RPC wait queue length will eventually be exported to userland via the RPC
iostats interface.
Test plan:
Compile kernel with CONFIG_NFS enabled.
Signed-off-by: Chuck Lever <cel@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Add a field in nfs_server to record a timestamp when a mount succeeds.
Report the number of seconds the file system has been mounted via
nfs_show_stats().
Test plan:
Mount an NFS file system, watch the mountstats reports and compare with
clock time.
Add a per-superblock performance counter facility to the NFS client. This
facility mimics the counters available for block devices and for
networking. Expose these new counters via the new /proc/self/mountstats
interface.
Thanks to Andrew Morton and Trond Myklebust for their review and comments.
Test plan:
fsx and iozone on UP and SMP systems, with and without pre-emption. Watch
for memory overwrite bugs, and performance loss (significantly more CPU
required per op).
Sometimes it's important to know the exact RPC retransmit settings the
kernel is using for an NFS mount point. Add this facility to the NFS
client's show_options method.
Test plan:
Set various retransmit settings via the mount command, and check that the
settings are reflected in /proc/mounts.
Create a new file under /proc/self, called mountstats, where mounted file
systems can export information (configuration options, performance counters,
and so on). Use a mechanism similar to /proc/mounts and s_ops->show_options.
This mechanism does not violate namespace security, and is safe to use while
other processes are unmounting file systems.
Thanks to Mike Waychison for his review and comments.
Test-plan:
Test concurrent mount/unmount operations while cat'ing /proc/self/mountstats.
read_cache_mtime is no longer used in nfs_inode. This patch removes
references of read_cache_mtime in the code comments.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@gmail.com>
Instead we use the nlm_lockowner->pid.
The nfs_open_context may live longer than the file descriptor that spawned
it, so it needs to carry a reference to the vfsmount. If not, then
generic_shutdown_super() may end up being called before reads and writes
have been flushed out.
Make a couple of functions static while we're at it...
The 40-bit DMA workaround recently implemented for 5714, 5715, and
5780 needs to be expanded because there may be other tg3 devices
behind the EPB Express to PCIX bridge in the 5780 class device.
For example, some 4-port card or mother board designs have 5704 behind
the 5714.
All devices behind the EPB require the 40-bit DMA workaround.
Thanks to Chris Elmquist again for reporting the problem and testing
the patch.
Signed-off-by: Michael Chan <mchan@broadcom.com>
The patch '[PATCH] RCU signal handling' [1] added an export for
__put_task_struct_cb, a put_task_struct helper newly introduced in that
patch. But the put_task_struct couldn't be used modular previously as
__put_task_struct wasn't exported. There are not callers of it in modular
code, and it shouldn't be exported because we don't want drivers to hold
references to task_structs.
This patch removes the export and folds __put_task_struct into
__put_task_struct_cb as there's no other caller.
[1] http://www2.kernel.org/git/gitweb.cgi?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=e56d090310d7625ecb43a1eeebd479f04affb48b
Acked-by: Paul E. McKenney <paulmck@us.ibm.com>
This patch fixes illegal __GFP_FS allocation inside ext3 transaction in
ext3_symlink(). Such allocation may re-enter ext3 code from
try_to_free_pages. But JBD/ext3 code keeps a pointer to current journal
handle in task_struct and, hence, is not reentrable.
This bug led to "Assertion failure in journal_dirty_metadata()" messages.
http://bugzilla.openvz.org/show_bug.cgi?id=115
Signed-off-by: Andrey Savochkin <saw@saw.sw.com.sg>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
The cache reaper currently tries to free all alien caches and all remote
per cpu pages in each pass of cache_reap. For a machines with large number
of nodes (such as Altix) this may lead to sporadic delays of around ~10ms.
Interrupts are disabled while reclaiming creating unacceptable delays.
This patch changes that behavior by adding a per cpu reap_node variable.
Instead of attempting to free all caches, we free only one alien cache and
the per cpu pages from one remote node. That reduces the time spend in
cache_reap. However, doing so will lengthen the time it takes to
completely drain all remote per cpu pagesets and all alien caches. The
time needed will grow with the number of nodes in the system. All caches
are drained when they overflow their respective capacity. So the drawback
here is only that a bit of memory may be wasted for awhile longer.
Details:
1. Rename drain_remote_pages to drain_node_pages to allow the specification
of the node to drain of pcp pages.
2. Add additional functions init_reap_node, next_reap_node for NUMA
that manage a per cpu reap_node counter.
3. Add a reap_alien function that reaps only from the current reap_node.
For us this seems to be a critical issue. Holdoffs of an average of ~7ms
cause some HPC benchmarks to slow down significantly. F.e. NAS parallel
slows down dramatically. NAS parallel has a 12-16 seconds runtime w/o rotor
compared to 5.8 secs with the rotor patches. It gets down to 5.05 secs with
the additional interrupt holdoff reductions.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Fix some bugs in mtd/jffs2 on 64bit platform.
The MEMGETBADBLOCK/MEMSETBADBLOCK ioctl are not listed in compat_ioctl.h.
And some variables in jffs2 are declared as uint32_t but used to hold
size_t values.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: David Woodhouse <dwmw2@infradead.org>
I have benchmarked this on an x86_64 NUMA system and see no significant
performance difference on kernbench. Tested on both x86_64 and powerpc.
The way we do file struct accounting is not very suitable for batched
freeing. For scalability reasons, file accounting was
constructor/destructor based. This meant that nr_files was decremented
only when the object was removed from the slab cache. This is susceptible
to slab fragmentation. With RCU based file structure, consequent batched
freeing and a test program like Serge's, we just speed this up and end up
with a very fragmented slab -
llm22:~ # cat /proc/sys/fs/file-nr
587730 0 758844
At the same time, I see only a 2000+ objects in filp cache. The following
patch I fixes this problem.
This patch changes the file counting by removing the filp_count_lock.
Instead we use a separate percpu counter, nr_files, for now and all
accesses to it are through get_nr_files() api. In the sysctl handler for
nr_files, we populate files_stat.nr_files before returning to user.
Counting files as an when they are created and destroyed (as opposed to
inside slab) allows us to correctly count open files with RCU.
Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
This patch adds new tunables for RCU queue and finished batches. There are
two types of controls - number of completed RCU updates invoked in a batch
(blimit) and monitoring for high rate of incoming RCUs on a cpu (qhimark,
qlowmark).
By default, the per-cpu batch limit is set to a small value. If the input
RCU rate exceeds the high watermark, we do two things - force quiescent
state on all cpus and set the batch limit of the CPU to INTMAX. Setting
batch limit to INTMAX forces all finished RCUs to be processed in one shot.
If we have more than INTMAX RCUs queued up, then we have bigger problems
anyway. Once the incoming queued RCUs fall below the low watermark, the
batch limit is set to the default.
Implement percpu_counter_sum(). This is a more accurate but slower version of
percpu_counter_read_positive().
We need this for Alex's speedup-ext3_statfs patch and for the nr_file
accounting fix. Otherwise these things would be too inaccurate on large CPU
counts.
Cc: Ravikiran G Thirumalai <kiran@scalex86.org>
Cc: Alex Tomas <alex@clusterfs.com>
They aren't used (nor even really usable) outside of pipe.c anyway
Systems with extemely large numbers of nodes or cpus need to kmalloc
structures larger than is currently supported. This patch increases the
maximum supported size for very large systems.
This patch should have no effect on current systems.
(akpm: why not just use alloc_pages() for sysfs_cpus?)
Signed-off-by: Jack Steiner <steiner@sgi.com>
include/linux/memory_hotplug.h:53: warning: 'struct page' declared inside parameter list
(akpm: I tossed in a couple more possibly-needed-sometime struct decls too)
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Also from Thomas Gleixner <tglx@linutronix.de>
Function next_timer_interrupt() got broken with a recent patch
6ba1b91213e81aa92b5cf7539f7d2a94ff54947c as sys_nanosleep() was moved to
hrtimer. This broke things as next_timer_interrupt() did not check hrtimer
tree for next event.
Function next_timer_interrupt() is needed with dyntick (CONFIG_NO_IDLE_HZ,
VST) implementations, as the system can be in idle when next hrtimer event
was supposed to happen. At least ARM and S390 currently use
next_timer_interrupt().
Add new PCI IDs for HFC-S PCI based ISDN TA 'Primux II S0' and 'Primux II S0'
from Gerdes AG
Signed-off-by: Martin Bachem <info@colognechip.com>
Signed-off-by: Karsten Keil <kkeil@suse.de>
The bitmaps associated with generation numbers for directory entries
are declared as an array of ints. On some platforms, this causes alignment
exceptions.
The following patch uses the standard bitmap declaration macros to
declare the bitmaps, fixing the problem.
Originally from Takashi Iwai.
Acked-by: Jeff Mahoney <jeffm@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
This patch adds mm->task_size to keep track of the task size of a given mm
and uses that to fix the powerpc vdso so that it uses the mm task size to
decide what pages to fault in instead of the current thread flags (which
broke when ptracing).
(akpm: I expect that mm_struct.task_size will become the way in which we
finally sort out the confusion between 32-bit processes and 32-bit mm's. It
may need tweaks, but at this stage this patch is powerpc-only.)
Allow sysadmin to disable all warnings about userland apps
making unaligned accesses by using:
# echo 1 > /proc/sys/kernel/ignore-unaligned-usertrap
Rather than having to use prctl on a process by process basis.
Default behaivour leaves the warnings enabled.
Signed-off-by: Jes Sorensen <jes@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
The nfnetlink_log infrastructure changes broke compatiblity of the LOG
targets. They currently use whatever log backend was registered first,
which means that if ipt_ULOG was loaded first, no messages will be printed
to the ring buffer anymore.
Restore compatiblity by using the old log functions by default and only use
the nf_log backend if the user explicitly said so.
I'm currently at the POSIX meeting and one thing covered was the
incompatibility of Linux's link() with the POSIX definition. The name.
Linux does not follow symlinks, POSIX requires it does.
Even if somebody thinks this is a good default behavior we cannot change this
because it would break the ABI. But the fact remains that some application
might want this behavior.
We have one chance to help implementing this without breaking the behavior.
For this we could use the new linkat interface which would need a new
flags parameter. If the new parameter is AT_SYMLINK_FOLLOW the new
behavior could be invoked.
I do not want to introduce such a patch now. But we could add the
parameter now, just don't use it. The patch below would do this. Can we
get this late patch applied before the release more or less fixes the
syscall API?
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Trivial comment fix for include/linux/serial_reg.h
This change reverts the 033b96fd30db52a710d97b06f87d16fc59fee0f1 commit
from Kay Sievers that removed the mount/umount uevents from the kernel.
Some older versions of HAL still depend on these events to detect when a
new device has been mounted. These events are not correctly emitted,
and are broken by design, and so, should not be relied upon by any
future program. Instead, the /proc/mounts file should be polled to
properly detect this kind of event.
A feature-removal-schedule.txt entry has been added, noting when this
interface will be removed from the kernel.
It's MMC_CMD_MASK not MMC_CMD_TYPE.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
The compat syscalls are added to sys_ni.c since they are not defined if the
above CONFIG options are off. Also, nfs would not build with CONFIG_SYSCTL
off.
Noticed by Arthur Othieno.
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Signed-off-by: Luke Yang <luke.adi@gmail.com>
Currently, acpi video options can only be set on kernel command line. That's
little inflexible; I'd like userland s2ram application that just works, and
modifying kernel command line according to whitelist is not fun. It is better
to just allow s2ram application to set video options just before suspend
(according to the whitelist).
This implements sysctl to allow setting suspend video options without reboot.
(akpm: Documentation updates for this new sysctl are pending..)
Signed-off-by: Pavel Machek <pavel@suse.cz>
Cc: "Brown, Len" <len.brown@intel.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Some allocations are restricted to a limited set of nodes (due to memory
policies or cpuset constraints). If the page allocator is not able to find
enough memory then that does not mean that overall system memory is low.
In particular going postal and more or less randomly shooting at processes
is not likely going to help the situation but may just lead to suicide (the
whole system coming down).
It is better to signal to the process that no memory exists given the
constraints that the process (or the configuration of the process) has
placed on the allocation behavior. The process may be killed but then the
sysadmin or developer can investigate the situation. The solution is
similar to what we do when running out of hugepages.
This patch adds a check before we kill processes. At that point
performance considerations do not matter much so we just scan the zonelist
and reconstruct a list of nodes. If the list of nodes does not contain all
online nodes then this is a constrained allocation and we should kill the
current process.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Andi Kleen <ak@muc.de>
This patch makes ata_for_each_sg() start with pad_sgent when
qc->n_elem is zero. Previously, ata_for_each_sg() unconditionally
started with qc->__sg, handling the first sg to fill_sg() routines
even when the entry was invalid. And while at it, unwind ?: in
ata_qc_next_sg() into if statement.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
This provides an interface for arch code to find out how many
nanoseconds are going to be added on to xtime by the next call to
do_timer. The value returned is a fixed-point number in 52.12 format
in nanoseconds. The reason for this format is that it gives the
full precision that the timekeeping code is using internally.
The motivation for this is to fix a problem that has arisen on 32-bit
powerpc in that the value returned by do_gettimeofday drifts apart
from xtime if NTP is being used. PowerPC is now using a lockless
do_gettimeofday based on reading the timebase register and performing
some simple arithmetic. (This method of getting the time is also
exported to userspace via the VDSO.) However, the factor and offset
it uses were calculated based on the nominal tick length and weren't
being adjusted when NTP varied the tick length.
Note that 64-bit powerpc has had the lockless do_gettimeofday for a
long time now. It also had an extremely hairy routine that got called
from the 32-bit compat routine for adjtimex, which adjusted the
factor and offset according to what it thought the timekeeping code
was going to do. Not only was this only called if a 32-bit task did
adjtimex (i.e. not if a 64-bit task did adjtimex), it was also
duplicating computations from kernel/timer.c and it wasn't clear that
it was (still) correct.
The simple solution is to ask the timekeeping code how long the
current jiffy will be on each timer interrupt, after calling
do_timer. If this jiffy will be a different length from the last one,
we then need to compute new values for the factor and offset used in
the lockless do_gettimeofday. In this way we can keep xtime and
do_gettimeofday in sync, even when NTP is varying the tick length.
Note that when adjtimex varies the tick length, it almost always
introduces the variation from the next tick on. The only case I could
see where adjtimex would vary the length of the current tick is when
an old-style adjtime adjustment is being cancelled. (It's not clear
to me why the adjustment has to be cancelled immediately rather than
from the next tick on.) Thus I don't see any real need for a hook in
adjtimex; the rare case of an old-style adjustment being cancelled can
be fixed up at the next tick.
Acked-by: john stultz <johnstul@us.ibm.com>
AMD SimNow!'s JIT doesn't like them at all in the guest. For distribution
installation it's easiest if it's a boot time option.
Also I moved the variable to a more appropiate place and make
it independent from sysctl
And marked __read_mostly which it is.
Signed-off-by: Andi Kleen <ak@suse.de>
For two macros the arguments were expanded twice, change them to inline
functions to avoid it.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
nf_hook() is supposed to call the netfilter hook and return control of the
packet back to the caller in case it may pass, the okfn is only used for
queueing.
When a packet matching an IPsec policy is SNATed so it doesn't match any
policy anymore it looses its xfrm bundle, which makes xfrm4_output_finish
crash because of a NULL pointer dereference.
This patch directs these packets to the original output path instead. Since
the packets have already passed the POST_ROUTING hook, but need to start at
the beginning of the original output path which includes another
POST_ROUTING invocation, a flag is added to the IPCB to indicate that the
packet was rerouted and doesn't need to pass the POST_ROUTING hook again.
1. The tracee can go from ptrace_stop() to do_signal_stop()
after __ptrace_unlink(p).
2. It is unsafe to __ptrace_unlink(p) while p->parent may wait
for tasklist_lock in ptrace_detach().
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Roland McGrath <roland@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
To find out if a packet needs to be handled by IPsec after SNAT, packets
are currently rerouted in POST_ROUTING and a new xfrm lookup is done. This
breaks SNAT of non-unicast packets to non-local addresses because the
packet is routed as incoming packet and no neighbour entry is bound to the
dst_entry. In general, it seems to be a bad idea to replace the dst_entry
after the packet was already sent to the output routine because its state
might not match what's expected.
This patch changes the xfrm lookup in POST_ROUTING to re-use the original
dst_entry without routing the packet again. This means no policy routing
can be used for transport mode transforms (which keep the original route)
when packets are SNATed to match the policy, but it looks like the best
we can do for now.
Revert commit d7102e95b7b9c00277562c29aad421d2d521c5f6:
[PATCH] sched: filter affine wakeups
Apparently caused more than 10% performance regression for aim7 benchmark.
The setup in use is 16-cpu HP rx8620, 64Gb of memory and 12 MSA1000s with 144
disks. Each disk is 72Gb with a single ext3 filesystem (courtesy of HP, who
supplied benchmark results).
The problem is, for aim7, the wake-up pattern is random, but it still needs
load balancing action in the wake-up path to achieve best performance. With
the above commit, lack of load balancing hurts that workload.
However, for workloads like database transaction processing, the requirement
is exactly opposite. In the wake up path, best performance is achieved with
absolutely zero load balancing. We simply wake up the process on the CPU that
it was previously run. Worst performance is obtained when we do load
balancing at wake up.
There isn't an easy way to auto detect the workload characteristics. Ingo's
earlier patch that detects idle CPU and decide whether to load balance or not
doesn't perform with aim7 either since all CPUs are busy (it causes even
bigger perf. regression).
Revert commit d7102e95b7b9c00277562c29aad421d2d521c5f6, which causes more
than 10% performance regression with aim7.
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
If 2 threads attached to the same process are blocking on different locks on
different files (maybe even on different servers) but have the same lock
arguments (i.e. same offset+length - actually quite common, since most
processes try to lock the entire file) then the first GRANTED call that wakes
one up will also wake the other.
Currently when the NLM_GRANTED callback comes in, lockd walks the list of
blocked locks in search of a match to the lock that the NLM server has
granted. Although it checks the lock pid, start and end, it fails to check
the filehandle and the server address.
By checking the filehandle and server IP address, we ensure that this only
happens if the locks truly are referencing the same file.
This patch reverts commit f93ea411b73594f7d144855fd34278bcf34a9afc:
[PATCH] jbd: split checkpoint lists
This broke journal_flush() for OCFS2, which is its method of being sure
that metadata is sent to disk for another node.
And two related commits 8d3c7fce2d20ecc3264c8d8c91ae3beacdeaed1b and
43c3e6f5abdf6acac9b90c86bf03f995bf7d3d92 with the subjects:
[PATCH] jbd: log_do_checkpoint fix
[PATCH] jbd: remove_transaction fix
These seem to be incremental bugfixes on the original patch and as such are
no longer needed.
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
Cc: Jan Kara <jack@ucw.cz>
