This patch applies the mutex so far only protecting the controller list
to (almost) all accesses of controller data structures. It also reworks
waiting on state changes in old_capi_manufacturer so that it no longer
poll and holds a module reference to the controller owner while waiting
(the latter was partly done already). Modification and checking of the
blocked state remains racy by design, the caller is responsible for
dealing with this.
Signed-off-by: Jan Kiszka <jan.kiszka@web.de>
Another step towards proper locking: Rework the callback provided to
capidrv for controller state changes. This is so far attached to an
application, which would require us to hold the corresponding lock
across notification calls.
But there is no direct relation between a controller up/down event and
an application, so let's decouple them and provide a notifier call chain
for those events instead. This notifier chain is first of all used
internally. Here we request the highest priority to unsure that
housekeeping work is done before any other notifications. The chain is
exported via [un]register_capictr_notifier to our only user, capidrv, to
replace the racy and unfixable capi20_set_callback.
At least for our internal use, fix the misnomers that refer to a CAPI
controller as 'card'. No functional changes.
Stop computing the number of neighbour table settings we have by
counting the number of binary sysctls. This behaviour was silly
and meant that we could not add another neighbour table setting
without also adding another binary sysctl.
Don't pass the binary sysctl path for neighour table entries
into neigh_sysctl_register. These parameters are no longer
used and so are just dead code.
Stop using the binary sysctl enumeartion in sysctl.h as an index into
a per interface array. This leads to unnecessary binary sysctl number
allocation, and a fragility in data structure and implementation
because of unnecessary coupling.
This patch fixes following sparse warnings:
include/linux/kfifo.h:127:25: warning: Using plain integer as NULL pointer
kernel/kfifo.c:83:21: warning: Using plain integer as NULL pointer
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Stefani Seibold <stefani@seibold.net>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf top: Fix help text alignment
perf: Fix hypervisor sample reporting
perf: Make bp_len type to u64 generic across the arch
with 32 bit userland and 64 bit kernels, it is unlikely but possible
that insertion of new rules fails even tough there are only about 2000
iptables rules.
This happens because the compat delta is using a short int.
Easily reproducible via "iptables -m limit" ; after about 2050
rules inserting new ones fails with -ELOOP.
Note that compat_delta included 2 bytes of padding on x86_64, so
structure size remains the same.
Parse and dump the conntrack zone in ctnetlink.
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
GCC is now smart enough to follow the inline trail correctly.
vmlinux size remain the same.
No changes in vmlinux filesize.
Based upon a patch by Oliver Hartkopp <oliver@hartkopp.net>.
The function name must be followed by a space, hypen, space, and a
short description.
Add netdev ops for configuring SR-IOV VF devices through the PF driver.
Signed-off-by: Mitch Williams <mitch.a.williams@intel.com>
Add SR-IOV VF management methods to IFLA_LINKINFO. This allows userspace to
use rtnetlink to configure VF network devices.
Add and export pci_num_vf to allow other subsystems to determine how many
virtual function devices are associated with an SR-IOV physical function
device.
Add macros dev_is_pci, dev_is_ps, and dev_num_vf to make it easier for
non-PCI specific code to determine SR-IOV capabilities.
Add macros to test a private structure for msg_enable bits
and the netif_msg_##bit to test and call netdev_printk if set
Simplifies logic in callers and adds message logging consistency
These netdev_printk routines take a struct net_device * and emit
dev_printk logging messages adding "%s: " ... netdev->dev.parent
to the dev_printk format and arguments.
This can create some uniformity in the output message log.
These helpers should not be used until a successful alloc_netdev.
Add support for mangling TCP SIP packets.
Add TCP support, which is mandated by RFC3261 for all SIP elements.
SIP over TCP is similar to UDP, except that messages are delimited
by Content-Length: headers and multiple messages may appear in one
packet.
When using TCP multiple SIP messages might be present in a single packet.
A following patch will parse them by setting the dptr to the beginning of
each message. The NAT helper needs to reload the dptr value after mangling
the packet however, so it needs to know the offset of the message to the
beginning of the packet.
This patchset enables the ethtool layer to program n-tuple
filters to an underlying device. The idea is to allow capable
hardware to have static rules applied that can assist steering
flows into appropriate queues.
Hardware that is known to support these types of filters today
are ixgbe and niu.
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
Some places in kernel need to iterate over a hlist in seq_file,
so provide some common helpers.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
The static initial tables are pretty large, and after the net
namespace has been instantiated, they just hang around for nothing.
This commit removes them and creates tables on-demand at runtime when
needed.
Size shrinks by 7735 bytes (x86_64).
The respective xt_table structures already have most of the metadata
needed for hook setup. Add a 'priority' field to struct xt_table so
that xt_hook_link() can be called with a reduced number of arguments.
So should we be having more tables in the future, it comes at no
static cost (only runtime, as before) - space saved:
6807373->6806555.
Rewrite COMPAT_XT_ALIGN in terms of dummy structure hack.
Compat counters logically have nothing to do with it.
Use ALIGN() macro while I'm at it for same types.
There is compat_u64 type which deals with different u64 type alignment
on different compat-capable platforms, so use it and removed some
hardcoded assumptions.
ima_path_check actually deals with files! call it ima_file_check instead.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
The "Untangling ima mess, part 2 with counters" patch messed
up the counters. Based on conversations with Al Viro, this patch
streamlines ima_path_check() by removing the counter maintaince.
The counters are now updated independently, from measuring the file,
in __dentry_open() and alloc_file() by calling ima_counts_get().
ima_path_check() is called from nfsd and do_filp_open().
It also did not measure all files that should have been measured.
Reason: ima_path_check() got bogus value passed as mask.
[AV: mea culpa]
[AV: add missing nfsd bits]
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
[libata] Call flush_dcache_page after PIO data transfers in libata-sff.c
ahci: add Acer G725 to broken suspend list
libata: fix ata_id_logical_per_physical_sectors
libata-scsi passthru: fix bug which truncated LBA48 return values
This is to make the annotation of percpu variables during the next merge
window less painfull.
Extracted from a patch by Rusty Russell.
Acked-by: Tejun Heo <tj@kernel.org>
This patch adds GSO/checksum offload to af_packet sockets using
virtio_net_hdr. Based on Rusty's patch to add this support to tun.
It allows GSO/checksum offload to be enabled when using raw socket
backend with virtio_net.
Adds PACKET_VNET_HDR socket option to prepend virtio_net_hdr in the
receive path and process/skip virtio_net_hdr in the send path. This
option is only allowed with SOCK_RAW sockets attached to ethernet
type devices.
v2 updates
Michael's Comments
- Perform length check in packet_snd() when GSO is off even when
vnet_hdr is present.
- Check for SKB_GSO_FCOE type and return -EINVAL
- don't allow tx/rx ring when vnet_hdr is enabled.
Herbert's Comments
- Removed ethernet specific code.
- protocol value is assumed to be passed in by the caller.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Handle futex value corruption gracefully
futex: Handle user space corruption gracefully
futex_lock_pi() key refcnt fix
softlockup: Add sched_clock_tick() to avoid kernel warning on kgdb resume
Many drivers do this in them manually. Now they can use this function.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
This patch introduces the similar helpers as those already done for uc list.
However multicast lists are no list_head lists but "mademanually". The three
macros added by this patch will make the transition of mc_list to list_head
smooth in two steps:
1) convert all drivers to use these macros (with the original iterator of type
"struct dev_mc_list")
2) once all drivers are converted, convert list type and iterators to "struct
netdev_hw_addr" in one patch.
>From now on, drivers can (and should) use "netdev_for_each_mc_addr" to iterate
over the addresses with iterator of type "struct netdev_hw_addr". Also macros
"netdev_mc_count" and "netdev_mc_empty" to read list's length. This is the state
which should be reached in all drivers.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
The value we get from the low byte of the ATA_ID_SECTOR_SIZE word is not not
a plain multiple, but the log of it, so fix the helper to give the correct
answer. Without this we'll get an incorrect minimal I/O size in the block
limits VPD page for 4k sector drives.
Also change the return value of ata_id_logical_per_physical_sectors to u16
for the unlikely case of very large logical sectors.
Ifdef out
struct proto_ops::compat_ioctl
struct proto_ops::compat_setsockopt
struct proto_ops::compat_getsockopt
to make structures smaller on COMPAT=n kernels.
In order to use macvlan with qemu and other tools that require
a tap file descriptor, the macvtap driver adds a small backend
with a character device with the same interface as the tun
driver, with a minimum set of features.
Macvtap interfaces are created in the same way as macvlan
interfaces using ip link, but the netif is just used as a
handle for configuration and accounting, while the data
goes through the chardev. Each macvtap interface has its
own character device, simplifying permission management
significantly over the generic tun/tap driver.
Cc: Patrick McHardy <kaber@trash.net>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: David S. Miller" <davem@davemloft.net>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Or Gerlitz <ogerlitz@voltaire.com>
Cc: netdev@vger.kernel.org
Cc: bridge@lists.linux-foundation.org
This makes it possible to hook into the macvlan driver
from another kernel module. In particular, the goal is
to extend it with the macvtap backend that provides
a tun/tap compatible interface directly on the macvlan
device.
In the vlan and macvlan drivers, the start_xmit function forwards
data to the dev_queue_xmit function for another device, which may
potentially belong to a different namespace.
To make sure that classification stays within a single namespace,
this resets the potentially critical fields.
Change 'bp_len' type to __u64 to make it work across archs as
the s390 architecture watch point length can be upto 2^64.
reference:
http://lkml.org/lkml/2010/1/25/212
This is an ABI change that is not backward compatible with
the previous hardware breakpoint info layout integrated in this
development cycle, a rebuilt of perf tools is necessary for
versions based on 2.6.33-rc1 - 2.6.33-rc6 to work with a
kernel based on this patch.
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: "K. Prasad" <prasad@linux.vnet.ibm.com>
Cc: Maneesh Soni <maneesh@in.ibm.com>
Cc: Martin <schwidefsky@de.ibm.com>
LKML-Reference: <20100130045518.GA20776@in.ibm.com>
