path: root/include/linux
2013-07-09ipc/sem: separate wait-for-zero and alter tasks into seperate queuesManfred Spraul
Introduce separate queues for operations that do not modify the semaphore values. Advantages: - Simpler logic in check_restart(). - Faster update_queue(): Right now, all wait-for-zero operations are always tested, even if the semaphore value is not 0. - wait-for-zero gets again priority, as in linux <=3.0.9 Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09ptrace: revert "Prepare to fix racy accesses on task breakpoints"Oleg Nesterov
This reverts commit bf26c018490c ("Prepare to fix racy accesses on task breakpoints"). The patch was fine but we can no longer race with SIGKILL after commit 9899d11f6544 ("ptrace: ensure arch_ptrace/ptrace_request can never race with SIGKILL"), the __TASK_TRACED tracee can't be woken up and ->ptrace_bps[] can't go away. Now that ptrace_get_breakpoints/ptrace_put_breakpoints have no callers, we can kill them and remove task->ptrace_bp_refcnt. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Michael Neuling <mikey@neuling.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09page migration: fix wrong comment in address_space_operations.migratepage()Tang Chen
There is no parameter "sync" in address_space_operations->migratepage(). It should be migrate_mode. And the comment is for MIGRATE_ASYNC. Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm: remove unused VM_<READfoo> macros and expand other in-placeJoe Perches
These VM_<READfoo> macros aren't used very often and three of them aren't used at all. Expand the ones that are used in-place, and remove all the now unused #define VM_<foo> macros. VM_READHINTMASK, VM_NormalReadHint and VM_ClearReadHint were added just before 2.4 and appears have never been used. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/writeback: commit reason of WB_REASON_FORKER_THREAD mismatch nameWanpeng Li
After commit 839a8e8660b6 ("writeback: replace custom worker pool implementation with unbound workqueue"), there is no bdi forker thread any more. However, WB_REASON_FORKER_THREAD is still used due to it is TPs userland visible and we won't be exposing exactly the same information with just a different name. Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/writeback: remove wb_reason_nameWanpeng Li
wb_reason_name is not used any more - remove it. Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09fs/fs-writeback.c: : make wb_do_writeback() as staticHaicheng Li
It's not used globally and could be static. Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Cc: Jan Kara <jack@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm: remove unused functions is_{normal_idx, normal, dma32, dma}Zhang Yanfei
These functions are nowhere used, so remove them. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09include/linux/gfp.h: fix the comment for GFP_ZONE_TABLEZhang Yanfei
0xc just means MOVABLE + DMA32, which results in zone DMA32. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/vmalloc.c: rename VM_UNLIST to VM_UNINITIALIZEDZhang Yanfei
VM_UNLIST was used to indicate that the vm_struct is not listed in vmlist. But after commit 4341fa454796 ("mm, vmalloc: remove list management of vmlist after initializing vmalloc"), the meaning of this flag changed. It now means the vm_struct is not fully initialized. So renaming it to VM_UNINITIALIZED seems more reasonable. Also change clear_vm_unlist to clear_vm_uninitialized_flag. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09audit: fix mq_open and mq_unlink to add the MQ root as a hidden parent ↵Jeff Layton
audit_names record The old audit PATH records for mq_open looked like this: type=PATH msg=audit(1366282323.982:869): item=1 name=(null) inode=6777 dev=00:0c mode=041777 ouid=0 ogid=0 rdev=00:00 obj=system_u:object_r:tmpfs_t:s15:c0.c1023 type=PATH msg=audit(1366282323.982:869): item=0 name="test_mq" inode=26732 dev=00:0c mode=0100700 ouid=0 ogid=0 rdev=00:00 obj=staff_u:object_r:user_tmpfs_t:s15:c0.c1023 ...with the audit related changes that went into 3.7, they now look like this: type=PATH msg=audit(1366282236.776:3606): item=2 name=(null) inode=66655 dev=00:0c mode=0100700 ouid=0 ogid=0 rdev=00:00 obj=staff_u:object_r:user_tmpfs_t:s15:c0.c1023 type=PATH msg=audit(1366282236.776:3606): item=1 name=(null) inode=6926 dev=00:0c mode=041777 ouid=0 ogid=0 rdev=00:00 obj=system_u:object_r:tmpfs_t:s15:c0.c1023 type=PATH msg=audit(1366282236.776:3606): item=0 name="test_mq" Both of these look wrong to me. As Steve Grubb pointed out: "What we need is 1 PATH record that identifies the MQ. The other PATH records probably should not be there." Fix it to record the mq root as a parent, and flag it such that it should be hidden from view when the names are logged, since the root of the mq filesystem isn't terribly interesting. With this change, we get a single PATH record that looks more like this: type=PATH msg=audit(1368021604.836:484): item=0 name="test_mq" inode=16914 dev=00:0c mode=0100644 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:user_tmpfs_t:s0 In order to do this, a new audit_inode_parent_hidden() function is added. If we do it this way, then we avoid having the existing callers of audit_inode needing to do any sort of flag conversion if auditing is inactive. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reported-by: Jiri Jaburek <jjaburek@redhat.com> Cc: Steve Grubb <sgrubb@redhat.com> Cc: Eric Paris <eparis@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-07Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "Once you have some time from extended weekend celebrations please consider pulling the following to get: - Various fixes and PCI driver for dw_dmac by Andy - DT binding for imx-dma by Markus & imx-sdma by Shawn - DT fixes for dmaengine by Lars - jz4740 dmac driver by Lars - and various fixes across the drivers" What "extended weekend celebrations"? I'm in the merge window, who has time for extended celebrations.. * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (40 commits) DMA: shdma: add DT support DMA: shdma: shdma_chan_filter() has to be in shdma-base.h DMA: shdma: (cosmetic) don't re-calculate a pointer dmaengine: at_hdmac: prepare clk before calling enable dmaengine/trivial: at_hdmac: add curly brackets to if/else expressions dmaengine: at_hdmac: remove unsuded atc_cleanup_descriptors() dmaengine: at_hdmac: add FIFO configuration parameter to DMA DT binding ARM: at91: dt: add header to define at_hdmac configuration MIPS: jz4740: Correct clock gate bit for DMA controller MIPS: jz4740: Remove custom DMA API MIPS: jz4740: Register jz4740 DMA device dma: Add a jz4740 dmaengine driver MIPS: jz4740: Acquire and enable DMA controller clock dma: mmp_tdma: disable irq when disabling dma channel dmaengine: PL08x: Avoid collisions with get_signal() macro dmaengine: dw: select DW_DMAC_BIG_ENDIAN_IO automagically dma: dw: add PCI part of the driver dma: dw: split driver to library part and platform code dma: move dw_dmac driver to an own directory dw_dmac: don't check resource with devm_ioremap_resource ...
2013-07-07Merge branch 'cpuinit-delete' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull first stage of __cpuinit removal from Paul Gortmaker: "The two commits here 1) dummy out all the __cpuinit macros so that we no longer generate such sections, and then 2) remove all the section processing that we used to do for those sections. This makes all the __cpuinit and friends no-ops, so that we can remove the use cases of it at our leisure. Expect stage 2, which does the tree wide removal sweep at the end of the merge window." * 'cpuinit-delete' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: modpost: remove all traces of cpuinit/cpuexit sections init.h: remove __cpuinit sections from the kernel
2013-07-06Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core updates from Thomas Gleixner: "The timer changes contain: - posix timer code consolidation and fixes for odd corner cases - sched_clock implementation moved from ARM to core code to avoid duplication by other architectures - alarm timer updates - clocksource and clockevents unregistration facilities - clocksource/events support for new hardware - precise nanoseconds RTC readout (Xen feature) - generic support for Xen suspend/resume oddities - the usual lot of fixes and cleanups all over the place The parts which touch other areas (ARM/XEN) have been coordinated with the relevant maintainers. Though this results in an handful of trivial to solve merge conflicts, which we preferred over nasty cross tree merge dependencies. The patches which have been committed in the last few days are bug fixes plus the posix timer lot. The latter was in akpms queue and next for quite some time; they just got forgotten and Frederic collected them last minute." * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits) hrtimer: Remove unused variable hrtimers: Move SMP function call to thread context clocksource: Reselect clocksource when watchdog validated high-res capability posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting posix_timers: fix racy timer delta caching on task exit posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule() selftests: add basic posix timers selftests posix_cpu_timers: consolidate expired timers check posix_cpu_timers: consolidate timer list cleanups posix_cpu_timer: consolidate expiry time type tick: Sanitize broadcast control logic tick: Prevent uncontrolled switch to oneshot mode tick: Make oneshot broadcast robust vs. CPU offlining x86: xen: Sync the CMOS RTC as well as the Xen wallclock x86: xen: Sync the wallclock when the system time is set timekeeping: Indicate that clock was set in the pvclock gtod notifier timekeeping: Pass flags instead of multiple bools to timekeeping_update() xen: Remove clock_was_set() call in the resume path hrtimers: Support resuming with two or more CPUs online (but stopped) timer: Fix jiffies wrap behavior of round_jiffies_common() ...
2013-07-06Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull irqdomain refactoring from Grant Likely: "This is the long awaited simplification of irqdomain. It gets rid of the different types of irq domains and instead both linear and tree mappings can be supported in a single domain. Doing this removes a lot of special case code and makes irq domains simpler to understand overall" * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux: irq: fix checkpatch error irqdomain: Include hwirq number in /proc/interrupts irqdomain: make irq_linear_revmap() a fast path again irqdomain: remove irq_domain_generate_simple() irqdomain: Refactor irq_domain_associate_many() irqdomain: Beef up debugfs output irqdomain: Clean up aftermath of irq_domain refactoring irqdomain: Eliminate revmap type irqdomain: merge linear and tree reverse mappings. irqdomain: Add a name field irqdomain: Replace LEGACY mapping with LINEAR irqdomain: Relax failure path on setting up mappings
2013-07-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Do not idle omap device between crypto operations in one session. - Added sha224/sha384 shims for SSSE3. - More optimisations for camellia-aesni-avx2. - Removed defunct blowfish/twofish AVX2 implementations. - Added unaligned buffer self-tests. - Added PCLMULQDQ optimisation for CRCT10DIF. - Added support for Freescale's DCP co-processor - Misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (44 commits) crypto: testmgr - test hash implementations with unaligned buffers crypto: testmgr - test AEADs with unaligned buffers crypto: testmgr - test skciphers with unaligned buffers crypto: testmgr - check that entries in alg_test_descs are in correct order Revert "crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher" Revert "crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher" crypto: camellia-aesni-avx2 - tune assembly code for more performance hwrng: bcm2835 - fix MODULE_LICENSE tag hwrng: nomadik - use clk_prepare_enable() crypto: picoxcell - replace strict_strtoul() with kstrtoul() crypto: dcp - Staticize local symbols crypto: dcp - Use NULL instead of 0 crypto: dcp - Use devm_* APIs crypto: dcp - Remove redundant platform_set_drvdata() hwrng: use platform_{get,set}_drvdata() crypto: omap-aes - Don't idle/start AES device between Encrypt operations crypto: crct10dif - Use PTR_RET crypto: ux500 - Cocci spatch "resource_size.spatch" crypto: sha256_ssse3 - add sha224 support crypto: sha512_ssse3 - add sha384 support ...
2013-07-05clocksource: Reselect clocksource when watchdog validated high-res capabilityThomas Gleixner
Up to commit 5d33b883a (clocksource: Always verify highres capability) we had no sanity check when selecting a clocksource, which prevented that a non highres capable clocksource is used when the system already switched to highres/nohz mode. The new sanity check works as Alex and Tim found out. It prevents the TSC from being used. This happens because on x86 the boot process looks like this: tsc_start_freqency_validation(TSC); clocksource_register(HPET); clocksource_done_booting(); clocksource_select() Selects HPET which is valid for high-res switch_to_highres(); clocksource_register(TSC); TSC is not selected, because it is not yet flagged as VALID_HIGH_RES clocksource_watchdog() Validates TSC for highres, but that does not make TSC the current clocksource. Before the sanity check was added, we installed TSC unvalidated which worked most of the time. If the TSC was really detected as unstable, then the unstable logic removed it and installed HPET again. The sanity check is correct and needed. So the watchdog needs to kick a reselection of the clocksource, when it qualifies TSC as a valid high res clocksource. To solve this, we mark the clocksource which got the flag CLOCK_SOURCE_VALID_FOR_HRES set by the watchdog with an new flag CLOCK_SOURCE_RESELECT and trigger the watchdog thread. The watchdog thread evaluates the flag and invokes clocksource_select() when set. To avoid that the clocksource_done_booting() code, which is about to install the first real clocksource anyway, needs to go through clocksource_select and tick_oneshot_notify() pointlessly, split out the clocksource_watchdog_kthread() list walk code and invoke the select/notify only when called from clocksource_watchdog_kthread(). So clocksource_done_booting() can utilize the same splitout code without the select/notify invocation and the clocksource_mutex unlock/relock dance. Reported-and-tested-by: Alex Shi <alex.shi@intel.com> Cc: Hans Peter Anvin <hpa@linux.intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Andi Kleen <andi.kleen@intel.com> Tested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@kernel.org> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1307042239150.11637@ionos.tec.linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-07-05DMA: shdma: add DT supportGuennadi Liakhovetski
This patch adds Device Tree support to the shdma driver. No special DT properties are used, only standard DMA DT bindings are implemented. Since shdma controllers reside on SoCs, their configuration is SoC-specific and shall be passed to the driver from the SoC platform data, using the auxdata procedure. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-07-05DMA: shdma: shdma_chan_filter() has to be in shdma-base.hGuennadi Liakhovetski
shdma_chan_filter() is a function, provided by the shdma-base.c module, move its declaration to the appropriate header. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-07-05dmaengine: PL08x: Avoid collisions with get_signal() macroMark Brown
As pointed out by Arnd Bergmann there is a get_signal macro definied in linux/signal.h which can conflict with the platform data callback function of the same name leading to confusing errors from the compiler (especially if signal.h manages to get pulled into the driver itself due to header dependencies). Avoid such errors by renaming get_signal and put_signal in the platform data to get_xfer_signal and put_xfer_signal. Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-07-05dmaengine: at_hdmac: extend hardware handshaking interface identificationNicolas Ferre
Peripheral handshaking identification numbers can be bigger than 15, so new fields have been created in the CFG register. Add macros to take this modification into account and use them in at_dma_xlate() function. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-07-05dma: imx-dma: Add oftree supportMarkus Pargmann
Adding devicetree support for imx-dma driver. Use driver name for function 'imx_dma_is_general_purpose' because the devicename for devicetree initialized devices is different. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-07-04Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree updates from Grant Likely: "This branch contains the following changes: - Removal of CONFIG_OF_DEVICE, it is always enabled by CONFIG_OF - Remove #ifdef from linux/of_platform.h to increase compiler syntax coverage - Bug fix for address decoding on Bimini and js2x powerpc platforms. - miscellaneous binding changes One note on the above. The binding changes going in from all kinds of different trees has gotten rather out of hand. I picked up some during this cycle, but even going though my tree isn't a great fit. Ian Campbell has prototyped splitting the bindings and .dtb files into a separate repository. The plan is to migrate to using that sometime in the next few kernel releases which should get rid of a lot of the churn on binding docs and .dts files" * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: of: Fix address decoding on Bimini and js2x machines of: remove CONFIG_OF_DEVICE usb: chipidea: depend on CONFIG_OF instead of CONFIG_OF_DEVICE of: remove of_platform_driver ibmebus: convert of_platform_driver to platform_driver driver core: move to_platform_driver to platform_device.h mfd: DT bindings for the palmas family MFD ARM: dts: omap3-devkit8000: fix NAND memory binding of/base: fix typos of: remove #ifdef from linux/of_platform.h
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "First round of updates for the input subsystem. You will get a new touchsreen driver for Cypress 4th generation devices, a driver for a special controller implementing PS/2 protocol in OLPC devices, and a driver for power key for SiRFprimaII PWRC. HID and bcm5497 now support for the 2013 MacBook Air. EVIOCGKEY and the rest of evdev ioctls now flush events of matching type from the client's event queue so that clients can be sure any events received after issuing EVIOCG* ioctl are new events. And a host of cleanups and improvements in other drivers" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (87 commits) Input: cyttsp4 - kfree xfer_buf on error path in probe() Input: tps6507x-ts - select INPUT_POLLDEV Input: bcm5974 - add support for the 2013 MacBook Air HID: apple: Add support for the 2013 Macbook Air Input: cyttsp4 - leak on error path in probe() Input: cyttsp4 - silence NULL dereference warning Input: cyttsp4 - silence shift wrap warning Input: tps6507x-ts - convert to polled input device infrastructure ARM: davinci: da850-evm: remove vref from touchscreen platform data Input: cyttsp4 - SPI driver for Cypress TMA4XX touchscreen devices Input: cyttsp4 - I2C driver for Cypress TMA4XX touchscreen devices Input: cyttsp4 - add core driver for Cypress TMA4XX touchscreen devices Input: cyttsp - I2C driver split into two modules Input: add OLPC AP-SP driver Input: nspire-keypad - remove redundant dev_err call in nspire_keypad_probe() Input: tps6507x-ts - remove vref from platform data Input: tps6507x-ts - use bool for booleans Input: tps6507x-ts - remove bogus unreachable code Input: samsung-keypad - let device core setup the default pin configuration Input: wacom_i2c - implement hovering capability ...
2013-07-04Merge branch 'timers/posix-cpu-timers-for-tglx' ofThomas Gleixner
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into timers/core Frederic sayed: "Most of these patches have been hanging around for several month now, in -mmotm for a significant chunk. They already missed a few releases." Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "This is the powerpc changes for the 3.11 merge window. In addition to the usual bug fixes and small updates, the main highlights are: - Support for transparent huge pages by Aneesh Kumar for 64-bit server processors. This allows the use of 16M pages as transparent huge pages on kernels compiled with a 64K base page size. - Base VFIO support for KVM on power by Alexey Kardashevskiy - Wiring up of our nvram to the pstore infrastructure, including putting compressed oopses in there by Aruna Balakrishnaiah - Move, rework and improve our "EEH" (basically PCI error handling and recovery) infrastructure. It is no longer specific to pseries but is now usable by the new "powernv" platform as well (no hypervisor) by Gavin Shan. - I fixed some bugs in our math-emu instruction decoding and made it usable to emulate some optional FP instructions on processors with hard FP that lack them (such as fsqrt on Freescale embedded processors). - Support for Power8 "Event Based Branch" facility by Michael Ellerman. This facility allows what is basically "userspace interrupts" for performance monitor events. - A bunch of Transactional Memory vs. Signals bug fixes and HW breakpoint/watchpoint fixes by Michael Neuling. And more ... I appologize in advance if I've failed to highlight something that somebody deemed worth it." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) pstore: Add hsize argument in write_buf call of pstore_ftrace_call powerpc/fsl: add MPIC timer wakeup support powerpc/mpic: create mpic subsystem object powerpc/mpic: add global timer support powerpc/mpic: add irq_set_wake support powerpc/85xx: enable coreint for all the 64bit boards powerpc/8xx: Erroneous double irq_eoi() on CPM IRQ in MPC8xx powerpc/fsl: Enable CONFIG_E1000E in mpc85xx_smp_defconfig powerpc/mpic: Add get_version API both for internal and external use powerpc: Handle both new style and old style reserve maps powerpc/hw_brk: Fix off by one error when validating DAWR region end powerpc/pseries: Support compression of oops text via pstore powerpc/pseries: Re-organise the oops compression code pstore: Pass header size in the pstore write callback powerpc/powernv: Fix iommu initialization again powerpc/pseries: Inform the hypervisor we are using EBB regs powerpc/perf: Add power8 EBB support powerpc/perf: Core EBB support for 64-bit book3s powerpc/perf: Drop MMCRA from thread_struct powerpc/perf: Don't enable if we have zero events ...
2013-07-03Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: - new driver to support GMT G762/G763 pwm fan controllers - add support for DS1631, DS1721, and DS1731 to ds1621 driver - remove detect function from ds1621 driver as unreliable - bug fixes in nct6775, iio_hwmon, and adm1021 drivers - remove redundant platform_set_drvdata in various drivers - add device tree support to ina2xx driver * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (ds1621) Fix temperature rounding operations hwmon: (nct6775) Drop unsupported fan alarm attributes for NCT6775 hwmon: (nct6775) Fix temperature alarm attributes Add support for GMT G762/G763 PWM fan controllers hwmon: (ina2xx) Add device tree support to pass the shunt resistor hwmon: (ds1621) Update documentation hwmon: (ds1621) Add DS1731 chip support to ds1621 driver hwmon: (iio_hwmon) add alias table hwmon: (adm1021) Do not create min sysfs attributes for LM84 hwmon: (ds1621) Remove detect function hwmon: (ds1621) Add ds1631 chip support to ds1621 driver and documentation hwmon: (ds1621) Add ds1721 update interval sysfs attribute hwmon: (ds1621) Add ds1721 chip support hwmon: (w83627ehf) Remove redundant platform_set_drvdata() hwmon: (ntc_thermistor) Remove redundant platform_set_drvdata() hwmon: (i5k_amb) Remove redundant platform_set_drvdata() hwmon: (coretemp) Remove redundant platform_set_drvdata() hwmon: (abituguru3) Remove redundant platform_set_drvdata()
2013-07-03Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem updates from Bryan Wu: - lp55xx device tree updates - mc13xxx driver updates - some clean up * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: leds: mc13783: Fix "uninitialized variable" warning leds: Convert led class driver from legacy pm ops to dev_pm_ops leds: leds-mc13783: Add MC13892 LED support leds: leds-mc13783: Prepare driver to support MC13892 LEDs leds: renesas-tpu: cleanup a small type issue leds: use platform_{get,set}_drvdata() leds: leds-gpio: Let device core handle pinctrl leds: lp5562: Properly setup of_device_id table leds: lp5523: Properly setup of_device_id table leds: lp5521: Properly setup of_device_id table leds: lp5562: support the device tree feature leds: lp55xx: support dynamic channel settings in the device tree structure leds: leds-ns2: remove unnecessary platform_set_drvdata() leds: leds-mc13783: remove unnecessary platform_set_drvdata() leds: leds-gpio: remove unnecessary platform_set_drvdata() leds: atmel-pwm: remove unnecessary platform_set_drvdata() leds: lp55xx: add support for Device Tree bindings
2013-07-03Merge tag 'sound-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "A relative calm release at this time with a flat diffstat. The only significant change in the ALSA core side is the support for more than 32 card instances, configurable via kconfig. Other than that, in both ASoC and other parts, mostly some improvements and fixes on the driver side. - hda: More quirks for ALC269-variants on Dell & co, VIA codec fixes - hda: Haswell HDMI audio fixes, runtime PM improvements - hda: Intel BayTrail support, ALC5505 DSP support - es1968: MediaForte M56VAP support - usb-audio: Improved support for Yamaha/Roland devices - usb-audio: M2Tech hiFace, Audio Advantage Micro II support - hdspm: wordclock fixes - ASoC: Pending fixes for WM8962 - ASoC: Cleanups and fixes for Blackfin, SGTL5000 and UX500 - ASoC: Generalisation of the Bluetooth and HDMI stub drivers - ASoC: SSM2518 and RT5640 codec drivers. - ASoC: Tegra CPUs with RT5640 machine driver - ASoC: AC'97 refactoring bug fixes - ASoC: ADAU1701 driver fixes - Clean up of *_set_drvdata() in a wide range of drivers" * tag 'sound-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (284 commits) ALSA: vmaster: Fix the regression of missing vmaster hook call ALSA: hda - Add Dell SSID to support Headset Mic recording ASoC: adau1701: remove control_data assignment ASoC: adau1701: more direct regmap usage ASoC: ac97: fixup multi-platform AC'97 module build failure ASoC: pxa2xx: fixup multi-platform AC'97 build failures ASoC: tegra20-ac97: Remove unused variable ASoC: tegra20-ac97: Remove duplicate error message ALSA: usb-audio: Add Audio Advantage Micro II ASoC: tas5086: fix Mid-Z implementation ASoC: tas5086: fix TAS5086_CLOCK_CONTROL register size ALSA: Replace the magic number 44 with const ALSA: hda - Fix the max length of control name in generic parser ALSA: hda - Guess what, it's two more Dell headset mic quirks ALSA: hda - Yet another Dell headset mic quirk ALSA: hda - Add support for ALC5505 DSP power-save mode ASoC: mfld: Remove unused variable ALSA: usb-audio: add quirks for Roland QUAD/OCTO-CAPTURE ALSA: usb-audio: claim autodetected PCM interfaces all at once ALSA: usb-audio: remove superfluous Roland quirks ...
2013-07-03Merge branch 'for-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: "Overview of changes: - The rest of maintainer email address updates. - Some core updates - more robust default behavior for port multipliers, better error reporting for SG_IO commands, and a way to better work around now ancient and probably pretty rare PATA -> SATA bridges with ATAPI devices. - sata_rcar stabilization. - Some hardware PCI ID additions and one-off low level driver updates." * 'for-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (22 commits) AHCI: use ATA_BUSY libata-zpodd: must use ata_tf_init() ahci: AHCI-mode SATA patch for Intel Coleto Creek DeviceIDs ata_piix: IDE-mode SATA patch for Intel Coleto Creek DeviceIDs libata: cleanup SAT error translation ahci: sata: add support for exynos5440 sata libata: skip SRST for all SIMG [34]7x port-multipliers ahci: remove pmp link online check in FBS EH sata highbank: add bit-banged SGPIO driver support ahci: make ahci_transmit_led_message into a function pointer sata_rcar: fix compilation warning in sata_rcar_thaw() sata_highbank: increase retry count but shorten duration for Calxeda controller ata: use pci_get_drvdata() ipr: qc_fill_rtf() method should not store alternate status register sata_rcar: add 'base' local variable to some functions sata_rcar: correct 'sata_rcar_sht' sata_rcar: kill superfluous code in sata_rcar_bmdma_fill_sg() libata: do not limit R-Car SATA driver to shmobile ata: use platform_{get,set}_drvdata() AHCI: Make distinct names for ports in /proc/interrupts ...
2013-07-03Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - various misc bits - I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been distracted. There has been quite a bit of activity. - About half the MM queue - Some backlight bits - Various lib/ updates - checkpatch updates - zillions more little rtc patches - ptrace - signals - exec - procfs - rapidio - nbd - aoe - pps - memstick - tools/testing/selftests updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits) tools/testing/selftests: don't assume the x bit is set on scripts selftests: add .gitignore for kcmp selftests: fix clean target in kcmp Makefile selftests: add .gitignore for vm selftests: add hugetlbfstest self-test: fix make clean selftests: exit 1 on failure kernel/resource.c: remove the unneeded assignment in function __find_resource aio: fix wrong comment in aio_complete() drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode drivers/memstick/host/r592.c: convert to module_pci_driver drivers/memstick/host/jmb38x_ms: convert to module_pci_driver pps-gpio: add device-tree binding and support drivers/pps/clients/pps-gpio.c: convert to module_platform_driver drivers/pps/clients/pps-gpio.c: convert to devm_* helpers drivers/parport/share.c: use kzalloc Documentation/accounting/getdelays.c: avoid strncpy in accounting tool aoe: update internal version number to v83 aoe: update copyright date aoe: perform I/O completions in parallel ...
2013-07-03Merge tag 'pci-v3.11-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "PCI device hotplug - Add pci_alloc_dev() interface (Gu Zheng) - Add pci_bus_get()/put() for reference counting (Jiang Liu) - Fix SR-IOV reference count issues (Jiang Liu) - Remove unused acpi_pci_roots list (Jiang Liu) MSI - Conserve interrupt resources on x86 (Alexander Gordeev) AER - Force fatal severity when component has been reset (Betty Dall) - Reset link below Root Port as well as Downstream Port (Betty Dall) - Fix "Firmware first" flag setting (Bjorn Helgaas) - Don't parse HEST for non-PCIe devices (Bjorn Helgaas) ASPM - Warn when we can't disable ASPM as driver requests (Bjorn Helgaas) Miscellaneous - Add CircuitCo PCI IDs (Darren Hart) - Add AMD CZ SATA and SMBus PCI IDs (Shane Huang) - Work around Ivytown NTB BAR size issue (Jon Mason) - Detect invalid initial BAR values (Kevin Hao) - Add pcibios_release_device() (Sebastian Ott) - Fix powerpc & sparc PCI_UNKNOWN power state usage (Bjorn Helgaas)" * tag 'pci-v3.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits) MAINTAINERS: Add ACPI folks for ACPI-related things under drivers/pci PCI: Add CircuitCo vendor ID and subsystem ID PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM) PCI: Return early on allocation failures to unindent mainline code PCI: Simplify IOV implementation and fix reference count races PCI: Drop redundant setting of bus->is_added in virtfn_add_bus() unicore32/PCI: Remove redundant call of pci_bus_add_devices() m68k/PCI: Remove redundant call of pci_bus_add_devices() PCI / ACPI / PM: Use correct power state strings in messages PCI: Fix comment typo for pcie_pme_remove() PCI: Rename pci_release_bus_bridge_dev() to pci_release_host_bridge_dev() PCI: Fix refcount issue in pci_create_root_bus() error recovery path ia64/PCI: Clean up pci_scan_root_bus() usage PCI/AER: Reset link for devices below Root Port or Downstream Port ACPI / APEI: Force fatal AER severity when component has been reset PCI/AER: Remove "extern" from function declarations PCI/AER: Move AER severity defines to aer.h PCI/AER: Set dev->__aer_firmware_first only for matching devices PCI/AER: Factor out HEST device type matching PCI/AER: Don't parse HEST table for non-PCIe devices ...
2013-07-03nbd: correct disconnect behaviorPaul Clements
Currently, when a disconnect is requested by the user (via NBD_DISCONNECT ioctl) the return from NBD_DO_IT is undefined (it is usually one of several error codes). This means that nbd-client does not know if a manual disconnect was performed or whether a network error occurred. Because of this, nbd-client's persist mode (which tries to reconnect after error, but not after manual disconnect) does not always work correctly. This change fixes this by causing NBD_DO_IT to always return 0 if a user requests a disconnect. This means that nbd-client can correctly either persist the connection (if an error occurred) or disconnect (if the user requested it). Signed-off-by: Paul Clements <paul.clements@steeleye.com> Acked-by: Rob Landley <rob@landley.net> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rapidio: change endpoint device name formatAlexandre Bounine
Change endpoint device name format to use a component tag value instead of device destination ID. RapidIO specification defines a component tag to be a unique identifier for devices in a network. RapidIO switches already use component tag as part of their device name and also use it for device identification when processing error management event notifications. Forming an endpoint's device name using its component tag instead of destination ID allows to keep sysfs device directories unchanged in case if a routing process dynamically changes endpoint's destination ID as a result of route optimization. This change should not affect any existing users because a valid device destination ID always should be obtained by reading "destid" attribute and not by parsing device name. This patch also removes switchid member from struct rio_switch because it simply duplicates the component tag and does not have other use than in device name generation. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Cc: Stef van Os <stef.van.os@Prodrive.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rapidio: add udev notificationAlexandre Bounine
Add RapidIO-specific modalias generation to enable udev notifications about RapidIO-specific events. The RapidIO modalias string format is shown below: "rapidio:vNNNNdNNNNavNNNNadNNNN" Where: v - Device Vendor ID (16 bit), d - Device ID (16 bit), av - Assembly Vendor ID (16 bit), ad - Assembly ID (16 bit), as they are reported in corresponding Capability Registers (CARs) of each RapidIO device. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Cc: Stef van Os <stef.van.os@Prodrive.nl> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rapidio: update enumerator registration mechanismAlexandre Bounine
Update enumeration/discovery method registration mechanism to allow loading enumeration/discovery methods before all mports are registered. Existing statically linked RapidIO subsystem expects that all available RapidIO mport devices are initialized and registered before the enumeration/discovery method is registered. Switching to loadable mport device drivers creates situation when mport device driver can be loaded after enumeration/discovery method is attached (e.g., loadable mport driver in a system with statically linked RapidIO core and enumerator). This also will happen in a system with hot-pluggable RapidIO controllers. To remove the dependency on the initialization/registration order this patch introduces enumeration/discovery registration mechanism that supports arbitrary registration order of mports and enumerator/discovery methods. The following registration rules are implemented: - only one enumeration/discovery method can be registered for given mport ID (including RIO_MPORT_ANY); - when new enumeration/discovery methods tries to attach to the registered mport device, method with matching mport ID will replace a default method previously registered for given mport (if any); - enumeration/discovery method with target ID=RIO_MPORT_ANY will be attached only to mports that do not have another enumerator attached to them; - when new mport device is registered with RapidIO subsystem, registration routine searches for the enumeration/discovery method with the best matching mport ID; Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Cc: Stef van Os <stef.van.os@Prodrive.nl> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rapidio: convert switch drivers to modulesAlexandre Bounine
Rework RapidIO switch drivers to add an option to build them as loadable kernel modules. This patch removes RapidIO-specific vmlinux section and converts switch drivers to be compatible with LDM driver registration method. To simplify registration of device-specific callback routines this patch introduces rio_switch_ops data structure. The sw_sysfs() callback is removed from the list of device-specific operations because under the new structure its functions can be handled by switch driver's probe() and remove() routines. If a specific switch device driver is not loaded the RapidIO subsystem core will use default standard-based operations to configure a switch. Because the current implementation of RapidIO enumeration/discovery method relies on availability of device-specific operations for error management, switch device drivers must be loaded before the RapidIO enumeration/discovery starts. This patch also moves several common routines from enumeration/discovery module into the RapidIO core code to make switch-specific operations accessible to all components of RapidIO subsystem. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Cc: Stef van Os <stef.van.os@Prodrive.nl> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03kernel/fork.c:copy_process(): don't add the uninitialized child to ↵Oleg Nesterov
thread/task/pid lists copy_process() adds the new child to thread_group/init_task.tasks list and then does attach_pid(child, PIDTYPE_PID). This means that the lockless next_thread() or next_task() can see this thread with the wrong pid. Say, "ls /proc/pid/task" can list the same inode twice. We could move attach_pid(child, PIDTYPE_PID) up, but in this case find_task_by_vpid() can find the new thread before it was fully initialized. And this is already true for PIDTYPE_PGID/PIDTYPE_SID, With this patch copy_process() initializes child->pids[*].pid first, then calls attach_pid() to insert the task into the pid->tasks list. attach_pid() no longer need the "struct pid*" argument, it is always called after pid_link->pid was already set. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03exit.c: unexport __set_special_pids()Oleg Nesterov
Move __set_special_pids() from exit.c to sys.c close to its single caller and make it static. And rename it to set_special_pids(), another helper with this name has gone away. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03lcd: add devm_lcd_device_{register,unregister}()Jingoo Han
These functions allow the driver core to automatically clean up any allocation made by lcd drivers. Thus it simplifies the error paths. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03backlight: add devm_backlight_device_{register,unregister}()Jingoo Han
These functions allow the driver core to automatically clean up any allocation made by backlight drivers. Thus it simplifies the error paths. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/dma: remove unused support for MEMSET operationsBartlomiej Zolnierkiewicz
There have never been any real users of MEMSET operations since they have been introduced in January 2007 by commit 7405f74badf4 ("dmaengine: refactor dmaengine around dma_async_tx_descriptor"). Therefore remove support for them for now, it can be always brought back when needed. [sebastian.hesselbarth@gmail.com: fix drivers/dma/mv_xor] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Vinod Koul <vinod.koul@intel.com> Acked-by: Dan Williams <djbw@fb.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Olof Johansson <olof@lixom.net> Cc: Kevin Hilman <khilman@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03dmi: add support for exact DMI matches in addition to substring matchingJani Nikula
dmi_match() considers a substring match to be a successful match. This is not always sufficient to distinguish between DMI data for different systems. Add support for exact string matching using strcmp() in addition to the substring matching using strstr(). The specific use case in the i915 driver is to allow us to use an exact match for D510MO, without also incorrectly matching D510MOV: { .ident = "Intel D510MO", .matches = { DMI_MATCH(DMI_BOARD_VENDOR, "Intel"), DMI_EXACT_MATCH(DMI_BOARD_NAME, "D510MO"), }, } Signed-off-by: Jani Nikula <jani.nikula@intel.com> Cc: <annndddrr@gmail.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Cornel Panceac <cpanceac@gmail.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers: avoid format strings in names passed to alloc_workqueue()Kees Cook
For the workqueue creation interfaces that do not expect format strings, make sure they cannot accidently be parsed that way. Additionally, clean up calls made with a single parameter that would be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03err.h: IS_ERR() can accept __user pointersDan Carpenter
Sparse generates a false positive when you pass a __user or __iomem pointer to the IS_ERR() functions. drivers/rtc/rtc-ds1286.c:344:36: sparse: incorrect type in argument 1 (different address spaces) drivers/rtc/rtc-ds1286.c:344:36: expected void const *ptr drivers/rtc/rtc-ds1286.c:344:36: got unsigned int [noderef] [usertype] <asn:2>*rtcregs We can silence these by adding a __force here and upgrading to Sparse v0.4.5-rc1 or later. This change has no effect when using current Sparse releases. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Christopher Li <sparse@chrisli.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03sparsemem: add BUILD_BUG_ON when sizeof mem_section is non-power-of-2Cody P Schafer
Instead of leaving a hidden trap for the next person who comes along and wants to add something to mem_section, add a big fat warning about it needing to be a power-of-2, and insert a BUILD_BUG_ON() in sparse_init() to catch mistakes. Right now non-power-of-2 mem_sections cause a number of WARNs at boot (which don't clearly point to the size of mem_section as an issue), but the system limps on (temporarily, at least). This is based upon Dave Hansen's earlier RFC where he ran into the same issue: "sparsemem: fix boot when SECTIONS_PER_ROOT is not power-of-2" http://lkml.indiana.edu/hypermail/linux/kernel/1205.2/03077.html Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Acked-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Jiang Liu <liuj97@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: kill free_all_bootmem_node()Jiang Liu
Now nobody makes use of free_all_bootmem_node(), kill it. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Yinghai Lu <yinghai@kernel.org> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: introduce helper function set_max_mapnr()Jiang Liu
Introduce a helper function set_max_mapnr() to set global variable max_mapnr. Also unify condition compilation for max_mapnr with CONFIG_NEED_MULTIPLE_NODES instead of CONFIG_DISCONTIGMEM. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: kill global variable num_physpagesJiang Liu
Now all references to num_physpages have been removed, so kill it. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
