path: root/include/linux
2010-12-03mtd: onenand: add option and variable for cache program featureRoman Tereshonkov
A new option is added for cache program feature. A new variable ongoing is introduced for onenand_chip to handle the multi-command cache program operation. Signed-off-by: Roman Tereshonkov <roman.tereshonkov@nokia.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-30Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (82 commits) mtd: fix build error in m25p80.c mtd: Remove redundant mutex from mtd_blkdevs.c MTD: Fix wrong check register_blkdev return value Revert "mtd: cleanup Kconfig dependencies" mtd: cfi_cmdset_0002: make sector erase command variable mtd: cfi_cmdset_0002: add CFI detection for SST 38VF640x chips mtd: cfi_util: add support for switching SST 39VF640xB chips into QRY mode mtd: cfi_cmdset_0001: use defined value of P_ID_INTEL_PERFORMANCE instead of hardcoded one block2mtd: dubious assignment P4080/mtd: Fix the freescale lbc issue with 36bit mode P4080/eLBC: Make Freescale elbc interrupt common to elbc devices mtd: phram: use KBUILD_MODNAME mtd: OneNAND: S5PC110: Fix double call suspend & resume function mtd: nand: fix MTD_MODE_RAW writes jffs2: use kmemdup mtd: sm_ftl: cosmetic, use bool when possible mtd: r852: remove useless pci powerup/down from suspend/resume routines mtd: blktrans: fix a race vs kthread_stop mtd: blktrans: kill BKL mtd: allow to unload the mtdtrans module if its block devices aren't open ... Fix up trivial whitespace-introduced conflict in drivers/mtd/mtdchar.c
2010-10-30Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git Conflicts: drivers/mtd/mtd_blkdevs.c Merge Grant's device-tree bits so that we can apply the subsequent fixes. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) b43: Fix warning at drivers/mmc/core/core.c:237 in mmc_wait_for_cmd mac80211: fix failure to check kmalloc return value in key_key_read libertas: Fix sd8686 firmware reload ath9k: Fix incorrect access of rate flags in RC netfilter: xt_socket: Make tproto signed in socket_mt6_v1(). stmmac: enable/disable rx/tx in the core with a single write. net: atarilance - flags should be unsigned long netxen: fix kdump pktgen: Limit how much data we copy onto the stack. net: Limit socket I/O iovec total length to INT_MAX. USB: gadget: fix ethernet gadget crash in gether_setup fib: Fix fib zone and its hash leak on namespace stop cxgb3: Fix panic in free_tx_desc() cxgb3: fix crash due to manipulating queues before registration 8390: Don't oops on starting dev queue dccp ccid-2: Stop polling dccp: Refine the wait-for-ccid mechanism dccp: Extend CCID packet dequeueing interface dccp: Return-value convention of hc_tx_send_packet() igbvf: fix panic on load ...
2010-10-29Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdb,ppc: Individual register get/set for ppc kgdbts: prevent re-entry to kgdbts before it unregisters debug_core,x86,blackfin: Clean up hw debug disable API kdb: Fix early debugging crash regression kgdb,arm: fix register dump kdb: fix per_cpu command to remove supress mask kdb: Add kdb kernel module sample
2010-10-29debug_core,x86,blackfin: Clean up hw debug disable APIDongdong Deng
The kgdb_disable_hw_debug() was an architecture specific function for disabling all hardware breakpoints on a per cpu basis when entering the debug core. This patch will remove the weak function kdbg_disable_hw_debug() and change it into a call back which lives with the rest of hw breakpoint call backs in struct kgdb_arch. Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-29readv/writev: do the same MAX_RW_COUNT truncation that read/write doesLinus Torvalds
We used to protect against overflow, but rather than return an error, do what read/write does, namely to limit the total size to MAX_RW_COUNT. This is not only more consistent, but it also means that any broken low-level read/write routine that still keeps counts in 'int' can't break. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (29 commits) braino in internal.h convert simple cases of nfs-related ->get_sb() to ->mount() convert btrfs convert ceph convert gfs2 convert afs convert ecryptfs convert sysfs convert cgroup and cpuset switch get_sb_ns() users switch procfs to ->mount() setting ->proc_mnt doesn't belong in proc_get_sb() convert cifs convert nilfs switch logfs to ->mount() logfs: fix a leak in get_sb logfs get_sb, part 3 logfs get_sb, part 2 logfs get_sb massage, part 1 convert v9fs ...
2010-10-29Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched_stat: Update sched_info_queue/dequeue() code comments sched, cgroup: Fixup broken cgroup movement
2010-10-29switch get_sb_ns() usersAl Viro
2010-10-29convert get_sb_pseudo() usersAl Viro
2010-10-29convert get_sb_nodev() usersAl Viro
2010-10-29convert get_sb_single() usersAl Viro
2010-10-29convert get_sb_mtd() users to ->mount()Al Viro
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29beginning of transtion: ->mount()Al Viro
eventual replacement for ->get_sb() - does *not* get vfsmount, return ERR_PTR(error) or root of subtree to be mounted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29mfd: Factor out WM831x I2C I/O from the core driverMark Brown
In preparation for the addition of SPI support for the WM831x move the I2C specific code into a separate file with a separate Kconfig option so the I2C support can be excluded from the build. Also update the 1133-EV1 PMIC module support for SMDK6410 to use the new symbol. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Voltages and GPIOs platform_data definitions for max8998Lukasz Majewski
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29regulator: max8998 BUCK1/2 internal voltages and indexes definedLukasz Majewski
BUCK1/2 internal voltages and indexes defined in the struct max8998_data max_get_voltage_register now uses index values to chose proper register More generic BUCK1/2 registers names provided Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Support for ICs compliant with max8998Lukasz Majewski
2010-10-29mfd: Adding twl6030 mmc card detect support for MMC1kishore kadiyala
Adding card detect callback function and card detect configuration function for MMC1 Controller on OMAP4. Card detect configuration function does initial configuration of the MMC Control & PullUp-PullDown registers of Phoenix. For MMC1 Controller, card detect interrupt source is twl6030 which is non-gpio. The card detect call back function provides card present/absent status by reading MMC Control register present on twl6030. Since OMAP4 doesn't use any GPIO line as used in OMAP3 for card detect, the suspend/resume initialization which was done in omap_hsmmc_gpio_init previously is moved to the probe thus making it generic for both OMAP3 & OMAP4. Cc: Tony Lindgren <tony@atomide.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add mc13892 support to mc13xxxUwe Kleine-König
mc13892 is the companion PMIC for Freescale's i.MX51. It's similar enough to mc13782 to support it in a single driver. This patch introduces enough compatibility cruft to keep all users of the superseded mc13783 driver unchanged. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Remove deprecated mc13783 functionsUwe Kleine-König
The last user is gone since v2.6.34-rc1~40 Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Allow for bypass of cell resource conflict checkDaniel Drake
The upcoming VIA VX855 MFD driver needs to communicate resources to subdevices where the resources may be claimed by ACPI. Add a flag to mfd_cell to request that resources are not policed. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Declare abx500_remove_ops()Mark Brown
Otherwise sparse warns about a public symbol with no declaration and the compiler can't spot if the callers and users have different signatures for the function. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add basic tps6586x interrupt supportGary King
Add support for enabling and disabling tps6586x subdevice interrupts Signed-off-by: Gary King <gking@nvidia.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Update chip id of 88pm8607Haojian Zhuang
Chipid of 88pm8607 is 0x40 or 0x50. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Align ab8500 with the abx500 interfaceMattias Wallin
This patch makes the ab8500 mixed signal chip expose the same interface for register access as the ab3100, ab3550 and ab5500 chip. The ab8500_read() and ab8500_write() is removed and replaced with abx500_get_register_interruptible() and abx500_set_register_interruptible(). Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mmc: Allow 2 byte requests in 4-bit mode for tmio_mmcYusuke Goda
Adjust the tmio_mmc block size check to accept 2-byte requests in 4-bit mode if the hardware supports it. Tested with the SDHI hardware block included in sh7724. Signed-off-by: Yusuke Goda <yusuke.goda.sx@renesas.com> Signed-off-by: Matt Fleming <matt@console-pimps.org> Acked-by: Magnus Damm <damm@opensource.se> Tested-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mmc: Allow the platform to specify the sh_mmcif get_cd handlerArnd Hannemann
In some platforms (e.g. AP4EVB) the card detect pin of a slot is not directly connected to the sh_mmcif controller, so that polling needs to be used. To overcome the overhead induced by querying the controller on each poll cycle, card detection can be handled in the platform code more efficiently. This patch exposes a get_cd hook for that purpose. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Tested-by: Yusuke Goda <yusuke.goda.sx@renesas.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Allow the platform to specify the sh_mobile_sdhi get_cd handlerArnd Hannemann
On some platforms (e.g. AP4EVB) the card detect pin of a slot is not directly connected to the sdhi hardware, so that polling needs to be used with tmio_mmc and card detection is handled in the platform code. This patch allows to set tmio_mmc capabilities (to pass the MMC_CAP_NEEDS_POLL flag) and exposes a get_cd hook for that purpose. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mmc: Allow the tmio_mmc mfd driver to specify get_cd handlerArnd Hannemann
Some controllers, supported by the tmio_mmc driver do not have the card detect pin of a slot connected, so that polling needs to be used and card detection is handled by other means. This patch exposes a get_cd hook for that purpose. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29rtc: Add MAX8998 rtc driverJoonyoung Shim
This adds support for the RTC provided by the Maxim 8998 chip. This driver was tested on a GONI board by using the rtc-test application from the Documentation/rtc.txt. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add MAX8998 interrupts supportJoonyoung Shim
Use genirq and provide seperated file for interrupts support. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Use i2c_client as an argument on MAX8998 i2c routinesJoonyoung Shim
The MAX8998 chip have regulator and rtc features. The i2c slave address of regulator and rtc is different, so needs each i2c client on i2c operation functions. Also, this patch exports i2c operation functions instead of callback to make easy to read. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29i2c: twl: add register defines for pm master moduleFelipe Balbi
Some modules already need to talk to at least PROTECT_KEY register, while at that, add defines to the entire register space. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29gpio: Add bitmask to block requests to unavailable stmpe GPIOsWolfram Sang
GPIOs on these controller are multi-functional. If you decided to use some of them e.g. as input channels for the ADC, you surely don't want those pins to be reassigned as simple GPIOs (which may be triggered even from userspace via 'export'). Same for the touchscreen controller pins. Since knowledge about the hardware is needed to decide which GPIOs to reserve, let this bitmask be inside platform_data and provide some defines to assist potential users. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Rabin Vincent <rabin.vincent@stericsson.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Move PCF50633 IRQ protoypes where the definitions can see themMark Brown
Fixed warnings about unprototyped global functions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-28regulator: Add option for machine drivers to enable the dummy regulatorMark Brown
Allow machine drivers to explicitly enable the use of the dummy regulator, enabling simpler support for systems with only a few specific supplies visible to software. It is strongly recommended that this is not used on systems with substantial software control over their PMICs, for maximum functionality constrints should be as fully specified as possible. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-28Regulator: LP3972 PMIC regulator driverAxel Lin
This patch adds regulator drivers for National Semiconductors LP3972 PMIC. This LP3972 PMIC controller has 3 DC/DC voltage converters and 5 low drop-out (LDO) regulators. LP3972 PMIC controller uses I2C interface. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-28MAX8952 PMIC Driver Initial ReleaseMyungJoo Ham
MAX8952 PMIC is used to provide voltage output between 770mV - 1400mV with DVS support. In this initial release, users can set voltages for four DVS modes, RAMP delay values, and SYNC frequency. Controlling FPWM/SYNC_MODE/Pull-Down/Ramp Modes and reading CHIP_ID is not supported in this release. If GPIO of EN is not valid in platform data, the driver assumes that it is always-on. If GPIO of VID0 or VID1 is invalid, the driver pulls down VID0 and VID1 to fix DVS mode as 0 and disables DVS support. We assume that V_OUT is capable to provide every voltage from 770mV to 1.40V in 10mV steps although the data sheet has some ambiguity on it. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> -- v2: - Style correction - Can accept platform_data with invalid GPIOs - Removed unnecessary features - Improved error handling Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (841 commits) Staging: brcm80211: fix usage of roundup in structures Staging: bcm: fix up network device reference counting Staging: keucr: fix up US_ macro change staging: brcm80211: brcmfmac: Removed codeversion from firmware filenames. staging: brcm80211: Remove unnecessary header files. staging: brcm80211: Remove unnecessary includes from bcmutils.c staging: brcm80211: Removed unnecessary pktsetprio() function. Staging: brcm80211: remove typedefs.h Staging: brcm80211: remove uintptr typedef usage Staging: hv: remove struct vmbus_channel_interface Staging: hv: remove Open from struct vmbus_channel_interface Staging: hv: storvsc: call vmbus_open directly Staging: hv: netvsc: call vmbus_open directly Staging: hv: channel: export vmbus_open to modules Staging: hv: remove Close from struct vmbus_channel_interface Staging: hv: netvsc: call vmbus_close directly Staging: hv: storvsc: call vmbus_close directly Staging: hv: channel: export vmbus_close to modules Staging: hv: remove SendPacket from struct vmbus_channel_interface Staging: hv: storvsc: call vmbus_sendpacket directly ... Fix up conflicts in drivers/staging/cx25821/cx25821-audio-upstream.c drivers/staging/cx25821/cx25821-audio.h due to warring whitespace cleanups (neither of which were all that great)
2010-10-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (32 commits) sh: intc: switch irq_desc iteration to new active IRQ iterator. sh: fix up cpu hotplug IRQ migration for irq_data changes. sh: oprofile: Make sure the backtrace op is available for timer-fallback. sh64: oprofile: Fix up kernel stack pointer size mismatch. sh: oprofile: Fix up and extend op_name_from_perf_id(). sh: lockless get_user_pages_fast() sh64: _PAGE_SPECIAL support. sound: sh: ctrl_in/outX to __raw_read/writeX conversion. sh: disable deprecated genirq support. sh: update show_interrupts() for irq_data chip lookup. sh: intc: irq_data conversion. sh64: irq_data conversion. sh64: update for IRQ flag handling naming changes. rtc: rtc-rs5c313: ctrl_in/outX to __raw_read/writeX conversion. sh: mach-se: irq_data conversion. input: hp680_ts_input: ctrl_in/outX to __raw_read/writeX conversion. input: jornada680_kbd: ctrl_in/outX to __raw_read/writeX conversion. sh: hd64461: irq_data conversion. sh: mach-x3proto: irq_data conversion. sh: mach-systemh: irq_data conversion. ...
2010-10-28Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) x86: allocate space within a region top-down x86: update iomem_resource end based on CPU physical address capabilities x86/PCI: allocate space from the end of a region, not the beginning PCI: allocate bus resources from the top down resources: support allocating space within a region from the top down resources: handle overflow when aligning start of available area resources: ensure callback doesn't allocate outside available space resources: factor out resource_clip() to simplify find_resource() resources: add a default alignf to simplify find_resource() x86/PCI: MMCONFIG: fix region end calculation PCI: Add support for polling PME state on suspended legacy PCI devices PCI: Export some PCI PM functionality PCI: fix message typo PCI: log vendor/device ID always PCI: update Intel chipset names and defines PCI: use new ccflags variable in Makefile PCI: add PCI_MSIX_TABLE/PBA defines PCI: add PCI vendor id for STmicroelectronics x86/PCI: irq and pci_ids patch for Intel Patsburg DeviceIDs PCI: OLPC: Only enable PCI configuration type override on XO-1 ...
2010-10-28net: Limit socket I/O iovec total length to INT_MAX.David S. Miller
This helps protect us from overflow issues down in the individual protocol sendmsg/recvmsg handlers. Once we hit INT_MAX we truncate out the rest of the iovec by setting the iov_len members to zero. This works because: 1) For SOCK_STREAM and SOCK_SEQPACKET sockets, partial writes are allowed and the application will just continue with another write to send the rest of the data. 2) For datagram oriented sockets, where there must be a one-to-one correspondance between write() calls and packets on the wire, INT_MAX is going to be far larger than the packet size limit the protocol is going to check for and signal with -EMSGSIZE. Based upon a patch by Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-28dccp: Extend CCID packet dequeueing interfaceGerrit Renker
This extends the packet dequeuing interface of dccp_write_xmit() to allow 1. CCIDs to take care of timing when the next packet may be sent; 2. delayed sending (as before, with an inter-packet gap up to 65.535 seconds). The main purpose is to take CCID-2 out of its polling mode (when it is network- limited, it tries every millisecond to send, without interruption). The mode of operation for (2) is as follows: * new packet is enqueued via dccp_sendmsg() => dccp_write_xmit(), * ccid_hc_tx_send_packet() detects that it may not send (e.g. window full), * it signals this condition via `CCID_PACKET_WILL_DEQUEUE_LATER', * dccp_write_xmit() returns without further action; * after some time the wait-condition for CCID becomes true, * that CCID schedules the tasklet, * tasklet function calls ccid_hc_tx_send_packet() via dccp_write_xmit(), * since the wait-condition is now true, ccid_hc_tx_packet() returns "send now", * packet is sent, and possibly more (since dccp_write_xmit() loops). Code reuse: the taskled function calls dccp_write_xmit(), the timer function reduces to a wrapper around the same code. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-28Merge 'staging-next' to Linus's treeGreg Kroah-Hartman
This merges the staging-next tree to Linus's tree and resolves some conflicts that were present due to changes in other trees that were affected by files here. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (505 commits) [media] af9015: Fix max I2C message size when used with tda18271 [media] IR: initialize ir_raw_event in few more drivers [media] Guard a divide in v4l1 compat layer [media] imon: fix nomouse modprobe option [media] imon: remove redundant change_protocol call [media] imon: fix my egregious brown paper bag w/rdev/idev split [media] cafe_ccic: Configure ov7670 correctly [media] ov7670: allow configuration of image size, clock speed, and I/O method [media] af9015: support for DigitalNow TinyTwin v3 [1f4d:9016] [media] af9015: map DigitalNow TinyTwin v2 remote [media] DigitalNow TinyTwin remote controller [media] af9015: RC fixes and improvements videodev2.h.xml: Update to reflect the latest changes at videodev2.h [media] v4l: document new Bayer and monochrome pixel formats [media] DocBook/v4l: Add missing formats used on gspca cpia1 and sn9c2028 [media] firedtv: add parameter to fake ca_system_ids in CA_INFO [media] tm6000: fix a macro coding style issue tm6000: Remove some ugly debug code [media] Nova-S-Plus audio line input [media] [RFC,1/1] V4L2: Use new CAP bits in existing RDS capable drivers ...
2010-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (66 commits) mmc: add new sdhci-pxa driver for Marvell SoCs mmc: make number of mmcblk minors configurable mmc_spi: Recover from CRC errors for r/w operation over SPI. mmc: sdhci-pltfm: add -pltfm driver for imx35/51 mmc: sdhci-of-esdhc: factor out common stuff mmc: sdhci_pltfm: pass more data on custom init call mmc: sdhci: introduce get_ro private write-protect hook mmc: sdhci-pltfm: move .h file into appropriate subdir mmc: sdhci-pltfm: Add structure for host-specific data mmc: fix cb710 kconfig dependency warning mmc: cb710: remove debugging printk (info duplicated from mmc-core) mmc: cb710: clear irq handler on init() error path mmc: cb710: remove unnecessary msleep() mmc: cb710: implement get_cd() callback mmc: cb710: partially demystify clock selection mmc: add a file to debugfs for changing host clock at runtime mmc: sdhci: allow for eMMC 74 clock generation by controller mmc: sdhci: highspeed: check for mmc as well as sd cards mmc: sdhci: Add Moorestown device support mmc: sdhci: Intel Medfield support ...
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: (28 commits) net/9p: Return error on read with NULL buffer 9p: Add datasync to client side TFSYNC/RFSYNC for dotl net/9p: Return error if we fail to encode protocol data fs/9p: Use generic_file_open with lookup_instantiate_filp fs/9p: Add missing iput in v9fs_vfs_lookup fs/9p: Use mknod 9p operation on create without open request net/9p: Add waitq to VirtIO transport. [net/9p]Serialize virtqueue operations to make VirtIO transport SMP safe. 9p: Implement TREADLINK operation for 9p2000.L 9p: Use V9FS_MAGIC in statfs 9p: Implement TGETLOCK 9p: Implement TLOCK [9p] Introduce client side TFSYNC/RFSYNC for dotl. [fs/9p] Add file_operations for cached mode in dotl protocol. fs/9p: Add access = client option to opt in acl evaluation. fs/9p: Implement create time inheritance fs/9p: Update ACL on chmod fs/9p: Implement setting posix acl fs/9p: Add xattr callbacks for POSIX ACL fs/9p: Implement POSIX ACL permission checking function ...
