path: root/include/linux
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-03Remove long-unmaintained ftape driver subsystem.Jeff Garzik
It's bitrotten, long unmaintained, long hidden under BROKEN_ON_SMP, etc. As scheduled in feature-removal-schedule.txt, and ack'd several times on lkml. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[XFRM]: Fix aevent structuring to be more complete.Jamal Hadi Salim
aevents can not uniquely identify an SA. We break the ABI with this patch, but consensus is that since it is not yet utilized by any (known) application then it is fine (better do it now than later). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack/nf_nat: add TFTP helper portPatrick McHardy
Add IPv4 and IPv6 capable nf_conntrack port of the TFTP conntrack/NAT helper. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack/nf_nat: add SIP helper portPatrick McHardy
Add IPv4 and IPv6 capable nf_conntrack port of the SIP conntrack/NAT helper. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack/nf_nat: add PPTP helper portPatrick McHardy
Add nf_conntrack port of the PPtP conntrack/NAT helper. Since there seems to be no IPv6-capable PPtP implementation the helper only support IPv4. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack/nf_nat: add IRC helper portPatrick McHardy
Add nf_conntrack port of the IRC conntrack/NAT helper. Since DCC doesn't support IPv6 yet, the helper is still IPv4 only. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack/nf_nat: add H.323 helper portPatrick McHardy
Add IPv4 and IPv6 capable nf_conntrack port of the H.323 conntrack/NAT helper. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack/nf_nat: add amanda helper portPatrick McHardy
Add IPv4 and IPv6 capable nf_conntrack port of the Amanda conntrack/NAT helper. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_nat: add FTP NAT helper portJozsef Kadlecsik
Add FTP NAT helper. Split out from Jozsef's big nf_nat patch with a few small fixes by myself. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: Add NAT support for nf_conntrackJozsef Kadlecsik
Add NAT support for nf_conntrack. Joint work of Jozsef Kadlecsik, Yasuyuki Kozakai, Martin Josefsson and myself. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Accept wildcard delimiters in in[46]_ptonPatrick McHardy
Accept -1 as delimiter to abort parsing without an error at the first unknown character. This is needed by the upcoming nf_conntrack SIP helper, where addresses are delimited by either '\r' or '\n' characters. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[EBTABLES]: Split ebt_replace into user and kernel variants, annotate.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: ebtables: add --snap-arp optionBart De Schuymer
The attached patch adds --snat-arp support, which makes it possible to change the source mac address in both the mac header and the arp header with one rule. Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: x_tables: add NFLOG targetPatrick McHardy
Add new NFLOG target to allow use of nfnetlink_log for both IPv4 and IPv6. Currently we have two (unsupported by userspace) hacks in the LOG and ULOG targets to optionally call to the nflog API. They lack a few features, namely the IPv4 and IPv6 LOG targets can not specify a number of arguments related to nfnetlink_log, while the ULOG target is only available for IPv4. Remove those hacks and add a clean way to use nfnetlink_log. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: x_tables: add port of hashlimit match for IPv4 and IPv6Patrick McHardy
2006-12-02[NETFILTER]: nfnetlink_log: remove useless prefix length limitationPatrick McHardy
There is no reason for limiting netlink attributes in size. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nfnetlink_queue: allow changing queue length through netlinkEric Leblond
Signed-off-by: Eric Leblond <eric@inl.fr> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: sip conntrack: better NAT handlingPatrick McHardy
The NAT handling of the SIP helper has a few problems: - Request headers are only mangled in the reply direction, From/To headers not at all, which can lead to authentication failures with DNAT in case the authentication domain is the IP address - Contact headers in responses are only mangled for REGISTER responses - Headers may be mangled even though they contain addresses not participating in the connection, like alternative addresses - Packets are droppen when domain names are used where the helper expects IP addresses This patch takes a different approach, instead of fixed rules what field to mangle to what content, it adds symetric mapping of From/To/Via/Contact headers, which allows to deal properly with echoed addresses in responses and foreign addresses not belonging to the connection. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: sip conntrack: do case insensitive SIP header searchPatrick McHardy
SIP headers are generally case-insensitive, only SDP headers are case sensitive. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: sip conntrack: minor cleanupPatrick McHardy
- Use enum for header field enumeration - Use numerical value instead of pointer to header info structure to identify headers, unexport ct_sip_hdrs - group SIP and SDP entries in header info structure - remove double forward declaration of ct_sip_get_info Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: conntrack: add '_get' to {ip, nf}_conntrack_expect_findYasuyuki Kozakai
We usually uses 'xxx_find_get' for function which increments reference count. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: automatic sysctl registation for conntrack protocolsPatrick McHardy
Add helper functions for sysctl registration with optional instantiating of common path elements (like net/netfilter) and use it for support for automatic registation of conntrack protocol sysctls. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[DCCP]: Tidy up unused structuresGerrit Renker
This removes and cleans up unused variables and structures which have become unnecessary following the introduction of the EWMA patch to automatically track the CCID 3 receiver/sender packet sizes `s'. It deprecates the PACKET_SIZE socket option by returning an error code and printing a deprecation warning if an application tries to read or write this socket option. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[DCCP]: Remove allocation of sysctl numbersGerrit Renker
This is in response to a request sent earlier by Eric W. Biederman and replaces all sysctl numbers for net.dccp.default with CTL_UNNUMBERED. It has been tested to compile and to work. Commiter note: I've removed the use of CTL_UNNUMBERED, not setting .ctl_name sets it to 0, that is the what CTL_UNNUMBERED is, reason is to avoid unneeded source code cluttering. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[TCP]: Renove the __ prefix on the struct tcp_sock membersArnaldo Carvalho de Melo
As this struct is not userland visible at all. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[TCP]: Change tcp_header_len member in tcp_sock to u16Arnaldo Carvalho de Melo
With this we eliminate the last hole in struct tcp_sock. End result: [acme@newtoy net-2.6.20]$ codiff -sV /tmp/tcp.o.before net/ipv4/tcp.o /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ipv4/tcp.c: struct tcp_sock | -4 tcp_header_len; from: int /* 1000(0) 4(0) */ to: u16 /* 1000(0) 2(0) */ 1 struct changed [acme@newtoy net-2.6.20]$ Now sizeof(tcp_sock) is just... [acme@newtoy net-2.6.20]$ pahole --sizes ../OUTPUT/qemu/net-2.6.20/net/ipv4/tcp.o | grep -w tcp_sock struct tcp_sock: 1500 0 1500 bytes ;-) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[NET]: Pack struct hh_cacheArnaldo Carvalho de Melo
[acme@newtoy net-2.6.20]$ pahole net/ipv4/tcp.o hh_cache /* /pub/scm/linux/kernel/git/acme/net-2.6.20/include/linux/netdevice.h:190 */ struct hh_cache { struct hh_cache * hh_next; /* 0 4 */ atomic_t hh_refcnt; /* 4 4 */ __be16 hh_type; /* 8 2 */ /* XXX 2 bytes hole, try to pack */ int hh_len; /* 12 4 */ int (*hh_output)(); /* 16 4 */ rwlock_t hh_lock; /* 20 36 */ long unsigned int hh_data[24]; /* 56 96 */ }; /* size: 152, sum members: 150, holes: 1, sum holes: 2 */ [acme@newtoy net-2.6.20]$ find net -name "*.[ch]" | xargs grep 'hh_len.\+=' | sort -u net/atm/br2684.c: hh->hh_len = PADLEN + ETH_HLEN; net/ethernet/eth.c: hh->hh_len = ETH_HLEN; net/ipv4/ipconfig.c: int hh_len = LL_RESERVED_SPACE(dev); net/ipv4/ip_output.c: hh_len = LL_RESERVED_SPACE(rt->u.dst.dev); net/ipv4/ip_output.c: int hh_len = LL_RESERVED_SPACE(dev); net/ipv4/netfilter.c: hh_len = (*pskb)->dst->dev->hard_header_len; net/ipv4/raw.c: hh_len = LL_RESERVED_SPACE(rt->u.dst.dev); net/ipv6/ip6_output.c: hh_len = LL_RESERVED_SPACE(rt->u.dst.dev); net/ipv6/netfilter/ip6t_REJECT.c: hh_len = (dst->dev->hard_header_len + 15)&~15; net/ipv6/raw.c: hh_len = LL_RESERVED_SPACE(rt->u.dst.dev); [acme@newtoy net-2.6.20]$ [acme@newtoy net-2.6.20]$ find include -name "*.h" | xargs grep 'define ETH_HLEN' include/linux/if_ether.h:#define ETH_HLEN 14 /* Total octets in header. */ (((dev)->hard_header_len&~(HH_DATA_MOD - 1)) + HH_DATA_MOD) [acme@newtoy net-2.6.20]$ pahole net/ipv4/tcp.o net_device | grep hard_header_len short unsigned int hard_header_len; /* 106 2 */ [acme@newtoy net-2.6.20]$ So I think we're safe in turning hh_len an u16, end result: [acme@newtoy net-2.6.20]$ codiff -sV /tmp/tcp.o.before net/ipv4/tcp.o /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ipv4/tcp.c: struct hh_cache | -4 hh_len; from: int /* 12(0) 4(0) */ to: u16 /* 10(0) 2(0) */ 1 struct changed [acme@newtoy net-2.6.20]$ Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[RTNETLINK]: Add rtnl_put_cacheinfo() to unify some codeThomas Graf
IPv4, IPv6, and DECNet all use struct rta_cacheinfo in a similiar way, therefore rtnl_put_cacheinfo() is added to reuse code. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETLINK]: Remove unused dst_pid field in netlink_skb_parmsThomas Graf
The destination PID is passed directly to netlink_unicast() respectively netlink_multicast(). Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Add documentation for TFRC structuresGerrit Renker
This adds documentation for the TFRC structure fields. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[NET]: Split skb->csumAl Viro
... into anonymous union of __wsum and __u32 (csum and csum_offset resp.) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Netfilter sctp annotations.Al Viro
2006-12-02[SCTP]: Annotate SCTP headers.Al Viro
2006-12-02[DCCP]: Adds the tx buffer sysctlsIan McDonald
This one got lost on the way from Ian to Gerrit to me, fix it. Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[BNX2]: Add 5709 PCI ID.Michael Chan
Add PCI ID and detection for 5709 copper and SerDes chips. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Preliminaty annotation of skb->csum.Al Viro
It's still not completely right; we need to split it into anon unions of __wsum and unsigned - for cases when we use it for partial checksum and for offset of checksum in skb Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: netfilter checksum annotationsAl Viro
2006-12-02[NET]: Annotate __skb_checksum_complete() and friends.Al Viro
2006-12-02[NET]: Annotate skb_copy_and_csum_bits() and callers.Al Viro
2006-12-02[NET]: Annotate skb_checksum() and callers.Al Viro
2006-12-02[NET]: Annotate callers of csum_partial_copy_...() and csum_and_copy...() in ↵Al Viro
net/* Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate csum_partial() callers in net/*Al Viro
2006-12-02[NET]: Annotate checksums in on-the-wire packets.Al Viro
2006-12-02[NET]: Introduce types for checksums.Al Viro
New types - for 16bit checksums and "unfolded" 32bit variant. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate net_srandom().Al Viro
2006-12-02[BRIDGE]: Annotations.Al Viro
2006-12-02[ATM]: Annotations.Al Viro
2006-12-02[NETFILTER]: More trivial annotations.Al Viro
2006-12-02[RANDOM]: Annotate random.h IP helpers.Al Viro
