gcc aligns strings as a performance consideration for those cases where
strings are being used a lot.
Their use is not performance critical, and hence it seems better to save
some space.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
The whole point to using the strict functions is to check the return
value. If you don't, strict_strto*() will return you uninitialised
garbage. Offenders have been observed in the wild.
Introduce two additional min/max macros to compare three operands. This
will save some cycles as well as some bytes on the stack and last but not
least more pleasing as macro nesting.
[akpm@linux-foundation.org: fix warnings]
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Cc: Joe Perches <joe@perches.com>
Cc: Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Add vzalloc() and vzalloc_node() to encapsulate the
vmalloc-then-memset-zero operation.
Use __GFP_ZERO to zero fill the allocated memory.
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Acked-by: Greg Ungerer <gerg@snapgear.com>
Introduce ___GFP_* masks in order for gfp_t to not be mixed with plain
integers which causes a lot of warnings like the following:
warning: restricted gfp_t degrades to integer
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Declare 'bdi_pending_list' and 'tag_pages_for_writeback()' to remove
following sparse warnings:
mm/backing-dev.c:46:1: warning: symbol 'bdi_pending_list' was not declared. Should it be static?
mm/page-writeback.c:825:6: warning: symbol 'tag_pages_for_writeback' was not declared. Should it be static?
The page_check_address() conditionally grabs *@ptlp in case of returning
non-NULL. Rename and wrap it using __cond_lock() removes following
warnings from sparse:
mm/rmap.c:472:9: warning: context imbalance in 'page_mapped_in_vma' - unexpected unlock
mm/rmap.c:524:9: warning: context imbalance in 'page_referenced_one' - unexpected unlock
mm/rmap.c:706:9: warning: context imbalance in 'page_mkclean_one' - unexpected unlock
mm/rmap.c:1066:9: warning: context imbalance in 'try_to_unmap_one' - unexpected unlock
The page_lock_anon_vma() conditionally grabs RCU and anon_vma lock but
page_unlock_anon_vma() releases them unconditionally. This leads sparse
to complain about context imbalance. Annotate them.
The get_locked_pte() conditionally grabs 'ptl' in case of returning
non-NULL. This leads sparse to complain about context imbalance. Rename
and wrap it using __cond_lock() to make sparse happy.
This change reduces mmap_sem hold times that are caused by waiting for
disk transfers when accessing file mapped VMAs.
It introduces the VM_FAULT_ALLOW_RETRY flag, which indicates that the call
site wants mmap_sem to be released if blocking on a pending disk transfer.
In that case, filemap_fault() returns the VM_FAULT_RETRY status bit and
do_page_fault() will then re-acquire mmap_sem and retry the page fault.
It is expected that the retry will hit the same page which will now be
cached, and thus it will complete with a low mmap_sem hold time.
Tests:
- microbenchmark: thread A mmaps a large file and does random read accesses
to the mmaped area - achieves about 55 iterations/s. Thread B does
mmap/munmap in a loop at a separate location - achieves 55 iterations/s
before, 15000 iterations/s after.
- We are seeing related effects in some applications in house, which show
significant performance regressions when running without this change.
[akpm@linux-foundation.org: fix warning & crash]
Signed-off-by: Michel Lespinasse <walken@google.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Ying Han <yinghan@google.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Cc: <linux-arch@vger.kernel.org>
Reorder structure anon_vma to remove alignment padding on 64 builds when
(CONFIG_KSM || CONFIG_MIGRATION).
This will shrink the size of the anon_vma structure from 40 to 32 bytes
& allow more objects per slab in its kmem_cache.
Under slub the objects in the anon_vma kmem_cache will then be 40 bytes
with 102 objects per slab. (On v2.6.36 without this patch,the size is 48
bytes and 85 objects/slab.)
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
Keep the current interface but ignore the KM_type and use a stack based
approach.
The advantage is that we get rid of crappy code like:
#define __KM_PTE \
(in_nmi() ? KM_NMI_PTE : \
in_irq() ? KM_IRQ_PTE : \
KM_PTE0)
and in general can stop worrying about what context we're in and what kmap
slots might be appropriate for that.
The downside is that FRV kmap_atomic() gets more expensive.
For now we use a CPP trick suggested by Andrew:
#define kmap_atomic(page, args...) __kmap_atomic(page)
to avoid having to touch all kmap_atomic() users in a single patch.
[ not compiled on:
- mn10300: the arch doesn't actually build with highmem to begin with ]
[akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c]
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Ensure kmap_atomic() usage is strictly nested
BDIs or if significant congestion is not being encountered in the current zone
If congestion_wait() is called with no BDI congested, the caller will
sleep for the full timeout and this may be an unnecessary sleep. This
patch adds a wait_iff_congested() that checks congestion and only sleeps
if a BDI is congested else, it calls cond_resched() to ensure the caller
is not hogging the CPU longer than its quota but otherwise will not sleep.
This is aimed at reducing some of the major desktop stalls reported during
IO. For example, while kswapd is operating, it calls congestion_wait()
but it could just have been reclaiming clean page cache pages with no
congestion. Without this patch, it would sleep for a full timeout but
after this patch, it'll just call schedule() if it has been on the CPU too
long. Similar logic applies to direct reclaimers that are not making
enough progress.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
NODE_NOT_IN_PAGE_FLAGS is defined in mm.h when the node information is not
stored in the page flags bitmap.
Unfortunately, there's a typo in one of the checks for it. This patch
fixes it (s/NODE_NOT_IN_PAGEFLAGS/NODE_NOT_IN_PAGE_FLAGS/). Since this
has been around for ages, I doubt it's been causing any serious problems.
Cc: Christoph Lameter <clameter@sgi.com>
To help developers and applications gain visibility into writeback
behaviour adding two entries to vm_stat_items and /proc/vmstat. This will
allow us to track the "written" and "dirtied" counts.
# grep nr_dirtied /proc/vmstat
nr_dirtied 3747
# grep nr_written /proc/vmstat
nr_written 3618
Signed-off-by: Michael Rubin <mrubin@google.com>
behaviour this patch adds two counters to /proc/vmstat.
nr_dirtied 3747
nr_written 3618
These entries allow user apps to understand writeback behaviour over time
and learn how it is impacting their performance. Currently there is no
way to inspect dirty and writeback speed over time. It's not possible for
nr_dirty/nr_writeback.
These entries are necessary to give visibility into writeback behaviour.
We have /proc/diskstats which lets us understand the io in the block
layer. We have blktrace for more in depth understanding. We have
e2fsprogs and debugsfs to give insight into the file systems behaviour,
but we don't offer our users the ability understand what writeback is
doing. There is no way to know how active it is over the whole system, if
it's falling behind or to quantify it's efforts. With these values
exported users can easily see how much data applications are sending
through writeback and also at what rates writeback is processing this
data. Comparing the rates of change between the two allow developers to
see when writeback is not able to keep up with incoming traffic and the
rate of dirty memory being sent to the IO back end. This allows folks to
understand their io workloads and track kernel issues. Non kernel
engineers at Google often use these counters to solve puzzling performance
problems.
Patch #4 adds a pernode vmstat file with nr_dirtied and nr_written
Patch #5 add writeback thresholds to /proc/vmstat
Currently these values are in debugfs. But they should be promoted to
/proc since they are useful for developers who are writing databases
and file servers and are not debugging the kernel.
The output is as below:
# grep threshold /proc/vmstat
nr_pages_dirty_threshold 409111
nr_pages_dirty_background_threshold 818223
This patch:
This allows code outside of the mm core to safely manipulate page
writeback state and not worry about the other accounting. Not using these
routines means that some code will lose track of the accounting and we get
bugs.
Modify nilfs2 to use interface.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: Jiro SEKIBA <jir@unicus.jp>
Now, sysfs interface of memory hotplug shows whether the section is
removable or not. But it checks only migrateype of pages and doesn't
check details of cluster of pages.
Next, memory hotplug's set_migratetype_isolate() has the same kind of
check, too.
This patch adds the function __count_unmovable_pages() and makes above 2
checks to use the same logic. Then, is_removable and hotremove code uses
the same logic. No changes in the hotremove logic itself.
TODO: need to find a way to check RECLAMABLE. But, considering bit,
calling shrink_slab() against a range before starting memory hotremove
sounds better. If so, this patch's logic doesn't need to be changed.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reported-by: Michal Hocko <mhocko@suse.cz>
Non-NUMA systems do never create these files anyway, since they are only
created by driver subsystem when NUMA is configured.
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
The presently-unused macro was missing one parameter.
Signed-off-by: zeal <zealcook@gmail.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
It's pointless to kill a task if another thread sharing its mm cannot be
killed to allow future memory freeing. A subsequent patch will prevent
kills in such cases, but first it's necessary to have a way to flag a task
that shares memory with an OOM_DISABLE task that doesn't incur an
additional tasklist scan, which would make select_bad_process() an O(n^2)
function.
This patch adds an atomic counter to struct mm_struct that follows how
many threads attached to it have an oom_score_adj of OOM_SCORE_ADJ_MIN.
They cannot be killed by the kernel, so their memory cannot be freed in
oom conditions.
This only requires task_lock() on the task that we're operating on, it
does not require mm->mmap_sem since task_lock() pins the mm and the
operation is atomic.
[rientjes@google.com: changelog and sys_unshare() code]
[rientjes@google.com: protect oom_disable_count with task_lock in fork]
[rientjes@google.com: use old_mm for oom_disable_count in exec]
Signed-off-by: Ying Han <yinghan@google.com>
Signed-off-by: David Rientjes <rientjes@google.com>
This helper is wrong: it coerces signed values into unsigned ones, so code
such as
if (kfifo_alloc(...) < 0) {
error
will fail to detect the error.
So let's disable __kfifo_must_check_helper() for 2.6.36.
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Stefani Seibold <stefani@seibold.net>
Cc: <stable@kernel.org>
This comment landed in the wrong place.
Cc: Eric Paris <eparis@redhat.com>
Cc: Jan Engelhardt <jengelh@medozas.de>
* git://git.infradead.org/battery-2.6:
power_supply: Makefile cleanup
bq27x00_battery: Add missing kfree(di->bus) in bq27x00_battery_remove()
power_supply: Introduce maximum current property
power_supply: Add types for USB chargers
ds2782_battery: Fix units
power_supply: Add driver for TWL4030/TPS65950 BCI charger
bq20z75: Add support for more power supply properties
wm831x_power: Add missing kfree(wm831x_power) in wm831x_power_remove()
jz4740-battery: Add missing kfree(jz_battery) in jz_battery_remove()
ds2760_battery: Add missing kfree(di) in ds2760_battery_remove()
olpc_battery: Fix endian neutral breakage for s16 values
ds2760_battery: Fix W1 and W1_SLAVE_DS2760 dependency
pcf50633-charger: Add missing sysfs_remove_group()
power_supply: Add driver for TI BQ20Z75 gas gauge IC
wm831x_power: Remove duplicate chg mask
omap: rx51: Add support for USB chargers
power_supply: Add isp1704 charger detection driver
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (22 commits)
Add _addr_lsb field to ia64 siginfo
Fix migration.c compilation on s390
HWPOISON: Remove retry loop for try_to_unmap
HWPOISON: Turn addr_valid from bitfield into char
HWPOISON: Disable DEBUG by default
HWPOISON: Convert pr_debugs to pr_info
HWPOISON: Improve comments in memory-failure.c
x86: HWPOISON: Report correct address granuality for huge hwpoison faults
Encode huge page size for VM_FAULT_HWPOISON errors
Fix build error with !CONFIG_MIGRATION
hugepage: move is_hugepage_on_freelist inside ifdef to avoid warning
Clean up __page_set_anon_rmap
HWPOISON, hugetlb: fix unpoison for hugepage
HWPOISON, hugetlb: soft offlining for hugepage
HWPOSION, hugetlb: recover from free hugepage error when !MF_COUNT_INCREASED
hugetlb: move refcounting in hugepage allocation inside hugetlb_lock
HWPOISON, hugetlb: add free check to dequeue_hwpoison_huge_page()
hugetlb: hugepage migration core
hugetlb: redefine hugepage copy functions
hugetlb: add allocate function for hugepage migration
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits)
svcrpc: svc_tcp_sendto XPT_DEAD check is redundant
svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue
svcrpc: assume svc_delete_xprt() called only once
svcrpc: never clear XPT_BUSY on dead xprt
nfsd4: fix connection allocation in sequence()
nfsd4: only require krb5 principal for NFSv4.0 callbacks
nfsd4: move minorversion to client
nfsd4: delay session removal till free_client
nfsd4: separate callback change and callback probe
nfsd4: callback program number is per-session
nfsd4: track backchannel connections
nfsd4: confirm only on succesful create_session
nfsd4: make backchannel sequence number per-session
nfsd4: use client pointer to backchannel session
nfsd4: move callback setup into session init code
nfsd4: don't cache seq_misordered replies
SUNRPC: Properly initialize sock_xprt.srcaddr in all cases
SUNRPC: Use conventional switch statement when reclassifying sockets
sunrpc/xprtrdma: clean up workqueue usage
sunrpc: Turn list_for_each-s into the ..._entry-s
Fix up trivial conflicts (two different deprecation notices added in
separate branches) in Documentation/feature-removal-schedule.txt
git://git.linux-nfs.org/projects/trondmy/nfs-2.6
* 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
net/sunrpc: Use static const char arrays
nfs4: fix channel attribute sanity-checks
NFSv4.1: Use more sensible names for 'initialize_mountpoint'
NFSv4.1: pnfs: filelayout: add driver's LAYOUTGET and GETDEVICEINFO infrastructure
NFSv4.1: pnfs: add LAYOUTGET and GETDEVICEINFO infrastructure
NFS: client needs to maintain list of inodes with active layouts
NFS: create and destroy inode's layout cache
NFSv4.1: pnfs: filelayout: introduce minimal file layout driver
NFSv4.1: pnfs: full mount/umount infrastructure
NFS: set layout driver
NFS: ask for layouttypes during v4 fsinfo call
NFS: change stateid to be a union
NFSv4.1: pnfsd, pnfs: protocol level pnfs constants
SUNRPC: define xdr_decode_opaque_fixed
NFSD: remove duplicate NFS4_STATEID_SIZE
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin:
Blackfin: fix inverted anomaly 05000481 logic
Blackfin: drop unused irq_panic()/DEBUG_ICACHE_CHECK
Blackfin: ppi/spi/twi headers: add missing __BFP undef
Blackfin: update defconfigs
Blackfin: bfin_twi.h: start a common TWI header
netdev: bfin_mac: push settings to platform resources
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (24 commits)
hwmon: lis3: Release resources in case of failure
hwmon: lis3: Short explanations of platform data fields
hwmon: lis3: Enhance lis3 selftest with IRQ line test
hwmon: lis3: use block read to access data registers
hwmon: lis3: Adjust fuzziness for 8 bit device
hwmon: lis3: New parameters to platform data
hwmon: lis3: restore axis enabled bits
hwmon: lis3: Power on corrections
hwmon: lis3: Update coordinates at polled device open
hwmon: lis3: Cleanup interrupt handling
hwmon: lis3: regulator control
hwmon: lis3: pm_runtime support
Kirkwood: add fan support for Network Space Max v2
hwmon: add generic GPIO fan driver
hwmon: (coretemp) fix reading of microcode revision (v2)
hwmon: ({core, pkg, via-cpu}temp) remove unnecessary CONFIG_HOTPLUG_CPU ifdefs
hwmon: (pkgtemp) align driver initialization style with coretemp
hwmon: LTC4261 Hardware monitoring driver
hwmon: (lis3) add axes module parameter for custom axis-mapping
hwmon: (hp_accel) Add HP Mini 510x family support
Short documentation at kernel doc format.
Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Acked-by: Eric Piel <eric.piel@tremplin-utc.net>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Add optional blockread function to interface driver. If available
the chip driver uses it for data register access. For 12 bit device
it reads 6 bytes to get 3*16bit data. For 8 bit device it reads out
5 bytes since every second byte is dummy.
This optimizes bus usage and reduces number of operations and
interrupts needed for one data update.
Added default output data rate setting to platform data.
If default rate is 0, reset default value is used.
Added control for duration via platform data.
Added possibility to configure interrupts to trig on
both rising and falling edge. The lis3 WU unit can be
configured quite many ways and with some configurations it
is quite handy to get coordinate refresh when some
event trigs and when it reason goes away.
Based on pm_runtime control, turn lis3 regulators on and off.
Perform context save and restore on transitions.
Feature is optional and must be enabled in platform data.
This patch adds hwmon support for fans connected to GPIO lines.
Platform specific information such as GPIO pinout and speed conversion array
(rpm from/to GPIO value) are passed to the driver via platform_data.
Signed-off-by: Simon Guinot <sguinot@lacie.com>
* 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (67 commits)
SUNRPC: Cleanup duplicate assignment in rpcauth_refreshcred
nfs: fix unchecked value
Ask for time_delta during fsinfo probe
Revalidate caches on lock
SUNRPC: After calling xprt_release(), we must restart from call_reserve
NFSv4: Fix up the 'dircount' hint in encode_readdir
NFSv4: Clean up nfs4_decode_dirent
NFSv4: nfs4_decode_dirent must clear entry->fattr->valid
NFSv4: Fix a regression in decode_getfattr
NFSv4: Fix up decode_attr_filehandle() to handle the case of empty fh pointer
NFS: Ensure we check all allocation return values in new readdir code
NFS: Readdir plus in v4
NFS: introduce generic decode_getattr function
NFS: check xdr_decode for errors
NFS: nfs_readdir_filler catch all errors
NFS: readdir with vmapped pages
NFS: remove page size checking code
NFS: decode_dirent should use an xdr_stream
SUNRPC: Add a helper function xdr_inline_peek
NFS: remove readdir plus limit
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits)
omap: complete removal of machine_desc.io_pg_offst and .phys_io
omap: UART: fix wakeup registers for OMAP24xx UART2
omap: Fix spotty MMC voltages
ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h
serial: omap-serial: fix signess error
OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish
omap: dma: Fix buffering disable bit setting for omap24xx
omap: serial: Fix the boot-up crash/reboot without CONFIG_PM
OMAP3: PM: fix scratchpad memory accesses for off-mode
omap4: pandaboard: enable the ehci port on pandaboard
omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set
omap4: pandaboard: remove unused hsmmc definition
OMAP: McBSP: Remove null omap44xx ops comment
OMAP: McBSP: Swap CLKS source definition
OMAP: McBSP: Fix CLKR and FSR signal muxing
OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks
OMAP: control: move plat-omap/control.h to mach-omap2/control.h
OMAP: split plat-omap/common.c
OMAP: McBSP: implement functional clock switching via clock framework
OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c
Fixed up trivial conflicts in arch/arm/mach-omap2/
{board-zoom-peripherals.c,devices.c} as per Tony
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci
* 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (50 commits)
davinci: fix remaining board support after io_pgoffst removal
davinci: mityomapl138: make file local data static
arm/davinci: remove duplicated include
davinci: Initial support for Omapl138-Hawkboard
davinci: MityDSP-L138/MityARM-1808 read MAC address from I2C Prom
davinci: add tnetv107x touchscreen platform device
input: add driver for tnetv107x touchscreen controller
davinci: add keypad config for tnetv107x evm board
davinci: add tnetv107x keypad platform device
input: add driver for tnetv107x on-chip keypad controller
net: davinci_emac: cleanup unused cpdma code
net: davinci_emac: switch to new cpdma layer
net: davinci_emac: separate out cpdma code
net: davinci_emac: cleanup unused mdio emac code
omap: cleanup unused davinci mdio arch code
davinci: cleanup mdio arch code and switch to phy_id
net: davinci_emac: switch to new mdio
omap: add mdio platform devices
davinci: add mdio platform devices
net: davinci_emac: separate out davinci mdio
Fix up trivial conflict in drivers/input/keyboard/Kconfig (two entries
added next to each other - one from the davinci merge, one from the
input merge)
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (48 commits)
[S390] topology: export cpu topology via proc/sysinfo
[S390] topology: move topology sysinfo code
[S390] topology: clean up facility detection
[S390] cleanup facility list handling
[S390] enable ARCH_DMA_ADDR_T_64BIT with 64BIT
[S390] dasd: ignore unsolicited interrupts for DIAG
[S390] kvm: Enable z196 instruction facilities
[S390] dasd: fix unsolicited interrupt recognition
[S390] dasd: fix use after free in dbf
[S390] kvm: Fix badness at include/asm/mmu_context.h:83
[S390] cio: fix I/O cancel function
[S390] topology: change default
[S390] smp: use correct cpu address in print_cpu_info()
[S390] remove ieee_instruction_pointer from thread_struct
[S390] cleanup system call parameter setup
[S390] correct alignment of cpuid structure
[S390] cleanup lowcore access from external interrupts
[S390] cleanup lowcore access from program checks
[S390] pgtable: move pte_mkhuge() from hugetlb.h to pgtable.h
[S390] fix SIGBUS handling
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits)
ALSA: hda - Disable sticky PCM stream assignment for AD codecs
ALSA: usb - Creative USB X-Fi volume knob support
ALSA: ca0106: Use card specific dac id for mute controls.
ALSA: ca0106: Allow different sound cards to use different SPI channel mappings.
ALSA: ca0106: Create a nice spot for mapping channels to dacs.
ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence.
ALSA: ca0106: Pull out dac powering routine into separate function.
ALSA: ca0106 - add Sound Blaster 5.1vx info.
ASoC: tlv320dac33: Use usleep_range for delays
ALSA: usb-audio: add Novation Launchpad support
ALSA: hda - Add workarounds for CT-IBG controllers
ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs
ASoC: tpa6130a2: Error handling for broken chip
ASoC: max98088: Staticise m98088_eq_band
ASoC: soc-core: Fix codec->name memory leak
ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066
ALSA: hda - Add some workarounds for Creative IBG
ALSA: hda - Fix wrong SPDIF NID assignment for CA0110
ALSA: hda - Fix codec rename rules for ALC662-compatible codecs
ALSA: hda - Add alc_init_jacks() call to other codecs
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb
* 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb:
uwb: Orphan the UWB and WUSB subsystems
uwb: Remove the WLP subsystem and drivers
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mtd/m25p80: add support to parse the partitions by OF node
of/irq: of_irq.c needs to include linux/irq.h
of/mips: Cleanup some include directives/files.
of/mips: Add device tree support to MIPS
of/flattree: Eliminate need to provide early_init_dt_scan_chosen_arch
of/device: Rework to use common platform_device_alloc() for allocating devices
of/xsysace: Fix OF probing on little-endian systems
of: use __be32 types for big-endian device tree data
of/irq: remove references to NO_IRQ in drivers/of/platform.c
of/promtree: add package-to-path support to pdt
of/promtree: add of_pdt namespace to pdt code
of/promtree: no longer call prom_ functions directly; use an ops structure
of/promtree: make drivers/of/pdt.c no longer sparc-only
sparc: break out some PROM device-tree building code out into drivers/of
of/sparc: convert various prom_* functions to use phandle
sparc: stop exporting openprom.h header
powerpc, of_serial: Endianness issues setting up the serial ports
of: MTD: Fix OF probing on little-endian systems
of: GPIO: Fix OF probing on little-endian systems
Replace the BKL with a mutex to protect the venus_comm structure which
binds the mountpoint with the character device and holds the upcall
queues.
Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu>
Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu>
Now that shared inode state is locked using the cii->c_lock, the BKL is
only used to protect the upcall queues used to communicate with the
userspace cache manager. The remaining state is all local and we can
push the lock further down into coda_upcall().
We mostly need it to protect cached user permissions. The c_flags field
is advisory, reading the wrong value is harmless and in the worst case
we hit a slow path where we have to make an extra upcall to the
userspace cache manager when revalidating a dentry or inode.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (75 commits)
Input: wacom - specify Cinitq supported tools
Input: ab8500-ponkey - fix IRQ freeing in error path
Input: adp5588-keys - use more obvious i2c_device_id name string
Input: ad7877 - switch to using threaded IRQ
Input: ad7877 - use attribute group to control visibility of attributes
Input: serio - add support for PS2Mult multiplexer protocol
Input: wacom - properly enable runtime PM
Input: ad7877 - filter events where pressure is beyond the maximum
Input: ad7877 - implement EV_KEY:BTN_TOUCH reporting
Input: ad7877 - implement specified chip select behavior
Input: hp680_ts_input - use cancel_delayed_work_sync()
Input: mousedev - correct lockdep annotation
Input: ads7846 - switch to using threaded IRQ
Input: serio - support multiple child devices per single parent
Input: synaptics - simplify pass-through port handling
Input: add ROHM BU21013 touch panel controller support
Input: omap4-keypad - wake-up on events & long presses
Input: omap4-keypad - fix interrupt line configuration
Input: omap4-keypad - SYSCONFIG register configuration
Input: omap4-keypad - use platform device helpers
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (110 commits)
sh: i2c-sh7760: Replase from ctrl_* to __raw_*
sh: clkfwk: Shuffle around to match the intc split up.
sh: clkfwk: modify for_each_frequency end condition
sh: fix clk_get() error handling
sh: clkfwk: Fix fault in frequency iterator.
sh: clkfwk: Add a helper for rate rounding by divisor ranges.
sh: clkfwk: Abstract rate rounding helper.
sh: clkfwk: support clock remapping.
sh: pci: Convert to upper/lower_32_bits() helpers.
sh: mach-sdk7786: Add support for the FPGA SRAM.
sh: Provide a generic SRAM pool for tiny memories.
sh: pci: Support secondary FPGA-driven PCIe clocks on SDK7786.
sh: pci: Support slot 4 routing on SDK7786.
sh: Fix up PMB locking.
sh: mach-sdk7786: Add support for fpga gpios.
sh: use pr_fmt for clock framework, too.
sh: remove name and id from struct clk
sh: free-without-alloc fix for sh_mobile_lcdcfb
sh: perf: Set up perf_max_events.
sh: perf: Support SH-X3 hardware counters.
Fix up trivial conflicts (perf_max_events got removed) in arch/sh/kernel/perf_event.c
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
Revert "block: fix accounting bug on cross partition merges"
Improve performance of the sske operation by using the nonquiescing
variant if the affected page has no mappings established. On machines
with no support for the new sske variant the mask bit will be ignored.
The only Wimedia LLC Protocol (WLP) hardware was an Intel i1480 chip
with a beta release of firmware that was never commercially available as
a product. This hardware and firmware is no longer available as Intel
sold their UWB/WLP IP. I also see little prospect of other WLP
capable hardware ever being available.
Signed-off-by: David Vrabel <david.vrabel@csr.com>
Move all the pin settings out of the Kconfig and into the platform
resources (MII vs RMII). This clean up also lets us push out the
phy settings so that board porters may control the layout.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
