output_one() processes the first SA all subsequent transport mode SAs and is called in a loop that calls the netfilter hooks between each two calls. In order to avoid the tail call issue, I've added the inline function nf_hook which is nf_hook_slow plus the empty list check. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-26[IPSEC]: Kill obsolete get_mss functionHerbert Xu
Now that we've switched over to storing MTUs in the xfrm_dst entries, we no longer need the dst's get_mss methods. This patch gets rid of them. It also documents the fact that our MTU calculation is not optimal for ESP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-04-19[NET]: Shave sizeof(ptr) bytes off dst_entryHerbert Xu
Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
