Replace references to the v4l2_mbus_pixelcode enum with the new
media_bus_format enum in all common headers.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
The video enum_dv_timings and dv_timings_cap operations are deprecated
and unused. Remove them.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
The dv_timings_cap and enum_dv_timings subdev operations are implemented
at the device level, but apply to pads. Create new variants of those
operations at the pad level. The device level variants will be removed
once all drivers are ported to the pad level DT timings operations.
The g_std and s_std operations are video-related, move them to the video
ops where they belong.
While there was already a g_tvnorms_output video op, it's counterpart for
video capture was missing. Add it.
This is necessary for generic bridge drivers like soc-camera to set the
video_device tvnorms field correctly. Otherwise ENUMSTD cannot work.
Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com>
V4L2_MBUS_FRAME_DESC_FL_BLOB intends to say the receiver must use 1D DMA to
receive the image, as the format does not have line offsets. This typically
includes all compressed formats.
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
When the sub-device is registered, increment the use count of the sub-device
owner only if it's different from the owner of the driver for the media
device. This avoids increasing the use count by the module itself and thus
making it possible to unload it when it's not in use.
The notify function is a void function, yet the v4l2_subdev_notify
define uses it in a ? : construction, which causes sparse warnings.
Replace the define by a static inline function and move it to
v4l2-device.h, which is where it belongs since it needs to know the
v4l2_device struct. This wasn't a problem when it was a define, but
as a static inline function this no longer compiles in v4l2-subdev.h.
Add VIDIOC_ENUM_FREQ_BANDS, enumerate supported frequency bands,
IOCTL support for sub-device tuners too.
Cc: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Antti Palosaari <crope@iki.fi>
Support this ioctl as part of the v4l2 core. Use the new ioctl
name and struct v4l2_edid type in the existing core code.
Add support for 32-bit ioctls with v4l-subdev device nodes.
Rather than keep adding new ioctls to the list in v4l2-compat-ioctl32.c, just check
if the ioctl is a non-private V4L2 ioctl and if so, call the conversion code.
We keep forgetting to add new ioctls, so this is a more robust solution.
In addition extend the subdev API with support for a compat32 function to
convert custom v4l-subdev ioctls.
Tested-by: Sakari Ailus <sakari.ailus@linux.intel.com>
The helper function is defined by a macro that is erroneously called
with the compose rectangle instead of the crop rectangle. Fix it.
Acked-by: Sakari Ailus <sakari.ailus@iki.fi>
This struct shall be used by subdevice drivers to pass per-subdevice data,
e.g. power supplies, to generic V4L2 methods, at the same time allowing
optional host-specific extensions via the host_priv pointer. To avoid
having to pass two pointers to those methods, add a pointer to this new
struct to struct v4l2_subdev.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
BUG*() and WARN*() macros specify their conditions as unlikely, using
BUG_ON(unlikely(condition)) is redundant, remove it.
By integrating the v4l2-async API internals a bit more with
the core overall the v4l2-async code becomes a bit simpler
and easier to follow.
Acked-and-tested-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Currently bridge device drivers register devices for all subdevices
synchronously, typically, during their probing. E.g. if an I2C CMOS sensor
is attached to a video bridge device, the bridge driver will create an I2C
device and wait for the respective I2C driver to probe. This makes linking
of devices straight forward, but this approach cannot be used with
intrinsically asynchronous and unordered device registration systems like
the Flattened Device Tree. To support such systems this patch adds an
asynchronous subdevice registration framework to V4L2. To use it respective
(e.g. I2C) subdevice drivers must register themselves with the framework.
A bridge driver on the other hand must register notification callbacks,
that will be called upon various related events.
Tested-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
It is often useful to have simple means to get from a subdevice to the
underlying physical device. This patch adds such a pointer to struct
v4l2_subdev and sets it accordingly in the I2C and SPI cases.
This has been replaced by the new and much better VIDIOC_DBG_G_CHIP_INFO.
These ops are no longer used, so it's time to remove them.
This patch adds a v4l2_subdev_has_op() macro and a v4l2_device_has_op macro to
quickly check if a specific subdev or any subdev supports a particular subdev
operation.
This makes it easy for drivers to disable certain ioctls if none of the subdevs
supports the necessary functionality.
This ioctl is defined as IOW, so pass the argument as const.
Acked-by: Alexey Klimov <klimov.linux@gmail.com>
Add subdev callbacks for setting up parameters of the frame on media bus
that are not exposed to user space directly. This is just an initial,
mostly stub implementation. struct v4l2_mbus_frame_desc is intended
to be extended with sub-structures specific to a particular hardware media
bus. For now these new callbacks are used only to query or specify maximum
size of a compressed or hybrid (container) media bus frame in octets.
The s_rx_buffer callback allows the host to set buffer for a data being
received by the subdev, e.g. non-image frame (meta) data. This callback
can be implemented by subdevice like a MIPI CSI2 receiver, allowing the
host driver to gather additional data into frame buffer passed to user
space.
Write-only ioctls should have a const argument in the ioctl op.
Do this conversion for vidioc_s_crop.
Adding const for write-only ioctls was decided during the 2012 Media Workshop.
Do this conversion for vidioc_s_modulator.
[mchehab@redhat.com: fix a merge conflict at Documentation/video4linux/v4l2-framework.txt]
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Reviewed-by: Mauro Carvalho Chehab <mchehab@redhat.com>
v4l2_subdev_link_validate() is the default op for validating a link. In V4L2
subdev context, it is used to call a pad op which performs the proper link
check without much extra work.
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Unify functions to get try pointers and validate the pad number accessed by
the user.
v4l2_subdev *"
vdev_to_v4l2_subdev() should return struct v4l2_subdev *, not void *. Fix
this.
Add support for VIDIOC_SUBDEV_S_SELECTION and VIDIOC_SUBDEV_G_SELECTION
IOCTLs. They replace functionality provided by VIDIOC_SUBDEV_S_CROP and
VIDIOC_SUBDEV_G_CROP IOCTLs and also add new functionality (composing).
VIDIOC_SUBDEV_G_CROP and VIDIOC_SUBDEV_S_CROP continue to be supported.
VIDIOC_G_STD can return the current TV-norm to the user in one of two ways:
if an .vidioc_g_std() ioctl operation is provided by the driver, it is
called, otherwise the value ot the .current_norm field of struct
video_device is returned. Since subdevice drivers currently have no access
to struct video_device objects, the only way to provide this information to
the user is by implementing a .g_std() method.
Currently only very few drivers actually use video_device nodes, embedded
in struct v4l2_subdev. Allocate these nodes dynamically for those drivers
to save memory for the rest.
Tested-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Add media bus configuration types and two subdev operations to get
supported mediabus configurations and to set a specific configuration.
Subdevs can support several configurations, e.g., they can send video data
on 1 or several lanes, can be configured to use a specific CSI-2 channel,
in such cases subdevice drivers return bitmasks with all respective bits
set. When a set-configuration operation is called, it has to specify a
non-ambiguous configuration.
Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com>
Callback is used to acquire current analog TV standard from a subdev.
It is used to avoid keeping current standard in top-level driver.
Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
Callback is used to acquire current digital video preset from a subdev.
It is used to avoid keeping dv preset in top-level driver.
Callback is used to acquire TV norms supported by a subdev.
It is used to avoid having standards in top-level driver.
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
just per-fh
The driver had to decide how many events to allocate when the v4l2_fh struct
was created. It was possible to add more events afterwards, but there was no
way to ensure that you wouldn't miss important events if the event queue
would fill up for that filehandle.
In addition, once there were no more free events, any new events were simply
dropped on the floor.
For the control event in particular this made life very difficult since
control status/value changes could just be missed if the number of allocated
events and the speed at which the application read events was too low to keep
up with the number of generated events. The application would have no idea
what the latest state was for a control since it could have missed the latest
control change.
So this patch makes some major changes in how events are allocated. Instead
of allocating events per-filehandle they are now allocated when subscribing an
event. So for that particular event type N events (determined by the driver)
are allocated. Those events are reserved for that particular event type.
This ensures that you will not miss events for a particular type altogether.
In addition, if there are N events in use and a new event is raised, then
the oldest event is dropped and the new one is added. So the latest event
is always available.
This can be further improved by adding the ability to merge the state of
two events together, ensuring that no data is lost at all. This will be
added in the next patch.
This also makes it possible to allow the user to determine the number of
events that will be allocated. This is not implemented at the moment, but
would be trivial.
The tuner ops g_frequency, g_tuner and s_tuner require that the tuner type
field is filled in. Document this.
The tuner-core doc is based on a patch from Mauro Carvalho Chehab <mchehab@redhat.com>.
s_mode is no longer used, so remove it.
Some buggy sensors generate corrupt frames when the stream is started.
This new operation return the number of corrupt frames to skip when
starting the stream.
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
This patch adds the VIDIOC_SUBDEV_S_CROP and G_CROP ioctls to the
userland API. CROPCAP is not implemented because it's redundant.
Signed-off-by: Antti Koskipaa <akoskipa@gmail.com>
The three new ioctl VIDIOC_SUBDEV_ENUM_FRAME_INTERVAL,
VIDIOC_SUBDEV_G_FRAME_INTERVAL and VIDIOC_SUBDEV_S_FRAME_INTERVAL can be
used to enumerate and configure a subdev's frame rate from userspace.
Two new video::g/s_frame_interval subdev operations are introduced to
support those ioctls. The existing video::g/s_parm operations are
deprecated and shouldn't be used anymore.
Add a userspace API to get, set and enumerate the media format on a
subdev pad.
The format at the output of a subdev usually depends on the format at
its input(s). The try format operation is thus not suitable for probing
format at individual pads, as it can't modify the device state and thus
can't remember the format tried at the input to compute the output
format.
To fix the problem, pass an extra argument to the get/set format
operations to select the 'try' or 'active' format.
The try format is used when probing the subdev. Setting the try format
must not change the device configuration but can store data for later
reuse. Data storage is provided at the file-handle level so applications
probing the subdev concurently won't interfere with each other.
The active format is used when configuring the subdev. It's identical to
the format handled by the usual get/set operations.
Add a v4l2_subdev_pad_ops structure for the operations that need to be
performed at the pad level such as format-related operations.
Pad format-related operations use v4l2_mbus_framefmt instead of
v4l2_format.
V4L2 sub-devices store pad formats and crop settings in the file handle.
To let drivers initialize those settings properly, add an open operation
that is called when the subdev is opened as well as a corresponding
close operation.
Used for storing subdev information per file handle and hold V4L2 file
handle.
