path: root/include/linux
2012-07-28acpi: add a way to promote/demote vendor backlight driversCorentin Chary
Instead of adding a big blacklist in video_detect.c to set ACPI_VIDEO_BACKLIGHT_DMI_VENDOR correctly, let external modules promote or demote themselves when they know the generic video module won't work. Currently drivers where using acpi_video_unregister() directly but: - That didn't respect any acpi_backlight=[video|vendor] parameter provided by the user. - Any later call to acpi_video_register() would still re-load the generic video module (and some gpu drivers are doing that). This patch fix those two issues. Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2012-07-26Merge tag 'gpio-for-v3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO changes from Linus Walleij: - New driver for AMD-8111 southbridge GPIOs - New driver for Wolfson Micro Arizona devices - Propagate device tree parse errors - Probe deferral finalizations - all expected calls to GPIO will now hopefully request deferral where apropriate - Misc updates to TCA6424, WM8994, LPC32xx, PCF857x, Samsung MXC, OMAP and PCA953X drivers. Fix up gpio_idx conflicts in drivers/gpio/gpio-mxc.c * tag 'gpio-for-v3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio: of_get_named_gpio_flags() return -EPROBE_DEFER if GPIO not yet available gpiolib: Defer failed gpio requests by default MAINTAINERS: add entry OMAP GPIO driver gpio/pca953x: increase variables size to support 24 bit of data GPIO: PCA953X: Increase size of invert variable to support 24 bit gpio/omap: move bank->dbck initialization to omap_gpio_mod_init() gpio/mxc: use the edge_sel feature if available gpio: propagate of_parse_phandle_with_args errors gpio: samsung: add flags specifier to device-tree binding gpiolib: Add support for Wolfson Microelectronics Arizona class devices gpio: gpio-lpc32xx: Add gpio_to_irq mapping gpio: pcf857x: share 8/16 bit access functions gpio: LPC32xx: Driver cleanup MAINTAINERS: Add Wolfson gpiolib drivers to the Wolfson entry gpiolib: wm8994: Convert to devm_kzalloc() gpiolib: wm8994: Use irq_domain mappings for gpios gpio: add a driver for GPIO pins found on AMD-8111 south bridge chips gpio/tca6424: merge I2C transactions, remove cast gpio/of: fix a typo of comment message
2012-07-26posix_types.h: Cleanup stale __NFDBITS and related definitionsJosh Boyer
Recently, glibc made a change to suppress sign-conversion warnings in FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the kernel's definition of __NFDBITS if applications #include <linux/types.h> after including <sys/select.h>. A build failure would be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2 flags to gcc. It was suggested that the kernel should either match the glibc definition of __NFDBITS or remove that entirely. The current in-kernel uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no uses of the related __FDELT and __FDMASK defines. Given that, we'll continue the cleanup that was started with commit 8b3d1cda4f5f ("posix_types: Remove fd_set macros") and drop the remaining unused macros. Additionally, linux/time.h has similar macros defined that expand to nothing so we'll remove those at the same time. Reported-by: Jeff Law <law@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> CC: <stable@vger.kernel.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> [ .. and fix up whitespace as per akpm ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-26Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pul x86/efi changes from Ingo Molnar: "This tree adds an EFI bootloader handover protocol, which, once supported on the bootloader side, will make bootup faster and might result in simpler bootloaders. The other change activates the EFI wall clock time accessors on x86-64 as well, instead of the legacy RTC readout." * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, efi: Handover Protocol x86-64/efi: Use EFI to deal with platform wall clock
2012-07-26Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The biggest change is a performance improvement on SMP systems: | 4 socket 40 core + SMT Westmere box, single 30 sec tbench | runs, higher is better: | | clients 1 2 4 8 16 32 64 128 |.......................................................................... | pre 30 41 118 645 3769 6214 12233 14312 | post 299 603 1211 2418 4697 6847 11606 14557 | | A nice increase in performance. which speedup is particularly noticeable on heavily interacting few-tasks workloads, so the changes should help desktop-style Xorg workloads and interactivity as well, on multi-core CPUs. There are also cpuset suspend behavior fixes/restructuring and various smaller tweaks." * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix race in task_group() sched: Improve balance_cpu() to consider other cpus in its group as target of (pinned) task sched: Reset loop counters if all tasks are pinned and we need to redo load balance sched: Reorder 'struct lb_env' members to reduce its size sched: Improve scalability via 'CPU buddies', which withstand random perturbations cpusets: Remove/update outdated comments cpusets, hotplug: Restructure functions that are invoked during hotplug cpusets, hotplug: Implement cpuset tree traversal in a helper function CPU hotplug, cpusets, suspend: Don't modify cpusets during suspend/resume sched/x86: Remove broken power estimation
2012-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto updates from Herbert Xu: - Fixed algorithm construction hang when self-test fails. - Added SHA variants to talitos AEAD list. - New driver for Exynos random number generator. - Performance enhancements for arc4. - Added hwrng support to caam. - Added ahash support to caam. - Fixed bad kfree in aesni-intel. - Allow aesni-intel in FIPS mode. - Added atmel driver with support for AES/3DES/SHA. - Bug fixes for mv_cesa. - CRC hardware driver for BF60x family processors. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (66 commits) crypto: twofish-avx - remove useless instruction crypto: testmgr - add aead cbc aes hmac sha1,256,512 test vectors crypto: talitos - add sha224, sha384 and sha512 to existing AEAD algorithms crypto: talitos - export the talitos_submit function crypto: talitos - move talitos structures to header file crypto: atmel - add new tests to tcrypt crypto: atmel - add Atmel SHA1/SHA256 driver crypto: atmel - add Atmel DES/TDES driver crypto: atmel - add Atmel AES driver ARM: AT91SAM9G45: add crypto peripherals crypto: testmgr - allow aesni-intel and ghash_clmulni-intel in fips mode hwrng: exynos - Add support for Exynos random number generator crypto: aesni-intel - fix wrong kfree pointer crypto: caam - ERA retrieval and printing for SEC device crypto: caam - Using alloc_coherent for caam job rings crypto: algapi - Fix hang on crypto allocation crypto: arc4 - now arc needs blockcipher support crypto: caam - one tasklet per job ring crypto: caam - consolidate memory barriers from job ring en/dequeue crypto: caam - only query h/w in job ring dequeue path ...
2012-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input layer updates from Dmitry Torokhov: "First set of updates for the input subsystem. You will get a new touchscreen driver (Melfas mms114), a new keypad driver for LPC32xx SoC, large update to Atmel mXT touchscreen driver, a lot of drivers acquired device tree support and a slew of other fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (57 commits) Input: add MELFAS mms114 touchscreen driver Input: add support for key scan interface of the LPC32xx SoC Input: omap4-keypad - add device tree support Input: hanwang - add support for Art Master II tablet Input: spear_keyboard - reconfigure operating frequency on suspend Input: spear_keyboard - fix clock handling during suspend/resume Input: ff-memless - fix a couple min_t() casts Input: synaptics - print firmware ID and board number at init Input: spear_keyboard - generalize keyboard frequency configuration Input: spear_keyboard - rename bit definitions to reflect register Input: spear_keyboard - use correct io accessors Input: spear-keyboard - fix disable device_init_wakeup in remove Input: wacom_i2c - fix compiler warning Input: imx_keypad - check error returned by clk_prepare_enable() Input: imx_keypad - adapt the new kpp clock name Input: imx_keypad - use clk_prepare_enable/clk_disable_unprepare() Input: ad7879 - add option to correct xy axis Input: synaptics_usb - Remove TrackPoint name trailing whitespace Revert "Input: atmel_mxt_ts - warn if sysfs could not be created" Input: MT - Include win8 support ...
2012-07-26Merge tag 'spi-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/misc Pull spi updates from Mark Brown: "Since Grant is even more specacularly busy than usual for the time being I've been collecting SPI patches for him for this release - probably things will revert back to Grant before the next release. There's nothing too exciting here, mostly it's simple driver specific stuff: - Add spi: to the modaliases of SPI devices to provide namespacing. - A driver for AD-FMCOMMS1-EBZ. - DT binding for Orion. - Fixes and cleanups for i.MX, PL0022, OMAP and bitbang drivers. There may be a few more fixes I've missed, people keep sending me new things." * tag 'spi-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/misc: spi/orion: remove uneeded spi_info spi/bcm63xx: fix clock configuration selection spi/orion: add device tree binding spi/omap2: mark omap2_mcspi_master_setup as __devinit spi: omap2-mcspi: Fix the below warning spi: Add AD-FMCOMMS1-EBZ I2C-SPI bridge driver spi/imx: use gpio_is_valid to determine if a gpio is valid spi/imx: remove redundant config.speed_hz setting spi/gpio: start with CS non-active spi: tegra: use dmaengine based dma driver spi/pl022: cleanup pl022 header documentation spi/pl022: enable runtime PM spi/pl022: delete DB5500 support spi/pl022: disable port when unused spi: Add "spi:" prefix to modalias attribute of spi devices
2012-07-26Merge tag 'driver-core-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core changes from Greg Kroah-Hartman: "Here's the big driver core pull request for 3.6-rc1. Unlike 3.5, this kernel should be a lot tamer, with the printk changes now settled down. All we have here is some extcon driver updates, w1 driver updates, a few printk cleanups that weren't needed for 3.5, but are good to have now, and some other minor fixes/changes in the driver core. All of these have been in the linux-next releases for a while now. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'driver-core-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits) printk: Export struct log size and member offsets through vmcoreinfo Drivers: hv: Change the hex constant to a decimal constant driver core: don't trigger uevent after failure extcon: MAX77693: Add extcon-max77693 driver to support Maxim MAX77693 MUIC device sysfs: fail dentry revalidation after namespace change fix sysfs: fail dentry revalidation after namespace change extcon: spelling of detach in function doc extcon: arizona: Stop microphone detection if we give up on it extcon: arizona: Update cable reporting calls and split headset PM / Runtime: Do not increment device usage counts before probing kmsg - do not flush partial lines when the console is busy kmsg - export "continuation record" flag to /dev/kmsg kmsg - avoid warning for CONFIG_PRINTK=n compilations kmsg - properly print over-long continuation lines driver-core: Use kobj_to_dev instead of re-implementing it driver-core: Move kobj_to_dev from genhd.h to device.h driver core: Move deferred devices to the end of dpm_list before probing driver core: move uevent call to driver_register driver core: fix shutdown races with probe/remove(v3) Extcon: Arizona: Add driver for Wolfson Arizona class devices ...
2012-07-26Merge tag 'staging-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging tree patches from Greg Kroah-Hartman: "Here's the big staging tree merge for the 3.6-rc1 merge window. There are some patches in here outside of drivers/staging/, notibly the iio code (which is still stradeling the staging / not staging boundry), the pstore code, and the tracing code. All of these have gotten acks from the various subsystem maintainers to be included in this tree. The pstore and tracing patches are related, and are coming here as they replace one of the android staging drivers. Otherwise, the normal staging mess. Lots of cleanups and a few new drivers (some iio drivers, and the large csr wireless driver abomination.) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/staging/comedi/drivers/s626.h and drivers/staging/gdm72xx/netlink_k.c * tag 'staging-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1108 commits) staging: csr: delete a bunch of unused library functions staging: csr: remove csr_utf16.c staging: csr: remove csr_pmem.h staging: csr: remove CsrPmemAlloc staging: csr: remove CsrPmemFree() staging: csr: remove CsrMemAllocDma() staging: csr: remove CsrMemCalloc() staging: csr: remove CsrMemAlloc() staging: csr: remove CsrMemFree() and CsrMemFreeDma() staging: csr: remove csr_util.h staging: csr: remove CsrOffSetOf() stating: csr: remove unneeded #includes in csr_util.c staging: csr: make CsrUInt16ToHex static staging: csr: remove CsrMemCpy() staging: csr: remove CsrStrLen() staging: csr: remove CsrVsnprintf() staging: csr: remove CsrStrDup staging: csr: remove CsrStrChr() staging: csr: remove CsrStrNCmp staging: csr: remove CsrStrCmp ...
2012-07-26Merge tag 'usb-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg Kroah-Hartman: "Here's the big USB patch set for the 3.6-rc1 merge window. Lots of little changes in here, primarily for gadget controllers and drivers. There's some scsi changes that I think also went in through the scsi tree, but they merge just fine. All of these patches have been in the linux-next tree for a while now. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up trivial conflicts in include/scsi/scsi_device.h (same libata conflict that Jeff had already encountered) * tag 'usb-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (207 commits) usb: Add USB_QUIRK_RESET_RESUME for all Logitech UVC webcams usb: Add quirk detection based on interface information usb: s3c-hsotg: Add header file protection macros in s3c-hsotg.h USB: ehci-s5p: Add vbus setup function to the s5p ehci glue layer USB: add USB_VENDOR_AND_INTERFACE_INFO() macro USB: notify phy when root hub port connect change USB: remove 8 bytes of padding from usb_host_interface on 64 bit builds USB: option: add ZTE MF821D USB: sierra: QMI mode MC7710 moved to qcserial USB: qcserial: adding Sierra Wireless devices USB: qcserial: support generic Qualcomm serial ports USB: qcserial: make probe more flexible USB: qcserial: centralize probe exit path USB: qcserial: consolidate usb_set_interface calls USB: ehci-s5p: Add support for device tree USB: ohci-exynos: Add support for device tree USB: ehci-omap: fix compile failure(v1) usb: host: tegra: pass correct pointer in ehci_setup() USB: ehci-fsl: Update ifdef check to work on 64-bit ppc USB: serial: keyspan: Removed unrequired parentheses. ...
2012-07-25Merge branch 'master' [vanilla Linus master] into libata-dev.git/upstreamJeff Garzik
Two bits were appended to the end of the bitfield list in struct scsi_device. Resolve that conflict by including both bits. Conflicts: include/scsi/scsi_device.h
2012-07-24Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull first round of SCSI updates from James Bottomley: "The most important feature of this patch set is the new async infrastructure that makes sure async_synchronize_full() synchronizes all domains and allows us to remove all the hacks (like having scsi_complete_async_scans() in the device base code) and means that the async infrastructure will "just work" in future. The rest is assorted driver updates (aacraid, bnx2fc, virto-scsi, megaraid, bfa, lpfc, qla2xxx, qla4xxx) plus a lot of infrastructure work in sas and FC. Signed-off-by: James Bottomley <JBottomley@Parallels.com>" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (97 commits) [SCSI] Revert "[SCSI] fix async probe regression" [SCSI] cleanup usages of scsi_complete_async_scans [SCSI] queue async scan work to an async_schedule domain [SCSI] async: make async_synchronize_full() flush all work regardless of domain [SCSI] async: introduce 'async_domain' type [SCSI] bfa: Fix to set correct return error codes and misc cleanup. [SCSI] aacraid: Series 7 Async. (performance) mode support [SCSI] aha152x: Allow use on 64bit systems [SCSI] virtio-scsi: Add vdrv->scan for post VIRTIO_CONFIG_S_DRIVER_OK LUN scanning [SCSI] bfa: squelch lockdep complaint with a spin_lock_init [SCSI] qla2xxx: remove unnecessary reads of PCI_CAP_ID_EXP [SCSI] qla4xxx: remove unnecessary read of PCI_CAP_ID_EXP [SCSI] ufs: fix incorrect return value about SUCCESS and FAILED [SCSI] ufs: reverse the ufshcd_is_device_present logic [SCSI] ufs: use module_pci_driver [SCSI] usb-storage: update usb devices for write cache quirk in quirk list. [SCSI] usb-storage: add support for write cache quirk [SCSI] set to WCE if usb cache quirk is present. [SCSI] virtio-scsi: hotplug support for virtio-scsi [SCSI] virtio-scsi: split scatterlist per target ...
2012-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmwLinus Torvalds
Pull GFS2 updates from Steven Whitehouse. * git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw: GFS2: Eliminate 64-bit divides GFS2: Reduce file fragmentation GFS2: kernel panic with small gfs2 filesystems - 1 RG GFS2: Fixing double brelse'ing bh allocated in gfs2_meta_read when EIO occurs GFS2: Combine functions get_local_rgrp and gfs2_inplace_reserve GFS2: Add kobject release method GFS2: Size seq_file buffer more carefully GFS2: Use seq_vprintf for glocks debugfs file seq_file: Add seq_vprintf function and export it GFS2: Use lvbs for storing rgrp information with mount option GFS2: Cache last hash bucket for glock seq_files GFS2: Increase buffer size for glocks and glstats debugfs files GFS2: Fix error handling when reading an invalid block from the journal GFS2: Add "top dir" flag support GFS2: Fold quota data into the reservations struct GFS2: Extend the life of the reservations
2012-07-24Merge branch 'for-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: "Nothing too interesting. A minor bug fix and some cleanups." * 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: Update remount documentation cgroup: cgroup_rm_files() was calling simple_unlink() with the wrong inode cgroup: Remove populate() documentation cgroup: remove hierarchy_mutex
2012-07-24Merge branch 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "There are three major changes. - WQ_HIGHPRI has been reimplemented so that high priority work items are served by worker threads with -20 nice value from dedicated highpri worker pools. - CPU hotplug support has been reimplemented such that idle workers are kept across CPU hotplug events. This makes CPU hotplug cheaper (for PM) and makes the code simpler. - flush_kthread_work() has been reimplemented so that a work item can be freed while executing. This removes an annoying behavior difference between kthread_worker and workqueue." * 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix spurious CPU locality WARN from process_one_work() kthread_worker: reimplement flush_kthread_work() to allow freeing the work item being executed kthread_worker: reorganize to prepare for flush_kthread_work() reimplementation workqueue: simplify CPU hotplug code workqueue: remove CPU offline trustee workqueue: don't butcher idle workers on an offline CPU workqueue: reimplement CPU online rebinding to handle idle workers workqueue: drop @bind from create_worker() workqueue: use mutex for global_cwq manager exclusion workqueue: ROGUE workers are UNBOUND workers workqueue: drop CPU_DYING notifier operation workqueue: perform cpu down operations from low priority cpu_notifier() workqueue: reimplement WQ_HIGHPRI using a separate worker_pool workqueue: introduce NR_WORKER_POOLS and for_each_worker_pool() workqueue: separate out worker_pool flags workqueue: use @pool instead of @gcwq or @cpu where applicable workqueue: factor out worker_pool from global_cwq workqueue: don't use WQ_HIGHPRI for unbound workqueues
2012-07-24Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine update from Vinod Koul: "This time we have a new dmaengine driver from the tegra folks. Also we have Guennadi's cleanup of sh drivers which incudes a library for sh drivers. And the usual odd fixes in bunch of drivers and some nice cleanup of dw_dmac from Andy." Fix up conflicts in drivers/mmc/host/sh_mmcif.c * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (46 commits) dmaengine: Cleanup logging messages mmc: sh_mmcif: switch to the new DMA channel allocation and configuration dma: sh: provide a migration path for slave drivers to stop using .private dma: sh: use an integer slave ID to improve API compatibility dmaengine: shdma: prepare to stop using struct dma_chan::private sh: remove unused DMA device pointer from SIU platform data ASoC: siu: don't use DMA device for channel filtering dmaengine: shdma: (cosmetic) simplify a static function dmaengine: at_hdmac: add a few const qualifiers dw_dmac: use 'u32' for LLI structure members, not dma_addr_t dw_dmac: mark dwc_dump_lli inline dma: mxs-dma: Export missing symbols from mxs-dma.c dma: shdma: convert to the shdma base library ASoC: fsi: prepare for conversion to the shdma base library usb: renesas_usbhs: prepare for conversion to the shdma base library ASoC: siu: prepare for conversion to the shdma base library serial: sh-sci: prepare for conversion to the shdma base library mmc: sh_mobile_sdhi: prepare for conversion to the shdma base library mmc: sh_mmcif: remove unneeded struct sh_mmcif_dma, prepare to shdma conversion dma: shdma: prepare for conversion to the shdma base library ...
2012-07-24Merge tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linuxLinus Torvalds
Pull common clk framework changes from Michael Turquette: "This includes a small number of core framework improvments, platform ports and new DT bindings." Fix up trivial conflicts in drivers/clk/Makefile * tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linux: (21 commits) clk: fix compile for OF && !COMMON_CLK clk: fix clk_get on of_clk_get_by_name return check clk: mxs: clk_register_clkdev mx28 usb clocks clk: add highbank clock support dt: add clock binding doc to primecell bindings clk: add DT fixed-clock binding support clk: add DT clock binding support ARM: integrator: convert to common clock clk: add versatile ICST307 driver ARM: integrator: put symbolic bus names on devices ARM: u300: convert to common clock clk: cache parent clocks only for muxes clk: wm831x: Add initial WM831x clock driver clk: Constify struct clk_init_data clk: Add CLK_IS_BASIC flag to identify basic clocks clk: Add support for rate table based dividers clk: Add support for power of two type dividers clk: mxs: imx28: decrease the frequency of ref_io1 for SSP2 and SSP3 clk: mxs: add clkdev lookup for pwm clk: mxs: Fix the GPMI clock name ...
2012-07-24Merge tag 'iommu-updates-v3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "The most important part of these updates is the IOMMU groups code enhancement written by Alex Williamson. It abstracts the problem that a given hardware IOMMU can't isolate any given device from any other device (e.g. 32 bit PCI devices can't usually be isolated). Devices that can't be isolated are grouped together. This code is required for the upcoming VFIO framework. Another IOMMU-API change written by me is the introduction of domain attributes. This makes it easier to handle GART-like IOMMUs with the IOMMU-API because now the start-address and the size of the domain address space can be queried. Besides that there are a few cleanups and fixes for the NVidia Tegra IOMMU drivers and the reworked init-code for the AMD IOMMU. The latter is from my patch-set to support interrupt remapping. The rest of this patch-set requires x86 changes which are not mergabe yet. So full support for interrupt remapping with AMD IOMMUs will come in a future merge window." * tag 'iommu-updates-v3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (33 commits) iommu/amd: Fix hotplug with iommu=pt iommu/amd: Add missing spin_lock initialization iommu/amd: Convert iommu initialization to state machine iommu/amd: Introduce amd_iommu_init_dma routine iommu/amd: Move unmap_flush message to amd_iommu_init_dma_ops() iommu/amd: Split enable_iommus() routine iommu/amd: Introduce early_amd_iommu_init routine iommu/amd: Move informational prinks out of iommu_enable iommu/amd: Split out PCI related parts of IOMMU initialization iommu/amd: Use acpi_get_table instead of acpi_table_parse iommu/amd: Fix sparse warnings iommu/tegra: Don't call alloc_pdir with as->lock iommu/tegra: smmu: Fix unsleepable memory allocation at alloc_pdir() iommu/tegra: smmu: Remove unnecessary sanity check at alloc_pdir() iommu/exynos: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/tegra: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/msm: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/omap: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/vt-d: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/amd: Implement DOMAIN_ATTR_GEOMETRY attribute ...
2012-07-24Merge tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pciLinus Torvalds
Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug: - Add MMCONFIG support for hot-added host bridges (Jiang Liu) Device hotplug: - Move fixups from __init to __devinit (Sebastian Andrzej Siewior) - Call FINAL fixups for hot-added devices, too (Myron Stowe) - Factor out generic code for P2P bridge hot-add (Yinghai Lu) - Remove all functions in a slot, not just those with _EJx (Amos Kong) Dynamic resource management: - Track bus number allocation (struct resource tree per domain) (Yinghai Lu) - Make P2P bridge 1K I/O windows work with resource reassignment (Bjorn Helgaas, Yinghai Lu) - Disable decoding while updating 64-bit BARs (Bjorn Helgaas) Power management: - Add PCIe runtime D3cold support (Huang Ying) Virtualization: - Add VFIO infrastructure (ACS, DMA source ID quirks) (Alex Williamson) - Add quirks for devices with broken INTx masking (Jan Kiszka) Miscellaneous: - Fix some PCI Express capability version issues (Myron Stowe) - Factor out some arch code with a weak, generic, pcibios_setup() (Myron Stowe)" * tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (122 commits) PCI: hotplug: ensure a consistent return value in error case PCI: fix undefined reference to 'pci_fixup_final_inited' PCI: build resource code for M68K architecture PCI: pciehp: remove unused pciehp_get_max_lnk_width(), pciehp_get_cur_lnk_width() PCI: reorder __pci_assign_resource() (no change) PCI: fix truncation of resource size to 32 bits PCI: acpiphp: merge acpiphp_debug and debug PCI: acpiphp: remove unused res_lock sparc/PCI: replace pci_cfg_fake_ranges() with pci_read_bridge_bases() PCI: call final fixups hot-added devices PCI: move final fixups from __init to __devinit x86/PCI: move final fixups from __init to __devinit MIPS/PCI: move final fixups from __init to __devinit PCI: support sizing P2P bridge I/O windows with 1K granularity PCI: reimplement P2P bridge 1K I/O windows (Intel P64H2) PCI: disable MEM decoding while updating 64-bit MEM BARs PCI: leave MEM and IO decoding disabled during 64-bit BAR sizing, too PCI: never discard enable/suspend/resume_early/resume fixups PCI: release temporary reference in __nv_msi_ht_cap_quirk() PCI: restructure 'pci_do_fixups()' ...
2012-07-24Merge tag 'dt-for-3.6' of git://sources.calxeda.com/kernel/linuxLinus Torvalds
Pull devicetree updates from Rob Herring: "A small set of changes for devicetree: - Couple of Documentation fixes - Addition of new helper function of_node_full_name - Improve of_parse_phandle_with_args return values - Some NULL related sparse fixes" Grant's busy packing. * tag 'dt-for-3.6' of git://sources.calxeda.com/kernel/linux: of: mtd: nuke useless const qualifier devicetree: add helper inline for retrieving a node's full name of: return -ENOENT when no property usage-model.txt: fix typo machine_init->init_machine of: Fix null pointer related warnings in base.c file LED: Fix missing semicolon in OF documentation of: fix a few typos in the binding documentation
2012-07-24Merge tag 'pinctrl-for-v3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control changes from Linus Walleij: "These are the accumulated pin control patches for v3.6: - Various cleanups to the U300 driver - Refactor the pin control core to automatically remove any GPIO ranges when the drivers are removed, instead of having the drivers do this explicitly. - Add a function for registering a batch of GPIO ranges. - Fix a number of incorrect but non-regressive error checks. - Incremental improvements to the COH901, i.MX and Nomadik drivers - Add a one-register-per-pin entirely Device Tree-based pin control driver from Tony Lindgren." * tag 'pinctrl-for-v3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl: Add one-register-per-pin type device tree based pinctrl driver pinctrl/nomadik: add spi2_oc1_2 pin group pinctrl/nomadik: kerneldoc fix pinctrl/nomadik: use devm_* allocators for gpio probe pinctrl/nomadik: add pin group to mco function pinctrl/nomadik: add hsit_a_2 pin group pinctrl/nomadik: add pin group smcs1 and smps0 pinctrl/nomadik: fix hsir_a_1_pins pin list pinctrl: pinctrl-imx: fix map setting problem if NO_PAD_CTL is set pinctrl/coh901: use clk_prepare_[en|dis]able() pinctrl/pinctrl-tegra: remove IS_ERR checking of pmx->pctl pinctrl/pinctrl-spear: remove IS_ERR checking of pmx->pctl pinctrl/u300: drop unused variable pinctrl: select the proper symbol pinctrl: add pinctrl_add_gpio_ranges function pinctrl: remove pinctrl_remove_gpio_range pinctrl/pinctrl-core: cleanup pinctrl_register pinctrl/u300: delete pointless debug print pinctrl/pinctrl-u300: remove devm_kfree at driver unload
2012-07-24Merge tag 'rdma-for-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull InfiniBand/RDMA changes from Roland Dreier: - Updates to the qib low-level driver - First chunk of changes for SR-IOV support for mlx4 IB - RDMA CM support for IPv6-only binding - Other misc cleanups and fixes Fix up some add-add conflicts in include/linux/mlx4/device.h and drivers/net/ethernet/mellanox/mlx4/main.c * tag 'rdma-for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (30 commits) IB/qib: checkpatch fixes IB/qib: Add congestion control agent implementation IB/qib: Reduce sdma_lock contention IB/qib: Fix an incorrect log message IB/qib: Fix QP RCU sparse warnings mlx4: Put physical GID and P_Key table sizes in mlx4_phys_caps struct and paravirtualize them mlx4_core: Allow guests to have IB ports mlx4_core: Implement mechanism for reserved Q_Keys net/mlx4_core: Free ICM table in case of error IB/cm: Destroy idr as part of the module init error flow mlx4_core: Remove double function declarations IB/mlx4: Fill the masked_atomic_cap attribute in query device IB/mthca: Fill in sq_sig_type in query QP IB/mthca: Warning about event for non-existent QPs should show event type IB/qib: Fix sparse RCU warnings in qib_keys.c net/mlx4_core: Initialize IB port capabilities for all slaves mlx4: Use port management change event instead of smp_snoop IB/qib: RCU locking for MR validation IB/qib: Avoid returning EBUSY from MR deregister IB/qib: Fix UC MR refs for immediate operations ...
2012-07-24Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull i2c updates from Jean Delvare: "The most important changes here are a big cleanup of the i2c-piix4 driver, cleanups and interrupt support to the i2c-i801 driver, and support for the SCCB protocol." * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-omap: Add support for I2C_M_STOP message flag i2c: Fall back to emulated SMBus if the operation isn't supported natively i2c: Add SCCB support i2c-tiny-usb: Add support for the Robofuzz OSIF USB/I2C converter i2c-i801: Enable IRQ for byte_by_byte transactions i2c-i801: Enable interrupts on ICH5/7/8/9/10 i2c-i801: Enable IRQ for SMBus transactions i2c-i801: Consolidate polling i2c-i801: Drop ENABLE_INT9 i2c-i801: Rename some SMBHSTCNT bit constants i2c-i801: Check and return errors during byte-by-byte transfers i2c-i801: Clear only status bits in HST_STS i2c-i801: Refactor use of LAST_BYTE in i801_block_transaction_byte_by_byte i2c-smbus: Use module_i2c_driver() i2c/writing-clients: Mention module_i2c_driver() i2c-piix4: Support AMD auxiliary SMBus controller i2c-piix4: Separate registration and probing code i2c-piix4: Eliminate piix4_smba global variable i2c/busses: Use module_pci_driver i2c: Update Guenter Roeck's e-mail address
2012-07-24Merge tag 'sound-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound update from Takashi Iwai: "This is a fairly quiet release in all sound area. Only a little bit of changes in the core side while most of changes are seen in the drivers. HD-audio: - A few new codec additions for Nvidia, Realtek and VIA - Intel Haswell audio support - Support for "phantom" jacks for consistent jack reporting - Major clean-ups in HDMI/DP driver codes - A workaround for inverted digital-mic pins with Realtek codecs - Removal of beep_mode=2 option ASoC: - Added the ability to add and remove DAPM paths dynamically, mostly for reparenting on clock changes - New machine drivers for Marvell Brownstone, ST-Ericsson Ux500 reference platform and ttc-dkp - New CPU drivers for Blackfin BF6xx SPORTs in I2S mode, Marvell MMP, Synopsis Designware I2S controllers, and SPEAr DMA and S/PDIF - New CODEC drivers for Dialog DA732x, ST STA529, ST-Ericsson AB8500, TI Isabelle and Wolfson Microelectronics WM5102 and WM5110 - DAPM fixes for the recent locking changes - Fix for _PRE and _POST widgets (which have been broken for a few releases now) - A couple of minor driver updates Misc - Conversion to new dev_pm_ops in platform and PCI drivers - LTC support and some fixes in PCXHR driver - A few fixes and PM support for ISA OPti9xx and WSS cards - Some TLV code cleanup - Move driver-specific headers from include/sound to local dirs" * tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (212 commits) ASoC: dapm: Fix _PRE and _POST events for DAPM performance improvements ALSA: hda - add dock support for Thinkpad X230 Tablet ALSA: hda - Turn on PIN_OUT from hdmi playback prepare. ASoC imx-audmux: add MX31_AUDMUX_PORT7_SSI_PINS_7 define ASoC: littlemill: Add userspace control of the WM1250 I/O ASoC: wm8994: Update micdet for irqdomain conversion ALSA: hda - make sure alc268 does not OOPS on codec parse ALSA: hda - Add support for Realtek ALC282 ALSA: hda - Fix index number conflicts of phantom jacks ALSA: opti9xx: Fix section mismatch by PM support ALSA: snd-opti9xx: Implement suspend/resume ALSA: hda - Add new GPU codec ID to snd-hda ALSA: hda - Fix driver type of Haswell controller to AZX_DRIVER_SCH ALSA: hda - add Haswell HDMI codec id ALSA: hda - Add DeviceID for Haswell HDA ALSA: wss_lib: Fix resume on Yamaha OPL3-SAx ALSA: wss_lib: fix suspend/resume ALSA: es1938: replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE ALSA: tlv: add DECLARE_TLV_DB_RANGE() ALSA: tlv: add DECLARE_TLV_CONTAINER() ...
2012-07-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Trivial updates all over the place as usual." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits) Fix typo in include/linux/clk.h . pci: hotplug: Fix typo in pci iommu: Fix typo in iommu video: Fix typo in drivers/video Documentation: Add newline at end-of-file to files lacking one arm,unicore32: Remove obsolete "select MISC_DEVICES" module.c: spelling s/postition/position/g cpufreq: Fix typo in cpufreq driver trivial: typo in comment in mksysmap mach-omap2: Fix typo in debug message and comment scsi: aha152x: Fix sparse warning and make printing pointer address more portable. Change email address for Steve Glendinning Btrfs: fix typo in convert_extent_bit via: Remove bogus if check netprio_cgroup.c: fix comment typo backlight: fix memory leak on obscure error path Documentation: asus-laptop.txt references an obsolete Kconfig item Documentation: ManagementStyle: fixed typo mm/vmscan: cleanup comment error in balance_pgdat mm: cleanup on the comments of zone_reclaim_stat ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: "The list of changes worth pointing out explicitly: - We are getting 'UHID', which is a new framework for implementing HID transport drivers in userspace (this is different from HIDRAW, which is transport-independent and provides report parsing facilities; uhid is for the other (transport) part of the pipeline). It's needed for (and currently being used by) Bluetooth-LowEnergy, as its specification mandates things we don't want in the kernel. Written by David Herrmann. - there have been quite a few bugs in runtime suspend/resume paths (probably never reported to actually happen in the wild, but still). Alan Stern fixed those. - a few other driver updates and fixes and random new device support." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (45 commits) HID: add ASUS AIO keyboard model AK1D HID: add support for Cypress barcode scanner 04B4:ED81 HID: Allow drivers to be their own listener HID: usbhid: fix error paths in suspend HID: usbhid: check for suspend or reset before restarting HID: usbhid: replace HID_REPORTED_IDLE with HID_SUSPENDED HID: usbhid: inline some simple routines HID: usbhid: fix autosuspend calls HID: usbhid: fix use-after-free bug HID: hid-core: optimize in case of hidraw HID: hidraw: fix list->buffer memleak HID: uhid: Fix sending events with invalid data HID: roccat: added sensor sysfs attribute for Savu HID: Add driver for Holtek based keyboards with broken HID HID: Add suport for the brightness control keys on HP keyboards HID: magicmouse: Implement Multi-touch Protocol B (MT-B) HID: magicmouse: Removing report_touches switch HID: roccat: rename roccat_common functions to roccat_common2 HID: roccat: fix wrong hid_err usage on struct usb_device HID: roccat: move functionality to roccat-common ...
2012-07-24Merge tag 'stable/for-linus-3.6-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen update from Konrad Rzeszutek Wilk: "Features: * Performance improvement to lower the amount of traps the hypervisor has to do 32-bit guests. Mainly for setting PTE entries and updating TLS descriptors. * MCE polling driver to collect hypervisor MCE buffer and present them to /dev/mcelog. * Physical CPU online/offline support. When an privileged guest is booted it is present with virtual CPUs, which might have an 1:1 to physical CPUs but usually don't. This provides mechanism to offline/online physical CPUs. Bug-fixes for: * Coverity found fixes in the console and ACPI processor driver. * PVonHVM kexec fixes along with some cleanups. * Pages that fall within E820 gaps and non-RAM regions (and had been released to hypervisor) would be populated back, but potentially in non-RAM regions." * tag 'stable/for-linus-3.6-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: populate correct number of pages when across mem boundary (v2) xen PVonHVM: move shared_info to MMIO before kexec xen: simplify init_hvm_pv_info xen: remove cast from HYPERVISOR_shared_info assignment xen: enable platform-pci only in a Xen guest xen/pv-on-hvm kexec: shutdown watches from old kernel xen/x86: avoid updating TLS descriptors if they haven't changed xen/x86: add desc_equal() to compare GDT descriptors xen/mm: zero PTEs for non-present MFNs in the initial page table xen/mm: do direct hypercall in xen_set_pte() if batching is unavailable xen/hvc: Fix up checks when the info is allocated. xen/acpi: Fix potential memory leak. xen/mce: add .poll method for mcelog device driver xen/mce: schedule a workqueue to avoid sleep in atomic context xen/pcpu: Xen physical cpus online/offline sys interface xen/mce: Register native mce handler as vMCE bounce back point x86, MCE, AMD: Adjust initcall sequence for xen xen/mce: Add mcelog support for Xen platform
2012-07-24Merge tag 'kvm-3.6-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Avi Kivity: "Highlights include - full big real mode emulation on pre-Westmere Intel hosts (can be disabled with emulate_invalid_guest_state=0) - relatively small ppc and s390 updates - PCID/INVPCID support in guests - EOI avoidance; 3.6 guests should perform better on 3.6 hosts on interrupt intensive workloads) - Lockless write faults during live migration - EPT accessed/dirty bits support for new Intel processors" Fix up conflicts in: - Documentation/virtual/kvm/api.txt: Stupid subchapter numbering, added next to each other. - arch/powerpc/kvm/booke_interrupts.S: PPC asm changes clashing with the KVM fixes - arch/s390/include/asm/sigp.h, arch/s390/kvm/sigp.c: Duplicated commits through the kvm tree and the s390 tree, with subsequent edits in the KVM tree. * tag 'kvm-3.6-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (93 commits) KVM: fix race with level interrupts x86, hyper: fix build with !CONFIG_KVM_GUEST Revert "apic: fix kvm build on UP without IOAPIC" KVM guest: switch to apic_set_eoi_write, apic_write apic: add apic_set_eoi_write for PV use KVM: VMX: Implement PCID/INVPCID for guests with EPT KVM: Add x86_hyper_kvm to complete detect_hypervisor_platform check KVM: PPC: Critical interrupt emulation support KVM: PPC: e500mc: Fix tlbilx emulation for 64-bit guests KVM: PPC64: booke: Set interrupt computation mode for 64-bit host KVM: PPC: bookehv: Add ESR flag to Data Storage Interrupt KVM: PPC: bookehv64: Add support for std/ld emulation. booke: Added crit/mc exception handler for e500v2 booke/bookehv: Add host crit-watchdog exception support KVM: MMU: document mmu-lock and fast page fault KVM: MMU: fix kvm_mmu_pagetable_walk tracepoint KVM: MMU: trace fast page fault KVM: MMU: fast path of handling guest page fault KVM: MMU: introduce SPTE_MMU_WRITEABLE bit KVM: MMU: fold tlb flush judgement into mmu_spte_update ...
2012-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David S Miller: 1) Remove the ipv4 routing cache. Now lookups go directly into the FIB trie and use prebuilt routes cached there. No more garbage collection, no more rDOS attacks on the routing cache. Instead we now get predictable and consistent performance, no matter what the pattern of traffic we service. This has been almost 2 years in the making. Special thanks to Julian Anastasov, Eric Dumazet, Steffen Klassert, and others who have helped along the way. I'm sure that with a change of this magnitude there will be some kind of fallout, but such things ought the be simple to fix at this point. Luckily I'm not European so I'll be around all of August to fix things :-) The major stages of this work here are each fronted by a forced merge commit whose commit message contains a top-level description of the motivations and implementation issues. 2) Pre-demux of established ipv4 TCP sockets, saves a route demux on input. 3) TCP SYN/ACK performance tweaks from Eric Dumazet. 4) Add namespace support for netfilter L4 conntrack helpers, from Gao Feng. 5) Add config mechanism for Energy Efficient Ethernet to ethtool, from Yuval Mintz. 6) Remove quadratic behavior from /proc/net/unix, from Eric Dumazet. 7) Support for connection tracker helpers in userspace, from Pablo Neira Ayuso. 8) Allow userspace driven TX load balancing functions in TEAM driver, from Jiri Pirko. 9) Kill off NLMSG_PUT and RTA_PUT macros, more gross stuff with embedded gotos. 10) TCP Small Queues, essentially minimize the amount of TCP data queued up in the packet scheduler layer. Whereas the existing BQL (Byte Queue Limits) limits the pkt_sched --> netdevice queuing levels, this controls the TCP --> pkt_sched queueing levels. From Eric Dumazet. 11) Reduce the number of get_page/put_page ops done on SKB fragments, from Alexander Duyck. 12) Implement protection against blind resets in TCP (RFC 5961), from Eric Dumazet. 13) Support the client side of TCP Fast Open, basically the ability to send data in the SYN exchange, from Yuchung Cheng. Basically, the sender queues up data with a sendmsg() call using MSG_FASTOPEN, then they do the connect() which emits the queued up fastopen data. 14) Avoid all the problems we get into in TCP when timers or PMTU events hit a locked socket. The TCP Small Queues changes added a tcp_release_cb() that allows us to queue work up to the release_sock() caller, and that's what we use here too. From Eric Dumazet. 15) Zero copy on TX support for TUN driver, from Michael S. Tsirkin. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1870 commits) genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEP r8169: revert "add byte queue limit support". ipv4: Change rt->rt_iif encoding. net: Make skb->skb_iif always track skb->dev ipv4: Prepare for change of rt->rt_iif encoding. ipv4: Remove all RTCF_DIRECTSRC handliing. ipv4: Really ignore ICMP address requests/replies. decnet: Don't set RTCF_DIRECTSRC. net/ipv4/ip_vti.c: Fix __rcu warnings detected by sparse. ipv4: Remove redundant assignment rds: set correct msg_namelen openvswitch: potential NULL deref in sample() tcp: dont drop MTU reduction indications bnx2x: Add new 57840 device IDs tcp: avoid oops in tcp_metrics and reset tcpm_stamp niu: Change niu_rbr_fill() to use unlikely() to check niu_rbr_add_page() return value niu: Fix to check for dma mapping errors. net: Fix references to out-of-scope variables in put_cmsg_compat() net: ethernet: davinci_emac: add pm_runtime support net: ethernet: davinci_emac: Remove unnecessary #include ...
2012-07-24i2c: Add SCCB supportLaurent Pinchart
SCCB is a serial communication bus developed by Omnivision. Its 2-wire mode is very similar to SMBus byte data transactions, but requires the controller to ignore the ACK bit and to insert a stop condition after each message. Add a device SCCB flag and a message stop flag to be passed to controller drivers. [JD: Kill rogue definition in go7007 driver.] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-07-24sched: Fix race in task_group()Peter Zijlstra
Stefan reported a crash on a kernel before a3e5d1091c1 ("sched: Don't call task_group() too many times in set_task_rq()"), he found the reason to be that the multiple task_group() invocations in set_task_rq() returned different values. Looking at all that I found a lack of serialization and plain wrong comments. The below tries to fix it using an extra pointer which is updated under the appropriate scheduler locks. Its not pretty, but I can't really see another way given how all the cgroup stuff works. Reported-and-tested-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1340364965.18025.71.camel@twins Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-24sched: Improve scalability via 'CPU buddies', which withstand random ↵Mike Galbraith
perturbations Traversing an entire package is not only expensive, it also leads to tasks bouncing all over a partially idle and possible quite large package. Fix that up by assigning a 'buddy' CPU to try to motivate. Each buddy may try to motivate that one other CPU, if it's busy, tough, it may then try its SMT sibling, but that's all this optimization is allowed to cost. Sibling cache buddies are cross-wired to prevent bouncing. 4 socket 40 core + SMT Westmere box, single 30 sec tbench runs, higher is better: clients 1 2 4 8 16 32 64 128 .......................................................................... pre 30 41 118 645 3769 6214 12233 14312 post 299 603 1211 2418 4697 6847 11606 14557 A nice increase in performance. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1339471112.7352.32.camel@marge.simpson.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-24cpusets, hotplug: Restructure functions that are invoked during hotplugSrivatsa S. Bhat
Separate out the cpuset related handling for CPU/Memory online/offline. This also helps us exploit the most obvious and basic level of optimization that any notification mechanism (CPU/Mem online/offline) has to offer us: "We *know* why we have been invoked. So stop pretending that we are lost, and do only the necessary amount of processing!". And while at it, rename scan_for_empty_cpusets() to scan_cpusets_upon_hotplug(), which is more appropriate considering how it is restructured. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120524141650.3692.48637.stgit@srivatsabhat.in.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-24Merge branch 'uhid' into for-linusJiri Kosina
Conflicts: drivers/hid/Kconfig
2012-07-24Merge branches 'hidraw', 'magicmouse', 'multitouch', 'roccat', ↵Jiri Kosina
'suspend-fixes' and 'upstream' into for-linus
2012-07-24Fix typo in include/linux/clk.h .Jan-Simon Möller
Signed-off-by: Jan-Simon Möller <jansimon.moeller@gmx.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-kernel@vger.kernel.org Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-24genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEPWANG Cong
lockdep_is_held() is defined when CONFIG_LOCKDEP, not CONFIG_PROVE_LOCKING. Cc: "David S. Miller" <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull arch/tile updates from Chris Metcalf: "These changes provide support for PCIe root complex and USB host mode for tilegx's on-chip I/Os. In addition, this pull provides the required underpinning for the on-chip networking support that was pulled into 3.5. The changes have all been through LKML (with several rounds for PCIe RC) and on linux-next." * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: updates to pci root complex from community feedback bounce: allow use of bounce pool via config option usb: add host support for the tilegx architecture arch/tile: provide kernel support for the tilegx USB shim tile pci: enable IOMMU to support DMA for legacy devices arch/tile: enable ZONE_DMA for tilegx tilegx pci: support I/O to arbitrarily-cached pages tile: remove unused header arch/tile: tilegx PCI root complex support arch/tile: provide kernel support for the tilegx TRIO shim arch/tile: break out the "csum a long" function to <asm/checksum.h> arch/tile: provide kernel support for the tilegx mPIPE shim arch/tile: common DMA code for the GXIO IORPC subsystem arch/tile: support MMIO-based readb/writeb etc. arch/tile: introduce GXIO IORPC framework for tilegx
2012-07-23Merge tag 'sh-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
Pull SuperH updates from Paul Mundt: - Migration off of old-style dynamic IRQ API. - irqdomain and generic irq chip propagation. - div4/6 clock consolidation, another step towards co-existing with the common struct clk infrastructure. - Extensive PFC rework - Decoupling GPIO from pin state. - Initial pinctrl support to facilitate incremental migration off of legacy pinmux. - gpiolib support made optional, and made pinctrl-backed. * tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: (38 commits) sh: pfc: pin config get/set support. sh: pfc: Prefer DRV_NAME over KBUILD_MODNAME. sh: pfc: pinctrl legacy group support. sh: pfc: Ignore pinmux GPIOs with invalid enum IDs. sh: pfc: Export pinctrl binding init symbol. sh: pfc: Error out on pinctrl init resolution failure. sh: pfc: Make pr_fmt consistent across pfc drivers. sh: pfc: pinctrl legacy function support. sh: pfc: Rudimentary pinctrl-backed GPIO support. sh: pfc: Dumb GPIO stringification. sh: pfc: Shuffle PFC support core. sh: pfc: Verify pin type encoding size at build time. sh: pfc: Kill off unused pinmux bias flags. sh: pfc: Make gpio chip support optional where possible. sh: pfc: Split out gpio chip support. sh64: Fix up section mismatch warnings. sh64: Attempt to make reserved insn trap handler resemble C. sh: Consolidate die definitions for trap handlers. sh64: Kill off old exception debugging helpers. sh64: Use generic unaligned access control/counters. ...
2012-07-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "Notable highlights: - iommu improvements from Anton removing the per-iommu global lock in favor of dividing the DMA space into pools, each with its own lock, and hashed on the CPU number. Along with making the locking more fine grained, this gives significant improvements in multiqueue networking scalability. - Still from Anton, we know provide a vdso based variant of getcpu which makes sched_getcpu with the appropriate glibc patch something like 18 times faster. - More anton goodness (he's been busy !) in other areas such as a faster __clear_user and copy_page on P7, various perf fixes to improve sampling quality, etc... - One more step toward removing legacy i2c interfaces by using new device-tree based probing of platform devices for the AOA audio drivers - A nice series of patches from Michael Neuling that helps avoiding confusion between register numbers and litterals in assembly code, trying to enforce the use of "%rN" register names in gas rather than plain numbers. - A pile of FSL updates - The usual bunch of small fixes, cleanups etc... You may spot a change to drivers/char/mem. The patch got no comment or ack from outside, it's a trivial patch to allow the architecture to skip creating /dev/port, which we use to disable it on ppc64 that don't have a legacy brige. On those, IO ports 0...64K are not mapped in kernel space at all, so accesses to /dev/port cause oopses (and yes, distros -still- ship userspace that bangs hard coded ports such as kbdrate)." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits) powerpc/mpic: Create a revmap with enough entries for IPIs and timers Remove stale .rej file powerpc/iommu: Fix iommu pool initialization powerpc/eeh: Check handle_eeh_events() return value powerpc/85xx: Add phy nodes in SGMII mode for MPC8536/44/72DS & P2020DS powerpc/e500: add paravirt QEMU platform powerpc/mpc85xx_ds: convert to unified PCI init powerpc/fsl-pci: get PCI init out of board files powerpc/85xx: Update corenet64_smp_defconfig powerpc/85xx: Update corenet32_smp_defconfig powerpc/85xx: Rename P1021RDB-PC device trees to be consistent powerpc/watchdog: move booke watchdog param related code to setup-common.c sound/aoa: Adapt to new i2c probing scheme i2c/powermac: Improve detection of devices from device-tree powerpc: Disable /dev/port interface on systems without an ISA bridge of: Improve prom_update_property() function powerpc: Add "memory" attribute for mfmsr() powerpc/ftrace: Fix assembly trampoline register usage powerpc/hw_breakpoints: Fix incorrect pointer access powerpc: Put the gpr save/restore functions in their own section ...
2012-07-23Merge tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc power management changes from Arnd Bergmann: "These are various power management related changes, mainly concerning cpuidle on i.MX and OMAP, as well as a the move of the omap smartreflex driver to live in the power subsystem." Fix up conflicts in arch/arm/mach-{imx/mach-imx6q.c,omap2/prm2xxx_3xxx.h} * tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits) ARM: OMAP2+: PM: fix IRQ_NOAUTOEN removal by mis-merge ARM: OMAP2+: do not allow SmartReflex to be built as a module ARM: OMAP2: Use hwmod to initialize mmc for 2420 ARM: OMAP3: PM: cpuidle: optimize the clkdm idle latency in C1 state ARM: OMAP3: PM: cpuidle: optimize the PER latency in C1 state ARM: OMAP3: PM: cpuidle: default to C1 in next_valid_state ARM: OMAP3: PM: cleanup cam_pwrdm leftovers ARM: OMAP3: PM: call pre/post transition per powerdomain ARM: OMAP2+: powerdomain: allow pre/post transtion to be per pwrdm ARM: OMAP3: PM: Remove IO Daisychain control from cpuidle ARM: OMAP3PLUS: hwmod: reconfigure IO Daisychain during hwmod mux ARM: OMAP3+: PRM: Enable IO wake up ARM: OMAP4: PRM: Add IO Daisychain support ARM: OMAP3: PM: Move IO Daisychain function to omap3 prm file ARM: OMAP3: PM: correct enable/disable of daisy io chain ARM: OMAP2+: PRM: fix compile for OMAP4-only build W1: OMAP HDQ1W: use runtime PM ARM: OMAP2+: HDQ1W: use omap_device W1: OMAP HDQ1W: use 32-bit register accesses W1: OMAP HDQ1W: allow driver to be built on all OMAP2+ ...
2012-07-23Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc board specific updates from Arnd Bergmann: "These changes are all for individual board files. In the long run, those files will largely go away, and the amount of changes appears to be continuously decreasing, which is a good sign. This time around, changes are focused on tegra, omap and samsung." Fix conflicts in arch/arm/mach-{omap2/common-board-devices.c,tegra/Makefile.boot} as per the 'for-linus' branch. * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits) ARM: EXYNOS: Add leds status1 and status2 on Origen board ARM: S3C64XX: Mark most Cragganmore initdata devinitdata ARM: EXYNOS: Add missing .reserve field to SMDKC210 ARM: EXYNOS: Add DRM device to SMDK4X12 board ARM: S3C64XX: Clean up after SPI driver platform data updates ARM: SAMSUNG: no need to set the value for clk_xusbxti when it is 24Mhz ARM: EXYNOS: Add framebuffer support for SMDK4X12 ARM: EXYNOS: Add HSOTG support to SMDK4X12 ARM: S5PV210: Add audio platform device in Goni board ARM: S5PV210: Add audio platform device in Aquila board ARM: EXYNOS: Add audio platform device in SMDKV310 board ARM: S3C64XX: Don't specify an irq_base for WM1192-EV1 board ARM: OMAP3: Fix omap3evm randconfig error introduced by VBUS support ARM: OMAP: board-omap4panda: MUX configuration for sys_nirq2 ARM: OMAP: board-4430sdp: MUX configuration for sys_nirq2 ARM: OMAP3530evm: set pendown_state and debounce time for ads7846 ARM: omap3evm: enable VBUS switch for EHCI tranceiver ARM: OMAP3EVM: Adding USB internal LDOs board file ARM: OMAP3EVM: Add NAND flash definition ARM: OMAP3: cm-t35: add tvp5150 decoder support ...
2012-07-23Merge tag 'newsoc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull support for three new arm SoC types from Arnd Bergmann: - The mvebu platform includes Marvell's Armada XP and Armada 370 chips, made by the mvebu business unit inside of Marvell. Since the same group also made the older but similar platforms we call "orion5x", "kirkwood", "mv78xx0" and "dove", we plan to move all of them into the mach-mvebu directory in the future. - socfpga is Altera's platform based on Cortex-A9 cores and a lot of FPGA space. This is similar to the Xilinx zynq platform we already support. The code is particularly clean, which is helped by the fact that the hardware doesn't do much besides the parts that are expected to get added in the FPGA. - The OMAP subarchitecture gains support for the latest generation, the OMAP5 based on the new Cortex-A15 core. Support is rather rudimentary for now, but will be extended in the future. * tag 'newsoc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (25 commits) ARM: socfpga: initial support for Altera's SOCFPGA platform arm: mvebu: generate DTBs for supported SoCs ARM: mvebu: MPIC: read number of interrupts from control register arm: mach-mvebu: add entry to MAINTAINERS arm: mach-mvebu: add compilation/configuration change arm: mach-mvebu: add defconfig arm: mach-mvebu: add documentation for new device tree bindings arm: mach-mvebu: add support for Armada 370 and Armada XP with DT arm: mach-mvebu: add source files arm: mach-mvebu: add header clocksource: time-armada-370-xp: Marvell Armada 370/XP SoC timer driver ARM: Kconfig update to support additional GPIOs in OMAP5 ARM: OMAP5: Add the build support arm/dts: OMAP5: Add omap5 dts files ARM: OMAP5: board-generic: Add device tree support ARM: omap2+: board-generic: clean up the irq data from board file ARM: OMAP5: Add SMP support ARM: OMAP5: Add the WakeupGen IP updates ARM: OMAP5: l3: Add l3 error handler support for omap5 ARM: OMAP5: gpmc: Update gpmc_init() ... Conflicts: Documentation/devicetree/bindings/arm/omap/omap.txt arch/arm/mach-omap2/Makefile drivers/clocksource/Kconfig drivers/clocksource/Makefile
2012-07-23Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc device tree description updates from Arnd Bergmann: "This branch contains two kinds of updates: Some platforms in the process of getting converted to device tree based booting, and the platform specific patches necessary for that are included here. Other platforms are already converted, so we just need to update the actual device tree source files and the binding documents to add support for new board and new drivers. In the future we will probably separate those into two branches, and in the long run, the plan is to move the device tree source files out of the kernel repository, but that has to wait until we have completed a much larger portion of the binding documents." Fix up trivial conflicts in arch/arm/mach-imx/clk-imx6q.c due to newly added clkdev registers next to a few removed unnecessary ones. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: LPC32xx: Add PWM to base dts file ARM: EXYNOS: mark the DMA channel binding for SPI as preliminary ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS5 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOS5 ARM: EXYNOS: Add spi clock support for EXYNOS5 ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS4 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOX4 ARM: EXYNOS: Fix the incorrect hierarchy of spi controller bus clock ARM: ux500: Remove PMU platform registration when booting with DT ARM: ux500: Remove temporary snowball_of_platform_devs enablement structure ARM: ux500: Ensure vendor specific properties have the vendor's identifier pinctrl: pinctrl-nomadik: Append sleepmode property with vendor specific prefixes ARM: ux500: Move rtc-pl031 registration to Device Tree when enabled ARM: ux500: Enable the AB8500 RTC for all DT:ed DB8500 based devices ARM: ux500: Correctly reference IRQs supplied by the AB8500 from Device Tree ARM: ux500: Apply ab8500-debug node do the db8500 DT structure ARM: ux500: Add a ab8500-usb Device Tree node for db8500 based devices ARM: ux500: Add db8500 Device Tree node for misc/ab8500-pwm ARM: ux500: Add db8500 Device Tree node for ab8500-sysctrl ARM: ux500: Enable LED heartbeat functionality on Snowbal via DT ...
2012-07-23Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm soc-specific updates from Arnd Bergmann: "This is stuff that does not fit well into another category and in particular is not related to a particular board. The largest part in here is extending the am33xx support in the omap platform." Fix up trivial conflicts in arch/arm/mach-{imx/mach-mx35_3ds.c, tegra/Makefile} * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (74 commits) ARM: LPC32xx: Add PWM support ARM: LPC32xx: Add PWM clock ARM: LPC32xx: Set system serial based on cpu unique id ARM: vexpress: Config option for early printk console ARM: vexpress: Add Device Tree for V2P-CA15_CA7 core tile ARM: vexpress: Convert V2P-CA15 Device Tree to 64 bit addresses ARM: vexpress: Add fixed regulator for SMSC ARM: vexpress: Add missing SP804 interrupt in motherboard's DTS files ARM: vexpress: Initial common clock support ARM: SAMSUNG: Introduce Kconfig variable for Samsung custom clk API ARM: EXYNOS: Add missing static storage class specifier in pmu.c file ARM: EXYNOS: Make combiner_init function static ARM: EXYNOS: Update HSOTG PHY clock setting for EXYNOS4X12 ARM: versatile: Make plat-versatile clock optional ARM: vexpress: Check master site in daughterboard's sysctl operations ARM: vexpress: remove automatic errata workaround selection ARM: LPC32xx: Adjust to pl08x DMA interface changes ARM: EXYNOS: Clear SYS_WDTRESET bit to use watchdog reset ARM: imx: fix mx51 ehci setup errors ARM: imx: make ehci power/oc polarities configurable ...
2012-07-23Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical arm-soc bug fixes from Arnd Bergmann: "These were submitted as bug fixes before v3.5 but not considered important enough to be included in it." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM:vt8500: Convert to use .restart and remove arch_reset() ARM: davinci: da8xx: fix interrupt handling ARM: OMAP2+: fix CONFIG_CPU_IDLE dependency on CONFIG_PM ARM: mxs/tx28: fix odd include ARM: OMAP: remove unused cpu detection macros ARM: OMAP: fix typos related to OMAP330 ARM: OMAP7XX: Remove omap730.h and omap850.h ARM: OMAP2+: fix naming collision of variable nr_irqs ARM: OMAP: omap2plus_defconfig: Enable EXT4 support ARM: OMAP depends on MMU arm: omap3: am35x: Set proper powerdomain states ARM: OMAP AM35x: clockdomain data: Fix clockdomain dependencies ARM: OMAP AM35x: EMAC/MDIO integration: Add Davinci EMAC/MDIO hwmod support ARM: OMAP: AM35xx: fix UART4 softreset ARM: OMAP AM35xx: clock and hwmod data: fix UART4 data ARM: OMAP AM35xx: clock and hwmod data: fix AM35xx HSOTGUSB hwmod ARM: OMAP: Fix dts files w/ status property: "disable" -> "disabled" ARM: OMAP: beagle: Set USB Host Port 1 to OMAP_USBHS_PORT_MODE_UNUSED ARM: OMAP2: twl-common: Fix compiler warning ARM: OMAP: fix the ads7846 init code ...
2012-07-23Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull the big VFS changes from Al Viro: "This one is *big* and changes quite a few things around VFS. What's in there: - the first of two really major architecture changes - death to open intents. The former is finally there; it was very long in making, but with Miklos getting through really hard and messy final push in fs/namei.c, we finally have it. Unlike his variant, this one doesn't introduce struct opendata; what we have instead is ->atomic_open() taking preallocated struct file * and passing everything via its fields. Instead of returning struct file *, it returns -E... on error, 0 on success and 1 in "deal with it yourself" case (e.g. symlink found on server, etc.). See comments before fs/namei.c:atomic_open(). That made a lot of goodies finally possible and quite a few are in that pile: ->lookup(), ->d_revalidate() and ->create() do not get struct nameidata * anymore; ->lookup() and ->d_revalidate() get lookup flags instead, ->create() gets "do we want it exclusive" flag. With the introduction of new helper (kern_path_locked()) we are rid of all struct nameidata instances outside of fs/namei.c; it's still visible in namei.h, but not for long. Come the next cycle, declaration will move either to fs/internal.h or to fs/namei.c itself. [me, miklos, hch] - The second major change: behaviour of final fput(). Now we have __fput() done without any locks held by caller *and* not from deep in call stack. That obviously lifts a lot of constraints on the locking in there. Moreover, it's legal now to call fput() from atomic contexts (which has immediately simplified life for aio.c). We also don't need anti-recursion logics in __scm_destroy() anymore. There is a price, though - the damn thing has become partially asynchronous. For fput() from normal process we are guaranteed that pending __fput() will be done before the caller returns to userland, exits or gets stopped for ptrace. For kernel threads and atomic contexts it's done via schedule_work(), so theoretically we might need a way to make sure it's finished; so far only one such place had been found, but there might be more. There's flush_delayed_fput() (do all pending __fput()) and there's __fput_sync() (fput() analog doing __fput() immediately). I hope we won't need them often; see warnings in fs/file_table.c for details. [me, based on task_work series from Oleg merged last cycle] - sync series from Jan - large part of "death to sync_supers()" work from Artem; the only bits missing here are exofs and ext4 ones. As far as I understand, those are going via the exofs and ext4 trees resp.; once they are in, we can put ->write_super() to the rest, along with the thread calling it. - preparatory bits from unionmount series (from dhowells). - assorted cleanups and fixes all over the place, as usual. This is not the last pile for this cycle; there's at least jlayton's ESTALE work and fsfreeze series (the latter - in dire need of fixes, so I'm not sure it'll make the cut this cycle). I'll probably throw symlink/hardlink restrictions stuff from Kees into the next pile, too. Plus there's a lot of misc patches I hadn't thrown into that one - it's large enough as it is..." * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (127 commits) ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file() btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file() switch dentry_open() to struct path, make it grab references itself spufs: shift dget/mntget towards dentry_open() zoran: don't bother with struct file * in zoran_map ecryptfs: don't reinvent the wheels, please - use struct completion don't expose I_NEW inodes via dentry->d_inode tidy up namei.c a bit unobfuscate follow_up() a bit ext3: pass custom EOF to generic_file_llseek_size() ext4: use core vfs llseek code for dir seeks vfs: allow custom EOF in generic_file_llseek code vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder sync passes vfs: Remove unnecessary flushing of block devices vfs: Make sys_sync writeout also block device inodes vfs: Create function for iterating over block devices vfs: Reorder operations during sys_sync quota: Move quota syncing to ->sync_fs method quota: Split dquot_quota_sync() to writeback and cache flushing part vfs: Move noop_backing_dev_info check from sync into writeback ...
2012-07-23Merge branches 'iommu/fixes', 'x86/amd', 'groups', 'arm/tegra' and ↵Joerg Roedel
'api/domain-attr' into next Conflicts: drivers/iommu/iommu.c include/linux/iommu.h
2012-07-23tcp: dont drop MTU reduction indicationsEric Dumazet
ICMP messages generated in output path if frame length is bigger than mtu are actually lost because socket is owned by user (doing the xmit) One example is the ipgre_tunnel_xmit() calling icmp_send(skb, ICMP_DEST_UNREACH, ICMP_FRAG_NEEDED, htonl(mtu)); We had a similar case fixed in commit a34a101e1e6 (ipv6: disable GSO on sockets hitting dst_allfrag). Problem of such fix is that it relied on retransmit timers, so short tcp sessions paid a too big latency increase price. This patch uses the tcp_release_cb() infrastructure so that MTU reduction messages (ICMP messages) are not lost, and no extra delay is added in TCP transmits. Reported-by: Maciej Żenczykowski <maze@google.com> Diagnosed-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Nandita Dukkipati <nanditad@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Tore Anderson <tore@fud.no> Signed-off-by: David S. Miller <davem@davemloft.net>
