path: root/include/linux
2008-01-28[NET] sysctl: make sysctl_somaxconn per-namespacePavel Emelyanov
Just move the variable on the struct net and adjust its usage. Others sysctls from sys.net.core table are more difficult to virtualize (i.e. make them per-namespace), but I'll look at them as well a bit later. Signed-off-by: Pavel Emelyanov <xemul@oenvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETLINK]: Mark attribute construction exception unlikelyPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Only increment counter on first peek/recvHerbert Xu
The previous move of the the UDP inDatagrams counter caused each peek of the same packet to be counted separately. This may be undesirable. This patch fixes this by adding a bit to sk_buff to record whether this packet has already been seen through skb_recv_datagram. We then only increment the counter when the packet is seen for the first time. The only dodgy part is the fact that skb_recv_datagram doesn't have a good way of returning this new bit of information. So I've added a new function __skb_recv_datagram that does return this and made skb_recv_datagram a wrapper around it. The plan is to eventually replace all uses of skb_recv_datagram with this new function at which time it can be renamed its proper name. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Avoid repeated counting of checksum errors due to peekingHerbert Xu
Currently it is possible for two processes to peek on the same socket and end up incrementing the error counter twice for the same packet. This patch fixes it by making skb_kill_datagram return whether it succeeded in unlinking the packet and only incrementing the counter if it did. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[INET]: Merge sys.net.ipv4.ip_forward and sys.net.ipv4.conf.all.forwardingPavel Emelyanov
AFAIS these two entries should do the same thing - change the forwarding state on ipv4_devconf and on all the devices. I propose to merge the handlers together using ctl paths. The inet_forward_change() is static after this and I move it higher to be closer to other "propagation" helpers and to avoid diff making patches based on { and } matching :) i.e. - make them easier to read. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Remove the empty net_tablePavel Emelyanov
I have removed all the entries from this table (core_table, ipv4_table and tr_table), so now we can safely drop it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TR]: Use ctl paths to register net/token-ring/ tablePavel Emelyanov
The same thing for token-ring - use ctl paths and get rid of external references on the tr_table. Unfortunately, I couldn't split this patch into cleanup and use-the-paths parts. As a lame excuse I can say, that the cleanup is just moving the tr_table from one file to another - closet to a single variable, that this ctl table tunes. Since the source file becomes empty after the move, I remove it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_queue: move list_head/skb/id to struct nf_infoPatrick McHardy
Move common fields for queue management to struct nf_info and rename it to struct nf_queue_entry. The avoids one allocation/free per packet and simplifies the code a bit. Alternatively we could add some private room at the tail, but since all current users use identical structs this seems easier. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_queue: move queueing related functions/struct to seperate headerPatrick McHardy
2008-01-28[NETFILTER]: nf_queue: remove unused data pointerPatrick McHardy
Remove the data pointer from struct nf_queue_handler. It has never been used and is useless for the only handler that really matters, nfnetlink_queue, since the handler is shared between all instances. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_queue: make queue_handler constPatrick McHardy
2008-01-28[NETFILTER]: nf_ct_h323: remove ipv6 module dependencyPatrick McHardy
nf_conntrack_h323 needs ip6_route_output for the call forwarding filter. Add a ->route function to nf_afinfo and use that to avoid pulling in the ipv6 module. Fix the #ifdef for the IPv6 code while I'm at it - the IPv6 support is only needed when IPv6 conntrack is enabled. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: x_tables: add rateest matchPatrick McHardy
Add rate estimator match. The rate estimator match can match on estimated rates by the RATEEST target. It supports matching on absolute bps/pps values, comparing two rate estimators and matching on the difference between two rate estimators. This is what I use to route outgoing data connections from a FTP server over two lines based on the available bandwidth: # estimate outgoing rates iptables -t mangle -A POSTROUTING -o eth0 -j RATEEST --rateest-name eth0 \ --rateest-interval 250ms \ --rateest-ewma 0.5s iptables -t mangle -A POSTROUTING -o ppp0 -j RATEEST --rateest-name ppp0 \ --rateest-interval 250ms \ --rateest-ewma 0.5s # mark based on available bandwidth iptables -t mangle -A BALANCE -m state --state NEW \ -m helper --helper ftp \ -m rateest --rateest-delta \ --rateest1 eth0 \ --rateest-bps1 2.5mbit \ --rateest-gt \ --rateest2 ppp0 \ --rateest-bps2 2mbit \ -j CONNMARK --set-mark 0x1 iptables -t mangle -A BALANCE -m state --state NEW \ -m helper --helper ftp \ -m rateest --rateest-delta \ --rateest1 ppp0 \ --rateest-bps1 2mbit \ --rateest-gt \ --rateest2 eth0 \ --rateest-bps2 2.5mbit \ -j CONNMARK --set-mark 0x2 iptables -t mangle -A BALANCE -j CONNMARK --restore-mark Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: x_tables: add RATEEST targetPatrick McHardy
Add new rate estimator target (using gen_estimator). In combination with the rateest match (next patch) this can be used for load-based multipath routing. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: IPv6 capable xt_TOS v1 targetJan Engelhardt
Extends the xt_DSCP target by xt_TOS v1 to add support for selectively setting and flipping any bit in the IPv4 TOS and IPv6 Priority fields. (ipt_TOS and xt_DSCP only accepted a limited range of possible values.) Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: IPv6 capable xt_tos v1 matchJan Engelhardt
Extends the xt_dscp match by xt_tos v1 to add support for selectively matching any bit in the IPv4 TOS and IPv6 Priority fields. (ipt_tos and xt_dscp only accepted a limited range of possible values.) Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: ipt_addrtype: limit address type checking to an interfaceLaszlo Attila Toth
Addrtype match has a new revision (1), which lets address type checking limited to the interface the current packet belongs to. Either incoming or outgoing interface can be used depending on the current hook. In the FORWARD hook two maches should be used if both interfaces have to be checked. The new structure is ipt_addrtype_info_v1. Revision 0 lets older userspace programs use the match as earlier. ipt_addrtype_info is used. Signed-off-by: Laszlo Attila Toth <panther@balabit.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: merge ipt_owner/ip6t_owner in xt_ownerJan Engelhardt
xt_owner merges ipt_owner and ip6t_owner, and adds a flag to match on socket (non-)existence. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: x_tables: struct xt_table_info dietEric Dumazet
Instead of using a big array of NR_CPUS entries, we can compute the size needed at runtime, using nr_cpu_ids This should save some ram (especially on David's machines where NR_CPUS=4096 : 32 KB can be saved per table, and 64KB for dynamically allocated ones (because of slab/slub alignements) ) In particular, the 'bootstrap' tables are not any more static (in data section) but on stack as their size is now very small. This also should reduce the size used on stack in compat functions (get_info() declares an automatic variable, that could be bigger than kernel stack size for big NR_CPUS) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: x_tables: add TCPOPTSTRIP targetSven Schnelle
Signed-off-by: Sven Schnelle <svens@bitebene.org> Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28sysctl: Infrastructure for per namespace sysctlsEric W. Biederman
This patch implements the basic infrastructure for per namespace sysctls. A list of lists of sysctl headers is added, allowing each namespace to have it's own list of sysctl headers. Each list of sysctl headers has a lookup function to find the first sysctl header in the list, allowing the lists to have a per namespace instance. register_sysct_root is added to tell sysctl.c about additional lists of sysctl_headers. As all of the users are expected to be in kernel no unregister function is provided. sysctl_head_next is updated to walk through the list of lists. __register_sysctl_paths is added to add a new sysctl table on a non-default sysctl list. The only intrusive part of this patch is propagating the information to decided which list of sysctls to use for sysctl_check_table. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Daniel Lezcano <dlezcano@fr.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28sysctl: Remember the ctl_table we passed to register_sysctl_pathsEric W. Biederman
By doing this we allow users of register_sysctl_paths that build and dynamically allocate their ctl_table to be simpler. This allows them to just remember the ctl_table_header returned from register_sysctl_paths from which they can now find the ctl_table array they need to free. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Daniel Lezcano <dlezcano@fr.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28sysctl: Add register_sysctl_paths functionEric W. Biederman
There are a number of modules that register a sysctl table somewhere deeply nested in the sysctl hierarchy, such as fs/nfs, fs/xfs, dev/cdrom, etc. They all specify several dummy ctl_tables for the path name. This patch implements register_sysctl_path that takes an additional path name, and makes up dummy sysctl nodes for each component. This patch was originally written by Olaf Kirch and brought to my attention and reworked some by Olaf Hering. I have changed a few additional things so the bugs are mine. After converting all of the easy callers Olaf Hering observed allyesconfig ARCH=i386, the patch reduces the final binary size by 9369 bytes. .text +897 .data -7008 text data bss dec hex filename 26959310 4045899 4718592 35723801 2211a19 ../vmlinux-vanilla 26960207 4038891 4718592 35717690 221023a ../O-allyesconfig/vmlinux So this change is both a space savings and a code simplification. CC: Olaf Kirch <okir@suse.de> CC: Olaf Hering <olaf@aepfle.de> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Daniel Lezcano <dlezcano@fr.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Convert old checksum helper namesPatrick McHardy
Kill the defines again, convert to the new checksum helper names and remove the dependency of NET_ACT_NAT on NETFILTER. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Move netfilter checksum helpers to net/core/utils.cPatrick McHardy
This allows to get rid of the CONFIG_NETFILTER dependency of NET_ACT_NAT. This patch redefines the old names to keep the noise low, the next patch converts all users. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Integrate state transitions for passive-closeGerrit Renker
This adds the necessary state transitions for the two forms of passive-close * PASSIVE_CLOSE - which is entered when a host receives a Close; * PASSIVE_CLOSEREQ - which is entered when a client receives a CloseReq. Here is a detailed account of what the patch does in each state. 1) Receiving CloseReq The pseudo-code in 8.5 says: Step 13: Process CloseReq If P.type == CloseReq and S.state < CLOSEREQ, Generate Close S.state := CLOSING Set CLOSING timer. This means we need to address what to do in CLOSED, LISTEN, REQUEST, RESPOND, PARTOPEN, and OPEN. * CLOSED: silently ignore - it may be a late or duplicate CloseReq; * LISTEN/RESPOND: will not appear, since Step 7 is performed first (we know we are the client); * REQUEST: perform Step 13 directly (no need to enqueue packet); * OPEN/PARTOPEN: enter PASSIVE_CLOSEREQ so that the application has a chance to process unread data. When already in PASSIVE_CLOSEREQ, no second CloseReq is enqueued. In any other state, the CloseReq is ignored. I think that this offers some robustness against rare and pathological cases: e.g. a simultaneous close where the client sends a Close and the server a CloseReq. The client will then be retransmitting its Close until it gets the Reset, so ignoring the CloseReq while in state CLOSING is sane. 2) Receiving Close The code below from 8.5 is unconditional. Step 14: Process Close If P.type == Close, Generate Reset(Closed) Tear down connection Drop packet and return Thus we need to consider all states: * CLOSED: silently ignore, since this can happen when a retransmitted or late Close arrives; * LISTEN: dccp_rcv_state_process() will generate a Reset ("No Connection"); * REQUEST: perform Step 14 directly (no need to enqueue packet); * RESPOND: dccp_check_req() will generate a Reset ("Packet Error") -- left it at that; * OPEN/PARTOPEN: enter PASSIVE_CLOSE so that application has a chance to process unread data; * CLOSEREQ: server performed active-close -- perform Step 14; * CLOSING: simultaneous-close: use a tie-breaker to avoid message ping-pong (see comment); * PASSIVE_CLOSEREQ: ignore - the peer has a bug (sending first a CloseReq and now a Close); * TIMEWAIT: packet is ignored. Note that the condition of receiving a packet in state CLOSED here is different from the condition "there is no socket for such a connection": the socket still exists, but its state indicates it is unusable. Last, dccp_finish_passive_close sets either DCCP_CLOSED or DCCP_CLOSING = TCP_CLOSING, so that sk_stream_wait_close() will wait for the final Reset (which will trigger CLOSING => CLOSED). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Dedicated auxiliary states to support passive-closeGerrit Renker
This adds two auxiliary states to deal with passive closes: * PASSIVE_CLOSE (reached from OPEN via reception of Close) and * PASSIVE_CLOSEREQ (reached from OPEN via reception of CloseReq) as internal intermediate states. These states are used to allow a receiver to process unread data before acknowledging the received connection-termination-request (the Close/CloseReq). Without such support, it will happen that passively-closed sockets enter CLOSED state while there is still unprocessed data in the queue; leading to unexpected and erratic API behaviour. PASSIVE_CLOSE has been mapped into TCPF_CLOSE_WAIT, so that the code will seamlessly work with inet_accept() (which tests for this state). The state names are thanks to Arnaldo, who suggested this naming scheme following an earlier revision of this patch. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: Add RFC4214 supportFred L. Templin
This patch includes support for the Intra-Site Automatic Tunnel Addressing Protocol (ISATAP) per RFC4214. It uses the SIT module, and is configured using extensions to the "iproute2" utility. The diffs are specific to the Linux 2.6.24-rc2 kernel distribution. This version includes the diff for ./include/linux/if.h which was missing in the v2.4 submission and is needed to make the patch compile. The patch has been installed, compiled and tested in a clean 2.6.24-rc2 kernel build area. Signed-off-by: Fred L. Templin <fred.l.templin@boeing.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Name magic constants in sock_wake_async()Pavel Emelyanov
The sock_wake_async() performs a bit different actions depending on "how" argument. Unfortunately this argument ony has numerical magic values. I propose to give names to their constants to help people reading this function callers understand what's going on without looking into this function all the time. I suppose this is 2.6.25 material, but if it's not (or the naming seems poor/bad/awful), I can rework it against the current net-2.6 tree. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PCOUNTER] Fix build error without CONFIG_SMPIlpo Järvinen
I keep getting this build error and couldn't find anyone fixing it in archives. ...Maybe all net developers except me build just SMP kernels :-). In file included from include/net/sock.h:50, from ipc/mqueue.c:35: include/linux/pcounter.h: In function 'pcounter_add': include/linux/pcounter.h:87: error: 'struct pcounter' has no member named 'value' make[1]: *** [ipc/mqueue.o] Error 1 make: *** [ipc] Error 2 Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Make PARTOPEN an autonomous stateGerrit Renker
This decouples PARTOPEN from TCP-specific stream-states. It thus addresses the FIXME. The code has been checked with regard to dependency on PARTOPEN and FIN_WAIT1 states (to which PARTOPEN previously was mapped): there is no difference, as PARTOPEN is always referred to directly (i.e. not via the mapping to TCP state). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[LIB]: Introduce struct pcounterArnaldo Carvalho de Melo
This just generalises what was introduced by Eric Dumazet for the struct proto inuse field in 286ab3d46058840d68e5d7d52e316c1f7e98c59f: [NET]: Define infrastructure to keep 'inuse' changes in an efficent SMP/NUMA way. Please look at the comment in there to see the rationale. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: adding 802.11n definitions in ieee80211.hRon Rindjunsky
This patch adds several structs and definitions to ieee80211.h to support 802.11n draft specifications. As 802.11n depends on and extends the 802.11e standard in several issues, there are also several definitions that belong to 802.11e. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Consolidate net namespace related proc files creation.Denis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Make rtnetlink infrastructure network namespace aware (v3)Denis V. Lunev
After this patch none of the netlink callback support anything except the initial network namespace but the rtnetlink infrastructure now handles multiple network namespaces. Changes from v2: - IPv6 addrlabel processing Changes from v1: - no need for special rtnl_unlock handling - fixed IPv6 ndisc Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28ieee80211: Add IEEE80211_MAX_FRAME_LEN to linux/ieee80211.hMichael Wu
This patch adds IEEE80211_MAX_FRAME_LEN which is useful for drivers trying to determine how much to allocate for their RX buffers. It also updates the comment on IEEE80211_MAX_DATA_LEN based on revisions in 802.11e. IEEE80211_MAX_FRAG_THRESHOLD and IEEE80211_MAX_RTS_THRESHOLD are also revised due to the new maximum frame size. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETPOLL]: Don't need rx_flags.Stephen Hemminger
The rx_flags variable is redundant. Turning rx on/off is done via setting the rx_np pointer. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETPOLL]: no need to store local_macStephen Hemminger
The local_mac is managed by the network device, no need to keep a spare copy and all the management problems that could cause. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CAN]: Add missing Kbuild entriesOliver Hartkopp
This patch adds the missing Kbuild entries and the missing Kbuild file in include/linux/can for the CAN subsystem. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CAN]: Fix plain integer definitions in userspace header.Oliver Hartkopp
This patch fixes the use of plain integers instead of __u32 in a struct that is visible from kernel space and user space. Thanks to Sam Ravnborg for pointing out the wrong plain int usage. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CAN]: Add broadcast manager (bcm) protocolOliver Hartkopp
This patch adds the CAN broadcast manager (bcm) protocol. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CAN]: Add raw protocolOliver Hartkopp
This patch adds the CAN raw protocol. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CAN]: Add PF_CAN core moduleOliver Hartkopp
This patch adds the CAN core functionality but no protocols or drivers. No protocol implementations are included here. They come as separate patches. Protocol numbers are already in include/linux/can.h. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CAN]: Allocate protocol numbers for PF_CANOliver Hartkopp
This patch adds a protocol/address family number, ARP hardware type, ethernet packet type, and a line discipline number for the SocketCAN implementation. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Rewrite SACK block processing & sack_recv_cache useIlpo Järvinen
Key points of this patch are: - In case new SACK information is advance only type, no skb processing below previously discovered highest point is done - Optimize cases below highest point too since there's no need to always go up to highest point (which is very likely still present in that SACK), this is not entirely true though because I'm dropping the fastpath_skb_hint which could previously optimize those cases even better. Whether that's significant, I'm not too sure. Currently it will provide skipping by walking. Combined with RB-tree, all skipping would become fast too regardless of window size (can be done incrementally later). Previously a number of cases in TCP SACK processing fails to take advantage of costly stored information in sack_recv_cache, most importantly, expected events such as cumulative ACK and new hole ACKs. Processing on such ACKs result in rather long walks building up latencies (which easily gets nasty when window is huge). Those latencies are often completely unnecessary compared with the amount of _new_ information received, usually for cumulative ACK there's no new information at all, yet TCP walks whole queue unnecessary potentially taking a number of costly cache misses on the way, etc.! Since the inclusion of highest_sack, there's a lot information that is very likely redundant (SACK fastpath hint stuff, fackets_out, highest_sack), though there's no ultimate guarantee that they'll remain the same whole the time (in all unearthly scenarios). Take advantage of this knowledge here and drop fastpath hint and use direct access to highest SACKed skb as a replacement. Effectively "special cased" fastpath is dropped. This change adds some complexity to introduce better coveraged "fastpath", though the added complexity should make TCP behave more cache friendly. The current ACK's SACK blocks are compared against each cached block individially and only ranges that are new are then scanned by the high constant walk. For other parts of write queue, even when in previously known part of the SACK blocks, a faster skip function is used (if necessary at all). In addition, whenever possible, TCP fast-forwards to highest_sack skb that was made available by an earlier patch. In typical case, no other things but this fast-forward and mandatory markings after that occur making the access pattern quite similar to the former fastpath "special case". DSACKs are special case that must always be walked. The local to recv_sack_cache copying could be more intelligent w.r.t DSACKs which are likely to be there only once but that is left to a separate patch. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Earlier SACK block verification & simplify access to themIlpo Järvinen
2008-01-28[TCP]: Convert highest_sack to sk_buff to allow direct accessIlpo Järvinen
It is going to replace the sack fastpath hint quite soon... :-) Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6] ADDRCONF: Support RFC3484 configurable address selection policy table.YOSHIFUJI Hideaki
Policy table is implemented as an RCU linear list since we do not expect large list nor frequent updates. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Splice receive support.Jens Axboe
Support for network splice receive. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
