path: root/include/linux
2006-01-10[PATCH] lib/zlib*: cleanupsAdrian Bunk
This patch contains the following possible cleanups: - #if 0 the following unused functions: - zlib_deflate/deflate.c: zlib_deflateSetDictionary - zlib_deflate/deflate.c: zlib_deflateParams - zlib_deflate/deflate.c: zlib_deflateCopy - zlib_inflate/infblock.c: zlib_inflate_set_dictionary - zlib_inflate/infblock.c: zlib_inflate_blocks_sync_point - zlib_inflate/inflate_sync.c: zlib_inflateSync - zlib_inflate/inflate_sync.c: zlib_inflateSyncPoint - remove the following unneeded EXPORT_SYMBOL's: - zlib_deflate/deflate_syms.c: zlib_deflateCopy - zlib_deflate/deflate_syms.c: zlib_deflateParams - zlib_inflate/inflate_syms.c: zlib_inflateSync - zlib_inflate/inflate_syms.c: zlib_inflateSyncPoint Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] DocBook: fix kernel-doc commentsMartin Waitz
Fix typos in comments to remove kernel-doc warnings. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] nvidiafb: Add support for some pci-e chipsetsAntonino A. Daplas
Chipsets with PCI device ids & 0xf0 == 0x00f0 has their actual chipset type in offset 0x1800 of the mmio space. Add support for this. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] vesafb: Drop blank hookAntonino A. Daplas
From: Bugzilla Bug 5351 "After resuming from S3 (suspended while in X), the LCD panel stays black . However, the laptop is up again, and I can SSH into it from another machine. I can get the panel working again, when I first direct video output to the CRT output of the laptop, and then back to LCD (done by repeatedly hitting Fn+F5 buttons on the Toshiba, which directs output to either LCD, CRT or TV) None of this ever happened with older kernels." This bug is due to the recently added vesafb_blank() method in vesafb. It works with CRT displays, but has a high incidence of problems in laptop users. Since CRT users don't really get that much benefit from hardware blanking, drop support for this. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes: fix build breakageAnanth N Mavinakayanahalli
The following patch (against 2.6.15-rc5-mm3) fixes a kprobes build break due to changes introduced in the kprobe locking in 2.6.15-rc5-mm3. In addition, the patch reverts back the open-coding of kprobe_mutex. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes: arch_remove_kprobeAnil S Keshavamurthy
Currently arch_remove_kprobes() is only implemented/required for x86_64 and powerpc. All other architecture like IA64, i386 and sparc64 implementes a dummy function which is being called from arch independent kprobes.c file. This patch removes the dummy functions and replaces it with #define arch_remove_kprobe(p, s) do { } while(0) Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes: changed from using spinlock to mutexAnil S Keshavamurthy
Since Kprobes runtime exception handlers is now lock free as this code path is now using RCU to walk through the list, there is no need for the register/unregister{_kprobe} to use spin_{lock/unlock}_isr{save/restore}. The serialization during registration/unregistration is now possible using just a mutex. In the above process, this patch also fixes a minor memory leak for x86_64 and powerpc. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Remove getnstimestamp()Matt Helsley
Remove getnstimestamp() in favor of ktime.h's ktime_get_ts() Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: convert posix timers completelyThomas Gleixner
- convert posix-timers.c to use hrtimers - remove the now obsolete abslist code Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: switch clock_nanosleep to hrtimer nanosleep APIThomas Gleixner
Switch clock_nanosleep to use the new nanosleep functions in hrtimer.c Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: create hrtimer nanosleep APIThomas Gleixner
introduce the hrtimer_nanosleep() and hrtimer_nanosleep_real() APIs. Not yet used by any code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: switch itimers to hrtimerThomas Gleixner
switch itimers to a hrtimers-based implementation Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: hrtimer core codeThomas Gleixner
hrtimer subsystem core. It is initialized at bootup and expired by the timer interrupt, but is otherwise not utilized by any other subsystem yet. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: introduce ktime_t time formatThomas Gleixner
- introduce ktime_t: nanosecond-resolution time format. - eliminate the plain s64 scalar type, and always use the union. This simplifies the arithmetics. Idea from Roman Zippel. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: introduce nsec_t type and conversion functionsThomas Gleixner
- introduce the nsec_t type - basic nsec conversion routines: timespec_to_ns(), timeval_to_ns(), ns_to_timespec(), ns_to_timeval(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: create and use timespec_valid macroThomas Gleixner
add timespec_valid(ts) [returns false if the timespec is denorm] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: coding style and white space cleanup 2Thomas Gleixner
style/whitespace/macro cleanups of posix-timers.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: make clockid_t arguments constThomas Gleixner
add const arguments to the posix-timers.h API functions Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: coding style and white space cleanupIngo Molnar
style and whitespace cleanup of the rest of time.h. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: coding style clean up of clock constantsIngo Molnar
clean up the CLOCK_ portions of time.h Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: remove unused clock constantsThomas Gleixner
remove unused CLOCK_ constants from time.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: clean up mktime and make arguments constIngo Molnar
add 'const' to mktime arguments, and clean it up a bit Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: deinline mktime and set_normalized_timespecThomas Gleixner
mktime() and set_normalized_timespec() are large inline functions used in many places: deinline them. From: George Anzinger, off-by-1 bugfix Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: move div_long_long_rem out of jiffies.hThomas Gleixner
move div_long_long_rem() from jiffies.h into a new calc64.h include file, as it is a general math function useful for other things than the jiffy code. Convert it to an inline function Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] per-mountpoint noatime/nodiratimeChristoph Hellwig
Turn noatime and nodiratime into per-mount instead of per-sb flags. After all the preparations this is a rather trivial patch. The mount code needs to treat the two options as per-mount instead of per-superblock, and touch_atime needs to be changed to check the new MNT_ flags in addition to the MS_ flags that are kept for filesystems that are always noatime/nodiratime but not user settable anymore. Besides that core code only nfs needed an update because it's leaving atime updates to the server and thus sets the S_NOATIME flag on every inode, but needs to know whether it's a real noatime mount for an getattr optimization. While we're at it I've killed the IS_NOATIME/IS_NODIRATIME macros that were only used by touch_atime. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] sanitize building of fs/compat_ioctl.cChristoph Hellwig
Now that all these entries in the arch ioctl32.c files are gone [1], we can build fs/compat_ioctl.c as a normal object and kill tons of cruft. We need a special do_ioctl32_pointer handler for s390 so the compat_ptr call is done. This is not needed but harmless on all other architectures. Also remove some superflous includes in fs/compat_ioctl.c Tested on ppc64. [1] parisc still had it's PPP handler left, which is not fully correct for ppp and besides that ppp uses the generic SIOCPRIV ioctl so it'd kick in for all netdevice users. We can introduce a proper handler in one of the next patch series by adding a compat_ioctl method to struct net_device but for now let's just kill it - parisc doesn't compile in mainline anyway and I don't want this to block this patchset. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] __deprecated_for_modules the lookup_hash() prototypeAdrian Bunk
This patch __deprecated_for_modules the lookup_hash() prototype. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove update_atimeChristoph Hellwig
All callers use touch_atime now which takes a vfsmount and allows us to implement per-mount noatime. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] move xattr permission checks into the VFSakpm@osdl.org
) From: Christoph Hellwig <hch@lst.de> The xattr code has rather complex permission checks because the rules are very different for different attribute namespaces. This patch moves as much as we can into the generic code. Currently all the major disk based filesystems duplicate these checks, while many minor filesystems or network filesystems lack some or all of them. To do this we need defines for the extended attribute names in common code, I moved them up from JFS which had the nicest defintions. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] add vfs_* helpers for xattr operationsChristoph Hellwig
Add vfs_getxattr, vfs_setxattr and vfs_removexattr helpers for common checks around invocation of the xattr methods. NFSD already was missing some of the checks and there will be more soon. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: James Morris <jmorris@namei.org> (James, I haven't touched selinux yet because it's doing various odd things and I'm not sure how it would interact with the security attribute fallbacks you added. Could you investigate whether it could use vfs_getxattr or if not add a __vfs_getxattr helper to share the bits it is fine with?) For NFSv4: instead of just converting it add an nfsd_getxattr helper for the code shared by NFSv2/3 and NFSv4 ACLs. In fact that code isn't even NFS-specific, but I'll wait for more users to pop up first before moving it to common code. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kexec: increase max segment limitakpm@osdl.org
) From: Vivek Goyal <vgoyal@in.ibm.com> - In some cases, the number of segments, on a kexec load, exceeds the existing cap of 8. This patch increases the KEXEC_SEGMENT_MAX limit from 8 to 16. Signed-off-by: Rachita Kothiyal <rachita@in.ibm.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kdump: dynamic per cpu allocation of memory for saving cpu registersVivek Goyal
- In case of system crash, current state of cpu registers is saved in memory in elf note format. So far memory for storing elf notes was being allocated statically for NR_CPUS. - This patch introduces dynamic allocation of memory for storing elf notes. It uses alloc_percpu() interface. This should lead to better memory usage. - Introduced based on Andi Kleen's and Eric W. Biederman's suggestions. - This patch also moves memory allocation for elf notes from architecture dependent portion to architecture independent portion. Now crash_notes is architecture independent. The whole idea is that size of memory to be allocated per cpu (MAX_NOTE_BYTES) can be architecture dependent and allocation of this memory can be architecture independent. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dump_thread() cleanupakpm@osdl.org
) From: Adrian Bunk <bunk@stusta.de> - create one common dump_thread() prototype in kernel.h - dump_thread() is only used in fs/binfmt_aout.c and can therefore be removed on all architectures where CONFIG_BINFMT_AOUT is not available Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Add list_for_each_entry_safe_reverse()David Howells
Add list_for_each_entry_safe_reverse() to linux/list.h This is needed by unmerged cachefs and be an as-yet-unreviewed device_shutdown() fix. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Patrick Mochel <mochel@digitalimplant.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] i386: GPIO driver for AMD CS5535/CS5536Ben Gardner
A simple driver for the CS5535 and CS5536 that allows a user-space program to manipulate GPIO pins. The CS5535/CS5536 chips are Geode processor companion devices. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
2006-01-09Merge master.kernel.org:/pub/scm/linux/kernel/git/mingo/mutex-2.6Linus Torvalds
2006-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2006-01-09[PATCH] mutex subsystem, semaphore to completion: drivers/block/loop.cIngo Molnar
convert the block loop device from semaphores to completions. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, semaphore to completion: IDE ->gendev_rel_semAleksey Makarov
The patch changes semaphores that are initialized as locked to complete(). Source: MontaVista Software, Inc. Modified-by: Steven Rostedt <rostedt@goodmis.org> The following patch is from Montavista. I modified it slightly. Semaphores are currently being used where it makes more sense for completions. This patch corrects that. Signed-off-by: Aleksey Makarov <amakarov@ru.mvista.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, sb->s_lockIngo Molnar
This patch converts the superblock-lock semaphore to a mutex, affecting lock_super()/unlock_super(). Tested on ext3 and XFS. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, more debugging codeIngo Molnar
more mutex debugging: check for held locks during memory freeing, task exit, enable sysrq printouts, etc. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-09[PATCH] mutex subsystem, debugging codeIngo Molnar
mutex implementation - add debugging code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-09[PATCH] mutex subsystem, coreIngo Molnar
mutex implementation, core files: just the basic subsystem, no users of it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-09[PATCH] mutex subsystem, add typecheck_fn(type, function)Chuck Ebbert
add typecheck_fn(type, function) to do type-checking of function pointers. Modified-by: Ingo Molnar <mingo@elte.hu> (made it typeof() based, instead of typedef based.) Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2006-01-10s/assoicated/associated/Adrian Bunk
2006-01-09Merge master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
