path: root/include/media/v4l2-common.h
2006-09-26V4L/DVB (4582): VIDIOC_INT_S_REGISTER is IOW, not IOR.Hans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4553): Add support for saa7111 and partial support for saa7118Mauro Carvalho Chehab
2006-09-26V4L/DVB (4546): Add u32 argument to VIDIOC_INT_RESET.Hans Verkuil
The extra argument makes it possible to reset subsystems of a chip if that is supported. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4190): Add helper functions for control processing to v4l2-common.Hans Verkuil
Control processing is often duplicated in the various drivers. Unfortunately, simple things like the names of controls are often different between drivers, even though it is the same controls. Adding in the new extended controls and the need for having control helper functions became apparent. Several functions have now been added to v4l2-common to do things like filling the v4l2_queryctrl and v4l2_querymenu structs, to check for valid control input and to move to the next control when enumerating over all controls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4065): Several improvements at videodev.cMauro Carvalho Chehab
Videodev now is capable of better handling V4L2 api, by processing V4L2 ioctls and using callbacks to the driver. The drivers should be migrated to the newer way and the older one will be obsoleted soon. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4005): Add support for the cx25836/7 video decoder.Hans Verkuil
Signed-off-by: Scott Alfter <salfter@ssai.us> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3711): Add support for VIDIOC_INT_S_CRYSTAL_FREQ internal command.Hans Verkuil
Some saa7115-based cards use a different crystal frequency and a different audio clock generation. Add a new VIDIOC_INT_S_CRYSTAL_FREQ command to be able to set these values. Also change the default APLL setting to 0. It makes no sense to have the audio clock independent from the video clock, this can lead to audio/video synchronization problems. Setting this to 0 is also consistent with the old saa7114.c source and the way the Hauppauge Windows driver sets it. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3582): Implement correct msp3400 input/output routingHans Verkuil
- implement VIDIOC_INT_S_AUDIO_ROUTING for msp3400 and tvaudio - use the new command in bttv, pvrusb2 and em28xx. - remove the now obsolete MSP_SET_MATRIX from msp3400 (yeah!) - remove the obsolete VIDIOC_S_AUDIO from msp3400. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3577): Cleanup audio input handlingHans Verkuil
Cleanup audio input handling in bttv and tvaudio: - inputs were specified that were never used - mute was handled as a special input which led to confusing code - confusing naming made it difficult to see if the setting was for i2c or gpio. The old audiochip.h input names moved to tvaudio.h. Currently this is used both by tvaudio and msp3400 until the msp3400 implements the new msp3400-specific inputs. Detect in bttv the tvaudio and msp3400 i2c clients and use these client pointers to set the inputs directly instead of broadcasting the command. Removed AUDC_SET_INPUT. Now replaced by VIDIOC_S_AUDIO. This will be replaced again later by the new ROUTING commands. Removed VIDIOC_G_AUDIO implementations in i2c drivers: this command is a user level command and not to be used internally. It wasn't called at all anyway. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3513): Remove saa711x driverMauro Carvalho Chehab
Now, em28xx uses saa7115 instead of saa711x. saa7115 driver is capable of handling saa 7113, 7114 and 7115. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-27V4L/DVB (3371): Add debug to ioctl arguments.Mauro Carvalho Chehab
Added a new function that allows printing ioctl arguments. This makes easier to include debug code under v4l ioctl handling. Also fixed some declarations on internal ioctl. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-23V4L/DVB (3430): Add new internal VIDIOC_INT commandsHans Verkuil
- Add new internal VIDIOC_INT commands for setting the tuner mode, for putting a chip into standby mode and to set/get the routing of inputs/outputs of audio or video of a chip. These new commands will replace older commands that are no longer up to the task. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-23V4L/DVB (3420): Added iocls to configure VBI on tvp5150Mauro Carvalho Chehab
- Added iocls to configure VBI on tvp5150 Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-15V4L/DVB (3384): Separate tv & radio freqs, fix cb/freq transmit order for ↵Hans Verkuil
tuners that need this. - Moved MSP_SET_MATRIX to v4l2-common.h - Fix typos and integer overflows in tea5767.c - Split old freq field into a tv_freq and a radio_freq. Prevents that a radio tuner is initialized with a tv frequency or vice versa. - When switching to radio mode initialize the tuner with the last used radio frequency (this was already done for the TV mode). As a result of these changes the tuner module now remembers the last set radio and TV frequencies, which is what you would expect to happen. - Move out of range frequencies to the closest valid frequency as per v4l2 API spec. - Fix incorrect initial radio frequency (multiplier is 16000, not 16) - Add boundary check for out of range frequencies. - Use new flag to check if the order of the CB and freq. depends on the last set frequency. That is needed for some tuners or you can get static as a result. The flag is added for those tuners where I know that the datasheet indicates that this is necessary. - For this new check use the last set div value, not the last frequency as radio frequencies are always much higher due to the 16000 multiplier. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3345): Fixes some bad global variablesMauro Carvalho Chehab
- Debug global var is already used inside kernel. - v4l_dbg now expects the debug var - global vars inside msp34xx renamed to msp_* Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3307): Some cleanups at I2C modulesMauro Carvalho Chehab
- i2c names shorten - removed obsoleted flags on newer modules - small cleanups Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3278): convert diagnostics over to the new v4l2-common.h macros.Hans Verkuil
- Convert diagnostics over to the new v4l2-common.h macros. - deprecated tuner_debug option, the new option is debug. - renamed cx25840_debug to debug. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3276): Added new diagnositics macros, convert msp3400 to the new ↵Hans Verkuil
macros. - Added new v4l_err, v4l_warn, v4l_info and v4l_dbg macros to v4l2-common.h for use in v4l-dvb i2c drivers. This ensures a unique prefix for each device instance. - At a later stage these macros may be reimplemented using the device-generic macros from device.h. - Converted the msp3400 driver to the new macros. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3269): ioctls cleanups.Michael Krufky
- Now, all internal ioctls are at v4l2-common.h - removed unused ioctl at saa6752hs.h - all debug ioctl code moved to v4l2-common.c - removed duplicated stuff from other cards Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3214): Calculate the saa7115 AMCLK regs instead of using fixed valuesHans Verkuil
- Calculate the audio master clock registers from the actual frequencies. This simplifies the code and it also prepares for adding CGC2 support. - VIDIOC_INT_AUDIO_CLOCK_FREQ now receives an u32 instead of an enum. It is more generic and actually easier to implement. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3233): Fixed API to set I2S speed controlMauro Carvalho Chehab
- Created a new ioctl to control I2S speed. Old calls to an inadequate V4L2 API replaced. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-11-13[PATCH] v4l: (945) adds a new include for internal v4l2 ioctls and apiHans Verkuil
Adds a new include for internal V4L2 ioctls and API Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
