path: root/include/media/v4l2-ctrls.h
2012-05-14[media] V4L: Add helper function for standard integer menu controlsSylwester Nawrocki
This patch adds v4l2_ctrl_new_int_menu() helper function which can be used in drivers for creating standard integer menu control with driver-specific menu item list. It is similar to v4l2_ctrl_new_std_menu(), except it doesn't have a mask parameter and an additional qmenu parameter allows passing an array of signed 64-bit integers as the menu item list. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Tested-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l: v4l2-ctrls: moves the forward declaration of struct fileLaurent Pinchart
This fixes the following warning: In file included from drivers/media/video/v4l2-subdev.c:29: include/media/v4l2-ctrls.h:501: warning: 'struct file' declared inside parameter list include/media/v4l2-ctrls.h:501: warning: its scope is only this definition or declaration, which is probably not what you want include/media/v4l2-ctrls.h:509: warning: 'struct file' declared inside parameter list Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l: Allow changing control handler lockSakari Ailus
Allow choosing the lock used by the control handler. This may be handy sometimes when a driver providing multiple subdevs does not want to use several locks to serialise its functions. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-07[media] v4l2-ctrls: Use v4l2_subscribed_event_opsHans de Goede
Signed-off-by: Hans de Goede <hdegoede@redhat.com> [hans.verkuil@cisco.com: Fix a locking bug] Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-19[media] V4L: fix a compiler warningGuennadi Liakhovetski
Fix the warning: In file included from /home/lyakh/software/project/24/src/linux-2.6/drivers/media/video/v4l2-subdev.c:29: linux-2.6/include/media/v4l2-ctrls.h:497: warning: 'struct file' declared inside parameter list linux-2.6/include/media/v4l2-ctrls.h:497: warning: its scope is only this definition or declaration, which is probably not what you want linux-2.6/include/media/v4l2-ctrls.h:505: warning: 'struct file' declared inside parameter list Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-19Merge tag 'v3.4-rc3' into staging/for_v3.5Mauro Carvalho Chehab
* tag 'v3.4-rc3': (3755 commits) Linux 3.4-rc3 x86-32: fix up strncpy_from_user() sign error ARM: 7386/1: jump_label: fixup for rename to static_key ARM: 7384/1: ThumbEE: Disable userspace TEEHBR access for !CONFIG_ARM_THUMBEE ARM: 7382/1: mm: truncate memory banks to fit in 4GB space for classic MMU ARM: 7359/2: smp_twd: Only wait for reprogramming on active cpus PCI: Fix regression in pci_restore_state(), v3 SCSI: Fix error handling when no ULD is attached ARM: OMAP: clock: cleanup CPUfreq leftovers, fix build errors ARM: dts: remove blank interrupt-parent properties ARM: EXYNOS: Fix Kconfig dependencies for device tree enabled machine files do not export kernel's NULL #define to userspace ARM: EXYNOS: Remove broken config values for touchscren for NURI board ARM: EXYNOS: set fix xusbxti clock for NURI and Universal210 boards ARM: EXYNOS: fix regulator name for NURI board ARM: SAMSUNG: make SAMSUNG_PM_DEBUG select DEBUG_LL cpufreq: OMAP: fix build errors: depends on ARCH_OMAP2PLUS sparc64: Eliminate obsolete __handle_softirq() function sparc64: Fix bootup crash on sun4v. ARM: msm: Fix section mismatches in proc_comm.c ...
2012-04-10[media] v4l: Introduce integer menu controlsSakari Ailus
Create a new control type called V4L2_CTRL_TYPE_INTEGER_MENU. Integer menu controls are just like menu controls but the menu items are 64-bit integers rather than strings. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Tested-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-24Merge tag 'device-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/device.h> avoidance patches from Paul Gortmaker: "Nearly every subsystem has some kind of header with a proto like: void foo(struct device *dev); and yet there is no reason for most of these guys to care about the sub fields within the device struct. This allows us to significantly reduce the scope of headers including headers. For this instance, a reduction of about 40% is achieved by replacing the include with the simple fact that the device is some kind of a struct. Unlike the much larger module.h cleanup, this one is simply two commits. One to fix the implicit <linux/device.h> users, and then one to delete the device.h includes from the linux/include/ dir wherever possible." * tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: device.h: audit and cleanup users in main include dir device.h: cleanup users outside of linux/include (C files)
2012-03-16device.h: audit and cleanup users in main include dirPaul Gortmaker
The <linux/device.h> header includes a lot of stuff, and it in turn gets a lot of use just for the basic "struct device" which appears so often. Clean up the users as follows: 1) For those headers only needing "struct device" as a pointer in fcn args, replace the include with exactly that. 2) For headers not really using anything from device.h, simply delete the include altogether. 3) For headers relying on getting device.h implicitly before being included themselves, now explicitly include device.h 4) For files in which doing #1 or #2 uncovers an implicit dependency on some other header, fix by explicitly adding the required header(s). Any C files that were implicitly relying on device.h to be present have already been dealt with in advance. Total removals from #1 and #2: 51. Total additions coming from #3: 9. Total other implicit dependencies from #4: 7. As of 3.3-rc1, there were 110, so a net removal of 42 gives about a 38% reduction in device.h presence in include/* Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-14[media] v4l2-ctrls: add helper functions for control eventsHans Verkuil
Many drivers just support control events, and most radio drivers just need to poll for control events. Add some functions to simplify those jobs. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-02-14[media] v4l2: standardize log start/end messageHans Verkuil
For drivers that properly use the v4l2 framework (i.e. set v4l2_dev in the video_device struct), the start and end messages of VIDIOC_LOG_STATUS are now generated automatically. People tended to forget these, but the v4l2-ctl tool scans for these messages, and it also makes it easier to read the status output in the kernel log. The cx18, ivtv and bttv drivers were changed since they no longer need to log these start/end messages. In saa7164 two empty log_status functions were removed. Also added a helper function to v4l2-ctrl.c that can be used as the vidioc_log_status callback if all you need to do is to log the current control values. This is now used by pwc and vivi. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: Steven Toth <stoth@kernellabs.com> Cc: Andy Walls <awalls@md.metrocast.net> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-21[media] v4l2-ctrls: implement new volatile autocluster schemeHans Verkuil
The problem tackled in this patch is how to handle volatile autoclusters correctly. A volatile autocluster is a cluster of related controls where one control is the control that toggles between manual and auto mode and the other controls are the values for the manual mode. For example autogain and gain, autoexposure and exposure, etc. If the hardware lets you read out the automatically calculated manual values while in automode, then those manual controls should be marked volatile. gain value as calculated by the autogain circuitry, then you would mark the gain control as volatile (i.e. continuously changing). The question in such use cases is what to do when switching from the auto mode to the manual mode. Should we switch to the last set manual values or should the volatile values be copied and used as the initial manual values. For example: suppose the mode is manual gain and gain is set to 5. Then autogain is turned on and the gain is set by the hardware to 2. Finally the user switches back to manual gain. What should the gain be? 2 or 5? After a long discussion the decisions was made to keep the last value as calculated by the auto mode (so 2 in the example above). The reason is that webcams that do such things will adapt themselves to the current light conditions and when you switch back to manual mode you expect that you keep the same picture. If you would switch back to old manual values, then that would give you a suddenly different picture, which is jarring for the user. Additionally, this would be difficult to implement in applications that store and restore the control values at application exit and start. If you want to keep the old manual values when you switch from auto to manual, then there would have to be a way for applications to get hold of those old values while in auto mode, but there isn't. So this patch will do all the heavy lifting in v4l2-ctrls.c: if you go from auto mode to manual mode and the manual controls are volatile, then g_volatile_ctrl will be called to get the current values for the manual controls before switching to manual mode. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-21[media] v4l2-ctrls: replace is_volatile with V4L2_CTRL_FLAG_VOLATILEHans Verkuil
With the new flag there is no need anymore to have a separate is_volatile field. Modify all users to use the new flag. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-ctrls/v4l2-events: small coding style cleanupsHans Verkuil
Thanks to Laurent Pinchart <laurent.pinchart@ideasonboard.com>. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-ctrls: improve discovery of controls of the same clusterHans Verkuil
The implementation of VIDIOC_G/S/TRY_EXT_CTRLS in the control framework has to figure out which controls in the control list belong to the same cluster. Since controls belonging to the same cluster need to be handled as a unit, this is important information. It did that by going over the controls in the list and for each control that belonged to a multi-control cluster it would walk the remainder of the list to try and find controls that belong to that same cluster. This approach has two disadvantages: 1) it was a potentially quadratic algorithm (although highly unlikely that it would ever be that bad in practice). 2) it took place with the control handler's lock held. Since we want to make it possible in the future to change control values from interrupt context, doing a lot of work while holding a lock is not a good idea. In the new code the algorithm is no longer quadratic but linear in the number of controls in the list. Also, it now can be done beforehand. Another change that was made was to so the try and set at the same time. Before when S_TRY_EXT_CTRLS was called it would 'try' the controls first, and then it would 'set' them. The idea was that any 'try' errors would prevent the 'set' from happening, thus avoiding having partially set control lists. However, this caused more problems than it solved because between the 'try' and the 'set' changes might have happened, so it had to try a second time, and since actual controls with a try_ctrl op are very rare (and those that we have just adjust values and do not return an error), I've decided to drop that two-stage approach and just combine try and set. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-event/ctrls/fh: allocate events per fh and per type instead of ↵Hans Verkuil
just per-fh The driver had to decide how many events to allocate when the v4l2_fh struct was created. It was possible to add more events afterwards, but there was no way to ensure that you wouldn't miss important events if the event queue would fill up for that filehandle. In addition, once there were no more free events, any new events were simply dropped on the floor. For the control event in particular this made life very difficult since control status/value changes could just be missed if the number of allocated events and the speed at which the application read events was too low to keep up with the number of generated events. The application would have no idea what the latest state was for a control since it could have missed the latest control change. So this patch makes some major changes in how events are allocated. Instead of allocating events per-filehandle they are now allocated when subscribing an event. So for that particular event type N events (determined by the driver) are allocated. Those events are reserved for that particular event type. This ensures that you will not miss events for a particular type altogether. In addition, if there are N events in use and a new event is raised, then the oldest event is dropped and the new one is added. So the latest event is always available. This can be further improved by adding the ability to merge the state of two events together, ensuring that no data is lost at all. This will be added in the next patch. This also makes it possible to allow the user to determine the number of events that will be allocated. This is not implemented at the moment, but would be trivial. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-ctrls/event: remove struct v4l2_ctrl_fh, instead use ↵Hans Verkuil
v4l2_subscribed_event The v4l2_ctrl_fh struct connected v4l2_ctrl with v4l2_fh so the control would know which filehandles subscribed to it. However, it is much easier to use struct v4l2_subscribed_event directly for that and get rid of that intermediate struct. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-ctrls: make manual_mode_value 8 bits and check against control ↵Hans Verkuil
range Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-ctrls: simplify event subscriptionHans Verkuil
2011-07-27[media] v4l2-ctrls: add control eventsHans Verkuil
Whenever a control changes value or state an event is sent to anyone that subscribed to it. This functionality is useful for control panels but also for applications that need to wait for (usually status) controls to change value. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-ctrls: add v4l2_fh pointer to the set control functionsHans Verkuil
When an application changes a control you want to generate an event. However, you want to avoid sending such an event back to the application (file handle) that caused the change. Add the filehandle to the various set control functions. The filehandle isn't used yet, but the control event patches will need this. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-ctrls: add v4l2_ctrl_auto_cluster to simplify autogain/gain ↵Hans Verkuil
scenarios It is a bit tricky to handle autogain/gain type scenerios correctly. Such controls need to be clustered and the V4L2_CTRL_FLAG_UPDATE should be set on the autofoo controls. In addition, the manual controls should be marked inactive when the automatic mode is on, and active when the manual mode is on. This also requires specialized volatile handling. The chances of drivers doing all these things correctly are pretty remote. So a new v4l2_ctrl_auto_cluster function was added that takes care of these issues. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-19[media] v4l: Include linux/videodev2.h in media/v4l2-ctrls.hLaurent Pinchart
The later makes extensive use of structures defined in the former. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-19[media] v4l2-ctrls: v4l2_ctrl_handler_setup must set is_new to 1Hans Verkuil
Renamed has_new to is_new. Drivers can use the is_new field to determine if a new value was specified for a control. The v4l2_ctrl_handler_setup() must always set this to 1 since the setup has to force a full update of all controls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] v4l2-ctrls: use const char * const * for the menu arraysHans Verkuil
This prevents checkpatch warnings generated when defining 'static const char *foo[]' arrays. It makes sense to use const char * const * anyway since the pointers in the array are indeed const. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: v4l2: Add new control handling frameworkHans Verkuil
Add a new framework to handle controls which makes life for driver developers much easier. Note that this patch moves some of the control support that used to be in v4l2-common.c to v4l2-ctrls.c. The tables were copied unchanged. The body of v4l2_ctrl_query_fill() was copied to a new v4l2_ctrl_fill() function in v4l2-ctrls.c. This new function doesn't use the v4l2_queryctrl struct anymore, which makes it more general. The remainder of v4l2-ctrls.c is all new. Highlights include: - No need to implement VIDIOC_QUERYCTRL, QUERYMENU, S_CTRL, G_CTRL, S_EXT_CTRLS, G_EXT_CTRLS or TRY_EXT_CTRLS in either bridge drivers or subdevs. New wrapper functions are provided that can just be plugged in. Once everything has been converted these wrapper functions can be removed as well. - When subdevices are added their controls can be automatically merged with the bridge driver's controls. - Most drivers just need to implement s_ctrl to set the controls. The framework handles the locking and tries to be as 'atomic' as possible. - Ready for the subdev device nodes: the same mechanism applies to subdevs and their device nodes as well. Sub-device drivers can make controls local, preventing them from being merged with bridge drivers. - Takes care of backwards compatibility handling of VIDIOC_S_CTRL and VIDIOC_G_CTRL. Handling of V4L2_CID_PRIVATE_BASE is fully transparent. CTRL_CLASS controls are automatically added. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
