path: root/include/net/ax25.h
2006-03-19[AX.25]: Fix potencial memory hole.Ralf Baechle DL5RB
If the AX.25 dialect chosen by the sysadmin is set to DAMA master / 3 (or DAMA slave / 2, if CONFIG_AX25_DAMA_SLAVE=n) ax25_kick() will fall through the switch statement without calling ax25_send_iframe() or any other function that would eventually free skbn thus leaking the packet. Fix by restricting the sysctl inferface to allow only actually supported AX.25 dialects. The system administration mistake needed for this to happen is rather unlikely, so this is an uncritical hole. Coverity #651. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
2005-10-22[AX.25]: Fix signed char bugRalf Baechle
On architectures where the char type defaults to unsigned some of the arithmetic in the AX.25 stack to fail, resulting in some packets being dropped on receive. Credits for tracking this down and the original patch to Bob Brose N0QBJ <linuxhams@n0qbj-11.ampr.org>. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-12[AX.25]: Add descriptions to constantsRalf Baechle
Comment the names used for the AX.25 state machine. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[AX.25]: Add more PIDsRalf Baechle
Add a few more PID definitions. AX.25 PIDs are the equivalent to IP protocol numbers. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[AX.25]: Rename ax25_encapsulate to ax25_hard_headerRalf Baechle
Rename ax25_encapsulate to ax25_hard_header which these days more accurately describes what the function is supposed to do. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-08[AX.25]: Make asc2ax() thread-proofRalf Baechle
Asc2ax was still using a static buffer for all invocations which isn't exactly SMP-safe. Change asc2ax to take an additional result buffer as the argument. Change all callers to provide such a buffer. This one only really is a fix for ROSE and as per recent discussions there's still much more to fix in ROSE ... Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-06[AX25]: Make ax2asc thread-proofRalf Baechle
Ax2asc was still using a static buffer for all invocations which isn't exactly SMP-safe. Change ax2asc to take an additional result buffer as the argument. Change all callers to provide such a buffer. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-23[AX25]: UID fixesRalf Baechle
o Brown paperbag bug - ax25_findbyuid() was always returning a NULL pointer as the result. Breaks ROSE completly and AX.25 if UID policy set to deny. o While the list structure of AX.25's UID to callsign mapping table was properly protected by a spinlock, it's elements were not refcounted resulting in a race between removal and usage of an element. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[AX25]: endian-annotate ax25_type_trans()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[AX25] Introduce ax25_type_transArnaldo Carvalho de Melo
Replacing the open coded equivalents and making ax25 look more like a linux network protocol, i.e. more similar to inet. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-21[AX25]: make ax25_queue_xmit a net_device parameterArnaldo Carvalho de Melo
I.e. not using skb->dev as a way to pass the parameter used to fill... skb->dev :-) Also to get the _type_trans open coded sequence grouped, next changesets will introduce ax25_type_trans. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
