path: root/include/linux
2006-09-27[PATCH] kdump: introduce "reset_devices" command line optionVivek Goyal
Resetting the devices during driver initialization can be a costly operation in terms of time (especially scsi devices). This option can be used by drivers to know that user forcibly wants the devices to be reset during initialization. This option can be useful while kernel is booting in unreliable environment. For ex. during kdump boot where devices are in unknown random state and BIOS execution has been skipped. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] NOMMU: move the fallback arch_vma_name() to a sensible placeDavid Howells
Move the fallback arch_vma_name() to a sensible place (kernel/signal.c). Currently it's in fs/proc/task_mmu.c, a file that is dependent on both CONFIG_PROC_FS and CONFIG_MMU being enabled, but it's used from kernel/signal.c from where it is called unconditionally. [akpm@osdl.org: build fix] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] NOMMU: Implement /proc/pid/maps for NOMMUDavid Howells
Implement /proc/pid/maps for NOMMU by reading the vm_area_list attached to current->mm->context.vmlist. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] NOMMU: Set BDI capabilities for /dev/mem and /dev/kmemDavid Howells
Set the backing device info capabilities for /dev/mem and /dev/kmem to permit direct sharing under no-MMU conditions and full mapping capabilities under MMU conditions. Make the BDI used by these available to all directly mappable character devices. Also comment the capabilities for /dev/zero. [akpm@osdl.org: ifdef reductions] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Mark __remove_vm_area() staticRolf Eike Beer
The function is exported but not used from anywhere else. It's also marked as "not for driver use" so noone out there should really care. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] do_no_pfn()Jes Sorensen
Implement do_no_pfn() for handling mapping of memory without a struct page backing it. This avoids creating fake page table entries for regions which are not backed by real memory. This feature is used by the MSPEC driver and other users, where it is highly undesirable to have a struct page sitting behind the page (for instance if the page is accessed in cached mode via the struct page in parallel to the the driver accessing it uncached, which can result in data corruption on some architectures, such as ia64). This version uses specific NOPFN_{SIGBUS,OOM} return values, rather than expect all negative pfn values would be an error. It also bugs on cow mappings as this would not work with the VM. [akpm@osdl.org: micro-optimise] Signed-off-by: Jes Sorensen <jes@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Add node to zone for the NUMA caseChristoph Lameter
Add the node in order to optimize zone_to_nid. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Disable GFP_THISNODE in the non-NUMA caseChristoph Lameter
GFP_THISNODE must be set to 0 in the non numa case otherwise we disable retry and warnings for failing allocations in the SMP and UP case. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Add NUMA_BUILD definition in kernel.h to avoid #ifdef CONFIG_NUMAChristoph Lameter
The NUMA_BUILD constant is always available and will be set to 1 on NUMA_BUILDs. That way checks valid only under CONFIG_NUMA can easily be done without #ifdef CONFIG_NUMA F.e. if (NUMA_BUILD && <numa_condition>) { ... } [akpm: not a thing we'd normally do, but CONFIG_NUMA is special: it is causing ifdef explosion in core kernel, so let's see if this is a comfortable way in whcih to control that] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] own header file for struct pageHeiko Carstens
This moves the definition of struct page from mm.h to its own header file page-struct.h. This is a prereq to fix SetPageUptodate which is broken on s390: #define SetPageUptodate(_page) do { struct page *__page = (_page); if (!test_and_set_bit(PG_uptodate, &__page->flags)) page_test_and_clear_dirty(_page); } while (0) _page gets used twice in this macro which can cause subtle bugs. Using __page for the page_test_and_clear_dirty call doesn't work since it causes yet another problem with the page_test_and_clear_dirty macro as well. In order to avoid all these problems caused by macros it seems to be a good idea to get rid of them and convert them to static inline functions. Because of header file include order it's necessary to have a seperate header file for the struct page definition. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] vm: add per-zone writeout counterAndrew Morton
The VM is supposed to minimise the number of pages which get written off the LRU (for IO scheduling efficiency, and for high reclaim-success rates). But we don't actually have a clear way of showing how true this is. So add `nr_vmscan_write' to /proc/vmstat and /proc/zoneinfo - the number of pages which have been written by the vm scanner in this zone and globally. Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Allow an arch to expand node boundariesMel Gorman
Arch-independent zone-sizing determines the size of a node (pgdat->node_spanned_pages) based on the physical memory that was registered by the architecture. However, when CONFIG_MEMORY_HOTPLUG_RESERVE is set, the architecture expects that the spanned_pages will be much larger and that mem_map will be allocated that is used lated on memory hot-add. This patch allows an architecture that sets CONFIG_MEMORY_HOTPLUG_RESERVE to call push_node_boundaries() which will set the node beginning and end to at *least* the requested boundary. Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Andi Kleen <ak@muc.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Keith Mannthey" <kmannth@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Account for memmap and optionally the kernel image as holesMel Gorman
The x86_64 code accounted for memmap and some portions of the the DMA zone as holes. This was because those areas would never be reclaimed and accounting for them as memory affects min watermarks. This patch will account for the memmap as a memory hole. Architectures may optionally use set_dma_reserve() if they wish to account for a portion of memory in ZONE_DMA as a hole. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Andi Kleen <ak@muc.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Keith Mannthey" <kmannth@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Introduce mechanism for registering active regions of memoryMel Gorman
At a basic level, architectures define structures to record where active ranges of page frames are located. Once located, the code to calculate zone sizes and holes in each architecture is very similar. Some of this zone and hole sizing code is difficult to read for no good reason. This set of patches eliminates the similar-looking architecture-specific code. The patches introduce a mechanism where architectures register where the active ranges of page frames are with add_active_range(). When all areas have been discovered, free_area_init_nodes() is called to initialise the pgdat and zones. The zone sizes and holes are then calculated in an architecture independent manner. Patch 1 introduces the mechanism for registering and initialising PFN ranges Patch 2 changes ppc to use the mechanism - 139 arch-specific LOC removed Patch 3 changes x86 to use the mechanism - 136 arch-specific LOC removed Patch 4 changes x86_64 to use the mechanism - 74 arch-specific LOC removed Patch 5 changes ia64 to use the mechanism - 52 arch-specific LOC removed Patch 6 accounts for mem_map as a memory hole as the pages are not reclaimable. It adjusts the watermarks slightly Tony Luck has successfully tested for ia64 on Itanium with tiger_defconfig, gensparse_defconfig and defconfig. Bob Picco has also tested and debugged on IA64. Jack Steiner successfully boot tested on a mammoth SGI IA64-based machine. These were on patches against 2.6.17-rc1 and release 3 of these patches but there have been no ia64-changes since release 3. There are differences in the zone sizes for x86_64 as the arch-specific code for x86_64 accounts the kernel image and the starting mem_maps as memory holes but the architecture-independent code accounts the memory as present. The big benefit of this set of patches is a sizable reduction of architecture-specific code, some of which is very hairy. There should be a greater reduction when other architectures use the same mechanisms for zone and hole sizing but I lack the hardware to test on. Additional credit; Dave Hansen for the initial suggestion and comments on early patches Andy Whitcroft for reviewing early versions and catching numerous errors Tony Luck for testing and debugging on IA64 Bob Picco for fixing bugs related to pfn registration, reviewing a number of patch revisions, providing a number of suggestions on future direction and testing heavily Jack Steiner and Robin Holt for testing on IA64 and clarifying issues related to memory holes Yasunori for testing on IA64 Andi Kleen for reviewing and feeding back about x86_64 Christian Kujau for providing valuable information related to ACPI problems on x86_64 and testing potential fixes This patch: Define the structure to represent an active range of page frames within a node in an architecture independent manner. Architectures are expected to register active ranges of PFNs using add_active_range(nid, start_pfn, end_pfn) and call free_area_init_nodes() passing the PFNs of the end of each zone. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Bob Picco <bob.picco@hp.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Andi Kleen <ak@muc.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Keith Mannthey" <kmannth@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Make kmem_cache_destroy() return voidAlexey Dobriyan
un-, de-, -free, -destroy, -exit, etc functions should in general return void. Also, There is very little, say, filesystem driver code can do upon failed kmem_cache_destroy(). If it will be decided to BUG in this case, BUG should be put in generic code, instead. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3: Fix sparse warningsDave Kleikamp
Fixing up some endian-ness warnings in preparation to clone ext4 from ext3. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3: More whitespace cleanupsDave Kleikamp
More white space cleanups in preparation of cloning ext4 from ext3. Removing spaces that precede a tab. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] JBD: 16T fixesEric Sandeen
These are a few places I've found in jbd that look like they may not be 16T-safe, or consistent with the use of unsigned longs for block containers. Problems here would be somewhat hard to hit, would require journal blocks past the 8T boundary, which would not be terribly common. Still, should fix. (some of these have come from the ext4 work on jbd as well). I think there's one more possibility that the wrap() function may not be safe IF your last block in the journal butts right up against the 232 block boundary, but that seems like a VERY remote possibility, and I'm not worrying about it at this point. Signed-off-by: Eric Sandeen <esandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3 and jbd cleanup: remove whitespaceMingming Cao
Remove whitespace from ext3 and jbd, before we clone ext4. Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/i2c-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/i2c-2.6: (30 commits) i2c: Drop unimplemented slave functions i2c: Constify i2c_algorithm declarations, part 2 i2c: Constify i2c_algorithm declarations, part 1 i2c: Let drivers constify i2c_algorithm data i2c-isa: Restore driver owner i2c-viapro: Add support for the VT8237A and VT8251 i2c: Warn on i2c client creation failure i2c-core: Drop useless bitmaskings i2c-algo-pcf: Discard the mdelay data struct member i2c-algo-bit: Cleanups i2c-isa: Fail adding driver on attach_adapter error i2c: __must_check fixes (chip drivers) i2c-dev: attach/detach_adapter cleanups i2c-stub: Chip address as a module parameter i2c: Plan i2c-isa for removal i2c: New bus driver for TI OMAP boards i2c-algo-bit: Discard the mdelay data struct member i2c-matroxfb: Struct init conversion i2c: Fix copy-n-paste in subsystem Kconfig i2c-au1550: Add I2C support for Au1200 ...
2006-09-27Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (28 commits) pciehp - fix wrong return value IA64: PCI: dont disable irq which is not enabled acpiphp: add support for ioapic hot-remove PCI: assign ioapic resource at hotplug acpiphp: disable bridges acpiphp: stop bus device before acpi_bus_trim PCI: add pci_stop_bus_device acpiphp: do not initialize existing ioapics acpiphp: initialize ioapics before starting devices acpiphp: set hpp values before starting devices PCI Hotplug: cleanup pcihp skeleton code. PCI: Restore PCI Express capability registers after PM event PCI: drivers/pci/hotplug/acpiphp_glue.c: make a function static PCI: Multiprobe sanitizer PCI: fix __must_check warnings PCI Hotplug: fix __must_check warnings SHPCHP: fix __must_check warnings PCI-Express AER implemetation: pcie_portdrv error handler PCI-Express AER implemetation: AER core and aerdriver PCI-Express AER implemetation: export pcie_port_bus_type ...
2006-09-27[MIPS] Remove EV96100 as previously announced.Ralf Baechle
2006-09-26PCI: add pci_stop_bus_deviceSatoru Takeuchi
This patch adds pci_stop_bus_device() which stops a PCI device (detach the driver, remove from the global list and so on) and any children. This is needed for ACPI based PCI-to-PCI bridge hot-remove, and it will be also needed for ACPI based PCI root bridge hot-remove. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: MUNEDA Takahiro <muneda.takahiro@jp.fujitsu.com> Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26PCI: Multiprobe sanitizerAlan Cox
There are numerous drivers that can use multithreaded probing but having some kind of global flag as the way to control this makes migration to threaded probing hard and since it enables it everywhere and is almost as likely to cause serious pain as holding a clog dance in a minefield. If we have a pci_driver multithread_probe flag to inherit you can turn it on for one driver at a time. From playing so far however I think we need a different model at the device layer which serializes until the called probe function says "ok you can start another one now". That would need some kind of flag and semaphore plus a helper function. Anyway in the absence of that this is a starting point to usefully play with this stuff Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26PCI: fix __must_check warningsGreg Kroah-Hartman
2006-09-26PCI-Express AER implemetation: AER core and aerdriverZhang, Yanmin
Patch 3 implements the core part of PCI-Express AER and aerdrv port service driver. When a root port service device is probed, the aerdrv will call request_irq to register irq handler for AER error interrupt. When a device sends an PCI-Express error message to the root port, the root port will trigger an interrupt, by either MSI or IO-APIC, then kernel would run the irq handler. The handler collects root error status register and schedules a work. The work will call the core part to process the error based on its type (Correctable/non-fatal/fatal). As for Correctable errors, the patch chooses to just clear the correctable error status register of the device. As for the non-fatal error, the patch follows generic PCI error handler rules to call the error callback functions of the endpoint's driver. If the device is a bridge, the patch chooses to broadcast the error to downstream devices. As for the fatal error, the patch resets the pci-express link and follows generic PCI error handler rules to call the error callback functions of the endpoint's driver. If the device is a bridge, the patch chooses to broadcast the error to downstream devices. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26MSI: Blacklist PCI-E chipsets depending on Hypertransport MSI capabilityBrice Goglin
Introduce msi_ht_cap_enabled() to check the MSI capability in the Hypertransport configuration space. It is used in a generic quirk quirk_msi_ht_cap() to check whether MSI is enabled on hypertransport chipset, and a nVidia specific quirk quirk_nvidia_ck804_msi_ht_cap() where two 2 HT MSI mappings have to be checked. Both quirks set the PCI_BUS_FLAGS_NO_MSI bus flag when MSI is disabled. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26MSI: Rename PCI_CAP_ID_HT_IRQCONF into PCI_CAP_ID_HTBrice Goglin
0x08 is the HT capability, while PCI_CAP_ID_HT_IRQCONF would be the subtype 0x80 that mpic_scan_ht_pic() uses. Rename PCI_CAP_ID_HT_IRQCONF into PCI_CAP_ID_HT. And by the way, use it in the ipath driver instead of defining its own HT_CAPABILITY_ID. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c: Drop unimplemented slave functionsJean Delvare
i2c: Drop unimplemented slave functions Drop the function declarations for slave mode support of i2c adapters. This was never implemented, and by the time it is I bet we will want something different anyway. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c: Let drivers constify i2c_algorithm dataDavid Brownell
i2c: Let drivers constify i2c_algorithm data Let drivers constify I2C algorithm method operations tables, moving them from ".data" to ".rodata". Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-algo-pcf: Discard the mdelay data struct memberAdrian Bunk
i2c-algo-pcf: Discard the mdelay data struct member Just as i2c-algo-bit, i2c-algo-pcf has an unused mdelay struct member, which we can get rid of to spare some code and memory. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-algo-bit: Discard the mdelay data struct memberJean Delvare
i2c-algo-bit: Discard the mdelay data struct member The i2c_algo_bit_data structure has an mdelay member, which is not used by the algorithm code (the code has always been ifdef'd out.) Let's discard it to save some code and memory. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-algo-sibyte: Merge into i2c-sibyteJean Delvare
i2c-algo-sibyte: Merge into i2c-sibyte Merge i2c-algo-sibyte into i2c-sibyte, as this is a complete, hardware-dependent SMBus implementation and not a reusable algorithm. Perform some basic coding style cleanups while we're here (mainly space-based indentation replaced by tabulations.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (225 commits) [PATCH] Don't set calgary iommu as default y [PATCH] i386/x86-64: New Intel feature flags [PATCH] x86: Add a cumulative thermal throttle event counter. [PATCH] i386: Make the jiffies compares use the 64bit safe macros. [PATCH] x86: Refactor thermal throttle processing [PATCH] Add 64bit jiffies compares (for use with get_jiffies_64) [PATCH] Fix unwinder warning in traps.c [PATCH] x86: Allow disabling early pci scans with pci=noearly or disallowing conf1 [PATCH] x86: Move direct PCI scanning functions out of line [PATCH] i386/x86-64: Make all early PCI scans dependent on CONFIG_PCI [PATCH] Don't leak NT bit into next task [PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinder [PATCH] Fix some broken white space in ia32_signal.c [PATCH] Initialize argument registers for 32bit signal handlers. [PATCH] Remove all traces of signal number conversion [PATCH] Don't synchronize time reading on single core AMD systems [PATCH] Remove outdated comment in x86-64 mmconfig code [PATCH] Use string instructions for Core2 copy/clear [PATCH] x86: - restore i8259A eoi status on resume [PATCH] i386: Split multi-line printk in oops output. ...
2006-09-26Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (47 commits) Driver core: Don't call put methods while holding a spinlock Driver core: Remove unneeded routines from driver core Driver core: Fix potential deadlock in driver core PCI: enable driver multi-threaded probe Driver Core: add ability for drivers to do a threaded probe sysfs: add proper sysfs_init() prototype drivers/base: check errors drivers/base: Platform notify needs to occur before drivers attach to the device v4l-dev2: handle __must_check add CONFIG_ENABLE_MUST_CHECK add __must_check to device management code Driver core: fixed add_bind_files() definition Driver core: fix comments in drivers/base/power/resume.c sysfs_remove_bin_file: no return value, dump_stack on error kobject: must_check fixes Driver core: add ability for devices to create and remove bin files Class: add support for class interfaces for devices Driver core: create devices/virtual/ tree Driver core: add device_rename function Driver core: add ability for classes to handle devices properly ...
2006-09-26[PATCH] PM: Add pm_trace switchRafael J. Wysocki
Add the pm_trace attribute in /sys/power which has to be explicitly set to one to really enable the "PM tracing" code compiled in when CONFIG_PM_TRACE is set (which modifies the machine's CMOS clock in unpredictable ways). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] PM: make it possible to disable console suspendingRafael J. Wysocki
Change suspend_console() so that it waits for all consoles to flush the remaining messages and make it possible to switch the console suspending off with the help of a Kconfig option. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Stefan Seyfried <seife@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] swsusp: Use memory bitmaps during resumeRafael J. Wysocki
Make swsusp use memory bitmaps to store its internal information during the resume phase of the suspend-resume cycle. If the pfns of saveable pages are saved during the suspend phase instead of the kernel virtual addresses of these pages, we can use them during the resume phase directly to set the corresponding bits in a memory bitmap. Then, this bitmap is used to mark the page frames corresponding to the pages that were saveable before the suspend (aka "unsafe" page frames). Next, we allocate as many page frames as needed to store the entire suspend image and make sure that there will be some extra free "safe" page frames for the list of PBEs constructed later. Subsequently, the image is loaded and, if possible, the data loaded from it are written into their "original" page frames (ie. the ones they had occupied before the suspend). The image data that cannot be written into their "original" page frames are loaded into "safe" page frames and their "original" kernel virtual addresses, as well as the addresses of the "safe" pages containing their copies, are stored in a list of PBEs. Finally, the list of PBEs is used to copy the remaining image data into their "original" page frames (this is done atomically, by the architecture-dependent parts of swsusp). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] swsusp: clean up suspend headerRafael J. Wysocki
Remove some things that are no longer used or defined elsewhere from suspend.h and make the inline version of software_suspend() return the right error code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] Disable CPU hotplug during suspendRafael J. Wysocki
The current suspend code has to be run on one CPU, so we use the CPU hotplug to take the non-boot CPUs offline on SMP machines. However, we should also make sure that these CPUs will not be enabled by someone else after we have disabled them. The functions disable_nonboot_cpus() and enable_nonboot_cpus() are moved to kernel/cpu.c, because they now refer to some stuff in there that should better be static. Also it's better if disable_nonboot_cpus() returns an error instead of panicking if something goes wrong, and enable_nonboot_cpus() has no reason to panic(), because the CPUs may have been enabled by the userland before it tries to take them online. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] swsusp: read speedupAndrew Morton
Implement async reads for swsusp resuming. Crufty old PIII testbox: 15.7 MB/s -> 20.3 MB/s Sony Vaio: 14.6 MB/s -> 33.3 MB/s I didn't implement the post-resume bio_set_pages_dirty(). I don't really understand why resume needs to run set_page_dirty() against these pages. It might be a worry that this code modifies PG_Uptodate, PG_Error and PG_Locked against the image pages. Can this possibly affect the resumed-into kernel? Hopefully not, if we're atomically restoring its mem_map? Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Jens Axboe <axboe@suse.de> Cc: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] swsusp: write speedupAndrew Morton
Switch the swsusp writeout code from 4k-at-a-time to 4MB-at-a-time. Crufty old PIII testbox: 12.9 MB/s -> 20.9 MB/s Sony Vaio: 14.7 MB/s -> 26.5 MB/s The implementation is crude. A better one would use larger BIOs, but wouldn't gain any performance. The memcpys will be mostly pipelined with the IO and basically come for free. The ENOMEM path has not been tested. It should be. Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] add DIV_ROUND_UP()Steven Whitehouse
Add the DIV_ROUND_UP() helper macro: divide `n' by `d', rounding up. Stolen from the gfs2 tree(!) because the swsusp patches need it. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] smp_call_function_single() cleanupAndrew Morton
If we're going to implement smp_call_function_single() on three architecture with the same prototype then it should have a declaration in a non-arch-specific header file. Move it into <linux/smp.h>. Cc: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] Translate asm version of ELFNOTE macro into preprocessor macroIan Campbell
I've come across some problems with the assembly version of the ELFNOTE macro currently in -mm. (in x86-put-note-sections-into-a-pt_note-segment-in-vmlinux.patch) The first is that older gas does not support :varargs in .macro definitions (in my testing 2.17 does while 2.15 does not, I don't know when it became supported). The Changes file says binutils >= 2.12 so I think we need to avoid using it. There are no other uses in mainline or -mm. Old gas appears to just ignore it so you get "too many arguments" type errors. Secondly it seems that passing strings as arguments to assembler macros is broken without varargs. It looks like they get unquoted or each character is treated as a separate argument or something and this causes all manner of grief. I think this is because of the use of -traditional when compiling assembly files. Therefore I have translated the assembler macro into a pre-processor macro. I added the desctype as a separate argument instead of including it with the descdata as the previous version did since -traditional means the ELFNOTE definition after the #else needs to have the same number of arguments (I think so anyway, the -traditional CPP semantics are pretty fscking strange!). With this patch I am able to define elfnotes in assembly like this with both old and new assemblers. ELFNOTE(Xen, XEN_ELFNOTE_GUEST_OS, .asciz, "linux") ELFNOTE(Xen, XEN_ELFNOTE_GUEST_VERSION, .asciz, "2.6") ELFNOTE(Xen, XEN_ELFNOTE_XEN_VERSION, .asciz, "xen-3.0") ELFNOTE(Xen, XEN_ELFNOTE_VIRT_BASE, .long, __PAGE_OFFSET) Which seems reasonable enough. Signed-off-by: Ian Campbell <ian.campbell@xensource.com> Acked-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] x86: put .note.* sections into a PT_NOTE segment in vmlinuxJeremy Fitzhardinge
This patch will pack any .note.* section into a PT_NOTE segment in the output file. To do this, we tell ld that we need a PT_NOTE segment. This requires us to start explicitly mapping sections to segments, so we also need to explicitly create PT_LOAD segments for text and data, and map the sections to them appropriately. Fortunately, each section will default to its previous section's segment, so it doesn't take many changes to vmlinux.lds.S. This only changes i386 for now, but I presume the corresponding changes for other architectures will be as simple. This change also adds <linux/elfnote.h>, which defines C and Assembler macros for actually creating ELF notes. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] avr32 architectureHaavard Skinnemoen
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000 CPU and the AT32STK1000 development board. AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. The AVR32 architecture is not binary compatible with earlier 8-bit AVR architectures. The AVR32 architecture, including the instruction set, is described by the AVR32 Architecture Manual, available from http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It features a 7-stage pipeline, 16KB instruction and data caches and a full Memory Management Unit. It also comes with a large set of integrated peripherals, many of which are shared with the AT91 ARM-based controllers from Atmel. Full data sheet is available from http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf while the CPU core implementation including caches and MMU is documented by the AVR32 AP Technical Reference, available from http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf Information about the AT32STK1000 development board can be found at http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918 including a BSP CD image with an earlier version of this patch, development tools (binaries and source/patches) and a root filesystem image suitable for booting from SD card. Alternatively, there's a preliminary "getting started" guide available at http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links to the sources and patches you will need in order to set up a cross-compiling environment for avr32-linux. This patch, as well as the other patches included with the BSP and the toolchain patches, is actively supported by Atmel Corporation. [dmccr@us.ibm.com: Fix more pxx_page macro locations] [bunk@stusta.de: fix `make defconfig'] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] FRV: permit __do_IRQ() to be dispensed withDavid Howells
Permit __do_IRQ() to be dispensed with based on a configuration option. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] selinux: replace ctxid with sid in selinux_audit_rule_match interfaceStephen Smalley
Replace ctxid with sid in selinux_audit_rule_match interface for consistency with other interfaces. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] selinux: rename selinux_ctxid_to_stringStephen Smalley
Rename selinux_ctxid_to_string to selinux_sid_to_string to be consistent with other interfaces. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
